--- ray/src/rt/ambient.c 2003/06/26 00:58:10 2.51 +++ ray/src/rt/ambient.c 2014/04/25 18:38:47 2.80 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: ambient.c,v 2.51 2003/06/26 00:58:10 schorsch Exp $"; +static const char RCSid[] = "$Id: ambient.c,v 2.80 2014/04/25 18:38:47 greg Exp $"; #endif /* * ambient.c - routines dealing with ambient (inter-reflected) component. @@ -9,9 +9,12 @@ static const char RCSid[] = "$Id: ambient.c,v 2.51 200 #include "copyright.h" +#include + #include "platform.h" #include "ray.h" #include "otypes.h" +#include "resolu.h" #include "ambient.h" #include "random.h" @@ -21,7 +24,9 @@ static const char RCSid[] = "$Id: ambient.c,v 2.51 200 extern char *shm_boundary; /* memory sharing boundary */ -#define MAXASET 511 /* maximum number of elements in ambient set */ +#ifndef MAXASET +#define MAXASET 4095 /* maximum number of elements in ambient set */ +#endif OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */ double maxarad; /* maximum ambient radius */ @@ -34,9 +39,9 @@ static int nunflshed = 0; /* number of unflushed ambi #ifndef SORT_THRESH #ifdef SMLMEM -#define SORT_THRESH ((3L<<20)/sizeof(AMBVAL)) +#define SORT_THRESH ((16L<<20)/sizeof(AMBVAL)) #else -#define SORT_THRESH ((9L<<20)/sizeof(AMBVAL)) +#define SORT_THRESH ((64L<<20)/sizeof(AMBVAL)) #endif #endif #ifndef SORT_INTVL @@ -46,6 +51,8 @@ static int nunflshed = 0; /* number of unflushed ambi #define MAX_SORT_INTVL (SORT_INTVL<<6) #endif + +static double qambacc = 0.; /* ambient accuracy to the 1/4 power */ static double avsum = 0.; /* computed ambient value sum (log) */ static unsigned int navsum = 0; /* number of values in avsum */ static unsigned int nambvals = 0; /* total number of indirect values */ @@ -73,17 +80,31 @@ static long lastpos = -1; /* last flush position */ #define newambval() (AMBVAL *)malloc(sizeof(AMBVAL)) #define freeav(av) free((void *)av); -static void initambfile(), avsave(), avinsert(), sortambvals(), unloadatree(); -static int avlmemi(); -static AMBVAL *avstore(); +static void initambfile(int creat); +static void avsave(AMBVAL *av); +static AMBVAL *avstore(AMBVAL *aval); +static AMBTREE *newambtree(void); +static void freeambtree(AMBTREE *atp); + +typedef void unloadtf_t(AMBVAL *); +static unloadtf_t avinsert; +static unloadtf_t av2list; +static unloadtf_t avfree; +static void unloadatree(AMBTREE *at, unloadtf_t *f); + +static int aposcmp(const void *avp1, const void *avp2); +static int avlmemi(AMBVAL *avaddr); +static void sortambvals(int always); + #ifdef F_SETLKW -static void aflock(); +static void aflock(int typ); #endif void -setambres(ar) /* set ambient resolution */ -int ar; +setambres( /* set ambient resolution */ + int ar +) { ambres = ar < 0 ? 0 : ar; /* may be done already */ /* set min & max radii */ @@ -104,30 +125,34 @@ int ar; void -setambacc(newa) /* set ambient accuracy */ -double newa; +setambacc( /* set ambient accuracy */ + double newa +) { double ambdiff; if (newa < 0.0) newa = 0.0; ambdiff = fabs(newa - ambacc); - if (ambdiff >= .01 && (ambacc = newa) > FTINY && nambvals > 0) - sortambvals(1); /* rebuild tree */ + if (ambdiff >= .01 && (ambacc = newa) > FTINY) { + qambacc = sqrt(sqrt(ambacc)); + if (nambvals > 0) + sortambvals(1); /* rebuild tree */ + } } void -setambient() /* initialize calculation */ +setambient(void) /* initialize calculation */ { int readonly = 0; - long pos, flen; + long flen; AMBVAL amb; /* make sure we're fresh */ ambdone(); /* init ambient limits */ setambres(ambres); - setambacc(ambacc); + qambacc = sqrt(sqrt(ambacc *= (ambacc > FTINY))); if (ambfile == NULL || !ambfile[0]) return; if (ambacc <= FTINY) { @@ -141,7 +166,7 @@ setambient() /* initialize calculation */ readonly = (ambfp = fopen(ambfile, "r")) != NULL; if (ambfp != NULL) { initambfile(0); /* file exists */ - pos = ftell(ambfp); + lastpos = ftell(ambfp); while (readambval(&amb, ambfp)) avinsert(avstore(&amb)); nambshare = nambvals; /* share loaded values */ @@ -155,31 +180,37 @@ setambient() /* initialize calculation */ return; /* avoid ambsync() */ } /* align file pointer */ - pos += (long)nambvals*AMBVALSIZ; - flen = lseek(fileno(ambfp), (off_t)0L, 2); - if (flen != pos) { + lastpos += (long)nambvals*AMBVALSIZ; + flen = lseek(fileno(ambfp), (off_t)0, SEEK_END); + if (flen != lastpos) { sprintf(errmsg, "ignoring last %ld values in ambient file (corrupted)", - (flen - pos)/AMBVALSIZ); + (flen - lastpos)/AMBVALSIZ); error(WARNING, errmsg); - fseek(ambfp, pos, 0); + fseek(ambfp, lastpos, SEEK_SET); #ifndef _WIN32 /* XXX we need a replacement for that one */ - ftruncate(fileno(ambfp), (off_t)pos); + ftruncate(fileno(ambfp), (off_t)lastpos); #endif } } else if ((ambfp = fopen(ambfile, "w+")) != NULL) { initambfile(1); /* else create new file */ + fflush(ambfp); + lastpos = ftell(ambfp); } else { sprintf(errmsg, "cannot open ambient file \"%s\"", ambfile); error(SYSTEM, errmsg); } - nunflshed++; /* lie */ - ambsync(); +#ifdef getc_unlocked + flockfile(ambfp); /* application-level lock */ +#endif +#ifdef F_SETLKW + aflock(F_UNLCK); /* release file */ +#endif } void -ambdone() /* close ambient file and free memory */ +ambdone(void) /* close ambient file and free memory */ { if (ambfp != NULL) { /* close ambient file */ ambsync(); @@ -192,7 +223,7 @@ ambdone() /* close ambient file and free memory */ lastpos = -1; } /* free ambient tree */ - unloadatree(&atrunk, free); + unloadatree(&atrunk, &avfree); /* reset state variables */ avsum = 0.; navsum = 0; @@ -205,12 +236,13 @@ ambdone() /* close ambient file and free memory */ void -ambnotify(obj) /* record new modifier */ -OBJECT obj; +ambnotify( /* record new modifier */ + OBJECT obj +) { static int hitlimit = 0; - register OBJREC *o; - register char **amblp; + OBJREC *o; + char **amblp; if (obj == OVOID) { /* starting over */ ambset[0] = 0; @@ -232,14 +264,28 @@ OBJECT obj; } } +/************ THE FOLLOWING ROUTINES DIFFER BETWEEN NEW & OLD ***************/ +#ifdef NEWAMB + +#define tfunc(lwr, x, upr) (((x)-(lwr))/((upr)-(lwr))) + +static double sumambient(COLOR acol, RAY *r, FVECT rn, int al, + AMBTREE *at, FVECT c0, double s); +static int makeambient(COLOR acol, RAY *r, FVECT rn, int al); +static void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv, + FVECT uvw[3]); + void -ambient(acol, r, nrm) /* compute ambient component for ray */ -COLOR acol; -register RAY *r; -FVECT nrm; +multambient( /* compute ambient component & multiply by coef. */ + COLOR aval, + RAY *r, + FVECT nrm +) { static int rdepth = 0; /* ambient recursion */ + COLOR acol; + int ok; double d, l; if (ambdiv <= 0) /* no ambient calculation */ @@ -253,62 +299,355 @@ FVECT nrm; goto dumbamb; if (ambacc <= FTINY) { /* no ambient storage */ + copycolor(acol, aval); rdepth++; + ok = doambient(acol, r, r->rweight, NULL, NULL, NULL, NULL); + rdepth--; + if (!ok) + goto dumbamb; + copycolor(aval, acol); + return; + } + + if (tracktime) /* sort to minimize thrashing */ + sortambvals(0); + /* interpolate ambient value */ + setcolor(acol, 0.0, 0.0, 0.0); + d = sumambient(acol, r, nrm, rdepth, + &atrunk, thescene.cuorg, thescene.cusize); + if (d > FTINY) { + d = 1.0/d; + scalecolor(acol, d); + multcolor(aval, acol); + return; + } + rdepth++; /* need to cache new value */ + ok = makeambient(acol, r, nrm, rdepth-1); + rdepth--; + if (ok) { + multcolor(aval, acol); /* computed new value */ + return; + } +dumbamb: /* return global value */ + if ((ambvwt <= 0) | (navsum == 0)) { + multcolor(aval, ambval); + return; + } + l = bright(ambval); /* average in computations */ + if (l > FTINY) { + d = (log(l)*(double)ambvwt + avsum) / + (double)(ambvwt + navsum); + d = exp(d) / l; + scalecolor(aval, d); + multcolor(aval, ambval); /* apply color of ambval */ + } else { + d = exp( avsum / (double)navsum ); + scalecolor(aval, d); /* neutral color */ + } +} + + +double +sumambient( /* get interpolated ambient value */ + COLOR acol, + RAY *r, + FVECT rn, + int al, + AMBTREE *at, + FVECT c0, + double s +) +{ /* initial limit is 10 degrees plus ambacc radians */ + const double minangle = 10.0 * PI/180.; + const double maxangle = (minangle+ambacc-PI/2.)*pow(r->rweight,0.13) + + PI/2.; + double wsum = 0.0; + FVECT ck0; + int i, j; + AMBVAL *av; + /* sum this node */ + for (av = at->alist; av != NULL; av = av->next) { + double d, delta_r2, delta_t2; + COLOR ct; + FVECT uvw[3]; + /* record access */ + if (tracktime) + av->latick = ambclock; + /* + * Ambient level test + */ + if (av->lvl > al) /* list sorted, so this works */ + break; + if (av->weight < 0.9*r->rweight) + continue; + /* + * Direction test using unperturbed normal + */ + decodedir(uvw[2], av->ndir); + d = DOT(uvw[2], r->ron); + if (d <= 0.0) /* >= 90 degrees */ + continue; + delta_r2 = 2.0 - 2.0*d; /* approx. radians^2 */ + if (delta_r2 >= maxangle*maxangle) + continue; + /* + * Elliptical radii test based on Hessian + */ + decodedir(uvw[0], av->udir); + VCROSS(uvw[1], uvw[2], uvw[0]); + VSUB(ck0, av->pos, r->rop); + d = DOT(ck0, uvw[0]) / av->rad[0]; + delta_t2 = d*d; + d = DOT(ck0, uvw[1]) / av->rad[1]; + delta_t2 += d*d; + d = DOT(ck0, uvw[2]) / av->rad[0]; + delta_t2 += d*d; + if (delta_t2 >= qambacc*qambacc) + continue; + /* + * Extrapolate value and compute final weight (hat function) + */ + extambient(ct, av, r->rop, rn, uvw); + d = tfunc(maxangle, sqrt(delta_r2), 0.0) * + tfunc(qambacc, sqrt(delta_t2), 0.0); + scalecolor(ct, d); + addcolor(acol, ct); + wsum += d; + } + if (at->kid == NULL) + return(wsum); + /* sum children */ + s *= 0.5; + for (i = 0; i < 8; i++) { + for (j = 0; j < 3; j++) { + ck0[j] = c0[j]; + if (1<rop[j] < ck0[j] - OCTSCALE*s) + break; + if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s) + break; + } + if (j == 3) + wsum += sumambient(acol, r, rn, al, + at->kid+i, ck0, s); + } + return(wsum); +} + + +int +makeambient( /* make a new ambient value for storage */ + COLOR acol, + RAY *r, + FVECT rn, + int al +) +{ + AMBVAL amb; + FVECT uvw[3]; + int i; + + amb.weight = 1.0; /* compute weight */ + for (i = al; i-- > 0; ) + amb.weight *= AVGREFL; + if (r->rweight < 0.1*amb.weight) /* heuristic override */ + amb.weight = 1.25*r->rweight; + setcolor(acol, AVGREFL, AVGREFL, AVGREFL); + /* compute ambient */ + i = doambient(acol, r, amb.weight, uvw, amb.rad, amb.gpos, amb.gdir); + scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */ + if (i <= 0 || amb.rad[0] <= FTINY) /* no Hessian or zero radius */ + return(i); + /* store value */ + VCOPY(amb.pos, r->rop); + amb.ndir = encodedir(r->ron); + amb.udir = encodedir(uvw[0]); + amb.lvl = al; + copycolor(amb.val, acol); + /* insert into tree */ + avsave(&amb); /* and save to file */ + if (rn != r->ron) { /* texture */ + VCOPY(uvw[2], r->ron); + extambient(acol, &amb, r->rop, rn, uvw); + } + return(1); +} + + +void +extambient( /* extrapolate value at pv, nv */ + COLOR cr, + AMBVAL *ap, + FVECT pv, + FVECT nv, + FVECT uvw[3] +) +{ + static FVECT my_uvw[3]; + FVECT v1; + int i; + double d = 1.0; /* zeroeth order */ + + if (uvw == NULL) { /* need local coordinates? */ + decodedir(my_uvw[2], ap->ndir); + decodedir(my_uvw[0], ap->udir); + VCROSS(my_uvw[1], my_uvw[2], my_uvw[0]); + uvw = my_uvw; + } + for (i = 3; i--; ) /* gradient due to translation */ + d += (pv[i] - ap->pos[i]) * + (ap->gpos[0]*uvw[0][i] + ap->gpos[1]*uvw[1][i]); + + VCROSS(v1, uvw[2], nv); /* gradient due to rotation */ + for (i = 3; i--; ) + d += v1[i] * (ap->gdir[0]*uvw[0][i] + ap->gdir[1]*uvw[1][i]); + + if (d <= 0.0) { + setcolor(cr, 0.0, 0.0, 0.0); + return; + } + copycolor(cr, ap->val); + scalecolor(cr, d); +} + + +static void +avinsert( /* insert ambient value in our tree */ + AMBVAL *av +) +{ + AMBTREE *at; + AMBVAL *ap; + AMBVAL avh; + FVECT ck0; + double s; + int branch; + int i; + + if (av->rad[0] <= FTINY) + error(CONSISTENCY, "zero ambient radius in avinsert"); + at = &atrunk; + VCOPY(ck0, thescene.cuorg); + s = thescene.cusize; + while (s*(OCTSCALE/2) > av->rad[1]*qambacc) { + if (at->kid == NULL) + if ((at->kid = newambtree()) == NULL) + error(SYSTEM, "out of memory in avinsert"); + s *= 0.5; + branch = 0; + for (i = 0; i < 3; i++) + if (av->pos[i] > ck0[i] + s) { + ck0[i] += s; + branch |= 1 << i; + } + at = at->kid + branch; + } + avh.next = at->alist; /* order by increasing level */ + for (ap = &avh; ap->next != NULL; ap = ap->next) + if (ap->next->lvl >= av->lvl) + break; + av->next = ap->next; + ap->next = (AMBVAL*)av; + at->alist = avh.next; +} + + +#else /* ! NEWAMB */ + +static double sumambient(COLOR acol, RAY *r, FVECT rn, int al, + AMBTREE *at, FVECT c0, double s); +static double makeambient(COLOR acol, RAY *r, FVECT rn, int al); +static void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv); + + +void +multambient( /* compute ambient component & multiply by coef. */ + COLOR aval, + RAY *r, + FVECT nrm +) +{ + static int rdepth = 0; /* ambient recursion */ + COLOR acol; + double d, l; + + if (ambdiv <= 0) /* no ambient calculation */ + goto dumbamb; + /* check number of bounces */ + if (rdepth >= ambounce) + goto dumbamb; + /* check ambient list */ + if (ambincl != -1 && r->ro != NULL && + ambincl != inset(ambset, r->ro->omod)) + goto dumbamb; + + if (ambacc <= FTINY) { /* no ambient storage */ + copycolor(acol, aval); + rdepth++; d = doambient(acol, r, r->rweight, NULL, NULL); rdepth--; if (d <= FTINY) goto dumbamb; + copycolor(aval, acol); return; } if (tracktime) /* sort to minimize thrashing */ sortambvals(0); - /* get ambient value */ + /* interpolate ambient value */ setcolor(acol, 0.0, 0.0, 0.0); d = sumambient(acol, r, nrm, rdepth, &atrunk, thescene.cuorg, thescene.cusize); if (d > FTINY) { - scalecolor(acol, 1.0/d); + d = 1.0/d; + scalecolor(acol, d); + multcolor(aval, acol); return; } rdepth++; /* need to cache new value */ d = makeambient(acol, r, nrm, rdepth-1); rdepth--; - if (d > FTINY) + if (d > FTINY) { + multcolor(aval, acol); /* got new value */ return; + } dumbamb: /* return global value */ - copycolor(acol, ambval); - if (ambvwt <= 0 | navsum == 0) + if ((ambvwt <= 0) | (navsum == 0)) { + multcolor(aval, ambval); return; + } l = bright(ambval); /* average in computations */ if (l > FTINY) { d = (log(l)*(double)ambvwt + avsum) / (double)(ambvwt + navsum); d = exp(d) / l; - scalecolor(acol, d); /* apply color of ambval */ + scalecolor(aval, d); + multcolor(aval, ambval); /* apply color of ambval */ } else { d = exp( avsum / (double)navsum ); - setcolor(acol, d, d, d); /* neutral color */ + scalecolor(aval, d); /* neutral color */ } } -double -sumambient(acol, r, rn, al, at, c0, s) /* get interpolated ambient value */ -COLOR acol; -register RAY *r; -FVECT rn; -int al; -AMBTREE *at; -FVECT c0; -double s; +static double +sumambient( /* get interpolated ambient value */ + COLOR acol, + RAY *r, + FVECT rn, + int al, + AMBTREE *at, + FVECT c0, + double s +) { double d, e1, e2, wt, wsum; COLOR ct; FVECT ck0; int i; - register int j; - register AMBVAL *av; + int j; + AMBVAL *av; wsum = 0.0; /* do this node */ @@ -321,18 +660,13 @@ double s; */ if (av->lvl > al) /* list sorted, so this works */ break; - if (av->weight < r->rweight-FTINY) + if (av->weight < 0.9*r->rweight) continue; /* * Ambient radius test. */ - d = av->pos[0] - r->rop[0]; - e1 = d * d; - d = av->pos[1] - r->rop[1]; - e1 += d * d; - d = av->pos[2] - r->rop[2]; - e1 += d * d; - e1 /= av->rad * av->rad; + VSUB(ck0, av->pos, r->rop); + e1 = DOT(ck0, ck0) / (av->rad * av->rad); if (e1 > ambacc*ambacc*1.21) continue; /* @@ -349,8 +683,9 @@ double s; } } e2 = (1.0 - d) * r->rweight; - if (e2 < 0.0) e2 = 0.0; - if (e1 + e2 > ambacc*ambacc*1.21) + if (e2 < 0.0) + e2 = 0.0; + else if (e1 + e2 > ambacc*ambacc*1.21) continue; /* * Ray behind test. @@ -400,30 +735,39 @@ double s; break; } if (j == 3) - wsum += sumambient(acol, r, rn, al, at->kid+i, ck0, s); + wsum += sumambient(acol, r, rn, al, + at->kid+i, ck0, s); } return(wsum); } -double -makeambient(acol, r, rn, al) /* make a new ambient value */ -COLOR acol; -register RAY *r; -FVECT rn; -int al; +static double +makeambient( /* make a new ambient value for storage */ + COLOR acol, + RAY *r, + FVECT rn, + int al +) { AMBVAL amb; FVECT gp, gd; - /* compute weight */ - amb.weight = pow(AVGREFL, (double)al); - if (r->rweight < 0.1*amb.weight) /* heuristic */ - amb.weight = r->rweight; + int i; + + amb.weight = 1.0; /* compute weight */ + for (i = al; i-- > 0; ) + amb.weight *= AVGREFL; + if (r->rweight < 0.1*amb.weight) /* heuristic override */ + amb.weight = 1.25*r->rweight; + setcolor(acol, AVGREFL, AVGREFL, AVGREFL); /* compute ambient */ amb.rad = doambient(acol, r, amb.weight, gp, gd); - if (amb.rad <= FTINY) + if (amb.rad <= FTINY) { + setcolor(acol, 0.0, 0.0, 0.0); return(0.0); - /* store it */ + } + scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */ + /* store value */ VCOPY(amb.pos, r->rop); VCOPY(amb.dir, r->ron); amb.lvl = al; @@ -438,14 +782,16 @@ int al; } -void -extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */ -COLOR cr; -register AMBVAL *ap; -FVECT pv, nv; +static void +extambient( /* extrapolate value at pv, nv */ + COLOR cr, + AMBVAL *ap, + FVECT pv, + FVECT nv +) { FVECT v1; - register int i; + int i; double d; d = 1.0; /* zeroeth order */ @@ -465,20 +811,65 @@ FVECT pv, nv; static void -initambfile(creat) /* initialize ambient file */ -int creat; +avinsert( /* insert ambient value in our tree */ + AMBVAL *av +) { + AMBTREE *at; + AMBVAL *ap; + AMBVAL avh; + FVECT ck0; + double s; + int branch; + int i; + + if (av->rad <= FTINY) + error(CONSISTENCY, "zero ambient radius in avinsert"); + at = &atrunk; + VCOPY(ck0, thescene.cuorg); + s = thescene.cusize; + while (s*(OCTSCALE/2) > av->rad*ambacc) { + if (at->kid == NULL) + if ((at->kid = newambtree()) == NULL) + error(SYSTEM, "out of memory in avinsert"); + s *= 0.5; + branch = 0; + for (i = 0; i < 3; i++) + if (av->pos[i] > ck0[i] + s) { + ck0[i] += s; + branch |= 1 << i; + } + at = at->kid + branch; + } + avh.next = at->alist; /* order by increasing level */ + for (ap = &avh; ap->next != NULL; ap = ap->next) + if (ap->next->lvl >= av->lvl) + break; + av->next = ap->next; + ap->next = (AMBVAL*)av; + at->alist = avh.next; +} + +#endif /* ! NEWAMB */ + +/************* FOLLOWING ROUTINES SAME FOR NEW & OLD METHODS ***************/ + +static void +initambfile( /* initialize ambient file */ + int cre8 +) +{ extern char *progname, *octname; static char *mybuf = NULL; #ifdef F_SETLKW - aflock(creat ? F_WRLCK : F_RDLCK); + aflock(cre8 ? F_WRLCK : F_RDLCK); #endif SET_FILE_BINARY(ambfp); if (mybuf == NULL) mybuf = (char *)bmalloc(BUFSIZ+8); setbuf(ambfp, mybuf); - if (creat) { /* new file */ + if (cre8) { /* new file */ newheader("RADIANCE", ambfp); fprintf(ambfp, "%s -av %g %g %g -aw %d -ab %d -aa %g ", progname, colval(ambval,RED), @@ -487,13 +878,12 @@ int creat; fprintf(ambfp, "-ad %d -as %d -ar %d ", ambdiv, ambssamp, ambres); if (octname != NULL) - printargs(1, &octname, ambfp); - else - fputc('\n', ambfp); + fputs(octname, ambfp); + fputc('\n', ambfp); fprintf(ambfp, "SOFTWARE= %s\n", VersionID); fputnow(ambfp); fputformat(AMBFMT, ambfp); - putc('\n', ambfp); + fputc('\n', ambfp); putambmagic(ambfp); } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp)) error(USER, "bad ambient file"); @@ -501,8 +891,9 @@ int creat; static void -avsave(av) /* insert and save an ambient value */ -AMBVAL *av; +avsave( /* insert and save an ambient value */ + AMBVAL *av +) { avinsert(avstore(av)); if (ambfp == NULL) @@ -519,15 +910,16 @@ writerr: static AMBVAL * -avstore(aval) /* allocate memory and store aval */ -register AMBVAL *aval; +avstore( /* allocate memory and store aval */ + AMBVAL *aval +) { - register AMBVAL *av; + AMBVAL *av; double d; if ((av = newambval()) == NULL) error(SYSTEM, "out of memory in avstore"); - copystruct(av, aval); + *av = *aval; av->latick = ambclock; av->next = NULL; nambvals++; @@ -546,9 +938,9 @@ static AMBTREE *atfreelist = NULL; /* free ambient tr static AMBTREE * -newambtree() /* allocate 8 ambient tree structs */ +newambtree(void) /* allocate 8 ambient tree structs */ { - register AMBTREE *atp, *upperlim; + AMBTREE *atp, *upperlim; if (atfreelist == NULL) { /* get more nodes */ atfreelist = (AMBTREE *)malloc(ATALLOCSZ*8*sizeof(AMBTREE)); @@ -562,14 +954,15 @@ newambtree() /* allocate 8 ambient tree structs */ } atp = atfreelist; atfreelist = atp->kid; - bzero((char *)atp, 8*sizeof(AMBTREE)); + memset((char *)atp, '\0', 8*sizeof(AMBTREE)); return(atp); } static void -freeambtree(atp) /* free 8 ambient tree structs */ -AMBTREE *atp; +freeambtree( /* free 8 ambient tree structs */ + AMBTREE *atp +) { atp->kid = atfreelist; atfreelist = atp; @@ -577,52 +970,13 @@ AMBTREE *atp; static void -avinsert(av) /* insert ambient value in our tree */ -register AMBVAL *av; +unloadatree( /* unload an ambient value tree */ + AMBTREE *at, + unloadtf_t *f +) { - register AMBTREE *at; - register AMBVAL *ap; - AMBVAL avh; - FVECT ck0; - double s; - int branch; - register int i; - - if (av->rad <= FTINY) - error(CONSISTENCY, "zero ambient radius in avinsert"); - at = &atrunk; - VCOPY(ck0, thescene.cuorg); - s = thescene.cusize; - while (s*(OCTSCALE/2) > av->rad*ambacc) { - if (at->kid == NULL) - if ((at->kid = newambtree()) == NULL) - error(SYSTEM, "out of memory in avinsert"); - s *= 0.5; - branch = 0; - for (i = 0; i < 3; i++) - if (av->pos[i] > ck0[i] + s) { - ck0[i] += s; - branch |= 1 << i; - } - at = at->kid + branch; - } - avh.next = at->alist; /* order by increasing level */ - for (ap = &avh; ap->next != NULL; ap = ap->next) - if (ap->next->lvl >= av->lvl) - break; - av->next = ap->next; - ap->next = av; - at->alist = avh.next; -} - - -static void -unloadatree(at, f) /* unload an ambient value tree */ -register AMBTREE *at; -void (*f)(); -{ - register AMBVAL *av; - register int i; + AMBVAL *av; + int i; /* transfer values at this node */ for (av = at->alist; av != NULL; av = at->alist) { at->alist = av->next; @@ -644,25 +998,35 @@ static struct avl { static AMBVAL **avlist2; /* memory positions for sorting */ static int i_avlist; /* index for lists */ +static int alatcmp(const void *av1, const void *av2); -static int -av2list(av) -register AMBVAL *av; +static void +avfree(AMBVAL *av) { + free(av); +} + +static void +av2list( + AMBVAL *av +) +{ #ifdef DEBUG if (i_avlist >= nambvals) error(CONSISTENCY, "too many ambient values in av2list1"); #endif - avlist1[i_avlist].p = avlist2[i_avlist] = av; + avlist1[i_avlist].p = avlist2[i_avlist] = (AMBVAL*)av; avlist1[i_avlist++].t = av->latick; } static int -alatcmp(av1, av2) /* compare ambient values for MRA */ -struct avl *av1, *av2; +alatcmp( /* compare ambient values for MRA */ + const void *av1, + const void *av2 +) { - register long lc = av2->t - av1->t; + long lc = ((struct avl *)av2)->t - ((struct avl *)av1)->t; return(lc<0 ? -1 : lc>0 ? 1 : 0); } @@ -674,41 +1038,41 @@ struct avl *av1, *av2; * assumes pointers differ by exact struct size increments. */ static int -aposcmp(avp1, avp2) /* compare ambient value positions */ -const void *avp1, *avp2; +aposcmp( /* compare ambient value positions */ + const void *avp1, + const void *avp2 +) { - register long diff = *(char * const *)avp1 - *(char * const *)avp2; + long diff = *(char * const *)avp1 - *(char * const *)avp2; if (diff < 0) return(-1); return(diff > 0); } -#if 1 + static int -avlmemi(avaddr) /* find list position from address */ -AMBVAL *avaddr; +avlmemi( /* find list position from address */ + AMBVAL *avaddr +) { - register AMBVAL **avlpp; + AMBVAL **avlpp; avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2, - nambvals, sizeof(AMBVAL *), aposcmp); + nambvals, sizeof(AMBVAL *), &aposcmp); if (avlpp == NULL) error(CONSISTENCY, "address not found in avlmemi"); return(avlpp - avlist2); } -#else -#define avlmemi(avaddr) ((AMBVAL **)bsearch((char *)&avaddr,(char *)avlist2, \ - nambvals,sizeof(AMBVAL *),aposcmp) - avlist2) -#endif static void -sortambvals(always) /* resort ambient values */ -int always; +sortambvals( /* resort ambient values */ + int always +) { AMBTREE oldatrunk; AMBVAL tav, *tap, *pnext; - register int i, j; + int i, j; /* see if it's time yet */ if (!always && (ambclock++ < lastsort+sortintvl || nambvals < SORT_THRESH)) @@ -739,10 +1103,10 @@ int always; if (avlist2 != NULL) free((void *)avlist2); if (always) { /* rebuild without sorting */ - copystruct(&oldatrunk, &atrunk); + oldatrunk = atrunk; atrunk.alist = NULL; atrunk.kid = NULL; - unloadatree(&oldatrunk, avinsert); + unloadatree(&oldatrunk, &avinsert); } } else { /* sort memory by last access time */ /* @@ -759,25 +1123,25 @@ int always; eputs(errmsg); #endif i_avlist = 0; - unloadatree(&atrunk, av2list); /* empty