--- ray/src/rt/ambient.c 1989/02/02 10:41:17 1.1 +++ ray/src/rt/ambient.c 1999/01/10 12:45:19 2.46 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1996 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -6,122 +6,212 @@ static char SCCSid[] = "$SunId$ LBL"; /* * ambient.c - routines dealing with ambient (inter-reflected) component. - * - * The macro AMBFLUSH (if defined) is the number of ambient values - * to wait before flushing to the ambient file. - * - * 5/9/86 */ #include "ray.h" #include "octree.h" +#include "otypes.h" + +#include "ambient.h" + #include "random.h" -#define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */ +#ifndef OCTSCALE +#define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */ +#endif +typedef struct ambtree { + AMBVAL *alist; /* ambient value list */ + struct ambtree *kid; /* 8 child nodes */ +} AMBTREE; /* ambient octree */ + extern CUBE thescene; /* contains space boundaries */ -extern COLOR ambval; /* global ambient component */ -extern double ambacc; /* ambient accuracy */ -extern int ambres; /* ambient resolution */ -extern int ambdiv; /* number of divisions for calculation */ -extern int ambssamp; /* number of super-samples */ -extern int ambounce; /* number of ambient bounces */ -extern char *amblist[]; /* ambient include/exclude list */ -extern int ambincl; /* include == 1, exclude == 0 */ +extern char *shm_boundary; /* memory sharing boundary */ -OBJECT ambset[128]; /* ambient include/exclude set */ +#define MAXASET 511 /* maximum number of elements in ambient set */ +OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */ -double maxarad; /* maximum ambient radius */ -double minarad; /* minimum ambient radius */ +double maxarad; /* maximum ambient radius */ +double minarad; /* minimum ambient radius */ -typedef struct ambval { - FVECT pos; /* position in space */ - FVECT dir; /* normal direction */ - int lvl; /* recursion level of parent ray */ - float weight; /* weight of parent ray */ - COLOR val; /* computed ambient value */ - float rad; /* validity radius */ - struct ambval *next; /* next in list */ -} AMBVAL; /* ambient value */ +static AMBTREE atrunk; /* our ambient trunk node */ -typedef struct ambtree { - AMBVAL *alist; /* ambient value list */ - struct ambtree *kid; /* 8 child nodes */ -} AMBTREE; /* ambient octree */ +static FILE *ambfp = NULL; /* ambient file pointer */ +static int nunflshed = 0; /* number of unflushed ambient values */ -typedef struct { - float k; /* error contribution per sample */ - COLOR v; /* ray sum */ - int n; /* number of samples */ - short t, p; /* theta, phi indices */ -} AMBSAMP; /* ambient sample */ +#ifndef SORT_THRESH +#ifdef BIGMEM +#define SORT_THRESH ((9L<<20)/sizeof(AMBVAL)) +#else +#define SORT_THRESH ((3L<<20)/sizeof(AMBVAL)) +#endif +#endif +#ifndef SORT_INTVL +#define SORT_INTVL (SORT_THRESH<<1) +#endif +#ifndef MAX_SORT_INTVL +#define MAX_SORT_INTVL (SORT_INTVL<<6) +#endif -static AMBTREE atrunk; /* our ambient trunk node */ +static double avsum = 0.; /* computed ambient value sum (log) */ +static unsigned int navsum = 0; /* number of values in avsum */ +static unsigned int nambvals = 0; /* total number of indirect values */ +static unsigned int nambshare = 0; /* number of values from file */ +static unsigned long ambclock = 0; /* ambient access clock */ +static unsigned long lastsort = 0; /* time of last value sort */ +static long sortintvl = SORT_INTVL; /* time until next sort */ -static