| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: ambient.c,v 2.90 2014/06/06 00:57:46 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* ambient.c - routines dealing with ambient (inter-reflected) component.
| 6 |
| 7 |
* Declarations of external symbols in ambient.h
| 8 |
| 9 |
| 10 |
#include "copyright.h"
| 11 |
| 12 |
#include <string.h>
| 13 |
| 14 |
#include "platform.h"
| 15 |
#include "ray.h"
| 16 |
#include "otypes.h"
| 17 |
#include "resolu.h"
| 18 |
#include "ambient.h"
| 19 |
#include "random.h"
| 20 |
| 21 |
#ifndef OCTSCALE
| 22 |
#define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */
| 23 |
#endif
| 24 |
| 25 |
extern char *shm_boundary; /* memory sharing boundary */
| 26 |
| 27 |
#ifndef MAXASET
| 28 |
#define MAXASET 4095 /* maximum number of elements in ambient set */
| 29 |
#endif
| 30 |
OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
| 31 |
| 32 |
double maxarad; /* maximum ambient radius */
| 33 |
double minarad; /* minimum ambient radius */
| 34 |
| 35 |
static AMBTREE atrunk; /* our ambient trunk node */
| 36 |
| 37 |
static FILE *ambfp = NULL; /* ambient file pointer */
| 38 |
static int nunflshed = 0; /* number of unflushed ambient values */
| 39 |
| 40 |
#ifndef SORT_THRESH
| 41 |
#ifdef SMLMEM
| 42 |
#define SORT_THRESH ((16L<<20)/sizeof(AMBVAL))
| 43 |
#else
| 44 |
#define SORT_THRESH ((64L<<20)/sizeof(AMBVAL))
| 45 |
#endif
| 46 |
#endif
| 47 |
#ifndef SORT_INTVL
| 48 |
#define SORT_INTVL (SORT_THRESH<<1)
| 49 |
#endif
| 50 |
#ifndef MAX_SORT_INTVL
| 51 |
#define MAX_SORT_INTVL (SORT_INTVL<<6)
| 52 |
#endif
| 53 |
| 54 |
| 55 |
static double avsum = 0.; /* computed ambient value sum (log) */
| 56 |
static unsigned int navsum = 0; /* number of values in avsum */
| 57 |
static unsigned int nambvals = 0; /* total number of indirect values */
| 58 |
static unsigned int nambshare = 0; /* number of values from file */
| 59 |
static unsigned long ambclock = 0; /* ambient access clock */
| 60 |
static unsigned long lastsort = 0; /* time of last value sort */
| 61 |
static long sortintvl = SORT_INTVL; /* time until next sort */
| 62 |
static FILE *ambinp = NULL; /* auxiliary file for input */
| 63 |
static long lastpos = -1; /* last flush position */
| 64 |
| 65 |
#define MAXACLOCK (1L<<30) /* clock turnover value */
| 66 |
| 67 |
* Track access times unless we are sharing ambient values
| 68 |
* through memory on a multiprocessor, when we want to avoid
| 69 |
* claiming our own memory (copy on write). Go ahead anyway
| 70 |
* if more than two thirds of our values are unshared.
| 71 |
* Compile with -Dtracktime=0 to turn this code off.
| 72 |
| 73 |
#ifndef tracktime
| 74 |
#define tracktime (shm_boundary == NULL || nambvals > 3*nambshare)
| 75 |
#endif
| 76 |
| 77 |
#define AMBFLUSH (BUFSIZ/AMBVALSIZ)
| 78 |
| 79 |
#define newambval() (AMBVAL *)malloc(sizeof(AMBVAL))
| 80 |
#define freeav(av) free((void *)av);
| 81 |
| 82 |
static void initambfile(int creat);
| 83 |
static void avsave(AMBVAL *av);
| 84 |
static AMBVAL *avstore(AMBVAL *aval);
| 85 |
static AMBTREE *newambtree(void);
| 86 |
static void freeambtree(AMBTREE *atp);
| 87 |
| 88 |
typedef void unloadtf_t(AMBVAL *);
| 89 |
static unloadtf_t avinsert;
| 90 |
static unloadtf_t av2list;
| 91 |
static unloadtf_t avfree;
| 92 |
static void unloadatree(AMBTREE *at, unloadtf_t *f);
| 93 |
| 94 |
static int aposcmp(const void *avp1, const void *avp2);
| 95 |
static int avlmemi(AMBVAL *avaddr);
| 96 |
static void sortambvals(int always);
| 97 |
| 98 |
#ifdef F_SETLKW
| 99 |
static void aflock(int typ);
| 100 |
#endif
| 101 |
| 102 |
| 103 |
void
| 104 |
setambres( /* set ambient resolution */
| 105 |
int ar
| 106 |
| 107 |
| 108 |
ambres = ar < 0 ? 0 : ar; /* may be done already */
| 109 |
/* set min & max radii */
| 110 |
if (ar <= 0) {
| 111 |
minarad = 0;
| 112 |
maxarad = thescene.cusize*0.2;
| 113 |
} else {
| 114 |
minarad = thescene.cusize / ar;
| 115 |
maxarad = 64.0 * minarad; /* heuristic */
| 116 |
if (maxarad > thescene.cusize*0.2)
| 117 |
| 118 |
| 119 |
if (minarad <= FTINY)
| 120 |
minarad = 10.0*FTINY;
| 121 |
if (maxarad <= minarad)
| 122 |
| 123 |
| 124 |
| 125 |
| 126 |
void
| 127 |
setambacc( /* set ambient accuracy */
| 128 |
double newa
| 129 |
| 130 |
| 131 |
