--- ray/src/rt/ambient.c 1992/11/03 21:29:52 2.14
+++ ray/src/rt/ambient.c 2003/02/22 02:07:28 2.47
@@ -1,34 +1,83 @@
-/* Copyright (c) 1992 Regents of the University of California */
#ifndef lint
-static char SCCSid[] = "$SunId$ LBL";
+static const char RCSid[] = "$Id: ambient.c,v 2.47 2003/02/22 02:07:28 greg Exp $";
#endif
* ambient.c - routines dealing with ambient (inter-reflected) component.
- * 5/9/86
+ * Declarations of external symbols in ambient.h
+ * The Radiance Software License, Version 1.0
+ * Copyright (c) 1990 - 2002 The Regents of the University of California,
+ * through Lawrence Berkeley National Laboratory. All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions
+ * are met:
+ * 1. Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided with the
+ * distribution.
+ * 3. The end-user documentation included with the redistribution,
+ * if any, must include the following acknowledgment:
+ * "This product includes Radiance software
+ * (http://radsite.lbl.gov/)
+ * developed by the Lawrence Berkeley National Laboratory
+ * (http://www.lbl.gov/)."
+ * Alternately, this acknowledgment may appear in the software itself,
+ * if and wherever such third-party acknowledgments normally appear.
+ * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
+ * and "The Regents of the University of California" must
+ * not be used to endorse or promote products derived from this
+ * software without prior written permission. For written
+ * permission, please contact radiance@radsite.lbl.gov.
+ * 5. Products derived from this software may not be called "Radiance",
+ * nor may "Radiance" appear in their name, without prior written
+ * permission of Lawrence Berkeley National Laboratory.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
+ * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
+ * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * This software consists of voluntary contributions made by many
+ * individuals on behalf of Lawrence Berkeley National Laboratory. For more
+ * information on Lawrence Berkeley National Laboratory, please see
#include "ray.h"
-#include "octree.h"
#include "otypes.h"
#include "ambient.h"
#include "random.h"
-#define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */
+#ifndef OCTSCALE
+#define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */
+#endif
-typedef struct ambtree {
- AMBVAL *alist; /* ambient value list */
- struct ambtree *kid; /* 8 child nodes */
-} AMBTREE; /* ambient octree */
+extern char *shm_boundary; /* memory sharing boundary */
-extern CUBE thescene; /* contains space boundaries */
#define MAXASET 511 /* maximum number of elements in ambient set */
OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
@@ -38,69 +87,192 @@ double minarad; /* minimum ambient radius */
static AMBTREE atrunk; /* our ambient trunk node */
static FILE *ambfp = NULL; /* ambient file pointer */
+static int nunflshed = 0; /* number of unflushed ambient values */
-#define AMBFLUSH (BUFSIZ/AMBVALSIZ)
+#ifndef SORT_THRESH
+#ifdef BIGMEM
+#define SORT_THRESH ((9L<<20)/sizeof(AMBVAL))
+#else
+#define SORT_THRESH ((3L<<20)/sizeof(AMBVAL))
+#endif
+#endif
+#ifndef SORT_INTVL
+#define SORT_INTVL (SORT_THRESH<<1)
+#endif
+#ifndef MAX_SORT_INTVL
+#define MAX_SORT_INTVL (SORT_INTVL<<6)
+#endif
-#define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL))
+static double avsum = 0.; /* computed ambient value sum (log) */
+static unsigned int navsum = 0; /* number of values in avsum */
+static unsigned int nambvals = 0; /* total number of indirect values */
+static unsigned int nambshare = 0; /* number of values from file */
+static unsigned long ambclock = 0; /* ambient access clock */
+static unsigned long lastsort = 0; /* time of last value sort */
+static long sortintvl = SORT_INTVL; /* time until next sort */
+static FILE *ambinp = NULL; /* auxiliary file for input */
+static long lastpos = -1; /* last flush position */
-#define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE))
+#define MAXACLOCK (1L<<30) /* clock turnover value */
+ * Track access times unless we are sharing ambient values
+ * through memory on a multiprocessor, when we want to avoid
+ * claiming our own memory (copy on write). Go ahead anyway
+ * if more than two thirds of our values are unshared.
