1 |
/* Copyright (c) 1993 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* ambient.c - routines dealing with ambient (inter-reflected) component. |
9 |
10 |
11 |
#include "ray.h" |
12 |
13 |
#include "octree.h" |
14 |
15 |
#include "otypes.h" |
16 |
17 |
#include "ambient.h" |
18 |
19 |
#include "random.h" |
20 |
21 |
#define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */ |
22 |
23 |
typedef struct ambtree { |
24 |
AMBVAL *alist; /* ambient value list */ |
25 |
struct ambtree *kid; /* 8 child nodes */ |
26 |
} AMBTREE; /* ambient octree */ |
27 |
28 |
extern CUBE thescene; /* contains space boundaries */ |
29 |
30 |
#define MAXASET 511 /* maximum number of elements in ambient set */ |
31 |
OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */ |
32 |
33 |
double maxarad; /* maximum ambient radius */ |
34 |
double minarad; /* minimum ambient radius */ |
35 |
36 |
static AMBTREE atrunk; /* our ambient trunk node */ |
37 |
38 |
static char *ambfname = NULL; /* ambient file name */ |
39 |
static FILE *ambfp = NULL; /* ambient file pointer */ |
40 |
static int nunflshed = 0; /* number of unflushed ambient values */ |
41 |
42 |
#define AMBFLUSH (BUFSIZ/AMBVALSIZ) |
43 |
44 |
#define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL)) |
45 |
46 |
#define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE)) |
47 |
48 |
extern long ftell(), lseek(); |
49 |
static int initambfile(), avsave(), avinsert(); |
50 |
51 |
52 |
setambres(ar) /* set ambient resolution */ |
53 |
int ar; |
54 |
55 |
/* set min & max radii */ |
56 |
if (ar <= 0) { |
57 |
minarad = 0.0; |
58 |
maxarad = thescene.cusize / 2.0; |
59 |
} else { |
60 |
minarad = thescene.cusize / ar; |
61 |
maxarad = 16.0 * minarad; /* heuristic */ |
62 |
if (maxarad > thescene.cusize / 2.0) |
63 |
64 |
65 |
if (maxarad <= FTINY) |
66 |
maxarad = .001; |
67 |
68 |
69 |
70 |
setambient(afile) /* initialize calculation */ |
71 |
char *afile; |
72 |
73 |
long headlen; |
74 |
AMBVAL amb; |
75 |
/* init ambient limits */ |
76 |
setambres(ambres); |
77 |
/* open ambient file */ |
78 |
if ((ambfname = afile) != NULL) { |
79 |
if ((ambfp = fopen(afile, "r+")) != NULL) { |
80 |
initambfile(0); |
81 |
headlen = ftell(ambfp); |
82 |
while (readambval(&amb, ambfp)) |
83 |
avinsert(&amb, &atrunk, thescene.cuorg, |
84 |
thescene.cusize); |
85 |
/* align */ |
86 |
fseek(ambfp, -((ftell(ambfp)-headlen)%AMBVALSIZ), 1); |
87 |
} else if ((ambfp = fopen(afile, "w+")) != NULL) |
88 |
initambfile(1); |
89 |
else { |
90 |
sprintf(errmsg, "cannot open ambient file \"%s\"", |
91 |
afile); |
92 |
error(SYSTEM, errmsg); |
93 |
94 |
nunflshed++; /* lie */ |
95 |
ambsync(); |
96 |
97 |
98 |
99 |
100 |
ambnotify(obj) /* record new modifier */ |
101 |
OBJECT obj; |
102 |
103 |
static int hitlimit = 0; |
104 |
register OBJREC *o = objptr(obj); |
105 |
register char **amblp; |
106 |
107 |
if (hitlimit || !ismodifier(o->otype)) |
108 |
return; |
109 |
for (amblp = amblist; *amblp != NULL; amblp++) |
110 |
if (!strcmp(o->oname, *amblp)) { |
