--- ray/src/rt/ambient.c 1992/07/16 13:37:12 2.7 +++ ray/src/rt/ambient.c 1992/09/21 12:07:31 2.12 @@ -1,4 +1,4 @@ -/* Copyright (c) 1991 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -7,9 +7,6 @@ static char SCCSid[] = "$SunId$ LBL"; /* * ambient.c - routines dealing with ambient (inter-reflected) component. * - * The macro AMBFLUSH (if defined) is the number of ambient values - * to wait before flushing to the ambient file. - * * 5/9/86 */ @@ -23,34 +20,33 @@ static char SCCSid[] = "$SunId$ LBL"; #include "random.h" -#define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */ +#define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */ typedef struct ambtree { - AMBVAL *alist; /* ambient value list */ - struct ambtree *kid; /* 8 child nodes */ + AMBVAL *alist; /* ambient value list */ + struct ambtree *kid; /* 8 child nodes */ } AMBTREE; /* ambient octree */ extern CUBE thescene; /* contains space boundaries */ -#define MAXASET 511 /* maximum number of elements in ambient set */ -OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */ +#define MAXASET 511 /* maximum number of elements in ambient set */ +OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */ -double maxarad; /* maximum ambient radius */ -double minarad; /* minimum ambient radius */ +double maxarad; /* maximum ambient radius */ +double minarad; /* minimum ambient radius */ -static AMBTREE atrunk; /* our ambient trunk node */ +static AMBTREE atrunk; /* our ambient trunk node */ static FILE *ambfp = NULL; /* ambient file pointer */ -static char *afname; /* ambient file name */ -static long ambheadlen; /* length of ambient file header */ -#define AMBFLUSH (BUFSIZ/AMBVALSIZ) +#define AMBFLUSH (BUFSIZ/AMBVALSIZ) -#define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL)) +#define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL)) -#define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE)) +#define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE)) extern long ftell(), lseek(); +static int initambfile(), avsave(), avinsert(), ambsync(); setambres(ar) /* set ambient resolution */ @@ -74,19 +70,21 @@ int ar; setambient(afile) /* initialize calculation */ char *afile; { - AMBVAL amb; + long headlen; + AMBVAL amb; /* init ambient limits */ setambres(ambres); /* open ambient file */ - if ((afname = afile) != NULL) + if (afile != NULL) if ((ambfp = fopen(afile, "r+")) != NULL) { initambfile(0); + headlen = ftell(ambfp); while (readambval(&amb, ambfp)) avinsert(&amb, &atrunk, thescene.cuorg, thescene.cusize); /* align */ - fseek(ambfp, -((ftell(ambfp)-ambheadlen)%AMBVALSIZ), 1); - } else if ((ambfp = fopen(afile, "w")) != NULL) + fseek(ambfp, -((ftell(ambfp)-headlen)%AMBVALSIZ), 1); + } else if ((ambfp = fopen(afile, "w+")) != NULL) initambfile(1); else { sprintf(errmsg, "cannot open ambient file \"%s\"", @@ -96,38 +94,11 @@ char *afile; } -initambfile(creat) /* initialize ambient file */ -int creat; -{ - extern char *progname, *octname; - - setbuf(ambfp, bmalloc(BUFSIZ)); - if (creat) { /* new file */ - fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ", - progname, colval(ambval,RED), - colval(ambval,GRN), colval(ambval,BLU), - ambounce, ambacc); - fprintf(ambfp, "-ad %d -as %d -ar %d %s\n", - ambdiv, ambssamp, ambres, - octname==NULL ? "" : octname); - fputformat(AMBFMT, ambfp); - putc('\n', ambfp); - putambmagic(ambfp); - fflush(ambfp); - } else if (checkheader(ambfp, AMBFMT, NULL) < 0 - || !hasambmagic(ambfp)) { - sprintf(errmsg, "\"%s\" is not an ambient file", afname); - error(USER, afname); - } - ambheadlen = ftell(ambfp); -} - - ambnotify(obj) /* record new modifier */ -OBJECT obj; +OBJECT obj; { static int hitlimit = 0; - register OBJREC *o = objptr(obj); + register OBJREC *o = objptr(obj); register char **amblp; if (hitlimit || !ismodifier(o->otype)) @@ -150,7 +121,7 @@ COLOR acol; register RAY *r; { static int rdepth = 0; /* ambient recursion */ - double d; + double d; if (ambdiv <= 0) /* no ambient calculation */ goto dumbamb; @@ -192,17 +163,17 @@ sumambient(acol, r, al, at, c0, s) /* get interpolated COLOR acol; register RAY *r; int al; -AMBTREE *at; +AMBTREE *at; FVECT c0; -double s; +double s; { extern double sqrt(); - double d, e1, e2, wt, wsum; + double d, e1, e2, wt, wsum; COLOR ct; FVECT ck0; int i; register int j; - register AMBVAL *av; + register AMBVAL *av; /* do this node */ wsum = 0.0; for (av = at->alist; av != NULL; av = av->next) { @@ -281,7 +252,7 @@ COLOR acol; register RAY *r; int al; { - AMBVAL amb; + AMBVAL amb; FVECT gp, gd; /* compute weight */ amb.weight = pow(AVGREFL, (double)al); @@ -306,12 +277,12 @@ int al; extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */ COLOR cr; -register AMBVAL *ap; +register AMBVAL *ap; FVECT pv, nv; { FVECT v1, v2; register int i; - double d; + double d; d = 1.0; /* zeroeth order */ /* gradient due to translation */ @@ -331,8 +302,39 @@ FVECT pv, nv; static +initambfile(creat) /* initialize ambient file */ +int creat; +{ + extern char *progname, *octname, VersionID[]; + +#ifdef MSDOS + setmode(fileno(ambfp), O_BINARY); +#endif + setbuf(ambfp, bmalloc(BUFSIZ)); + if (creat) { /* new file */ + fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ", + progname, colval(ambval,RED), + colval(ambval,GRN), colval(ambval,BLU), + ambounce, ambacc); + fprintf(ambfp, "-ad %d -as %d -ar %d %s\n", + ambdiv, ambssamp, ambres, + octname==NULL ? "" : octname); + fprintf(ambfp, "SOFTWARE= %s\n", VersionID); + fputformat(AMBFMT, ambfp); + putc('\n', ambfp); + putambmagic(ambfp); + fflush(ambfp); +#ifndef NIX + sync(); /* protect against NFS buffering */ +#endif + } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp)) + error(USER, "bad ambient file"); +} + + +static avsave(av) /* insert and save an ambient value */ -AMBVAL *av; +AMBVAL *av; { static int nunflshed = 0; @@ -354,14 +356,14 @@ writerr: static avinsert(aval, at, c0, s) /* insert ambient value in a tree */ -AMBVAL *aval; +AMBVAL *aval; register AMBTREE *at; FVECT c0; -double s; +double s; { FVECT ck0; int branch; - register AMBVAL *av; + register AMBVAL *av; register int i; if ((av = newambval()) == NULL) @@ -389,15 +391,27 @@ memerr: } -#include +#ifdef NIX +static +ambsync() /* flush ambient file */ +{ + return(fflush(ambfp)); +} +#else + +#include +#include +#include + static ambsync() /* synchronize ambient file */ { static FILE *ambinp = NULL; struct flock fls; - AMBVAL avs; + struct stat sts; + AMBVAL avs; long lastpos, flen; register int n; /* gain exclusive access */ @@ -408,21 +422,24 @@ ambsync() /* synchronize ambient file */ if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0) error(SYSTEM, "cannot lock ambient file"); /* see if file has grown */ - lastpos = lseek(fileno(ambfp), 0L, 2); /* may move pointer */ - flen = lseek(fileno(ambfp), 0L, 1); /* new(?) file length */ - if (n = (flen - lastpos)%AMBVALSIZ) /* assure alignment */ - lseek(fileno(ambfp), flen -= n, 0); + lastpos = lseek(fileno(ambfp), 0L, 1); /* get previous position */ + if (fstat(fileno(ambfp), &sts) < 0) /* get current length */ + error(SYSTEM, "cannot stat ambient file"); + flen = sts.st_size; if (n = (flen - lastpos)/AMBVALSIZ) { /* file has grown */ - if (ambinp == NULL && (ambinp = fopen(afname, "r")) == NULL) - error(SYSTEM, "cannot reopen ambient file"); - fseek(ambinp, lastpos, 0); /* go to previous position */ + if (ambinp == NULL) /* use duplicate file */ + ambinp = fdopen(dup(fileno(ambfp)), "r"); while (n--) { /* load contributed values */ readambval(&avs, ambinp); avinsert(&avs,&atrunk,thescene.cuorg,thescene.cusize); - } + } /* moves shared file pointer */ + if (n = (flen - lastpos)%AMBVALSIZ) /* alignment */ + lseek(fileno(ambfp), flen-n, 0); } n = fflush(ambfp); /* calls write() at last */ fls.l_type = F_UNLCK; /* release file */ fcntl(fileno(ambfp), F_SETLKW, &fls); return(n); } + +#endif
