root/radiance/ray/src/rt/ambient.c
Revision: 2.11
Committed: Thu Jul 16 19:44:46 1992 UTC (31 years, 11 months ago) by greg
added sync() call to avoid NFS buffering
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * ambient.c - routines dealing with ambient (inter-reflected) component.
9 *
10 * 5/9/86
11 */
12
13 #include "ray.h"
14
15 #include "octree.h"
16
17 #include "otypes.h"
18
19 #include "ambient.h"
20
21 #include "random.h"
22
23 #define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */
24
25 typedef struct ambtree {
26 AMBVAL *alist; /* ambient value list */
27 struct ambtree *kid; /* 8 child nodes */
28 } AMBTREE; /* ambient octree */
29
30 extern CUBE thescene; /* contains space boundaries */
31
32 #define MAXASET 511 /* maximum number of elements in ambient set */
33 OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
34
35 double maxarad; /* maximum ambient radius */
36 double minarad; /* minimum ambient radius */
37
38 static AMBTREE atrunk; /* our ambient trunk node */
39
40 static FILE *ambfp = NULL; /* ambient file pointer */
41
42 #define AMBFLUSH (BUFSIZ/AMBVALSIZ)
43
44 #define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL))
45
46 #define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE))
47
48 extern long ftell(), lseek();
49 static int initambfile(), avsave(), avinsert(), ambsync();
50
51
52 setambres(ar) /* set ambient resolution */
53 int ar;
54 {
55 /* set min & max radii */
56 if (ar <= 0) {
57 minarad = 0.0;
58 maxarad = thescene.cusize / 2.0;
59 } else {
60 minarad = thescene.cusize / ar;
61 maxarad = 16.0 * minarad; /* heuristic */
62 if (maxarad > thescene.cusize / 2.0)
63 maxarad = thescene.cusize / 2.0;
64 }
65 if (maxarad <= FTINY)
66 maxarad = .001;
67 }
68
69
70 setambient(afile) /* initialize calculation */
71 char *afile;
72 {
73 long headlen;
74 AMBVAL amb;
75 /* init ambient limits */
76 setambres(ambres);
77 /* open ambient file */
78 if (afile != NULL)
79 if ((ambfp = fopen(afile, "r+")) != NULL) {
80 initambfile(0);
81 headlen = ftell(ambfp);
82 while (readambval(&amb, ambfp))
83 avinsert(&amb, &atrunk, thescene.cuorg,
84 thescene.cusize);
85 /* align */
86 fseek(ambfp, -((ftell(ambfp)-headlen)%AMBVALSIZ), 1);
87 } else if ((ambfp = fopen(afile, "w+")) != NULL)
88 initambfile(1);
89 else {
90 sprintf(errmsg, "cannot open ambient file \"%s\"",
91 afile);
92 error(SYSTEM, errmsg);
93 }
94 }
95
96
97 ambnotify(obj) /* record new modifier */
98 OBJECT obj;
99 {
100 static int hitlimit = 0;
101 register OBJREC *o = objptr(obj);
102 register char **amblp;
103
104 if (hitlimit || !ismodifier(o->otype))
105 return;
106 for (amblp = amblist; *amblp != NULL; amblp++)
107 if (!strcmp(o->oname, *amblp)) {
108 if (ambset[0] >= MAXASET) {
109 error(WARNING, "too many modifiers in ambient list");
110 hitlimit++;
111 return; /* should this be fatal? */
112 }
113 insertelem(ambset, obj);
114 return;
115 }
116 }
117
118
119 ambient(acol, r) /* compute ambient component for ray */
120 COLOR acol;
121 register RAY *r;
122 {
123 static int rdepth = 0; /* ambient recursion */
124 double d;
125
126 if (ambdiv <= 0) /* no ambient calculation */
127 goto dumbamb;
128 /* check number of bounces */
129 if (rdepth >= ambounce)
130 goto dumbamb;
131 /* check ambient list */
132 if (ambincl != -1 && r->ro != NULL &&
133 ambincl != inset(ambset, r->ro->omod))
134 goto dumbamb;
135
136 if (ambacc <= FTINY) { /* no ambient storage */
137 rdepth++;
138 d = doambient(acol, r, r->rweight, NULL, NULL);
139 rdepth--;
140 if (d == 0.0)
141 goto dumbamb;
142 return;
143 }
144 /* get ambient value */
145 setcolor(acol, 0.0, 0.0, 0.0);
146 d = sumambient(acol, r, rdepth,
147 &atrunk, thescene.cuorg, thescene.cusize);
148 if (d > FTINY)
149 scalecolor(acol, 1.0/d);
150 else {
151 d = makeambient(acol, r, rdepth++);
152 rdepth--;
153 }
154 if (d > FTINY)
155 return;
156 dumbamb: /* return global value */
157 copycolor(acol, ambval);
158 }
159
160
161 double
162 sumambient(acol, r, al, at, c0, s) /* get interpolated ambient value */
163 COLOR acol;
164 register RAY *r;
165 int al;
166 AMBTREE *at;
167 FVECT c0;
168 double s;
169 {
170 extern double sqrt();
171 double d, e1, e2, wt, wsum;
172 COLOR ct;
173 FVECT ck0;
174 int i;
175 register int j;
176 register AMBVAL *av;
177 /* do this node */
178 wsum = 0.0;
179 for (av = at->alist; av != NULL; av = av->next) {
180 /*
181 * Ambient level test.