static double olda; /* remember previous setting here */
| 132 |
| 133 |
newa *= (newa > 0);
| 134 |
if (fabs(newa - olda) >= .05*(newa + olda)) {
| 135 |
ambacc = newa;
| 136 |
if (nambvals > 0)
| 137 |
sortambvals(1); /* rebuild tree */
| 138 |
| 139 |
| 140 |
| 141 |
| 142 |
void
| 143 |
setambient(void) /* initialize calculation */
| 144 |
| 145 |
int readonly = 0;
| 146 |
long flen;
| 147 |
AMBVAL amb;
| 148 |
/* make sure we're fresh */
| 149 |
ambdone();
| 150 |
/* init ambient limits */
| 151 |
setambres(ambres);
| 152 |
setambacc(ambacc);
| 153 |
if (ambfile == NULL || !ambfile[0])
| 154 |
return;
| 155 |
if (ambacc <= FTINY) {
| 156 |
sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened",
| 157 |
ambfile);
| 158 |
error(WARNING, errmsg);
| 159 |
return;
| 160 |
| 161 |
/* open ambient file */
| 162 |
if ((ambfp = fopen(ambfile, "r+")) == NULL)
| 163 |
readonly = (ambfp = fopen(ambfile, "r")) != NULL;
| 164 |
if (ambfp != NULL) {
| 165 |
initambfile(0); /* file exists */
| 166 |
lastpos = ftell(ambfp);
| 167 |
while (readambval(&amb, ambfp))
| 168 |
avstore(&amb);
| 169 |
nambshare = nambvals; /* share loaded values */
| 170 |
if (readonly) {
| 171 |
sprintf(errmsg,
| 172 |
"loaded %u values from read-only ambient file",
| 173 |
nambvals);
| 174 |
| 175 |
fclose(ambfp); /* close file so no writes */
| 176 |
ambfp = NULL;
| 177 |
return; /* avoid ambsync() */
| 178 |
| 179 |
/* align file pointer */
| 180 |
lastpos += (long)nambvals*AMBVALSIZ;
| 181 |
flen = lseek(fileno(ambfp), (off_t)0, SEEK_END);
| 182 |
if (flen != lastpos) {
| 183 |
sprintf(errmsg,
| 184 |
"ignoring last %ld values in ambient file (corrupted)",
| 185 |
(flen - lastpos)/AMBVALSIZ);
| 186 |
| 187 |
fseek(ambfp, lastpos, SEEK_SET);
| 188 |
#ifndef _WIN32 /* XXX we need a replacement for that one */
| 189 |
ftruncate(fileno(ambfp), (off_t)lastpos);
| 190 |
#endif
| 191 |
| 192 |
} else if ((ambfp = fopen(ambfile, "w+")) != NULL) {
| 193 |
initambfile(1); /* else create new file */
| 194 |
fflush(ambfp);
| 195 |
| 196 |
} else {
| 197 |
sprintf(errmsg, "cannot open ambient file \"%s\"", ambfile);
| 198 |
error(SYSTEM, errmsg);
| 199 |
| 200 |
#ifdef getc_unlocked
| 201 |
flockfile(ambfp); /* application-level lock */
| 202 |
#endif
| 203 |
#ifdef F_SETLKW
| 204 |
aflock(F_UNLCK); /* release file */
| 205 |
#endif
| 206 |
| 207 |
| 208 |
| 209 |
void
| 210 |
ambdone(void) /* close ambient file and free memory */
| 211 |
| 212 |
if (ambfp != NULL) { /* close ambient file */
| 213 |
ambsync();
| 214 |
fclose(ambfp);
| 215 |
ambfp = NULL;
| 216 |
if (ambinp != NULL) {
| 217 |
fclose(ambinp);
| 218 |
ambinp = NULL;
| 219 |
| 220 |
lastpos = -1;
| 221 |
| 222 |
/* free ambient tree */
| 223 |
unloadatree(&atrunk, &avfree);
| 224 |
/* reset state variables */
| 225 |
avsum = 0.;
| 226 |
navsum = 0;
| 227 |
nambvals = 0;
| 228 |
nambshare = 0;
| 229 |
ambclock = 0;
| 230 |
lastsort = 0;
| 231 |
| 232 |
| 233 |
| 234 |
| 235 |
void
| 236 |
ambnotify( /* record new modifier */
| 237 |
OBJECT obj
| 238 |
| 239 |
| 240 |
static int hitlimit = 0;
| 241 |
OBJREC *o;
| 242 |
char **amblp;
| 243 |
| 244 |
if (obj == OVOID) { /* starting over */
| 245 |
ambset[0] = 0;
| 246 |
hitlimit = 0;
| 247 |
return;
| 248 |
| 249 |
o = objptr(obj);
| 250 |
if (hitlimit || !ismodifier(o->otype))
| 251 |
return;
| 252 |
for (amblp = amblist; *amblp != NULL; amblp++)
| 253 |
if (!strcmp(o->oname, *amblp)) {
| 254 |
if (ambset[0] >= MAXASET) {
| 255 |
error(WARNING, "too many modifiers in ambient list");
| 256 |
hitlimit++;
| 257 |
return; /* should this be fatal? */
| 258 |
| 259 |
insertelem(ambset, obj);
| 260 |
return;
| 261 |
| 262 |
| 263 |
| 264 |
/************ THE FOLLOWING ROUTINES DIFFER BETWEEN NEW & OLD ***************/
| 265 |
| 266 |
#ifndef OLDAMB
| 267 |
| 268 |
#define tfunc(lwr, x, upr) (((x)-(lwr))/((upr)-(lwr)))
| 269 |
| 270 |
static int plugaleak(RAY *r, AMBVAL *ap, FVECT anorm, double ang);
| 271 |
static double sumambient(COLOR acol, RAY *r, FVECT rn, int al,
| 272 |
AMBTREE *at, FVECT c0, double s);
| 273 |
static int makeambient(COLOR acol, RAY *r, FVECT rn, int al);
| 274 |
static void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv,
| 275 |
FVECT uvw[3]);
| 276 |
| 277 |
void
| 278 |
