root/radiance/ray/src/rt/ambient.c
Thu Jun 19 16:26:55 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.90: +2 -2 lines
Diff to previous 2.90 , to selected 2.82
Fri Jun 6 00:57:46 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.89: +3 -3 lines
Diff to previous 2.89 , to selected 2.82
Removed redundant address operator
Sun May 11 19:03:37 2014 UTC (10 years ago) by greg
Changes since 2.88: +4 -4 lines
Diff to previous 2.88 , to selected 2.82
Changes to hem-in too-large cache radii with -ar 0
Fri May 9 23:08:50 2014 UTC (10 years ago) by greg
Changes since 2.87: +6 -5 lines
Diff to previous 2.87 , to selected 2.82
Changed avstore() to call avinsert() automatically
Fri May 9 16:40:01 2014 UTC (10 years ago) by greg
Changes since 2.86: +11 -9 lines
Diff to previous 2.86 , to selected 2.82
Sort ambient cache lists by weight as well as level
Wed May 7 01:16:03 2014 UTC (10 years ago) by greg
Changes since 2.85: +62 -9 lines
Diff to previous 2.85 , to selected 2.82
Tue May 6 17:15:11 2014 UTC (10 years ago) by greg
Changes since 2.84: +2 -2 lines
Diff to previous 2.84 , to selected 2.82
Bug fix (-DNEWAMB) where ray behind test was failing
Sat Apr 26 15:54:43 2014 UTC (10 years ago) by greg
Changes since 2.83: +13 -12 lines
Diff to previous 2.83 , to selected 2.82
Went back to direct manipulation of ambacc (-aa) parameter
Sat Apr 26 05:15:17 2014 UTC (10 years ago) by greg
Changes since 2.82: +28 -25 lines
Diff to previous 2.82
Experimenting with depth-first ambient tree traversal, avoiding long-reach
Revision 2.82 - (view) (download) (annotate) - [selected]
Sat Apr 26 02:59:16 2014 UTC (10 years ago) by greg
Changes since 2.81: +7 -9 lines
Diff to previous 2.81
Fixed setambacc() routine so it works with rvu properly
Fri Apr 25 23:04:16 2014 UTC (10 years ago) by greg
Changes since 2.80: +13 -5 lines
Diff to previous 2.80 , to selected 2.82
Added back version of ray behind test, but still some problem cases
Fri Apr 25 18:38:47 2014 UTC (10 years ago) by greg
Changes since 2.79: +5 -11 lines
Diff to previous 2.79 , to selected 2.82
Replaced behind test in sumambient with distanc metric used by Schwarzhaupt
Fri Apr 25 00:21:52 2014 UTC (10 years ago) by greg
Changes since 2.78: +5 -3 lines
Diff to previous 2.78 , to selected 2.82
Made minimum angular displacement more generous with small -aa settings
Thu Apr 24 19:16:52 2014 UTC (10 years ago) by greg
Diff to previous 2.77 , to selected 2.82
Reinstated clamping of translation gradient when increasing radius to minimum
Wed Apr 23 17:30:10 2014 UTC (10 years ago) by greg
Diff to previous 2.76 , to selected 2.82
Bug fix and optimization
Wed Apr 23 06:04:18 2014 UTC (10 years ago) by greg
Diff to previous 2.75 , to selected 2.82
Fixed numerous errors in Hessian (-DNEWAMB) calculation, doubtless more to go
Sat Apr 19 19:20:47 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.74: +3 -3 lines
Diff to previous 2.74 , to selected 2.82
Tidying up code, bug fixes and minor improvements
Sat Apr 19 02:39:44 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.73: +9 -4 lines
Diff to previous 2.73 , to selected 2.82
Wed Apr 16 20:32:00 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.72: +5 -6 lines
Diff to previous 2.72 , to selected 2.82
Continued work on Hessian calculation
Fri Apr 11 22:54:34 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.71: +43 -24 lines
Diff to previous 2.71 , to selected 2.82
Fixed compile errors and tidied up new code
Fri Apr 11 20:31:37 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.70: +362 -71 lines
Diff to previous 2.70 , to selected 2.82
Thu Sep 22 02:15:56 2011 UTC (12 years, 7 months ago) by greg
