1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: ambient.c,v 2.67 2007/11/17 06:21:58 greg Exp $"; |
3 |
#endif |
4 |
5 |
* ambient.c - routines dealing with ambient (inter-reflected) component. |
6 |
7 |
* Declarations of external symbols in ambient.h |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include <string.h> |
13 |
14 |
#include "platform.h" |
15 |
#include "ray.h" |
16 |
#include "otypes.h" |
17 |
#include "resolu.h" |
18 |
#include "ambient.h" |
19 |
#include "random.h" |
20 |
21 |
#ifndef OCTSCALE |
22 |
#define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */ |
23 |
#endif |
24 |
25 |
extern char *shm_boundary; /* memory sharing boundary */ |
26 |
27 |
#ifndef MAXASET |
28 |
#define MAXASET 4095 /* maximum number of elements in ambient set */ |
29 |
#endif |
30 |
OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */ |
31 |
32 |
double maxarad; /* maximum ambient radius */ |
33 |
double minarad; /* minimum ambient radius */ |
34 |
35 |
static AMBTREE atrunk; /* our ambient trunk node */ |
36 |
37 |
static FILE *ambfp = NULL; /* ambient file pointer */ |
38 |
static int nunflshed = 0; /* number of unflushed ambient values */ |
39 |
40 |
#ifndef SORT_THRESH |
41 |
#ifdef SMLMEM |
42 |
#define SORT_THRESH ((3L<<20)/sizeof(AMBVAL)) |
43 |
#else |
44 |
#define SORT_THRESH ((9L<<20)/sizeof(AMBVAL)) |
45 |
#endif |
46 |
#endif |
47 |
#ifndef SORT_INTVL |
48 |
#define SORT_INTVL (SORT_THRESH<<1) |
49 |
#endif |
50 |
#ifndef MAX_SORT_INTVL |
51 |
#define MAX_SORT_INTVL (SORT_INTVL<<6) |
52 |
#endif |
53 |
54 |
static double avsum = 0.; /* computed ambient value sum (log) */ |
55 |
static unsigned int navsum = 0; /* number of values in avsum */ |
56 |
static unsigned int nambvals = 0; /* total number of indirect values */ |
57 |
static unsigned int nambshare = 0; /* number of values from file */ |
58 |
static unsigned long ambclock = 0; /* ambient access clock */ |
59 |
static unsigned long lastsort = 0; /* time of last value sort */ |
60 |
static long sortintvl = SORT_INTVL; /* time until next sort */ |
61 |
static FILE *ambinp = NULL; /* auxiliary file for input */ |
62 |
static long lastpos = -1; /* last flush position */ |
63 |
64 |
#define MAXACLOCK (1L<<30) /* clock turnover value */ |
65 |
66 |
* Track access times unless we are sharing ambient values |
67 |
* through memory on a multiprocessor, when we want to avoid |
68 |
* claiming our own memory (copy on write). Go ahead anyway |
69 |
* if more than two thirds of our values are unshared. |
70 |
* Compile with -Dtracktime=0 to turn this code off. |
71 |
72 |
#ifndef tracktime |
73 |
#define tracktime (shm_boundary == NULL || nambvals > 3*nambshare) |
74 |
#endif |
75 |
76 |
#define AMBFLUSH (BUFSIZ/AMBVALSIZ) |
77 |
78 |
#define newambval() (AMBVAL *)malloc(sizeof(AMBVAL)) |
79 |
#define freeav(av) free((void *)av); |
80 |
81 |
static void initambfile(int creat); |
82 |
static void avsave(AMBVAL *av); |
83 |
static AMBVAL *avstore(AMBVAL *aval); |
84 |
static AMBTREE *newambtree(void); |
85 |
static void freeambtree(AMBTREE *atp); |
86 |
87 |
typedef void unloadtf_t(void *); |
88 |
static unloadtf_t avinsert; |
89 |
static unloadtf_t av2list; |
90 |
static void unloadatree(AMBTREE *at, unloadtf_t *f); |
91 |
92 |
static int aposcmp(const void *avp1, const void *avp2); |
93 |
static int avlmemi(AMBVAL *avaddr); |
94 |