multambient( /* compute ambient component & multiply by coef. */
| 279 |
COLOR aval,
| 280 |
RAY *r,
| 281 |
FVECT nrm
| 282 |
| 283 |
| 284 |
static int rdepth = 0; /* ambient recursion */
| 285 |
COLOR acol;
| 286 |
int ok;
| 287 |
double d, l;
| 288 |
| 289 |
if (ambdiv <= 0) /* no ambient calculation */
| 290 |
goto dumbamb;
| 291 |
/* check number of bounces */
| 292 |
if (rdepth >= ambounce)
| 293 |
goto dumbamb;
| 294 |
/* check ambient list */
| 295 |
if (ambincl != -1 && r->ro != NULL &&
| 296 |
ambincl != inset(ambset, r->ro->omod))
| 297 |
goto dumbamb;
| 298 |
| 299 |
if (ambacc <= FTINY) { /* no ambient storage */
| 300 |
copycolor(acol, aval);
| 301 |
rdepth++;
| 302 |
ok = doambient(acol, r, r->rweight,
| 303 |
NULL, NULL, NULL, NULL, NULL);
| 304 |
rdepth--;
| 305 |
if (!ok)
| 306 |
goto dumbamb;
| 307 |
copycolor(aval, acol);
| 308 |
return;
| 309 |
| 310 |
| 311 |
if (tracktime) /* sort to minimize thrashing */
| 312 |
sortambvals(0);
| 313 |
/* interpolate ambient value */
| 314 |
setcolor(acol, 0.0, 0.0, 0.0);
| 315 |
d = sumambient(acol, r, nrm, rdepth,
| 316 |
&atrunk, thescene.cuorg, thescene.cusize);
| 317 |
if (d > FTINY) {
| 318 |
d = 1.0/d;
| 319 |
scalecolor(acol, d);
| 320 |
multcolor(aval, acol);
| 321 |
return;
| 322 |
| 323 |
rdepth++; /* need to cache new value */
| 324 |
ok = makeambient(acol, r, nrm, rdepth-1);
| 325 |
rdepth--;
| 326 |
if (ok) {
| 327 |
multcolor(aval, acol); /* computed new value */
| 328 |
return;
| 329 |
| 330 |
dumbamb: /* return global value */
| 331 |
if ((ambvwt <= 0) | (navsum == 0)) {
| 332 |
multcolor(aval, ambval);
| 333 |
return;
| 334 |
| 335 |
l = bright(ambval); /* average in computations */
| 336 |
if (l > FTINY) {
| 337 |
d = (log(l)*(double)ambvwt + avsum) /
| 338 |
(double)(ambvwt + navsum);
| 339 |
d = exp(d) / l;
| 340 |
scalecolor(aval, d);
| 341 |
multcolor(aval, ambval); /* apply color of ambval */
| 342 |
} else {
| 343 |
d = exp( avsum / (double)navsum );
| 344 |
scalecolor(aval, d); /* neutral color */
| 345 |
| 346 |
| 347 |
| 348 |
| 349 |
/* Plug a potential leak where ambient cache value is occluded */
| 350 |
static int
| 351 |
| 352 |
| 353 |
const double cost70sq = 0.1169778; /* cos(70deg)^2 */
| 354 |
RAY rtst;
| 355 |
FVECT vdif;
| 356 |
double normdot, ndotd, nadotd;
| 357 |
double a, b, c, t[2];
| 358 |
| 359 |
ang += 2.*PI*(ang < 0); /* check direction flags */
| 360 |
if ( !(ap->corral>>(int)(ang*(16./PI)) & 1) )
| 361 |
return(0);
| 362 |
| 363 |
* Generate test ray, targeting 20 degrees above sample point plane
| 364 |
* along surface normal from cache position. This should be high
| 365 |
* enough to miss local geometry we don't really care about.
| 366 |
| 367 |
VSUB(vdif, ap->pos, r->rop);
| 368 |
normdot = DOT(anorm, r->ron);
| 369 |
ndotd = DOT(vdif, r->ron);
| 370 |
nadotd = DOT(vdif, anorm);
| 371 |
a = normdot*normdot - cost70sq;
| 372 |
b = 2.0*(normdot*ndotd - nadotd*cost70sq);
| 373 |
c = ndotd*ndotd - DOT(vdif,vdif)*cost70sq;
| 374 |
if (quadratic(t, a, b, c) != 2)
| 375 |
return(1); /* should rarely happen */
| 376 |
if (t[1] <= FTINY)
| 377 |
return(0); /* should fail behind test */
| 378 |
rayorigin(&rtst, SHADOW, r, NULL);
| 379 |
VSUM(rtst.rdir, vdif, anorm, t[1]); /* further dist. > plane */
| 380 |
rtst.rmax = normalize(rtst.rdir); /* short ray test */
| 381 |
while (localhit(&rtst, &thescene)) { /* check for occluder */
| 382 |
if (rtst.ro->omod != OVOID &&
| 383 |
(rtst.clipset == NULL ||
| 384 |
!inset(rtst.clipset, rtst.ro->omod)))
| 385 |
return(1); /* plug light leak */
| 386 |
VCOPY(rtst.rorg, rtst.rop); /* skip invisible surface */
| 387 |
rtst.rmax -= rtst.rot;
| 388 |
rayclear(&rtst);
| 389 |
| 390 |
return(0); /* seems we're OK */
| 391 |
| 392 |
| 393 |
| 394 |
static double
| 395 |
sumambient( /* get interpolated ambient value */
| 396 |
COLOR acol,
| 397 |
RAY *r,
| 398 |
FVECT rn,
| 399 |
int al,
| 400 |
AMBTREE *at,
| 401 |
FVECT c0,
| 402 |
double s
| 403 |
| 404 |
{ /* initial limit is 10 degrees plus ambacc radians */
| 405 |
const double minangle = 10.0 * PI/180.;
| 406 |
double maxangle = minangle + ambacc;
| 407 |
double wsum = 0.0;
| 408 |
FVECT ck0;
| 409 |
int i, j;
| 410 |
AMBVAL *av;
| 411 |
| 412 |
if (at->kid != NULL) { /* sum children first */
| 413 |
s *= 0.5;
| 414 |
