Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added ability to open and load read-only file in setambient()
changed to using VCROSS() macro in extambient()
moved lseek() and ftell() declarations to standard.h
switched to geometric mean for average -av substitute
corrected problem in error reporting
added -aw to ambient file header changed sort frequency slightly to adjust for slower ambient clock
made ambclock advance more slowly
made tick part of array to sort in sortambvals() to reduce paging
fixed potential problem with alatcmp() function on 16-bit machines made error-reporting version of avlmemi() the default
improved logic for when to track time on multiprocessors
added texturing to ambient value computation using extambient()
made setambacc() a little simpler
added automatic ambient value computation (AMBVWT != 0)
undid artifact of ancient change (1.6) that caused unnec. noise
changed maxarad heuristic limit and overrode super-sampling for ambient values that have radii less than minarad after division sampling
adjusted sorting parameters and increased OCTSCALE
adjustments to sort interval defaults and minor improvements
minor improvements
added memory sorting to ambient caching module
changed setting of minarad for -ar 0
ordered ambient lists by level to improve virtual memory performance
changed code to always seek even when it shouldn't be necessary
major and minor bug fixes
corrected flaws in setting and resetting of ambient accuracy
fixed bug due to NFS sloppiness on writing files w/o lock manager
made parallel operations conditional on F_SETLKW
took out ambfname again
bug fixes and improvements on stdio flushing
modified ambsync() to work on forked processes sharing file pointers
fdopen() error check in ambsync()
Changes for PC port
added sync() call to avoid NFS buffering
made ambsync() more efficient with use of duplicate file descriptor
bug fix in misuse of lseek()
minor changes
added calls to lock ambient file and guarantee synchronization between cooperating processes
avoid zero maxarad for scenes with no local objects
changed jittering test to use urand
fixed test when ambrad == 0.
changed heuristic value for when to demote ambient comp. weight
made ambient value weighting and levels more incremental
some minor improvements
added stratified sampling with urand()
Added check for ambset overflow
undid last change, which didn't do much but make artifacts
Sum children first and quit if more than WDONE over requirement
Undid last delta, calculating error not variance!
Fixed wrong calculation of variance
Added variables to avoid confusion in doambient
Fixed incorrect octree test in sumambient
