root/radiance/ray/src/rt/ambient.c
Revision: 2.58
Committed: Tue Apr 19 01:15:06 2005 UTC (20 years ago) by greg
Changes since 2.57: +25 -14 lines
2 static const char RCSid[] = "$Id: ambient.c,v 2.57 2004/11/05 17:36:55 greg Exp $";
5 * ambient.c - routines dealing with ambient (inter-reflected) component.
6 *
7 * Declarations of external symbols in ambient.h
8 */
9
10 #include "copyright.h"
11
12 #include <string.h>
13
14 #include "platform.h"
15 #include "ray.h"
16 #include "otypes.h"
17 #include "resolu.h"
18 #include "ambient.h"
19 #include "random.h"
20
21 #ifndef OCTSCALE
22 #define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */
23 #endif
24
25 extern char *shm_boundary; /* memory sharing boundary */
26
27 #ifndef MAXASET
28 #define MAXASET 2047 /* maximum number of elements in ambient set */
29 #endif
30 OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
31
32 double maxarad; /* maximum ambient radius */
33 double minarad; /* minimum ambient radius */
34
35 static AMBTREE atrunk; /* our ambient trunk node */
36
37 static FILE *ambfp = NULL; /* ambient file pointer */
38 static int nunflshed = 0; /* number of unflushed ambient values */
39
40 #ifndef SORT_THRESH
41 #ifdef SMLMEM
42 #define SORT_THRESH ((3L<<20)/sizeof(AMBVAL))
43 #else
44 #define SORT_THRESH ((9L<<20)/sizeof(AMBVAL))
45 #endif
46 #endif
47 #ifndef SORT_INTVL
48 #define SORT_INTVL (SORT_THRESH<<1)
49 #endif
50 #ifndef MAX_SORT_INTVL
51 #define MAX_SORT_INTVL (SORT_INTVL<<6)
52 #endif
53
54 static double avsum = 0.; /* computed ambient value sum (log) */
55 static unsigned int navsum = 0; /* number of values in avsum */
56 static unsigned int nambvals = 0; /* total number of indirect values */
57 static unsigned int nambshare = 0; /* number of values from file */
58 static unsigned long ambclock = 0; /* ambient access clock */
59 static unsigned long lastsort = 0; /* time of last value sort */
60 static long sortintvl = SORT_INTVL; /* time until next sort */
61 static FILE *ambinp = NULL; /* auxiliary file for input */
62 static long lastpos = -1; /* last flush position */
63
64 #define MAXACLOCK (1L<<30) /* clock turnover value */
65 /*
66 * Track access times unless we are sharing ambient values
67 * through memory on a multiprocessor, when we want to avoid
68 * claiming our own memory (copy on write). Go ahead anyway
69 * if more than two thirds of our values are unshared.
70 * Compile with -Dtracktime=0 to turn this code off.
