--- ray/src/rt/ambient.c 2021/02/19 22:05:46 2.110 +++ ray/src/rt/ambient.c 2024/11/06 20:16:58 2.124 @@ -1,4 +1,4 @@ -static const char RCSid[] = "$Id: ambient.c,v 2.110 2021/02/19 22:05:46 greg Exp $"; +static const char RCSid[] = "$Id: ambient.c,v 2.124 2024/11/06 20:16:58 greg Exp $"; /* * ambient.c - routines dealing with ambient (inter-reflected) component. * @@ -22,8 +22,6 @@ static const char RCSid[] = "$Id: ambient.c,v 2.110 20 #define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */ #endif -extern char *shm_boundary; /* memory sharing boundary */ - #ifndef MAXASET #define MAXASET 4095 /* maximum number of elements in ambient set */ #endif @@ -37,50 +35,21 @@ static AMBTREE atrunk; /* our ambient trunk node */ static FILE *ambfp = NULL; /* ambient file pointer */ static int nunflshed = 0; /* number of unflushed ambient values */ -#ifndef SORT_THRESH -#ifdef SMLMEM -#define SORT_THRESH ((16L<<20)/sizeof(AMBVAL)) -#else -#define SORT_THRESH ((64L<<20)/sizeof(AMBVAL)) -#endif -#endif -#ifndef SORT_INTVL -#define SORT_INTVL (SORT_THRESH<<1) -#endif -#ifndef MAX_SORT_INTVL -#define MAX_SORT_INTVL (SORT_INTVL<<6) -#endif - - static double avsum = 0.; /* computed ambient value sum (log) */ static unsigned int navsum = 0; /* number of values in avsum */ static unsigned int nambvals = 0; /* total number of indirect values */ static unsigned int nambshare = 0; /* number of values from file */ -static unsigned long ambclock = 0; /* ambient access clock */ -static unsigned long lastsort = 0; /* time of last value sort */ -static long sortintvl = SORT_INTVL; /* time until next sort */ static FILE *ambinp = NULL; /* auxiliary file for input */ static long lastpos = -1; /* last flush position */ -#define MAXACLOCK (1L<<30) /* clock turnover value */ - /* - * Track access times unless we are sharing ambient values - * through memory on a multiprocessor, when we want to avoid - * claiming our own memory (copy on write). Go ahead anyway - * if more than two thirds of our values are unshared. - * Compile with -Dtracktime=0 to turn this code off. - */ -#ifndef tracktime -#define tracktime (shm_boundary == NULL || nambvals > 3*nambshare) -#endif - #define AMBFLUSH (BUFSIZ/AMBVALSIZ) -#define newambval() (AMBVAL *)malloc(sizeof(AMBVAL)) +#define AVSIZE (sizeof(AMBVAL)-sizeof(SCOLOR)+sizeof(COLORV)*NCSAMP) +#define newambval() (AMBVAL *)malloc(AVSIZE) -#define tfunc(lwr, x, upr) (((x)-(lwr))/((upr)-(lwr))) +#define tfunc(x0, x, x1) (((x)-(x0))/((x1)-(x0))) -static void initambfile(int creat); +static void initambfile(int cre8); static void avsave(AMBVAL *av); static AMBVAL *avstore(AMBVAL *aval); static AMBTREE *newambtree(void); @@ -88,19 +57,16 @@ static void freeambtree(AMBTREE *atp); typedef void unloadtf_t(AMBVAL *); static unloadtf_t avinsert; -static unloadtf_t av2list; static unloadtf_t avfree; static void unloadatree(AMBTREE *at, unloadtf_t *f); -static int aposcmp(const void *avp1, const void *avp2); -static int avlmemi(AMBVAL *avaddr); -static void sortambvals(int always); +static void sortambvals(void); static int plugaleak(RAY *r, AMBVAL *ap, FVECT anorm, double ang); -static