root/radiance/ray/src/rt/ambient.c
Revision: 2.82
Committed: Sat Apr 26 02:59:16 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.81: +7 -9 lines
Fixed setambacc() routine so it works with rvu properly
2 static const char RCSid[] = "$Id: ambient.c,v 2.81 2014/04/25 23:04:16 greg Exp $";
5 * ambient.c - routines dealing with ambient (inter-reflected) component.
6 *
7 * Declarations of external symbols in ambient.h
8 */
9
10 #include "copyright.h"
11
12 #include <string.h>
13
14 #include "platform.h"
15 #include "ray.h"
16 #include "otypes.h"
17 #include "resolu.h"
18 #include "ambient.h"
19 #include "random.h"
20
21 #ifndef OCTSCALE
22 #define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */
23 #endif
24
25 extern char *shm_boundary; /* memory sharing boundary */
26
27 #ifndef MAXASET
28 #define MAXASET 4095 /* maximum number of elements in ambient set */
29 #endif
30 OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
31
32 double maxarad; /* maximum ambient radius */
33 double minarad; /* minimum ambient radius */
34
35 static AMBTREE atrunk; /* our ambient trunk node */
36
37 static FILE *ambfp = NULL; /* ambient file pointer */
38 static int nunflshed = 0; /* number of unflushed ambient values */
39
40 #ifndef SORT_THRESH
41 #ifdef SMLMEM
42 #define SORT_THRESH ((16L<<20)/sizeof(AMBVAL))
43 #else
44 #define SORT_THRESH ((64L<<20)/sizeof(AMBVAL))
45 #endif
46 #endif
47 #ifndef SORT_INTVL
48 #define SORT_INTVL (SORT_THRESH<<1)
49 #endif
50 #ifndef MAX_SORT_INTVL
51 #define MAX_SORT_INTVL (SORT_INTVL<<6)
52 #endif
53
54
55 static double qambacc = 0.; /* ambient accuracy to the 1/4 power */
56 static double avsum = 0.; /* computed ambient value sum (log) */
57 static unsigned int navsum = 0; /* number of values in avsum */
58 static unsigned int nambvals = 0; /* total number of indirect values */
59 static unsigned int nambshare = 0; /* number of values from file */
60 static unsigned long ambclock = 0; /* ambient access clock */
61 static unsigned long lastsort = 0; /* time of last value sort */
62 static long sortintvl = SORT_INTVL; /* time until next sort */
63 static FILE *ambinp = NULL; /* auxiliary file for input */
64 static long lastpos = -1; /* last flush position */
65
66 #define MAXACLOCK (1L<<30) /* clock turnover value */
67 /*
68 * Track access times unless we are sharing ambient values
69 * through memory on a multiprocessor, when we want to avoid
70 * claiming our own memory (copy on write). Go ahead anyway
71 * if more than two thirds of our values are unshared.
72 * Compile with -Dtracktime=0 to turn this code off.
73 */
74 #ifndef tracktime
75 #define tracktime (shm_boundary == NULL || nambvals > 3*nambshare)
76 #endif
77
78 #define AMBFLUSH (BUFSIZ/AMBVALSIZ)
79
80 #define newambval() (AMBVAL *)malloc(sizeof(AMBVAL))
81 #define freeav(av) free((void *)av);
82
83 static void initambfile(int creat);
84 static void avsave(AMBVAL *av);
85 static AMBVAL *avstore(AMBVAL *aval);
86 static AMBTREE *newambtree(void);
87 static void freeambtree(AMBTREE *atp);
88
89 typedef void unloadtf_t(AMBVAL *);
90 static unloadtf_t avinsert;
91 static unloadtf_t av2list;
92 static unloadtf_t avfree;
93 static void unloadatree(AMBTREE *at, unloadtf_t *f);
94
95 static int aposcmp(const void *avp1, const void *avp2);
96 static int avlmemi(AMBVAL *avaddr);
97 static void sortambvals(int always);
98
99 #ifdef F_SETLKW
100 static void aflock(int typ);
101 #endif
102
103
104 void
105 setambres( /* set ambient resolution */
106 int ar
107 )
108 {
109 ambres = ar < 0 ? 0 : ar; /* may be done already */
110 /* set min & max radii */
111 if (ar <= 0) {
112 minarad = 0;
113 maxarad = thescene.cusize / 2.0;
114 } else {
115 minarad = thescene.cusize / ar;
116 maxarad = 64 * minarad; /* heuristic */
117 if (maxarad > thescene.cusize / 2.0)
118 maxarad = thescene.cusize / 2.0;
119 }
120 if (minarad <= FTINY)
121 minarad = 10*FTINY;
122 if (maxarad <= minarad)
123 maxarad = 64 * minarad;
124 }
125
126
127 void
128 setambacc( /* set ambient accuracy */
129 double newa
130 )
131 {
132 double olda = qambacc*qambacc*qambacc*qambacc;
133
134 newa *= (newa > 0);
135 if (fabs(newa - olda) >= .05*(newa + olda)) {
136 qambacc = sqrt(sqrt(ambacc = newa));
137 if (nambvals > 0)
138 sortambvals(1); /* rebuild tree */
139 }
140 }
141
142
143 void