static void sortambvals(int always); |
95 |
96 |
#ifdef F_SETLKW |
97 |
static void aflock(int typ); |
98 |
#endif |
99 |
100 |
101 |
extern void |
102 |
setambres( /* set ambient resolution */ |
103 |
int ar |
104 |
105 |
106 |
ambres = ar < 0 ? 0 : ar; /* may be done already */ |
107 |
/* set min & max radii */ |
108 |
if (ar <= 0) { |
109 |
minarad = 0; |
110 |
maxarad = thescene.cusize / 2.0; |
111 |
} else { |
112 |
minarad = thescene.cusize / ar; |
113 |
maxarad = 64 * minarad; /* heuristic */ |
114 |
if (maxarad > thescene.cusize / 2.0) |
115 |
116 |
117 |
if (minarad <= FTINY) |
118 |
minarad = 10*FTINY; |
119 |
if (maxarad <= minarad) |
120 |
maxarad = 64 * minarad; |
121 |
122 |
123 |
124 |
extern void |
125 |
setambacc( /* set ambient accuracy */ |
126 |
double newa |
127 |
128 |
129 |
double ambdiff; |
130 |
131 |
if (newa < 0.0) |
132 |
newa = 0.0; |
133 |
ambdiff = fabs(newa - ambacc); |
134 |
if (ambdiff >= .01 && (ambacc = newa) > FTINY && nambvals > 0) |
135 |
sortambvals(1); /* rebuild tree */ |
136 |
137 |
138 |
139 |
extern void |
140 |
setambient(void) /* initialize calculation */ |
141 |
142 |
int readonly = 0; |
143 |
long flen; |
144 |
AMBVAL amb; |
145 |
/* make sure we're fresh */ |
146 |
ambdone(); |
147 |
/* init ambient limits */ |
148 |
setambres(ambres); |
149 |
setambacc(ambacc); |
150 |
if (ambfile == NULL || !ambfile[0]) |
151 |
return; |
152 |
if (ambacc <= FTINY) { |
153 |
sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened", |
154 |
ambfile); |
155 |
error(WARNING, errmsg); |
156 |
return; |
157 |
158 |
/* open ambient file */ |
159 |
if ((ambfp = fopen(ambfile, "r+")) == NULL) |
160 |
readonly = (ambfp = fopen(ambfile, "r")) != NULL; |
161 |
if (ambfp != NULL) { |
162 |
initambfile(0); /* file exists */ |
163 |
lastpos = ftell(ambfp); |
164 |
while (readambval(&amb, ambfp)) |
165 |
avinsert(avstore(&amb)); |
166 |
nambshare = nambvals; /* share loaded values */ |
167 |
if (readonly) { |
168 |
sprintf(errmsg, |
169 |
"loaded %u values from read-only ambient file", |
170 |
nambvals); |
171 |
172 |
fclose(ambfp); /* close file so no writes */ |
173 |
ambfp = NULL; |
174 |
return; /* avoid ambsync() */ |
175 |
176 |
/* align file pointer */ |
177 |
lastpos += (long)nambvals*AMBVALSIZ; |
178 |
flen = lseek(fileno(ambfp), (off_t)0, SEEK_END); |
179 |
if (flen != lastpos) { |
180 |
sprintf(errmsg, |
181 |
"ignoring last %ld values in ambient file (corrupted)", |
182 |
(flen - lastpos)/AMBVALSIZ); |
183 |
184 |
fseek(ambfp, lastpos, SEEK_SET); |
185 |
#ifndef _WIN32 /* XXX we need a replacement for that one */ |
186 |
ftruncate(fileno(ambfp), (off_t)lastpos); |
187 |
#endif |
188 |
189 |
} else if ((ambfp = fopen(ambfile, "w+")) != NULL) { |
190 |
initambfile(1); /* else create new file */ |
191 |
fflush(ambfp); |
192 |
193 |
} else { |
194 |
sprintf(errmsg, "cannot open ambient file \"%s\"", ambfile); |
195 |
error(SYSTEM, errmsg); |
196 |
197 |
#ifdef F_SETLKW |
198 |
aflock(F_UNLCK); /* release file */ |
199 |
#endif |
200 |
201 |
202 |
203 |
extern void |
204 |
ambdone(void) /* close ambient file and free memory */ |
205 |
206 |
if (ambfp != NULL) { /* close ambient file */ |
207 |
ambsync(); |
208 |
fclose(ambfp); |
209 |
ambfp = NULL; |
210 |
if (ambinp != NULL) { |
211 |
fclose(ambinp); |
212 |
ambinp = NULL; |
213 |
214 |
lastpos = -1; |
215 |
216 |