double sumambient(COLOR acol, RAY *r, FVECT rn, int al, +static double sumambient(SCOLOR acol, RAY *r, FVECT rn, int al, AMBTREE *at, FVECT c0, double s); -static int makeambient(COLOR acol, RAY *r, FVECT rn, int al); -static int extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv, +static int makeambient(SCOLOR acol, RAY *r, FVECT rn, int al); +static int extambient(SCOLOR cr, AMBVAL *ap, FVECT pv, FVECT nv, FVECT uvw[3]); #ifdef F_SETLKW @@ -142,7 +108,7 @@ setambacc( /* set ambient accuracy */ if (fabs(newa - olda) >= .05*(newa + olda)) { ambacc = newa; if (ambacc > FTINY && nambvals > 0) - sortambvals(1); /* rebuild tree */ + sortambvals(); /* rebuild tree */ } } @@ -229,9 +195,6 @@ ambdone(void) /* close ambient file and free memory navsum = 0; nambvals = 0; nambshare = 0; - ambclock = 0; - lastsort = 0; - sortintvl = SORT_INTVL; } @@ -267,13 +230,14 @@ ambnotify( /* record new modifier */ void multambient( /* compute ambient component & multiply by coef. */ - COLOR aval, + SCOLOR aval, RAY *r, FVECT nrm ) { + static double logAvgAbsorp = 1; static int rdepth = 0; /* ambient recursion */ - COLOR acol, caustic; + SCOLOR acol, caustic; int i, ok; double d, l; @@ -283,12 +247,18 @@ multambient( /* compute ambient component & multiply if (ambPmap(aval, r, rdepth)) return; + if (logAvgAbsorp > 0) /* exclude in -aw to avoid growth */ + logAvgAbsorp = log(1.-AVGREFL); + /* PMAP: Factor in specular-diffuse ambient (caustics) from photon * map, if enabled and ray is primary, else caustic is zero. Continue * with RADIANCE ambient calculation */ - copycolor(caustic, aval); - ambPmapCaustic(caustic, r, rdepth); - +{/* XXX TEMPORARY */ + COLOR pmc; + scolor_color(pmc, aval); + ambPmapCaustic(pmc, r, rdepth); + setscolor(caustic, colval(pmc,RED), colval(pmc,GRN), colval(pmc,BLU)); +} if (ambdiv <= 0) /* no ambient calculation */ goto dumbamb; /* check number of bounces */ @@ -299,15 +269,17 @@ multambient( /* compute ambient component & multiply ambincl != inset(ambset, r->ro->omod)) goto dumbamb; - if (ambacc <= FTINY) { /* no ambient storage */ - FVECT uvd[2]; + if (ambacc <= FTINY) { /* no ambient storage? */ + double rdot = DOT(nrm,r->ron); + int sgn = 1 - 2*(rdot < 0); float dgrad[2], *dgp = NULL; + FVECT uvd[2]; - if (nrm != r->ron && DOT(nrm,r->ron) < 0.9999) + if (sgn*rdot < 0.9999) dgp = dgrad; /* compute rotational grad. */ - copycolor(acol, aval); + copyscolor(acol, aval); rdepth++; - ok = doambient(acol, r, r->rweight, + ok = doambient(acol, r, r->rweight*sgn, uvd, NULL, NULL, dgp, NULL); rdepth--; if (!ok) @@ -317,31 +289,27 @@ multambient( /* compute ambient component & multiply VCROSS(v1, r->ron, nrm); d = 1.0; for (i = 3; i--; ) - d += v1[i] * (dgp[0]*uvd[0][i] + dgp[1]*uvd[1][i]); + d += sgn*v1[i] * (dgp[0]*uvd[0][i] + dgp[1]*uvd[1][i]); if (d >= 0.05) - scalecolor(acol, d); + scalescolor(acol, d); } - copycolor(aval, acol); + copyscolor(aval, acol); /* PMAP: add in caustic */ - addcolor(aval, caustic); + saddscolor(aval, caustic); return; } - - if (tracktime) /* sort to minimize thrashing */ - sortambvals(0); /* interpolate ambient value */ - setcolor(acol, 0.0, 