182 */
183 if (av->lvl > al || av->weight < r->rweight-FTINY)
184 continue;
185 /*
186 * Ambient radius test.
187 */
188 e1 = 0.0;
189 for (j = 0; j < 3; j++) {
190 d = av->pos[j] - r->rop[j];
191 e1 += d * d;
192 }
193 e1 /= av->rad * av->rad;
194 if (e1 > ambacc*ambacc*1.21)
195 continue;
196 /*
197 * Normal direction test.
198 */
199 e2 = (1.0 - DOT(av->dir, r->ron)) * r->rweight;
200 if (e2 < 0.0) e2 = 0.0;
201 if (e1 + e2 > ambacc*ambacc*1.21)
202 continue;
203 /*
204 * Ray behind test.
205 */
206 d = 0.0;
207 for (j = 0; j < 3; j++)
208 d += (r->rop[j] - av->pos[j]) *
209 (av->dir[j] + r->ron[j]);
210 if (d*0.5 < -minarad*ambacc-.001)
211 continue;
212 /*
213 * Jittering final test reduces image artifacts.
214 */
215 wt = sqrt(e1) + sqrt(e2);
216 wt *= .9 + .2*urand(9015+samplendx);
217 if (wt > ambacc)
218 continue;
219 if (wt <= 1e-3)
220 wt = 1e3;
221 else
222 wt = 1.0 / wt;
223 wsum += wt;
224 extambient(ct, av, r->rop, r->ron);
225 scalecolor(ct, wt);
226 addcolor(acol, ct);
227 }
228 if (at->kid == NULL)
229 return(wsum);
230 /* do children */
231 s *= 0.5;
232 for (i = 0; i < 8; i++) {
233 for (j = 0; j < 3; j++) {
234 ck0[j] = c0[j];
235 if (1<<j & i)
236 ck0[j] += s;
237 if (r->rop[j] < ck0[j] - OCTSCALE*s)
238 break;
239 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
240 break;
241 }
242 if (j == 3)
243 wsum += sumambient(acol, r, al, at->kid+i, ck0, s);
244 }
245 return(wsum);
246 }
247
248
249 double
250 makeambient(acol, r, al) /* make a new ambient value */
251 COLOR acol;
252 register RAY *r;
253 int al;
254 {
255 AMBVAL amb;
256 FVECT gp, gd;
257 /* compute weight */
258 amb.weight = pow(AVGREFL, (double)al);
259 if (r->rweight < 0.2*amb.weight) /* heuristic */
260 amb.weight = r->rweight;
261 /* compute ambient */
262 amb.rad = doambient(acol, r, amb.weight, gp, gd);
263 if (amb.rad == 0.0)
264 return(0.0);
265 /* store it */
266 VCOPY(amb.pos, r->rop);
267 VCOPY(amb.dir, r->ron);
268 amb.lvl = al;
269 copycolor(amb.val, acol);
270 VCOPY(amb.gpos, gp);
271 VCOPY(amb.gdir, gd);
272 /* insert into tree */
273 avsave(&amb); /* and save to file */
274 return(amb.rad);
275 }
276
277
278 extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */
279 COLOR cr;
280 register AMBVAL *ap;
281 FVECT pv, nv;
282 {
283 FVECT v1, v2;
284 register int i;
285 double d;
286
287 d = 1.0; /* zeroeth order */
288 /* gradient due to translation */
289 for (i = 0; i < 3; i++)
290 d += ap->gpos[i]*(pv[i]-ap->pos[i]);
291 /* gradient due to rotation */
292 VCOPY(v1, ap->dir);
293 fcross(v2, v1, nv);
294 d += DOT(ap->gdir, v2);
295 if (d <= 0.0) {
296 setcolor(cr, 0.0, 0.0, 0.0);
297 return;
298 }
299 copycolor(cr, ap->val);
300 scalecolor(cr, d);
301 }
302
303
304 static
305 initambfile(creat) /* initialize ambient file */
306 int creat;
307 {
308 extern char *progname, *octname, VersionID[];
309
310 setbuf(ambfp, bmalloc(BUFSIZ));
311 if (creat) { /* new file */
312 fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ",
313 progname, colval(ambval,RED),
314 colval(ambval,GRN), colval(ambval,BLU),
315 ambounce, ambacc);
316 fprintf(ambfp, "-ad %d -as %d -ar %d %s\n",
