root/radiance/ray/src/rt/ambient.c
Revision: 2.85
Committed: Tue May 6 17:15:11 2014 UTC (11 years, 3 months ago) by greg
Changes since 2.84: +2 -2 lines
Bug fix (-DNEWAMB) where ray behind test was failing
2 static const char RCSid[] = "$Id: ambient.c,v 2.84 2014/04/26 15:54:43 greg Exp $";
5 * ambient.c - routines dealing with ambient (inter-reflected) component.
6 *
7 * Declarations of external symbols in ambient.h
8 */
9
10 #include "copyright.h"
11
12 #include <string.h>
13
14 #include "platform.h"
15 #include "ray.h"
16 #include "otypes.h"
17 #include "resolu.h"
18 #include "ambient.h"
19 #include "random.h"
20
21 #ifndef OCTSCALE
22 #define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */
23 #endif
24
25 extern char *shm_boundary; /* memory sharing boundary */
26
27 #ifndef MAXASET
28 #define MAXASET 4095 /* maximum number of elements in ambient set */
29 #endif
30 OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
31
32 double maxarad; /* maximum ambient radius */
33 double minarad; /* minimum ambient radius */
34
35 static AMBTREE atrunk; /* our ambient trunk node */
36
37 static FILE *ambfp = NULL; /* ambient file pointer */
38 static int nunflshed = 0; /* number of unflushed ambient values */
39
40 #ifndef SORT_THRESH
41 #ifdef SMLMEM
42 #define SORT_THRESH ((16L<<20)/sizeof(AMBVAL))
43 #else
44 #define SORT_THRESH ((64L<<20)/sizeof(AMBVAL))
45 #endif
46 #endif
47 #ifndef SORT_INTVL
48 #define SORT_INTVL (SORT_THRESH<<1)
49 #endif
50 #ifndef MAX_SORT_INTVL
51 #define MAX_SORT_INTVL (SORT_INTVL<<6)
52 #endif
53
54
55 static double avsum = 0.; /* computed ambient value sum (log) */
56 static unsigned int navsum = 0; /* number of values in avsum */
57 static unsigned int nambvals = 0; /* total number of indirect values */
58 static unsigned int nambshare = 0; /* number of values from file */
59 static unsigned long ambclock = 0; /* ambient access clock */
60 static unsigned long lastsort = 0; /* time of last value sort */
61 static long sortintvl = SORT_INTVL; /* time until next sort */
62 static FILE *ambinp = NULL; /* auxiliary file for input */
63 static long lastpos = -1; /* last flush position */
64
65 #define MAXACLOCK (1L<<30) /* clock turnover value */
66 /*
67 * Track access times unless we are sharing ambient values
68 * through memory on a multiprocessor, when we want to avoid
69 * claiming our own memory (copy on write). Go ahead anyway
70 * if more than two thirds of our values are unshared.
71 * Compile with -Dtracktime=0 to turn this code off.
72 */
73 #ifndef tracktime
74 #define tracktime (shm_boundary == NULL || nambvals > 3*nambshare)
75 #endif
76
77 #define AMBFLUSH (BUFSIZ/AMBVALSIZ)
78
79 #define newambval() (AMBVAL *)malloc(sizeof(AMBVAL))
80 #define freeav(av) free((void *)av);
81
82 static void initambfile(int creat);
83 static void avsave(AMBVAL *av);
84 static AMBVAL *avstore(AMBVAL *aval);
85 static AMBTREE *newambtree(void);
86 static void freeambtree(AMBTREE *atp);
87
88 typedef void unloadtf_t(AMBVAL *);
89 static unloadtf_t avinsert;
90 static unloadtf_t av2list;
91 static unloadtf_t avfree;
92 static void unloadatree(AMBTREE *at, unloadtf_t *f);
93
94 static int aposcmp(const void *avp1, const void *avp2);
95 static int avlmemi(AMBVAL *avaddr);
96 static void sortambvals(int always);
97
98 #ifdef F_SETLKW
99 static void aflock(int typ);
100 #endif
101
102
103 void
104 setambres( /* set ambient resolution */
105 int ar
106 )
107 {
108 ambres = ar < 0 ? 0 : ar; /* may be done already */
109 /* set min & max radii */
110 if (ar <= 0) {
111 minarad = 0;
112 maxarad = thescene.cusize*0.5;
113 } else {
114 minarad = thescene.cusize / ar;
115 maxarad = 64.0 * minarad; /* heuristic */
116 if (maxarad > thescene.cusize*0.5)
117 maxarad = thescene.cusize*0.5;
118 }
119 if (minarad <= FTINY)
120 minarad = 10.0*FTINY;
121 if (maxarad <= minarad)
122 maxarad = 64.0 * minarad;
123 }
124
125
126 void
127 setambacc( /* set ambient accuracy */
128 double newa
129 )
130 {
131 static double olda; /* remember previous setting here */
132
133 newa *= (newa > 0);
134 if (fabs(newa - olda) >= .05*(newa + olda)) {
135 ambacc = newa;
136 if (nambvals > 0)
137 sortambvals(1); /* rebuild tree */
138 }
139 }
140
141
142 void
143 setambient(void) /* initialize calculation */
144 {
145 int readonly = 0;
146 long flen;
147 AMBVAL amb;
148 /* make sure we're fresh */
