--- ray/src/rt/ambient.c 2024/01/31 04:03:03 2.122 +++ ray/src/rt/ambient.c 2024/04/05 01:10:26 2.123 @@ -1,4 +1,4 @@ -static const char RCSid[] = "$Id: ambient.c,v 2.122 2024/01/31 04:03:03 greg Exp $"; +static const char RCSid[] = "$Id: ambient.c,v 2.123 2024/04/05 01:10:26 greg Exp $"; /* * ambient.c - routines dealing with ambient (inter-reflected) component. * @@ -269,15 +269,17 @@ multambient( /* compute ambient component & multiply ambincl != inset(ambset, r->ro->omod)) goto dumbamb; - if (ambacc <= FTINY) { /* no ambient storage */ - FVECT uvd[2]; + if (ambacc <= FTINY) { /* no ambient storage? */ + double rdot = DOT(nrm,r->ron); + int sgn = 1 - 2*(rdot < 0); float dgrad[2], *dgp = NULL; + FVECT uvd[2]; - if (nrm != r->ron && DOT(nrm,r->ron) < 0.9999) + if (sgn*rdot < 0.9999) dgp = dgrad; /* compute rotational grad. */ copyscolor(acol, aval); rdepth++; - ok = doambient(acol, r, r->rweight, + ok = doambient(acol, r, r->rweight*sgn, uvd, NULL, NULL, dgp, NULL); rdepth--; if (!ok) @@ -287,7 +289,7 @@ multambient( /* compute ambient component & multiply VCROSS(v1, r->ron, nrm); d = 1.0; for (i = 3; i--; ) - d += v1[i] * (dgp[0]*uvd[0][i] + dgp[1]*uvd[1][i]); + d += sgn*v1[i] * (dgp[0]*uvd[0][i] + dgp[1]*uvd[1][i]); if (d >= 0.05) scalescolor(acol, d); } @@ -404,6 +406,7 @@ sumambient( /* get interpolated ambient value */ ) { /* initial limit is 10 degrees plus ambacc radians */ const double minangle = 10.0 * PI/180.; + const int sgn = 1 - 2*(DOT(r->ron,rn) < 0); double maxangle = minangle + ambacc; double wsum = 0.0; FVECT ck0; @@ -448,7 +451,7 @@ sumambient( /* get interpolated ambient value */ * Direction test using unperturbed normal */ decodedir(uvw[2], av->ndir); - d = DOT(uvw[2], r->ron); + d = sgn * DOT(uvw[2], r->ron); if (d <= 0.0) /* >= 90 degrees */ continue; delta_r2 = 2.0 - 2.0*d; /* approx. radians^2 */ @@ -504,6 +507,7 @@ makeambient( /* make a new ambient value for storage int al ) { + int sgn = 1 - 2*(DOT(r->ron,rn) < 0); AMBVAL amb; FVECT uvw[3]; int i; @@ -515,23 +519,23 @@ makeambient( /* make a new ambient value for storage amb.weight = 1.25*r->rweight; setscolor(acol, AVGREFL, AVGREFL, AVGREFL); /* compute ambient */ - i = doambient(acol, r, amb.weight, + i = doambient(acol, r, amb.weight*sgn, uvw, amb.rad, amb.gpos, amb.gdir, &amb.corral); scalescolor(acol, 1./AVGREFL); /* undo assumed reflectance */ if (i <= 0 || amb.rad[0] <= FTINY) /* no Hessian or zero radius */ return(i); + uvw[2][0] = sgn*r->ron[0]; /* orient unperturbed normal */ + uvw[2][1] = sgn*r->ron[1]; + uvw[2][2] = sgn*r->ron[2]; /* store value */ VCOPY(amb.pos, r->rop); - amb.ndir = encodedir(r->ron); + amb.ndir = encodedir(uvw[2]); amb.udir = encodedir(uvw[0]); amb.lvl = al; copyscolor(amb.val, acol); - /* insert into tree */ - avsave(&amb); /* and save to file */ - if (rn != r->ron) { /* texture */ - VCOPY(uvw[2], r->ron); + avsave(&amb); /* insert and save to file */ + if (DOT(uvw[2],rn) < 0.9999) /* texture? */ extambient(acol, &amb, r->rop, rn, uvw); - } return(1); }