71 */
72 #ifndef tracktime
73 #define tracktime (shm_boundary == NULL || nambvals > 3*nambshare)
74 #endif
75
76 #define AMBFLUSH (BUFSIZ/AMBVALSIZ)
77
78 #define newambval() (AMBVAL *)malloc(sizeof(AMBVAL))
79 #define freeav(av) free((void *)av);
80
81 static void initambfile(int creat);
82 static void avsave(AMBVAL *av);
83 static AMBVAL *avstore(AMBVAL *aval);
84 static AMBTREE *newambtree(void);
85 static void freeambtree(AMBTREE *atp);
86
87 typedef void unloadtf_t(void *);
88 static unloadtf_t avinsert;
89 static unloadtf_t av2list;
90 static void unloadatree(AMBTREE *at, unloadtf_t *f);
91
92 static int aposcmp(const void *avp1, const void *avp2);
93 static int avlmemi(AMBVAL *avaddr);
94 static void sortambvals(int always);
95
96 #ifdef F_SETLKW
97 static void aflock(int typ);
98 #endif
99
100
101 extern void
102 setambres( /* set ambient resolution */
103 int ar
104 )
105 {
106 ambres = ar < 0 ? 0 : ar; /* may be done already */
107 /* set min & max radii */
108 if (ar <= 0) {
109 minarad = 0;
110 maxarad = thescene.cusize / 2.0;
111 } else {
112 minarad = thescene.cusize / ar;
113 maxarad = 64 * minarad; /* heuristic */
114 if (maxarad > thescene.cusize / 2.0)
115 maxarad = thescene.cusize / 2.0;
116 }
117 if (minarad <= FTINY)
118 minarad = 10*FTINY;
119 if (maxarad <= minarad)
120 maxarad = 64 * minarad;
121 }
122
123
124 extern void
125 setambacc( /* set ambient accuracy */
126 double newa
127 )
128 {
129 double ambdiff;
130
131 if (newa < 0.0)
132 newa = 0.0;
133 ambdiff = fabs(newa - ambacc);
134 if (ambdiff >= .01 && (ambacc = newa) > FTINY && nambvals > 0)
135 sortambvals(1); /* rebuild tree */
136 }
137
138
139 extern void
140 setambient(void) /* initialize calculation */
141 {
142 int readonly = 0;
143 long pos, flen;
144 AMBVAL amb;
145 /* make sure we're fresh */
146 ambdone();
147 /* init ambient limits */
148 setambres(ambres);
149 setambacc(ambacc);
150 if (ambfile == NULL || !ambfile[0])
151 return;
152 if (ambacc <= FTINY) {
153 sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened",
154 ambfile);
155 error(WARNING, errmsg);
156 return;
157 }
158 /* open ambient file */
159 if ((ambfp = fopen(ambfile, "r+")) == NULL)
160 readonly = (ambfp = fopen(ambfile, "r")) != NULL;
161 if (ambfp != NULL) {
162 initambfile(0); /* file exists */
163 pos = ftell(ambfp);
164 while (readambval(&amb, ambfp))
165 avinsert(avstore(&amb));
166 nambshare = nambvals; /* share loaded values */
167 if (readonly) {
168 sprintf(errmsg,
169 "loaded %u values from read-only ambient file",
170 nambvals);
171 error(WARNING, errmsg);
172 fclose(ambfp); /* close file so no writes */
173 ambfp = NULL;
174 return; /* avoid ambsync() */
175 }
176 /* align file pointer */
177 pos += (long)nambvals*AMBVALSIZ;
178 flen = lseek(fileno(ambfp), (off_t)0, SEEK_END);
179 if (flen != pos) {
180 sprintf(errmsg,
181 "ignoring last %ld values in ambient file (corrupted)",
182 (flen - pos)/AMBVALSIZ);
183 error(WARNING, errmsg);
184 fseek(ambfp, pos, 0);
185 #ifndef _WIN32 /* XXX we need a replacement for that one */
186 ftruncate(fileno(ambfp), (off_t)pos);
187 #endif
188 }
189 } else if ((ambfp = fopen(ambfile, "w+")) != NULL) {
190 initambfile(1); /* else create new file */
191 } else {
192 sprintf(errmsg, "cannot open ambient file \"%s\"", ambfile);
193 error(SYSTEM, errmsg);
194 }
195 nunflshed++; /* lie */
196 ambsync();
197 }
198
199
200 extern void