111 |
if (ambset[0] >= MAXASET) { |
112 |
error(WARNING, "too many modifiers in ambient list"); |
113 |
hitlimit++; |
114 |
return; /* should this be fatal? */ |
115 |
116 |
insertelem(ambset, obj); |
117 |
return; |
118 |
119 |
120 |
121 |
122 |
ambient(acol, r) /* compute ambient component for ray */ |
123 |
COLOR acol; |
124 |
register RAY *r; |
125 |
126 |
static int rdepth = 0; /* ambient recursion */ |
127 |
double d; |
128 |
129 |
if (ambdiv <= 0) /* no ambient calculation */ |
130 |
goto dumbamb; |
131 |
/* check number of bounces */ |
132 |
if (rdepth >= ambounce) |
133 |
goto dumbamb; |
134 |
/* check ambient list */ |
135 |
if (ambincl != -1 && r->ro != NULL && |
136 |
ambincl != inset(ambset, r->ro->omod)) |
137 |
goto dumbamb; |
138 |
139 |
if (ambacc <= FTINY) { /* no ambient storage */ |
140 |
rdepth++; |
141 |
d = doambient(acol, r, r->rweight, NULL, NULL); |
142 |
rdepth--; |
143 |
if (d == 0.0) |
144 |
goto dumbamb; |
145 |
return; |
146 |
147 |
/* get ambient value */ |
148 |
setcolor(acol, 0.0, 0.0, 0.0); |
149 |
d = sumambient(acol, r, rdepth, |
150 |
&atrunk, thescene.cuorg, thescene.cusize); |
151 |
if (d > FTINY) |
152 |
scalecolor(acol, 1.0/d); |
153 |
else { |
154 |
d = makeambient(acol, r, rdepth++); |
155 |
rdepth--; |
156 |
157 |
if (d > FTINY) |
158 |
return; |
159 |
dumbamb: /* return global value */ |
160 |
copycolor(acol, ambval); |
161 |
162 |
163 |
164 |
double |
165 |
sumambient(acol, r, al, at, c0, s) /* get interpolated ambient value */ |
166 |
COLOR acol; |
167 |
register RAY *r; |
168 |
int al; |
169 |
AMBTREE *at; |
170 |
FVECT c0; |
171 |
double s; |
172 |
173 |
double d, e1, e2, wt, wsum; |
174 |
COLOR ct; |
175 |
FVECT ck0; |
176 |
int i; |
177 |
register int j; |
178 |
register AMBVAL *av; |
179 |
/* do this node */ |
180 |
wsum = 0.0; |
181 |
for (av = at->alist; av != NULL; av = av->next) { |
182 |
183 |
* Ambient level test. |
184 |
185 |
if (av->lvl > al || av->weight < r->rweight-FTINY) |
186 |
continue; |
187 |
188 |
* Ambient radius test. |
189 |
190 |
e1 = 0.0; |
191 |
for (j = 0; j < 3; j++) { |
192 |
d = av->pos[j] - r->rop[j]; |
193 |
e1 += d * d; |
194 |
195 |
e1 /= av->rad * av->rad; |
196 |
if (e1 > ambacc*ambacc*1.21) |
197 |
continue; |
198 |
199 |
* Normal direction test. |
200 |
201 |
e2 = (1.0 - DOT(av->dir, r->ron)) * r->rweight; |
202 |
if (e2 < 0.0) e2 = 0.0; |
203 |
if (e1 + e2 > ambacc*ambacc*1.21) |
204 |
continue; |
205 |
206 |
* Ray behind test. |
207 |
208 |
d = 0.0; |
209 |
for (j = 0; j < 3; j++) |
210 |
d += (r->rop[j] - av->pos[j]) * |
211 |
(av->dir[j] + r->ron[j]); |
212 |
if (d*0.5 < -minarad*ambacc-.001) |
213 |
continue; |
214 |
215 |
* Jittering final test reduces image artifacts. |
216 |
217 |
wt = sqrt(e1) + sqrt(e2); |
218 |
wt *= .9 + .2*urand(9015+samplendx); |
219 |
if (wt > ambacc) |
220 |
continue; |
221 |
if (wt <= 1e-3) |
222 |
wt = 1e3; |
223 |
else |
224 |
wt = 1.0 / wt; |
225 |
wsum += wt; |
226 |
extambient(ct, av, r->rop, r->ron); |
227 |
scalecolor(ct, wt); |