/* free ambient tree */ |
217 |
unloadatree(&atrunk, free); |
218 |
/* reset state variables */ |
219 |
avsum = 0.; |
220 |
navsum = 0; |
221 |
nambvals = 0; |
222 |
nambshare = 0; |
223 |
ambclock = 0; |
224 |
lastsort = 0; |
225 |
sortintvl = SORT_INTVL; |
226 |
227 |
228 |
229 |
extern void |
230 |
ambnotify( /* record new modifier */ |
231 |
OBJECT obj |
232 |
233 |
234 |
static int hitlimit = 0; |
235 |
register OBJREC *o; |
236 |
register char **amblp; |
237 |
238 |
if (obj == OVOID) { /* starting over */ |
239 |
ambset[0] = 0; |
240 |
hitlimit = 0; |
241 |
return; |
242 |
243 |
o = objptr(obj); |
244 |
if (hitlimit || !ismodifier(o->otype)) |
245 |
return; |
246 |
for (amblp = amblist; *amblp != NULL; amblp++) |
247 |
if (!strcmp(o->oname, *amblp)) { |
248 |
if (ambset[0] >= MAXASET) { |
249 |
error(WARNING, "too many modifiers in ambient list"); |
250 |
hitlimit++; |
251 |
return; /* should this be fatal? */ |
252 |
253 |
insertelem(ambset, obj); |
254 |
return; |
255 |
256 |
257 |
258 |
259 |
extern void |
260 |
multambient( /* compute ambient component & multiply by coef. */ |
261 |
COLOR aval, |
262 |
register RAY *r, |
263 |
FVECT nrm |
264 |
265 |
266 |
static int rdepth = 0; /* ambient recursion */ |
267 |
COLOR acol; |
268 |
double d, l; |
269 |
270 |
if (ambdiv <= 0) /* no ambient calculation */ |
271 |
goto dumbamb; |
272 |
/* check number of bounces */ |
273 |
if (rdepth >= ambounce) |
274 |
goto dumbamb; |
275 |
/* check ambient list */ |
276 |
if (ambincl != -1 && r->ro != NULL && |
277 |
ambincl != inset(ambset, r->ro->omod)) |
278 |
goto dumbamb; |
279 |
280 |
if (ambacc <= FTINY) { /* no ambient storage */ |
281 |
copycolor(acol, aval); |
282 |
rdepth++; |
283 |
d = doambient(acol, r, r->rweight, NULL, NULL); |
284 |
rdepth--; |
285 |
if (d <= FTINY) |
286 |
goto dumbamb; |
287 |
copycolor(aval, acol); |
288 |
return; |
289 |
290 |
291 |
if (tracktime) /* sort to minimize thrashing */ |
292 |
sortambvals(0); |
293 |
/* interpolate ambient value */ |
294 |
setcolor(acol, 0.0, 0.0, 0.0); |
295 |
d = sumambient(acol, r, nrm, rdepth, |
296 |
&atrunk, thescene.cuorg, thescene.cusize); |
297 |
if (d > FTINY) { |
298 |
d = 1.0/d; |
299 |
scalecolor(acol, d); |
300 |
multcolor(aval, acol); |
301 |
return; |
302 |
303 |
rdepth++; /* need to cache new value */ |
304 |
d = makeambient(acol, r, nrm, rdepth-1); |
305 |
rdepth--; |
306 |
if (d > FTINY) { |
307 |
multcolor(aval, acol); /* got new value */ |
308 |
return; |
309 |
310 |
dumbamb: /* return global value */ |
311 |
if ((ambvwt <= 0) | (navsum == 0)) { |
312 |
multcolor(aval, ambval); |
313 |
return; |
314 |
315 |
l = bright(ambval); /* average in computations */ |
316 |
if (l > FTINY) { |
317 |
d = (log(l)*(double)ambvwt + avsum) / |
318 |
(double)(ambvwt + navsum); |
319 |
d = exp(d) / l; |
320 |
scalecolor(aval, d); |
321 |
multcolor(aval, ambval); /* apply color of ambval */ |
322 |
} else { |
323 |
d = exp( avsum / (double)navsum ); |
324 |
scalecolor(aval, d); /* neutral color */ |
325 |
326 |
327 |
328 |
329 |
extern double |
330 |
sumambient( /* get interpolated ambient value */ |
331 |
COLOR acol, |
332 |
register RAY *r, |
333 |
FVECT rn, |
334 |
int al, |
335 |
AMBTREE *at, |
336 |
FVECT c0, |
337 |
double s |
338 |
339 |
340 |
double d, e1, e2, wt, wsum; |
341 |
COLOR ct; |
342 |
FVECT ck0; |
343 |
int i; |
344 |
register int j; |