201 ambdone(void) /* close ambient file and free memory */
202 {
203 if (ambfp != NULL) { /* close ambient file */
204 ambsync();
205 fclose(ambfp);
206 ambfp = NULL;
207 if (ambinp != NULL) {
208 fclose(ambinp);
209 ambinp = NULL;
210 }
211 lastpos = -1;
212 }
213 /* free ambient tree */
214 unloadatree(&atrunk, free);
215 /* reset state variables */
216 avsum = 0.;
217 navsum = 0;
218 nambvals = 0;
219 nambshare = 0;
220 ambclock = 0;
221 lastsort = 0;
222 sortintvl = SORT_INTVL;
223 }
224
225
226 extern void
227 ambnotify( /* record new modifier */
228 OBJECT obj
229 )
230 {
231 static int hitlimit = 0;
232 register OBJREC *o;
233 register char **amblp;
234
235 if (obj == OVOID) { /* starting over */
236 ambset[0] = 0;
237 hitlimit = 0;
238 return;
239 }
240 o = objptr(obj);
241 if (hitlimit || !ismodifier(o->otype))
242 return;
243 for (amblp = amblist; *amblp != NULL; amblp++)
244 if (!strcmp(o->oname, *amblp)) {
245 if (ambset[0] >= MAXASET) {
246 error(WARNING, "too many modifiers in ambient list");
247 hitlimit++;
248 return; /* should this be fatal? */
249 }
250 insertelem(ambset, obj);
251 return;
252 }
253 }
254
255
256 extern void
257 multambient( /* compute ambient component & multiply by coef. */
258 COLOR aval,
259 register RAY *r,
260 FVECT nrm
261 )
262 {
263 static int rdepth = 0; /* ambient recursion */
264 COLOR acol;
265 double d, l;
266
267 if (ambdiv <= 0) /* no ambient calculation */
268 goto dumbamb;
269 /* check number of bounces */
270 if (rdepth >= ambounce)
271 goto dumbamb;
272 /* check ambient list */
273 if (ambincl != -1 && r->ro != NULL &&
274 ambincl != inset(ambset, r->ro->omod))
275 goto dumbamb;
276
277 if (ambacc <= FTINY) { /* no ambient storage */
278 rdepth++;
279 d = doambient(acol, r, aval, intens(aval)*r->rweight,
280 NULL, NULL);
281 rdepth--;
282 if (d <= FTINY)
283 goto dumbamb;
284 multcolor(aval, acol);
285 return;
286 }
287
288 if (tracktime) /* sort to minimize thrashing */
289 sortambvals(0);
290 /* get ambient value */
291 setcolor(acol, 0.0, 0.0, 0.0);
292 d = sumambient(acol, r, nrm, rdepth,
293 &atrunk, thescene.cuorg, thescene.cusize);
294 if (d > FTINY) {
295 scalecolor(acol, 1.0/d);
296 multcolor(aval, acol);
297 return;
298 }
299 rdepth++; /* need to cache new value */
300 d = makeambient(acol, r, aval, nrm, rdepth-1);
301 rdepth--;
302 if (d > FTINY) {
303 multcolor(aval, acol); /* got new value */
304 return;
305 }
306 dumbamb: /* return global value */
307 if ((ambvwt <= 0) | (navsum == 0)) {
308 multcolor(aval, ambval);
309 return;
310 }
311 l = bright(ambval); /* average in computations */
312 if (l > FTINY) {
313 d = (log(l)*(double)ambvwt + avsum) /
314 (double)(ambvwt + navsum);
315 d = exp(d) / l;
316 scalecolor(aval, d);
317 multcolor(aval, ambval); /* apply color of ambval */
318 } else {
319 d = exp( avsum / (double)navsum );
320 scalecolor(aval, d); /* neutral color */
321 }
322 }
323
324
325 extern double
326 sumambient( /* get interpolated ambient value */
327 COLOR acol,
328 register RAY *r,
329 FVECT rn,
330 int al,
331 AMBTREE *at,
332 FVECT c0,
333 double s
334 )
335 {
336 double d, e1, e2, wt, wsum;
337 COLOR ct;
338 FVECT ck0;
339 int i;
340 register int j;
341 register AMBVAL *av;
342
343 wsum = 0.0;
344 /* do this node */
345 for (av = at->alist; av != NULL; av = av->next) {
346 double rn_dot = -2.0;
347 if (tracktime)
348 av->latick = ambclock;
349 /*
350 * Ambient level test.