+ * Compile with -Dtracktime=0 to turn this code off.
+#ifndef tracktime
+#define tracktime (shm_boundary == NULL || nambvals > 3*nambshare)
+#endif
-extern long ftell(), lseek();
-static int initambfile(), avsave(), avinsert(), ambsync();
+#define AMBFLUSH (BUFSIZ/AMBVALSIZ)
+#define newambval() (AMBVAL *)malloc(sizeof(AMBVAL))
+#define freeav(av) free((void *)av);
+static void initambfile(), avsave(), avinsert(), sortambvals(), unloadatree();
+static int avlmemi();
+static AMBVAL *avstore();
+#ifdef F_SETLKW
+static void aflock();
+#endif
+void
setambres(ar) /* set ambient resolution */
int ar;
+ ambres = ar < 0 ? 0 : ar; /* may be done already */
/* set min & max radii */
if (ar <= 0) {
- minarad = 0.0;
+ minarad = 0;
maxarad = thescene.cusize / 2.0;
} else {
minarad = thescene.cusize / ar;
- maxarad = 16.0 * minarad; /* heuristic */
+ maxarad = 64 * minarad; /* heuristic */
if (maxarad > thescene.cusize / 2.0)
- if (maxarad <= FTINY)
- maxarad = .001;
+ if (minarad <= FTINY)
+ minarad = 10*FTINY;
+ if (maxarad <= minarad)
-setambient(afile) /* initialize calculation */
-char *afile;
+void
+setambacc(newa) /* set ambient accuracy */
+double newa;
- long headlen;
+ double ambdiff;
+ if (newa < 0.0)
+ newa = 0.0;
+ ambdiff = fabs(newa - ambacc);
+ if (ambdiff >= .01 && (ambacc = newa) > FTINY && nambvals > 0)
+ sortambvals(1); /* rebuild tree */
+void
+setambient() /* initialize calculation */
+ int readonly = 0;
+ long pos, flen;
AMBVAL amb;
+ /* make sure we're fresh */
+ ambdone();
/* init ambient limits */
setambres(ambres);
+ setambacc(ambacc);
+ if (ambfile == NULL || !ambfile[0])
+ return;
+ if (ambacc <= FTINY) {
+ sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened",
+ ambfile);
+ error(WARNING, errmsg);
+ return;
/* open ambient file */
- if (afile != NULL)
- if ((ambfp = fopen(afile, "r+")) != NULL) {
- initambfile(0);
- headlen = ftell(ambfp);
- while (readambval(&amb, ambfp))
- avinsert(&amb, &atrunk, thescene.cuorg,
- thescene.cusize);
- /* align */
- fseek(ambfp, -((ftell(ambfp)-headlen)%AMBVALSIZ), 1);
- } else if ((ambfp = fopen(afile, "w+")) != NULL)
- initambfile(1);
- else {
- sprintf(errmsg, "cannot open ambient file \"%s\"",
- afile);
- error(SYSTEM, errmsg);
+ if ((ambfp = fopen(ambfile, "r+")) == NULL)
+ readonly = (ambfp = fopen(ambfile, "r")) != NULL;
+ if (ambfp != NULL) {
+ initambfile(0); /* file exists */
+ pos = ftell(ambfp);
+ while (readambval(&amb, ambfp))
+ avinsert(avstore(&amb));
+ nambshare = nambvals; /* share loaded values */
+ if (readonly) {
+ sprintf(errmsg,
+ "loaded %u values from read-only ambient file",
+ nambvals);
+ fclose(ambfp); /* close file so no writes */
+ ambfp = NULL;
+ return; /* avoid ambsync() */
+ /* align file pointer */
+ pos += (long)nambvals*AMBVALSIZ;
+ flen = lseek(fileno(ambfp), (off_t)0L, 2);
+ if (flen != pos) {
+ sprintf(errmsg,
+ "ignoring last %ld values in ambient file (corrupted)",
+ (flen - pos)/AMBVALSIZ);
+ fseek(ambfp, pos, 0);
