--- ray/src/rt/ambient.c 1991/10/26 15:19:06 1.18 +++ ray/src/rt/ambient.c 1996/02/14 15:43:22 2.36 @@ -1,4 +1,4 @@ -/* Copyright (c) 1991 Regents of the University of California */ +/* Copyright (c) 1995 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -6,11 +6,6 @@ static char SCCSid[] = "$SunId$ LBL"; /* * ambient.c - routines dealing with ambient (inter-reflected) component. - * - * The macro AMBFLUSH (if defined) is the number of ambient values - * to wait before flushing to the ambient file. - * - * 5/9/86 */ #include "ray.h" @@ -23,61 +18,147 @@ static char SCCSid[] = "$SunId$ LBL"; #include "random.h" -#define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */ +#ifndef OCTSCALE +#define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */ +#endif typedef struct ambtree { - AMBVAL *alist; /* ambient value list */ - struct ambtree *kid; /* 8 child nodes */ + AMBVAL *alist; /* ambient value list */ + struct ambtree *kid; /* 8 child nodes */ } AMBTREE; /* ambient octree */ extern CUBE thescene; /* contains space boundaries */ -#define MAXASET 511 /* maximum number of elements in ambient set */ -OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */ +extern char *shm_boundary; /* memory sharing boundary */ -double maxarad; /* maximum ambient radius */ -double minarad; /* minimum ambient radius */ +#define MAXASET 511 /* maximum number of elements in ambient set */ +OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */ -static AMBTREE atrunk; /* our ambient trunk node */ +double maxarad; /* maximum ambient radius */ +double minarad; /* minimum ambient radius */ +static AMBTREE atrunk; /* our ambient trunk node */ + static FILE *ambfp = NULL; /* ambient file pointer */ +static int nunflshed = 0; /* number of unflushed ambient values */ -#define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL)) +#ifndef SORT_THRESH +#ifdef BIGMEM +#define SORT_THRESH ((9L<<20)/sizeof(AMBVAL)) +#else +#define SORT_THRESH ((3L<<20)/sizeof(AMBVAL)) +#endif +#endif +#ifndef SORT_INTVL +#define SORT_INTVL (SORT_THRESH*256) +#endif +#ifndef MAX_SORT_INTVL +#define MAX_SORT_INTVL (SORT_INTVL<<4) +#endif -#define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE)) +static COLOR avsum = BLKCOLOR; /* computed ambient value sum */ +static unsigned int nambvals = 0; /* total number of indirect values */ +static unsigned int nambshare = 0; /* number of values from file */ +static unsigned long ambclock = 0; /* ambient access clock */ +static unsigned long lastsort = 0; /* time of last value sort */ +static long sortintvl = SORT_INTVL; /* time until next sort */ +#define MAXACLOCK (1L<<30) /* clock turnover value */ + /* + * Track access times unless we are sharing ambient values + * through memory on a multiprocessor, when we want to avoid + * claiming our own memory (copy on write). Go ahead anyway + * if more than two thirds of our values are unshared. + */ +#define tracktime (shm_boundary == NULL || nambvals > 3*nambshare) -setambient(afile) /* initialize calculation */ -char *afile; +#define AMBFLUSH (BUFSIZ/AMBVALSIZ) + +#define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL)) + +extern long ftell(), lseek(); +static int initambfile(), avsave(), avinsert(), sortambvals(); +static AMBVAL *avstore(); +#ifdef F_SETLKW +static aflock(); +#endif + + +setambres(ar) /* set ambient resolution */ +int ar; { - long ftell(); - AMBVAL amb; + ambres = ar < 0 ? 