--- ray/src/rt/ambient.c 1993/08/05 10:02:00 2.20 +++ ray/src/rt/ambient.c 1994/03/24 13:41:04 2.24 @@ -46,7 +46,7 @@ static int nunflshed = 0; /* number of unflushed ambi #define freeambtree(t) free((char *)(t)) extern long ftell(), lseek(); -static int initambfile(), avsave(), avinsert(), loadtree(); +static int initambfile(), avsave(), avinsert(), loadatree(); static AMBVAL *avstore(); #ifdef F_SETLKW static aflock(); @@ -56,7 +56,7 @@ static aflock(); setambres(ar) /* set ambient resolution */ int ar; { - ambres = ar; /* may be done already */ + ambres = ar < 0 ? 0 : ar; /* may be done already */ /* set min & max radii */ if (ar <= 0) { minarad = 0.0; @@ -72,21 +72,25 @@ int ar; } -resetambacc(newa) /* change ambient accuracy setting */ +setambacc(newa) /* set ambient accuracy */ double newa; { + static double oldambacc = -1.0; AMBTREE oldatrunk; - if (fabs(newa - ambacc) < 0.01) + ambacc = newa < 0.0 ? 0.0 : newa; /* may be done already */ + if (oldambacc < -FTINY) + oldambacc = ambacc; /* do nothing first call */ + if (fabs(newa - oldambacc) < 0.01) return; /* insignificant -- don't bother */ - ambacc = newa; if (ambacc <= FTINY) return; /* cannot build new tree */ /* else need to rebuild tree */ copystruct(&oldatrunk, &atrunk); atrunk.alist = NULL; atrunk.kid = NULL; - loadtree(&oldatrunk); + loadatree(&oldatrunk); + oldambacc = ambacc; /* remeber setting for next call */ } @@ -97,10 +101,11 @@ char *afile; AMBVAL amb; /* init ambient limits */ setambres(ambres); + setambacc(ambacc); if (afile == NULL) return; if (ambacc <= FTINY) { - sprintf(errmsg, "zero ambient accuracy so \"%s\" not loaded", + sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened", afile); error(WARNING, errmsg); return; @@ -110,8 +115,7 @@ char *afile; initambfile(0); headlen = ftell(ambfp); while (readambval(&amb, ambfp)) - avinsert(avstore(&amb), &atrunk, - thescene.cuorg, thescene.cusize); + avinsert(avstore(&amb)); /* align */ fseek(ambfp, -((ftell(ambfp)-headlen)%AMBVALSIZ), 1); } else if ((ambfp = fopen(afile, "w+")) != NULL) @@ -210,7 +214,9 @@ double s; /* * Ambient level test. */ - if (av->lvl > al || av->weight < r->rweight-FTINY) + if (av->lvl > al) /* list sorted, so this works */ + break; + if (av->weight < r->rweight-FTINY) continue; /* * Ambient radius test. @@ -343,8 +349,9 @@ int creat; #ifdef MSDOS setmode(fileno(ambfp), O_BINARY); #endif - setbuf(ambfp, bmalloc(BUFSIZ)); + setbuf(ambfp, bmalloc(BUFSIZ+8)); if (creat) { /* new file */ + newheader("RADIANCE", ambfp); fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ", progname, colval(ambval,RED), colval(ambval,GRN), colval(ambval,BLU), @@ -365,7 +372,7 @@ static avsave(av) /* insert and save an ambient value */ AMBVAL *av; { - avinsert(avstore(av), &atrunk, thescene.cuorg, thescene.cusize); + avinsert(avstore(av)); if (ambfp == NULL) return; if (writambval(av, ambfp) < 0) @@ -393,19 +400,22 @@ register AMBVAL *aval; static -avinsert(av, at, c0, s) /* insert ambient value in a tree */ +avinsert(av) /* insert ambient value in our tree */ register AMBVAL *av; -register AMBTREE *at; -FVECT c0; -double s; { + register AMBTREE *at; + register AMBVAL *ap; + AMBVAL avh; FVECT ck0; + double s; int branch; register int i; if (av->rad <= FTINY) error(CONSISTENCY, "zero ambient radius in avinsert"); - VCOPY(ck0, c0); + at = &atrunk; + VCOPY(ck0, thescene.cuorg); + s = thescene.cusize; while (s*(OCTSCALE/2) > av->rad*ambacc) { if (at->kid == NULL) if ((at->kid = newambtree()) == NULL) @@ -419,13 +429,18 @@ double s; } at = at->kid + branch; } - av->next = at->alist; - at->alist = av; + avh.next = at->alist; /* order by increasing level */ + for (ap = &avh; ap->next != NULL; ap = ap->next) + if (ap->next->lvl >= av->lvl) + break; + av->next = ap->next; + ap->next = av; + at->alist = avh.next; } static -loadtree(at) /* move tree to main store */ +loadatree(at) /* move tree to main store */ register AMBTREE *at; { register AMBVAL *av; @@ -433,10 +448,12 @@ register AMBTREE *at; /* transfer values at this node */ for (av = at->alist; av != NULL; av = at->alist) { at->alist = av->next; - avinsert(av, &atrunk, thescene.cuorg, thescene.cusize); + avinsert(av); } + if (at->kid == NULL) + return; for (i = 0; i < 8; i++) /* transfer and free children */ - loadtree(at->kid+i); + loadatree(at->kid+i); freeambtree(at->kid); } @@ -472,7 +489,7 @@ ambsync() /* synchronize ambient file */ aflock(F_WRLCK); /* see if file has grown */ if ((flen = lseek(fileno(ambfp), 0L, 2)) < 0) - error(SYSTEM, "cannot seek on ambient file"); + goto seekerr; if (n = flen - lastpos) { /* file has grown */ if (ambinp == NULL) { /* use duplicate filedes */ ambinp = fdopen(dup(fileno(ambfp)), "r"); @@ -480,22 +497,34 @@ ambsync() /* synchronize ambient file */ error(SYSTEM, "fdopen failed in ambsync"); } if (fseek(ambinp, lastpos, 0) < 0) - error(SYSTEM, "fseek failed in ambsync"); + goto seekerr; while (n >= AMBVALSIZ) { /* load contributed values */ readambval(&avs, ambinp); - avinsert(avstore(&avs), &atrunk, - thescene.cuorg, thescene.cusize); + avinsert(avstore(&avs)); n -= AMBVALSIZ; } - if (n) /* alignment */ - lseek(fileno(ambfp), flen-n, 0); + /*** seek always as safety measure + if (n) ***/ /* alignment */ + if (lseek(fileno(ambfp), flen-n, 0) < 0) + goto seekerr; } +#ifdef DEBUG + if (ambfp->_ptr - ambfp->_base != nunflshed*AMBVALSIZ) { + sprintf(errmsg, "ambient file buffer at %d rather than %d", + ambfp->_ptr - ambfp->_base, + nunflshed*AMBVALSIZ); + error(CONSISTENCY, errmsg); + } +#endif syncend: n = fflush(ambfp); /* calls write() at last */ - lastpos = lseek(fileno(ambfp), 0L, 1); + if ((lastpos = lseek(fileno(ambfp), 0L, 1)) < 0) + goto seekerr; aflock(F_UNLCK); /* release file */ nunflshed = 0; return(n); +seekerr: + error(SYSTEM, "seek failed in ambsync"); } #else