144 setambient(void) /* initialize calculation */
145 {
146 int readonly = 0;
147 long flen;
148 AMBVAL amb;
149 /* make sure we're fresh */
150 ambdone();
151 /* init ambient limits */
152 setambres(ambres);
153 setambacc(ambacc);
154 if (ambfile == NULL || !ambfile[0])
155 return;
156 if (ambacc <= FTINY) {
157 sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened",
158 ambfile);
159 error(WARNING, errmsg);
160 return;
161 }
162 /* open ambient file */
163 if ((ambfp = fopen(ambfile, "r+")) == NULL)
164 readonly = (ambfp = fopen(ambfile, "r")) != NULL;
165 if (ambfp != NULL) {
166 initambfile(0); /* file exists */
167 lastpos = ftell(ambfp);
168 while (readambval(&amb, ambfp))
169 avinsert(avstore(&amb));
170 nambshare = nambvals; /* share loaded values */
171 if (readonly) {
172 sprintf(errmsg,
173 "loaded %u values from read-only ambient file",
174 nambvals);
175 error(WARNING, errmsg);
176 fclose(ambfp); /* close file so no writes */
177 ambfp = NULL;
178 return; /* avoid ambsync() */
179 }
180 /* align file pointer */
181 lastpos += (long)nambvals*AMBVALSIZ;
182 flen = lseek(fileno(ambfp), (off_t)0, SEEK_END);
183 if (flen != lastpos) {
184 sprintf(errmsg,
185 "ignoring last %ld values in ambient file (corrupted)",
186 (flen - lastpos)/AMBVALSIZ);
187 error(WARNING, errmsg);
188 fseek(ambfp, lastpos, SEEK_SET);
189 #ifndef _WIN32 /* XXX we need a replacement for that one */
190 ftruncate(fileno(ambfp), (off_t)lastpos);
191 #endif
192 }
193 } else if ((ambfp = fopen(ambfile, "w+")) != NULL) {
194 initambfile(1); /* else create new file */
195 fflush(ambfp);
196 lastpos = ftell(ambfp);
197 } else {
198 sprintf(errmsg, "cannot open ambient file \"%s\"", ambfile);
199 error(SYSTEM, errmsg);
200 }
201 #ifdef getc_unlocked
202 flockfile(ambfp); /* application-level lock */
203 #endif
204 #ifdef F_SETLKW
205 aflock(F_UNLCK); /* release file */
206 #endif
207 }
208
209
210 void
211 ambdone(void) /* close ambient file and free memory */
212 {
213 if (ambfp != NULL) { /* close ambient file */
214 ambsync();
215 fclose(ambfp);
216 ambfp = NULL;
217 if (ambinp != NULL) {
218 fclose(ambinp);
219 ambinp = NULL;
220 }
221 lastpos = -1;
222 }
223 /* free ambient tree */
224 unloadatree(&atrunk, &avfree);
225 /* reset state variables */
226 avsum = 0.;
227 navsum = 0;
228 nambvals = 0;
229 nambshare = 0;
230 ambclock = 0;
231 lastsort = 0;
232 sortintvl = SORT_INTVL;
233 }
234
235
236 void
237 ambnotify( /* record new modifier */
238 OBJECT obj
239 )
240 {
241 static int hitlimit = 0;
242 OBJREC *o;
243 char **amblp;
244
245 if (obj == OVOID) { /* starting over */
246 ambset[0] = 0;
247 hitlimit = 0;
248 return;
249 }
250 o = objptr(obj);
251 if (hitlimit || !ismodifier(o->otype))
252 return;
253 for (amblp = amblist; *amblp != NULL; amblp++)
254 if (!strcmp(o->oname, *amblp)) {
255 if (ambset[0] >= MAXASET) {
256 error(WARNING, "too many modifiers in ambient list");
257 hitlimit++;
258 return; /* should this be fatal? */
259 }
260 insertelem(ambset, obj);
261 return;
262 }
263 }
264
265 /************ THE FOLLOWING ROUTINES DIFFER BETWEEN NEW & OLD ***************/
266
267 #ifdef NEWAMB
268
269 #define tfunc(lwr, x, upr) (((x)-(lwr))/((upr)-(lwr)))
270
271 static double sumambient(COLOR acol, RAY *r, FVECT rn, int al,
272 AMBTREE *at, FVECT c0, double s);
273 static int makeambient(COLOR acol, RAY *r, FVECT rn, int al);
274 static void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv,
275 FVECT uvw[3]);
276
277 void
278 multambient( /* compute ambient component & multiply by coef. */
279 COLOR aval,
280 RAY *r,
281 FVECT nrm
282 )
283 {
284 static int rdepth = 0; /* ambient recursion */
285 COLOR acol;
286 int ok;
287 double d, l;
288
289 if (ambdiv <= 0) /* no ambient calculation */
290 goto dumbamb;
291 /* check number of bounces */
292 if (rdepth >= ambounce)
293 goto dumbamb;
294 /* check ambient list */
295 if (ambincl != -1 && r->ro != NULL &&
296 ambincl != inset(ambset, r->ro->omod))
297 goto dumbamb;
298
299 if (ambacc <= FTINY) { /* no ambient storage */
300 copycolor(acol, aval);
301 rdepth++;
302 ok = doambient(acol, r, r->rweight, NULL, NULL, NULL, NULL);
303 rdepth--;
304 if (!ok)
305 goto dumbamb;
306 copycolor(aval, acol);
307 return;
308 }
309
310 if (tracktime) /* sort to minimize thrashing */
311 sortambvals(0);
312 /* interpolate ambient value */