351 */
352 if (av->lvl > al) /* list sorted, so this works */
353 break;
354 if (av->weight < r->rweight-FTINY)
355 continue;
356 /*
357 * Ambient radius test.
358 */
359 d = av->pos[0] - r->rop[0];
360 e1 = d * d;
361 d = av->pos[1] - r->rop[1];
362 e1 += d * d;
363 d = av->pos[2] - r->rop[2];
364 e1 += d * d;
365 e1 /= av->rad * av->rad;
366 if (e1 > ambacc*ambacc*1.21)
367 continue;
368 /*
369 * Direction test using closest normal.
370 */
371 d = DOT(av->dir, r->ron);
372 if (rn != r->ron) {
373 rn_dot = DOT(av->dir, rn);
374 if (rn_dot > 1.0-FTINY)
375 rn_dot = 1.0-FTINY;
376 if (rn_dot >= d-FTINY) {
377 d = rn_dot;
378 rn_dot = -2.0;
379 }
380 }
381 e2 = (1.0 - d) * r->rweight;
382 if (e2 < 0.0) e2 = 0.0;
383 if (e1 + e2 > ambacc*ambacc*1.21)
384 continue;
385 /*
386 * Ray behind test.
387 */
388 d = 0.0;
389 for (j = 0; j < 3; j++)
390 d += (r->rop[j] - av->pos[j]) *
391 (av->dir[j] + r->ron[j]);
392 if (d*0.5 < -minarad*ambacc-.001)
393 continue;
394 /*
395 * Jittering final test reduces image artifacts.
396 */
397 e1 = sqrt(e1);
398 e2 = sqrt(e2);
399 wt = e1 + e2;
400 if (wt > ambacc*(.9+.2*urand(9015+samplendx)))
401 continue;
402 /*
403 * Recompute directional error using perturbed normal
404 */
405 if (rn_dot > 0.0) {
406 e2 = sqrt((1.0 - rn_dot)*r->rweight);
407 wt = e1 + e2;
408 }
409 if (wt <= 1e-3)
410 wt = 1e3;
411 else
412 wt = 1.0 / wt;
413 wsum += wt;
414 extambient(ct, av, r->rop, rn);
415 scalecolor(ct, wt);
416 addcolor(acol, ct);
417 }
418 if (at->kid == NULL)
419 return(wsum);
420 /* do children */
421 s *= 0.5;
422 for (i = 0; i < 8; i++) {
423 for (j = 0; j < 3; j++) {
424 ck0[j] = c0[j];
425 if (1<<j & i)
426 ck0[j] += s;
427 if (r->rop[j] < ck0[j] - OCTSCALE*s)
428 break;
429 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
430 break;
431 }
432 if (j == 3)
433 wsum += sumambient(acol, r, rn, al, at->kid+i, ck0, s);
434 }
435 return(wsum);
436 }
437
438
439 extern double
440 makeambient( /* make a new ambient value */
441 COLOR acol,
442 RAY *r,
443 COLOR ac,
444 FVECT rn,
445 int al
446 )
447 {
448 AMBVAL amb;
449 double coef;
450 FVECT gp, gd;
451 /* compute weight */
452 amb.weight = pow(AVGREFL, (double)al);
453 coef = intens(ac)*r->rweight;
454 if (coef < 0.1*amb.weight) /* heuristic */
455 amb.weight = coef;
456 /* compute ambient */
457 amb.rad = doambient(acol, r, ac, amb.weight, gp, gd);
458 if (amb.rad <= FTINY)
459 return(0.0);
460 /* store it */
461 VCOPY(amb.pos, r->rop);
462 VCOPY(amb.dir, r->ron);
463 amb.lvl = al;
464 copycolor(amb.val, acol);
465 VCOPY(amb.gpos, gp);
466 VCOPY(amb.gdir, gd);
467 /* insert into tree */
468 avsave(&amb); /* and save to file */
469 if (rn != r->ron)
470 extambient(acol, &amb, r->rop, rn); /* texture */
471 return(amb.rad);
472 }
473
474
475 extern void
476 extambient( /* extrapolate value at pv, nv */
477 COLOR cr,
478 register AMBVAL *ap,
479 FVECT pv,
480 FVECT nv
481 )
482 {