for (i = 0; i < 8; i++) {
| 415 |
for (j = 0; j < 3; j++) {
| 416 |
ck0[j] = c0[j];
| 417 |
if (1<<j & i)
| 418 |
ck0[j] += s;
| 419 |
if (r->rop[j] < ck0[j] - OCTSCALE*s)
| 420 |
break;
| 421 |
if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
| 422 |
break;
| 423 |
| 424 |
if (j == 3)
| 425 |
wsum += sumambient(acol, r, rn, al,
| 426 |
at->kid+i, ck0, s);
| 427 |
| 428 |
/* good enough? */
| 429 |
if (wsum >= 0.05 && s > minarad*10.0)
| 430 |
return(wsum);
| 431 |
| 432 |
/* adjust maximum angle */
| 433 |
if (at->alist != NULL && (at->alist->lvl <= al) & (r->rweight < 0.6))
| 434 |
maxangle = (maxangle - PI/2.)*pow(r->rweight,0.13) + PI/2.;
| 435 |
/* sum this node */
| 436 |
for (av = at->alist; av != NULL; av = av->next) {
| 437 |
double u, v, d, delta_r2, delta_t2;
| 438 |
COLOR ct;
| 439 |
FVECT uvw[3];
| 440 |
/* record access */
| 441 |
if (tracktime)
| 442 |
av->latick = ambclock;
| 443 |
| 444 |
* Ambient level test
| 445 |
| 446 |
if (av->lvl > al || /* list sorted, so this works */
| 447 |
(av->lvl == al) & (av->weight < 0.9*r->rweight))
| 448 |
break;
| 449 |
| 450 |
* Direction test using unperturbed normal
| 451 |
| 452 |
decodedir(uvw[2], av->ndir);
| 453 |
d = DOT(uvw[2], r->ron);
| 454 |
if (d <= 0.0) /* >= 90 degrees */
| 455 |
continue;
| 456 |
delta_r2 = 2.0 - 2.0*d; /* approx. radians^2 */
| 457 |
if (delta_r2 >= maxangle*maxangle)
| 458 |
continue;
| 459 |
| 460 |
* Modified ray behind test
| 461 |
| 462 |
VSUB(ck0, r->rop, av->pos);
| 463 |
d = DOT(ck0, uvw[2]);
| 464 |
if (d < -minarad*ambacc-.001)
| 465 |
continue;
| 466 |
d /= av->rad[0];
| 467 |
delta_t2 = d*d;
| 468 |
if (delta_t2 >= ambacc*ambacc)
| 469 |
continue;
| 470 |
| 471 |
* Elliptical radii test based on Hessian
| 472 |
| 473 |
decodedir(uvw[0], av->udir);
| 474 |
VCROSS(uvw[1], uvw[2], uvw[0]);
| 475 |
d = (u = DOT(ck0, uvw[0])) / av->rad[0];
| 476 |
delta_t2 += d*d;
| 477 |
d = (v = DOT(ck0, uvw[1])) / av->rad[1];
| 478 |
delta_t2 += d*d;
| 479 |
| 480 |
continue;
| 481 |
| 482 |
* Test for potential light leak
| 483 |
| 484 |
if (av->corral && plugaleak(r, av, uvw[2], atan2a(v,u)))
| 485 |
continue;
| 486 |
| 487 |
* Extrapolate value and compute final weight (hat function)
| 488 |
| 489 |
extambient(ct, av, r->rop, rn, uvw);
| 490 |
d = tfunc(maxangle, sqrt(delta_r2), 0.0) *
| 491 |
tfunc(ambacc, sqrt(delta_t2), 0.0);
| 492 |
scalecolor(ct, d);
| 493 |
addcolor(acol, ct);
| 494 |
wsum += d;
| 495 |
| 496 |
return(wsum);
| 497 |
| 498 |
| 499 |
| 500 |
static int
| 501 |
makeambient( /* make a new ambient value for storage */
| 502 |
COLOR acol,
| 503 |
RAY *r,
| 504 |
FVECT rn,
| 505 |
int al
| 506 |
| 507 |
| 508 |
AMBVAL amb;
| 509 |
FVECT uvw[3];
| 510 |
int i;
| 511 |
| 512 |
amb.weight = 1.0; /* compute weight */
| 513 |
for (i = al; i-- > 0; )
| 514 |
amb.weight *= AVGREFL;
| 515 |
if (r->rweight < 0.1*amb.weight) /* heuristic override */
| 516 |
amb.weight = 1.25*r->rweight;
| 517 |
setcolor(acol, AVGREFL, AVGREFL, AVGREFL);
| 518 |
/* compute ambient */
| 519 |
i = doambient(acol, r, amb.weight,
| 520 |
uvw, amb.rad, amb.gpos, amb.gdir, &amb.corral);
| 521 |
scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */
| 522 |
if (i <= 0 || amb.rad[0] <= FTINY) /* no Hessian or zero radius */
| 523 |
return(i);
| 524 |
/* store value */
| 525 |
VCOPY(amb.pos, r->rop);
| 526 |
amb.ndir = encodedir(r->ron);
| 527 |
amb.udir = encodedir(uvw[0]);
| 528 |
amb.lvl = al;
| 529 |
copycolor(amb.val, acol);
| 530 |
/* insert into tree */
| 531 |
avsave(&amb); /* and save to file */
| 532 |
if (rn != r->ron) { /* texture */
| 533 |
VCOPY(uvw[2], r->ron);
| 534 |
extambient(acol, &amb, r->rop, rn, uvw);
| 535 |
| 536 |
return(1);
| 537 |
| 538 |
| 539 |
| 540 |
static void
| 541 |
extambient( /* extrapolate value at pv, nv */
| 542 |
COLOR cr,
| 543 |
AMBVAL *ap,
| 544 |
FVECT pv,
| 545 |
FVECT nv,
| 546 |
FVECT uvw[3]
| 547 |
| 548 |
| 549 |
static FVECT my_uvw[3];
| 550 |
FVECT v1;
| 551 |
int i;
| 552 |
double d = 1.0; /* zeroeth order */
| 553 |
| 554 |
if (uvw == NULL) { /* need local coordinates? */
| 555 |
decodedir(my_uvw[2], ap->ndir);
| 556 |
decodedir(my_uvw[0], ap->udir);
| 557 |
VCROSS(my_uvw[1], my_uvw[2], my_uvw[0]);
| 558 |
uvw = my_uvw;
| 559 |
| 560 |