345 |
register AMBVAL *av; |
346 |
347 |
wsum = 0.0; |
348 |
/* do this node */ |
349 |
for (av = at->alist; av != NULL; av = av->next) { |
350 |
double rn_dot = -2.0; |
351 |
if (tracktime) |
352 |
av->latick = ambclock; |
353 |
354 |
* Ambient level test. |
355 |
356 |
if (av->lvl > al) /* list sorted, so this works */ |
357 |
break; |
358 |
if (av->weight < 0.9*r->rweight) |
359 |
continue; |
360 |
361 |
* Ambient radius test. |
362 |
363 |
d = av->pos[0] - r->rop[0]; |
364 |
e1 = d * d; |
365 |
d = av->pos[1] - r->rop[1]; |
366 |
e1 += d * d; |
367 |
d = av->pos[2] - r->rop[2]; |
368 |
e1 += d * d; |
369 |
e1 /= av->rad * av->rad; |
370 |
if (e1 > ambacc*ambacc*1.21) |
371 |
continue; |
372 |
373 |
* Direction test using closest normal. |
374 |
375 |
d = DOT(av->dir, r->ron); |
376 |
if (rn != r->ron) { |
377 |
rn_dot = DOT(av->dir, rn); |
378 |
if (rn_dot > 1.0-FTINY) |
379 |
rn_dot = 1.0-FTINY; |
380 |
if (rn_dot >= d-FTINY) { |
381 |
d = rn_dot; |
382 |
rn_dot = -2.0; |
383 |
384 |
385 |
e2 = (1.0 - d) * r->rweight; |
386 |
if (e2 < 0.0) e2 = 0.0; |
387 |
if (e1 + e2 > ambacc*ambacc*1.21) |
388 |
continue; |
389 |
390 |
* Ray behind test. |
391 |
392 |
d = 0.0; |
393 |
for (j = 0; j < 3; j++) |
394 |
d += (r->rop[j] - av->pos[j]) * |
395 |
(av->dir[j] + r->ron[j]); |
396 |
if (d*0.5 < -minarad*ambacc-.001) |
397 |
continue; |
398 |
399 |
* Jittering final test reduces image artifacts. |
400 |
401 |
e1 = sqrt(e1); |
402 |
e2 = sqrt(e2); |
403 |
wt = e1 + e2; |
404 |
if (wt > ambacc*(.9+.2*urand(9015+samplendx))) |
405 |
continue; |
406 |
407 |
* Recompute directional error using perturbed normal |
408 |
409 |
if (rn_dot > 0.0) { |
410 |
e2 = sqrt((1.0 - rn_dot)*r->rweight); |
411 |
wt = e1 + e2; |
412 |
413 |
if (wt <= 1e-3) |
414 |
wt = 1e3; |
415 |
else |
416 |
wt = 1.0 / wt; |
417 |
wsum += wt; |
418 |
extambient(ct, av, r->rop, rn); |
419 |
scalecolor(ct, wt); |
420 |
addcolor(acol, ct); |
421 |
422 |
if (at->kid == NULL) |
423 |
return(wsum); |
424 |
/* do children */ |
425 |
s *= 0.5; |
426 |
for (i = 0; i < 8; i++) { |
427 |
for (j = 0; j < 3; j++) { |
428 |
ck0[j] = c0[j]; |
429 |
if (1<<j & i) |
430 |
ck0[j] += s; |
431 |
if (r->rop[j] < ck0[j] - OCTSCALE*s) |
432 |
break; |
433 |
if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s) |
434 |
break; |
435 |
436 |
if (j == 3) |
437 |
wsum += sumambient(acol, r, rn, al, |
438 |
at->kid+i, ck0, s); |
439 |
440 |
return(wsum); |
441 |
442 |
443 |
444 |
extern double |
445 |
makeambient( /* make a new ambient value for storage */ |
446 |
COLOR acol, |
447 |
RAY *r, |
448 |
FVECT rn, |
449 |
int al |
450 |
451 |
452 |
AMBVAL amb; |
453 |
FVECT gp, gd; |
454 |
int i; |
455 |
456 |
amb.weight = 1.0; /* compute weight */ |
457 |
for (i = al; i-- > 0; ) |
458 |
amb.weight *= AVGREFL; |
459 |
if (r->rweight < 0.1*amb.weight) /* heuristic override */ |
460 |
amb.weight = 1.25*r->rweight; |
461 |
setcolor(acol, AVGREFL, AVGREFL, AVGREFL); |
462 |
/* compute ambient */ |
463 |
amb.rad = doambient(acol, r, amb.weight, gp, gd); |
464 |
if (amb.rad <= FTINY) { |
465 |
466 |
return(0.0); |
467 |
468 |
scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */ |
469 |
/* store value */ |
470 |
VCOPY(amb.pos, r->rop); |
471 |
VCOPY(amb.dir, r->ron); |
472 |
amb.lvl = al; |
473 |
copycolor(amb.val, acol); |
474 |
VCOPY(amb.gpos, gp); |
475 |