483 FVECT v1;
484 register int i;
485 double d;
486
487 d = 1.0; /* zeroeth order */
488 /* gradient due to translation */
489 for (i = 0; i < 3; i++)
490 d += ap->gpos[i]*(pv[i]-ap->pos[i]);
491 /* gradient due to rotation */
492 VCROSS(v1, ap->dir, nv);
493 d += DOT(ap->gdir, v1);
494 if (d <= 0.0) {
495 setcolor(cr, 0.0, 0.0, 0.0);
496 return;
497 }
498 copycolor(cr, ap->val);
499 scalecolor(cr, d);
500 }
501
502
503 static void
504 initambfile( /* initialize ambient file */
505 int creat
506 )
507 {
508 extern char *progname, *octname;
509 static char *mybuf = NULL;
510
511 #ifdef F_SETLKW
512 aflock(creat ? F_WRLCK : F_RDLCK);
513 #endif
514 SET_FILE_BINARY(ambfp);
515 if (mybuf == NULL)
516 mybuf = (char *)bmalloc(BUFSIZ+8);
517 setbuf(ambfp, mybuf);
518 if (creat) { /* new file */
519 newheader("RADIANCE", ambfp);
520 fprintf(ambfp, "%s -av %g %g %g -aw %d -ab %d -aa %g ",
521 progname, colval(ambval,RED),
522 colval(ambval,GRN), colval(ambval,BLU),
523 ambvwt, ambounce, ambacc);
524 fprintf(ambfp, "-ad %d -as %d -ar %d ",
525 ambdiv, ambssamp, ambres);
526 if (octname != NULL)
527 printargs(1, &octname, ambfp);
528 else
529 fputc('\n', ambfp);
530 fprintf(ambfp, "SOFTWARE= %s\n", VersionID);
531 fputnow(ambfp);
532 fputformat(AMBFMT, ambfp);
533 putc('\n', ambfp);
534 putambmagic(ambfp);
535 } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp))
536 error(USER, "bad ambient file");
537 }
538
539
540 static void
541 avsave( /* insert and save an ambient value */
542 AMBVAL *av
543 )
544 {
545 avinsert(avstore(av));
546 if (ambfp == NULL)
547 return;
548 if (writambval(av, ambfp) < 0)
549 goto writerr;
550 if (++nunflshed >= AMBFLUSH)
551 if (ambsync() == EOF)
552 goto writerr;
553 return;
554 writerr:
555 error(SYSTEM, "error writing to ambient file");
556 }
557
558
559 static AMBVAL *
560 avstore( /* allocate memory and store aval */
561 register AMBVAL *aval
562 )
563 {
564 register AMBVAL *av;
565 double d;
566
567 if ((av = newambval()) == NULL)
568 error(SYSTEM, "out of memory in avstore");
569 *av = *aval;
570 av->latick = ambclock;
571 av->next = NULL;
572 nambvals++;
573 d = bright(av->val);
574 if (d > FTINY) { /* add to log sum for averaging */
575 avsum += log(d);
576 navsum++;
577 }
578 return(av);
579 }
580
581
582 #define ATALLOCSZ 512 /* #/8 trees to allocate at once */
583
584 static AMBTREE *atfreelist = NULL; /* free ambient tree structures */
585
586
587 static AMBTREE *
588 newambtree(void) /* allocate 8 ambient tree structs */
589 {
590 register AMBTREE *atp, *upperlim;
591
592 if (atfreelist == NULL) { /* get more nodes */
593 atfreelist = (AMBTREE *)malloc(ATALLOCSZ*8*sizeof(AMBTREE));
594 if (atfreelist == NULL)
595 return(NULL);
596 /* link new free list */
597 upperlim = atfreelist + 8*(ATALLOCSZ-1);
598 for (atp = atfreelist; atp < upperlim; atp += 8)
599 atp->kid = atp + 8;
600 atp->kid = NULL;
601 }
602 atp = atfreelist;