228 |
addcolor(acol, ct); |
229 |
230 |
if (at->kid == NULL) |
231 |
return(wsum); |
232 |
/* do children */ |
233 |
s *= 0.5; |
234 |
for (i = 0; i < 8; i++) { |
235 |
236 |
ck0[j] = c0[j]; |
237 |
if (1<<j & i) |
238 |
ck0[j] += s; |
239 |
if (r->rop[j] < ck0[j] - OCTSCALE*s) |
240 |
break; |
241 |
if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s) |
242 |
break; |
243 |
244 |
if (j == 3) |
245 |
wsum += sumambient(acol, r, al, at->kid+i, ck0, s); |
246 |
247 |
return(wsum); |
248 |
249 |
250 |
251 |
double |
252 |
makeambient(acol, r, al) /* make a new ambient value */ |
253 |
COLOR acol; |
254 |
register RAY *r; |
255 |
int al; |
256 |
257 |
AMBVAL amb; |
258 |
FVECT gp, gd; |
259 |
/* compute weight */ |
260 |
amb.weight = pow(AVGREFL, (double)al); |
261 |
if (r->rweight < 0.2*amb.weight) /* heuristic */ |
262 |
amb.weight = r->rweight; |
263 |
/* compute ambient */ |
264 |
amb.rad = doambient(acol, r, amb.weight, gp, gd); |
265 |
if (amb.rad == 0.0) |
266 |
return(0.0); |
267 |
/* store it */ |
268 |
VCOPY(amb.pos, r->rop); |
269 |
VCOPY(amb.dir, r->ron); |
270 |
amb.lvl = al; |
271 |
copycolor(amb.val, acol); |
272 |
VCOPY(amb.gpos, gp); |
273 |
VCOPY(amb.gdir, gd); |
274 |
/* insert into tree */ |
275 |
avsave(&amb); /* and save to file */ |
276 |
return(amb.rad); |
277 |
278 |
279 |
280 |
extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */ |
281 |
COLOR cr; |
282 |
register AMBVAL *ap; |
283 |
FVECT pv, nv; |
284 |
285 |
FVECT v1, v2; |
286 |
register int i; |
287 |
double d; |
288 |
289 |
d = 1.0; /* zeroeth order */ |
290 |
/* gradient due to translation */ |
291 |
for (i = 0; i < 3; i++) |
292 |
d += ap->gpos[i]*(pv[i]-ap->pos[i]); |
293 |
/* gradient due to rotation */ |
294 |
VCOPY(v1, ap->dir); |
295 |
fcross(v2, v1, nv); |
296 |
d += DOT(ap->gdir, v2); |
297 |
if (d <= 0.0) { |
298 |
setcolor(cr, 0.0, 0.0, 0.0); |
299 |
return; |
300 |
301 |
copycolor(cr, ap->val); |
302 |
scalecolor(cr, d); |
303 |
304 |
305 |
306 |
static |
307 |
initambfile(creat) /* initialize ambient file */ |
308 |
int creat; |
309 |
310 |
extern char *progname, *octname, VersionID[]; |
311 |
312 |
#ifdef MSDOS |
313 |
setmode(fileno(ambfp), O_BINARY); |
314 |
#endif |
315 |
setbuf(ambfp, bmalloc(BUFSIZ)); |
316 |
if (creat) { /* new file */ |
317 |
fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ", |
318 |
progname, colval(ambval,RED), |
319 |
colval(ambval,GRN), colval(ambval,BLU), |
320 |
ambounce, ambacc); |
321 |
fprintf(ambfp, "-ad %d -as %d -ar %d %s\n", |
322 |
ambdiv, ambssamp, ambres, |
323 |
octname==NULL ? "" : octname); |
324 |
fprintf(ambfp, "SOFTWARE= %s\n", VersionID); |
325 |
fputformat(AMBFMT, ambfp); |
326 |
putc('\n', ambfp); |
327 |
putambmagic(ambfp); |
328 |
} else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp)) { |
329 |
sprintf(errmsg, "bad ambient file \"%s\"", ambfname); |
330 |
error(USER, errmsg); |
331 |
332 |
333 |
334 |
335 |
static |
336 |
avsave(av) /* insert and save an ambient value */ |
337 |
AMBVAL *av; |