Changes since 2.69: +28 -32 lines
Diff to previous 2.69 , to selected 2.82
Minor optimizations
Mon Jun 27 22:10:37 2011 UTC (12 years, 10 months ago) by greg
Changes since 2.68: +2 -2 lines
Diff to previous 2.68 , to selected 2.82
Minor bug fix thanks to R. Fritz
Thu Oct 14 05:54:44 2010 UTC (13 years, 7 months ago) by greg
Changes since 2.67: +11 -17 lines
Diff to previous 2.67 , to selected 2.82
Fixed long-standing bug in ambient file synchronization under FreeBSD
Sat Nov 17 06:21:58 2007 UTC (16 years, 6 months ago) by greg
CVS Tags: rad3R9, rad4R0
Diff to previous 2.66 , to selected 2.82
Increased limits to number of modifiers for trace and ambient include/exclude
Sat Sep 15 05:16:10 2007 UTC (16 years, 8 months ago) by greg
Changes since 2.65: +16 -16 lines
Diff to previous 2.65 , to selected 2.82
Cleaned up use of lastpos
Sat Sep 15 02:47:30 2007 UTC (16 years, 8 months ago) by greg
Changes since 2.64: +6 -2 lines
Diff to previous 2.64 , to selected 2.82
Fixed initialization bug introduced in last change
Fri Sep 14 00:50:31 2007 UTC (16 years, 8 months ago) by greg
Changes since 2.63: +8 -4 lines
Diff to previous 2.63 , to selected 2.82
Eliminated unnecessary call to lseek(2)
Thu Sep 13 20:13:16 2007 UTC (16 years, 8 months ago) by greg
Changes since 2.62: +4 -9 lines
Diff to previous 2.62 , to selected 2.82
Made it so ambsync() loads values even if there are none to write
Mon Aug 22 16:07:26 2005 UTC (18 years, 8 months ago) by greg
CVS Tags: rad3R7P2, rad3R8
Changes since 2.61: +2 -2 lines
Diff to previous 2.61 , to selected 2.82
Tue May 31 18:01:09 2005 UTC (18 years, 11 months ago) by greg
CVS Tags: rad3R7P1
Changes since 2.60: +23 -22 lines
Diff to previous 2.60 , to selected 2.82
Sat May 28 22:27:54 2005 UTC (18 years, 11 months ago) by greg
Changes since 2.59: +14 -11 lines
Diff to previous 2.59 , to selected 2.82
Wed May 25 18:06:22 2005 UTC (18 years, 11 months ago) by greg
Changes since 2.58: +6 -4 lines
Diff to previous 2.58 , to selected 2.82
Fixed bug introduced with ray contribution output in ambient calculation
Changes since 2.57: +25 -14 lines
Diff to previous 2.57 , to selected 2.82
Fri Nov 5 17:36:55 2004 UTC (19 years, 6 months ago) by greg
Changes since 2.56: +4 -2 lines
Diff to previous 2.56 , to selected 2.82
Tue Mar 30 16:13:00 2004 UTC (20 years, 1 month ago) by schorsch
Changes since 2.55: +120 -83 lines
Diff to previous 2.55 , to selected 2.82
Changes since 2.54: +5 -5 lines
Diff to previous 2.54 , to selected 2.82
Diff to previous 2.53 , to selected 2.82
Changes since 2.52: +6 -6 lines
Diff to previous 2.52 , to selected 2.82
Changes since 2.51: +4 -2 lines
Diff to previous 2.51 , to selected 2.82
Changes since 2.50: +3 -1 lines
Diff to previous 2.50 , to selected 2.82
Changes since 2.49: +3 -7 lines
Diff to previous 2.49 , to selected 2.82
Diff to previous 2.48 , to selected 2.82
Changes since 2.47: +1 -56 lines
Diff to previous 2.47 , to selected 2.82
Changes since 2.46: +183 -61 lines
Diff to previous 2.46 , to selected 2.82
Sun Jan 10 12:45:19 1999 UTC (25 years, 4 months ago) by gwlarson
Changes since 2.45: +19 -7 lines
Diff to previous 2.45 , to selected 2.82
added ability to open and load read-only file in setambient()
Wed Aug 12 18:16:07 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 2.44: +3 -4 lines
Diff to previous 2.44 , to selected 2.82
changed to using VCROSS() macro in extambient()
Wed Jun 17 13:29:55 1998 UTC (25 years, 11 months ago) by gwlarson
Changes since 2.43: +0 -1 lines
Diff to previous 2.43 , to selected 2.82
moved lseek() and ftell() declarations to standard.h
