--- ray/src/rt/ambient.c 2003/05/15 05:13:35 2.49 +++ ray/src/rt/ambient.c 2005/05/25 18:06:22 2.59 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: ambient.c,v 2.49 2003/05/15 05:13:35 greg Exp $"; +static const char RCSid[] = "$Id: ambient.c,v 2.59 2005/05/25 18:06:22 greg Exp $"; #endif /* * ambient.c - routines dealing with ambient (inter-reflected) component. @@ -9,12 +9,13 @@ static const char RCSid[] = "$Id: ambient.c,v 2.49 200 #include "copyright.h" -#include "ray.h" +#include +#include "platform.h" +#include "ray.h" #include "otypes.h" - +#include "resolu.h" #include "ambient.h" - #include "random.h" #ifndef OCTSCALE @@ -23,7 +24,9 @@ static const char RCSid[] = "$Id: ambient.c,v 2.49 200 extern char *shm_boundary; /* memory sharing boundary */ -#define MAXASET 511 /* maximum number of elements in ambient set */ +#ifndef MAXASET +#define MAXASET 2047 /* maximum number of elements in ambient set */ +#endif OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */ double maxarad; /* maximum ambient radius */ @@ -75,17 +78,30 @@ static long lastpos = -1; /* last flush position */ #define newambval() (AMBVAL *)malloc(sizeof(AMBVAL)) #define freeav(av) free((void *)av); -static void initambfile(), avsave(), avinsert(), sortambvals(), unloadatree(); -static int avlmemi(); -static AMBVAL *avstore(); +static void initambfile(int creat); +static void avsave(AMBVAL *av); +static AMBVAL *avstore(AMBVAL *aval); +static AMBTREE *newambtree(void); +static void freeambtree(AMBTREE *atp); + +typedef void unloadtf_t(void *); +static unloadtf_t avinsert; +static unloadtf_t av2list; +static void unloadatree(AMBTREE *at, unloadtf_t *f); + +static int aposcmp(const void *avp1, const void *avp2); +static int avlmemi(AMBVAL *avaddr); +static void sortambvals(int always); + #ifdef F_SETLKW -static void aflock(); +static void aflock(int typ); #endif -void -setambres(ar) /* set ambient resolution */ -int ar; +extern void +setambres( /* set ambient resolution */ + int ar +) { ambres = ar < 0 ? 0 : ar; /* may be done already */ /* set min & max radii */ @@ -105,9 +121,10 @@ int ar; } -void -setambacc(newa) /* set ambient accuracy */ -double newa; +extern void +setambacc( /* set ambient accuracy */ + double newa +) { double ambdiff; @@ -119,8 +136,8 @@ double newa; } -void -setambient() /* initialize calculation */ +extern void +setambient(void) /* initialize calculation */ { int readonly = 0; long pos, flen; @@ -158,14 +175,16 @@ setambient() /* initialize calculation */ } /* align file pointer */ pos += (long)nambvals*AMBVALSIZ; - flen = lseek(fileno(ambfp), (off_t)0L, 2); + flen = lseek(fileno(ambfp), (off_t)0, SEEK_END); if (flen != pos) { sprintf(errmsg, "ignoring last %ld values in ambient file (corrupted)", (flen - pos)/AMBVALSIZ); error(WARNING, errmsg); fseek(ambfp, pos, 0); +#ifndef _WIN32 /* XXX we need a replacement for that one */ ftruncate(fileno(ambfp), (off_t)pos); +#endif } } else if ((ambfp = fopen(ambfile, "w+")) != NULL) { initambfile(1); /* else create new file */ @@ -178,8 +197,8 @@ setambient() /* initialize calculation */ } -void -ambdone() /* close ambient file and free memory */ +extern void +ambdone(void) /* close ambient file and free memory */ { if (ambfp != NULL) { /* close ambient file */ ambsync(); @@ -204,9 +223,10 @@ ambdone() /* close ambient file and free memory */ } -void -ambnotify(obj) /* record new modifier */ -OBJECT obj; +extern void +ambnotify( /* record new modifier */ + OBJECT obj +) { static int hitlimit = 0; register OBJREC *o; @@ -233,13 +253,15 @@ OBJECT obj; } -void -ambient(acol, r, nrm) /* compute