149 ambdone();
150 /* init ambient limits */
151 setambres(ambres);
152 setambacc(ambacc);
153 if (ambfile == NULL || !ambfile[0])
154 return;
155 if (ambacc <= FTINY) {
156 sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened",
157 ambfile);
158 error(WARNING, errmsg);
159 return;
160 }
161 /* open ambient file */
162 if ((ambfp = fopen(ambfile, "r+")) == NULL)
163 readonly = (ambfp = fopen(ambfile, "r")) != NULL;
164 if (ambfp != NULL) {
165 initambfile(0); /* file exists */
166 lastpos = ftell(ambfp);
167 while (readambval(&amb, ambfp))
168 avinsert(avstore(&amb));
169 nambshare = nambvals; /* share loaded values */
170 if (readonly) {
171 sprintf(errmsg,
172 "loaded %u values from read-only ambient file",
173 nambvals);
174 error(WARNING, errmsg);
175 fclose(ambfp); /* close file so no writes */
176 ambfp = NULL;
177 return; /* avoid ambsync() */
178 }
179 /* align file pointer */
180 lastpos += (long)nambvals*AMBVALSIZ;
181 flen = lseek(fileno(ambfp), (off_t)0, SEEK_END);
182 if (flen != lastpos) {
183 sprintf(errmsg,
184 "ignoring last %ld values in ambient file (corrupted)",
185 (flen - lastpos)/AMBVALSIZ);
186 error(WARNING, errmsg);
187 fseek(ambfp, lastpos, SEEK_SET);
188 #ifndef _WIN32 /* XXX we need a replacement for that one */
189 ftruncate(fileno(ambfp), (off_t)lastpos);
190 #endif
191 }
192 } else if ((ambfp = fopen(ambfile, "w+")) != NULL) {
193 initambfile(1); /* else create new file */
194 fflush(ambfp);
195 lastpos = ftell(ambfp);
196 } else {
197 sprintf(errmsg, "cannot open ambient file \"%s\"", ambfile);
198 error(SYSTEM, errmsg);
199 }
200 #ifdef getc_unlocked
201 flockfile(ambfp); /* application-level lock */
202 #endif
203 #ifdef F_SETLKW
204 aflock(F_UNLCK); /* release file */
205 #endif
206 }
207
208
209 void
210 ambdone(void) /* close ambient file and free memory */
211 {
212 if (ambfp != NULL) { /* close ambient file */
213 ambsync();
214 fclose(ambfp);
215 ambfp = NULL;
216 if (ambinp != NULL) {
217 fclose(ambinp);
218 ambinp = NULL;
219 }
220 lastpos = -1;
221 }
222 /* free ambient tree */
223 unloadatree(&atrunk, &avfree);
224 /* reset state variables */
225 avsum = 0.;
226 navsum = 0;
227 nambvals = 0;
228 nambshare = 0;
229 ambclock = 0;
230 lastsort = 0;
231 sortintvl = SORT_INTVL;
232 }
233
234
235 void
236 ambnotify( /* record new modifier */
237 OBJECT obj
238 )
239 {
240 static int hitlimit = 0;
241 OBJREC *o;
242 char **amblp;
243
244 if (obj == OVOID) { /* starting over */
245 ambset[0] = 0;
246 hitlimit = 0;
247 return;
248 }
249 o = objptr(obj);
250 if (hitlimit || !ismodifier(o->otype))
251 return;
252 for (amblp = amblist; *amblp != NULL; amblp++)
253 if (!strcmp(o->oname, *amblp)) {
254 if (ambset[0] >= MAXASET) {
255 error(WARNING, "too many modifiers in ambient list");
256 hitlimit++;
257 return; /* should this be fatal? */
258 }
259 insertelem(ambset, obj);
260 return;
261 }
262 }
263
264 /************ THE FOLLOWING ROUTINES DIFFER BETWEEN NEW & OLD ***************/
265
266 #ifdef NEWAMB
267
268 #define tfunc(lwr, x, upr) (((x)-(lwr))/((upr)-(lwr)))
269
270 static double sumambient(COLOR acol, RAY *r, FVECT rn, int al,
271 AMBTREE *at, FVECT c0, double s);
272 static int makeambient(COLOR acol, RAY *r, FVECT rn, int al);
273 static void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv,
274 FVECT uvw[3]);
275
276 void
277 multambient( /* compute ambient component & multiply by coef. */
278 COLOR aval,
279 RAY *r,
280 FVECT nrm
281 )
282 {
283 static int rdepth = 0; /* ambient recursion */
284 COLOR acol;
285 int ok;
286 double d, l;
287
288 if (ambdiv <= 0) /* no ambient calculation */
289 goto dumbamb;
290 /* check number of bounces */
291 if (rdepth >= ambounce)
292 goto dumbamb;
293 /* check ambient list */
294 if (ambincl != -1 && r->ro != NULL &&
295 ambincl != inset(ambset, r->ro->omod))
296 goto dumbamb;
297
298 if (ambacc <= FTINY) { /* no ambient storage */
299 copycolor(acol, aval);
300 rdepth++;
301 ok = doambient(acol, r, r->rweight, NULL, NULL, NULL, NULL);
302 rdepth--;
303 if (!ok)
304 goto dumbamb;
305 copycolor(aval, acol);
306 return;
307 }
308
309 if (tracktime) /* sort to minimize thrashing */
310 sortambvals(0);
311 /* interpolate ambient value */
312 setcolor(acol, 0.0, 0.0, 0.0);
313 d = sumambient(acol, r, nrm, rdepth,
314 &atrunk, thescene.cuorg, thescene.cusize);
315 if (d > FTINY) {