Sat Aug 30 10:17:01 1997 UTC (26 years, 8 months ago) by gregl
Changes since 2.42: +23 -8 lines
Diff to previous 2.42 , to selected 2.82
switched to geometric mean for average -av substitute
Thu Jan 2 09:37:13 1997 UTC (27 years, 4 months ago) by greg
Diff to previous 2.41 , to selected 2.82
corrected problem in error reporting
Wed Jul 10 13:33:56 1996 UTC (27 years, 10 months ago) by greg
Changes since 2.40: +4 -4 lines
Diff to previous 2.40 , to selected 2.82
added -aw to ambient file header
changed sort frequency slightly to adjust for slower ambient clock
Tue Jul 9 21:56:44 1996 UTC (27 years, 10 months ago) by greg
Changes since 2.39: +8 -7 lines
Diff to previous 2.39 , to selected 2.82
made ambclock advance more slowly
Tue Jul 9 19:37:09 1996 UTC (27 years, 10 months ago) by greg
Changes since 2.38: +25 -19 lines
Diff to previous 2.38 , to selected 2.82
made tick part of array to sort in sortambvals() to reduce paging
Tue Jul 9 13:32:35 1996 UTC (27 years, 10 months ago) by greg
Changes since 2.37: +4 -3 lines
Diff to previous 2.37 , to selected 2.82
fixed potential problem with alatcmp() function on 16-bit machines
made error-reporting version of avlmemi() the default
Tue May 28 14:24:44 1996 UTC (27 years, 11 months ago) by greg
Changes since 2.36: +18 -4 lines
Diff to previous 2.36 , to selected 2.82
Wed Feb 14 15:43:22 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.35: +3 -8 lines
Diff to previous 2.35 , to selected 2.82
Tue Nov 21 14:28:22 1995 UTC (28 years, 6 months ago) by greg
Changes since 2.34: +6 -3 lines
Diff to previous 2.34 , to selected 2.82
improved logic for when to track time on multiprocessors
Mon Nov 6 12:03:13 1995 UTC (28 years, 6 months ago) by greg
Changes since 2.33: +12 -7 lines
Diff to previous 2.33 , to selected 2.82
added texturing to ambient value computation using extambient()
Tue Oct 24 13:33:23 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.32: +9 -14 lines
Diff to previous 2.32 , to selected 2.82
made setambacc() a little simpler
Tue Oct 17 18:22:47 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.31: +23 -7 lines
Diff to previous 2.31 , to selected 2.82
added automatic ambient value computation (AMBVWT != 0)
Tue Oct 3 11:53:30 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.30: +1 -2 lines
Diff to previous 2.30 , to selected 2.82
undid artifact of ancient change (1.6) that caused unnec. noise
Wed May 3 09:46:27 1995 UTC (29 years ago) by greg
Diff to previous 2.29 , to selected 2.82
Tue May 2 15:28:36 1995 UTC (29 years ago) by greg
Changes since 2.28: +13 -10 lines
Diff to previous 2.28 , to selected 2.82
adjusted sorting parameters and increased OCTSCALE
Sun Apr 30 13:24:36 1995 UTC (29 years ago) by greg
Changes since 2.27: +14 -5 lines
Diff to previous 2.27 , to selected 2.82
adjustments to sort interval defaults and minor improvements
Sat Apr 29 10:51:28 1995 UTC (29 years ago) by greg
Changes since 2.26: +63 -29 lines
Diff to previous 2.26 , to selected 2.82
minor improvements
Thu Apr 27 14:12:05 1995 UTC (29 years ago) by greg
Changes since 2.25: +183 -12 lines
Diff to previous 2.25 , to selected 2.82
added memory sorting to ambient caching module
Thu Jun 2 11:45:27 1994 UTC (29 years, 11 months ago) by greg
Changes since 2.24: +6 -4 lines
Diff to previous 2.24 , to selected 2.82
changed setting of minarad for -ar 0
Thu Mar 24 13:41:04 1994 UTC (30 years, 2 months ago) by greg
Changes since 2.23: +1 -0 lines
Diff to previous 2.23 , to selected 2.82
Sat Dec 18 10:37:01 1993 UTC (30 years, 5 months ago) by greg
Changes since 2.22: +12 -3 lines
Diff to previous 2.22 , to selected 2.82
