--- ray/src/rt/ambient.c 1993/08/05 16:25:05 2.21 +++ ray/src/rt/ambient.c 2004/11/05 17:36:55 2.57 @@ -1,33 +1,32 @@ -/* Copyright (c) 1993 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: ambient.c,v 2.57 2004/11/05 17:36:55 greg Exp $"; #endif - /* * ambient.c - routines dealing with ambient (inter-reflected) component. + * + * Declarations of external symbols in ambient.h */ -#include "ray.h" +#include "copyright.h" -#include "octree.h" +#include +#include "platform.h" +#include "ray.h" #include "otypes.h" - +#include "resolu.h" #include "ambient.h" - #include "random.h" -#define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */ +#ifndef OCTSCALE +#define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */ +#endif -typedef struct ambtree { - AMBVAL *alist; /* ambient value list */ - struct ambtree *kid; /* 8 child nodes */ -} AMBTREE; /* ambient octree */ +extern char *shm_boundary; /* memory sharing boundary */ -extern CUBE thescene; /* contains space boundaries */ - -#define MAXASET 511 /* maximum number of elements in ambient set */ +#ifndef MAXASET +#define MAXASET 2047 /* maximum number of elements in ambient set */ +#endif OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */ double maxarad; /* maximum ambient radius */ @@ -38,90 +37,159 @@ static AMBTREE atrunk; /* our ambient trunk node */ static FILE *ambfp = NULL; /* ambient file pointer */ static int nunflshed = 0; /* number of unflushed ambient values */ +#ifndef SORT_THRESH +#ifdef SMLMEM +#define SORT_THRESH ((3L<<20)/sizeof(AMBVAL)) +#else +#define SORT_THRESH ((9L<<20)/sizeof(AMBVAL)) +#endif +#endif +#ifndef SORT_INTVL +#define SORT_INTVL (SORT_THRESH<<1) +#endif +#ifndef MAX_SORT_INTVL +#define MAX_SORT_INTVL (SORT_INTVL<<6) +#endif + +static double avsum = 0.; /* computed ambient value sum (log) */ +static unsigned int navsum = 0; /* number of values in avsum */ +static unsigned int nambvals = 0; /* total number of indirect values */ +static unsigned int nambshare = 0; /* number of values from file */ +static unsigned long ambclock = 0; /* ambient access clock */ +static unsigned long lastsort = 0; /* time of last value sort */ +static long sortintvl = SORT_INTVL; /* time until next sort */ +static FILE *ambinp = NULL; /* auxiliary file for input */ +static long lastpos = -1; /* last flush position */ + +#define MAXACLOCK (1L<<30) /* clock turnover value */ + /* + * Track access times unless we are sharing ambient values + * through memory on a multiprocessor, when we want to avoid + * claiming our own memory (copy on write). Go ahead anyway + * if more than two thirds of our values are unshared. + * Compile with -Dtracktime=0 to turn this code off. + */ +#ifndef tracktime +#define tracktime (shm_boundary == NULL || nambvals > 3*nambshare) +#endif + #define AMBFLUSH (BUFSIZ/AMBVALSIZ) -#define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL)) +#define newambval() (AMBVAL *)malloc(sizeof(AMBVAL)) +#define freeav(av) free((void *)av); -#define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE)) -#define freeambtree(t) free((char *)(t)) +static void initambfile(int creat); +static void avsave(AMBVAL *av); +static AMBVAL *avstore(AMBVAL *aval); +static AMBTREE *newambtree(void); +static void freeambtree(AMBTREE *atp); -extern long ftell(), lseek(); -static int initambfile(), avsave(), avinsert(), loadatree(); -static AMBVAL *avstore(); +typedef void unloadtf_t(void *); +static unloadtf_t avinsert; +static unloadtf_t av2list; +static void unloadatree(AMBTREE *at, unloadtf_t *f); + +static int aposcmp(const void *avp1, const void *avp2); +static int avlmemi(AMBVAL *avaddr); +static void sortambvals(int always); + #ifdef F_SETLKW -static aflock(); +static void aflock(int typ); #endif -setambres(ar) /* set ambient resolution */ -int ar; +extern void +setambres( /* set ambient resolution */ + int ar +) { ambres = ar < 0 ? 