+ ftruncate(fileno(ambfp), (off_t)pos);
+ } else if ((ambfp = fopen(ambfile, "w+")) != NULL) {
+ initambfile(1); /* else create new file */
+ } else {
+ sprintf(errmsg, "cannot open ambient file \"%s\"", ambfile);
+ error(SYSTEM, errmsg);
+ nunflshed++; /* lie */
+ ambsync();
+void
+ambdone() /* close ambient file and free memory */
+ if (ambfp != NULL) { /* close ambient file */
+ ambsync();
+ fclose(ambfp);
+ ambfp = NULL;
+ if (ambinp != NULL) {
+ fclose(ambinp);
+ ambinp = NULL;
+ lastpos = -1;
+ /* free ambient tree */
+ unloadatree(&atrunk, free);
+ /* reset state variables */
+ avsum = 0.;
+ navsum = 0;
+ nambvals = 0;
+ nambshare = 0;
+ ambclock = 0;
+ lastsort = 0;
+ sortintvl = SORT_INTVL;
+void
ambnotify(obj) /* record new modifier */
OBJECT obj;
static int hitlimit = 0;
- register OBJREC *o = objptr(obj);
+ register OBJREC *o;
register char **amblp;
+ if (obj == OVOID) { /* starting over */
+ ambset[0] = 0;
+ hitlimit = 0;
+ return;
+ o = objptr(obj);
if (hitlimit || !ismodifier(o->otype))
return;
for (amblp = amblist; *amblp != NULL; amblp++)
@@ -116,12 +288,14 @@ OBJECT obj;
-ambient(acol, r) /* compute ambient component for ray */
+void
+ambient(acol, r, nrm) /* compute ambient component for ray */
COLOR acol;
register RAY *r;
+FVECT nrm;
static int rdepth = 0; /* ambient recursion */
- double d;
+ double d, l;
if (ambdiv <= 0) /* no ambient calculation */
goto dumbamb;
@@ -137,31 +311,48 @@ register RAY *r;
rdepth++;
d = doambient(acol, r, r->rweight, NULL, NULL);
rdepth--;
- if (d == 0.0)
+ if (d <= FTINY)
goto dumbamb;
return;
+ if (tracktime) /* sort to minimize thrashing */
+ sortambvals(0);
/* get ambient value */
setcolor(acol, 0.0, 0.0, 0.0);
- d = sumambient(acol, r, rdepth,
+ d = sumambient(acol, r, nrm, rdepth,
&atrunk, thescene.cuorg, thescene.cusize);
- if (d > FTINY)
+ if (d > FTINY) {
scalecolor(acol, 1.0/d);
- else {
- d = makeambient(acol, r, rdepth++);
- rdepth--;
+ return;
+ rdepth++; /* need to cache new value */
+ d = makeambient(acol, r, nrm, rdepth-1);
+ rdepth--;
if (d > FTINY)
return;
dumbamb: /* return global value */
copycolor(acol, ambval);
+ if (ambvwt <= 0 | navsum == 0)
+ return;
+ l = bright(ambval); /* average in computations */
+ if (l > FTINY) {
+ d = (log(l)*(double)ambvwt + avsum) /
+ (double)(ambvwt + navsum);
+ d = exp(d) / l;
+ scalecolor(acol, d); /* apply color of ambval */
+ } else {
+ d = exp( avsum / (double)navsum );
+ setcolor(acol, d, d, d); /* neutral color */
double
-sumambient(acol, r, al, at, c0, s) /* get interpolated ambient value */
+sumambient(acol, r, rn, al, at, c0, s) /* get interpolated ambient value */
COLOR acol;
register RAY *r;
+FVECT rn;
int al;
AMBTREE *at;
FVECT c0;
@@ -173,29 +364,46 @@ double s;
int i;
register int j;
register AMBVAL *av;
- /* do this node */
wsum = 0.0;
+ /* do this node */
for (av = at->alist; av != NULL; av = av->next) {
+ double rn_dot = -2.0;
+ if (tracktime)
+ av->latick = ambclock;
* Ambient level test.