317 ambdiv, ambssamp, ambres,
318 octname==NULL ? "" : octname);
319 fprintf(ambfp, "SOFTWARE= %s\n", VersionID);
320 fputformat(AMBFMT, ambfp);
321 putc('\n', ambfp);
322 putambmagic(ambfp);
323 fflush(ambfp);
324 #ifndef NIX
325 sync(); /* protect against NFS buffering */
326 #endif
327 } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp))
328 error(USER, "bad ambient file");
329 }
330
331
332 static
333 avsave(av) /* insert and save an ambient value */
334 AMBVAL *av;
335 {
336 static int nunflshed = 0;
337
338 avinsert(av, &atrunk, thescene.cuorg, thescene.cusize);
339 if (ambfp == NULL)
340 return;
341 if (writambval(av, ambfp) < 0)
342 goto writerr;
343 if (++nunflshed >= AMBFLUSH) {
344 if (ambsync() == EOF)
345 goto writerr;
346 nunflshed = 0;
347 }
348 return;
349 writerr:
350 error(SYSTEM, "error writing ambient file");
351 }
352
353
354 static
355 avinsert(aval, at, c0, s) /* insert ambient value in a tree */
356 AMBVAL *aval;
357 register AMBTREE *at;
358 FVECT c0;
359 double s;
360 {
361 FVECT ck0;
362 int branch;
363 register AMBVAL *av;
364 register int i;
365
366 if ((av = newambval()) == NULL)
367 goto memerr;
368 copystruct(av, aval);
369 VCOPY(ck0, c0);
370 while (s*(OCTSCALE/2) > av->rad*ambacc) {
371 if (at->kid == NULL)
372 if ((at->kid = newambtree()) == NULL)
373 goto memerr;
374 s *= 0.5;
375 branch = 0;
376 for (i = 0; i < 3; i++)
377 if (av->pos[i] > ck0[i] + s) {
378 ck0[i] += s;
379 branch |= 1 << i;
380 }
381 at = at->kid + branch;
382 }
383 av->next = at->alist;
384 at->alist = av;
385 return;
386 memerr:
387 error(SYSTEM, "out of memory in avinsert");
388 }
389
390
391 #ifdef NIX
392
393 static
394 ambsync() /* flush ambient file */
395 {
396 return(fflush(ambfp));
397 }
398
399 #else
400
401 #include <fcntl.h>
402 #include <sys/types.h>
403 #include <sys/stat.h>
404
405 static
406 ambsync() /* synchronize ambient file */
407 {
408 static FILE *ambinp = NULL;
409 struct flock fls;
410 struct stat sts;
411 AMBVAL avs;
412 long lastpos, flen;
413 register int n;
414 /* gain exclusive access */
415 fls.l_type = F_WRLCK;
416 fls.l_whence = 0;
417 fls.l_start = 0L;
418 fls.l_len = 0L;
419 if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0)
420 error(SYSTEM, "cannot lock ambient file");
421 /* see if file has grown */
422 lastpos = lseek(fileno(ambfp), 0L, 1); /* get previous position */
423 if (fstat(fileno(ambfp), &sts) < 0) /* get current length */
424 error(SYSTEM, "cannot stat ambient file");
425 flen = sts.st_size;
426 if (n = (flen - lastpos)/AMBVALSIZ) { /* file has grown */
427 if (ambinp == NULL) /* use duplicate file */
428 ambinp = fdopen(dup(fileno(ambfp)), "r");
429 while (n--) { /* load contributed values */
430 readambval(&avs, ambinp);
431 avinsert(&avs,&atrunk,thescene.cuorg,thescene.cusize);
432 } /* moves shared file pointer */
433 if (n = (flen - lastpos)%AMBVALSIZ) /* alignment */
434 lseek(fileno(ambfp), flen-n, 0);
435 }
436 n = fflush(ambfp); /* calls write() at last */
437 fls.l_type = F_UNLCK; /* release file */
438 fcntl(fileno(ambfp), F_SETLKW, &fls);
439 return(n);
440 }
441
442 #endif