FILE *ambfp = NULL; /* ambient file pointer */ +#define MAXACLOCK (1L<<30) /* clock turnover value */ + /* + * Track access times unless we are sharing ambient values + * through memory on a multiprocessor, when we want to avoid + * claiming our own memory (copy on write). Go ahead anyway + * if more than two thirds of our values are unshared. + * Compile with -Dtracktime=0 to turn this code off. + */ +#ifndef tracktime +#define tracktime (shm_boundary == NULL || nambvals > 3*nambshare) +#endif -#define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL)) +#define AMBFLUSH (BUFSIZ/AMBVALSIZ) -#define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE)) +#define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL)) -double sumambient(), doambient(), makeambient(); +static int initambfile(), avsave(), avinsert(), sortambvals(), avlmemi(); +static AMBVAL *avstore(); +#ifdef F_SETLKW +static aflock(); +#endif +setambres(ar) /* set ambient resolution */ +int ar; +{ + ambres = ar < 0 ? 0 : ar; /* may be done already */ + /* set min & max radii */ + if (ar <= 0) { + minarad = 0; + maxarad = thescene.cusize / 2.0; + } else { + minarad = thescene.cusize / ar; + maxarad = 64 * minarad; /* heuristic */ + if (maxarad > thescene.cusize / 2.0) + maxarad = thescene.cusize / 2.0; + } + if (minarad <= FTINY) + minarad = 10*FTINY; + if (maxarad <= minarad) + maxarad = 64 * minarad; +} + + +setambacc(newa) /* set ambient accuracy */ +double newa; +{ + double ambdiff; + + if (newa < 0.0) + newa = 0.0; + ambdiff = fabs(newa - ambacc); + if (ambdiff >= .01 && (ambacc = newa) > FTINY && nambvals > 0) + sortambvals(1); /* rebuild tree */ +} + + setambient(afile) /* initialize calculation */ char *afile; { - long ftell(); - char **amblp; - OBJECT obj; - AMBVAL amb; - /* set up ambient set */ - ambset[0] = 0; - for (amblp = amblist; *amblp != NULL; amblp++) { - if ((obj = modifier(*amblp)) == OVOID) { - sprintf(errmsg, "unknown %s modifier \"%s\"", - ambincl ? "include" : "exclude", *amblp); + int readonly = 0; + long pos, flen; + AMBVAL amb; + /* init ambient limits */ + setambres(ambres); + setambacc(ambacc); + if (afile == NULL) + return; + if (ambacc <= FTINY) { + sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened", + afile); + error(WARNING, errmsg); + return; + } + /* open ambient file */ + if ((ambfp = fopen(afile, "r+")) == NULL) + readonly = (ambfp = fopen(afile, "r")) != NULL; + if (ambfp != NULL) { + initambfile(0); /* file exists */ + pos = ftell(ambfp); + while (readambval(&amb, ambfp)) + avinsert(avstore(&amb)); + nambshare = nambvals; /* share loaded values */ + if (readonly) { + sprintf(errmsg, + "loaded %u values from read-only ambient file", + nambvals); error(WARNING, errmsg); - continue; + fclose(ambfp); /* close file so no writes */ + ambfp = NULL; + return; /* avoid ambsync() */ } - if (!inset(ambset, obj)) - insertelem(ambset, obj); + /* align file pointer */ + pos += (long)nambvals*AMBVALSIZ; + flen = lseek(fileno(ambfp), 0L, 2); + if (flen != pos) { + sprintf(errmsg, + "ignoring last %ld values in ambient file (corrupted)", + (flen - pos)/AMBVALSIZ); + error(WARNING, errmsg); + fseek(ambfp, pos, 0); + ftruncate(fileno(ambfp), pos); + } + } else if ((ambfp = fopen(afile, "w+")) != NULL) { + initambfile(1); /* else create new file */ + } else { + sprintf(errmsg, "cannot open ambient file \"%s\"", afile); + error(SYSTEM, errmsg); } - maxarad = thescene.cusize / 2.0; /* maximum