603 atfreelist = atp->kid;
604 memset((char *)atp, '\0', 8*sizeof(AMBTREE));
605 return(atp);
606 }
607
608
609 static void
610 freeambtree( /* free 8 ambient tree structs */
611 AMBTREE *atp
612 )
613 {
614 atp->kid = atfreelist;
615 atfreelist = atp;
616 }
617
618
619 static void
620 avinsert( /* insert ambient value in our tree */
621 void *av
622 )
623 {
624 register AMBTREE *at;
625 register AMBVAL *ap;
626 AMBVAL avh;
627 FVECT ck0;
628 double s;
629 int branch;
630 register int i;
631
632 if (((AMBVAL*)av)->rad <= FTINY)
633 error(CONSISTENCY, "zero ambient radius in avinsert");
634 at = &atrunk;
635 VCOPY(ck0, thescene.cuorg);
636 s = thescene.cusize;
637 while (s*(OCTSCALE/2) > ((AMBVAL*)av)->rad*ambacc) {
638 if (at->kid == NULL)
639 if ((at->kid = newambtree()) == NULL)
640 error(SYSTEM, "out of memory in avinsert");
641 s *= 0.5;
642 branch = 0;
643 for (i = 0; i < 3; i++)
644 if (((AMBVAL*)av)->pos[i] > ck0[i] + s) {
645 ck0[i] += s;
646 branch |= 1 << i;
647 }
648 at = at->kid + branch;
649 }
650 avh.next = at->alist; /* order by increasing level */
651 for (ap = &avh; ap->next != NULL; ap = ap->next)
652 if (ap->next->lvl >= ((AMBVAL*)av)->lvl)
653 break;
654 ((AMBVAL*)av)->next = ap->next;
655 ap->next = (AMBVAL*)av;
656 at->alist = avh.next;
657 }
658
659
660 static void
661 unloadatree( /* unload an ambient value tree */
662 register AMBTREE *at,
663 unloadtf_t *f
664 )
665 {
666 register AMBVAL *av;
667 register int i;
668 /* transfer values at this node */
669 for (av = at->alist; av != NULL; av = at->alist) {
670 at->alist = av->next;
671 (*f)(av);
672 }
673 if (at->kid == NULL)
674 return;
675 for (i = 0; i < 8; i++) /* transfer and free children */
676 unloadatree(at->kid+i, f);
677 freeambtree(at->kid);
678 at->kid = NULL;
679 }
680
681
682 static struct avl {
683 AMBVAL *p;
684 unsigned long t;
685 } *avlist1; /* ambient value list with ticks */
686 static AMBVAL **avlist2; /* memory positions for sorting */
687 static int i_avlist; /* index for lists */
688
689 static int alatcmp(const void *av1, const void *av2);
690
691 static void
692 av2list(
693 void *av
694 )
695 {
696 #ifdef DEBUG
697 if (i_avlist >= nambvals)
698 error(CONSISTENCY, "too many ambient values in av2list1");
699 #endif
700 avlist1[i_avlist].p = avlist2[i_avlist] = (AMBVAL*)av;
701 avlist1[i_avlist++].t = ((AMBVAL*)av)->latick;
702 }
703
704
705 static int
706 alatcmp( /* compare ambient values for MRA */
707 const void *av1,
708 const void *av2
709 )
710 {
711 register long lc = ((struct avl *)av2)->t - ((struct avl *)av1)->t;
712 return(lc<0 ? -1 : lc>0 ? 1 : 0);
713 }
714
715
716 /* GW NOTE 2002/10/3:
717 * I used to compare AMBVAL pointers, but found that this was the
718 * cause of a serious consistency error with gcc, since the optimizer
719 * uses some dangerous trick in pointer subtraction that
720 * assumes pointers differ by exact struct size increments.