ambient component for ray */ -COLOR acol; -register RAY *r; -FVECT nrm; +extern void +multambient( /* compute ambient component & multiply by coef. */ + COLOR aval, + register RAY *r, + FVECT nrm +) { static int rdepth = 0; /* ambient recursion */ + COLOR acol; double d, l; if (ambdiv <= 0) /* no ambient calculation */ @@ -254,10 +276,12 @@ FVECT nrm; if (ambacc <= FTINY) { /* no ambient storage */ rdepth++; - d = doambient(acol, r, r->rweight, NULL, NULL); + d = doambient(acol, r, aval, intens(aval)*r->rweight, + NULL, NULL); rdepth--; if (d <= FTINY) goto dumbamb; + multcolor(aval, acol); return; } @@ -265,43 +289,50 @@ FVECT nrm; sortambvals(0); /* get ambient value */ setcolor(acol, 0.0, 0.0, 0.0); - d = sumambient(acol, r, nrm, rdepth, + d = sumambient(acol, r, intens(aval)*r->rweight, nrm, rdepth, &atrunk, thescene.cuorg, thescene.cusize); if (d > FTINY) { scalecolor(acol, 1.0/d); + multcolor(aval, acol); return; } rdepth++; /* need to cache new value */ - d = makeambient(acol, r, nrm, rdepth-1); + d = makeambient(acol, r, aval, nrm, rdepth-1); rdepth--; - if (d > FTINY) + if (d > FTINY) { + multcolor(aval, acol); /* got new value */ return; + } dumbamb: /* return global value */ - copycolor(acol, ambval); - if (ambvwt <= 0 | navsum == 0) + if ((ambvwt <= 0) | (navsum == 0)) { + multcolor(aval, ambval); return; + } l = bright(ambval); /* average in computations */ if (l > FTINY) { d = (log(l)*(double)ambvwt + avsum) / (double)(ambvwt + navsum); d = exp(d) / l; - scalecolor(acol, d); /* apply color of ambval */ + scalecolor(aval, d); + multcolor(aval, ambval); /* apply color of ambval */ } else { d = exp( avsum / (double)navsum ); - setcolor(acol, d, d, d); /* neutral color */ + scalecolor(aval, d); /* neutral color */ } } -double -sumambient(acol, r, rn, al, at, c0, s) /* get interpolated ambient value */ -COLOR acol; -register RAY *r; -FVECT rn; -int al; -AMBTREE *at; -FVECT c0; -double s; +extern double +sumambient( /* get interpolated ambient value */ + COLOR acol, + register RAY *r, + double rw, + FVECT rn, + int al, + AMBTREE *at, + FVECT c0, + double s +) { double d, e1, e2, wt, wsum; COLOR ct; @@ -321,7 +352,7 @@ double s; */ if (av->lvl > al) /* list sorted, so this works */ break; - if (av->weight < r->rweight-FTINY) + if (av->weight < 0.9*rw) continue; /* * Ambient radius test. @@ -400,27 +431,32 @@ double s; break; } if (j == 3) - wsum += sumambient(acol, r, rn, al, at->kid+i, ck0, s); + wsum += sumambient(acol, r, rw, rn, al, + at->kid+i, ck0, s); } return(wsum); } -double -makeambient(acol, r, rn, al) /* make a new ambient value */ -COLOR acol; -register RAY *r; -FVECT rn; -int al; +extern double +makeambient( /* make a new ambient value */ + COLOR acol, + RAY *r, + COLOR ac, + FVECT rn, + int al +) { AMBVAL amb; + double coef; FVECT gp, gd; /* compute weight */ amb.weight = pow(AVGREFL, (double)al); - if (r->rweight < 0.1*amb.weight) /* heuristic */ - amb.weight = r->rweight; + coef = intens(ac)*r->rweight; + if (coef < 0.1*amb.weight) /* heuristic */ + amb.weight = coef; /* compute ambient */ - amb.rad = doambient(acol, r, amb.weight, gp, gd); + amb.rad = doambient(acol, r, ac, amb.weight, gp, gd); if (amb.rad <= FTINY) return(0.0); /* store it */ @@ -438,11 +474,13 @@ int al; } -void -extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */ -COLOR cr; -register AMBVAL *ap; -FVECT pv, nv; +extern void +extambient( /* extrapolate value at pv, nv */ + COLOR cr, + register AMBVAL *ap, + FVECT pv, + FVECT nv +) { FVECT v1; register int i; @@ -465,8 +503,9 @@ FVECT pv, nv; static void -initambfile(creat) /* initialize ambient file */ -int creat; +initambfile( /* initialize ambient file */ + int creat +) { extern char *progname, *octname; static char *mybuf = NULL; @@ -474,9 +513,7 @@ int creat; #ifdef F_SETLKW aflock(creat ? F_WRLCK : F_RDLCK); #endif -#ifdef MSDOS - setmode(fileno(ambfp), O_BINARY); -#endif + SET_FILE_BINARY(ambfp); if (mybuf == NULL) mybuf = (char *)bmalloc(BUFSIZ+8); setbuf(ambfp, mybuf); @@ -503,8 +540,9 @@ int creat; static void -avsave(av) /* insert and save an ambient value */ -AMBVAL *av; +avsave( /* insert and save an ambient value */ + AMBVAL *av +) { avinsert(avstore(av)); if (ambfp == NULL) @@ -521,15 +559,16 @@ writerr: static AMBVAL * -avstore(aval) /* allocate memory and store aval */ -register AMBVAL *aval; +avstore( /* allocate memory and store aval */ + register AMBVAL *aval +) { register AMBVAL *av; double d; if ((av = newambval()) == NULL) error(SYSTEM, "out of memory in avstore"); - copystruct(av, aval); + *av = *aval; av->latick = ambclock; av->next = NULL; nambvals++; @@ -548,7 +587,7 @@ static AMBTREE *atfreelist = NULL; /* free ambient tr static AMBTREE * -newambtree() /* allocate 8 ambient tree structs */ +newambtree(void) /* allocate 8 ambient tree structs */ { register AMBTREE *atp, *upperlim; @@ -564,14 +603,15 @@ newambtree() /* allocate 8 ambient tree structs */ } atp = atfreelist; atfreelist = atp->kid; - bzero((char *)atp, 8*sizeof(AMBTREE)); + memset((char *)atp, '\0', 8*sizeof(AMBTREE)); return(atp); } static void -freeambtree(atp) /* free 8 ambient tree structs */ -AMBTREE *atp; +freeambtree( /* free 8 ambient tree structs */ + AMBTREE *atp +) { atp->kid = atfreelist; atfreelist = atp; @@ -579,8 +619,9 @@ AMBTREE *atp; static void -avinsert(av) /* insert ambient value in our tree */ -register AMBVAL *av; +avinsert( /* insert ambient value in our tree */ + void *av +) { register AMBTREE *at; register AMBVAL *ap; @@ -590,19 +631,19 @@ register AMBVAL *av; int branch; register int i; - if (av->rad <= FTINY) + if (((AMBVAL*)av)->rad <= FTINY) error(CONSISTENCY, "zero ambient radius in avinsert"); at = &atrunk; VCOPY(ck0, thescene.cuorg); s = thescene.cusize; - while (s*(OCTSCALE/2) > av->rad*ambacc) { + while (s*(OCTSCALE/2) > ((AMBVAL*)av)->rad*ambacc) { if (at->kid == NULL) if ((at->kid = newambtree()) == NULL) error(SYSTEM, "out of memory in avinsert"); s *= 0.5; branch = 0; for (i = 0; i < 3; i++) - if (av->pos[i] > ck0[i] + s) { + if (((AMBVAL*)av)->pos[i] > ck0[i] + s) { ck0[i] += s; branch |= 1 << i; } @@ -610,18 +651,19 @@ register AMBVAL *av; } avh.next = at->alist; /* order by increasing level */ for (ap = &avh; ap->next != NULL; ap = ap->next) - if (ap->next->lvl >= av->lvl) + if (ap->next->lvl >= ((AMBVAL*)av)->lvl) break; - av->next = ap->next; - ap->next = av; + ((AMBVAL*)av)->next = ap->next; + ap->next = (AMBVAL*)av; at->alist = avh.next; } static void -unloadatree(at, f) /* unload an ambient value tree */ -register AMBTREE *at; -void (*f)(); +unloadatree( /* unload an ambient value tree */ + register AMBTREE *at, + unloadtf_t *f +) { register AMBVAL *av; register int i; @@ -646,25 +688,29 @@ static struct avl { static AMBVAL **avlist2; /* memory positions for sorting */ static int i_avlist; /* index for lists */ +static int alatcmp(const void *av1, const void *av2); -static int -av2list(av) -register AMBVAL *av; +static void +av2list( + void *av +) { #ifdef DEBUG if (i_avlist >= nambvals) error(CONSISTENCY, "too many ambient values in av2list1"); #endif - avlist1[i_avlist].p = avlist2[i_avlist] = av; - avlist1[i_avlist++].t = av->latick; + avlist1[i_avlist].p = avlist2[i_avlist] = (AMBVAL*)av; + avlist1[i_avlist++].t = ((AMBVAL*)av)->latick; } static int -alatcmp(av1, av2) /* compare ambient values for MRA */ -struct avl *av1, *av2; +alatcmp( /* compare ambient values for MRA */ + const void *av1, + const void *av2 +) { - register long lc = av2->t - av1->t; + register long lc = ((struct avl *)av2)->t - ((struct avl *)av1)->t; return(lc<0 ? -1 : lc>0 ? 