0 : ar; /* may be done already */ /* set min & max radii */ if (ar <= 0) { - minarad = 0.0; + minarad = 0; maxarad = thescene.cusize / 2.0; } else { minarad = thescene.cusize / ar; - maxarad = 16.0 * minarad; /* heuristic */ + maxarad = 64 * minarad; /* heuristic */ if (maxarad > thescene.cusize / 2.0) maxarad = thescene.cusize / 2.0; } - if (maxarad <= FTINY) - maxarad = .001; + if (minarad <= FTINY) + minarad = 10*FTINY; + if (maxarad <= minarad) + maxarad = 64 * minarad; } -setambacc(newa) /* set ambient accuracy */ -double newa; +extern void +setambacc( /* set ambient accuracy */ + double newa +) { - static double oldambacc = -1.0; - AMBTREE oldatrunk; + double ambdiff; - ambacc = newa < 0.0 ? 0.0 : newa; /* may be done already */ - if (oldambacc < -FTINY) - oldambacc = ambacc; /* do nothing first call */ - if (fabs(newa - oldambacc) < 0.01) - return; /* insignificant -- don't bother */ - if (ambacc <= FTINY) - return; /* cannot build new tree */ - /* else need to rebuild tree */ - copystruct(&oldatrunk, &atrunk); - atrunk.alist = NULL; - atrunk.kid = NULL; - loadatree(&oldatrunk); - oldambacc = ambacc; /* remeber setting for next call */ + if (newa < 0.0) + newa = 0.0; + ambdiff = fabs(newa - ambacc); + if (ambdiff >= .01 && (ambacc = newa) > FTINY && nambvals > 0) + sortambvals(1); /* rebuild tree */ } -setambient(afile) /* initialize calculation */ -char *afile; +extern void +setambient(void) /* initialize calculation */ { - long headlen; + int readonly = 0; + long pos, flen; AMBVAL amb; + /* make sure we're fresh */ + ambdone(); /* init ambient limits */ setambres(ambres); setambacc(ambacc); - if (afile == NULL) + if (ambfile == NULL || !ambfile[0]) return; if (ambacc <= FTINY) { sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened", - afile); + ambfile); error(WARNING, errmsg); return; } /* open ambient file */ - if ((ambfp = fopen(afile, "r+")) != NULL) { - initambfile(0); - headlen = ftell(ambfp); + if ((ambfp = fopen(ambfile, "r+")) == NULL) + readonly = (ambfp = fopen(ambfile, "r")) != NULL; + if (ambfp != NULL) { + initambfile(0); /* file exists */ + pos = ftell(ambfp); while (readambval(&amb, ambfp)) avinsert(avstore(&amb)); - /* align */ - fseek(ambfp, -((ftell(ambfp)-headlen)%AMBVALSIZ), 1); - } else if ((ambfp = fopen(afile, "w+")) != NULL) - initambfile(1); - else { - sprintf(errmsg, "cannot open ambient file \"%s\"", afile); + nambshare = nambvals; /* share loaded values */ + if (readonly) { + sprintf(errmsg, + "loaded %u values from read-only ambient file", + nambvals); + error(WARNING, errmsg); + fclose(ambfp); /* close file so no writes */ + ambfp = NULL; + return; /* avoid ambsync() */ + } + /* align file pointer */ + pos += (long)nambvals*AMBVALSIZ; + flen = lseek(fileno(ambfp), (off_t)0, SEEK_END); + if (flen != pos) { + sprintf(errmsg, + "ignoring last %ld values in ambient file (corrupted)", + (flen - pos)/AMBVALSIZ); + error(WARNING, errmsg); + fseek(ambfp, pos, 0); +#ifndef _WIN32 /* XXX we need a replacement for that one */ + ftruncate(fileno(ambfp), (off_t)pos); +#endif + } + } else if ((ambfp = fopen(ambfile, "w+")) != NULL) { + initambfile(1); /* else create new file */ + } else { + sprintf(errmsg, "cannot open ambient file \"%s\"", ambfile); error(SYSTEM, errmsg); } nunflshed++; /* lie */ @@ -129,13 +197,47 @@ char *afile; } -ambnotify(obj) /* record new modifier */ -OBJECT obj; +extern void +ambdone(void) /* close ambient file and free memory */ { + if (ambfp != NULL) { /* close ambient file */ + ambsync(); + fclose(ambfp); + ambfp = NULL; + if (ambinp != NULL) { + fclose(ambinp); + ambinp = NULL; + } + lastpos = -1; + } + /* free ambient tree */ + unloadatree(&atrunk, free); + /* reset state variables */ + avsum = 0.; + navsum = 0; + nambvals = 0; + nambshare = 0; + ambclock = 0; + lastsort = 0; + sortintvl = SORT_INTVL; +} + + +extern void +ambnotify( /* record new modifier */ + OBJECT obj +) +{ static int hitlimit = 0; - register OBJREC *o = objptr(obj); + register OBJREC *o; register char **amblp; + if (obj == OVOID) { /* starting over */ + ambset[0] = 0; + hitlimit = 0; + return; + } + o = objptr(obj); if (hitlimit || !ismodifier(o->otype)) return; for (amblp = amblist; *amblp != NULL; amblp++) @@ -151,12 +253,15 @@ OBJECT obj; } -ambient(acol, r) /* compute ambient component for ray */ -COLOR acol; -register RAY *r; +extern void +ambient( /* compute ambient component for ray */ + COLOR acol, + register RAY *r, + FVECT nrm +) { static int rdepth = 0; /* ambient recursion */ - double d; + double d, l; if (ambdiv <= 0) /* no ambient calculation */ goto dumbamb; @@ -172,35 +277,53 @@ register RAY *r; rdepth++; d = doambient(acol, r, r->rweight, NULL, NULL); rdepth--; - if (d == 0.0) + if (d <= FTINY) goto dumbamb; return; } + + if (tracktime) /* sort to minimize thrashing */ + sortambvals(0); /* get ambient value */ setcolor(acol, 0.0, 0.0, 0.0); - d = sumambient(acol, r, rdepth, + d = sumambient(acol, r, nrm, rdepth, &atrunk, thescene.cuorg, thescene.cusize); - if (d > FTINY) + if (d > FTINY) { scalecolor(acol, 1.0/d); - else { - d = makeambient(acol, r, rdepth++); - rdepth--; + return; } + rdepth++; /* need to cache new value */ + d = makeambient(acol, r, nrm, rdepth-1); + rdepth--; if (d > FTINY) return; dumbamb: /* return global value */ copycolor(acol, ambval); + if ((ambvwt <= 0) | (navsum == 0)) + return; + l = bright(ambval); /* average in computations */ + if (l > FTINY) { + d = (log(l)*(double)ambvwt + avsum) / + (double)(ambvwt + navsum); + d = exp(d) / l; + scalecolor(acol, d); /* apply color of ambval */ + } else { + d = exp( avsum / (double)navsum ); + setcolor(acol, d, d, d); /* neutral color */ + } } -double -sumambient(acol, r, al, at, c0, s) /* get interpolated ambient value */ -COLOR acol; -register RAY *r; -int al; -AMBTREE *at; -FVECT c0; -double s; +extern double +sumambient( /* get interpolated ambient value */ + COLOR acol, + register RAY *r, + FVECT rn, + int al, + AMBTREE *at, + FVECT c0, + double s +) { double d, e1, e2, wt, wsum; COLOR ct; @@ -208,29 +331,46 @@ double s; int i; register int j; register AMBVAL *av; - /* do this node */ + wsum = 0.0; + /* do this node */ for (av = at->alist; av != NULL; av = av->next) { + double rn_dot = -2.0; + if (tracktime) + av->latick = ambclock; /* * Ambient level test. */ - if (av->lvl > al || av->weight < r->rweight-FTINY) + if (av->lvl > al) /* list sorted, so this works */ + break; + if (av->weight < r->rweight-FTINY) continue; /* * Ambient radius test. */ - e1 = 0.0; - for (j = 0; j < 3; j++) { - d = av->pos[j] - r->rop[j]; - e1 += d * d; - } + d = av->pos[0] - r->rop[0]; + e1 = d * d; + d = av->pos[1] - r->rop[1]; + e1 += d * d; + d = av->pos[2] - r->rop[2]; + e1 += d * d; e1 /= av->rad * av->rad; if (e1 > ambacc*ambacc*1.21) continue; /* - * Normal direction test. + * Direction test using closest normal. */ - e2 = (1.0 - DOT(av->dir, r->ron)) * r->rweight; + d = DOT(av->dir, r->ron); + if (rn != r->ron) { + rn_dot = DOT(av->dir, rn); + if (rn_dot > 1.0-FTINY) + rn_dot = 1.0-FTINY; + if (rn_dot >= d-FTINY) { + d = rn_dot; + rn_dot = -2.0; + } + } + e2 = (1.0 - d) * r->rweight; if (e2 < 0.0) e2 = 0.0; if (e1 + e2 > ambacc*ambacc*1.21) continue; @@ -246,16 +386,24 @@ double s; /* * Jittering final test reduces image artifacts. */ - wt = sqrt(e1) + sqrt(e2); - wt *= .9 + .2*urand(9015+samplendx); - if (wt > ambacc) + e1 = sqrt(e1); + e2 = sqrt(e2); + wt = e1 + e2; + if (wt > ambacc*(.9+.2*urand(9015+samplendx))) continue; + /* + * Recompute directional error using perturbed normal + */ + if (rn_dot > 0.0) { + e2 = sqrt((1.0 - rn_dot)*r->rweight); + wt = e1 + e2; + } if (wt <= 1e-3) wt = 1e3; else wt = 1.0 / wt; wsum += wt; - extambient(ct, av, r->rop, r->ron); + extambient(ct, av, r->rop, rn); scalecolor(ct, wt); addcolor(acol, ct); } @@ -274,27 +422,29 @@ double s; break; } if (j == 3) - wsum += sumambient(acol, r, al, at->kid+i, ck0, s); + wsum += sumambient(acol, r, rn, al, at->kid+i, ck0, s); } return(wsum); } -double -makeambient(acol, r, al) /* make a new ambient value */ -COLOR acol; -register RAY *r; -int al; +extern double +makeambient( /* make a new ambient value */ + COLOR acol, + register RAY *r, + FVECT rn, + int al +) { AMBVAL amb; FVECT gp, gd; /* compute weight */ amb.weight = pow(AVGREFL, (double)al); - if (r->rweight < 0.2*amb.weight) /* heuristic */ + if (r->rweight < 0.1*amb.weight) /* heuristic */ amb.weight = r->rweight; /* compute ambient */ amb.rad = doambient(acol, r, amb.weight, gp, gd); - if (amb.rad == 0.0) + if (amb.rad <= FTINY) return(0.0); /* store it */ VCOPY(amb.pos, r->rop); @@ -305,16 +455,21 @@ int al; VCOPY(amb.gdir, gd); /* insert into tree */ avsave(&amb); /* and save to file */ + if (rn != r->ron) + extambient(acol, &amb, r->rop, rn); /* texture */ return(amb.rad); } -extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */ -COLOR cr; -register AMBVAL *ap; -FVECT pv, nv; +extern void +extambient( /* extrapolate value at pv, nv */ + COLOR cr, + register AMBVAL *ap, + FVECT pv, + FVECT nv +) { - FVECT v1, v2; + FVECT v1; register int i; double d; @@ -323,9 +478,8 @@ FVECT pv, nv; for (i = 0; i < 3; i++) d += ap->gpos[i]*(pv[i]-ap->pos[i]); /* gradient due to rotation */ - VCOPY(v1, ap->dir); - fcross(v2, v1, nv); - d += DOT(ap->gdir, v2); + VCROSS(v1, ap->dir, nv); + d += DOT(ap->gdir, v1); if (d <= 0.0) { setcolor(cr, 0.0, 0.0, 0.0); return; @@ -335,28 +489,35 @@ FVECT pv, nv; } -static -initambfile(creat) /* initialize ambient file */ -int creat; +static void +initambfile( /* initialize ambient file */ + int creat +) { - extern char *progname, *octname, VersionID[]; + extern char *progname, *octname; + static char *mybuf = NULL; #ifdef F_SETLKW aflock(creat ? F_WRLCK : F_RDLCK); #endif -#ifdef MSDOS - setmode(fileno(ambfp), O_BINARY); -#endif - setbuf(ambfp, bmalloc(BUFSIZ+8)); + SET_FILE_BINARY(ambfp); + if (mybuf == NULL) + mybuf = (char *)bmalloc(BUFSIZ+8); + setbuf(ambfp, mybuf); if (creat) { /* new file */ - fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ", + newheader("RADIANCE", ambfp); + fprintf(ambfp, "%s -av %g %g %g -aw %d -ab %d -aa %g ", progname, colval(ambval,RED), colval(ambval,GRN), colval(ambval,BLU), - ambounce, ambacc); - fprintf(ambfp, "-ad %d -as %d -ar %d %s\n", - ambdiv, ambssamp, ambres, - octname==NULL ? "" : octname); + ambvwt, ambounce, ambacc); + fprintf(ambfp, "-ad %d -as %d -ar %d ", + ambdiv, ambssamp, ambres); + if (octname != NULL) + printargs(1, &octname, ambfp); + else + fputc('\n', ambfp); fprintf(ambfp, "SOFTWARE= %s\n", VersionID); + fputnow(ambfp); fputformat(AMBFMT, ambfp); putc('\n', ambfp); putambmagic(ambfp); @@ -365,9 +526,10 @@ int creat; } -static -avsave(av) /* insert and save an ambient value */ -AMBVAL *av; +static void +avsave( /* insert and save an ambient value */ + AMBVAL *av +) { avinsert(avstore(av)); if (ambfp == NULL) @@ -379,80 +541,309 @@ AMBVAL *av; goto writerr; return; writerr: - error(SYSTEM, "error writing ambient file"); + error(SYSTEM, "error writing to ambient file"); } static AMBVAL * -avstore(aval) /* allocate memory and store aval */ -register AMBVAL *aval; +avstore( /* allocate memory and store aval */ + register AMBVAL *aval +) { register AMBVAL *av; + double d; if ((av = newambval()) == NULL) error(SYSTEM, "out of memory in avstore"); - copystruct(av, aval); + *av = *aval; + av->latick = ambclock; + av->next = NULL; + nambvals++; + d = bright(av->val); + if (d > FTINY) { /* add to log sum for averaging */ + avsum += log(d); + navsum++; + } return(av); } -static -avinsert(av) /* insert ambient value in our tree */ -register AMBVAL *av; +#define ATALLOCSZ 512 /* #/8 trees to allocate at once */ + +static AMBTREE *atfreelist = NULL; /* free ambient tree structures */ + + +static AMBTREE * +newambtree(void) /* allocate 8 ambient tree structs */ { + register AMBTREE *atp, *upperlim; + + if (atfreelist == NULL) { /* get more nodes */ + atfreelist = (AMBTREE *)malloc(ATALLOCSZ*8*sizeof(AMBTREE)); + if (atfreelist == NULL) + return(NULL); + /* link new free list */ + upperlim = atfreelist + 8*(ATALLOCSZ-1); + for (atp = atfreelist; atp < upperlim; atp += 8) + atp->kid = atp + 8; + atp->kid = NULL; + } + atp = atfreelist; + atfreelist = atp->kid; + memset((char *)atp, '\0', 8*sizeof(AMBTREE)); + return(atp); +} + + +static void +freeambtree( /* free 8 ambient tree structs */ + AMBTREE *atp +) +{ + atp->kid = atfreelist; + atfreelist = atp; +} + + +static void +avinsert( /* insert ambient value in our tree */ + void *av +) +{ register AMBTREE *at; + register AMBVAL *ap; + AMBVAL avh; FVECT ck0; double s; int branch; register int i; - if (av->rad <= FTINY) + if (((AMBVAL*)av)->rad <= FTINY) error(CONSISTENCY, "zero ambient radius in avinsert"); at = &atrunk; VCOPY(ck0, thescene.cuorg); s = thescene.cusize; - while (s*(OCTSCALE/2) > av->rad*ambacc) { + while (s*(OCTSCALE/2) > ((AMBVAL*)av)->rad*ambacc) { if (at->kid == NULL) if ((at->kid = newambtree()) == NULL) error(SYSTEM, "out of memory in avinsert"); s *= 0.5; branch = 0; for (i = 0; i < 3; i++) - if (av->pos[i] > ck0[i] + s) { + if (((AMBVAL*)av)->pos[i] > ck0[i] + s) { ck0[i] += s; branch |= 1 << i; } at = at->kid + branch; } - av->next = at->alist; - at->alist = av; + avh.next = at->alist; /* order by increasing level */ + for (ap = &avh; ap->next != NULL; ap = ap->next) + if (ap->next->lvl >= ((AMBVAL*)av)->lvl) + break; + ((AMBVAL*)av)->next = ap->next; + ap->next = (AMBVAL*)av; + at->alist = avh.next; } -static -loadatree(at) /* move tree to main store */ -register AMBTREE *at; +static void +unloadatree( /* unload an ambient value tree */ + register AMBTREE *at, + unloadtf_t *f +) { register AMBVAL *av; register int i; /* transfer values at this node */ for (av = at->alist; av != NULL; av = at->alist) { at->alist = av->next; - avinsert(av); + (*f)(av); } if (at->kid == NULL) return; for (i = 0; i < 8; i++) /* transfer and free children */ - loadatree(at->kid+i); + unloadatree(at->kid+i, f); freeambtree(at->kid); + at->kid = NULL; } +static struct avl { + AMBVAL *p; + unsigned long t; +} *avlist1; /* ambient value list with ticks */ +static AMBVAL **avlist2; /* memory positions for sorting */ +static int i_avlist; /* index for lists */ + +static int alatcmp(const void *av1, const void *av2); + +static void +av2list( + void *av +) +{ +#ifdef DEBUG + if (i_avlist >= nambvals) + error(CONSISTENCY, "too many ambient values in av2list1"); +#endif + avlist1[i_avlist].p = avlist2[i_avlist] = (AMBVAL*)av; + avlist1[i_avlist++].t = ((AMBVAL*)av)->latick; +} + + +static int +alatcmp( /* compare ambient values for MRA */ + const void *av1, + const void *av2 +) +{ + register long lc = ((struct avl *)av2)->t - ((struct avl *)av1)->t; + return(lc<0 ? -1 : lc>0 ? 1 : 0); +} + + +/* GW NOTE 2002/10/3: + * I used to compare AMBVAL pointers, but found that this was the + * cause of a serious consistency error with gcc, since the optimizer + * uses some dangerous trick in pointer subtraction that + * assumes pointers differ by exact struct size increments. + */ +static int +aposcmp( /* compare ambient value positions */ + const void *avp1, + const void *avp2 +) +{ + register long diff = *(char * const *)avp1 - *(char * const *)avp2; + if (diff < 0) + return(-1); + return(diff > 0); +} + +#if 1 +static int +avlmemi( /* find list position from address */ + AMBVAL *avaddr +) +{ + register AMBVAL **avlpp; + + avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2, + nambvals, sizeof(AMBVAL *), aposcmp); + if (avlpp == NULL) + error(CONSISTENCY, "address not found in avlmemi"); + return(avlpp - avlist2); +} +#else +#define avlmemi(avaddr) ((AMBVAL **)bsearch((char *)&avaddr,(char *)avlist2, \ + nambvals,sizeof(AMBVAL *),aposcmp) - avlist2) +#endif + + +static void +sortambvals( /* resort ambient values */ + int always +) +{ + AMBTREE oldatrunk; + AMBVAL tav, *tap, *pnext; + register int i, j; + /* see if it's time yet */ + if (!always && (ambclock++ < lastsort+sortintvl || + nambvals < SORT_THRESH)) + return; + /* + * The idea here is to minimize memory thrashing + * in VM systems by improving reference locality. + * We do this by periodically sorting our stored ambient + * values in memory in order of most recently to least + * recently accessed. This ordering was chosen so that new + * ambient values (which tend to be less important) go into + * higher memory with the infrequently accessed values. + * Since we expect our values to need sorting less + * frequently as the process continues, we double our + * waiting interval after each call. + * This routine is also called by setambacc() with + * the "always" parameter set to 1 so that the ambient + * tree will be rebuilt with the new accuracy parameter. + */ + if (tracktime) { /* allocate pointer arrays to sort */ + avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *)); + avlist1 = (struct avl *)malloc(nambvals*sizeof(struct avl)); + } else { + avlist2 = NULL; + avlist1 = NULL; + } + if (avlist1 == NULL) { /* no time tracking -- rebuild tree? */ + if (avlist2 != NULL) + free((void *)avlist2); + if (always) { /* rebuild without sorting */ + oldatrunk = atrunk; + atrunk.alist = NULL; + atrunk.kid = NULL; + unloadatree(&oldatrunk, avinsert); + } + } else { /* sort memory by last access time */ + /* + * Sorting memory is tricky because it isn't