ordered ambient lists by level to improve virtual memory performance
Fri Aug 6 17:24:24 1993 UTC (30 years, 9 months ago) by greg
Diff to previous 2.21 , to selected 2.82
changed code to always seek even when it shouldn't be necessary
Thu Aug 5 16:25:05 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.20: +43 -25 lines
Diff to previous 2.20 , to selected 2.82
major and minor bug fixes
Thu Aug 5 10:02:00 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.19: +68 -15 lines
Diff to previous 2.19 , to selected 2.82
corrected flaws in setting and resetting of ambient accuracy
Wed Aug 4 14:22:11 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.18: +39 -29 lines
Diff to previous 2.18 , to selected 2.82
fixed bug due to NFS sloppiness on writing files w/o lock manager
Fri Jan 29 12:02:23 1993 UTC (31 years, 3 months ago) by greg
Changes since 2.17: +12 -12 lines
Diff to previous 2.17 , to selected 2.82
made parallel operations conditional on F_SETLKW
Tue Jan 26 09:08:20 1993 UTC (31 years, 3 months ago) by greg
Changes since 2.16: +7 -11 lines
Diff to previous 2.16 , to selected 2.82
took out ambfname again
Fri Jan 22 09:51:13 1993 UTC (31 years, 4 months ago) by greg
Changes since 2.15: +22 -13 lines
Diff to previous 2.15 , to selected 2.82
bug fixes and improvements on stdio flushing
Wed Jan 20 10:48:23 1993 UTC (31 years, 4 months ago) by greg
Diff to previous 2.14 , to selected 2.82
modified ambsync() to work on forked processes sharing file pointers
Tue Nov 3 21:29:52 1992 UTC (31 years, 6 months ago) by greg
Changes since 2.13: +6 -4 lines
Diff to previous 2.13 , to selected 2.82
fdopen() error check in ambsync()
Fri Oct 2 16:14:53 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.12: +0 -1 lines
Diff to previous 2.12 , to selected 2.82
Mon Sep 21 12:07:31 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.11: +33 -30 lines
Diff to previous 2.11 , to selected 2.82
Changes for PC port
Thu Jul 16 19:44:46 1992 UTC (31 years, 10 months ago) by greg
Diff to previous 2.10 , to selected 2.82
added sync() call to avoid NFS buffering
Thu Jul 16 16:47:28 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.9: +28 -16 lines
Diff to previous 2.9 , to selected 2.82
made ambsync() more efficient with use of duplicate file descriptor
Thu Jul 16 15:53:42 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.8: +34 -33 lines
Diff to previous 2.8 , to selected 2.82
bug fix in misuse of lseek()
Thu Jul 16 14:03:27 1992 UTC (31 years, 10 months ago) by greg
Diff to previous 2.7 , to selected 2.82
minor changes
Thu Jul 16 13:37:12 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.6: +53 -9 lines
Diff to previous 2.6 , to selected 2.82
added calls to lock ambient file and guarantee synchronization
between cooperating processes
Thu Jul 16 12:09:08 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.5: +34 -7 lines
Diff to previous 2.5 , to selected 2.82
Mon Jul 13 16:17:49 1992 UTC (31 years, 10 months ago) by greg
Diff to previous 2.4 , to selected 2.82
Fri Apr 10 16:14:34 1992 UTC (32 years, 1 month ago) by greg
Diff to previous 2.3 , to selected 2.82
avoid zero maxarad for scenes with no local objects
Wed Mar 4 16:52:13 1992 UTC (32 years, 2 months ago) by greg
Changes since 2.2: +19 -6 lines
Diff to previous 2.2 , to selected 2.82
Wed Jan 15 10:36:42 1992 UTC (32 years, 4 months ago) by greg
Diff to previous 2.1 , to selected 2.82
changed jittering test to use urand
Tue Nov 12 17:09:42 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.18 , to selected 2.82
Sat Oct 26 15:19:06 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.17 , to selected 2.82
fixed test when ambrad == 0.