current tree */ + unloadatree(&atrunk, &av2list); /* empty current tree */ #ifdef DEBUG if (i_avlist < nambvals) error(CONSISTENCY, "missing ambient values in sortambvals"); #endif - qsort((char *)avlist1, nambvals, sizeof(struct avl), alatcmp); - qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), aposcmp); + qsort((char *)avlist1, nambvals, sizeof(struct avl), &alatcmp); + qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), &aposcmp); for (i = 0; i < nambvals; i++) { if (avlist1[i].p == NULL) continue; tap = avlist2[i]; - copystruct(&tav, tap); + tav = *tap; for (j = i; (pnext = avlist1[j].p) != tap; j = avlmemi(pnext)) { - copystruct(avlist2[j], pnext); + *(avlist2[j]) = *pnext; avinsert(avlist2[j]); avlist1[j].p = NULL; } - copystruct(avlist2[j], &tav); + *(avlist2[j]) = tav; avinsert(avlist2[j]); avlist1[j].p = NULL; } @@ -802,11 +1166,14 @@ int always; #ifdef F_SETLKW static void -aflock(typ) /* lock/unlock ambient file */ -int typ; +aflock( /* lock/unlock ambient file */ + int typ +) { static struct flock fls; /* static so initialized to zeroes */ + if (typ == fls.l_type) /* already called? */ + return; fls.l_type = typ; if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0) error(SYSTEM, "cannot (un)lock ambient file"); @@ -814,28 +1181,26 @@ int typ; int -ambsync() /* synchronize ambient file */ +ambsync(void) /* synchronize ambient file */ { long flen; AMBVAL avs; - register int n; + int n; - if (nunflshed == 0) + if (ambfp == NULL) /* no ambient file? */ return(0); - if (lastpos < 0) /* initializing (locked in initambfile) */ - goto syncend; - /* gain exclusive access */ - aflock(F_WRLCK); + /* gain appropriate access */ + aflock(nunflshed ? F_WRLCK : F_RDLCK); /* see if file has grown */ - if ((flen = lseek(fileno(ambfp), (off_t)0L, 2)) < 0) + if ((flen = lseek(fileno(ambfp), (off_t)0, SEEK_END)) < 0) goto seekerr; - if (n = flen - lastpos) { /* file has grown */ + if ((n = flen - lastpos) > 0) { /* file has grown */ if (ambinp == NULL) { /* use duplicate filedes */ ambinp = fdopen(dup(fileno(ambfp)), "r"); if (ambinp == NULL) error(SYSTEM, "fdopen failed in ambsync"); } - if (fseek(ambinp, lastpos, 0) < 0) + if (fseek(ambinp, lastpos, SEEK_SET) < 0) goto seekerr; while (n >= AMBVALSIZ) { /* load contributed values */ if (!readambval(&avs, ambinp)) { @@ -848,39 +1213,35 @@ ambsync() /* synchronize ambient file */ avinsert(avstore(&avs)); n -= AMBVALSIZ; } + lastpos = flen - n; /*** seek always as safety measure if (n) ***/ /* alignment */ - if (lseek(fileno(ambfp), (off_t)(flen-n), 0) < 0) + if (lseek(fileno(ambfp), (off_t)lastpos, SEEK_SET) < 0) goto seekerr; } -#ifdef DEBUG - if (ambfp->_ptr - ambfp->_base != nunflshed*AMBVALSIZ) { - sprintf(errmsg, "ambient file buffer at %d rather than %d", - ambfp->_ptr - ambfp->_base, - nunflshed*AMBVALSIZ); - error(CONSISTENCY, errmsg); - } -#endif -syncend: n = fflush(ambfp); /* calls write() at last */ - if ((lastpos = lseek(fileno(ambfp), (off_t)0L, 1)) < 0) + if (n != EOF) + lastpos += (long)nunflshed*AMBVALSIZ; + else if ((lastpos = lseek(fileno(ambfp), (off_t)0, SEEK_CUR)) < 0) goto seekerr; + aflock(F_UNLCK); /* release file */ nunflshed = 0; return(n); seekerr: error(SYSTEM, "seek failed in ambsync"); + return -1; /* pro forma return */ } -#else +#else /* ! F_SETLKW */ int -ambsync() /* flush ambient file */ +ambsync(void) /* flush ambient file */ { - if (nunflshed == 0) + if (ambfp == NULL) return(0); nunflshed = 0; return(fflush(ambfp)); } -#endif +#endif /* ! F_SETLKW */