contiguous. + * We have to sort an array of pointers by MRA and also + * by memory position. We then copy values in "loops" + * to minimize memory hits. Nevertheless, we will visit + * everyone at least twice, and this is an expensive process + * when we're thrashing, which is when we need to do it. + */ +#ifdef DEBUG + sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...", + nambvals, ambclock); + eputs(errmsg); +#endif + i_avlist = 0; + unloadatree(&atrunk, av2list); /* empty current tree */ +#ifdef DEBUG + if (i_avlist < nambvals) + error(CONSISTENCY, "missing ambient values in sortambvals"); +#endif + qsort((char *)avlist1, nambvals, sizeof(struct avl), alatcmp); + qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), aposcmp); + for (i = 0; i < nambvals; i++) { + if (avlist1[i].p == NULL) + continue; + tap = avlist2[i]; + tav = *tap; + for (j = i; (pnext = avlist1[j].p) != tap; + j = avlmemi(pnext)) { + *(avlist2[j]) = *pnext; + avinsert(avlist2[j]); + avlist1[j].p = NULL; + } + *(avlist2[j]) = tav; + avinsert(avlist2[j]); + avlist1[j].p = NULL; + } + free((void *)avlist1); + free((void *)avlist2); + /* compute new sort interval */ + sortintvl = ambclock - lastsort; + if (sortintvl >= MAX_SORT_INTVL/2) + sortintvl = MAX_SORT_INTVL; + else + sortintvl <<= 1; /* wait twice as long next */ +#ifdef DEBUG + eputs("done\n"); +#endif + } + if (ambclock >= MAXACLOCK) + ambclock = MAXACLOCK/2; + lastsort = ambclock; +} + + #ifdef F_SETLKW -static -aflock(typ) /* lock/unlock ambient file */ -int typ; +static void +aflock( /* lock/unlock ambient file */ + int typ +) { static struct flock fls; /* static so initialized to zeroes */ @@ -462,11 +853,9 @@ int typ; } -int -ambsync() /* synchronize ambient file */ +extern int +ambsync(void) /* synchronize ambient file */ { - static FILE *ambinp = NULL; - static long lastpos = -1; long flen; AMBVAL avs; register int n; @@ -478,9 +867,9 @@ ambsync() /* synchronize ambient file */ /* gain exclusive access */ aflock(F_WRLCK); /* see if file has grown */ - if ((flen = lseek(fileno(ambfp), 0L, 2)) < 0) + if ((flen = lseek(fileno(ambfp), (off_t)0, SEEK_END)) < 0) goto seekerr; - if (n = flen - lastpos) { /* file has grown */ + if ( (n = flen - lastpos) ) { /* file has grown */ if (ambinp == NULL) { /* use duplicate filedes */ ambinp = fdopen(dup(fileno(ambfp)), "r"); if (ambinp == NULL) @@ -489,12 +878,19 @@ ambsync() /* synchronize ambient file */ if (fseek(ambinp, lastpos, 0) < 0) goto seekerr; while (n >= AMBVALSIZ) { /* load contributed values */ - readambval(&avs, ambinp); + if (!readambval(&avs, ambinp)) { + sprintf(errmsg, + "ambient file \"%s\" corrupted near character %ld", + ambfile, flen - n); + error(WARNING, errmsg); + break; + } avinsert(avstore(&avs)); n -= AMBVALSIZ; } - if (n) /* alignment */ - if (lseek(fileno(ambfp), flen-n, 0) < 0) + /*** seek always as safety measure + if (n) ***/ /* alignment */ + if (lseek(fileno(ambfp), (off_t)(flen-n), SEEK_SET) < 0) goto seekerr; } #ifdef DEBUG @@ -507,19 +903,20 @@ ambsync() /* synchronize ambient file */ #endif syncend: n = fflush(ambfp); /* calls write() at last */ - if ((lastpos = lseek(fileno(ambfp), 0L, 1)) < 0) + if ((lastpos = lseek(fileno(ambfp), (off_t)0, SEEK_CUR)) < 0) goto seekerr; aflock(F_UNLCK); /* release file */ nunflshed = 0; return(n); seekerr: error(SYSTEM, "seek failed in ambsync"); + return -1; /* pro forma return */ } #else -int -ambsync() /* flush ambient file */ +extern int +ambsync(void) /* flush ambient file */ { if (nunflshed == 0) return(0);