0.0, 0.0); + scolorblack(acol); d = sumambient(acol, r, nrm, rdepth, &atrunk, thescene.cuorg, thescene.cusize); if (d > FTINY) { - d = 1.0/d; - scalecolor(acol, d); - multcolor(aval, acol); + scalescolor(acol, 1.0/d); + smultscolor(aval, acol); /* PMAP: add in caustic */ - addcolor(aval, caustic); + saddscolor(aval, caustic); return; } @@ -350,32 +318,32 @@ multambient( /* compute ambient component & multiply rdepth--; if (ok) { - multcolor(aval, acol); /* computed new value */ + smultscolor(aval, acol); /* computed new value */ /* PMAP: add in caustic */ - addcolor(aval, caustic); + saddscolor(aval, caustic); return; } dumbamb: /* return global value */ if ((ambvwt <= 0) | (navsum == 0)) { - multcolor(aval, ambval); + smultcolor(aval, ambval); /* PMAP: add in caustic */ - addcolor(aval, caustic); + saddscolor(aval, caustic); return; } l = bright(ambval); /* average in computations */ if (l > FTINY) { - d = (log(l)*(double)ambvwt + avsum) / + d = (log(l)*(double)ambvwt + avsum + logAvgAbsorp*navsum) / (double)(ambvwt + navsum); d = exp(d) / l; - scalecolor(aval, d); - multcolor(aval, ambval); /* apply color of ambval */ + scalescolor(aval, d); + smultcolor(aval, ambval); /* apply color of ambval */ } else { - d = exp( avsum / (double)navsum ); - scalecolor(aval, d); /* neutral color */ + d = exp( avsum/(double)navsum + logAvgAbsorp ); + scalescolor(aval, d); /* neutral color */ } } @@ -428,7 +396,7 @@ plugaleak(RAY *r, AMBVAL *ap, FVECT anorm, double ang) static double sumambient( /* get interpolated ambient value */ - COLOR acol, + SCOLOR acol, RAY *r, FVECT rn, int al, @@ -438,6 +406,7 @@ sumambient( /* get interpolated ambient value */ ) { /* initial limit is 10 degrees plus ambacc radians */ const double minangle = 10.0 * PI/180.; + const int sgn = 1 - 2*(DOT(r->ron,rn) < 0); double maxangle = minangle + ambacc; double wsum = 0.0; FVECT ck0; @@ -461,7 +430,7 @@ sumambient( /* get interpolated ambient value */ at->kid+i, ck0, s); } /* good enough? */ - if (wsum >= 0.05 && s > minarad*10.0) + if ((wsum >= 0.05) & (s*ambacc > minarad)) return(wsum); } /* adjust maximum angle */ @@ -470,11 +439,8 @@ sumambient( /* get interpolated ambient value */ /* sum this node */ for (av = at->alist; av != NULL; av = av->next) { double u, v, d, delta_r2, delta_t2; - COLOR ct; + SCOLOR sct; FVECT uvw[3]; - /* record access */ - if (tracktime) - av->latick = ambclock; /* * Ambient level test */ @@ -485,22 +451,23 @@ sumambient( /* get interpolated ambient value */ * Direction test using unperturbed normal */ decodedir(uvw[2], av->ndir); - d = DOT(uvw[2], r->ron); + d = sgn * DOT(uvw[2], r->ron); if (d <= 0.0) /* >= 90 degrees */ continue; delta_r2 = 2.0 - 2.0*d; /* approx. radians^2 */ if (delta_r2 >= maxangle*maxangle) continue; /* - * Modified ray behind test + * Original ray behind test */ - VSUB(ck0, r->rop, av->pos); - d = DOT(ck0, uvw[2]); - if (d < -minarad*ambacc-.001) + d = 0.0; + for (j = 0; j < 3; j++) + d += (r->rop[j] - av->pos[j])*(r->ron[j] + uvw[2][j]); + d *= 0.5; + if (d < -minarad*ambacc) continue; - d /= av->rad[0]; - delta_t2 = d*d; - if (delta_t2 >= ambacc*ambacc) + /* Pre-empt