0 : ar; /* may be done already */ + /* set min & max radii */ + if (ar <= 0) { + minarad = 0; + maxarad = thescene.cusize / 2.0; + } else { + minarad = thescene.cusize / ar; + maxarad = 64 * minarad; /* heuristic */ + if (maxarad > thescene.cusize / 2.0) + maxarad = thescene.cusize / 2.0; + } + if (minarad <= FTINY) + minarad = 10*FTINY; + if (maxarad <= minarad) + maxarad = 64 * minarad; +} - maxarad = thescene.cusize / 2.0; /* maximum radius */ - /* minimum radius */ - minarad = ambres > 0 ? thescene.cusize/ambres : 0.0; - /* open ambient file */ - if (afile != NULL) - if ((ambfp = fopen(afile, "r+")) != NULL) { - while (fread((char *)&amb,sizeof(AMBVAL),1,ambfp) == 1) - avinsert(&amb, &atrunk, thescene.cuorg, - thescene.cusize); - /* align */ - fseek(ambfp, -(ftell(ambfp)%sizeof(AMBVAL)), 1); - } else if ((ambfp = fopen(afile, "w")) == NULL) { - sprintf(errmsg, "cannot open ambient file \"%s\"", - afile); - error(SYSTEM, errmsg); - } +setambacc(newa) /* set ambient accuracy */ +double newa; +{ + double ambdiff; + + if (newa < 0.0) + newa = 0.0; + ambdiff = fabs(newa - ambacc); + if (ambdiff >= .01 && (ambacc = newa) > FTINY && nambvals > 0) + sortambvals(1); /* rebuild tree */ } +setambient(afile) /* initialize calculation */ +char *afile; +{ + long headlen; + AMBVAL amb; + /* init ambient limits */ + setambres(ambres); + setambacc(ambacc); + if (afile == NULL) + return; + if (ambacc <= FTINY) { + sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened", + afile); + error(WARNING, errmsg); + return; + } + /* open ambient file */ + if ((ambfp = fopen(afile, "r+")) != NULL) { + initambfile(0); + headlen = ftell(ambfp); + while (readambval(&amb, ambfp)) + avinsert(avstore(&amb)); + /* align */ + fseek(ambfp, -((ftell(ambfp)-headlen)%AMBVALSIZ), 1); + nambshare = nambvals; + } else if ((ambfp = fopen(afile, "w+")) != NULL) + initambfile(1); + else { + sprintf(errmsg, "cannot open ambient file \"%s\"", afile); + error(SYSTEM, errmsg); + } + nunflshed++; /* lie */ + ambsync(); +} + + ambnotify(obj) /* record new modifier */ -OBJECT obj; +OBJECT obj; { static int hitlimit = 0; - register OBJREC *o = objptr(obj); + register OBJREC *o = objptr(obj); register char **amblp; if (hitlimit || !ismodifier(o->otype)) @@ -95,12 +176,13 @@ OBJECT obj; } -ambient(acol, r) /* compute ambient component for ray */ +ambient(acol, r, nrm) /* compute ambient component for ray */ COLOR acol; register RAY *r; +FVECT nrm; { static int rdepth = 0; /* ambient recursion */ - double d; + double d; if (ambdiv <= 0) /* no ambient calculation */ goto dumbamb; @@ -116,59 +198,74 @@ register RAY *r; rdepth++; d = doambient(acol, r, r->rweight, NULL, NULL); rdepth--; - if (d == 0.0) + if (d <= FTINY) goto dumbamb; return; } + /* resort memory? */ + sortambvals(0); /* get ambient value */ setcolor(acol, 0.0, 0.0, 0.0); - d = sumambient(acol, r, rdepth, + d = sumambient(acol, r, nrm, rdepth, &atrunk, thescene.cuorg, thescene.cusize); - if (d > FTINY) + if (d > FTINY) { scalecolor(acol, 1.0/d); - else { - d = makeambient(acol, r, rdepth++); - rdepth--; + return; } + rdepth++; /* need to cache new value */ + d = makeambient(acol, r, nrm, rdepth-1); + rdepth--; if (d > FTINY) return; dumbamb: /* return global value */ copycolor(acol, ambval); + if (ambvwt <= 0 | nambvals == 0) + return; + scalecolor(acol, (double)ambvwt); + addcolor(acol, avsum); /* average in computations */ + d = 1.0/(ambvwt+nambvals); + scalecolor(acol, d); } double -sumambient(acol, r, al, at, c0, s) /* get interpolated ambient value */ +sumambient(acol, r, rn, al, at, c0, s) /* get interpolated ambient value */ COLOR acol; register RAY *r; +FVECT rn; int al; -AMBTREE *at; +AMBTREE *at; FVECT c0; -double s; +double s; { - extern double sqrt(); - double d, e1, e2, wt, wsum; + double d, e1, e2, wt, wsum; COLOR ct; FVECT ck0; int i; register int j; - register AMBVAL *av; - /* do this node */ + register AMBVAL *av; + wsum = 0.0; + /* do this node */ for (av = at->alist; av != NULL; av = av->next) { + if (tracktime) + av->latick = ambclock++; /* * Ambient level test. */ - if (av->lvl > al || av->weight < r->rweight-FTINY) + if (av->lvl > al) /* list sorted, so this works */ + break; + if (av->weight < r->rweight-FTINY) continue; /* * Ambient radius test. */ - e1 = 0.0; - for (j = 0; j < 3; j++) { - d = av->pos[j] - r->rop[j]; - e1 += d * d; - } + d = av->pos[0] - r->rop[0]; + e1 = d * d; + d = av->pos[1] - r->rop[1]; + e1 += d * d; + d = av->pos[2] - r->rop[2]; + e1 += d * d; e1 /= av->rad * av->rad; if (e1 > ambacc*ambacc*1.21) continue; @@ -192,15 +289,14 @@ double s; * Jittering final test reduces image artifacts. */ wt = sqrt(e1) + sqrt(e2); - wt *= .9 + .2*frandom(); - if (wt > ambacc) + if (wt > ambacc*(.9+.2*urand(9015+samplendx))) continue; if (wt <= 1e-3) wt = 1e3; else wt = 1.0 / wt; wsum += wt; - extambient(ct, av, r->rop, r->ron); + extambient(ct, av, r->rop, rn); scalecolor(ct, wt); addcolor(acol, ct); } @@ -219,27 +315,28 @@ double s; break; } if (j == 3) - wsum += sumambient(acol, r, al, at->kid+i, ck0, s); + wsum += sumambient(acol, r, rn, al, at->kid+i, ck0, s); } return(wsum); } double -makeambient(acol, r, al) /* make a new ambient value */ +makeambient(acol, r, rn, al) /* make a new ambient value */ COLOR acol; register RAY *r; +FVECT rn; int al; { - AMBVAL amb; + AMBVAL amb; FVECT gp, gd; /* compute weight */ amb.weight = pow(AVGREFL, (double)al); - if (r->rweight < 0.2*amb.weight) /* heuristic */ + if (r->rweight < 0.1*amb.weight) /* heuristic */ amb.weight = r->rweight; /* compute ambient */ amb.rad = doambient(acol, r, amb.weight, gp, gd); - if (amb.rad == 0.0) + if (amb.rad <= FTINY) return(0.0); /* store it */ VCOPY(amb.pos, r->rop); @@ -249,20 +346,21 @@ int al; VCOPY(amb.gpos, gp); VCOPY(amb.gdir, gd); /* insert into tree */ - avinsert(&amb, &atrunk, thescene.cuorg, thescene.cusize); - avsave(&amb); /* write to file */ + avsave(&amb); /* and save to file */ + if (rn != r->ron) + extambient(acol, &amb, r->rop, rn); /* texture */ return(amb.rad); } extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */ COLOR cr; -register AMBVAL *ap; +register AMBVAL *ap; FVECT pv, nv; { FVECT v1, v2; register int i; - double d; + double d; d = 1.0; /* zeroeth order */ /* gradient due to translation */ @@ -282,49 +380,129 @@ FVECT pv, nv; static -avsave(av) /* save an ambient value */ -AMBVAL *av; +initambfile(creat) /* initialize ambient file */ +int creat; { -#ifdef AMBFLUSH - static int nunflshed = 0; + extern char *progname, *octname, VersionID[]; + +#ifdef