313 setcolor(acol, 0.0, 0.0, 0.0);
314 d = sumambient(acol, r, nrm, rdepth,
315 &atrunk, thescene.cuorg, thescene.cusize);
316 if (d > FTINY) {
317 d = 1.0/d;
318 scalecolor(acol, d);
319 multcolor(aval, acol);
320 return;
321 }
322 rdepth++; /* need to cache new value */
323 ok = makeambient(acol, r, nrm, rdepth-1);
324 rdepth--;
325 if (ok) {
326 multcolor(aval, acol); /* computed new value */
327 return;
328 }
329 dumbamb: /* return global value */
330 if ((ambvwt <= 0) | (navsum == 0)) {
331 multcolor(aval, ambval);
332 return;
333 }
334 l = bright(ambval); /* average in computations */
335 if (l > FTINY) {
336 d = (log(l)*(double)ambvwt + avsum) /
337 (double)(ambvwt + navsum);
338 d = exp(d) / l;
339 scalecolor(aval, d);
340 multcolor(aval, ambval); /* apply color of ambval */
341 } else {
342 d = exp( avsum / (double)navsum );
343 scalecolor(aval, d); /* neutral color */
344 }
345 }
346
347
348 double
349 sumambient( /* get interpolated ambient value */
350 COLOR acol,
351 RAY *r,
352 FVECT rn,
353 int al,
354 AMBTREE *at,
355 FVECT c0,
356 double s
357 )
358 { /* initial limit is 10 degrees plus ambacc radians */
359 const double minangle = 10.0 * PI/180.;
360 const double maxangle = (minangle+ambacc-PI/2.)*pow(r->rweight,0.13)
361 + PI/2.;
362 double wsum = 0.0;
363 FVECT ck0;
364 int i, j;
365 AMBVAL *av;
366 /* sum this node */
367 for (av = at->alist; av != NULL; av = av->next) {
368 double d, delta_r2, delta_t2;
369 COLOR ct;
370 FVECT uvw[3];
371 /* record access */
372 if (tracktime)
373 av->latick = ambclock;
374 /*
375 * Ambient level test
376 */
377 if (av->lvl > al) /* list sorted, so this works */
378 break;
379 if (av->weight < 0.9*r->rweight)
380 continue;
381 /*
382 * Direction test using unperturbed normal
383 */
384 decodedir(uvw[2], av->ndir);
385 d = DOT(uvw[2], r->ron);
386 if (d <= 0.0) /* >= 90 degrees */
387 continue;
388 delta_r2 = 2.0 - 2.0*d; /* approx. radians^2 */
389 if (delta_r2 >= maxangle*maxangle)
390 continue;
391 /*
392 * Modified ray behind test
393 */
394 VSUB(ck0, av->pos, r->rop);
395 d = DOT(ck0, uvw[2]);
396 if (d < -minarad*qambacc-.001)
397 continue;
398 d /= av->rad[0];
399 delta_t2 = d*d;
400 if (delta_t2 >= qambacc*qambacc)
401 continue;
402 /*
403 * Elliptical radii test based on Hessian
404 */
405 decodedir(uvw[0], av->udir);
406 VCROSS(uvw[1], uvw[2], uvw[0]);
407 d = DOT(ck0, uvw[0]) / av->rad[0];
408 delta_t2 += d*d;
409 d = DOT(ck0, uvw[1]) / av->rad[1];
410 delta_t2 += d*d;
411 if (delta_t2 >= qambacc*qambacc)
412 continue;
413 /*
414 * Extrapolate value and compute final weight (hat function)
415 */
416 extambient(ct, av, r->rop, rn, uvw);
417 d = tfunc(maxangle, sqrt(delta_r2), 0.0) *
418 tfunc(qambacc, sqrt(delta_t2), 0.0);
419 scalecolor(ct, d);
420 addcolor(acol, ct);
421 wsum += d;
422 }
423 if (at->kid == NULL)
424 return(wsum);
425 /* sum children */
426 s *= 0.5;
427 for (i = 0; i < 8; i++) {
428 for (j = 0; j < 3; j++) {
429 ck0[j] = c0[j];
430 if (1<<j & i)
431 ck0[j] += s;
432 if (r->rop[j] < ck0[j] - OCTSCALE*s)
433 break;
434 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
435 break;
436 }
437 if (j == 3)
438 wsum += sumambient(acol, r, rn, al,
439 at->kid+i, ck0, s);
440 }
441 return(wsum);
442 }
443
444
445 int
446 makeambient( /* make a new ambient value for storage */
447 COLOR acol,
448 RAY *r,
449 FVECT rn,
450 int al
451 )
452 {
453 AMBVAL amb;
454 FVECT uvw[3];
455 int i;
456
457 amb.weight = 1.0; /* compute weight */
458 for (i = al; i-- > 0; )
459 amb.weight *= AVGREFL;
460 if (r->rweight < 0.1*amb.weight) /* heuristic override */
461 amb.weight = 1.25*r->rweight;
462 setcolor(acol, AVGREFL, AVGREFL, AVGREFL);
463 /* compute ambient */
464 i = doambient(acol, r, amb.weight, uvw, amb.rad, amb.gpos, amb.gdir);
465 scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */
466 if (i <= 0 || amb.rad[0] <= FTINY) /* no Hessian or zero radius */
467 return(i);
468 /* store value */
469 VCOPY(amb.pos, r->rop);
470 amb.ndir = encodedir(r->ron);
471 amb.udir = encodedir(uvw[0]);
472 amb.lvl = al;
473 copycolor(amb.val, acol);
474 /* insert into tree */
475 avsave(&amb); /* and save to file */
476 if (rn != r->ron) { /* texture */
477 VCOPY(uvw[2], r->ron);
478 extambient(acol, &amb, r->rop, rn, uvw);
479 }
480 return(1);
481 }
482
483
484 void