338 |
339 |
avinsert(av, &atrunk, thescene.cuorg, thescene.cusize); |
340 |
if (ambfp == NULL) |
341 |
return; |
342 |
if (writambval(av, ambfp) < 0) |
343 |
goto writerr; |
344 |
if (++nunflshed >= AMBFLUSH) |
345 |
if (ambsync() == EOF) |
346 |
goto writerr; |
347 |
return; |
348 |
writerr: |
349 |
sprintf(errmsg, "error writing ambient file \"%s\"", ambfname); |
350 |
351 |
352 |
353 |
354 |
static |
355 |
avinsert(aval, at, c0, s) /* insert ambient value in a tree */ |
356 |
AMBVAL *aval; |
357 |
register AMBTREE *at; |
358 |
FVECT c0; |
359 |
double s; |
360 |
361 |
FVECT ck0; |
362 |
int branch; |
363 |
364 |
register int i; |
365 |
366 |
if ((av = newambval()) == NULL) |
367 |
goto memerr; |
368 |
copystruct(av, aval); |
369 |
VCOPY(ck0, c0); |
370 |
while (s*(OCTSCALE/2) > av->rad*ambacc) { |
371 |
372 |
if ((at->kid = newambtree()) == NULL) |
373 |
goto memerr; |
374 |
s *= 0.5; |
375 |
branch = 0; |
376 |
377 |
if (av->pos[i] > ck0[i] + s) { |
378 |
ck0[i] += s; |
379 |
branch |= 1 << i; |
380 |
381 |
at = at->kid + branch; |
382 |
383 |
av->next = at->alist; |
384 |
at->alist = av; |
385 |
return; |
386 |
memerr: |
387 |
error(SYSTEM, "out of memory in avinsert"); |
388 |
389 |
390 |
391 |
#ifdef NIX |
392 |
393 |
int |
394 |
ambsync() /* flush ambient file */ |
395 |
396 |
if (nunflshed == 0) |
397 |
return(0); |
398 |
nunflshed = 0; |
399 |
return(fflush(ambfp)); |
400 |
401 |
402 |
#else |
403 |
404 |
int |
405 |
ambsync() /* synchronize ambient file */ |
406 |
407 |
static FILE *ambinp = NULL; |
408 |
static long lastpos = -1; |
409 |
struct flock fls; |
410 |
long flen; |
411 |
AMBVAL avs; |
412 |
register int n; |
413 |
414 |
415 |
return(0); |
416 |
/* gain exclusive access */ |
417 |
fls.l_type = F_WRLCK; |
418 |
fls.l_whence = 0; |
419 |
fls.l_start = 0L; |
420 |
fls.l_len = 0L; |
421 |
if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0) |
422 |
error(SYSTEM, "cannot lock ambient file"); |
423 |
if (lastpos < 0) /* initializing */ |
424 |
goto syncend; |
425 |
/* see if file has grown */ |
426 |
if ((flen = lseek(fileno(ambfp), 0L, 2)) < 0) |
427 |
error(SYSTEM, "cannot seek on ambient file"); |
428 |
if (n = flen - lastpos) { /* file has grown */ |
429 |
if (ambinp == NULL) { |
430 |
ambinp = fopen(ambfname, "r"); |
431 |
if (ambinp == NULL) |
432 |
error(SYSTEM, "fopen failed in ambsync"); |
433 |
434 |
if (fseek(ambinp, lastpos, 0) < 0) |
435 |
error(SYSTEM, "fseek failed in ambsync"); |
436 |
while (n >= AMBVALSIZ) { /* load contributed values */ |
437 |
readambval(&avs, ambinp); |
438 |
avinsert(&avs,&atrunk,thescene.cuorg,thescene.cusize); |
439 |
n -= AMBVALSIZ; |
440 |
441 |
if (n) /* alignment */ |
442 |
lseek(fileno(ambfp), flen-n, 0); |
443 |
444 |
syncend: |
445 |
n = fflush(ambfp); /* calls write() at last */ |
446 |
lastpos = lseek(fileno(ambfp), 0L, 1); |
447 |
fls.l_type = F_UNLCK; /* release file */ |
448 |
fcntl(fileno(ambfp), F_SETLKW, &fls); |
449 |
nunflshed = 0; |
450 |
return(n); |
451 |
452 |
453 |
#endif |
