root/radiance/ray/src/rt/ambient.c
Revision: 1.13
Committed: Thu Jun 6 10:48:50 1991 UTC (33 years ago) by greg
Changes since 1.12: +16 -8 lines
some minor improvements
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * ambient.c - routines dealing with ambient (inter-reflected) component.
9 *
10 * The macro AMBFLUSH (if defined) is the number of ambient values
11 * to wait before flushing to the ambient file.
12 *
13 * 5/9/86
14 */
15
16 #include "ray.h"
17
18 #include "octree.h"
19
20 #include "otypes.h"
21
22 #include "random.h"
23
24 #define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */
25
26 extern CUBE thescene; /* contains space boundaries */
27
28 extern COLOR ambval; /* global ambient component */
29 extern double ambacc; /* ambient accuracy */
30 extern int ambres; /* ambient resolution */
31 extern int ambdiv; /* number of divisions for calculation */
32 extern int ambssamp; /* number of super-samples */
33 extern int ambounce; /* number of ambient bounces */
34 extern char *amblist[]; /* ambient include/exclude list */
35 extern int ambincl; /* include == 1, exclude == 0 */
36
37 #define MAXASET 511 /* maximum number of elements in ambient set */
38 OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
39
40 double maxarad; /* maximum ambient radius */
41 double minarad; /* minimum ambient radius */
42
43 /*
44 * Since we've defined our vectors as float below to save space,
45 * watch out for changes in the definitions of VCOPY() and DOT().
46 */
47 typedef struct ambval {
48 float pos[3]; /* position in space */
49 float dir[3]; /* normal direction */
50 int lvl; /* recursion level of parent ray */
51 float weight; /* weight of parent ray */
52 COLOR val; /* computed ambient value */
53 float rad; /* validity radius */
54 struct ambval *next; /* next in list */
55 } AMBVAL; /* ambient value */
56
57 typedef struct ambtree {
58 AMBVAL *alist; /* ambient value list */
59 struct ambtree *kid; /* 8 child nodes */
60 } AMBTREE; /* ambient octree */
61
62 typedef struct {
63 float k; /* error contribution per sample */
64 COLOR v; /* ray sum */
65 int n; /* number of samples */
66 short t, p; /* theta, phi indices */
67 } AMBSAMP; /* ambient sample */
68
69 static AMBTREE atrunk; /* our ambient trunk node */
70
71 static FILE *ambfp = NULL; /* ambient file pointer */
72
73 #define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL))
74
75 #define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE))
76
77 double sumambient(), doambient(), makeambient();
78
79
80 setambient(afile) /* initialize calculation */
81 char *afile;
82 {
83 long ftell();
84 AMBVAL amb;
85
86 maxarad = thescene.cusize / 2.0; /* maximum radius */
87 /* minimum radius */
88 minarad = ambres > 0 ? thescene.cusize/ambres : 0.0;
89
90 /* open ambient file */
91 if (afile != NULL)
92 if ((ambfp = fopen(afile, "r+")) != NULL) {
93 while (fread((char *)&amb,sizeof(AMBVAL),1,ambfp) == 1)
94 avinsert(&amb, &atrunk, thescene.cuorg,
95 thescene.cusize);
96 /* align */
97 fseek(ambfp, -(ftell(ambfp)%sizeof(AMBVAL)), 1);
98 } else if ((ambfp = fopen(afile, "w")) == NULL) {
99 sprintf(errmsg, "cannot open ambient file \"%s\"",
100 afile);
101 error(SYSTEM, errmsg);
102 }
103 }
104
105
106 ambnotify(obj) /* record new modifier */