485 extambient( /* extrapolate value at pv, nv */
486 COLOR cr,
487 AMBVAL *ap,
488 FVECT pv,
489 FVECT nv,
490 FVECT uvw[3]
491 )
492 {
493 static FVECT my_uvw[3];
494 FVECT v1;
495 int i;
496 double d = 1.0; /* zeroeth order */
497
498 if (uvw == NULL) { /* need local coordinates? */
499 decodedir(my_uvw[2], ap->ndir);
500 decodedir(my_uvw[0], ap->udir);
501 VCROSS(my_uvw[1], my_uvw[2], my_uvw[0]);
502 uvw = my_uvw;
503 }
504 for (i = 3; i--; ) /* gradient due to translation */
505 d += (pv[i] - ap->pos[i]) *
506 (ap->gpos[0]*uvw[0][i] + ap->gpos[1]*uvw[1][i]);
507
508 VCROSS(v1, uvw[2], nv); /* gradient due to rotation */
509 for (i = 3; i--; )
510 d += v1[i] * (ap->gdir[0]*uvw[0][i] + ap->gdir[1]*uvw[1][i]);
511
512 if (d <= 0.0) {
513 setcolor(cr, 0.0, 0.0, 0.0);
514 return;
515 }
516 copycolor(cr, ap->val);
517 scalecolor(cr, d);
518 }
519
520
521 static void
522 avinsert( /* insert ambient value in our tree */
523 AMBVAL *av
524 )
525 {
526 AMBTREE *at;
527 AMBVAL *ap;
528 AMBVAL avh;
529 FVECT ck0;
530 double s;
531 int branch;
532 int i;
533
534 if (av->rad[0] <= FTINY)
535 error(CONSISTENCY, "zero ambient radius in avinsert");
536 at = &atrunk;
537 VCOPY(ck0, thescene.cuorg);
538 s = thescene.cusize;
539 while (s*(OCTSCALE/2) > av->rad[1]*qambacc) {
540 if (at->kid == NULL)
541 if ((at->kid = newambtree()) == NULL)
542 error(SYSTEM, "out of memory in avinsert");
543 s *= 0.5;
544 branch = 0;
545 for (i = 0; i < 3; i++)
546 if (av->pos[i] > ck0[i] + s) {
547 ck0[i] += s;
548 branch |= 1 << i;
549 }
550 at = at->kid + branch;
551 }
552 avh.next = at->alist; /* order by increasing level */
553 for (ap = &avh; ap->next != NULL; ap = ap->next)
554 if (ap->next->lvl >= av->lvl)
555 break;
556 av->next = ap->next;
557 ap->next = (AMBVAL*)av;
558 at->alist = avh.next;
559 }
560
561
562 #else /* ! NEWAMB */
563
564 static double sumambient(COLOR acol, RAY *r, FVECT rn, int al,
565 AMBTREE *at, FVECT c0, double s);
566 static double makeambient(COLOR acol, RAY *r, FVECT rn, int al);
567 static void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv);
568
569
570 void
571 multambient( /* compute ambient component & multiply by coef. */
572 COLOR aval,
573 RAY *r,
574 FVECT nrm
575 )
576 {
577 static int rdepth = 0; /* ambient recursion */
578 COLOR acol;
579 double d, l;
580
581 if (ambdiv <= 0) /* no ambient calculation */
582 goto dumbamb;
583 /* check number of bounces */
584 if (rdepth >= ambounce)
585 goto dumbamb;
586 /* check ambient list */
587 if (ambincl != -1 && r->ro != NULL &&
588 ambincl != inset(ambset, r->ro->omod))
589 goto dumbamb;
590
591 if (ambacc <= FTINY) { /* no ambient storage */
592 copycolor(acol, aval);
593 rdepth++;
594 d = doambient(acol, r, r->rweight, NULL, NULL);
595 rdepth--;
596 if (d <= FTINY)
597 goto dumbamb;
598 copycolor(aval, acol);
599 return;
600 }
601
602 if (tracktime) /* sort to minimize thrashing */
603 sortambvals(0);
604 /* interpolate ambient value */
605 setcolor(acol, 0.0, 0.0, 0.0);
606 d = sumambient(acol, r, nrm, rdepth,
607 &atrunk, thescene.cuorg, thescene.cusize);
608 if (d > FTINY) {
609 d = 1.0/d;
610 scalecolor(acol, d);
611 multcolor(aval, acol);
612 return;
613 }
614 rdepth++; /* need to cache new value */
615 d = makeambient(acol, r, nrm, rdepth-1);
616 rdepth--;
617 if (d > FTINY) {
618 multcolor(aval, acol); /* got new value */
619 return;
620 }
621 dumbamb: /* return global value */
622 if ((ambvwt <= 0) | (navsum == 0)) {
623 multcolor(aval, ambval);
624 return;
625 }
626 l = bright(ambval); /* average in computations */
627 if (l > FTINY) {
628 d = (log(l)*(double)ambvwt + avsum) /
629 (double)(ambvwt + navsum);
630 d = exp(d) / l;
631 scalecolor(aval, d);
632 multcolor(aval, ambval); /* apply color of ambval */
633 } else {
634 d = exp( avsum / (double)navsum );
635 scalecolor(aval, d); /* neutral color */
636 }
637 }
638
639
640 static double
641 sumambient( /* get interpolated ambient value */
642 COLOR acol,
643 RAY *r,
644 FVECT rn,
645 int al,
646 AMBTREE *at,
647 FVECT c0,
648 double s
649 )
650 {
651 double d, e1, e2, wt, wsum;
652 COLOR ct;
653 FVECT ck0;
654 int i;
655 int j;
656 AMBVAL *av;
657
658 wsum = 0.0;
659 /* do this node */
660 for (av = at->alist; av != NULL; av = av->next) {
661 double rn_dot = -2.0;
662 if (tracktime)
663 av->latick = ambclock;
664 /*
665 * Ambient level test.
