--- ray/src/rt/ambient.c 1992/11/03 21:29:52 2.14 +++ ray/src/rt/ambient.c 1993/01/29 12:02:23 2.18 @@ -1,4 +1,4 @@ -/* Copyright (c) 1992 Regents of the University of California */ +/* Copyright (c) 1993 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -6,8 +6,6 @@ static char SCCSid[] = "$SunId$ LBL"; /* * ambient.c - routines dealing with ambient (inter-reflected) component. - * - * 5/9/86 */ #include "ray.h" @@ -38,6 +36,7 @@ double minarad; /* minimum ambient radius */ static AMBTREE atrunk; /* our ambient trunk node */ static FILE *ambfp = NULL; /* ambient file pointer */ +static int nunflshed = 0; /* number of unflushed ambient values */ #define AMBFLUSH (BUFSIZ/AMBVALSIZ) @@ -46,7 +45,7 @@ static FILE *ambfp = NULL; /* ambient file pointer */ #define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE)) extern long ftell(), lseek(); -static int initambfile(), avsave(), avinsert(), ambsync(); +static int initambfile(), avsave(), avinsert(); setambres(ar) /* set ambient resolution */ @@ -75,7 +74,7 @@ char *afile; /* init ambient limits */ setambres(ambres); /* open ambient file */ - if (afile != NULL) + if (afile != NULL) { if ((ambfp = fopen(afile, "r+")) != NULL) { initambfile(0); headlen = ftell(ambfp); @@ -91,6 +90,9 @@ char *afile; afile); error(SYSTEM, errmsg); } + nunflshed++; /* lie */ + ambsync(); + } } @@ -322,10 +324,6 @@ int creat; fputformat(AMBFMT, ambfp); putc('\n', ambfp); putambmagic(ambfp); - fflush(ambfp); -#ifndef NIX - sync(); /* protect against NFS buffering */ -#endif } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp)) error(USER, "bad ambient file"); } @@ -335,18 +333,14 @@ static avsave(av) /* insert and save an ambient value */ AMBVAL *av; { - static int nunflshed = 0; - avinsert(av, &atrunk, thescene.cuorg, thescene.cusize); if (ambfp == NULL) return; if (writambval(av, ambfp) < 0) goto writerr; - if (++nunflshed >= AMBFLUSH) { + if (++nunflshed >= AMBFLUSH) if (ambsync() == EOF) goto writerr; - nunflshed = 0; - } return; writerr: error(SYSTEM, "error writing ambient file"); @@ -390,29 +384,20 @@ memerr: } -#ifdef NIX +#ifdef F_SETLKW -static -ambsync() /* flush ambient file */ -{ - return(fflush(ambfp)); -} - -#else - -#include -#include - -static +int ambsync() /* synchronize ambient file */ { static FILE *ambinp = NULL; + static long lastpos = -1; struct flock fls; - struct stat sts; -#define flen sts.st_size + long flen; AMBVAL avs; - long lastpos; register int n; + + if (nunflshed == 0) + return(0); /* gain exclusive access */ fls.l_type = F_WRLCK; fls.l_whence = 0; @@ -420,27 +405,45 @@ ambsync() /* synchronize ambient file */ fls.l_len = 0L; if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0) error(SYSTEM, "cannot lock ambient file"); + if (lastpos < 0) /* initializing */ + goto syncend; /* see if file has grown */ - lastpos = lseek(fileno(ambfp), 0L, 1); /* get previous position */ - if (fstat(fileno(ambfp), &sts) < 0) /* get current length */ - error(SYSTEM, "cannot stat ambient file"); - if (n = (flen - lastpos)/AMBVALSIZ) { /* file has grown */ - if (ambinp == NULL) { /* use duplicate file */ + if ((flen = lseek(fileno(ambfp), 0L, 2)) < 0) + error(SYSTEM, "cannot seek on ambient file"); + if (n = flen - lastpos) { /* file has grown */ + if (ambinp == NULL) { /* use duplicate filedes */ ambinp = fdopen(dup(fileno(ambfp)), "r"); if (ambinp == NULL) error(SYSTEM, "fdopen failed in ambsync"); } - while (n--) { /* load contributed values */ + if (fseek(ambinp, lastpos, 0) < 0) + error(SYSTEM, "fseek failed in ambsync"); + while (n >= AMBVALSIZ) { /* load contributed values */ readambval(&avs, ambinp); avinsert(&avs,&atrunk,thescene.cuorg,thescene.cusize); - } /* moves shared file pointer */ - if (n = (flen - lastpos)%AMBVALSIZ) /* alignment */ + n -= AMBVALSIZ; + } + if (n) /* alignment */ lseek(fileno(ambfp), flen-n, 0); } +syncend: n = fflush(ambfp); /* calls write() at last */ + lastpos = lseek(fileno(ambfp), 0L, 1); fls.l_type = F_UNLCK; /* release file */ fcntl(fileno(ambfp), F_SETLKW, &fls); + nunflshed = 0; return(n); +} + +#else + +int +ambsync() /* flush ambient file */ +{ + if (nunflshed == 0) + return(0); + nunflshed = 0; + return(fflush(ambfp)); } #endif