- if (av->lvl > al || av->weight < r->rweight-FTINY)
+ if (av->lvl > al) /* list sorted, so this works */
+ break;
+ if (av->weight < r->rweight-FTINY)
continue;
* Ambient radius test.
- e1 = 0.0;
- for (j = 0; j < 3; j++) {
- d = av->pos[j] - r->rop[j];
- e1 += d * d;
+ d = av->pos[0] - r->rop[0];
+ e1 = d * d;
+ d = av->pos[1] - r->rop[1];
+ e1 += d * d;
+ d = av->pos[2] - r->rop[2];
+ e1 += d * d;
e1 /= av->rad * av->rad;
if (e1 > ambacc*ambacc*1.21)
continue;
- * Normal direction test.
+ * Direction test using closest normal.
- e2 = (1.0 - DOT(av->dir, r->ron)) * r->rweight;
+ d = DOT(av->dir, r->ron);
+ if (rn != r->ron) {
+ rn_dot = DOT(av->dir, rn);
+ if (rn_dot > 1.0-FTINY)
+ rn_dot = 1.0-FTINY;
+ if (rn_dot >= d-FTINY) {
+ d = rn_dot;
+ rn_dot = -2.0;
+ e2 = (1.0 - d) * r->rweight;
if (e2 < 0.0) e2 = 0.0;
if (e1 + e2 > ambacc*ambacc*1.21)
continue;
@@ -211,16 +419,24 @@ double s;
* Jittering final test reduces image artifacts.
- wt = sqrt(e1) + sqrt(e2);
- wt *= .9 + .2*urand(9015+samplendx);
- if (wt > ambacc)
+ e1 = sqrt(e1);
+ e2 = sqrt(e2);
+ wt = e1 + e2;
+ if (wt > ambacc*(.9+.2*urand(9015+samplendx)))
continue;
+ * Recompute directional error using perturbed normal
+ if (rn_dot > 0.0) {
+ e2 = sqrt((1.0 - rn_dot)*r->rweight);
+ wt = e1 + e2;
if (wt <= 1e-3)
wt = 1e3;
else
wt = 1.0 / wt;
wsum += wt;
- extambient(ct, av, r->rop, r->ron);
+ extambient(ct, av, r->rop, rn);
scalecolor(ct, wt);
addcolor(acol, ct);
@@ -239,27 +455,28 @@ double s;
break;
if (j == 3)
- wsum += sumambient(acol, r, al, at->kid+i, ck0, s);
+ wsum += sumambient(acol, r, rn, al, at->kid+i, ck0, s);
return(wsum);
double
-makeambient(acol, r, al) /* make a new ambient value */
+makeambient(acol, r, rn, al) /* make a new ambient value */
COLOR acol;
register RAY *r;
+FVECT rn;
int al;
AMBVAL amb;
FVECT gp, gd;
/* compute weight */
amb.weight = pow(AVGREFL, (double)al);
- if (r->rweight < 0.2*amb.weight) /* heuristic */
+ if (r->rweight < 0.1*amb.weight) /* heuristic */
amb.weight = r->rweight;
/* compute ambient */
amb.rad = doambient(acol, r, amb.weight, gp, gd);
- if (amb.rad == 0.0)
+ if (amb.rad <= FTINY)
return(0.0);
/* store it */
VCOPY(amb.pos, r->rop);
@@ -270,16 +487,19 @@ int al;
VCOPY(amb.gdir, gd);
/* insert into tree */
avsave(&amb); /* and save to file */
+ if (rn != r->ron)
+ extambient(acol, &amb, r->rop, rn); /* texture */
return(amb.rad);
+void
extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */
COLOR cr;
register AMBVAL *ap;
FVECT pv, nv;
- FVECT v1, v2;
+ FVECT v1;
register int i;
double d;
@@ -288,9 +508,8 @@ FVECT pv, nv;
for (i = 0; i < 3; i++)
d += ap->gpos[i]*(pv[i]-ap->pos[i]);
/* gradient due to rotation */
- VCOPY(v1, ap->dir);
- fcross(v2, v1, nv);
- d += DOT(ap->gdir, v2);
+ VCROSS(v1, ap->dir, nv);