316 d = 1.0/d;
317 scalecolor(acol, d);
318 multcolor(aval, acol);
319 return;
320 }
321 rdepth++; /* need to cache new value */
322 ok = makeambient(acol, r, nrm, rdepth-1);
323 rdepth--;
324 if (ok) {
325 multcolor(aval, acol); /* computed new value */
326 return;
327 }
328 dumbamb: /* return global value */
329 if ((ambvwt <= 0) | (navsum == 0)) {
330 multcolor(aval, ambval);
331 return;
332 }
333 l = bright(ambval); /* average in computations */
334 if (l > FTINY) {
335 d = (log(l)*(double)ambvwt + avsum) /
336 (double)(ambvwt + navsum);
337 d = exp(d) / l;
338 scalecolor(aval, d);
339 multcolor(aval, ambval); /* apply color of ambval */
340 } else {
341 d = exp( avsum / (double)navsum );
342 scalecolor(aval, d); /* neutral color */
343 }
344 }
345
346
347 double
348 sumambient( /* get interpolated ambient value */
349 COLOR acol,
350 RAY *r,
351 FVECT rn,
352 int al,
353 AMBTREE *at,
354 FVECT c0,
355 double s
356 )
357 { /* initial limit is 10 degrees plus ambacc radians */
358 const double minangle = 10.0 * PI/180.;
359 double maxangle = minangle + ambacc;
360 double wsum = 0.0;
361 FVECT ck0;
362 int i, j;
363 AMBVAL *av;
364
365 if (at->kid != NULL) { /* sum children first */
366 s *= 0.5;
367 for (i = 0; i < 8; i++) {
368 for (j = 0; j < 3; j++) {
369 ck0[j] = c0[j];
370 if (1<<j & i)
371 ck0[j] += s;
372 if (r->rop[j] < ck0[j] - OCTSCALE*s)
373 break;
374 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
375 break;
376 }
377 if (j == 3)
378 wsum += sumambient(acol, r, rn, al,
379 at->kid+i, ck0, s);
380 }
381 /* good enough? */
382 if (wsum >= 0.05 && s > minarad*10.0)
383 return(wsum);
384 }
385 /* adjust maximum angle */
386 if (at->alist != NULL && (at->alist->lvl <= al) & (r->rweight < 0.6))
387 maxangle = (maxangle - PI/2.)*pow(r->rweight,0.13) + PI/2.;
388 /* sum this node */
389 for (av = at->alist; av != NULL; av = av->next) {
390 double d, delta_r2, delta_t2;
391 COLOR ct;
392 FVECT uvw[3];
393 /* record access */
394 if (tracktime)
395 av->latick = ambclock;
396 /*
397 * Ambient level test
398 */
399 if (av->lvl > al) /* list sorted, so this works */
400 break;
401 if (av->weight < 0.9*r->rweight)
402 continue;
403 /*
404 * Direction test using unperturbed normal
405 */
406 decodedir(uvw[2], av->ndir);
407 d = DOT(uvw[2], r->ron);
408 if (d <= 0.0) /* >= 90 degrees */
409 continue;
410 delta_r2 = 2.0 - 2.0*d; /* approx. radians^2 */
411 if (delta_r2 >= maxangle*maxangle)
412 continue;
413 /*
414 * Modified ray behind test
415 */
416 VSUB(ck0, r->rop, av->pos);
417 d = DOT(ck0, uvw[2]);
418 if (d < -minarad*ambacc-.001)
419 continue;
420 d /= av->rad[0];
421 delta_t2 = d*d;
422 if (delta_t2 >= ambacc*ambacc)
423 continue;
424 /*
425 * Elliptical radii test based on Hessian
426 */
427 decodedir(uvw[0], av->udir);
428 VCROSS(uvw[1], uvw[2], uvw[0]);
429 d = DOT(ck0, uvw[0]) / av->rad[0];
430 delta_t2 += d*d;
431 d = DOT(ck0, uvw[1]) / av->rad[1];
432 delta_t2 += d*d;
433 if (delta_t2 >= ambacc*ambacc)
434 continue;
435 /*
436 * Extrapolate value and compute final weight (hat function)
437 */
438 extambient(ct, av, r->rop, rn, uvw);
439 d = tfunc(maxangle, sqrt(delta_r2), 0.0) *
440 tfunc(ambacc, sqrt(delta_t2), 0.0);
441 scalecolor(ct, d);
442 addcolor(acol, ct);
443 wsum += d;
444 }
445 return(wsum);
446 }
447
448
449 int
450 makeambient( /* make a new ambient value for storage */
451 COLOR acol,
452 RAY *r,
453 FVECT rn,
454 int al
455 )
456 {
457 AMBVAL amb;
458 FVECT uvw[3];
459 int i;
460
461 amb.weight = 1.0; /* compute weight */
462 for (i = al; i-- > 0; )
463 amb.weight *= AVGREFL;
464 if (r->rweight < 0.1*amb.weight) /* heuristic override */
465 amb.weight = 1.25*r->rweight;
466 setcolor(acol, AVGREFL, AVGREFL, AVGREFL);
467 /* compute ambient */
468 i = doambient(acol, r, amb.weight, uvw, amb.rad, amb.gpos, amb.gdir);
469 scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */
470 if (i <= 0 || amb.rad[0] <= FTINY) /* no Hessian or zero radius */
471 return(i);
472 /* store value */
473 VCOPY(amb.pos, r->rop);
474 amb.ndir = encodedir(r->ron);
475 amb.udir = encodedir(uvw[0]);
476 amb.lvl = al;
477 copycolor(amb.val, acol);
478 /* insert into tree */
479 avsave(&amb); /* and save to file */
480 if (rn != r->ron) { /* texture */
481 VCOPY(uvw[2], r->ron);
482 extambient(acol, &amb, r->rop, rn, uvw);
483 }
484 return(1);
485 }
486
487