following test if we can */ + if (fabs(d) >= av->rad[0]*ambacc) continue; /* * Elliptical radii test based on Hessian @@ -521,12 +488,12 @@ sumambient( /* get interpolated ambient value */ /* * Extrapolate value and compute final weight (hat function) */ - if (!extambient(ct, av, r->rop, rn, uvw)) + if (!extambient(sct, av, r->rop, rn, uvw)) continue; d = tfunc(maxangle, sqrt(delta_r2), 0.0) * tfunc(ambacc, sqrt(delta_t2), 0.0); - scalecolor(ct, d); - addcolor(acol, ct); + scalescolor(sct, d); + saddscolor(acol, sct); wsum += d; } return(wsum); @@ -535,12 +502,13 @@ sumambient( /* get interpolated ambient value */ static int makeambient( /* make a new ambient value for storage */ - COLOR acol, + SCOLOR acol, RAY *r, FVECT rn, int al ) { + int sgn = 1 - 2*(DOT(r->ron,rn) < 0); AMBVAL amb; FVECT uvw[3]; int i; @@ -550,32 +518,32 @@ makeambient( /* make a new ambient value for storage amb.weight *= AVGREFL; if (r->rweight < 0.1*amb.weight) /* heuristic override */ amb.weight = 1.25*r->rweight; - setcolor(acol, AVGREFL, AVGREFL, AVGREFL); + setscolor(acol, AVGREFL, AVGREFL, AVGREFL); /* compute ambient */ - i = doambient(acol, r, amb.weight, + i = doambient(acol, r, amb.weight*sgn, uvw, amb.rad, amb.gpos, amb.gdir, &amb.corral); - scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */ + scalescolor(acol, 1./AVGREFL); /* undo assumed reflectance */ if (i <= 0 || amb.rad[0] <= FTINY) /* no Hessian or zero radius */ return(i); + uvw[2][0] = sgn*r->ron[0]; /* orient unperturbed normal */ + uvw[2][1] = sgn*r->ron[1]; + uvw[2][2] = sgn*r->ron[2]; /* store value */ VCOPY(amb.pos, r->rop); - amb.ndir = encodedir(r->ron); + amb.ndir = encodedir(uvw[2]); amb.udir = encodedir(uvw[0]); amb.lvl = al; - copycolor(amb.val, acol); - /* insert into tree */ - avsave(&amb); /* and save to file */ - if (rn != r->ron) { /* texture */ - VCOPY(uvw[2], r->ron); + copyscolor(amb.val, acol); + avsave(&amb); /* insert and save to file */ + if (DOT(uvw[2],rn) < 0.9999) /* texture? */ extambient(acol, &amb, r->rop, rn, uvw); - } return(1); } static int extambient( /* extrapolate value at pv, nv */ - COLOR cr, + SCOLOR scr, AMBVAL *ap, FVECT pv, FVECT nv, @@ -607,8 +575,8 @@ extambient( /* extrapolate value at pv, nv */ d = min_d; else if (d > max_d) d = max_d; - copycolor(cr, ap->val); - scalecolor(cr, d); + copyscolor(scr, ap->val); + scalescolor(scr, d); return(d > min_d); } @@ -671,6 +639,7 @@ initambfile( /* initialize ambient file */ if (mybuf == NULL) mybuf = (char *)bmalloc(BUFSIZ+8); setbuf(ambfp, mybuf); +retry: if (cre8) { /* new file */ newheader("RADIANCE", ambfp); fprintf(ambfp, "%s -av %g %g %g -aw %d -ab %d -aa %g ", @@ -679,16 +648,44 @@ initambfile( /* initialize ambient file */ ambvwt, ambounce, ambacc); fprintf(ambfp, "-ad %d -as %d -ar %d ", ambdiv, ambssamp, ambres); + fprintf(ambfp, "-dr %d -ds %g -dt %g -dc %g ", directrelay, + srcsizerat, shadthresh, shadcert); + fprintf(ambfp, "-ss %g -st %g -lr %d -lw %g ", specjitter, + specthresh, maxdepth, minweight); + fprintf(ambfp, "-cw %g %g -cs %d ", WLPART[3], WLPART[0], NCSAMP); if (octname != NULL) fputs(octname, ambfp); - fputc('\n', ambfp); + fputc('\n', ambfp); /* end