+ d += DOT(ap->gdir, v1);
if (d <= 0.0) {
setcolor(cr, 0.0, 0.0, 0.0);
return;
@@ -300,79 +519,141 @@ FVECT pv, nv;
-static
+static void
initambfile(creat) /* initialize ambient file */
int creat;
- extern char *progname, *octname, VersionID[];
+ extern char *progname, *octname;
+ static char *mybuf = NULL;
+#ifdef F_SETLKW
+ aflock(creat ? F_WRLCK : F_RDLCK);
+#endif
#ifdef MSDOS
setmode(fileno(ambfp), O_BINARY);
#endif
- setbuf(ambfp, bmalloc(BUFSIZ));
+ if (mybuf == NULL)
+ mybuf = (char *)bmalloc(BUFSIZ+8);
+ setbuf(ambfp, mybuf);
if (creat) { /* new file */
- fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ",
+ newheader("RADIANCE", ambfp);
+ fprintf(ambfp, "%s -av %g %g %g -aw %d -ab %d -aa %g ",
progname, colval(ambval,RED),
colval(ambval,GRN), colval(ambval,BLU),
- ambounce, ambacc);
- fprintf(ambfp, "-ad %d -as %d -ar %d %s\n",
- ambdiv, ambssamp, ambres,
- octname==NULL ? "" : octname);
+ ambvwt, ambounce, ambacc);
+ fprintf(ambfp, "-ad %d -as %d -ar %d ",
+ ambdiv, ambssamp, ambres);
+ if (octname != NULL)
+ printargs(1, &octname, ambfp);
+ else
+ fputc('\n', ambfp);
fprintf(ambfp, "SOFTWARE= %s\n", VersionID);
+ fputnow(ambfp);
fputformat(AMBFMT, ambfp);
putc('\n', ambfp);
putambmagic(ambfp);
- fflush(ambfp);
-#ifndef NIX
- sync(); /* protect against NFS buffering */
-#endif
} else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp))
error(USER, "bad ambient file");
-static
+static void
avsave(av) /* insert and save an ambient value */
AMBVAL *av;
- static int nunflshed = 0;
- avinsert(av, &atrunk, thescene.cuorg, thescene.cusize);
+ avinsert(avstore(av));
if (ambfp == NULL)
return;
if (writambval(av, ambfp) < 0)
goto writerr;
- if (++nunflshed >= AMBFLUSH) {
+ if (++nunflshed >= AMBFLUSH)
if (ambsync() == EOF)
goto writerr;
- nunflshed = 0;
return;
writerr:
- error(SYSTEM, "error writing ambient file");
+ error(SYSTEM, "error writing to ambient file");
-static
-avinsert(aval, at, c0, s) /* insert ambient value in a tree */
-AMBVAL *aval;
-register AMBTREE *at;
-FVECT c0;
-double s;
+static AMBVAL *
+avstore(aval) /* allocate memory and store aval */
+register AMBVAL *aval;
+ register AMBVAL *av;
+ double d;
+ if ((av = newambval()) == NULL)
+ error(SYSTEM, "out of memory in avstore");
+ copystruct(av, aval);
+ av->next = NULL;
+ nambvals++;
+ d = bright(av->val);
+ if (d > FTINY) { /* add to log sum for averaging */
+ avsum += log(d);
+ navsum++;
+ return(av);
+#define ATALLOCSZ 512 /* #/8 trees to allocate at once */
+static AMBTREE *atfreelist = NULL; /* free ambient tree structures */
+static AMBTREE *
+newambtree() /* allocate 8 ambient tree structs */
+ register AMBTREE *atp, *upperlim;
+ if (atfreelist == NULL) { /* get more nodes */
+ atfreelist = (AMBTREE *)malloc(ATALLOCSZ*8*sizeof(AMBTREE));
+ return(NULL);