488 void
489 extambient( /* extrapolate value at pv, nv */
490 COLOR cr,
491 AMBVAL *ap,
492 FVECT pv,
493 FVECT nv,
494 FVECT uvw[3]
495 )
496 {
497 static FVECT my_uvw[3];
498 FVECT v1;
499 int i;
500 double d = 1.0; /* zeroeth order */
501
502 if (uvw == NULL) { /* need local coordinates? */
503 decodedir(my_uvw[2], ap->ndir);
504 decodedir(my_uvw[0], ap->udir);
505 VCROSS(my_uvw[1], my_uvw[2], my_uvw[0]);
506 uvw = my_uvw;
507 }
508 for (i = 3; i--; ) /* gradient due to translation */
509 d += (pv[i] - ap->pos[i]) *
510 (ap->gpos[0]*uvw[0][i] + ap->gpos[1]*uvw[1][i]);
511
512 VCROSS(v1, uvw[2], nv); /* gradient due to rotation */
513 for (i = 3; i--; )
514 d += v1[i] * (ap->gdir[0]*uvw[0][i] + ap->gdir[1]*uvw[1][i]);
515
516 if (d <= 0.0) {
517 setcolor(cr, 0.0, 0.0, 0.0);
518 return;
519 }
520 copycolor(cr, ap->val);
521 scalecolor(cr, d);
522 }
523
524
525 static void
526 avinsert( /* insert ambient value in our tree */
527 AMBVAL *av
528 )
529 {
530 AMBTREE *at;
531 AMBVAL *ap;
532 AMBVAL avh;
533 FVECT ck0;
534 double s;
535 int branch;
536 int i;
537
538 if (av->rad[0] <= FTINY)
539 error(CONSISTENCY, "zero ambient radius in avinsert");
540 at = &atrunk;
541 VCOPY(ck0, thescene.cuorg);
542 s = thescene.cusize;
543 while (s*(OCTSCALE/2) > av->rad[1]*ambacc) {
544 if (at->kid == NULL)
545 if ((at->kid = newambtree()) == NULL)
546 error(SYSTEM, "out of memory in avinsert");
547 s *= 0.5;
548 branch = 0;
549 for (i = 0; i < 3; i++)
550 if (av->pos[i] > ck0[i] + s) {
551 ck0[i] += s;
552 branch |= 1 << i;
553 }
554 at = at->kid + branch;
555 }
556 avh.next = at->alist; /* order by increasing level */
557 for (ap = &avh; ap->next != NULL; ap = ap->next)
558 if (ap->next->lvl >= av->lvl)
559 break;
560 av->next = ap->next;
561 ap->next = (AMBVAL*)av;
562 at->alist = avh.next;
563 }
564
565
566 #else /* ! NEWAMB */
567
568 static double sumambient(COLOR acol, RAY *r, FVECT rn, int al,
569 AMBTREE *at, FVECT c0, double s);
570 static double makeambient(COLOR acol, RAY *r, FVECT rn, int al);
571 static void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv);
572
573
574 void
575 multambient( /* compute ambient component & multiply by coef. */
576 COLOR aval,
577 RAY *r,
578 FVECT nrm
579 )
580 {
581 static int rdepth = 0; /* ambient recursion */
582 COLOR acol;
583 double d, l;
584
585 if (ambdiv <= 0) /* no ambient calculation */
586 goto dumbamb;
587 /* check number of bounces */
588 if (rdepth >= ambounce)
589 goto dumbamb;
590 /* check ambient list */
591 if (ambincl != -1 && r->ro != NULL &&
592 ambincl != inset(ambset, r->ro->omod))
593 goto dumbamb;
594
595 if (ambacc <= FTINY) { /* no ambient storage */
596 copycolor(acol, aval);
597 rdepth++;
598 d = doambient(acol, r, r->rweight, NULL, NULL);
599 rdepth--;
600 if (d <= FTINY)
601 goto dumbamb;
602 copycolor(aval, acol);
603 return;
604 }
605
606 if (tracktime) /* sort to minimize thrashing */
607 sortambvals(0);
608 /* interpolate ambient value */
609 setcolor(acol, 0.0, 0.0, 0.0);
610 d = sumambient(acol, r, nrm, rdepth,
611 &atrunk, thescene.cuorg, thescene.cusize);
612 if (d > FTINY) {
613 d = 1.0/d;
614 scalecolor(acol, d);
615 multcolor(aval, acol);
616 return;
617 }
618 rdepth++; /* need to cache new value */
619 d = makeambient(acol, r, nrm, rdepth-1);
620 rdepth--;
621 if (d > FTINY) {
622 multcolor(aval, acol); /* got new value */
623 return;
624 }
625 dumbamb: /* return global value */
626 if ((ambvwt <= 0) | (navsum == 0)) {
627 multcolor(aval, ambval);
628 return;
629 }
630 l = bright(ambval); /* average in computations */
631 if (l > FTINY) {
632 d = (log(l)*(double)ambvwt + avsum) /
633 (double)(ambvwt + navsum);
634 d = exp(d) / l;
635 scalecolor(aval, d);
636 multcolor(aval, ambval); /* apply color of ambval */
637 } else {
638 d = exp( avsum / (double)navsum );
639 scalecolor(aval, d); /* neutral color */
640 }
641 }
642
643
644 static double
645 sumambient( /* get interpolated ambient value */
646 COLOR acol,
647 RAY *r,
648 FVECT rn,
649 int al,
650 AMBTREE *at,
651 FVECT c0,
652 double s
653 )
654 {
655 double d, e1, e2, wt, wsum;
656 COLOR ct;
657 FVECT ck0;
658 int i;
659 int j;
660 AMBVAL *av;
661
662 wsum = 0.0;
663 /* do this node */
664 for (av = at->alist; av != NULL; av = av->next) {
665 double rn_dot = -2.0;
666 if (tracktime)
667 av->latick = ambclock;
668 /*
669 * Ambient level test.