for (i = 3; i--; ) /* gradient due to translation */
| 561 |
d += (pv[i] - ap->pos[i]) *
| 562 |
(ap->gpos[0]*uvw[0][i] + ap->gpos[1]*uvw[1][i]);
| 563 |
| 564 |
VCROSS(v1, uvw[2], nv); /* gradient due to rotation */
| 565 |
for (i = 3; i--; )
| 566 |
d += v1[i] * (ap->gdir[0]*uvw[0][i] + ap->gdir[1]*uvw[1][i]);
| 567 |
| 568 |
if (d <= 0.0) {
| 569 |
setcolor(cr, 0.0, 0.0, 0.0);
| 570 |
return;
| 571 |
| 572 |
copycolor(cr, ap->val);
| 573 |
scalecolor(cr, d);
| 574 |
| 575 |
| 576 |
| 577 |
static void
| 578 |
avinsert( /* insert ambient value in our tree */
| 579 |
AMBVAL *av
| 580 |
| 581 |
| 582 |
AMBTREE *at;
| 583 |
AMBVAL *ap;
| 584 |
AMBVAL avh;
| 585 |
FVECT ck0;
| 586 |
double s;
| 587 |
int branch;
| 588 |
int i;
| 589 |
| 590 |
if (av->rad[0] <= FTINY)
| 591 |
error(CONSISTENCY, "zero ambient radius in avinsert");
| 592 |
at = &atrunk;
| 593 |
VCOPY(ck0, thescene.cuorg);
| 594 |
s = thescene.cusize;
| 595 |
while (s*(OCTSCALE/2) > av->rad[1]*ambacc) {
| 596 |
if (at->kid == NULL)
| 597 |
if ((at->kid = newambtree()) == NULL)
| 598 |
error(SYSTEM, "out of memory in avinsert");
| 599 |
s *= 0.5;
| 600 |
branch = 0;
| 601 |
for (i = 0; i < 3; i++)
| 602 |
if (av->pos[i] > ck0[i] + s) {
| 603 |
ck0[i] += s;
| 604 |
branch |= 1 << i;
| 605 |
| 606 |
at = at->kid + branch;
| 607 |
| 608 |
avh.next = at->alist; /* order by increasing level */
| 609 |
for (ap = &avh; ap->next != NULL; ap = ap->next)
| 610 |
if ( ap->next->lvl > av->lvl ||
| 611 |
(ap->next->lvl == av->lvl) &
| 612 |
(ap->next->weight <= av->weight) )
| 613 |
break;
| 614 |
av->next = ap->next;
| 615 |
ap->next = (AMBVAL*)av;
| 616 |
at->alist = avh.next;
| 617 |
| 618 |
| 619 |
| 620 |
#else /* ! NEWAMB */
| 621 |
| 622 |
| 623 |
| 624 |
static double makeambient(COLOR acol, RAY *r, FVECT rn, int al);
| 625 |
static void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv);
| 626 |
| 627 |
| 628 |
void
| 629 |
| 630 |
COLOR aval,
| 631 |
RAY *r,
| 632 |
FVECT nrm
| 633 |
| 634 |
| 635 |
| 636 |
COLOR acol;
| 637 |
double d, l;
| 638 |
| 639 |
| 640 |
goto dumbamb;
| 641 |
| 642 |
| 643 |
goto dumbamb;
| 644 |
| 645 |
| 646 |
| 647 |
goto dumbamb;
| 648 |
| 649 |
| 650 |
| 651 |
rdepth++;
| 652 |
d = doambient(acol, r, r->rweight, NULL, NULL);
| 653 |
rdepth--;
| 654 |
if (d <= FTINY)
| 655 |
goto dumbamb;
| 656 |
| 657 |
return;
| 658 |
| 659 |
| 660 |
| 661 |
sortambvals(0);
| 662 |
| 663 |
| 664 |
| 665 |
| 666 |
if (d > FTINY) {
| 667 |
d = 1.0/d;
| 668 |
| 669 |
| 670 |
return;
| 671 |
| 672 |
| 673 |
d = makeambient(acol, r, nrm, rdepth-1);
| 674 |
rdepth--;
| 675 |
if (d > FTINY) {
| 676 |
multcolor(aval, acol); /* got new value */
| 677 |
return;
| 678 |
| 679 |
| 680 |
| 681 |
| 682 |
return;
| 683 |
| 684 |
| 685 |
if (l > FTINY) {
| 686 |
| 687 |
| 688 |
d = exp(d) / l;
| 689 |
| 690 |
| 691 |
} else {
| 692 |
| 693 |
| 694 |
| 695 |
| 696 |
| 697 |
| 698 |
static double
| 699 |
| 700 |
COLOR acol,
| 701 |
RAY *r,
| 702 |
FVECT rn,
| 703 |
int al,
| 704 |
AMBTREE *at,
| 705 |
FVECT c0,
| 706 |
double s
| 707 |
| 708 |
| 709 |
double d, e1, e2, wt, wsum;
| 710 |
COLOR ct;
| 711 |
FVECT ck0;
| 712 |
int i;
| 713 |
int j;
| 714 |
AMBVAL *av;
| 715 |
| 716 |
wsum = 0.0;
| 717 |
/* do this node */
| 718 |
| 719 |
double rn_dot = -2.0;
| 720 |
if (tracktime)
| 721 |
| 722 |
| 723 |
* Ambient level test.
| 724 |
| 725 |
| 726 |
| 727 |
break;
| 728 |
| 729 |
* Ambient radius test.
| 730 |
| 731 |
VSUB(ck0, av->pos, r->rop);
| 732 |
e1 = DOT(ck0, ck0) / (av->rad * av->rad);
| 733 |
if (e1 > ambacc*ambacc*1.21)
| 734 |
continue;
| 735 |
| 736 |
* Direction test using closest normal.
| 737 |
| 738 |
d = DOT(av->dir, r->ron);
| 739 |
if (rn != r->ron) {
| 740 |
rn_dot = DOT(av->dir, rn);
| 741 |
if (rn_dot > 1.0-FTINY)
| 742 |
rn_dot = 1.0-FTINY;
| 743 |
if (rn_dot >= d-FTINY) {
| 744 |
d = rn_dot;
| 745 |
rn_dot = -2.0;
| 746 |
| 747 |
| 748 |
e2 = (1.0 - d) * r->rweight;
| 749 |
if (e2 < 0.0)
| 750 |
e2 = 0.0;
| 751 |
else if (e1 + e2 > ambacc*ambacc*1.21)
| 752 |
continue;
| 753 |
| 754 |
* Ray behind test.
| 755 |
| 756 |
d = 0.0;
| 757 |
| 758 |
d += (r->rop[j] - av->pos[j]) *
| 759 |
(av->dir[j] + r->ron[j]);
| 760 |
if (d*0.5 < -minarad*ambacc-.001)
| 761 |
continue;
| 762 |
| 763 |
* Jittering final test reduces image artifacts.
