--- ray/src/rt/ambient.c 1990/09/07 08:17:42 1.11 +++ ray/src/rt/ambient.c 1991/06/13 09:41:15 1.15 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1991 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -19,49 +19,25 @@ static char SCCSid[] = "$SunId$ LBL"; #include "otypes.h" +#include "ambient.h" + #include "random.h" #define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */ +typedef struct ambtree { + AMBVAL *alist; /* ambient value list */ + struct ambtree *kid; /* 8 child nodes */ +} AMBTREE; /* ambient octree */ + extern CUBE thescene; /* contains space boundaries */ -extern COLOR ambval; /* global ambient component */ -extern double ambacc; /* ambient accuracy */ -extern int ambres; /* ambient resolution */ -extern int ambdiv; /* number of divisions for calculation */ -extern int ambssamp; /* number of super-samples */ -extern int ambounce; /* number of ambient bounces */ -extern char *amblist[]; /* ambient include/exclude list */ -extern int ambincl; /* include == 1, exclude == 0 */ - #define MAXASET 511 /* maximum number of elements in ambient set */ OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */ double maxarad; /* maximum ambient radius */ double minarad; /* minimum ambient radius */ -typedef struct ambval { - FVECT pos; /* position in space */ - FVECT dir; /* normal direction */ - int lvl; /* recursion level of parent ray */ - float weight; /* weight of parent ray */ - COLOR val; /* computed ambient value */ - float rad; /* validity radius */ - struct ambval *next; /* next in list */ -} AMBVAL; /* ambient value */ - -typedef struct ambtree { - AMBVAL *alist; /* ambient value list */ - struct ambtree *kid; /* 8 child nodes */ -} AMBTREE; /* ambient octree */ - -typedef struct { - float k; /* error contribution per sample */ - COLOR v; /* ray sum */ - int n; /* number of samples */ - short t, p; /* theta, phi indices */ -} AMBSAMP; /* ambient sample */ - static AMBTREE atrunk; /* our ambient trunk node */ static FILE *ambfp = NULL; /* ambient file pointer */ @@ -70,9 +46,7 @@ static FILE *ambfp = NULL; /* ambient file pointer */ #define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE)) -double sumambient(), doambient(), makeambient(); - setambient(afile) /* initialize calculation */ char *afile; { @@ -141,7 +115,7 @@ register RAY *r; goto dumbamb; if (ambacc <= FTINY) { /* no ambient storage */ - if (doambient(acol, r) == 0.0) + if (doambient(acol, r, NULL, NULL) == 0.0) goto dumbamb; goto done; } @@ -209,7 +183,7 @@ double s; for (j = 0; j < 3; j++) d += (r->rop[j] - av->pos[j]) * (av->dir[j] + r->ron[j]); - if (d < -minarad) + if (d*0.5 < -minarad*ambacc) continue; /* * Jittering final test reduces image artifacts. @@ -223,7 +197,7 @@ double s; else wt = 1.0 / wt; wsum += wt; - copycolor(ct, av->val); + extambient(ct, av, r->rop, r->ron); scalecolor(ct, wt); addcolor(acol, ct); } @@ -254,8 +228,9 @@ COLOR acol; register RAY *r; { AMBVAL amb; + FVECT gp, gd; - amb.rad = doambient(acol, r); /* compute ambient */ + amb.rad = doambient(acol, r, gp, gd); /* compute ambient */ if (amb.rad == 0.0) return(0.0); /* store it */ @@ -264,6 +239,8 @@ register RAY *r; amb.lvl = r->rlvl; amb.weight = r->rweight; copycolor(amb.val, acol); + VCOPY(amb.gpos, gp); + VCOPY(amb.gdir, gd); /* insert into tree */ avinsert(&amb, &atrunk, thescene.cuorg, thescene.cusize); avsave(&amb); /* write to file */ @@ -271,167 +248,29 @@ register RAY *r; } -double -doambient(acol, r) /* compute ambient component */ -COLOR acol; -register RAY *r; +extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */ +COLOR cr; +register AMBVAL *ap; +FVECT pv, nv; { - extern int ambcmp(); - extern double sin(), cos(), sqrt(); - double phi, xd, yd, zd; - double b, b2; - register AMBSAMP *div; - AMBSAMP dnew; - RAY ar; - FVECT ux, uy; - double arad; - int ndivs, nt, np, ns, ne, i, j; - register