670 */
671 if (av->lvl > al) /* list sorted, so this works */
672 break;
673 if (av->weight < 0.9*r->rweight)
674 continue;
675 /*
676 * Ambient radius test.
677 */
678 VSUB(ck0, av->pos, r->rop);
679 e1 = DOT(ck0, ck0) / (av->rad * av->rad);
680 if (e1 > ambacc*ambacc*1.21)
681 continue;
682 /*
683 * Direction test using closest normal.
684 */
685 d = DOT(av->dir, r->ron);
686 if (rn != r->ron) {
687 rn_dot = DOT(av->dir, rn);
688 if (rn_dot > 1.0-FTINY)
689 rn_dot = 1.0-FTINY;
690 if (rn_dot >= d-FTINY) {
691 d = rn_dot;
692 rn_dot = -2.0;
693 }
694 }
695 e2 = (1.0 - d) * r->rweight;
696 if (e2 < 0.0)
697 e2 = 0.0;
698 else if (e1 + e2 > ambacc*ambacc*1.21)
699 continue;
700 /*
701 * Ray behind test.
702 */
703 d = 0.0;
704 for (j = 0; j < 3; j++)
705 d += (r->rop[j] - av->pos[j]) *
706 (av->dir[j] + r->ron[j]);
707 if (d*0.5 < -minarad*ambacc-.001)
708 continue;
709 /*
710 * Jittering final test reduces image artifacts.
711 */
712 e1 = sqrt(e1);
713 e2 = sqrt(e2);
714 wt = e1 + e2;
715 if (wt > ambacc*(.9+.2*urand(9015+samplendx)))
716 continue;
717 /*
718 * Recompute directional error using perturbed normal
719 */
720 if (rn_dot > 0.0) {
721 e2 = sqrt((1.0 - rn_dot)*r->rweight);
722 wt = e1 + e2;
723 }
724 if (wt <= 1e-3)
725 wt = 1e3;
726 else
727 wt = 1.0 / wt;
728 wsum += wt;
729 extambient(ct, av, r->rop, rn);
730 scalecolor(ct, wt);
731 addcolor(acol, ct);
732 }
733 if (at->kid == NULL)
734 return(wsum);
735 /* do children */
736 s *= 0.5;
737 for (i = 0; i < 8; i++) {
738 for (j = 0; j < 3; j++) {
739 ck0[j] = c0[j];
740 if (1<<j & i)
741 ck0[j] += s;
742 if (r->rop[j] < ck0[j] - OCTSCALE*s)
743 break;
744 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
745 break;
746 }
747 if (j == 3)
748 wsum += sumambient(acol, r, rn, al,
749 at->kid+i, ck0, s);
750 }
751 return(wsum);
752 }
753
754
755 static double
756 makeambient( /* make a new ambient value for storage */
757 COLOR acol,
758 RAY *r,
759 FVECT rn,
760 int al
761 )
762 {
763 AMBVAL amb;
764 FVECT gp, gd;
765 int i;
766
767 amb.weight = 1.0; /* compute weight */
768 for (i = al; i-- > 0; )
769 amb.weight *= AVGREFL;
770 if (r->rweight < 0.1*amb.weight) /* heuristic override */
771 amb.weight = 1.25*r->rweight;
772 setcolor(acol, AVGREFL, AVGREFL, AVGREFL);
773 /* compute ambient */
774 amb.rad = doambient(acol, r, amb.weight, gp, gd);
775 if (amb.rad <= FTINY) {
776 setcolor(acol, 0.0, 0.0, 0.0);
777 return(0.0);
778 }
779 scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */
780 /* store value */
781 VCOPY(amb.pos, r->rop);
782 VCOPY(amb.dir, r->ron);
783 amb.lvl = al;
784 copycolor(amb.val, acol);
785 VCOPY(amb.gpos, gp);
786 VCOPY(amb.gdir, gd);
787 /* insert into tree */
788 avsave(&amb); /* and save to file */
789 if (rn != r->ron)
790 extambient(acol, &amb, r->rop, rn); /* texture */
791 return(amb.rad);
792 }
793
794
795 static void
796 extambient( /* extrapolate value at pv, nv */
797 COLOR cr,
798 AMBVAL *ap,
799 FVECT pv,
800 FVECT nv
801 )
802 {
803 FVECT v1;
804 int i;
805 double d;
806
807 d = 1.0; /* zeroeth order */
808 /* gradient due to translation */
809 for (i = 0; i < 3; i++)
810 d += ap->gpos[i]*(pv[i]-ap->pos[i]);
811 /* gradient due to rotation */
812 VCROSS(v1, ap->dir, nv);
813 d += DOT(ap->gdir, v1);
814 if (d <= 0.0) {
815 setcolor(cr, 0.0, 0.0, 0.0);
816 return;
817 }
818 copycolor(cr, ap->val);
819 scalecolor(cr, d);
820 }
821
822
823 static void
824 avinsert( /* insert ambient value in our tree */
825 AMBVAL *av
826 )
827 {
828 AMBTREE *at;
829 AMBVAL *ap;
830 AMBVAL avh;
831 FVECT ck0;
832 double s;
833 int branch;
834 int i;
835
836 if (av->rad <= FTINY)
837 error(CONSISTENCY, "zero ambient radius in avinsert");
838 at = &atrunk;
839 VCOPY(ck0, thescene.cuorg);