107 OBJECT obj;
108 {
109 static int hitlimit = 0;
110 register OBJREC *o = objptr(obj);
111 register char **amblp;
112
113 if (hitlimit || !ismodifier(o->otype))
114 return;
115 for (amblp = amblist; *amblp != NULL; amblp++)
116 if (!strcmp(o->oname, *amblp)) {
117 if (ambset[0] >= MAXASET) {
118 error(WARNING, "too many modifiers in ambient list");
119 hitlimit++;
120 return; /* should this be fatal? */
121 }
122 insertelem(ambset, obj);
123 return;
124 }
125 }
126
127
128 ambient(acol, r) /* compute ambient component for ray */
129 COLOR acol;
130 register RAY *r;
131 {
132 static int rdepth = 0; /* ambient recursion */
133 double wsum;
134
135 rdepth++; /* increment level */
136
137 if (ambdiv <= 0) /* no ambient calculation */
138 goto dumbamb;
139 /* check number of bounces */
140 if (rdepth > ambounce)
141 goto dumbamb;
142 /* check ambient list */
143 if (ambincl != -1 && r->ro != NULL &&
144 ambincl != inset(ambset, r->ro->omod))
145 goto dumbamb;
146
147 if (ambacc <= FTINY) { /* no ambient storage */
148 if (doambient(acol, r) == 0.0)
149 goto dumbamb;
150 goto done;
151 }
152 /* get ambient value */
153 setcolor(acol, 0.0, 0.0, 0.0);
154 wsum = sumambient(acol, r, &atrunk, thescene.cuorg, thescene.cusize);
155 if (wsum > FTINY)
156 scalecolor(acol, 1.0/wsum);
157 else if (makeambient(acol, r) == 0.0)
158 goto dumbamb;
159 goto done;
160
161 dumbamb: /* return global value */
162 copycolor(acol, ambval);
163 done: /* must finish here! */
164 rdepth--;
165 }
166
167
168 double
169 sumambient(acol, r, at, c0, s) /* get interpolated ambient value */
170 COLOR acol;
171 register RAY *r;
172 AMBTREE *at;
173 FVECT c0;
174 double s;
175 {
176 extern double sqrt();
177 double d, e1, e2, wt, wsum;
178 COLOR ct;
179 FVECT ck0;
180 int i;
181 register int j;
182 register AMBVAL *av;
183 /* do this node */
184 wsum = 0.0;
185 for (av = at->alist; av != NULL; av = av->next) {
186 /*
187 * Ray strength test.
188 */
189 if (av->lvl > r->rlvl || av->weight < r->rweight-FTINY)
190 continue;
191 /*
192 * Ambient radius test.
193 */
194 e1 = 0.0;
195 for (j = 0; j < 3; j++) {
196 d = av->pos[j] - r->rop[j];
197 e1 += d * d;
198 }
199 e1 /= av->rad * av->rad;
200 if (e1 > ambacc*ambacc*1.21)
201 continue;
202 /*
203 * Normal direction test.
204 */
205 e2 = (1.0 - DOT(av->dir, r->ron)) * r->rweight;
206 if (e2 < 0.0) e2 = 0.0;
207 if (e1 + e2 > ambacc*ambacc*1.21)
208 continue;
209 /*
210 * Ray behind test.
211 */
212 d = 0.0;
213 for (j = 0; j < 3; j++)
214 d += (r->rop[j] - av->pos[j]) *
215 (av->dir[j] + r->ron[j]);
216 if (d*0.5 < -minarad*ambacc)
217 continue;
218 /*
219 * Jittering final test reduces image artifacts.
220 */
221 wt = sqrt(e1) + sqrt(e2);
222 wt *= .9 + .2*frandom();
223 if (wt > ambacc)
224 continue;
225 if (wt <= 1e-3)
226 wt = 1e3;
227 else
228 wt = 1.0 / wt;
229 wsum += wt;
230 copycolor(ct, av->val);
231 scalecolor(ct, wt);
232 addcolor(acol, ct);
233 }
234 if (at->kid == NULL)
235 return(wsum);
236 /* do children */
237 s *= 0.5;
238 for (i = 0; i < 8; i++) {
239 for (j = 0; j < 3; j++) {
240 ck0[j] = c0[j];
241 if (1<<j & i)
242 ck0[j] += s;
243 if (r->rop[j] < ck0[j] - OCTSCALE*s)
244 break;
245 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
246 break;
247 }
