root/radiance/ray/src/rt/ambient.c
Revision: 2.91
Committed: Thu Jun 19 16:26:55 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.90: +2 -2 lines
2 static const char RCSid[] = "$Id: ambient.c,v 2.90 2014/06/06 00:57:46 greg Exp $";
5 * ambient.c - routines dealing with ambient (inter-reflected) component.
6 *
7 * Declarations of external symbols in ambient.h
8 */
9
10 #include "copyright.h"
11
12 #include <string.h>
13
14 #include "platform.h"
15 #include "ray.h"
16 #include "otypes.h"
17 #include "resolu.h"
18 #include "ambient.h"
19 #include "random.h"
20
21 #ifndef OCTSCALE
22 #define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */
23 #endif
24
25 extern char *shm_boundary; /* memory sharing boundary */
26
27 #ifndef MAXASET
28 #define MAXASET 4095 /* maximum number of elements in ambient set */
29 #endif
30 OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
31
32 double maxarad; /* maximum ambient radius */
33 double minarad; /* minimum ambient radius */
34
35 static AMBTREE atrunk; /* our ambient trunk node */
36
37 static FILE *ambfp = NULL; /* ambient file pointer */
38 static int nunflshed = 0; /* number of unflushed ambient values */
39
40 #ifndef SORT_THRESH
41 #ifdef SMLMEM
42 #define SORT_THRESH ((16L<<20)/sizeof(AMBVAL))
43 #else
44 #define SORT_THRESH ((64L<<20)/sizeof(AMBVAL))
45 #endif
46 #endif
47 #ifndef SORT_INTVL
48 #define SORT_INTVL (SORT_THRESH<<1)
49 #endif
50 #ifndef MAX_SORT_INTVL
51 #define MAX_SORT_INTVL (SORT_INTVL<<6)
52 #endif
53
54
55 static double avsum = 0.; /* computed ambient value sum (log) */
56 static unsigned int navsum = 0; /* number of values in avsum */
57 static unsigned int nambvals = 0; /* total number of indirect values */
58 static unsigned int nambshare = 0; /* number of values from file */
59 static unsigned long ambclock = 0; /* ambient access clock */
60 static unsigned long lastsort = 0; /* time of last value sort */
61 static long sortintvl = SORT_INTVL; /* time until next sort */
62 static FILE *ambinp = NULL; /* auxiliary file for input */
63 static long lastpos = -1; /* last flush position */
64
65 #define MAXACLOCK (1L<<30) /* clock turnover value */
66 /*
67 * Track access times unless we are sharing ambient values
68 * through memory on a multiprocessor, when we want to avoid
69 * claiming our own memory (copy on write). Go ahead anyway
70 * if more than two thirds of our values are unshared.
71 * Compile with -Dtracktime=0 to turn this code off.
72 */
73 #ifndef tracktime
74 #define tracktime (shm_boundary == NULL || nambvals > 3*nambshare)
75 #endif
76
77 #define AMBFLUSH (BUFSIZ/AMBVALSIZ)
78
79 #define newambval() (AMBVAL *)malloc(sizeof(AMBVAL))
80 #define freeav(av) free((void *)av);
81
82 static void initambfile(int creat);
83 static void avsave(AMBVAL *av);
84 static AMBVAL *avstore(AMBVAL *aval);
85 static AMBTREE *newambtree(void);
86 static void freeambtree(AMBTREE *atp);
87
88 typedef void unloadtf_t(AMBVAL *);
89 static unloadtf_t avinsert;
90 static unloadtf_t av2list;
91 static unloadtf_t avfree;
92 static void unloadatree(AMBTREE *at, unloadtf_t *f);
93
94 static int aposcmp(const void *avp1, const void *avp2);
95 static int avlmemi(AMBVAL *avaddr);
96 static void sortambvals(int always);
97
98 #ifdef F_SETLKW