840 s = thescene.cusize;
841 while (s*(OCTSCALE/2) > av->rad*ambacc) {
842 if (at->kid == NULL)
843 if ((at->kid = newambtree()) == NULL)
844 error(SYSTEM, "out of memory in avinsert");
845 s *= 0.5;
846 branch = 0;
847 for (i = 0; i < 3; i++)
848 if (av->pos[i] > ck0[i] + s) {
849 ck0[i] += s;
850 branch |= 1 << i;
851 }
852 at = at->kid + branch;
853 }
854 avh.next = at->alist; /* order by increasing level */
855 for (ap = &avh; ap->next != NULL; ap = ap->next)
856 if (ap->next->lvl >= av->lvl)
857 break;
858 av->next = ap->next;
859 ap->next = (AMBVAL*)av;
860 at->alist = avh.next;
861 }
862
863 #endif /* ! NEWAMB */
864
865 /************* FOLLOWING ROUTINES SAME FOR NEW & OLD METHODS ***************/
866
867 static void
868 initambfile( /* initialize ambient file */
869 int cre8
870 )
871 {
872 extern char *progname, *octname;
873 static char *mybuf = NULL;
874
875 #ifdef F_SETLKW
876 aflock(cre8 ? F_WRLCK : F_RDLCK);
877 #endif
878 SET_FILE_BINARY(ambfp);
879 if (mybuf == NULL)
880 mybuf = (char *)bmalloc(BUFSIZ+8);
881 setbuf(ambfp, mybuf);
882 if (cre8) { /* new file */
883 newheader("RADIANCE", ambfp);
884 fprintf(ambfp, "%s -av %g %g %g -aw %d -ab %d -aa %g ",
885 progname, colval(ambval,RED),
886 colval(ambval,GRN), colval(ambval,BLU),
887 ambvwt, ambounce, ambacc);
888 fprintf(ambfp, "-ad %d -as %d -ar %d ",
889 ambdiv, ambssamp, ambres);
890 if (octname != NULL)
891 fputs(octname, ambfp);
892 fputc('\n', ambfp);
893 fprintf(ambfp, "SOFTWARE= %s\n", VersionID);
894 fputnow(ambfp);
895 fputformat(AMBFMT, ambfp);
896 fputc('\n', ambfp);
897 putambmagic(ambfp);
898 } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp))
899 error(USER, "bad ambient file");
900 }
901
902
903 static void
904 avsave( /* insert and save an ambient value */
905 AMBVAL *av
906 )
907 {
908 avinsert(avstore(av));
909 if (ambfp == NULL)
910 return;
911 if (writambval(av, ambfp) < 0)
912 goto writerr;
913 if (++nunflshed >= AMBFLUSH)
914 if (ambsync() == EOF)
915 goto writerr;
916 return;
917 writerr:
918 error(SYSTEM, "error writing to ambient file");
919 }
920
921
922 static AMBVAL *
923 avstore( /* allocate memory and store aval */
924 AMBVAL *aval
925 )
926 {
927 AMBVAL *av;
928 double d;
929
930 if ((av = newambval()) == NULL)
931 error(SYSTEM, "out of memory in avstore");
932 *av = *aval;
933 av->latick = ambclock;
934 av->next = NULL;
935 nambvals++;
936 d = bright(av->val);
937 if (d > FTINY) { /* add to log sum for averaging */
938 avsum += log(d);
939 navsum++;
940 }
941 return(av);
942 }
943
944
945 #define ATALLOCSZ 512 /* #/8 trees to allocate at once */
946
947 static AMBTREE *atfreelist = NULL; /* free ambient tree structures */
948
949
950 static AMBTREE *
951 newambtree(void) /* allocate 8 ambient tree structs */
952 {
953 AMBTREE *atp, *upperlim;
954
955 if (atfreelist == NULL) { /* get more nodes */
956 atfreelist = (AMBTREE *)malloc(ATALLOCSZ*8*sizeof(AMBTREE));
957 if (atfreelist == NULL)
958 return(NULL);
959 /* link new free list */
960 upperlim = atfreelist + 8*(ATALLOCSZ-1);
961 for (atp = atfreelist; atp < upperlim; atp += 8)
962 atp->kid = atp + 8;
963 atp->kid = NULL;
964 }
965 atp = atfreelist;
966 atfreelist = atp->kid;
967 memset((char *)atp, '\0', 8*sizeof(AMBTREE));
968 return(atp);
969 }
970
971
972 static void
973 freeambtree( /* free 8 ambient tree structs */
974 AMBTREE *atp
975 )
976 {
977 atp->kid = atfreelist;
978 atfreelist = atp;
979 }
980
981
982 static void
983 unloadatree( /* unload an ambient value tree */
984 AMBTREE *at,
985 unloadtf_t *f
986 )
987 {
988 AMBVAL *av;
989 int i;
990 /* transfer values at this node */
991 for (av = at->alist; av != NULL; av = at->alist) {
992 at->alist = av->next;
993 (*f)(av);
994 }
995 if (at->kid == NULL)