248 if (j == 3)
249 wsum += sumambient(acol, r, at->kid+i, ck0, s);
250 }
251 return(wsum);
252 }
253
254
255 double
256 makeambient(acol, r) /* make a new ambient value */
257 COLOR acol;
258 register RAY *r;
259 {
260 AMBVAL amb;
261
262 amb.rad = doambient(acol, r); /* compute ambient */
263 if (amb.rad == 0.0)
264 return(0.0);
265 /* store it */
266 VCOPY(amb.pos, r->rop);
267 VCOPY(amb.dir, r->ron);
268 amb.lvl = r->rlvl;
269 amb.weight = r->rweight;
270 copycolor(amb.val, acol);
271 /* insert into tree */
272 avinsert(&amb, &atrunk, thescene.cuorg, thescene.cusize);
273 avsave(&amb); /* write to file */
274 return(amb.rad);
275 }
276
277
278 double
279 doambient(acol, r) /* compute ambient component */
280 COLOR acol;
281 register RAY *r;
282 {
283 extern int ambcmp();
284 extern double sin(), cos(), sqrt();
285 int hlist[4];
286 double phi, xd, yd, zd;
287 double b, b2;
288 register AMBSAMP *div;
289 AMBSAMP dnew;
290 RAY ar;
291 FVECT ux, uy;
292 double arad;
293 int ndivs, nt, np, ns, ne, i, j;
294 register int k;
295
296 setcolor(acol, 0.0, 0.0, 0.0);
297 /* set number of divisions */
298 nt = sqrt(ambdiv * r->rweight * 0.5) + 0.5;
299 np = 2 * nt;
300 ndivs = nt * np;
301 /* check first */
302 if (ndivs == 0 || rayorigin(&ar, r, AMBIENT, 0.5) < 0)
303 return(0.0);
304 /* set number of super-samples */
305 ns = ambssamp * r->rweight + 0.5;
306 if (ns > 0) {
307 div = (AMBSAMP *)malloc(ndivs*sizeof(AMBSAMP));
308 if (div == NULL)
309 error(SYSTEM, "out of memory in doambient");
310 } else
311 div = NULL;
312 /* make axes */
313 uy[0] = uy[1] = uy[2] = 0.0;
314 for (k = 0; k < 3; k++)
315 if (r->ron[k] < 0.6 && r->ron[k] > -0.6)
316 break;
317 uy[k] = 1.0;
318 fcross(ux, r->ron, uy);
319 normalize(ux);
320 fcross(uy, ux, r->ron);
321 /* set up urand */
322 hlist[0] = r->rno;
323 /* sample divisions */
324 arad = 0.0;
325 ne = 0;
326 for (i = 0; i < nt; i++) {
327 hlist[1] = i;
328 for (j = 0; j < np; j++) {
329 rayorigin(&ar, r, AMBIENT, 0.5); /* pretested */
330 hlist[2] = j;
331 hlist[3] = 0;
332 zd = sqrt((i+urand(ilhash(hlist,4)))/nt);
333 hlist[3] = 1;
334 phi = 2.0*PI * (j+urand(ilhash(hlist,4)))/np;
335 xd = cos(phi) * zd;
336 yd = sin(phi) * zd;
337 zd = sqrt(1.0 - zd*zd);
338 for (k = 0; k < 3; k++)
339 ar.rdir[k] = xd*ux[k]+yd*uy[k]+zd*r->ron[k];
340 dimlist[ndims++] = i*np + j + 38813;
341 rayvalue(&ar);
342 ndims--;
343 if (ar.rot < FHUGE)
344 arad += 1.0 / ar.rot;
345 if (div != NULL) { /* save division */
346 div[ne].k = 0.0;
347 copycolor(div[ne].v, ar.rcol);
348 div[ne].n = 0;
349 div[ne].t = i; div[ne].p = j;
350 /* sum errors */
351 b = bright(ar.rcol);
352 if (i > 0) { /* from above */
353 b2 = bright(div[ne-np].v) - b;
354 b2 *= b2 * 0.25;
355 div[ne].k += b2;
356 div[ne].n++;
357 div[ne-np].k += b2;
358 div[ne-np].n++;
359 }
360 if (j > 0) { /* from behind */
361 b2 = bright(div[ne-1].v) - b;
362 b2 *= b2 * 0.25;
363 div[ne].k += b2;
364 div[ne].n++;
365 div[ne-1].k += b2;
366 div[ne-1].n++;
367 }
368 if (j == np-1) { /* around */
369 b2 = bright(div[ne-(np-1)].v) - b;
370 b2 *= b2 * 0.25;
371 div[ne].k += b2;
372 div[ne].n++;
373 div[ne-(np-1)].k += b2;
374 div[ne-(np-1)].n++;
375 }
376 ne++;
377 } else
378 addcolor(acol, ar.rcol);
379 }
380 }
381 for (k = 0; k < ne; k++) { /* compute errors */