99 static void aflock(int typ);
100 #endif
101
102
103 void
104 setambres( /* set ambient resolution */
105 int ar
106 )
107 {
108 ambres = ar < 0 ? 0 : ar; /* may be done already */
109 /* set min & max radii */
110 if (ar <= 0) {
111 minarad = 0;
112 maxarad = thescene.cusize*0.2;
113 } else {
114 minarad = thescene.cusize / ar;
115 maxarad = 64.0 * minarad; /* heuristic */
116 if (maxarad > thescene.cusize*0.2)
117 maxarad = thescene.cusize*0.2;
118 }
119 if (minarad <= FTINY)
120 minarad = 10.0*FTINY;
121 if (maxarad <= minarad)
122 maxarad = 64.0 * minarad;
123 }
124
125
126 void
127 setambacc( /* set ambient accuracy */
128 double newa
129 )
130 {
131 static double olda; /* remember previous setting here */
132
133 newa *= (newa > 0);
134 if (fabs(newa - olda) >= .05*(newa + olda)) {
135 ambacc = newa;
136 if (nambvals > 0)
137 sortambvals(1); /* rebuild tree */
138 }
139 }
140
141
142 void
143 setambient(void) /* initialize calculation */
144 {
145 int readonly = 0;
146 long flen;
147 AMBVAL amb;
148 /* make sure we're fresh */
149 ambdone();
150 /* init ambient limits */
151 setambres(ambres);
152 setambacc(ambacc);
153 if (ambfile == NULL || !ambfile[0])
154 return;
155 if (ambacc <= FTINY) {
156 sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened",
157 ambfile);
158 error(WARNING, errmsg);
159 return;
160 }
161 /* open ambient file */
162 if ((ambfp = fopen(ambfile, "r+")) == NULL)
163 readonly = (ambfp = fopen(ambfile, "r")) != NULL;
164 if (ambfp != NULL) {
165 initambfile(0); /* file exists */
166 lastpos = ftell(ambfp);
167 while (readambval(&amb, ambfp))
168 avstore(&amb);
169 nambshare = nambvals; /* share loaded values */
170 if (readonly) {
171 sprintf(errmsg,
172 "loaded %u values from read-only ambient file",
173 nambvals);
174 error(WARNING, errmsg);
175 fclose(ambfp); /* close file so no writes */
176 ambfp = NULL;
177 return; /* avoid ambsync() */
178 }
179 /* align file pointer */
180 lastpos += (long)nambvals*AMBVALSIZ;
181 flen = lseek(fileno(ambfp), (off_t)0, SEEK_END);
182 if (flen != lastpos) {
183 sprintf(errmsg,
184 "ignoring last %ld values in ambient file (corrupted)",
185 (flen - lastpos)/AMBVALSIZ);
186 error(WARNING, errmsg);
187 fseek(ambfp, lastpos, SEEK_SET);
188 #ifndef _WIN32 /* XXX we need a replacement for that one */
189 ftruncate(fileno(ambfp), (off_t)lastpos);
190 #endif
191 }
192 } else if ((ambfp = fopen(ambfile, "w+")) != NULL) {
193 initambfile(1); /* else create new file */
194 fflush(ambfp);
195 lastpos = ftell(ambfp);
196 } else {
197 sprintf(errmsg, "cannot open ambient file \"%s\"", ambfile);
198 error(SYSTEM, errmsg);
199 }
200 #ifdef getc_unlocked
201 flockfile(ambfp); /* application-level lock */
202 #endif
203 #ifdef F_SETLKW
204 aflock(F_UNLCK); /* release file */
205 #endif
206 }
207
208
209 void
210 ambdone(void) /* close ambient file and free memory */
211 {
212 if (ambfp != NULL) { /* close ambient file */
213 ambsync();
214 fclose(ambfp);
215 ambfp = NULL;
216 if (ambinp != NULL) {
217 fclose(ambinp);
218 ambinp = NULL;
219 }
220 lastpos = -1;
221 }
222 /* free ambient tree */
223 unloadatree(&atrunk, &avfree);
224 /* reset state variables */
225 avsum = 0.;
226 navsum = 0;
227 nambvals = 0;
228 nambshare = 0;
229 ambclock = 0;
230 lastsort = 0;