| 764 |
| 765 |
e1 = sqrt(e1);
| 766 |
e2 = sqrt(e2);
| 767 |
wt = e1 + e2;
| 768 |
if (wt > ambacc*(.9+.2*urand(9015+samplendx)))
| 769 |
continue;
| 770 |
| 771 |
* Recompute directional error using perturbed normal
| 772 |
| 773 |
if (rn_dot > 0.0) {
| 774 |
e2 = sqrt((1.0 - rn_dot)*r->rweight);
| 775 |
wt = e1 + e2;
| 776 |
| 777 |
if (wt <= 1e-3)
| 778 |
wt = 1e3;
| 779 |
else
| 780 |
wt = 1.0 / wt;
| 781 |
wsum += wt;
| 782 |
extambient(ct, av, r->rop, rn);
| 783 |
scalecolor(ct, wt);
| 784 |
addcolor(acol, ct);
| 785 |
| 786 |
| 787 |
return(wsum);
| 788 |
/* do children */
| 789 |
s *= 0.5;
| 790 |
| 791 |
| 792 |
ck0[j] = c0[j];
| 793 |
if (1<<j & i)
| 794 |
ck0[j] += s;
| 795 |
| 796 |
break;
| 797 |
| 798 |
break;
| 799 |
| 800 |
if (j == 3)
| 801 |
| 802 |
at->kid+i, ck0, s);
| 803 |
| 804 |
return(wsum);
| 805 |
| 806 |
| 807 |
| 808 |
static double
| 809 |
| 810 |
COLOR acol,
| 811 |
RAY *r,
| 812 |
FVECT rn,
| 813 |
int al
| 814 |
| 815 |
| 816 |
AMBVAL amb;
| 817 |
FVECT gp, gd;
| 818 |
int i;
| 819 |
| 820 |
| 821 |
| 822 |
| 823 |
| 824 |
| 825 |
| 826 |
| 827 |
amb.rad = doambient(acol, r, amb.weight, gp, gd);
| 828 |
if (amb.rad <= FTINY) {
| 829 |
| 830 |
return(0.0);
| 831 |
| 832 |
| 833 |
/* store value */
| 834 |
| 835 |
VCOPY(amb.dir, r->ron);
| 836 |
amb.lvl = al;
| 837 |
| 838 |
VCOPY(amb.gpos, gp);
| 839 |
VCOPY(amb.gdir, gd);
| 840 |
| 841 |
| 842 |
if (rn != r->ron)
| 843 |
extambient(acol, &amb, r->rop, rn); /* texture */
| 844 |
return(amb.rad);
| 845 |
| 846 |
| 847 |
| 848 |
static void
| 849 |
| 850 |
COLOR cr,
| 851 |
AMBVAL *ap,
| 852 |
FVECT pv,
| 853 |
FVECT nv
| 854 |
| 855 |
| 856 |
FVECT v1;
| 857 |
int i;
| 858 |
double d;
| 859 |
| 860 |
| 861 |
| 862 |
| 863 |
d += ap->gpos[i]*(pv[i]-ap->pos[i]);
| 864 |
| 865 |
VCROSS(v1, ap->dir, nv);
| 866 |
d += DOT(ap->gdir, v1);
| 867 |
if (d <= 0.0) {
| 868 |
| 869 |
return;
| 870 |
| 871 |
| 872 |
scalecolor(cr, d);
| 873 |
| 874 |
| 875 |
| 876 |
static void
| 877 |
| 878 |
AMBVAL *av
| 879 |
| 880 |
| 881 |
AMBTREE *at;
| 882 |
AMBVAL *ap;
| 883 |
AMBVAL avh;
| 884 |
FVECT ck0;
| 885 |
double s;
| 886 |
int branch;
| 887 |
int i;
| 888 |
| 889 |
if (av->rad <= FTINY)
| 890 |
| 891 |
at = &atrunk;
| 892 |
| 893 |
| 894 |
while (s*(OCTSCALE/2) > av->rad*ambacc) {
| 895 |
| 896 |
| 897 |
| 898 |
s *= 0.5;
| 899 |
branch = 0;
| 900 |
| 901 |
| 902 |
ck0[i] += s;
| 903 |
branch |= 1 << i;
| 904 |
| 905 |
| 906 |
| 907 |
| 908 |
| 909 |
| 910 |
| 911 |
| 912 |
break;
| 913 |
| 914 |
| 915 |
| 916 |
| 917 |
| 918 |
#endif /* ! NEWAMB */
| 919 |
| 920 |
/************* FOLLOWING ROUTINES SAME FOR NEW & OLD METHODS ***************/
| 921 |
| 922 |
static void
| 923 |
initambfile( /* initialize ambient file */
| 924 |
int cre8
| 925 |
| 926 |
| 927 |
extern char *progname, *octname;
| 928 |
static char *mybuf = NULL;
| 929 |
| 930 |
#ifdef F_SETLKW
| 931 |
aflock(cre8 ? F_WRLCK : F_RDLCK);
| 932 |
#endif
| 933 |
SET_FILE_BINARY(ambfp);
| 934 |
if (mybuf == NULL)
| 935 |
mybuf = (char *)bmalloc(BUFSIZ+8);
| 936 |
setbuf(ambfp, mybuf);
| 937 |
if (cre8) { /* new file */
| 938 |
newheader("RADIANCE", ambfp);
| 939 |
fprintf(ambfp, "%s -av %g %g %g -aw %d -ab %d -aa %g ",
| 940 |
progname, colval(ambval,RED),
| 941 |
colval(ambval,GRN), colval(ambval,BLU),
| 942 |
ambvwt, ambounce, ambacc);
| 943 |
fprintf(ambfp, "-ad %d -as %d -ar %d ",
| 944 |
ambdiv, ambssamp, ambres);
| 945 |
if (octname != NULL)
| 946 |
fputs(octname, ambfp);
| 947 |
fputc('\n', ambfp);
| 948 |
fprintf(ambfp, "SOFTWARE= %s\n", VersionID);
| 949 |
fputnow(ambfp);
| 950 |
fputformat(AMBFMT, ambfp);
| 951 |
fputc('\n', ambfp);
| 952 |
putambmagic(ambfp);
| 953 |
} else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp))
| 954 |
error(USER, "bad ambient file");
| 955 |
| 956 |
| 957 |
| 958 |
static void
| 959 |
avsave( /* insert and save an ambient value */
| 960 |
AMBVAL *av
| 961 |
| 962 |
| 963 |
avstore(av);
| 964 |
if (ambfp == NULL)
| 965 |
return;
| 966 |
if (writambval(av, ambfp) < 0)
| 967 |
goto writerr;
| 968 |
if (++nunflshed >= AMBFLUSH)
| 969 |
if (ambsync() == EOF)
| 970 |
goto writerr;
| 971 |
return;
| 972 |
writerr:
| 973 |
error(SYSTEM, "error writing to ambient file");
| 974 |
| 975 |
| 976 |
| 977 |
static AMBVAL *
| 978 |
avstore( /* allocate memory and save aval */
| 979 |
AMBVAL *aval
| 980 |
| 981 |
| 982 |
AMBVAL *av;
| 983 |
double d;
| 984 |
| 985 |
if ((av = newambval()) == NULL)
| 986 |
error(SYSTEM, "out of memory in avstore");
| 987 |
*av = *aval;
| 988 |
| 989 |
av->next = NULL;
| 990 |
nambvals++;
| 991 |
d = bright(av->val);
| 992 |
if (d > FTINY) { /* add to log sum for averaging */
| 993 |
avsum += log(d);
| 994 |
navsum++;
| 995 |
| 996 |
avinsert(av); /* insert in our cache tree */
| 997 |
return(av);
| 998 |
| 999 |
| 1000 |
| 1001 |