382 if (div[k].n > 1)
383 div[k].k /= div[k].n;
384 div[k].n = 1;
385 }
386 /* sort the divisions */
387 qsort(div, ne, sizeof(AMBSAMP), ambcmp);
388 /* skim excess */
389 while (ne > ns) {
390 ne--;
391 addcolor(acol, div[ne].v);
392 }
393 /* super-sample */
394 for (i = ns; i > 0; i--) {
395 rayorigin(&ar, r, AMBIENT, 0.5); /* pretested */
396 hlist[1] = div[0].t;
397 hlist[2] = div[0].p;
398 hlist[3] = 0;
399 zd = sqrt((div[0].t+urand(ilhash(hlist,4)+div[0].n))/nt);
400 hlist[3] = 1;
401 phi = 2.0*PI * (div[0].p+urand(ilhash(hlist,4)+div[0].n))/np;
402 xd = cos(phi) * zd;
403 yd = sin(phi) * zd;
404 zd = sqrt(1.0 - zd*zd);
405 for (k = 0; k < 3; k++)
406 ar.rdir[k] = xd*ux[k]+yd*uy[k]+zd*r->ron[k];
407 dimlist[ndims++] = div[0].t*np + div[0].p + 38813;
408 rayvalue(&ar);
409 ndims--;
410 rayvalue(&ar);
411 if (ar.rot < FHUGE)
412 arad += 1.0 / ar.rot;
413 /* recompute error */
414 copycolor(dnew.v, div[0].v);
415 addcolor(dnew.v, ar.rcol);
416 dnew.n = div[0].n + 1;
417 dnew.t = div[0].t; dnew.p = div[0].p;
418 b2 = bright(dnew.v)/dnew.n - bright(ar.rcol);
419 b2 = b2*b2 + div[0].k*(div[0].n*div[0].n);
420 dnew.k = b2/(dnew.n*dnew.n);
421 /* reinsert */
422 for (k = 0; k < ne-1 && dnew.k < div[k+1].k; k++)
423 copystruct(&div[k], &div[k+1]);
424 copystruct(&div[k], &dnew);
425
426 if (ne >= i) { /* extract darkest division */
427 ne--;
428 if (div[ne].n > 1) {
429 b = 1.0/div[ne].n;
430 scalecolor(div[ne].v, b);
431 div[ne].n = 1;
432 }
433 addcolor(acol, div[ne].v);
434 }
435 }
436 scalecolor(acol, 1.0/ndivs);
437 if (arad <= FTINY)
438 arad = FHUGE;
439 else
440 arad = (ndivs+ns) / arad / sqrt(r->rweight);
441 if (arad > maxarad)
442 arad = maxarad;
443 else if (arad < minarad)
444 arad = minarad;
445 if (div != NULL)
446 free((char *)div);
447 return(arad);
448 }
449
450
451 static int
452 ambcmp(d1, d2) /* decreasing order */
453 AMBSAMP *d1, *d2;
454 {
455 if (d1->k < d2->k)
456 return(1);
457 if (d1->k > d2->k)
458 return(-1);
459 return(0);
460 }
461
462
463 static
464 avsave(av) /* save an ambient value */
465 AMBVAL *av;
466 {
467 #ifdef AMBFLUSH
468 static int nunflshed = 0;
469 #endif
470 if (ambfp == NULL)
471 return;
472 if (fwrite((char *)av, sizeof(AMBVAL), 1, ambfp) != 1)
473 goto writerr;
474 #ifdef AMBFLUSH
475 if (++nunflshed >= AMBFLUSH) {
476 if (fflush(ambfp) == EOF)
477 goto writerr;
478 nunflshed = 0;
479 }
480 #endif
481 return;
482 writerr:
483 error(SYSTEM, "error writing ambient file");
484 }
485
486
487 static
488 avinsert(aval, at, c0, s) /* insert ambient value in a tree */
489 AMBVAL *aval;
490 register AMBTREE *at;
491 FVECT c0;
492 double s;
493 {
494 FVECT ck0;
495 int branch;
496 register AMBVAL *av;
497 register int i;
498
499 if ((av = newambval()) == NULL)
500 goto memerr;
501 copystruct(av, aval);
502 VCOPY(ck0, c0);
503 while (s*(OCTSCALE/2) > av->rad*ambacc) {
504 if (at->kid == NULL)
505 if ((at->kid = newambtree()) == NULL)
506 goto memerr;
507 s *= 0.5;
508 branch = 0;
509 for (i = 0; i < 3; i++)
510 if (av->pos[i] > ck0[i] + s) {
511 ck0[i] += s;
512 branch |= 1 << i;
513 }
514 at = at->kid + branch;
515 }
516 av->next = at->alist;
517 at->alist = av;
518 return;
519 memerr:
520 error(SYSTEM, "out of memory in avinsert");
521 }
