--- ray/src/rt/ambient.c 1991/10/26 15:19:06 1.18 +++ ray/src/rt/ambient.c 1992/07/16 16:47:28 2.10 @@ -42,30 +42,54 @@ static AMBTREE atrunk; /* our ambient trunk node */ static FILE *ambfp = NULL; /* ambient file pointer */ +#define AMBFLUSH (BUFSIZ/AMBVALSIZ) + #define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL)) #define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE)) +extern long ftell(), lseek(); +static int initambfile(), avsave(), avinsert(), ambsync(); + +setambres(ar) /* set ambient resolution */ +int ar; +{ + /* set min & max radii */ + if (ar <= 0) { + minarad = 0.0; + maxarad = thescene.cusize / 2.0; + } else { + minarad = thescene.cusize / ar; + maxarad = 16.0 * minarad; /* heuristic */ + if (maxarad > thescene.cusize / 2.0) + maxarad = thescene.cusize / 2.0; + } + if (maxarad <= FTINY) + maxarad = .001; +} + + setambient(afile) /* initialize calculation */ char *afile; { - long ftell(); + long headlen; AMBVAL amb; - - maxarad = thescene.cusize / 2.0; /* maximum radius */ - /* minimum radius */ - minarad = ambres > 0 ? thescene.cusize/ambres : 0.0; - - /* open ambient file */ + /* init ambient limits */ + setambres(ambres); + /* open ambient file */ if (afile != NULL) if ((ambfp = fopen(afile, "r+")) != NULL) { - while (fread((char *)&amb,sizeof(AMBVAL),1,ambfp) == 1) + initambfile(0); + headlen = ftell(ambfp); + while (readambval(&amb, ambfp)) avinsert(&amb, &atrunk, thescene.cuorg, thescene.cusize); /* align */ - fseek(ambfp, -(ftell(ambfp)%sizeof(AMBVAL)), 1); - } else if ((ambfp = fopen(afile, "w")) == NULL) { + fseek(ambfp, -((ftell(ambfp)-headlen)%AMBVALSIZ), 1); + } else if ((ambfp = fopen(afile, "w+")) != NULL) + initambfile(1); + else { sprintf(errmsg, "cannot open ambient file \"%s\"", afile); error(SYSTEM, errmsg); @@ -192,7 +216,7 @@ double s; * Jittering final test reduces image artifacts. */ wt = sqrt(e1) + sqrt(e2); - wt *= .9 + .2*frandom(); + wt *= .9 + .2*urand(9015+samplendx); if (wt > ambacc) continue; if (wt <= 1e-3) @@ -249,8 +273,7 @@ int al; VCOPY(amb.gpos, gp); VCOPY(amb.gdir, gd); /* insert into tree */ - avinsert(&amb, &atrunk, thescene.cuorg, thescene.cusize); - avsave(&amb); /* write to file */ + avsave(&amb); /* and save to file */ return(amb.rad); } @@ -282,23 +305,46 @@ FVECT pv, nv; static -avsave(av) /* save an ambient value */ +initambfile(creat) /* initialize ambient file */ +int creat; +{ + extern char *progname, *octname, VersionID[]; + + setbuf(ambfp, bmalloc(BUFSIZ)); + if (creat) { /* new file */ + fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ", + progname, colval(ambval,RED), + colval(ambval,GRN), colval(ambval,BLU), + ambounce, ambacc); + fprintf(ambfp, "-ad %d -as %d -ar %d %s\n", + ambdiv, ambssamp, ambres, + octname==NULL ? "" : octname); + fprintf(ambfp, "SOFTWARE= %s\n", VersionID); + fputformat(AMBFMT, ambfp); + putc('\n', ambfp); + putambmagic(ambfp); + fflush(ambfp); + } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp)) + error(USER, "bad ambient file"); +} + + +static +avsave(av) /* insert and save an ambient value */ AMBVAL *av; { -#ifdef AMBFLUSH static int nunflshed = 0; -#endif + + avinsert(av, &atrunk, thescene.cuorg, thescene.cusize); if (ambfp == NULL) return; - if (fwrite((char *)av, sizeof(AMBVAL), 1, ambfp) != 1) + if (writambval(av, ambfp) < 0) goto writerr; -#ifdef AMBFLUSH if (++nunflshed >= AMBFLUSH) { - if (fflush(ambfp) == EOF) + if (ambsync() == EOF) goto writerr; nunflshed = 0; } -#endif return; writerr: error(SYSTEM, "error writing ambient file"); @@ -340,3 +386,57 @@ double s; memerr: error(SYSTEM, "out of memory in avinsert"); } + + +#ifdef NIX + +static +ambsync() /* flush ambient file */ +{ + return(fflush(ambfp)); +} + +#else + +#include +#include +#include + +static +ambsync() /* synchronize ambient file */ +{ + static FILE *ambinp = NULL; + struct flock fls; + struct stat sts; + AMBVAL avs; + long lastpos, flen; + register int n; + /* gain exclusive access */ + fls.l_type = F_WRLCK; + fls.l_whence = 0; + fls.l_start = 0L; + fls.l_len = 0L; + if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0) + error(SYSTEM, "cannot lock ambient file"); + /* see if file has grown */ + lastpos = lseek(fileno(ambfp), 0L, 1); /* get previous position */ + if (fstat(fileno(ambfp), &sts) < 0) /* get current length */ + error(SYSTEM, "cannot stat ambient file"); + flen = sts.st_size; + if (n = (flen - lastpos)/AMBVALSIZ) { /* file has grown */ + if (ambinp == NULL) /* use duplicate file */ + ambinp = fdopen(dup(fileno(ambfp)), "r"); + while (n--) { /* load contributed values */ + readambval(&avs, ambinp); + avinsert(&avs,&atrunk,thescene.cuorg,thescene.cusize); + } /* moves shared file pointer */ + if (n = (flen - lastpos)%AMBVALSIZ) /* alignment */ + lseek(fileno(ambfp), flen-n, 0); + } + n = fflush(ambfp); /* calls write() at last */ + fls.l_type = F_UNLCK; /* release file */ + fcntl(fileno(ambfp), F_SETLKW, &fls); + return(n); +} + +#endif