+ /* link new free list */
+ upperlim = atfreelist + 8*(ATALLOCSZ-1);
+ for (atp = atfreelist; atp < upperlim; atp += 8)
+ atp->kid = atp + 8;
+ atp->kid = NULL;
+ atp = atfreelist;
+ atfreelist = atp->kid;
+ bzero((char *)atp, 8*sizeof(AMBTREE));
+ return(atp);
+static void
+freeambtree(atp) /* free 8 ambient tree structs */
+AMBTREE *atp;
+ atp->kid = atfreelist;
+ atfreelist = atp;
+static void
+avinsert(av) /* insert ambient value in our tree */
+register AMBVAL *av;
+ register AMBTREE *at;
+ register AMBVAL *ap;
+ AMBVAL avh;
FVECT ck0;
+ double s;
int branch;
- register AMBVAL *av;
register int i;
- if ((av = newambval()) == NULL)
- goto memerr;
- copystruct(av, aval);
- VCOPY(ck0, c0);
+ if (av->rad <= FTINY)
+ error(CONSISTENCY, "zero ambient radius in avinsert");
+ at = &atrunk;
+ VCOPY(ck0, thescene.cuorg);
+ s = thescene.cusize;
while (s*(OCTSCALE/2) > av->rad*ambacc) {
if (at->kid == NULL)
if ((at->kid = newambtree()) == NULL)
- goto memerr;
+ error(SYSTEM, "out of memory in avinsert");
s *= 0.5;
branch = 0;
@@ -382,65 +663,281 @@ double s;
at = at->kid + branch;
- av->next = at->alist;
- at->alist = av;
- return;
-memerr:
- error(SYSTEM, "out of memory in avinsert");
+ avh.next = at->alist; /* order by increasing level */
+ for (ap = &avh; ap->next != NULL; ap = ap->next)
+ if (ap->next->lvl >= av->lvl)
+ break;
+ av->next = ap->next;
+ ap->next = av;
+ at->alist = avh.next;
-#ifdef NIX
+static void
+unloadatree(at, f) /* unload an ambient value tree */
+register AMBTREE *at;
+void (*f)();
+ register int i;
+ /* transfer values at this node */
+ for (av = at->alist; av != NULL; av = at->alist) {
+ at->alist = av->next;
+ (*f)(av);
+ if (at->kid == NULL)
+ return;
+ for (i = 0; i < 8; i++) /* transfer and free children */
+ unloadatree(at->kid+i, f);
+ freeambtree(at->kid);
+ at->kid = NULL;
-static
-ambsync() /* flush ambient file */
+static struct avl {
+ AMBVAL *p;
+ unsigned long t;
+} *avlist1; /* ambient value list with ticks */
+static AMBVAL **avlist2; /* memory positions for sorting */
+static int i_avlist; /* index for lists */
+static int
+av2list(av)
- return(fflush(ambfp));
+#ifdef DEBUG
+ if (i_avlist >= nambvals)
+ error(CONSISTENCY, "too many ambient values in av2list1");
+#endif
+ avlist1[i_avlist].p = avlist2[i_avlist] = av;
+ avlist1[i_avlist++].t = av->latick;
+static int
+alatcmp(av1, av2) /* compare ambient values for MRA */
+struct avl *av1, *av2;
+ register long lc = av2->t - av1->t;
+ return(lc<0 ? -1 : lc>0 ? 1 : 0);
+/* GW NOTE 2002/10/3:
+ * I used to compare AMBVAL pointers, but found that this was the
+ * cause of a serious consistency error with gcc, since the optimizer
+ * uses some dangerous trick in pointer subtraction that
+ * assumes pointers differ by exact struct size increments.