of command line, not header! */ fprintf(ambfp, "SOFTWARE= %s\n", VersionID); fputnow(ambfp); + AMB_CNDX = CNDX; /* use current spectral sampling */ + AMB_WLPART = WLPART; + fputwlsplit(WLPART, ambfp); + fputncomp(NCSAMP, ambfp); fputformat(AMBFMT, ambfp); fputc('\n', ambfp); putambmagic(ambfp); - } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp)) - error(USER, "bad ambient file"); + } else if (getheader(ambfp, amb_headline, NULL) < 0 || !hasambmagic(ambfp)) { +#ifndef F_SETLKW + static int ntries = 3; + if (--ntries > 0 && ftell(ambfp) == 0) { + clearerr(ambfp); + sleep(2); + goto retry; + } +#endif + error(USER, "bad/incompatible ambient file"); + } + if ((AMB_CNDX != CNDX) | (AMB_WLPART != WLPART)) { + if (setspectrsamp(AMB_CNDX, AMB_WLPART) < 0) + error(USER, "bad wavelength sampling in ambient file"); + if (AMB_CNDX[3] == CNDX[3] && FABSEQ(AMB_WLPART[0],WLPART[0]) && + FABSEQ(AMB_WLPART[3],WLPART[3])) { + AMB_CNDX = CNDX; + AMB_WLPART = WLPART; /* just the same */ + } else + error(WARNING, "different ambient file wavelength sampling"); + } } @@ -721,11 +718,10 @@ avstore( /* allocate memory and save aval */ if ((av = newambval()) == NULL) error(SYSTEM, "out of memory in avstore"); - *av = *aval; - av->latick = ambclock; + memcpy(av, aval, AVSIZE); /* AVSIZE <= sizeof(AMBVAL) */ av->next = NULL; nambvals++; - d = bright(av->val); + d = pbright(av->val); if (d > FTINY) { /* add to log sum for averaging */ avsum += log(d); navsum++; @@ -795,175 +791,21 @@ unloadatree( /* unload an ambient value tree */ } -static struct avl { - AMBVAL *p; - unsigned long t; -} *avlist1; /* ambient value list with ticks */ -static AMBVAL **avlist2; /* memory positions for sorting */ -static int i_avlist; /* index for lists */ - -static int alatcmp(const void *av1, const void *av2); - static void avfree(AMBVAL *av) { free(av); } -static void -av2list( - AMBVAL *av -) -{ -#ifdef DEBUG - if (i_avlist >= nambvals) - error(CONSISTENCY, "too many ambient values in av2list1"); -#endif - avlist1[i_avlist].p = avlist2[i_avlist] = (AMBVAL*)av; - avlist1[i_avlist++].t = av->latick; -} - -static int -alatcmp( /* compare ambient values for MRA */ - const void *av1, - const void *av2 -) -{ - long lc = ((struct avl *)av2)->t - ((struct avl *)av1)->t; - return(lc<0 ? -1 : lc>0 ? 1 : 0); -} - - -/* GW NOTE 2002/10/3: - * I used to compare AMBVAL pointers, but found that this was the - * cause of a serious consistency error with gcc, since the optimizer - * uses some dangerous trick in pointer subtraction that - * assumes pointers differ by exact struct size increments. - */ -static int -aposcmp( /* compare ambient value positions */ - const void *avp1, - const void *avp2 -) -{ - long diff = *(char * const *)avp1 - *(char * const *)avp2; - if (diff < 0) - return(-1); - return(diff > 0); -} - - -static int -avlmemi( /* find list position from address */ - AMBVAL *avaddr -) -{ - AMBVAL **avlpp; - - avlpp = (AMBVAL **)bsearch(&avaddr, avlist2, - nambvals, sizeof(AMBVAL *), aposcmp); - if (avlpp == NULL) - error(CONSISTENCY, "address not found in avlmemi"); - return(avlpp - avlist2); -} - - static void -sortambvals( /* resort ambient values */ - int always -) +sortambvals(void) /* resort ambient values */ { - AMBTREE oldatrunk; - AMBVAL tav, *tap, *pnext; - int i, j; - /* see if it's time yet */ - if (!always && (ambclock++ < lastsort+sortintvl || - nambvals < SORT_THRESH)) - return; - /* - * The idea here is to minimize memory thrashing - * in VM systems by improving reference locality. - * We do this by periodically sorting our stored ambient - * values in memory in order of most recently to least - * recently accessed. This ordering was chosen so that new - * ambient values (which tend to be less important) go into - * higher memory with the infrequently accessed values. - * Since we expect our values to need sorting less - * frequently as the process continues, we double our - * waiting interval after each call. - * This routine is also called by setambacc() with - * the "always" parameter set to 1 so that the ambient - * tree will be rebuilt with the new accuracy parameter. - */ - if (tracktime) { /* allocate pointer arrays to sort */ - avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *)); - avlist1 = (struct avl *)malloc(nambvals*sizeof(struct avl)); - } else { - avlist2 = NULL; - avlist1 = NULL; - } - if (avlist1 == NULL) { /* no time tracking -- rebuild tree? */ - if (avlist2 != NULL) - free(avlist2); - if (always) { /* rebuild without sorting */ - oldatrunk = atrunk; - atrunk.alist = NULL; - atrunk.kid = NULL; - unloadatree(&oldatrunk, avinsert); - } - } else { /* sort memory by last access time */ - /* - * Sorting memory is tricky because it isn't contiguous. - * We have to sort an array of pointers by MRA and also - * by memory position. We then copy values in "loops" - * to minimize memory hits. Nevertheless, we will visit - * everyone at least twice, and this is an expensive process - * when we're thrashing, which is when we need to do it. - */ -#ifdef DEBUG - sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...", - nambvals, ambclock); - eputs(errmsg); -#endif - i_avlist = 0; - unloadatree(&atrunk, av2list); /* empty current tree */ -#ifdef DEBUG - if (i_avlist < nambvals) - error(CONSISTENCY, "missing ambient values in sortambvals"); -#endif - qsort(avlist1, nambvals, sizeof(struct avl), alatcmp); - qsort(avlist2, nambvals, sizeof(AMBVAL *), aposcmp); - for (i = 0; i < nambvals; i++) { - if (avlist1[i].p == NULL) - continue; - tap = avlist2[i]; - tav = *tap; - for (j = i; (pnext = avlist1[j].p) != tap; - j = avlmemi(pnext)) { - *(avlist2[j]) = *pnext; - avinsert(avlist2[j]); - avlist1[j].p = NULL; - } - *(avlist2[j]) = tav; - avinsert(avlist2[j]); - avlist1[j].p = NULL; - } - free(avlist1); - free(avlist2); - /* compute new sort interval */ - sortintvl = ambclock - lastsort; - if (sortintvl >= MAX_SORT_INTVL/2) - sortintvl = MAX_SORT_INTVL; - else - sortintvl <<= 1; /* wait twice as long next */ -#ifdef DEBUG - eputs("done\n"); -#endif - } - if (ambclock >= MAXACLOCK) - ambclock = MAXACLOCK/2; - lastsort = ambclock; + AMBTREE oldatrunk = atrunk; + + atrunk.alist = NULL; + atrunk.kid = NULL; + unloadatree(&oldatrunk, avinsert); }