666 */
667 if (av->lvl > al) /* list sorted, so this works */
668 break;
669 if (av->weight < 0.9*r->rweight)
670 continue;
671 /*
672 * Ambient radius test.
673 */
674 VSUB(ck0, av->pos, r->rop);
675 e1 = DOT(ck0, ck0) / (av->rad * av->rad);
676 if (e1 > ambacc*ambacc*1.21)
677 continue;
678 /*
679 * Direction test using closest normal.
680 */
681 d = DOT(av->dir, r->ron);
682 if (rn != r->ron) {
683 rn_dot = DOT(av->dir, rn);
684 if (rn_dot > 1.0-FTINY)
685 rn_dot = 1.0-FTINY;
686 if (rn_dot >= d-FTINY) {
687 d = rn_dot;
688 rn_dot = -2.0;
689 }
690 }
691 e2 = (1.0 - d) * r->rweight;
692 if (e2 < 0.0)
693 e2 = 0.0;
694 else if (e1 + e2 > ambacc*ambacc*1.21)
695 continue;
696 /*
697 * Ray behind test.
698 */
699 d = 0.0;
700 for (j = 0; j < 3; j++)
701 d += (r->rop[j] - av->pos[j]) *
702 (av->dir[j] + r->ron[j]);
703 if (d*0.5 < -minarad*ambacc-.001)
704 continue;
705 /*
706 * Jittering final test reduces image artifacts.
707 */
708 e1 = sqrt(e1);
709 e2 = sqrt(e2);
710 wt = e1 + e2;
711 if (wt > ambacc*(.9+.2*urand(9015+samplendx)))
712 continue;
713 /*
714 * Recompute directional error using perturbed normal
715 */
716 if (rn_dot > 0.0) {
717 e2 = sqrt((1.0 - rn_dot)*r->rweight);
718 wt = e1 + e2;
719 }
720 if (wt <= 1e-3)
721 wt = 1e3;
722 else
723 wt = 1.0 / wt;
724 wsum += wt;
725 extambient(ct, av, r->rop, rn);
726 scalecolor(ct, wt);
727 addcolor(acol, ct);
728 }
729 if (at->kid == NULL)
730 return(wsum);
731 /* do children */
732 s *= 0.5;
733 for (i = 0; i < 8; i++) {
734 for (j = 0; j < 3; j++) {
735 ck0[j] = c0[j];
736 if (1<<j & i)
737 ck0[j] += s;
738 if (r->rop[j] < ck0[j] - OCTSCALE*s)
739 break;
740 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
741 break;
742 }
743 if (j == 3)
744 wsum += sumambient(acol, r, rn, al,
745 at->kid+i, ck0, s);
746 }
747 return(wsum);
748 }
749
750
751 static double
752 makeambient( /* make a new ambient value for storage */
753 COLOR acol,
754 RAY *r,
755 FVECT rn,
756 int al
757 )
758 {
759 AMBVAL amb;
760 FVECT gp, gd;
761 int i;
762
763 amb.weight = 1.0; /* compute weight */
764 for (i = al; i-- > 0; )
765 amb.weight *= AVGREFL;
766 if (r->rweight < 0.1*amb.weight) /* heuristic override */
767 amb.weight = 1.25*r->rweight;
768 setcolor(acol, AVGREFL, AVGREFL, AVGREFL);
769 /* compute ambient */
770 amb.rad = doambient(acol, r, amb.weight, gp, gd);
771 if (amb.rad <= FTINY) {
772 setcolor(acol, 0.0, 0.0, 0.0);
773 return(0.0);
774 }
775 scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */
776 /* store value */
777 VCOPY(amb.pos, r->rop);
778 VCOPY(amb.dir, r->ron);
779 amb.lvl = al;
780 copycolor(amb.val, acol);
781 VCOPY(amb.gpos, gp);
782 VCOPY(amb.gdir, gd);
783 /* insert into tree */
784 avsave(&amb); /* and save to file */
785 if (rn != r->ron)
786 extambient(acol, &amb, r->rop, rn); /* texture */
787 return(amb.rad);
788 }
789
790
791 static void
792 extambient( /* extrapolate value at pv, nv */
793 COLOR cr,
794 AMBVAL *ap,
795 FVECT pv,
796 FVECT nv
797 )
798 {
799 FVECT v1;
800 int i;
801 double d;
802
803 d = 1.0; /* zeroeth order */
804 /* gradient due to translation */
805 for (i = 0; i < 3; i++)
806 d += ap->gpos[i]*(pv[i]-ap->pos[i]);
807 /* gradient due to rotation */
808 VCROSS(v1, ap->dir, nv);
809 d += DOT(ap->gdir, v1);
810 if (d <= 0.0) {
811 setcolor(cr, 0.0, 0.0, 0.0);
812 return;
813 }
814 copycolor(cr, ap->val);
815 scalecolor(cr, d);
816 }
817
818
819 static void
820 avinsert( /* insert ambient value in our tree */
821 AMBVAL *av
822 )
823 {
824 AMBTREE *at;
825 AMBVAL *ap;
826 AMBVAL avh;
827 FVECT ck0;
828 double s;
829 int branch;
830 int i;
831
832 if (av->rad <= FTINY)
833 error(CONSISTENCY, "zero ambient radius in avinsert");
834 at = &atrunk;
835 VCOPY(ck0, thescene.cuorg);