int k; + FVECT v1, v2; + register int i; + double d; - setcolor(acol, 0.0, 0.0, 0.0); - /* set number of divisions */ - nt = sqrt(ambdiv * r->rweight * 0.5) + 0.5; - np = 2 * nt; - ndivs = nt * np; - /* check first */ - if (ndivs == 0 || rayorigin(&ar, r, AMBIENT, 0.5) < 0) - return(0.0); - /* set number of super-samples */ - ns = ambssamp * r->rweight + 0.5; - if (ns > 0) { - div = (AMBSAMP *)malloc(ndivs*sizeof(AMBSAMP)); - if (div == NULL) - error(SYSTEM, "out of memory in doambient"); + d = 1.0; /* zeroeth order */ + /* gradient due to translation */ + for (i = 0; i < 3; i++) + d += ap->gpos[i]*(pv[i]-ap->pos[i]); + /* gradient due to rotation */ + VCOPY(v1, ap->dir); + fcross(v2, v1, nv); + d += DOT(ap->gdir, v2); + if (d <= 0.0) { + setcolor(cr, 0.0, 0.0, 0.0); + return; } - /* make axes */ - uy[0] = uy[1] = uy[2] = 0.0; - for (k = 0; k < 3; k++) - if (r->ron[k] < 0.6 && r->ron[k] > -0.6) - break; - uy[k] = 1.0; - fcross(ux, r->ron, uy); - normalize(ux); - fcross(uy, ux, r->ron); - /* sample divisions */ - arad = 0.0; - ne = 0; - for (i = 0; i < nt; i++) - for (j = 0; j < np; j++) { - rayorigin(&ar, r, AMBIENT, 0.5); /* pretested */ - zd = sqrt((i+frandom())/nt); - phi = 2.0*PI * (j+frandom())/np; - xd = cos(phi) * zd; - yd = sin(phi) * zd; - zd = sqrt(1.0 - zd*zd); - for (k = 0; k < 3; k++) - ar.rdir[k] = xd*ux[k]+yd*uy[k]+zd*r->ron[k]; - rayvalue(&ar); - if (ar.rot < FHUGE) - arad += 1.0 / ar.rot; - if (ns > 0) { /* save division */ - div[ne].k = 0.0; - copycolor(div[ne].v, ar.rcol); - div[ne].n = 0; - div[ne].t = i; div[ne].p = j; - /* sum errors */ - b = bright(ar.rcol); - if (i > 0) { /* from above */ - b2 = bright(div[ne-np].v) - b; - b2 *= b2 * 0.25; - div[ne].k += b2; - div[ne].n++; - div[ne-np].k += b2; - div[ne-np].n++; - } - if (j > 0) { /* from behind */ - b2 = bright(div[ne-1].v) - b; - b2 *= b2 * 0.25; - div[ne].k += b2; - div[ne].n++; - div[ne-1].k += b2; - div[ne-1].n++; - } - if (j == np-1) { /* around */ - b2 = bright(div[ne-(np-1)].v) - b; - b2 *= b2 * 0.25; - div[ne].k += b2; - div[ne].n++; - div[ne-(np-1)].k += b2; - div[ne-(np-1)].n++; - } - ne++; - } else - addcolor(acol, ar.rcol); - } - for (k = 0; k < ne; k++) { /* compute errors */ - if (div[k].n > 1) - div[k].k /= div[k].n; - div[k].n = 1; - } - /* sort the divisions */ - qsort(div, ne, sizeof(AMBSAMP), ambcmp); - /* skim excess */ - while (ne > ns) { - ne--; - addcolor(acol, div[ne].v); - } - /* super-sample */ - for (i = ns; i > 0; i--) { - rayorigin(&ar, r, AMBIENT, 0.5); /* pretested */ - zd = sqrt((div[0].t+frandom())/nt); - phi = 2.0*PI * (div[0].p+frandom())/np; - xd = cos(phi) * zd; - yd = sin(phi) * zd; - zd = sqrt(1.0 - zd*zd); - for (k = 0; k < 3; k++) - ar.rdir[k] = xd*ux[k]+yd*uy[k]+zd*r->ron[k]; - rayvalue(&ar); - if (ar.rot < FHUGE) - arad += 1.0 / ar.rot; - /* recompute error */ - copycolor(dnew.v, div[0].v); - addcolor(dnew.v, ar.rcol); - dnew.n = div[0].n + 1; - dnew.t = div[0].t; dnew.p = div[0].p; - b2 = bright(dnew.v)/dnew.n - bright(ar.rcol); - b2 = b2*b2 + div[0].k*(div[0].n*div[0].n); - dnew.k = b2/(dnew.n*dnew.n); - /* reinsert */ - for (k = 0; k < ne-1 && dnew.k < div[k+1].k; k++) - copystruct(&div[k], &div[k+1]); - copystruct(&div[k], &dnew); - - if (ne >= i) { /* extract darkest division */ - ne--; - if (div[ne].n > 1) - scalecolor(div[ne].v, 1.0/div[ne].n); - addcolor(acol, div[ne].v); - } - } - scalecolor(acol, 1.0/ndivs); - if (arad <= FTINY) - arad = FHUGE; - else - arad = (ndivs+ns) / arad / sqrt(r->rweight); - if (arad > maxarad) - arad = maxarad; - else if (arad < minarad) - arad = minarad; - if (ns > 0) - free((char *)div); - return(arad); -} - - -static int -ambcmp(d1, d2) /* decreasing order */ -AMBSAMP *d1, *d2; -{ - if (d1->k < d2->k) - return(1); - if (d1->k > d2->k) - return(-1); - return(0); + copycolor(cr, ap->val); + scalecolor(cr, d); }