radius */ - /* minimum radius */ - minarad = ambres > 0 ? thescene.cusize/ambres : 0.0; + nunflshed++; /* lie */ + ambsync(); +} - /* open ambient file */ - if (afile != NULL) - if ((ambfp = fopen(afile, "r+")) != NULL) { - while (fread(&amb, sizeof(AMBVAL), 1, ambfp) == 1) - avinsert(&amb, &atrunk, thescene.cuorg, - thescene.cusize); - /* align */ - fseek(ambfp, -(ftell(ambfp)%sizeof(AMBVAL)), 1); - } else if ((ambfp = fopen(afile, "w")) == NULL) { - sprintf(errmsg, "cannot open ambient file \"%s\"", - afile); - error(SYSTEM, errmsg); + +ambnotify(obj) /* record new modifier */ +OBJECT obj; +{ + static int hitlimit = 0; + register OBJREC *o = objptr(obj); + register char **amblp; + + if (hitlimit || !ismodifier(o->otype)) + return; + for (amblp = amblist; *amblp != NULL; amblp++) + if (!strcmp(o->oname, *amblp)) { + if (ambset[0] >= MAXASET) { + error(WARNING, "too many modifiers in ambient list"); + hitlimit++; + return; /* should this be fatal? */ + } + insertelem(ambset, obj); + return; } } -ambient(acol, r) /* compute ambient component for ray */ +ambient(acol, r, nrm) /* compute ambient component for ray */ COLOR acol; register RAY *r; +FVECT nrm; { static int rdepth = 0; /* ambient recursion */ - double wsum; + double d, l; - rdepth++; /* increment level */ - if (ambdiv <= 0) /* no ambient calculation */ goto dumbamb; /* check number of bounces */ - if (rdepth > ambounce) + if (rdepth >= ambounce) goto dumbamb; /* check ambient list */ if (ambincl != -1 && r->ro != NULL && @@ -129,57 +219,84 @@ register RAY *r; goto dumbamb; if (ambacc <= FTINY) { /* no ambient storage */ - if (doambient(acol, r) == 0.0) + rdepth++; + d = doambient(acol, r, r->rweight, NULL, NULL); + rdepth--; + if (d <= FTINY) goto dumbamb; - goto done; + return; } + + if (tracktime) /* sort to minimize thrashing */ + sortambvals(0); /* get ambient value */ setcolor(acol, 0.0, 0.0, 0.0); - wsum = sumambient(acol, r, &atrunk, thescene.cuorg, thescene.cusize); - if (wsum > FTINY) - scalecolor(acol, 1.0/wsum); - else if (makeambient(acol, r) == 0.0) - goto dumbamb; - goto done; - + d = sumambient(acol, r, nrm, rdepth, + &atrunk, thescene.cuorg, thescene.cusize); + if (d > FTINY) { + scalecolor(acol, 1.0/d); + return; + } + rdepth++; /* need to cache new value */ + d = makeambient(acol, r, nrm, rdepth-1); + rdepth--; + if (d > FTINY) + return; dumbamb: /* return global value */ copycolor(acol, ambval); -done: /* must finish here! */ - rdepth--; + if (ambvwt <= 0 | navsum == 0) + return; + l = bright(ambval); /* average in computations */ + if (l > FTINY) { + d = (log(l)*(double)ambvwt + avsum) / + (double)(ambvwt + navsum); + d = exp(d) / l; + scalecolor(acol, d); /* apply color of ambval */ + } else { + d = exp( avsum / (double)navsum ); + setcolor(acol, d, d, d); /* neutral color */ + } } double -sumambient(acol, r, at, c0, s) /* get interpolated ambient value */ +sumambient(acol, r, rn, al, at, c0, s) /* get interpolated ambient value */ COLOR acol; register RAY *r; -AMBTREE *at; +FVECT rn; +int al; +AMBTREE *at; FVECT c0; -double s; +double s; { - extern double sqrt(); - double d, e1, e2, wt, wsum; + double d, e1, e2, wt, wsum; COLOR ct; FVECT ck0; int i; register int j; - register AMBVAL *av; - /* do this node */ + register AMBVAL *av; + wsum = 0.0; + /* do this node */ for (av = at->alist; av != NULL; av = av->next) { + if (tracktime) + av->latick = ambclock; /* - * Ray strength test. + * Ambient level test. */ - if (av->lvl > r->rlvl || av->weight < r->rweight-FTINY) + if (av->lvl > al) /* list sorted, so this works */ + break; + if (av->weight < r->rweight-FTINY) continue; /* * Ambient radius test. */ - e1 = 0.0; - for (j = 0; j < 3; j++) { - d = av->pos[j] - r->rop[j]; - e1 += d * d; - } + d = av->pos[0] - r->rop[0]; + e1 = d * d; + d = av->pos[1] - r->rop[1]; + e1 += d * d; + d = av->pos[2] - r->rop[2]; + e1 += d * d; e1 /= av->rad * av->rad; if (e1 > ambacc*ambacc*1.21) continue; @@ -197,20 +314,20 @@ double s; for (j = 0; j < 3; j++) d += (r->rop[j] - av->pos[j]) * (av->dir[j] + r->ron[j]); - if (d < -minarad) + if (d*0.5 < -minarad*ambacc-.001) continue; /* * Jittering final test reduces image artifacts. */ wt = sqrt(e1) + sqrt(e2); - if (wt > ambacc*(0.9 + 0.2*frandom())) + if (wt > ambacc*(.9+.2*urand(9015+samplendx))) continue; if (wt <= 1e-3) wt = 1e3; else wt = 1.0 / wt; wsum += wt; - copycolor(ct, av->val); + extambient(ct, av, r->rop, rn); scalecolor(ct, wt); addcolor(acol, ct); } @@ -221,251 +338,206 @@ double s; for (i = 0; i < 8; i++) { for (j = 0; j < 3; j++) { ck0[j] = c0[j]; - if (1<rop[j] < ck0[j] - OCTSCALE*s) - break; - } else - if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s) - break; + if (r->rop[j] < ck0[j] - OCTSCALE*s) + break; + if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s) + break; } if (j == 3) - wsum += sumambient(acol, r, at->kid+i, ck0, s); + wsum += sumambient(acol, r, rn, al, at->kid+i, ck0, s); } return(wsum); } double -makeambient(acol, r) /* make a new ambient value */ +makeambient(acol, r, rn, al) /* make a new ambient value */ COLOR acol; register RAY *r; +FVECT rn; +int al; { - AMBVAL amb; - - amb.rad = doambient(acol, r); /* compute ambient */ - if (amb.rad == 0.0) + AMBVAL amb; + FVECT gp, gd; + /* compute weight */ + amb.weight = pow(AVGREFL, (double)al); + if (r->rweight < 0.1*amb.weight) /* heuristic */ + amb.weight = r->rweight; + /* compute ambient */ + amb.rad = doambient(acol, r, amb.weight, gp, gd); + if (amb.rad <= FTINY) return(0.0); /* store it */ VCOPY(amb.pos, r->rop); VCOPY(amb.dir, r->ron); - amb.lvl = r->rlvl; - amb.weight = r->rweight; + amb.lvl = al; copycolor(amb.val, acol); + VCOPY(amb.gpos, gp); + VCOPY(amb.gdir, gd); /* insert into tree */ - avinsert(&amb, &atrunk, thescene.cuorg, thescene.cusize); - avsave(&amb); /* write to file */ + avsave(&amb); /* and save to file */ + if (rn != r->ron) + extambient(acol, &amb, r->rop, rn); /* texture */ return(amb.rad); } -double -doambient(acol, r) /* compute ambient component */ -COLOR acol; -register RAY *r; +extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */ +COLOR cr; +register AMBVAL *ap; +FVECT pv, nv; { - extern int ambcmp(); - extern double sin(), cos(), sqrt(); - double phi, xd, yd, zd; - register AMBSAMP *div; - AMBSAMP dnew; - RAY ar; - FVECT ux, uy; - double arad; - int ndivs, nt, np, ns, ne, i, j; - register int k; + FVECT v1; + register int i; + double d; - setcolor(acol, 0.0, 0.0, 0.0); - /* set number of divisions */ - nt = sqrt(ambdiv * r->rweight * 0.5) + 0.5; - np = 2 * nt; - ndivs = nt * np; - /* check first */ - if (ndivs == 0 || rayorigin(&ar, r, AMBIENT, 0.5) < 0) - return(0.0); - /* set number of super-samples */ - ns = ambssamp * r->rweight + 0.5; - if (ns > 0) { - div = (AMBSAMP *)malloc(ndivs*sizeof(AMBSAMP)); - if (div == NULL) - error(SYSTEM, "out of memory in doambient"); + d = 1.0; /* zeroeth order */ + /* gradient due to translation */ + for (i = 0; i < 3; i++) + d += ap->gpos[i]*(pv[i]-ap->pos[i]); + /* gradient due to rotation */ + VCROSS(v1, ap->dir, nv); + d += DOT(ap->gdir, v1); + if (d <= 0.0) { + setcolor(cr, 0.0, 0.0, 0.0); + return; } - /* make axes */ - uy[0] = uy[1] = uy[2] = 0.0; - for (k = 0; k < 3; k++) - if (r->ron[k] < 0.6 && r->ron[k] > -0.6) - break; - uy[k] = 1.0; - fcross(ux, r->ron, uy); - normalize(ux); - fcross(uy, ux, r->ron); - /* sample divisions */ - arad = 0.0; - ne = 0; - for (i = 0; i < nt; i++) - for (j = 0; j < np; j++) { - rayorigin(&ar, r, AMBIENT, 0.5); /* pretested */ - zd = sqrt((i+frandom())/nt); - phi = 2.0*PI * (j+frandom())/np; - xd = cos(phi) * zd; - yd = sin(phi) * zd; - zd = sqrt(1.0 - zd*zd); - for (k = 0; k < 3; k++) - ar.rdir[k] = xd*ux[k]+yd*uy[k]+zd*r->ron[k]; - rayvalue(&ar); - if (ar.rot < FHUGE) - arad += 1.0 / ar.rot; - if (ns > 0) { /* save division */ - div[ne].k = 0.0; - copycolor(div[ne].v, ar.rcol); - div[ne].n = 0; - div[ne].t = i; div[ne].p = j; - /* sum errors */ - xd = bright(ar.rcol); - if (i > 0) { /* from above */ - yd = bright(div[ne-np].v) - xd; - yd *= yd * 0.25; - div[ne].k += yd; - div[ne].n++; - div[ne-np].k += yd; - div[ne-np].n++; - } - if (j > 0) { /* from behind */ - yd = bright(div[ne-1].v) - xd; - yd *= yd * 0.25; - div[ne].k += yd; - div[ne].n++; - div[ne-1].k += yd; - div[ne-1].n++; - } - if (j == np-1) { /* around */ - yd = bright(div[ne-(np-1)].v) - xd; - yd *= yd * 0.25; - div[ne].k += yd; - div[ne].n++; - div[ne-(np-1)].k += yd; - div[ne-(np-1)].n++; - } - ne++; - } else - addcolor(acol, ar.rcol); - } - for (k = 0; k < ne; k++) { /* compute errors */ - if (div[k].n > 1) - div[k].k /= div[k].n; - div[k].n = 1; - } - /* sort the divisions */ - qsort(div, ne, sizeof(AMBSAMP), ambcmp); - /* skim excess */ - while (ne > ns) { - ne--; - addcolor(acol, div[ne].v); - } - /* super-sample */ - for (i = ns; i > 0; i--) { - rayorigin(&ar, r, AMBIENT, 0.5); /* pretested */ - zd = sqrt((div[0].t+frandom())/nt); - phi = 2.0*PI * (div[0].p+frandom())/np; - xd = cos(phi) * zd; - yd = sin(phi) * zd; - zd = sqrt(1.0 - zd*zd); - for (k = 0; k < 3; k++) - ar.rdir[k] = xd*ux[k]+yd*uy[k]+zd*r->ron[k]; - rayvalue(&ar); - if (ar.rot < FHUGE) - arad += 1.0 / ar.rot; - /* recompute error */ - copycolor(dnew.v, div[0].v); - addcolor(dnew.v, ar.rcol); - dnew.n = div[0].n + 1; - dnew.t = div[0].t; dnew.p = div[0].p; - yd = bright(dnew.v)/dnew.n - bright(ar.rcol); - yd = yd*yd + div[0].k*(div[0].n*div[0].n); - dnew.k = yd/(dnew.n*dnew.n); - /* reinsert */ - for (k = 0; k < ne-1 && dnew.k < div[k+1].k; k++) - bcopy(&div[k+1], &div[k], sizeof(AMBSAMP)); - bcopy(&dnew, &div[k], sizeof(AMBSAMP)); - - if (ne >= i) { /* extract darkest division */ - ne--; - if (div[ne].n > 1) - scalecolor(div[ne].v, 1.0/div[ne].n); - addcolor(acol, div[ne].v); - } - } - scalecolor(acol, 1.0/ndivs); - if (arad <= FTINY) - arad = FHUGE; - else - arad = (ndivs+ns) / arad / sqrt(r->rweight); - if (arad > maxarad) - arad = maxarad; - else if (arad < minarad) - arad = minarad; - if (ns > 0) - free((char *)div); - return(arad); + copycolor(cr, ap->val); + scalecolor(cr, d); } -static int -ambcmp(d1, d2) /* decreasing order */ -AMBSAMP *d1, *d2; +static +initambfile(creat) /* initialize ambient file */ +int creat; { - if (d1->k < d2->k) - return(1); - if (d1->k > d2->k) - return(-1); - return(0); + extern char *progname, *octname, VersionID[]; + +#ifdef F_SETLKW + aflock(creat ? F_WRLCK : F_RDLCK); +#endif +#ifdef MSDOS + setmode(fileno(ambfp), O_BINARY); +#endif + setbuf(ambfp, bmalloc(BUFSIZ+8)); + if (creat) { /* new file */ + newheader("RADIANCE", ambfp); + fprintf(ambfp, "%s -av %g %g %g -aw %d -ab %d -aa %g ", + progname, colval(ambval,RED), + colval(ambval,GRN), colval(ambval,BLU), + ambvwt, ambounce, ambacc); + fprintf(ambfp, "-ad %d -as %d -ar %d %s\n", + ambdiv, ambssamp, ambres, + octname==NULL ? "" : octname); + fprintf(ambfp, "SOFTWARE= %s\n", VersionID); + fputformat(AMBFMT, ambfp); + putc('\n', ambfp); + putambmagic(ambfp); + } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp)) + error(USER, "bad ambient file"); } static -avsave(av) /* save an ambient value */ -AMBVAL *av; +avsave(av) /* insert and save an ambient value */ +AMBVAL *av; { -#ifdef AMBFLUSH - static int nunflshed = 0; -#endif + avinsert(avstore(av)); if (ambfp == NULL) return; - if (fwrite(av, sizeof(AMBVAL), 1, ambfp) != 1) + if (writambval(av, ambfp) < 0) goto writerr; -#ifdef AMBFLUSH - if (++nunflshed >= AMBFLUSH) { - if (fflush(ambfp) == EOF) + if (++nunflshed >= AMBFLUSH) + if (ambsync() == EOF) goto writerr; - nunflshed = 0; - } -#endif return; writerr: error(SYSTEM, "error writing ambient file"); } +static AMBVAL * +avstore(aval) /* allocate memory and store aval */ +register AMBVAL *aval; +{ + register AMBVAL *av; + double d; + + if ((av = newambval()) == NULL) + error(SYSTEM, "out of memory in avstore"); + copystruct(av, aval); + av->latick = ambclock; + av->next = NULL; + nambvals++; + d = bright(av->val); + if (d > FTINY) { /* add to log sum for averaging */ + avsum += log(d); + navsum++; + } + return(av); +} + + +#define ATALLOCSZ 512 /* #/8 trees to allocate at once */ + +static AMBTREE *atfreelist = NULL; /* free ambient tree structures */ + + static -avinsert(aval, at, c0, s) /* insert ambient value in a tree */ -AMBVAL *aval; -register AMBTREE *at; -FVECT c0; -double s; +AMBTREE * +newambtree() /* allocate 8 ambient tree structs */ { + register AMBTREE *atp, *upperlim; + + if (atfreelist == NULL) { /* get more nodes */ + atfreelist = (AMBTREE *)bmalloc(ATALLOCSZ*8*sizeof(AMBTREE)); + if (atfreelist == NULL) + return(NULL); + /* link new free list */ + upperlim = atfreelist + 8*(ATALLOCSZ-1); + for (atp = atfreelist; atp < upperlim; atp += 8) + atp->kid = atp + 8; + atp->kid = NULL; + } + atp = atfreelist; + atfreelist = atp->kid; + bzero((char *)atp, 8*sizeof(AMBTREE)); + return(atp); +} + + +static +freeambtree(atp) /* free 8 ambient tree structs */ +AMBTREE *atp; +{ + atp->kid = atfreelist; + atfreelist = atp; +} + + +static +avinsert(av) /* insert ambient value in our tree */ +register AMBVAL *av; +{ + register AMBTREE *at; + register AMBVAL *ap; + AMBVAL avh; FVECT ck0; + double s; int branch; - register AMBVAL *av; register int i; - if ((av = newambval()) == NULL) - goto memerr; - bcopy(aval, av, sizeof(AMBVAL)); - VCOPY(ck0, c0); + if (av->rad <= FTINY) + error(CONSISTENCY, "zero ambient radius in avinsert"); + at = &atrunk; + VCOPY(ck0, thescene.cuorg); + s = thescene.cusize; while (s*(OCTSCALE/2) > av->rad*ambacc) { if (at->kid == NULL) if ((at->kid = newambtree()) == NULL) - goto memerr; + error(SYSTEM, "out of memory in avinsert"); s *= 0.5; branch = 0; for (i = 0; i < 3; i++) @@ -475,9 +547,275 @@ double s; } at = at->kid + branch; } - av->next = at->alist; - at->alist = av; - return; -memerr: - error(SYSTEM, "out of memory in avinsert"); + avh.next = at->alist; /* order by