--- ray/src/rt/ambient.c 1992/07/16 13:37:12 2.7 +++ ray/src/rt/ambient.c 1992/07/16 19:44:46 2.11 @@ -7,9 +7,6 @@ static char SCCSid[] = "$SunId$ LBL"; /* * ambient.c - routines dealing with ambient (inter-reflected) component. * - * The macro AMBFLUSH (if defined) is the number of ambient values - * to wait before flushing to the ambient file. - * * 5/9/86 */ @@ -41,8 +38,6 @@ double minarad; /* minimum ambient radius */ static AMBTREE atrunk; /* our ambient trunk node */ static FILE *ambfp = NULL; /* ambient file pointer */ -static char *afname; /* ambient file name */ -static long ambheadlen; /* length of ambient file header */ #define AMBFLUSH (BUFSIZ/AMBVALSIZ) @@ -51,6 +46,7 @@ static long ambheadlen; /* length of ambient file hea #define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE)) extern long ftell(), lseek(); +static int initambfile(), avsave(), avinsert(), ambsync(); setambres(ar) /* set ambient resolution */ @@ -74,19 +70,21 @@ int ar; setambient(afile) /* initialize calculation */ char *afile; { + long headlen; AMBVAL amb; /* init ambient limits */ setambres(ambres); /* open ambient file */ - if ((afname = afile) != NULL) + if (afile != NULL) if ((ambfp = fopen(afile, "r+")) != NULL) { initambfile(0); + headlen = ftell(ambfp); while (readambval(&amb, ambfp)) avinsert(&amb, &atrunk, thescene.cuorg, thescene.cusize); /* align */ - fseek(ambfp, -((ftell(ambfp)-ambheadlen)%AMBVALSIZ), 1); - } else if ((ambfp = fopen(afile, "w")) != NULL) + fseek(ambfp, -((ftell(ambfp)-headlen)%AMBVALSIZ), 1); + } else if ((ambfp = fopen(afile, "w+")) != NULL) initambfile(1); else { sprintf(errmsg, "cannot open ambient file \"%s\"", @@ -96,33 +94,6 @@ char *afile; } -initambfile(creat) /* initialize ambient file */ -int creat; -{ - extern char *progname, *octname; - - setbuf(ambfp, bmalloc(BUFSIZ)); - if (creat) { /* new file */ - fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ", - progname, colval(ambval,RED), - colval(ambval,GRN), colval(ambval,BLU), - ambounce, ambacc); - fprintf(ambfp, "-ad %d -as %d -ar %d %s\n", - ambdiv, ambssamp, ambres, - octname==NULL ? "" : octname); - fputformat(AMBFMT, ambfp); - putc('\n', ambfp); - putambmagic(ambfp); - fflush(ambfp); - } else if (checkheader(ambfp, AMBFMT, NULL) < 0 - || !hasambmagic(ambfp)) { - sprintf(errmsg, "\"%s\" is not an ambient file", afname); - error(USER, afname); - } - ambheadlen = ftell(ambfp); -} - - ambnotify(obj) /* record new modifier */ OBJECT obj; { @@ -331,6 +302,34 @@ FVECT pv, nv; static +initambfile(creat) /* initialize ambient file */ +int creat; +{ + extern char *progname, *octname, VersionID[]; + + setbuf(ambfp, bmalloc(BUFSIZ)); + if (creat) { /* new file */ + fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ", + progname, colval(ambval,RED), + colval(ambval,GRN), colval(ambval,BLU), + ambounce, ambacc); + fprintf(ambfp, "-ad %d -as %d -ar %d %s\n", + ambdiv, ambssamp, ambres, + octname==NULL ? "" : octname); + fprintf(ambfp, "SOFTWARE= %s\n", VersionID); + fputformat(AMBFMT, ambfp); + putc('\n', ambfp); + putambmagic(ambfp); + fflush(ambfp); +#ifndef NIX + sync(); /* protect against NFS buffering */ +#endif + } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp)) + error(USER, "bad ambient file"); +} + + +static avsave(av) /* insert and save an ambient value */ AMBVAL *av; { @@ -389,14 +388,26 @@ memerr: } -#include +#ifdef NIX +static +ambsync() /* flush ambient file */ +{ + return(fflush(ambfp)); +} +#else + +#include +#include +#include + static ambsync() /* synchronize ambient file */ { static FILE *ambinp = NULL; struct flock fls; + struct stat sts; AMBVAL avs; long lastpos, flen; register int n; @@ -408,21 +419,24 @@ ambsync() /* synchronize ambient file */ if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0) error(SYSTEM, "cannot lock ambient file"); /* see if file has grown */ - lastpos = lseek(fileno(ambfp), 0L, 2); /* may move pointer */ - flen = lseek(fileno(ambfp), 0L, 1); /* new(?) file length */ - if (n = (flen - lastpos)%AMBVALSIZ) /* assure alignment */ - lseek(fileno(ambfp), flen -= n, 0); + lastpos = lseek(fileno(ambfp), 0L, 1); /* get previous position */ + if (fstat(fileno(ambfp), &sts) < 0) /* get current length */ + error(SYSTEM, "cannot stat ambient file"); + flen = sts.st_size; if (n = (flen - lastpos)/AMBVALSIZ) { /* file has grown */ - if (ambinp == NULL && (ambinp = fopen(afname, "r")) == NULL) - error(SYSTEM, "cannot reopen ambient file"); - fseek(ambinp, lastpos, 0); /* go to previous position */ + if (ambinp == NULL) /* use duplicate file */ + ambinp = fdopen(dup(fileno(ambfp)), "r"); while (n--) { /* load contributed values */ readambval(&avs, ambinp); avinsert(&avs,&atrunk,thescene.cuorg,thescene.cusize); - } + } /* moves shared file pointer */ + if (n = (flen - lastpos)%AMBVALSIZ) /* alignment */ + lseek(fileno(ambfp), flen-n, 0); } n = fflush(ambfp); /* calls write() at last */ fls.l_type = F_UNLCK; /* release file */ fcntl(fileno(ambfp), F_SETLKW, &fls); return(n); } + +#endif