VCOPY(amb.gdir, gd); |
476 |
/* insert into tree */ |
477 |
avsave(&amb); /* and save to file */ |
478 |
if (rn != r->ron) |
479 |
extambient(acol, &amb, r->rop, rn); /* texture */ |
480 |
return(amb.rad); |
481 |
482 |
483 |
484 |
extern void |
485 |
extambient( /* extrapolate value at pv, nv */ |
486 |
COLOR cr, |
487 |
register AMBVAL *ap, |
488 |
FVECT pv, |
489 |
FVECT nv |
490 |
491 |
492 |
FVECT v1; |
493 |
register int i; |
494 |
double d; |
495 |
496 |
d = 1.0; /* zeroeth order */ |
497 |
/* gradient due to translation */ |
498 |
for (i = 0; i < 3; i++) |
499 |
d += ap->gpos[i]*(pv[i]-ap->pos[i]); |
500 |
/* gradient due to rotation */ |
501 |
VCROSS(v1, ap->dir, nv); |
502 |
d += DOT(ap->gdir, v1); |
503 |
if (d <= 0.0) { |
504 |
setcolor(cr, 0.0, 0.0, 0.0); |
505 |
return; |
506 |
507 |
copycolor(cr, ap->val); |
508 |
scalecolor(cr, d); |
509 |
510 |
511 |
512 |
static void |
513 |
initambfile( /* initialize ambient file */ |
514 |
int cre8 |
515 |
516 |
517 |
extern char *progname, *octname; |
518 |
static char *mybuf = NULL; |
519 |
520 |
#ifdef F_SETLKW |
521 |
aflock(creat ? F_WRLCK : F_RDLCK); |
522 |
#endif |
523 |
SET_FILE_BINARY(ambfp); |
524 |
if (mybuf == NULL) |
525 |
mybuf = (char *)bmalloc(BUFSIZ+8); |
526 |
setbuf(ambfp, mybuf); |
527 |
if (cre8) { /* new file */ |
528 |
newheader("RADIANCE", ambfp); |
529 |
fprintf(ambfp, "%s -av %g %g %g -aw %d -ab %d -aa %g ", |
530 |
progname, colval(ambval,RED), |
531 |
colval(ambval,GRN), colval(ambval,BLU), |
532 |
ambvwt, ambounce, ambacc); |
533 |
fprintf(ambfp, "-ad %d -as %d -ar %d ", |
534 |
ambdiv, ambssamp, ambres); |
535 |
if (octname != NULL) |
536 |
fputs(octname, ambfp); |
537 |
fputc('\n', ambfp); |
538 |
fprintf(ambfp, "SOFTWARE= %s\n", VersionID); |
539 |
fputnow(ambfp); |
540 |
fputformat(AMBFMT, ambfp); |
541 |
542 |
putambmagic(ambfp); |
543 |
} else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp)) |
544 |
error(USER, "bad ambient file"); |
545 |
546 |
547 |
548 |
static void |
549 |
avsave( /* insert and save an ambient value */ |
550 |
AMBVAL *av |
551 |
552 |
553 |
avinsert(avstore(av)); |
554 |
if (ambfp == NULL) |
555 |
return; |
556 |
if (writambval(av, ambfp) < 0) |
557 |
goto writerr; |
558 |
if (++nunflshed >= AMBFLUSH) |
559 |
if (ambsync() == EOF) |
560 |
goto writerr; |
561 |
return; |
562 |
writerr: |
563 |
error(SYSTEM, "error writing to ambient file"); |
564 |
565 |
566 |
567 |
static AMBVAL * |
568 |
avstore( /* allocate memory and store aval */ |
569 |
register AMBVAL *aval |
570 |
571 |
572 |
573 |
double d; |
574 |
575 |
if ((av = newambval()) == NULL) |
576 |
error(SYSTEM, "out of memory in avstore"); |
577 |
*av = *aval; |
578 |
579 |
av->next = NULL; |
580 |
nambvals++; |
581 |
d = bright(av->val); |
582 |
if (d > FTINY) { /* add to log sum for averaging */ |
583 |
avsum += log(d); |
584 |
navsum++; |
585 |
586 |
return(av); |
587 |
588 |
589 |
590 |
#define ATALLOCSZ 512 /* #/8 trees to allocate at once */ |
591 |
592 |
static AMBTREE *atfreelist = NULL; /* free ambient tree structures */ |
593 |
594 |
595 |
static AMBTREE * |
596 |
newambtree(void) /* allocate 8 ambient tree structs */ |
597 |
598 |
register AMBTREE *atp, *upperlim; |
599 |
600 |
if (atfreelist == NULL) { /* get more nodes */ |
601 |
atfreelist = (AMBTREE *)malloc(ATALLOCSZ*8*sizeof(AMBTREE)); |
602 |
if (atfreelist == NULL) |
603 |