increasing level */ + for (ap = &avh; ap->next != NULL; ap = ap->next) + if (ap->next->lvl >= av->lvl) + break; + av->next = ap->next; + ap->next = av; + at->alist = avh.next; } + + +static +unloadatree(at, f) /* unload an ambient value tree */ +register AMBTREE *at; +int (*f)(); +{ + register AMBVAL *av; + register int i; + /* transfer values at this node */ + for (av = at->alist; av != NULL; av = at->alist) { + at->alist = av->next; + (*f)(av); + } + if (at->kid == NULL) + return; + for (i = 0; i < 8; i++) /* transfer and free children */ + unloadatree(at->kid+i, f); + freeambtree(at->kid); + at->kid = NULL; +} + + +static struct avl { + AMBVAL *p; + unsigned long t; +} *avlist1; /* ambient value list with ticks */ +static AMBVAL **avlist2; /* memory positions for sorting */ +static int i_avlist; /* index for lists */ + + +static +av2list(av) +register AMBVAL *av; +{ +#ifdef DEBUG + if (i_avlist >= nambvals) + error(CONSISTENCY, "too many ambient values in av2list1"); +#endif + avlist1[i_avlist].p = avlist2[i_avlist] = av; + avlist1[i_avlist++].t = av->latick; +} + + +static int +alatcmp(av1, av2) /* compare ambient values for MRA */ +struct avl *av1, *av2; +{ + register long lc = av2->t - av1->t; + return(lc<0 ? -1 : lc>0 ? 1 : 0); +} + + +static int +aposcmp(avp1, avp2) /* compare ambient value positions */ +AMBVAL **avp1, **avp2; +{ + return(*avp1 - *avp2); +} + + +#if 1 +static int +avlmemi(avaddr) /* find list position from address */ +AMBVAL *avaddr; +{ + register AMBVAL **avlpp; + + avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2, + nambvals, sizeof(AMBVAL *), aposcmp); + if (avlpp == NULL) + error(CONSISTENCY, "address not found in avlmemi"); + return(avlpp - avlist2); +} +#else +#define avlmemi(avaddr) ((AMBVAL **)bsearch((char *)&avaddr,(char *)avlist2, \ + nambvals,sizeof(AMBVAL *),aposcmp) - avlist2) +#endif + + +static +sortambvals(always) /* resort ambient values */ +int always; +{ + AMBTREE oldatrunk; + AMBVAL tav, *tap, *pnext; + register int i, j; + /* see if it's time yet */ + if (!always && (ambclock++ < lastsort+sortintvl || + nambvals < SORT_THRESH)) + return; + /* + * The idea here is to minimize memory thrashing + * in VM systems by improving reference locality. + * We do this by periodically sorting our stored ambient + * values in memory in order of most recently to least + * recently accessed. This ordering was chosen so that new + * ambient values (which tend to be less important) go into + * higher memory with the infrequently accessed values. + * Since we expect our values to need sorting less + * frequently as the process continues, we double our + * waiting interval after each call. + * This routine is also called by setambacc() with + * the "always" parameter set to 1 so that the ambient + * tree will be rebuilt with the new accuracy parameter. + */ + if (tracktime) { /* allocate pointer arrays to sort */ + avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *)); + avlist1 = (struct avl *)malloc(nambvals*sizeof(struct avl)); + } else { + avlist2 = NULL; + avlist1 = NULL; + } + if (avlist1 == NULL) { /* no time tracking -- rebuild tree? */ + if (avlist2 != NULL) + free((char *)avlist2); + if (always) { /* rebuild without sorting */ + copystruct(&oldatrunk, &atrunk); + atrunk.alist = NULL; + atrunk.kid = NULL; + unloadatree(&oldatrunk, avinsert); + } + } else { /* sort memory by last access time */ + /* + * Sorting memory is tricky because it isn't