996 return;
997 for (i = 0; i < 8; i++) /* transfer and free children */
998 unloadatree(at->kid+i, f);
999 freeambtree(at->kid);
1000 at->kid = NULL;
1001 }
1002
1003
1004 static struct avl {
1005 AMBVAL *p;
1006 unsigned long t;
1007 } *avlist1; /* ambient value list with ticks */
1008 static AMBVAL **avlist2; /* memory positions for sorting */
1009 static int i_avlist; /* index for lists */
1010
1011 static int alatcmp(const void *av1, const void *av2);
1012
1013 static void
1014 avfree(AMBVAL *av)
1015 {
1016 free(av);
1017 }
1018
1019 static void
1020 av2list(
1021 AMBVAL *av
1022 )
1023 {
1024 #ifdef DEBUG
1025 if (i_avlist >= nambvals)
1026 error(CONSISTENCY, "too many ambient values in av2list1");
1027 #endif
1028 avlist1[i_avlist].p = avlist2[i_avlist] = (AMBVAL*)av;
1029 avlist1[i_avlist++].t = av->latick;
1030 }
1031
1032
1033 static int
1034 alatcmp( /* compare ambient values for MRA */
1035 const void *av1,
1036 const void *av2
1037 )
1038 {
1039 long lc = ((struct avl *)av2)->t - ((struct avl *)av1)->t;
1040 return(lc<0 ? -1 : lc>0 ? 1 : 0);
1041 }
1042
1043
1044 /* GW NOTE 2002/10/3:
1045 * I used to compare AMBVAL pointers, but found that this was the
1046 * cause of a serious consistency error with gcc, since the optimizer
1047 * uses some dangerous trick in pointer subtraction that
1048 * assumes pointers differ by exact struct size increments.
1049 */
1050 static int
1051 aposcmp( /* compare ambient value positions */
1052 const void *avp1,
1053 const void *avp2
1054 )
1055 {
1056 long diff = *(char * const *)avp1 - *(char * const *)avp2;
1057 if (diff < 0)
1058 return(-1);
1059 return(diff > 0);
1060 }
1061
1062
1063 static int
1064 avlmemi( /* find list position from address */
1065 AMBVAL *avaddr
1066 )
1067 {
1068 AMBVAL **avlpp;
1069
1070 avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2,
1071 nambvals, sizeof(AMBVAL *), &aposcmp);
1072 if (avlpp == NULL)
1073 error(CONSISTENCY, "address not found in avlmemi");
1074 return(avlpp - avlist2);
1075 }
1076
1077
1078 static void
1079 sortambvals( /* resort ambient values */
1080 int always
1081 )
1082 {
1083 AMBTREE oldatrunk;
1084 AMBVAL tav, *tap, *pnext;
1085 int i, j;
1086 /* see if it's time yet */
1087 if (!always && (ambclock++ < lastsort+sortintvl ||
1088 nambvals < SORT_THRESH))
1089 return;
1090 /*
1091 * The idea here is to minimize memory thrashing
1092 * in VM systems by improving reference locality.
1093 * We do this by periodically sorting our stored ambient
1094 * values in memory in order of most recently to least
1095 * recently accessed. This ordering was chosen so that new
1096 * ambient values (which tend to be less important) go into
1097 * higher memory with the infrequently accessed values.
1098 * Since we expect our values to need sorting less
1099 * frequently as the process continues, we double our
1100 * waiting interval after each call.
1101 * This routine is also called by setambacc() with
1102 * the "always" parameter set to 1 so that the ambient
1103 * tree will be rebuilt with the new accuracy parameter.
1104 */
1105 if (tracktime) { /* allocate pointer arrays to sort */
1106 avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *));
1107 avlist1 = (struct avl *)malloc(nambvals*sizeof(struct avl));
1108 } else {
1109 avlist2 = NULL;
1110 avlist1 = NULL;
1111 }
1112 if (avlist1 == NULL) { /* no time tracking -- rebuild tree? */
1113 if (avlist2 != NULL)
1114 free((void *)avlist2);
1115 if (always) { /* rebuild without sorting */
1116 oldatrunk = atrunk;
1117 atrunk.alist = NULL;
1118 atrunk.kid = NULL;
1119 unloadatree(&oldatrunk, &avinsert);
1120 }
1121 } else { /* sort memory by last access time */
1122 /*
1123 * Sorting memory is tricky because it isn't contiguous.