#define ATALLOCSZ 512 /* #/8 trees to allocate at once */
| 1002 |
| 1003 |
static AMBTREE *atfreelist = NULL; /* free ambient tree structures */
| 1004 |
| 1005 |
| 1006 |
static AMBTREE *
| 1007 |
newambtree(void) /* allocate 8 ambient tree structs */
| 1008 |
| 1009 |
AMBTREE *atp, *upperlim;
| 1010 |
| 1011 |
if (atfreelist == NULL) { /* get more nodes */
| 1012 |
atfreelist = (AMBTREE *)malloc(ATALLOCSZ*8*sizeof(AMBTREE));
| 1013 |
| 1014 |
return(NULL);
| 1015 |
/* link new free list */
| 1016 |
upperlim = atfreelist + 8*(ATALLOCSZ-1);
| 1017 |
for (atp = atfreelist; atp < upperlim; atp += 8)
| 1018 |
atp->kid = atp + 8;
| 1019 |
atp->kid = NULL;
| 1020 |
| 1021 |
atp = atfreelist;
| 1022 |
atfreelist = atp->kid;
| 1023 |
memset((char *)atp, '\0', 8*sizeof(AMBTREE));
| 1024 |
return(atp);
| 1025 |
| 1026 |
| 1027 |
| 1028 |
static void
| 1029 |
freeambtree( /* free 8 ambient tree structs */
| 1030 |
AMBTREE *atp
| 1031 |
| 1032 |
| 1033 |
atp->kid = atfreelist;
| 1034 |
atfreelist = atp;
| 1035 |
| 1036 |
| 1037 |
| 1038 |
static void
| 1039 |
unloadatree( /* unload an ambient value tree */
| 1040 |
AMBTREE *at,
| 1041 |
unloadtf_t *f
| 1042 |
| 1043 |
| 1044 |
AMBVAL *av;
| 1045 |
int i;
| 1046 |
/* transfer values at this node */
| 1047 |
for (av = at->alist; av != NULL; av = at->alist) {
| 1048 |
at->alist = av->next;
| 1049 |
(*f)(av);
| 1050 |
| 1051 |
| 1052 |
return;
| 1053 |
for (i = 0; i < 8; i++) /* transfer and free children */
| 1054 |
unloadatree(at->kid+i, f);
| 1055 |
freeambtree(at->kid);
| 1056 |
at->kid = NULL;
| 1057 |
| 1058 |
| 1059 |
| 1060 |
static struct avl {
| 1061 |
AMBVAL *p;
| 1062 |
unsigned long t;
| 1063 |
} *avlist1; /* ambient value list with ticks */
| 1064 |
static AMBVAL **avlist2; /* memory positions for sorting */
| 1065 |
static int i_avlist; /* index for lists */
| 1066 |
| 1067 |
static int alatcmp(const void *av1, const void *av2);
| 1068 |
| 1069 |
static void
| 1070 |
avfree(AMBVAL *av)
| 1071 |
| 1072 |
free(av);
| 1073 |
| 1074 |
| 1075 |
static void
| 1076 |
av2list(
| 1077 |
AMBVAL *av
| 1078 |
| 1079 |
| 1080 |
#ifdef DEBUG
| 1081 |
if (i_avlist >= nambvals)
| 1082 |
error(CONSISTENCY, "too many ambient values in av2list1");
| 1083 |
#endif
| 1084 |
avlist1[i_avlist].p = avlist2[i_avlist] = (AMBVAL*)av;
| 1085 |
avlist1[i_avlist++].t = av->latick;
| 1086 |
| 1087 |
| 1088 |
| 1089 |
static int
| 1090 |
alatcmp( /* compare ambient values for MRA */
| 1091 |
const void *av1,
| 1092 |
const void *av2
| 1093 |
| 1094 |
| 1095 |
long lc = ((struct avl *)av2)->t - ((struct avl *)av1)->t;
| 1096 |
return(lc<0 ? -1 : lc>0 ? 1 : 0);
| 1097 |
| 1098 |
| 1099 |
| 1100 |
/* GW NOTE 2002/10/3:
| 1101 |
* I used to compare AMBVAL pointers, but found that this was the
| 1102 |
* cause of a serious consistency error with gcc, since the optimizer
| 1103 |
* uses some dangerous trick in pointer subtraction that
| 1104 |
* assumes pointers differ by exact struct size increments.
| 1105 |
| 1106 |
static int
| 1107 |
aposcmp( /* compare ambient value positions */
| 1108 |
const void *avp1,
| 1109 |
const void *avp2
| 1110 |
| 1111 |
| 1112 |
long diff = *(char * const *)avp1 - *(char * const *)avp2;
| 1113 |
if (diff < 0)
| 1114 |
return(-1);
| 1115 |
return(diff > 0);
| 1116 |
| 1117 |
| 1118 |
| 1119 |
static int
| 1120 |
avlmemi( /* find list position from address */
| 1121 |
AMBVAL *avaddr
| 1122 |
| 1123 |
| 1124 |
AMBVAL **avlpp;
| 1125 |
| 1126 |
avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2,
| 1127 |
nambvals, sizeof(AMBVAL *), &aposcmp);
| 1128 |
if (avlpp == NULL)
| 1129 |
error(CONSISTENCY, "address not found in avlmemi");
| 1130 |
return(avlpp - avlist2);
| 1131 |
| 1132 |
| 1133 |
| 1134 |
static void
| 1135 |
sortambvals( /* resort ambient values */
| 1136 |
int always
| 1137 |
| 1138 |
| 1139 |
AMBTREE oldatrunk;
| 1140 |
AMBVAL tav, *tap, *pnext;
| 1141 |
int i, j;
| 1142 |
/* see if it's time yet */
| 1143 |
if (!always && (ambclock++ < lastsort+sortintvl ||
| 1144 |
nambvals < SORT_THRESH))
| 1145 |
return;
| 1146 |
| 1147 |
* The idea here is to minimize memory thrashing
| 1148 |
* in VM systems by improving reference locality.
| 1149 |
* We do this by periodically sorting our stored ambient
| 1150 |
* values in memory in order of most recently to least
| 1151 |
* recently accessed. This ordering was chosen so that new
| 1152 |
* ambient values (which tend to be less important) go into
| 1153 |
* higher memory with the infrequently accessed values.
| 1154 |
* Since we expect our values to need sorting less
| 1155 |
* frequently as the process continues, we double our
| 1156 |
* waiting interval after each call.
| 1157 |
* This routine is also called by setambacc() with
| 1158 |
* the "always" parameter set to 1 so that the ambient
| 1159 |
* tree will be rebuilt with the new accuracy parameter.