F_SETLKW + aflock(creat ? F_WRLCK : F_RDLCK); #endif +#ifdef MSDOS + setmode(fileno(ambfp), O_BINARY); +#endif + setbuf(ambfp, bmalloc(BUFSIZ+8)); + if (creat) { /* new file */ + newheader("RADIANCE", ambfp); + fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ", + progname, colval(ambval,RED), + colval(ambval,GRN), colval(ambval,BLU), + ambounce, ambacc); + fprintf(ambfp, "-ad %d -as %d -ar %d %s\n", + ambdiv, ambssamp, ambres, + octname==NULL ? "" : octname); + fprintf(ambfp, "SOFTWARE= %s\n", VersionID); + fputformat(AMBFMT, ambfp); + putc('\n', ambfp); + putambmagic(ambfp); + } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp)) + error(USER, "bad ambient file"); +} + + +static +avsave(av) /* insert and save an ambient value */ +AMBVAL *av; +{ + avinsert(avstore(av)); if (ambfp == NULL) return; - if (fwrite((char *)av, sizeof(AMBVAL), 1, ambfp) != 1) + if (writambval(av, ambfp) < 0) goto writerr; -#ifdef AMBFLUSH - if (++nunflshed >= AMBFLUSH) { - if (fflush(ambfp) == EOF) + if (++nunflshed >= AMBFLUSH) + if (ambsync() == EOF) goto writerr; - nunflshed = 0; - } -#endif return; writerr: error(SYSTEM, "error writing ambient file"); } +static AMBVAL * +avstore(aval) /* allocate memory and store aval */ +register AMBVAL *aval; +{ + register AMBVAL *av; + + if ((av = newambval()) == NULL) + error(SYSTEM, "out of memory in avstore"); + copystruct(av, aval); + av->latick = ambclock; + av->next = NULL; + addcolor(avsum, av->val); /* add to sum for averaging */ + nambvals++; + return(av); +} + + +#define ATALLOCSZ 512 /* #/8 trees to allocate at once */ + +static AMBTREE *atfreelist = NULL; /* free ambient tree structures */ + + static -avinsert(aval, at, c0, s) /* insert ambient value in a tree */ -AMBVAL *aval; -register AMBTREE *at; -FVECT c0; -double s; +AMBTREE * +newambtree() /* allocate 8 ambient tree structs */ { + register AMBTREE *atp, *upperlim; + + if (atfreelist == NULL) { /* get more nodes */ + atfreelist = (AMBTREE *)bmalloc(ATALLOCSZ*8*sizeof(AMBTREE)); + if (atfreelist == NULL) + return(NULL); + /* link new free list */ + upperlim = atfreelist + 8*(ATALLOCSZ-1); + for (atp = atfreelist; atp < upperlim; atp += 8) + atp->kid = atp + 8; + atp->kid = NULL; + } + atp = atfreelist; + atfreelist = atp->kid; + bzero((char *)atp, 8*sizeof(AMBTREE)); + return(atp); +} + + +static +freeambtree(atp) /* free 8 ambient tree structs */ +AMBTREE *atp; +{ + atp->kid = atfreelist; + atfreelist = atp; +} + + +static +avinsert(av) /* insert ambient value in our tree */ +register AMBVAL *av; +{ + register AMBTREE *at; + register AMBVAL *ap; + AMBVAL avh; FVECT ck0; + double s; int branch; - register AMBVAL *av; register int i; - if ((av = newambval()) == NULL) - goto memerr; - copystruct(av, aval); - VCOPY(ck0, c0); + if (av->rad <= FTINY) + error(CONSISTENCY, "zero ambient radius in avinsert"); + at = &atrunk; + VCOPY(ck0, thescene.cuorg); + s = thescene.cusize; while (s*(OCTSCALE/2) > av->rad*ambacc) { if (at->kid == NULL) if ((at->kid = newambtree()) == NULL) - goto memerr; + error(SYSTEM, "out of memory in avinsert"); s *= 0.5; branch = 0; for (i = 0; i < 3; i++) @@ -334,9 +512,262 @@ double s; } at = at->kid + branch; } - av->next = at->alist; - at->alist = av; - return; -memerr: - error(SYSTEM, "out of memory in avinsert"); + avh.next = at->alist; /* order