contiguous. + * We have to sort an array of pointers by MRA and also + * by memory position. We then copy values in "loops" + * to minimize memory hits. Nevertheless, we will visit + * everyone at least twice, and this is an expensive process + * when we're thrashing, which is when we need to do it. + */ +#ifdef DEBUG + sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...", + nambvals, ambclock); + eputs(errmsg); +#endif + i_avlist = 0; + unloadatree(&atrunk, av2list); /* empty current tree */ +#ifdef DEBUG + if (i_avlist < nambvals) + error(CONSISTENCY, "missing ambient values in sortambvals"); +#endif + qsort((char *)avlist1, nambvals, sizeof(struct avl), alatcmp); + qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), aposcmp); + for (i = 0; i < nambvals; i++) { + if (avlist1[i].p == NULL) + continue; + tap = avlist2[i]; + copystruct(&tav, tap); + for (j = i; (pnext = avlist1[j].p) != tap; + j = avlmemi(pnext)) { + copystruct(avlist2[j], pnext); + avinsert(avlist2[j]); + avlist1[j].p = NULL; + } + copystruct(avlist2[j], &tav); + avinsert(avlist2[j]); + avlist1[j].p = NULL; + } + free((char *)avlist1); + free((char *)avlist2); + /* compute new sort interval */ + sortintvl = ambclock - lastsort; + if (sortintvl >= MAX_SORT_INTVL/2) + sortintvl = MAX_SORT_INTVL; + else + sortintvl <<= 1; /* wait twice as long next */ +#ifdef DEBUG + eputs("done\n"); +#endif + } + if (ambclock >= MAXACLOCK) + ambclock = MAXACLOCK/2; + lastsort = ambclock; +} + + +#ifdef F_SETLKW + +static +aflock(typ) /* lock/unlock ambient file */ +int typ; +{ + static struct flock fls; /* static so initialized to zeroes */ + + fls.l_type = typ; + if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0) + error(SYSTEM, "cannot (un)lock ambient file"); +} + + +int +ambsync() /* synchronize ambient file */ +{ + static FILE *ambinp = NULL; + static long lastpos = -1; + long flen; + AMBVAL avs; + register int n; + + if (nunflshed == 0) + return(0); + if (lastpos < 0) /* initializing (locked in initambfile) */ + goto syncend; + /* gain exclusive access */ + aflock(F_WRLCK); + /* see if file has grown */ + if ((flen = lseek(fileno(ambfp), 0L, 2)) < 0) + goto seekerr; + if (n = flen - lastpos) { /* file has grown */ + if (ambinp == NULL) { /* use duplicate filedes */ + ambinp = fdopen(dup(fileno(ambfp)), "r"); + if (ambinp == NULL) + error(SYSTEM, "fdopen failed in ambsync"); + } + if (fseek(ambinp, lastpos, 0) < 0) + goto seekerr; + while (n >= AMBVALSIZ) { /* load contributed values */ + if (!readambval(&avs, ambinp)) { + sprintf(errmsg, + "ambient file corrupted near character %ld", + flen - n); + error(WARNING, errmsg); + break; + } + avinsert(avstore(&avs)); + n -= AMBVALSIZ; + } + /*** seek always as safety measure + if (n) ***/ /* alignment */ + if (lseek(fileno(ambfp), flen-n, 0) < 0) + goto seekerr; + } +#ifdef DEBUG + if (ambfp->_ptr - ambfp->_base != nunflshed*AMBVALSIZ) { + sprintf(errmsg, "ambient file buffer at %d rather than %d", + ambfp->_ptr - ambfp->_base, + nunflshed*AMBVALSIZ); + error(CONSISTENCY, errmsg); + } +#endif +syncend: + n = fflush(ambfp); /* calls write() at last */ + if ((lastpos = lseek(fileno(ambfp), 0L, 1)) < 0) + goto seekerr; + aflock(F_UNLCK); /* release file */ + nunflshed = 0; + return(n); +seekerr: + error(SYSTEM, "seek failed in ambsync"); +} + +#else + +int +ambsync() /* flush ambient file */ +{ + if (nunflshed == 0) + return(0); + nunflshed = 0; + return(fflush(ambfp)); +} + +#endif
