--- ray/src/rt/ambient.c 1992/07/16 19:44:46 2.11 +++ ray/src/rt/ambient.c 1992/10/02 16:14:53 2.13 @@ -1,4 +1,4 @@ -/* Copyright (c) 1991 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -20,30 +20,30 @@ static char SCCSid[] = "$SunId$ LBL"; #include "random.h" -#define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */ +#define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */ typedef struct ambtree { - AMBVAL *alist; /* ambient value list */ - struct ambtree *kid; /* 8 child nodes */ + AMBVAL *alist; /* ambient value list */ + struct ambtree *kid; /* 8 child nodes */ } AMBTREE; /* ambient octree */ extern CUBE thescene; /* contains space boundaries */ -#define MAXASET 511 /* maximum number of elements in ambient set */ -OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */ +#define MAXASET 511 /* maximum number of elements in ambient set */ +OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */ -double maxarad; /* maximum ambient radius */ -double minarad; /* minimum ambient radius */ +double maxarad; /* maximum ambient radius */ +double minarad; /* minimum ambient radius */ -static AMBTREE atrunk; /* our ambient trunk node */ +static AMBTREE atrunk; /* our ambient trunk node */ static FILE *ambfp = NULL; /* ambient file pointer */ -#define AMBFLUSH (BUFSIZ/AMBVALSIZ) +#define AMBFLUSH (BUFSIZ/AMBVALSIZ) -#define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL)) +#define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL)) -#define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE)) +#define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE)) extern long ftell(), lseek(); static int initambfile(), avsave(), avinsert(), ambsync(); @@ -71,7 +71,7 @@ setambient(afile) /* initialize calculation */ char *afile; { long headlen; - AMBVAL amb; + AMBVAL amb; /* init ambient limits */ setambres(ambres); /* open ambient file */ @@ -95,10 +95,10 @@ char *afile; ambnotify(obj) /* record new modifier */ -OBJECT obj; +OBJECT obj; { static int hitlimit = 0; - register OBJREC *o = objptr(obj); + register OBJREC *o = objptr(obj); register char **amblp; if (hitlimit || !ismodifier(o->otype)) @@ -121,7 +121,7 @@ COLOR acol; register RAY *r; { static int rdepth = 0; /* ambient recursion */ - double d; + double d; if (ambdiv <= 0) /* no ambient calculation */ goto dumbamb; @@ -163,17 +163,16 @@ sumambient(acol, r, al, at, c0, s) /* get interpolated COLOR acol; register RAY *r; int al; -AMBTREE *at; +AMBTREE *at; FVECT c0; -double s; +double s; { - extern double sqrt(); - double d, e1, e2, wt, wsum; + double d, e1, e2, wt, wsum; COLOR ct; FVECT ck0; int i; register int j; - register AMBVAL *av; + register AMBVAL *av; /* do this node */ wsum = 0.0; for (av = at->alist; av != NULL; av = av->next) { @@ -252,7 +251,7 @@ COLOR acol; register RAY *r; int al; { - AMBVAL amb; + AMBVAL amb; FVECT gp, gd; /* compute weight */ amb.weight = pow(AVGREFL, (double)al); @@ -277,12 +276,12 @@ int al; extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */ COLOR cr; -register AMBVAL *ap; +register AMBVAL *ap; FVECT pv, nv; { FVECT v1, v2; register int i; - double d; + double d; d = 1.0; /* zeroeth order */ /* gradient due to translation */ @@ -307,6 +306,9 @@ int creat; { extern char *progname, *octname, VersionID[]; +#ifdef MSDOS + setmode(fileno(ambfp), O_BINARY); +#endif setbuf(ambfp, bmalloc(BUFSIZ)); if (creat) { /* new file */ fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ", @@ -321,7 +323,7 @@ int creat; putc('\n', ambfp); putambmagic(ambfp); fflush(ambfp); -#ifndef NIX +#ifndef NIX sync(); /* protect against NFS buffering */ #endif } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp)) @@ -331,7 +333,7 @@ int creat; static avsave(av) /* insert and save an ambient value */ -AMBVAL *av; +AMBVAL *av; { static int nunflshed = 0; @@ -353,14 +355,14 @@ writerr: static avinsert(aval, at, c0, s) /* insert ambient value in a tree */ -AMBVAL *aval; +AMBVAL *aval; register AMBTREE *at; FVECT c0; -double s; +double s; { FVECT ck0; int branch; - register AMBVAL *av; + register AMBVAL *av; register int i; if ((av = newambval()) == NULL) @@ -388,7 +390,7 @@ memerr: } -#ifdef NIX +#ifdef NIX static ambsync() /* flush ambient file */ @@ -408,7 +410,7 @@ ambsync() /* synchronize ambient file */ static FILE *ambinp = NULL; struct flock fls; struct stat sts; - AMBVAL avs; + AMBVAL avs; long lastpos, flen; register int n; /* gain exclusive access */