721 */
722 static int
723 aposcmp( /* compare ambient value positions */
724 const void *avp1,
725 const void *avp2
726 )
727 {
728 register long diff = *(char * const *)avp1 - *(char * const *)avp2;
729 if (diff < 0)
730 return(-1);
731 return(diff > 0);
732 }
733
734 #if 1
735 static int
736 avlmemi( /* find list position from address */
737 AMBVAL *avaddr
738 )
739 {
740 register AMBVAL **avlpp;
741
742 avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2,
743 nambvals, sizeof(AMBVAL *), aposcmp);
744 if (avlpp == NULL)
745 error(CONSISTENCY, "address not found in avlmemi");
746 return(avlpp - avlist2);
747 }
748 #else
749 #define avlmemi(avaddr) ((AMBVAL **)bsearch((char *)&avaddr,(char *)avlist2, \
750 nambvals,sizeof(AMBVAL *),aposcmp) - avlist2)
751 #endif
752
753
754 static void
755 sortambvals( /* resort ambient values */
756 int always
757 )
758 {
759 AMBTREE oldatrunk;
760 AMBVAL tav, *tap, *pnext;
761 register int i, j;
762 /* see if it's time yet */
763 if (!always && (ambclock++ < lastsort+sortintvl ||
764 nambvals < SORT_THRESH))
765 return;
766 /*
767 * The idea here is to minimize memory thrashing
768 * in VM systems by improving reference locality.
769 * We do this by periodically sorting our stored ambient
770 * values in memory in order of most recently to least
771 * recently accessed. This ordering was chosen so that new
772 * ambient values (which tend to be less important) go into
773 * higher memory with the infrequently accessed values.
774 * Since we expect our values to need sorting less
775 * frequently as the process continues, we double our
776 * waiting interval after each call.
777 * This routine is also called by setambacc() with
778 * the "always" parameter set to 1 so that the ambient
779 * tree will be rebuilt with the new accuracy parameter.
780 */
781 if (tracktime) { /* allocate pointer arrays to sort */
782 avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *));
783 avlist1 = (struct avl *)malloc(nambvals*sizeof(struct avl));
784 } else {
785 avlist2 = NULL;
786 avlist1 = NULL;
787 }
788 if (avlist1 == NULL) { /* no time tracking -- rebuild tree? */
789 if (avlist2 != NULL)
790 free((void *)avlist2);
791 if (always) { /* rebuild without sorting */
792 oldatrunk = atrunk;
793 atrunk.alist = NULL;
794 atrunk.kid = NULL;
795 unloadatree(&oldatrunk, avinsert);
796 }
797 } else { /* sort memory by last access time */
798 /*
799 * Sorting memory is tricky because it isn't contiguous.
800 * We have to sort an array of pointers by MRA and also
801 * by memory position. We then copy values in "loops"
802 * to minimize memory hits. Nevertheless, we will visit
803 * everyone at least twice, and this is an expensive process
804 * when we're thrashing, which is when we need to do it.