1124 * We have to sort an array of pointers by MRA and also
1125 * by memory position. We then copy values in "loops"
1126 * to minimize memory hits. Nevertheless, we will visit
1127 * everyone at least twice, and this is an expensive process
1128 * when we're thrashing, which is when we need to do it.
1129 */
1130 #ifdef DEBUG
1131 sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...",
1132 nambvals, ambclock);
1133 eputs(errmsg);
1134 #endif
1135 i_avlist = 0;
1136 unloadatree(&atrunk, &av2list); /* empty current tree */
1137 #ifdef DEBUG
1138 if (i_avlist < nambvals)
1139 error(CONSISTENCY, "missing ambient values in sortambvals");
1140 #endif
1141 qsort((char *)avlist1, nambvals, sizeof(struct avl), &alatcmp);
1142 qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), &aposcmp);
1143 for (i = 0; i < nambvals; i++) {
1144 if (avlist1[i].p == NULL)
1145 continue;
1146 tap = avlist2[i];
1147 tav = *tap;
1148 for (j = i; (pnext = avlist1[j].p) != tap;
1149 j = avlmemi(pnext)) {
1150 *(avlist2[j]) = *pnext;
1151 avinsert(avlist2[j]);
1152 avlist1[j].p = NULL;
1153 }
1154 *(avlist2[j]) = tav;
1155 avinsert(avlist2[j]);
1156 avlist1[j].p = NULL;
1157 }
1158 free((void *)avlist1);
1159 free((void *)avlist2);
1160 /* compute new sort interval */
1161 sortintvl = ambclock - lastsort;
1162 if (sortintvl >= MAX_SORT_INTVL/2)
1163 sortintvl = MAX_SORT_INTVL;
1164 else
1165 sortintvl <<= 1; /* wait twice as long next */
1166 #ifdef DEBUG
1167 eputs("done\n");
1168 #endif
1169 }
1170 if (ambclock >= MAXACLOCK)
1171 ambclock = MAXACLOCK/2;
1172 lastsort = ambclock;
1173 }
1174
1175
1176 #ifdef F_SETLKW
1177
1178 static void
1179 aflock( /* lock/unlock ambient file */
1180 int typ
1181 )
1182 {
1183 static struct flock fls; /* static so initialized to zeroes */
1184
1185 if (typ == fls.l_type) /* already called? */
1186 return;
1187 fls.l_type = typ;
1188 if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0)
1189 error(SYSTEM, "cannot (un)lock ambient file");
1190 }
1191
1192
1193 int
1194 ambsync(void) /* synchronize ambient file */
1195 {
1196 long flen;
1197 AMBVAL avs;
1198 int n;
1199
1200 if (ambfp == NULL) /* no ambient file? */
1201 return(0);
1202 /* gain appropriate access */
1203 aflock(nunflshed ? F_WRLCK : F_RDLCK);
1204 /* see if file has grown */
1205 if ((flen = lseek(fileno(ambfp), (off_t)0, SEEK_END)) < 0)
1206 goto seekerr;
1207 if ((n = flen - lastpos) > 0) { /* file has grown */
1208 if (ambinp == NULL) { /* use duplicate filedes */
1209 ambinp = fdopen(dup(fileno(ambfp)), "r");
1210 if (ambinp == NULL)
1211 error(SYSTEM, "fdopen failed in ambsync");
1212 }
1213 if (fseek(ambinp, lastpos, SEEK_SET) < 0)
1214 goto seekerr;
1215 while (n >= AMBVALSIZ) { /* load contributed values */
1216 if (!readambval(&avs, ambinp)) {
1217 sprintf(errmsg,
1218 "ambient file \"%s\" corrupted near character %ld",
1219 ambfile, flen - n);
1220 error(WARNING, errmsg);
1221 break;
1222 }
1223 avinsert(avstore(&avs));
1224 n -= AMBVALSIZ;
1225 }
1226 lastpos = flen - n;
1227 /*** seek always as safety measure
1228 if (n) ***/ /* alignment */
1229 if (lseek(fileno(ambfp), (off_t)lastpos, SEEK_SET) < 0)
1230 goto seekerr;
1231 }
1232 n = fflush(ambfp); /* calls write() at last */
1233 if (n != EOF)
1234 lastpos += (long)nunflshed*AMBVALSIZ;
1235 else if ((lastpos = lseek(fileno(ambfp), (off_t)0, SEEK_CUR)) < 0)
1236 goto seekerr;
1237
1238 aflock(F_UNLCK); /* release file */
1239 nunflshed = 0;
1240 return(n);
1241 seekerr:
1242 error(SYSTEM, "seek failed in ambsync");
1243 return -1; /* pro forma return */
1244 }
1245
1246 #else /* ! F_SETLKW */
1247
1248 int
1249 ambsync(void) /* flush ambient file */
1250 {
1251 if (ambfp == NULL)
1252 return(0);
1253 nunflshed = 0;
1254 return(fflush(ambfp));
1255 }
1256
1257 #endif /* ! F_SETLKW */