+static int
+aposcmp(avp1, avp2) /* compare ambient value positions */
+const void *avp1, *avp2;
+ register long diff = *(char * const *)avp1 - *(char * const *)avp2;
+ if (diff < 0)
+ return(-1);
+ return(diff > 0);
+#if 1
+static int
+avlmemi(avaddr) /* find list position from address */
+AMBVAL *avaddr;
+ register AMBVAL **avlpp;
+ avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2,
+ nambvals, sizeof(AMBVAL *), aposcmp);
+ if (avlpp == NULL)
+ error(CONSISTENCY, "address not found in avlmemi");
+ return(avlpp - avlist2);
#else
+#define avlmemi(avaddr) ((AMBVAL **)bsearch((char *)&avaddr,(char *)avlist2, \
+ nambvals,sizeof(AMBVAL *),aposcmp) - avlist2)
+#endif
-#include
-#include
-static
+static void
+sortambvals(always) /* resort ambient values */
+int always;
+ AMBTREE oldatrunk;
+ AMBVAL tav, *tap, *pnext;
+ register int i, j;
+ /* see if it's time yet */
+ if (!always && (ambclock++ < lastsort+sortintvl ||
+ nambvals < SORT_THRESH))
+ return;
+ * The idea here is to minimize memory thrashing
+ * in VM systems by improving reference locality.
+ * We do this by periodically sorting our stored ambient
+ * values in memory in order of most recently to least
+ * recently accessed. This ordering was chosen so that new
+ * ambient values (which tend to be less important) go into
+ * higher memory with the infrequently accessed values.
+ * Since we expect our values to need sorting less
+ * frequently as the process continues, we double our
+ * waiting interval after each call.
+ * This routine is also called by setambacc() with
+ * the "always" parameter set to 1 so that the ambient
+ * tree will be rebuilt with the new accuracy parameter.
+ if (tracktime) { /* allocate pointer arrays to sort */
+ avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *));
+ avlist1 = (struct avl *)malloc(nambvals*sizeof(struct avl));
+ } else {
+ avlist2 = NULL;
+ avlist1 = NULL;
+ if (avlist1 == NULL) { /* no time tracking -- rebuild tree? */
+ if (avlist2 != NULL)
+ free((void *)avlist2);
+ if (always) { /* rebuild without sorting */
+ copystruct(&oldatrunk, &atrunk);
+ atrunk.alist = NULL;
+ atrunk.kid = NULL;
+ unloadatree(&oldatrunk, avinsert);
+ } else { /* sort memory by last access time */
+ * Sorting memory is tricky because it isn't contiguous.
+ * We have to sort an array of pointers by MRA and also
+ * by memory position. We then copy values in "loops"
+ * to minimize memory hits. Nevertheless, we will visit
+ * everyone at least twice, and this is an expensive process
+ * when we're thrashing, which is when we need to do it.