return(NULL); |
604 |
/* link new free list */ |
605 |
upperlim = atfreelist + 8*(ATALLOCSZ-1); |
606 |
for (atp = atfreelist; atp < upperlim; atp += 8) |
607 |
atp->kid = atp + 8; |
608 |
atp->kid = NULL; |
609 |
610 |
atp = atfreelist; |
611 |
atfreelist = atp->kid; |
612 |
memset((char *)atp, '\0', 8*sizeof(AMBTREE)); |
613 |
return(atp); |
614 |
615 |
616 |
617 |
static void |
618 |
freeambtree( /* free 8 ambient tree structs */ |
619 |
AMBTREE *atp |
620 |
621 |
622 |
atp->kid = atfreelist; |
623 |
atfreelist = atp; |
624 |
625 |
626 |
627 |
static void |
628 |
avinsert( /* insert ambient value in our tree */ |
629 |
void *av |
630 |
631 |
632 |
register AMBTREE *at; |
633 |
register AMBVAL *ap; |
634 |
AMBVAL avh; |
635 |
FVECT ck0; |
636 |
double s; |
637 |
int branch; |
638 |
register int i; |
639 |
640 |
if (((AMBVAL*)av)->rad <= FTINY) |
641 |
error(CONSISTENCY, "zero ambient radius in avinsert"); |
642 |
at = &atrunk; |
643 |
VCOPY(ck0, thescene.cuorg); |
644 |
s = thescene.cusize; |
645 |
while (s*(OCTSCALE/2) > ((AMBVAL*)av)->rad*ambacc) { |
646 |
647 |
if ((at->kid = newambtree()) == NULL) |
648 |
error(SYSTEM, "out of memory in avinsert"); |
649 |
s *= 0.5; |
650 |
branch = 0; |
651 |
652 |
if (((AMBVAL*)av)->pos[i] > ck0[i] + s) { |
653 |
ck0[i] += s; |
654 |
branch |= 1 << i; |
655 |
656 |
at = at->kid + branch; |
657 |
658 |
avh.next = at->alist; /* order by increasing level */ |
659 |
for (ap = &avh; ap->next != NULL; ap = ap->next) |
660 |
if (ap->next->lvl >= ((AMBVAL*)av)->lvl) |
661 |
break; |
662 |
((AMBVAL*)av)->next = ap->next; |
663 |
ap->next = (AMBVAL*)av; |
664 |
at->alist = avh.next; |
665 |
666 |
667 |
668 |
static void |
669 |
unloadatree( /* unload an ambient value tree */ |
670 |
register AMBTREE *at, |
671 |
unloadtf_t *f |
672 |
673 |
674 |
675 |
register int i; |
676 |
/* transfer values at this node */ |
677 |
for (av = at->alist; av != NULL; av = at->alist) { |
678 |
at->alist = av->next; |
679 |
(*f)(av); |
680 |
681 |
682 |
return; |
683 |
for (i = 0; i < 8; i++) /* transfer and free children */ |
684 |
unloadatree(at->kid+i, f); |
685 |
freeambtree(at->kid); |
686 |
at->kid = NULL; |
687 |
688 |
689 |
690 |
static struct avl { |
691 |
AMBVAL *p; |
692 |
unsigned long t; |
693 |
} *avlist1; /* ambient value list with ticks */ |
694 |
static AMBVAL **avlist2; /* memory positions for sorting */ |
695 |
static int i_avlist; /* index for lists */ |
696 |
697 |
static int alatcmp(const void *av1, const void *av2); |
698 |
699 |
static void |
700 |
av2list( |
701 |
void *av |
702 |
703 |
704 |
#ifdef DEBUG |
705 |
if (i_avlist >= nambvals) |
706 |
error(CONSISTENCY, "too many ambient values in av2list1"); |
707 |
#endif |
708 |
avlist1[i_avlist].p = avlist2[i_avlist] = (AMBVAL*)av; |
709 |
avlist1[i_avlist++].t = ((AMBVAL*)av)->latick; |
710 |
711 |
712 |
713 |
static int |
714 |
alatcmp( /* compare ambient values for MRA */ |
715 |
const void *av1, |
716 |
const void *av2 |
717 |
718 |
719 |
register long lc = ((struct avl *)av2)->t - ((struct avl *)av1)->t; |
720 |
return(lc<0 ? -1 : lc>0 ? 1 : 0); |
721 |
722 |
723 |
724 |
/* GW NOTE 2002/10/3: |
725 |
* I used to compare AMBVAL pointers, but found that this was the |
726 |
* cause of a serious consistency error with gcc, since the optimizer |
727 |
* uses some dangerous trick in pointer subtraction that |
728 |