by increasing level */ + for (ap = &avh; ap->next != NULL; ap = ap->next) + if (ap->next->lvl >= av->lvl) + break; + av->next = ap->next; + ap->next = av; + at->alist = avh.next; } + + +static +unloadatree(at, f) /* unload an ambient value tree */ +register AMBTREE *at; +int (*f)(); +{ + register AMBVAL *av; + register int i; + /* transfer values at this node */ + for (av = at->alist; av != NULL; av = at->alist) { + at->alist = av->next; + (*f)(av); + } + if (at->kid == NULL) + return; + for (i = 0; i < 8; i++) /* transfer and free children */ + unloadatree(at->kid+i, f); + freeambtree(at->kid); + at->kid = NULL; +} + + +static AMBVAL **avlist1, **avlist2; /* ambient value lists for sorting */ +static int i_avlist; /* index for lists */ + + +static +av2list(av) +AMBVAL *av; +{ +#ifdef DEBUG + if (i_avlist >= nambvals) + error(CONSISTENCY, "too many ambient values in av2list1"); +#endif + avlist1[i_avlist] = avlist2[i_avlist] = av; + i_avlist++; +} + + +static int +alatcmp(avp1, avp2) /* compare ambient values for MRA */ +AMBVAL **avp1, **avp2; +{ + return((**avp2).latick - (**avp1).latick); +} + + +static int +aposcmp(avp1, avp2) /* compare ambient value positions */ +AMBVAL **avp1, **avp2; +{ + return(*avp1 - *avp2); +} + + +#ifdef DEBUG +static int +avlmemi(avaddr) /* find list position from address */ +AMBVAL *avaddr; +{ + register AMBVAL **avlpp; + + avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2, + nambvals, sizeof(AMBVAL *), aposcmp); + if (avlpp == NULL) + error(CONSISTENCY, "address not found in avlmemi"); + return(avlpp - avlist2); +} +#else +#define avlmemi(avaddr) ((AMBVAL **)bsearch((char *)&avaddr,(char *)avlist2, \ + nambvals,sizeof(AMBVAL *),aposcmp) - avlist2) +#endif + + +static +sortambvals(always) /* resort ambient values */ +int always; +{ + AMBTREE oldatrunk; + AMBVAL tav, *tap, *pnext; + register int i, j; + /* see if it's time yet */ + if (!always && (ambclock < lastsort+sortintvl || + nambvals < SORT_THRESH)) + return; + /* + * The idea here is to minimize memory thrashing + * in VM systems by improving reference locality. + * We do this by periodically sorting our stored ambient + * values in memory in order of most recently to least + * recently accessed. This ordering was chosen so that new + * ambient values (which tend to be less important) go into + * higher memory with the infrequently accessed values. + * Since we expect our values to need sorting less + * frequently as the process continues, we double our + * waiting interval after each call. + * This routine is also called by setambacc() with + * the "always" parameter set to 1 so that the ambient + * tree will be rebuilt with the new accuracy parameter. + */ + if (tracktime) { /* allocate pointer arrays to sort */ + avlist1 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *)); + avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *)); + } else + avlist1 = avlist2 = NULL; + if (avlist2 == NULL) { /* no time tracking -- rebuild tree? */ + if (avlist1 != NULL) + free((char *)avlist1); + if (always) { /* rebuild without sorting */ + copystruct(&oldatrunk, &atrunk); + atrunk.alist = NULL; + atrunk.kid = NULL; + unloadatree(&oldatrunk, avinsert); + } + } else { /* sort memory by last access time */ + /* + * Sorting memory is tricky because it isn't