836 s = thescene.cusize;
837 while (s*(OCTSCALE/2) > av->rad*ambacc) {
838 if (at->kid == NULL)
839 if ((at->kid = newambtree()) == NULL)
840 error(SYSTEM, "out of memory in avinsert");
841 s *= 0.5;
842 branch = 0;
843 for (i = 0; i < 3; i++)
844 if (av->pos[i] > ck0[i] + s) {
845 ck0[i] += s;
846 branch |= 1 << i;
847 }
848 at = at->kid + branch;
849 }
850 avh.next = at->alist; /* order by increasing level */
851 for (ap = &avh; ap->next != NULL; ap = ap->next)
852 if (ap->next->lvl >= av->lvl)
853 break;
854 av->next = ap->next;
855 ap->next = (AMBVAL*)av;
856 at->alist = avh.next;
857 }
858
859 #endif /* ! NEWAMB */
860
861 /************* FOLLOWING ROUTINES SAME FOR NEW & OLD METHODS ***************/
862
863 static void
864 initambfile( /* initialize ambient file */
865 int cre8
866 )
867 {
868 extern char *progname, *octname;
869 static char *mybuf = NULL;
870
871 #ifdef F_SETLKW
872 aflock(cre8 ? F_WRLCK : F_RDLCK);
873 #endif
874 SET_FILE_BINARY(ambfp);
875 if (mybuf == NULL)
876 mybuf = (char *)bmalloc(BUFSIZ+8);
877 setbuf(ambfp, mybuf);
878 if (cre8) { /* new file */
879 newheader("RADIANCE", ambfp);
880 fprintf(ambfp, "%s -av %g %g %g -aw %d -ab %d -aa %g ",
881 progname, colval(ambval,RED),
882 colval(ambval,GRN), colval(ambval,BLU),
883 ambvwt, ambounce, ambacc);
884 fprintf(ambfp, "-ad %d -as %d -ar %d ",
885 ambdiv, ambssamp, ambres);
886 if (octname != NULL)
887 fputs(octname, ambfp);
888 fputc('\n', ambfp);
889 fprintf(ambfp, "SOFTWARE= %s\n", VersionID);
890 fputnow(ambfp);
891 fputformat(AMBFMT, ambfp);
892 fputc('\n', ambfp);
893 putambmagic(ambfp);
894 } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp))
895 error(USER, "bad ambient file");
896 }
897
898
899 static void
900 avsave( /* insert and save an ambient value */
901 AMBVAL *av
902 )
903 {
904 avinsert(avstore(av));
905 if (ambfp == NULL)
906 return;
907 if (writambval(av, ambfp) < 0)
908 goto writerr;
909 if (++nunflshed >= AMBFLUSH)
910 if (ambsync() == EOF)
911 goto writerr;
912 return;
913 writerr:
914 error(SYSTEM, "error writing to ambient file");
915 }
916
917
918 static AMBVAL *
919 avstore( /* allocate memory and store aval */
920 AMBVAL *aval
921 )
922 {
923 AMBVAL *av;
924 double d;
925
926 if ((av = newambval()) == NULL)
927 error(SYSTEM, "out of memory in avstore");
928 *av = *aval;
929 av->latick = ambclock;
930 av->next = NULL;
931 nambvals++;
932 d = bright(av->val);
933 if (d > FTINY) { /* add to log sum for averaging */
934 avsum += log(d);
935 navsum++;
936 }
937 return(av);
938 }
939
940
941 #define ATALLOCSZ 512 /* #/8 trees to allocate at once */
942
943 static AMBTREE *atfreelist = NULL; /* free ambient tree structures */
944
945
946 static AMBTREE *
947 newambtree(void) /* allocate 8 ambient tree structs */
948 {
949 AMBTREE *atp, *upperlim;
950
951 if (atfreelist == NULL) { /* get more nodes */
952 atfreelist = (AMBTREE *)malloc(ATALLOCSZ*8*sizeof(AMBTREE));
953 if (atfreelist == NULL)
954 return(NULL);
955 /* link new free list */
956 upperlim = atfreelist + 8*(ATALLOCSZ-1);
957 for (atp = atfreelist; atp < upperlim; atp += 8)
958 atp->kid = atp + 8;
959 atp->kid = NULL;
960 }
961 atp = atfreelist;
962 atfreelist = atp->kid;
963 memset((char *)atp, '\0', 8*sizeof(AMBTREE));
964 return(atp);
965 }
966
967
968 static void
969 freeambtree( /* free 8 ambient tree structs */
970 AMBTREE *atp
971 )
972 {
973 atp->kid = atfreelist;
974 atfreelist = atp;
975 }
976
977
978 static void
979 unloadatree( /* unload an ambient value tree */
980 AMBTREE *at,
981 unloadtf_t *f
982 )
983 {
984 AMBVAL *av;
985 int i;
986 /* transfer values at this node */
987 for (av = at->alist; av != NULL; av = at->alist) {
988 at->alist = av->next;
989 (*f)(av);
990 }
991 if (at->kid == NULL)