* assumes pointers differ by exact struct size increments. |
729 |
730 |
static int |
731 |
aposcmp( /* compare ambient value positions */ |
732 |
const void *avp1, |
733 |
const void *avp2 |
734 |
735 |
736 |
register long diff = *(char * const *)avp1 - *(char * const *)avp2; |
737 |
if (diff < 0) |
738 |
return(-1); |
739 |
return(diff > 0); |
740 |
741 |
742 |
#if 1 |
743 |
static int |
744 |
avlmemi( /* find list position from address */ |
745 |
AMBVAL *avaddr |
746 |
747 |
748 |
register AMBVAL **avlpp; |
749 |
750 |
avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2, |
751 |
nambvals, sizeof(AMBVAL *), aposcmp); |
752 |
if (avlpp == NULL) |
753 |
error(CONSISTENCY, "address not found in avlmemi"); |
754 |
return(avlpp - avlist2); |
755 |
756 |
#else |
757 |
#define avlmemi(avaddr) ((AMBVAL **)bsearch((char *)&avaddr,(char *)avlist2, \ |
758 |
nambvals,sizeof(AMBVAL *),aposcmp) - avlist2) |
759 |
#endif |
760 |
761 |
762 |
static void |
763 |
sortambvals( /* resort ambient values */ |
764 |
int always |
765 |
766 |
767 |
AMBTREE oldatrunk; |
768 |
AMBVAL tav, *tap, *pnext; |
769 |
register int i, j; |
770 |
/* see if it's time yet */ |
771 |
if (!always && (ambclock++ < lastsort+sortintvl || |
772 |
nambvals < SORT_THRESH)) |
773 |
return; |
774 |
775 |
* The idea here is to minimize memory thrashing |
776 |
* in VM systems by improving reference locality. |
777 |
* We do this by periodically sorting our stored ambient |
778 |
* values in memory in order of most recently to least |
779 |
* recently accessed. This ordering was chosen so that new |
780 |
* ambient values (which tend to be less important) go into |
781 |
* higher memory with the infrequently accessed values. |
782 |
* Since we expect our values to need sorting less |
783 |
* frequently as the process continues, we double our |
784 |
* waiting interval after each call. |
785 |
* This routine is also called by setambacc() with |
786 |
* the "always" parameter set to 1 so that the ambient |
787 |
* tree will be rebuilt with the new accuracy parameter. |
788 |
789 |
if (tracktime) { /* allocate pointer arrays to sort */ |
790 |
avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *)); |
791 |
avlist1 = (struct avl *)malloc(nambvals*sizeof(struct avl)); |
792 |
} else { |
793 |
avlist2 = NULL; |
794 |
avlist1 = NULL; |
795 |
796 |
if (avlist1 == NULL) { /* no time tracking -- rebuild tree? */ |
797 |
if (avlist2 != NULL) |
798 |
free((void *)avlist2); |
799 |
if (always) { /* rebuild without sorting */ |
800 |
oldatrunk = atrunk; |
801 |
atrunk.alist = NULL; |
802 |
atrunk.kid = NULL; |
803 |
unloadatree(&oldatrunk, avinsert); |
804 |
805 |
} else { /* sort memory by last access time */ |
806 |
807 |
* Sorting memory is tricky because it isn't contiguous. |
808 |
* We have to sort an array of pointers by MRA and also |
809 |
* by memory position. We then copy values in "loops" |
810 |
* to minimize memory hits. Nevertheless, we will visit |
811 |
* everyone at least twice, and this is an expensive process |
812 |
* when we're thrashing, which is when we need to do it. |
813 |
814 |
#ifdef DEBUG |
815 |
sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...", |
816 |
nambvals, ambclock); |
817 |
eputs(errmsg); |
818 |
#endif |
819 |
i_avlist = 0; |
820 |
unloadatree(&atrunk, av2list); /* empty current tree */ |
821 |
#ifdef DEBUG |