Thu Aug 29 11:13:14 1991 UTC (32 years, 8 months ago) by greg
Diff to previous 1.16 , to selected 2.82
changed heuristic value for when to demote ambient comp. weight
Tue Aug 20 10:05:18 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.15: +31 -24 lines
Diff to previous 1.15 , to selected 2.82
made ambient value weighting and levels more incremental
Thu Jun 13 09:41:15 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.14: +27 -1 lines
Diff to previous 1.14 , to selected 2.82
Fri Jun 7 10:04:29 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.13: +13 -225 lines
Diff to previous 1.13 , to selected 2.82
Thu Jun 6 10:48:50 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.12: +16 -8 lines
Diff to previous 1.12 , to selected 2.82
some minor improvements
Wed May 22 12:44:39 1991 UTC (33 years ago) by greg
Changes since 1.11: +22 -5 lines
Diff to previous 1.11 , to selected 2.82
added stratified sampling with urand()
Fri Sep 7 08:17:42 1990 UTC (33 years, 8 months ago) by greg
Changes since 1.10: +9 -2 lines
Diff to previous 1.10 , to selected 2.82
Added check for ambset overflow
Tue Jun 26 09:00:07 1990 UTC (33 years, 11 months ago) by greg
Changes since 1.9: +0 -1 lines
Diff to previous 1.9 , to selected 2.82
Fri Jan 19 00:00:05 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.8: +5 -5 lines
Diff to previous 1.8 , to selected 2.82
Fri Jan 12 11:30:59 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.7: +20 -14 lines
Diff to previous 1.7 , to selected 2.82
Tue Sep 5 09:46:17 1989 UTC (34 years, 8 months ago) by greg
Changes since 1.6: +19 -24 lines
Diff to previous 1.6 , to selected 2.82
undid last change, which didn't do much but make artifacts
Tue Aug 8 17:31:23 1989 UTC (34 years, 9 months ago) by greg
Changes since 1.5: +25 -19 lines
Diff to previous 1.5 , to selected 2.82
Sum children first and quit if more than WDONE over requirement
Tue May 30 20:06:09 1989 UTC (34 years, 11 months ago) by greg
Diff to previous 1.4 , to selected 2.82
Undid last delta, calculating error not variance!
Tue May 30 11:06:29 1989 UTC (34 years, 11 months ago) by greg
Diff to previous 1.3 , to selected 2.82
Fixed wrong calculation of variance
Fri May 26 17:58:01 1989 UTC (35 years ago) by greg
Changes since 1.2: +17 -16 lines
Diff to previous 1.2 , to selected 2.82
Added variables to avoid confusion in doambient
Tue Feb 21 14:34:08 1989 UTC (35 years, 3 months ago) by greg
Diff to previous 1.1 , to selected 2.82
Fixed incorrect octree test in sumambient
Thu Feb 2 10:41:17 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.82