992 return;
993 for (i = 0; i < 8; i++) /* transfer and free children */
994 unloadatree(at->kid+i, f);
995 freeambtree(at->kid);
996 at->kid = NULL;
997 }
998
999
1000 static struct avl {
1001 AMBVAL *p;
1002 unsigned long t;
1003 } *avlist1; /* ambient value list with ticks */
1004 static AMBVAL **avlist2; /* memory positions for sorting */
1005 static int i_avlist; /* index for lists */
1006
1007 static int alatcmp(const void *av1, const void *av2);
1008
1009 static void
1010 avfree(AMBVAL *av)
1011 {
1012 free(av);
1013 }
1014
1015 static void
1016 av2list(
1017 AMBVAL *av
1018 )
1019 {
1020 #ifdef DEBUG
1021 if (i_avlist >= nambvals)
1022 error(CONSISTENCY, "too many ambient values in av2list1");
1023 #endif
1024 avlist1[i_avlist].p = avlist2[i_avlist] = (AMBVAL*)av;
1025 avlist1[i_avlist++].t = av->latick;
1026 }
1027
1028
1029 static int
1030 alatcmp( /* compare ambient values for MRA */
1031 const void *av1,
1032 const void *av2
1033 )
1034 {
1035 long lc = ((struct avl *)av2)->t - ((struct avl *)av1)->t;
1036 return(lc<0 ? -1 : lc>0 ? 1 : 0);
1037 }
1038
1039
1040 /* GW NOTE 2002/10/3:
1041 * I used to compare AMBVAL pointers, but found that this was the
1042 * cause of a serious consistency error with gcc, since the optimizer
1043 * uses some dangerous trick in pointer subtraction that
1044 * assumes pointers differ by exact struct size increments.
1045 */
1046 static int
1047 aposcmp( /* compare ambient value positions */
1048 const void *avp1,
1049 const void *avp2
1050 )
1051 {
1052 long diff = *(char * const *)avp1 - *(char * const *)avp2;
1053 if (diff < 0)
1054 return(-1);
1055 return(diff > 0);
1056 }
1057
1058
1059 static int
1060 avlmemi( /* find list position from address */
1061 AMBVAL *avaddr
1062 )
1063 {
1064 AMBVAL **avlpp;
1065
1066 avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2,
1067 nambvals, sizeof(AMBVAL *), &aposcmp);
1068 if (avlpp == NULL)
1069 error(CONSISTENCY, "address not found in avlmemi");
1070 return(avlpp - avlist2);
1071 }
1072
1073
1074 static void
1075 sortambvals( /* resort ambient values */
1076 int always
1077 )
1078 {
1079 AMBTREE oldatrunk;
1080 AMBVAL tav, *tap, *pnext;
1081 int i, j;
1082 /* see if it's time yet */
1083 if (!always && (ambclock++ < lastsort+sortintvl ||
1084 nambvals < SORT_THRESH))
1085 return;
1086 /*
1087 * The idea here is to minimize memory thrashing
1088 * in VM systems by improving reference locality.
1089 * We do this by periodically sorting our stored ambient
1090 * values in memory in order of most recently to least
1091 * recently accessed. This ordering was chosen so that new
1092 * ambient values (which tend to be less important) go into
1093 * higher memory with the infrequently accessed values.
1094 * Since we expect our values to need sorting less
1095 * frequently as the process continues, we double our
1096 * waiting interval after each call.
1097 * This routine is also called by setambacc() with
1098 * the "always" parameter set to 1 so that the ambient
1099 * tree will be rebuilt with the new accuracy parameter.
1100 */
1101 if (tracktime) { /* allocate pointer arrays to sort */
1102 avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *));
1103 avlist1 = (struct avl *)malloc(nambvals*sizeof(struct avl));
1104 } else {
1105 avlist2 = NULL;
1106 avlist1 = NULL;
1107 }
1108 if (avlist1 == NULL) { /* no time tracking -- rebuild tree? */
1109 if (avlist2 != NULL)
1110 free((void *)avlist2);
1111 if (always) { /* rebuild without sorting */
1112 oldatrunk = atrunk;
1113 atrunk.alist = NULL;
1114 atrunk.kid = NULL;
1115 unloadatree(&oldatrunk, &avinsert);
1116 }
1117 } else { /* sort memory by last access time */
1118 /*
1119 * Sorting memory is tricky because it isn't contiguous.