contiguous. + * We have to sort an array of pointers by MRA and also + * by memory position. We then copy values in "loops" + * to minimize memory hits. Nevertheless, we will visit + * everyone at least twice, and this is an expensive process + * when we're thrashing, which is when we need to do it. + */ +#ifdef DEBUG + sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...", + nambvals, ambclock); + eputs(errmsg); +#endif + i_avlist = 0; + unloadatree(&atrunk, av2list); /* empty current tree */ +#ifdef DEBUG + if (i_avlist < nambvals) + error(CONSISTENCY, "missing ambient values in sortambvals"); +#endif + qsort((char *)avlist1, nambvals, sizeof(AMBVAL *), alatcmp); + qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), aposcmp); + for (i = 0; i < nambvals; i++) { + if (avlist1[i] == NULL) + continue; + tap = avlist2[i]; + copystruct(&tav, tap); + for (j = i; (pnext = avlist1[j]) != tap; + j = avlmemi(pnext)) { + copystruct(avlist2[j], pnext); + avinsert(avlist2[j]); + avlist1[j] = NULL; + } + copystruct(avlist2[j], &tav); + avinsert(avlist2[j]); + avlist1[j] = NULL; + } + free((char *)avlist1); + free((char *)avlist2); + /* compute new sort interval */ + sortintvl = ambclock - lastsort; + if (sortintvl >= MAX_SORT_INTVL/2) + sortintvl = MAX_SORT_INTVL; + else + sortintvl <<= 1; /* wait twice as long next */ +#ifdef DEBUG + eputs("done\n"); +#endif + } + if (ambclock >= MAXACLOCK) + ambclock = MAXACLOCK/2; + lastsort = ambclock; +} + + +#ifdef F_SETLKW + +static +aflock(typ) /* lock/unlock ambient file */ +int typ; +{ + static struct flock fls; /* static so initialized to zeroes */ + + fls.l_type = typ; + if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0) + error(SYSTEM, "cannot (un)lock ambient file"); +} + + +int +ambsync() /* synchronize ambient file */ +{ + static FILE *ambinp = NULL; + static long lastpos = -1; + long flen; + AMBVAL avs; + register int n; + + if (nunflshed == 0) + return(0); + if (lastpos < 0) /* initializing (locked in initambfile) */ + goto syncend; + /* gain exclusive access */ + aflock(F_WRLCK); + /* see if file has grown */ + if ((flen = lseek(fileno(ambfp), 0L, 2)) < 0) + goto seekerr; + if (n = flen - lastpos) { /* file has grown */ + if (ambinp == NULL) { /* use duplicate filedes */ + ambinp = fdopen(dup(fileno(ambfp)), "r"); + if (ambinp == NULL) + error(SYSTEM, "fdopen failed in ambsync"); + } + if (fseek(ambinp, lastpos, 0) < 0) + goto seekerr; + while (n >= AMBVALSIZ) { /* load contributed values */ + readambval(&avs, ambinp); + avinsert(avstore(&avs)); + n -= AMBVALSIZ; + } + /*** seek always as safety measure + if (n) ***/ /* alignment */ + if (lseek(fileno(ambfp), flen-n, 0) < 0) + goto seekerr; + } +#ifdef DEBUG + if (ambfp->_ptr - ambfp->_base != nunflshed*AMBVALSIZ) { + sprintf(errmsg, "ambient file buffer at %d rather than %d", + ambfp->_ptr - ambfp->_base, + nunflshed*AMBVALSIZ); + error(CONSISTENCY, errmsg); + } +#endif +syncend: + n = fflush(ambfp); /* calls write() at last */ + if ((lastpos = lseek(fileno(ambfp), 0L, 1)) < 0) + goto seekerr; + aflock(F_UNLCK); /* release file */ + nunflshed = 0; + return(n); +seekerr: + error(SYSTEM, "seek failed in ambsync"); +} + +#else + +int +ambsync() /* flush ambient file */ +{ + if (nunflshed == 0) + return(0); + nunflshed = 0; + return(fflush(ambfp)); +} + +#endif