1 : 0); } @@ -676,8 +722,10 @@ struct avl *av1, *av2; * assumes pointers differ by exact struct size increments. */ static int -aposcmp(avp1, avp2) /* compare ambient value positions */ -const void *avp1, *avp2; +aposcmp( /* compare ambient value positions */ + const void *avp1, + const void *avp2 +) { register long diff = *(char * const *)avp1 - *(char * const *)avp2; if (diff < 0) @@ -687,8 +735,9 @@ const void *avp1, *avp2; #if 1 static int -avlmemi(avaddr) /* find list position from address */ -AMBVAL *avaddr; +avlmemi( /* find list position from address */ + AMBVAL *avaddr +) { register AMBVAL **avlpp; @@ -705,8 +754,9 @@ AMBVAL *avaddr; static void -sortambvals(always) /* resort ambient values */ -int always; +sortambvals( /* resort ambient values */ + int always +) { AMBTREE oldatrunk; AMBVAL tav, *tap, *pnext; @@ -741,7 +791,7 @@ int always; if (avlist2 != NULL) free((void *)avlist2); if (always) { /* rebuild without sorting */ - copystruct(&oldatrunk, &atrunk); + oldatrunk = atrunk; atrunk.alist = NULL; atrunk.kid = NULL; unloadatree(&oldatrunk, avinsert); @@ -772,14 +822,14 @@ int always; if (avlist1[i].p == NULL) continue; tap = avlist2[i]; - copystruct(&tav, tap); + tav = *tap; for (j = i; (pnext = avlist1[j].p) != tap; j = avlmemi(pnext)) { - copystruct(avlist2[j], pnext); + *(avlist2[j]) = *pnext; avinsert(avlist2[j]); avlist1[j].p = NULL; } - copystruct(avlist2[j], &tav); + *(avlist2[j]) = tav; avinsert(avlist2[j]); avlist1[j].p = NULL; } @@ -804,8 +854,9 @@ int always; #ifdef F_SETLKW static void -aflock(typ) /* lock/unlock ambient file */ -int typ; +aflock( /* lock/unlock ambient file */ + int typ +) { static struct flock fls; /* static so initialized to zeroes */ @@ -815,8 +866,8 @@ int typ; } -int -ambsync() /* synchronize ambient file */ +extern int +ambsync(void) /* synchronize ambient file */ { long flen; AMBVAL avs; @@ -829,9 +880,9 @@ ambsync() /* synchronize ambient file */ /* gain exclusive access */ aflock(F_WRLCK); /* see if file has grown */ - if ((flen = lseek(fileno(ambfp), (off_t)0L, 2)) < 0) + if ((flen = lseek(fileno(ambfp), (off_t)0, SEEK_END)) < 0) goto seekerr; - if (n = flen - lastpos) { /* file has grown */ + if ( (n = flen - lastpos) ) { /* file has grown */ if (ambinp == NULL) { /* use duplicate filedes */ ambinp = fdopen(dup(fileno(ambfp)), "r"); if (ambinp == NULL) @@ -852,7 +903,7 @@ ambsync() /* synchronize ambient file */ } /*** seek always as safety measure if (n) ***/ /* alignment */ - if (lseek(fileno(ambfp), (off_t)(flen-n), 0) < 0) + if (lseek(fileno(ambfp), (off_t)(flen-n), SEEK_SET) < 0) goto seekerr; } #ifdef DEBUG @@ -865,19 +916,20 @@ ambsync() /* synchronize ambient file */ #endif syncend: n = fflush(ambfp); /* calls write() at last */ - if ((lastpos = lseek(fileno(ambfp), (off_t)0L, 1)) < 0) + if ((lastpos = lseek(fileno(ambfp), (off_t)0, SEEK_CUR)) < 0) goto seekerr; aflock(F_UNLCK); /* release file */ nunflshed = 0; return(n); seekerr: error(SYSTEM, "seek failed in ambsync"); + return -1; /* pro forma return */ } #else -int -ambsync() /* flush ambient file */ +extern int +ambsync(void) /* flush ambient file */ { if (nunflshed == 0) return(0);