822 |
if (i_avlist < nambvals) |
823 |
error(CONSISTENCY, "missing ambient values in sortambvals"); |
824 |
#endif |
825 |
qsort((char *)avlist1, nambvals, sizeof(struct avl), alatcmp); |
826 |
qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), aposcmp); |
827 |
for (i = 0; i < nambvals; i++) { |
828 |
if (avlist1[i].p == NULL) |
829 |
continue; |
830 |
tap = avlist2[i]; |
831 |
tav = *tap; |
832 |
for (j = i; (pnext = avlist1[j].p) != tap; |
833 |
j = avlmemi(pnext)) { |
834 |
*(avlist2[j]) = *pnext; |
835 |
avinsert(avlist2[j]); |
836 |
avlist1[j].p = NULL; |
837 |
838 |
*(avlist2[j]) = tav; |
839 |
840 |
841 |
842 |
free((void *)avlist1); |
843 |
844 |
/* compute new sort interval */ |
845 |
sortintvl = ambclock - lastsort; |
846 |
if (sortintvl >= MAX_SORT_INTVL/2) |
847 |
sortintvl = MAX_SORT_INTVL; |
848 |
else |
849 |
sortintvl <<= 1; /* wait twice as long next */ |
850 |
#ifdef DEBUG |
851 |
eputs("done\n"); |
852 |
#endif |
853 |
854 |
if (ambclock >= MAXACLOCK) |
855 |
ambclock = MAXACLOCK/2; |
856 |
lastsort = ambclock; |
857 |
858 |
859 |
860 |
#ifdef F_SETLKW |
861 |
862 |
static void |
863 |
aflock( /* lock/unlock ambient file */ |
864 |
int typ |
865 |
866 |
867 |
static struct flock fls; /* static so initialized to zeroes */ |
868 |
869 |
if (typ == fls.l_type) /* already called? */ |
870 |
return; |
871 |
fls.l_type = typ; |
872 |
if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0) |
873 |
error(SYSTEM, "cannot (un)lock ambient file"); |
874 |
875 |
876 |
877 |
extern int |
878 |
ambsync(void) /* synchronize ambient file */ |
879 |
880 |
long flen; |
881 |
AMBVAL avs; |
882 |
register int n; |
883 |
884 |
if (ambfp == NULL) /* no ambient file? */ |
885 |
return(0); |
886 |
/* gain appropriate access */ |
887 |
aflock(nunflshed ? F_WRLCK : F_RDLCK); |
888 |
/* see if file has grown */ |
889 |
if ((flen = lseek(fileno(ambfp), (off_t)0, SEEK_END)) < 0) |
890 |
goto seekerr; |
891 |
if ((n = flen - lastpos) > 0) { /* file has grown */ |
892 |
if (ambinp == NULL) { /* use duplicate filedes */ |
893 |
ambinp = fdopen(dup(fileno(ambfp)), "r"); |
894 |
if (ambinp == NULL) |
895 |
error(SYSTEM, "fdopen failed in ambsync"); |
896 |
897 |
if (fseek(ambinp, lastpos, SEEK_SET) < 0) |
898 |
goto seekerr; |
899 |
while (n >= AMBVALSIZ) { /* load contributed values */ |
900 |
if (!readambval(&avs, ambinp)) { |
901 |
sprintf(errmsg, |
902 |
"ambient file \"%s\" corrupted near character %ld", |
903 |
ambfile, flen - n); |
904 |
905 |
break; |
906 |
907 |
avinsert(avstore(&avs)); |
908 |
n -= AMBVALSIZ; |
909 |
910 |
lastpos = flen - n; |
911 |
/*** seek always as safety measure |
912 |
if (n) ***/ /* alignment */ |
913 |
if (lseek(fileno(ambfp), (off_t)lastpos, SEEK_SET) < 0) |
914 |
goto seekerr; |
915 |
916 |
n = fflush(ambfp); /* calls write() at last */ |
917 |
if (n != EOF) |
918 |
lastpos += (long)nunflshed*AMBVALSIZ; |
919 |
else if ((lastpos = lseek(fileno(ambfp), (off_t)0, SEEK_CUR)) < 0) |
920 |
goto seekerr; |
921 |
922 |
923 |
nunflshed = 0; |
924 |
return(n); |
925 |
seekerr: |
926 |
error(SYSTEM, "seek failed in ambsync"); |
927 |
return -1; /* pro forma return */ |
928 |
929 |
930 |
#else |
931 |
932 |
extern int |
933 |
ambsync(void) /* flush ambient file */ |
934 |
935 |
936 |
return(0); |
937 |
nunflshed = 0; |
938 |
return(fflush(ambfp)); |
939 |
940 |
941 |
#endif |