1120 * We have to sort an array of pointers by MRA and also
1121 * by memory position. We then copy values in "loops"
1122 * to minimize memory hits. Nevertheless, we will visit
1123 * everyone at least twice, and this is an expensive process
1124 * when we're thrashing, which is when we need to do it.
1125 */
1126 #ifdef DEBUG
1127 sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...",
1128 nambvals, ambclock);
1129 eputs(errmsg);
1130 #endif
1131 i_avlist = 0;
1132 unloadatree(&atrunk, &av2list); /* empty current tree */
1133 #ifdef DEBUG
1134 if (i_avlist < nambvals)
1135 error(CONSISTENCY, "missing ambient values in sortambvals");
1136 #endif
1137 qsort((char *)avlist1, nambvals, sizeof(struct avl), &alatcmp);
1138 qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), &aposcmp);
1139 for (i = 0; i < nambvals; i++) {
1140 if (avlist1[i].p == NULL)
1141 continue;
1142 tap = avlist2[i];
1143 tav = *tap;
1144 for (j = i; (pnext = avlist1[j].p) != tap;
1145 j = avlmemi(pnext)) {
1146 *(avlist2[j]) = *pnext;
1147 avinsert(avlist2[j]);
1148 avlist1[j].p = NULL;
1149 }
1150 *(avlist2[j]) = tav;
1151 avinsert(avlist2[j]);
1152 avlist1[j].p = NULL;
1153 }
1154 free((void *)avlist1);
1155 free((void *)avlist2);
1156 /* compute new sort interval */
1157 sortintvl = ambclock - lastsort;
1158 if (sortintvl >= MAX_SORT_INTVL/2)
1159 sortintvl = MAX_SORT_INTVL;
1160 else
1161 sortintvl <<= 1; /* wait twice as long next */
1162 #ifdef DEBUG
1163 eputs("done\n");
1164 #endif
1165 }
1166 if (ambclock >= MAXACLOCK)
1167 ambclock = MAXACLOCK/2;
1168 lastsort = ambclock;
1169 }
1170
1171
1172 #ifdef F_SETLKW
1173
1174 static void
1175 aflock( /* lock/unlock ambient file */
1176 int typ
1177 )
1178 {
1179 static struct flock fls; /* static so initialized to zeroes */
1180
1181 if (typ == fls.l_type) /* already called? */
1182 return;
1183 fls.l_type = typ;
1184 if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0)
1185 error(SYSTEM, "cannot (un)lock ambient file");
1186 }
1187
1188
1189 int
1190 ambsync(void) /* synchronize ambient file */
1191 {
1192 long flen;
1193 AMBVAL avs;
1194 int n;
1195
1196 if (ambfp == NULL) /* no ambient file? */
1197 return(0);
1198 /* gain appropriate access */
1199 aflock(nunflshed ? F_WRLCK : F_RDLCK);
1200 /* see if file has grown */
1201 if ((flen = lseek(fileno(ambfp), (off_t)0, SEEK_END)) < 0)
1202 goto seekerr;
1203 if ((n = flen - lastpos) > 0) { /* file has grown */
1204 if (ambinp == NULL) { /* use duplicate filedes */
1205 ambinp = fdopen(dup(fileno(ambfp)), "r");
1206 if (ambinp == NULL)
1207 error(SYSTEM, "fdopen failed in ambsync");
1208 }
1209 if (fseek(ambinp, lastpos, SEEK_SET) < 0)
1210 goto seekerr;
1211 while (n >= AMBVALSIZ) { /* load contributed values */
1212 if (!readambval(&avs, ambinp)) {
1213 sprintf(errmsg,
1214 "ambient file \"%s\" corrupted near character %ld",
1215 ambfile, flen - n);
1216 error(WARNING, errmsg);
1217 break;
1218 }
1219 avinsert(avstore(&avs));
1220 n -= AMBVALSIZ;
1221 }
1222 lastpos = flen - n;
1223 /*** seek always as safety measure
1224 if (n) ***/ /* alignment */
1225 if (lseek(fileno(ambfp), (off_t)lastpos, SEEK_SET) < 0)
1226 goto seekerr;
1227 }
1228 n = fflush(ambfp); /* calls write() at last */
1229 if (n != EOF)
1230 lastpos += (long)nunflshed*AMBVALSIZ;
1231 else if ((lastpos = lseek(fileno(ambfp), (off_t)0, SEEK_CUR)) < 0)
1232 goto seekerr;
1233
1234 aflock(F_UNLCK); /* release file */
1235 nunflshed = 0;
1236 return(n);
1237 seekerr:
1238 error(SYSTEM, "seek failed in ambsync");
1239 return -1; /* pro forma return */
1240 }
1241
1242 #else /* ! F_SETLKW */
1243
1244 int
1245 ambsync(void) /* flush ambient file */
1246 {
1247 if (ambfp == NULL)
1248 return(0);
1249 nunflshed = 0;
1250 return(fflush(ambfp));
1251 }
1252
1253 #endif /* ! F_SETLKW */