+#ifdef DEBUG
+ sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...",
+ nambvals, ambclock);
+ eputs(errmsg);
+#endif
+ i_avlist = 0;
+ unloadatree(&atrunk, av2list); /* empty current tree */
+#ifdef DEBUG
+ if (i_avlist < nambvals)
+ error(CONSISTENCY, "missing ambient values in sortambvals");
+#endif
+ qsort((char *)avlist1, nambvals, sizeof(struct avl), alatcmp);
+ qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), aposcmp);
+ for (i = 0; i < nambvals; i++) {
+ if (avlist1[i].p == NULL)
+ continue;
+ tap = avlist2[i];
+ copystruct(&tav, tap);
+ for (j = i; (pnext = avlist1[j].p) != tap;
+ j = avlmemi(pnext)) {
+ copystruct(avlist2[j], pnext);
+ avinsert(avlist2[j]);
+ avlist1[j].p = NULL;
+ copystruct(avlist2[j], &tav);
+ free((void *)avlist1);
+ /* compute new sort interval */
+ sortintvl = ambclock - lastsort;
+ if (sortintvl >= MAX_SORT_INTVL/2)
+ sortintvl = MAX_SORT_INTVL;
+ else
+ sortintvl <<= 1; /* wait twice as long next */
+#ifdef DEBUG
+ eputs("done\n");
+#endif
+ if (ambclock >= MAXACLOCK)
+ ambclock = MAXACLOCK/2;
+ lastsort = ambclock;
+#ifdef F_SETLKW
+static void
+aflock(typ) /* lock/unlock ambient file */
+int typ;
+ static struct flock fls; /* static so initialized to zeroes */
+ fls.l_type = typ;
+ if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0)
+ error(SYSTEM, "cannot (un)lock ambient file");
+int
ambsync() /* synchronize ambient file */
- static FILE *ambinp = NULL;
- struct flock fls;
- struct stat sts;
-#define flen sts.st_size
+ long flen;
AMBVAL avs;
- long lastpos;
register int n;
+ if (nunflshed == 0)
+ return(0);
+ if (lastpos < 0) /* initializing (locked in initambfile) */
+ goto syncend;
/* gain exclusive access */
- fls.l_type = F_WRLCK;
- fls.l_whence = 0;
- fls.l_start = 0L;
- fls.l_len = 0L;
- if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0)
- error(SYSTEM, "cannot lock ambient file");
+ aflock(F_WRLCK);
/* see if file has grown */
- lastpos = lseek(fileno(ambfp), 0L, 1); /* get previous position */
- if (fstat(fileno(ambfp), &sts) < 0) /* get current length */
- error(SYSTEM, "cannot stat ambient file");
- if (n = (flen - lastpos)/AMBVALSIZ) { /* file has grown */
- if (ambinp == NULL) { /* use duplicate file */
+ if ((flen = lseek(fileno(ambfp), (off_t)0L, 2)) < 0)
+ goto seekerr;
+ if (n = flen - lastpos) { /* file has grown */
+ if (ambinp == NULL) { /* use duplicate filedes */
ambinp = fdopen(dup(fileno(ambfp)), "r");
if (ambinp == NULL)
error(SYSTEM, "fdopen failed in ambsync");
- while (n--) { /* load contributed values */
- readambval(&avs, ambinp);
- avinsert(&avs,&atrunk,thescene.cuorg,thescene.cusize);
- } /* moves shared file pointer */
- if (n = (flen - lastpos)%AMBVALSIZ) /* alignment */
- lseek(fileno(ambfp), flen-n, 0);
+ if (fseek(ambinp, lastpos, 0) < 0)
+ goto seekerr;
+ while (n >= AMBVALSIZ) { /* load contributed values */
+ if (!readambval(&avs, ambinp)) {
+ sprintf(errmsg,
+ "ambient file \"%s\" corrupted near character %ld",
+ ambfile, flen - n);
+ break;
+ avinsert(avstore(&avs));
+ n -= AMBVALSIZ;
+ /*** seek always as safety measure
+ if (n) ***/ /* alignment */
+ if (lseek(fileno(ambfp), (off_t)(flen-n), 0) < 0)
+ goto seekerr;
+#ifdef DEBUG
+ if (ambfp->_ptr - ambfp->_base != nunflshed*AMBVALSIZ) {
+ sprintf(errmsg, "ambient file buffer at %d rather than %d",
+ ambfp->_ptr - ambfp->_base,
+ nunflshed*AMBVALSIZ);
+ error(CONSISTENCY, errmsg);
+#endif
+syncend:
n = fflush(ambfp); /* calls write() at last */
- fls.l_type = F_UNLCK; /* release file */
- fcntl(fileno(ambfp), F_SETLKW, &fls);
+ if ((lastpos = lseek(fileno(ambfp), (off_t)0L, 1)) < 0)
+ goto seekerr;
+ aflock(F_UNLCK); /* release file */
+ nunflshed = 0;
return(n);
+seekerr:
+ error(SYSTEM, "seek failed in ambsync");
+#else
+int
+ambsync() /* flush ambient file */
+ return(0);
+ nunflshed = 0;
+ return(fflush(ambfp));
#endif