805 */
806 #ifdef DEBUG
807 sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...",
808 nambvals, ambclock);
809 eputs(errmsg);
810 #endif
811 i_avlist = 0;
812 unloadatree(&atrunk, av2list); /* empty current tree */
813 #ifdef DEBUG
814 if (i_avlist < nambvals)
815 error(CONSISTENCY, "missing ambient values in sortambvals");
816 #endif
817 qsort((char *)avlist1, nambvals, sizeof(struct avl), alatcmp);
818 qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), aposcmp);
819 for (i = 0; i < nambvals; i++) {
820 if (avlist1[i].p == NULL)
821 continue;
822 tap = avlist2[i];
823 tav = *tap;
824 for (j = i; (pnext = avlist1[j].p) != tap;
825 j = avlmemi(pnext)) {
826 *(avlist2[j]) = *pnext;
827 avinsert(avlist2[j]);
828 avlist1[j].p = NULL;
829 }
830 *(avlist2[j]) = tav;
831 avinsert(avlist2[j]);
832 avlist1[j].p = NULL;
833 }
834 free((void *)avlist1);
835 free((void *)avlist2);
836 /* compute new sort interval */
837 sortintvl = ambclock - lastsort;
838 if (sortintvl >= MAX_SORT_INTVL/2)
839 sortintvl = MAX_SORT_INTVL;
840 else
841 sortintvl <<= 1; /* wait twice as long next */
842 #ifdef DEBUG
843 eputs("done\n");
844 #endif
845 }
846 if (ambclock >= MAXACLOCK)
847 ambclock = MAXACLOCK/2;
848 lastsort = ambclock;
849 }
850
851
852 #ifdef F_SETLKW
853
854 static void
855 aflock( /* lock/unlock ambient file */
856 int typ
857 )
858 {
859 static struct flock fls; /* static so initialized to zeroes */
860
861 fls.l_type = typ;
862 if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0)
863 error(SYSTEM, "cannot (un)lock ambient file");
864 }
865
866
867 extern int
868 ambsync(void) /* synchronize ambient file */
869 {
870 long flen;
871 AMBVAL avs;
872 register int n;
873
874 if (nunflshed == 0)
875 return(0);
876 if (lastpos < 0) /* initializing (locked in initambfile) */
877 goto syncend;
878 /* gain exclusive access */
879 aflock(F_WRLCK);
880 /* see if file has grown */
881 if ((flen = lseek(fileno(ambfp), (off_t)0, SEEK_END)) < 0)
882 goto seekerr;
883 if ( (n = flen - lastpos) ) { /* file has grown */
884 if (ambinp == NULL) { /* use duplicate filedes */
885 ambinp = fdopen(dup(fileno(ambfp)), "r");
886 if (ambinp == NULL)
887 error(SYSTEM, "fdopen failed in ambsync");
888 }
889 if (fseek(ambinp, lastpos, 0) < 0)
890 goto seekerr;
891 while (n >= AMBVALSIZ) { /* load contributed values */
892 if (!readambval(&avs, ambinp)) {
893 sprintf(errmsg,
894 "ambient file \"%s\" corrupted near character %ld",
895 ambfile, flen - n);
896 error(WARNING, errmsg);
897 break;
898 }
899 avinsert(avstore(&avs));
900 n -= AMBVALSIZ;
901 }
902 /*** seek always as safety measure
903 if (n) ***/ /* alignment */
904 if (lseek(fileno(ambfp), (off_t)(flen-n), SEEK_SET) < 0)
905 goto seekerr;
906 }
907 #ifdef DEBUG
908 if (ambfp->_ptr - ambfp->_base != nunflshed*AMBVALSIZ) {
909 sprintf(errmsg, "ambient file buffer at %d rather than %d",
910 ambfp->_ptr - ambfp->_base,
911 nunflshed*AMBVALSIZ);
912 error(CONSISTENCY, errmsg);
913 }
914 #endif
915 syncend:
916 n = fflush(ambfp); /* calls write() at last */
917 if ((lastpos = lseek(fileno(ambfp), (off_t)0, SEEK_CUR)) < 0)
918 goto seekerr;
919 aflock(F_UNLCK); /* release file */
920 nunflshed = 0;
921 return(n);
922 seekerr:
923 error(SYSTEM, "seek failed in ambsync");
924 return -1; /* pro forma return */
925 }
926
927 #else
928
929 extern int
930 ambsync(void) /* flush ambient file */
931 {
932 if (nunflshed == 0)
933 return(0);
934 nunflshed = 0;
935 return(fflush(ambfp));
936 }
937
938 #endif