| 1160 |
| 1161 |
if (tracktime) { /* allocate pointer arrays to sort */
| 1162 |
avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *));
| 1163 |
avlist1 = (struct avl *)malloc(nambvals*sizeof(struct avl));
| 1164 |
} else {
| 1165 |
avlist2 = NULL;
| 1166 |
avlist1 = NULL;
| 1167 |
| 1168 |
if (avlist1 == NULL) { /* no time tracking -- rebuild tree? */
| 1169 |
if (avlist2 != NULL)
| 1170 |
free((void *)avlist2);
| 1171 |
if (always) { /* rebuild without sorting */
| 1172 |
oldatrunk = atrunk;
| 1173 |
atrunk.alist = NULL;
| 1174 |
atrunk.kid = NULL;
| 1175 |
unloadatree(&oldatrunk, &avinsert);
| 1176 |
| 1177 |
} else { /* sort memory by last access time */
| 1178 |
| 1179 |
* Sorting memory is tricky because it isn't contiguous.
| 1180 |
* We have to sort an array of pointers by MRA and also
| 1181 |
* by memory position. We then copy values in "loops"
| 1182 |
* to minimize memory hits. Nevertheless, we will visit
| 1183 |
* everyone at least twice, and this is an expensive process
| 1184 |
* when we're thrashing, which is when we need to do it.
| 1185 |
| 1186 |
#ifdef DEBUG
| 1187 |
sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...",
| 1188 |
nambvals, ambclock);
| 1189 |
eputs(errmsg);
| 1190 |
#endif
| 1191 |
i_avlist = 0;
| 1192 |
unloadatree(&atrunk, &av2list); /* empty current tree */
| 1193 |
#ifdef DEBUG
| 1194 |
if (i_avlist < nambvals)
| 1195 |
error(CONSISTENCY, "missing ambient values in sortambvals");
| 1196 |
#endif
| 1197 |
qsort((char *)avlist1, nambvals, sizeof(struct avl), alatcmp);
| 1198 |
qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), aposcmp);
| 1199 |
for (i = 0; i < nambvals; i++) {
| 1200 |
if (avlist1[i].p == NULL)
| 1201 |
continue;
| 1202 |
tap = avlist2[i];
| 1203 |
tav = *tap;
| 1204 |
for (j = i; (pnext = avlist1[j].p) != tap;
| 1205 |
j = avlmemi(pnext)) {
| 1206 |
*(avlist2[j]) = *pnext;
| 1207 |
avinsert(avlist2[j]);
| 1208 |
avlist1[j].p = NULL;
| 1209 |
| 1210 |
*(avlist2[j]) = tav;
| 1211 |
| 1212 |
| 1213 |
| 1214 |
free((void *)avlist1);
| 1215 |
| 1216 |
/* compute new sort interval */
| 1217 |
sortintvl = ambclock - lastsort;
| 1218 |
if (sortintvl >= MAX_SORT_INTVL/2)
| 1219 |
sortintvl = MAX_SORT_INTVL;
| 1220 |
else
| 1221 |
sortintvl <<= 1; /* wait twice as long next */
| 1222 |
#ifdef DEBUG
| 1223 |
eputs("done\n");
| 1224 |
#endif
| 1225 |
| 1226 |
if (ambclock >= MAXACLOCK)
| 1227 |
ambclock = MAXACLOCK/2;
| 1228 |
lastsort = ambclock;
| 1229 |
| 1230 |
| 1231 |
| 1232 |
#ifdef F_SETLKW
| 1233 |
| 1234 |
static void
| 1235 |
aflock( /* lock/unlock ambient file */
| 1236 |
int typ
| 1237 |
| 1238 |
| 1239 |
static struct flock fls; /* static so initialized to zeroes */
| 1240 |
| 1241 |
if (typ == fls.l_type) /* already called? */
| 1242 |
return;
| 1243 |
fls.l_type = typ;
| 1244 |
if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0)
| 1245 |
error(SYSTEM, "cannot (un)lock ambient file");
| 1246 |
| 1247 |
| 1248 |
| 1249 |
int
| 1250 |
ambsync(void) /* synchronize ambient file */
| 1251 |
| 1252 |
long flen;
| 1253 |
AMBVAL avs;
| 1254 |
int n;
| 1255 |
| 1256 |
if (ambfp == NULL) /* no ambient file? */
| 1257 |
return(0);
| 1258 |
/* gain appropriate access */
| 1259 |
aflock(nunflshed ? F_WRLCK : F_RDLCK);
| 1260 |
/* see if file has grown */
| 1261 |
if ((flen = lseek(fileno(ambfp), (off_t)0, SEEK_END)) < 0)
| 1262 |
goto seekerr;
| 1263 |
if ((n = flen - lastpos) > 0) { /* file has grown */
| 1264 |
if (ambinp == NULL) { /* use duplicate filedes */
| 1265 |
ambinp = fdopen(dup(fileno(ambfp)), "r");
| 1266 |
if (ambinp == NULL)
| 1267 |
error(SYSTEM, "fdopen failed in ambsync");
| 1268 |
| 1269 |
if (fseek(ambinp, lastpos, SEEK_SET) < 0)
| 1270 |
goto seekerr;
| 1271 |
while (n >= AMBVALSIZ) { /* load contributed values */
| 1272 |
if (!readambval(&avs, ambinp)) {
| 1273 |
sprintf(errmsg,
| 1274 |
"ambient file \"%s\" corrupted near character %ld",
| 1275 |
ambfile, flen - n);
| 1276 |
| 1277 |
break;
| 1278 |
| 1279 |
avstore(&avs);
| 1280 |
n -= AMBVALSIZ;
| 1281 |
| 1282 |
lastpos = flen - n;
| 1283 |
/*** seek always as safety measure
| 1284 |
if (n) ***/ /* alignment */
| 1285 |
if (lseek(fileno(ambfp), (off_t)lastpos, SEEK_SET) < 0)
| 1286 |
goto seekerr;
| 1287 |
| 1288 |
n = fflush(ambfp); /* calls write() at last */
| 1289 |
if (n != EOF)
| 1290 |
lastpos += (long)nunflshed*AMBVALSIZ;
| 1291 |
else if ((lastpos = lseek(fileno(ambfp), (off_t)0, SEEK_CUR)) < 0)
| 1292 |
goto seekerr;
| 1293 |
| 1294 |
| 1295 |
nunflshed = 0;
| 1296 |
return(n);
| 1297 |
seekerr:
| 1298 |
error(SYSTEM, "seek failed in ambsync");
| 1299 |
return -1; /* pro forma return */
| 1300 |
| 1301 |
| 1302 |
#else /* ! F_SETLKW */
| 1303 |
| 1304 |
int
| 1305 |
ambsync(void) /* flush ambient file */
| 1306 |
| 1307 |
if (ambfp == NULL)
| 1308 |
return(0);
| 1309 |
nunflshed = 0;
| 1310 |
return(fflush(ambfp));
| 1311 |
| 1312 |
| 1313 |
#endif /* ! F_SETLKW */