231 sortintvl = SORT_INTVL;
232 }
233
234
235 void
236 ambnotify( /* record new modifier */
237 OBJECT obj
238 )
239 {
240 static int hitlimit = 0;
241 OBJREC *o;
242 char **amblp;
243
244 if (obj == OVOID) { /* starting over */
245 ambset[0] = 0;
246 hitlimit = 0;
247 return;
248 }
249 o = objptr(obj);
250 if (hitlimit || !ismodifier(o->otype))
251 return;
252 for (amblp = amblist; *amblp != NULL; amblp++)
253 if (!strcmp(o->oname, *amblp)) {
254 if (ambset[0] >= MAXASET) {
255 error(WARNING, "too many modifiers in ambient list");
256 hitlimit++;
257 return; /* should this be fatal? */
258 }
259 insertelem(ambset, obj);
260 return;
261 }
262 }
263
264 /************ THE FOLLOWING ROUTINES DIFFER BETWEEN NEW & OLD ***************/
265
266 #ifndef OLDAMB
267
268 #define tfunc(lwr, x, upr) (((x)-(lwr))/((upr)-(lwr)))
269
270 static int plugaleak(RAY *r, AMBVAL *ap, FVECT anorm, double ang);
271 static double sumambient(COLOR acol, RAY *r, FVECT rn, int al,
272 AMBTREE *at, FVECT c0, double s);
273 static int makeambient(COLOR acol, RAY *r, FVECT rn, int al);
274 static void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv,
275 FVECT uvw[3]);
276
277 void
278 multambient( /* compute ambient component & multiply by coef. */
279 COLOR aval,
280 RAY *r,
281 FVECT nrm
282 )
283 {
284 static int rdepth = 0; /* ambient recursion */
285 COLOR acol;
286 int ok;
287 double d, l;
288
289 if (ambdiv <= 0) /* no ambient calculation */
290 goto dumbamb;
291 /* check number of bounces */
292 if (rdepth >= ambounce)
293 goto dumbamb;
294 /* check ambient list */
295 if (ambincl != -1 && r->ro != NULL &&
296 ambincl != inset(ambset, r->ro->omod))
297 goto dumbamb;
298
299 if (ambacc <= FTINY) { /* no ambient storage */
300 copycolor(acol, aval);
301 rdepth++;
302 ok = doambient(acol, r, r->rweight,
303 NULL, NULL, NULL, NULL, NULL);
304 rdepth--;
305 if (!ok)
306 goto dumbamb;
307 copycolor(aval, acol);
308 return;
309 }
310
311 if (tracktime) /* sort to minimize thrashing */
312 sortambvals(0);
313 /* interpolate ambient value */
314 setcolor(acol, 0.0, 0.0, 0.0);
315 d = sumambient(acol, r, nrm, rdepth,
316 &atrunk, thescene.cuorg, thescene.cusize);
317 if (d > FTINY) {
318 d = 1.0/d;
319 scalecolor(acol, d);
320 multcolor(aval, acol);
321 return;
322 }
323 rdepth++; /* need to cache new value */
324 ok = makeambient(acol, r, nrm, rdepth-1);
325 rdepth--;
326 if (ok) {
327 multcolor(aval, acol); /* computed new value */
328 return;
329 }
330 dumbamb: /* return global value */
331 if ((ambvwt <= 0) | (navsum == 0)) {
332 multcolor(aval, ambval);
333 return;
334 }
335 l = bright(ambval); /* average in computations */
336 if (l > FTINY) {
337 d = (log(l)*(double)ambvwt + avsum) /
338 (double)(ambvwt + navsum);
339 d = exp(d) / l;
340 scalecolor(aval, d);
341 multcolor(aval, ambval); /* apply color of ambval */
342 } else {
343 d = exp( avsum / (double)navsum );
344 scalecolor(aval, d); /* neutral color */
345 }
346 }
347
348
349 /* Plug a potential leak where ambient cache value is occluded */
350 static int
351 plugaleak(RAY *r, AMBVAL *ap, FVECT anorm, double ang)
352 {
353 const double cost70sq = 0.1169778; /* cos(70deg)^2 */
354 RAY rtst;
355 FVECT vdif;
356 double normdot, ndotd, nadotd;
357 double a, b, c, t[2];
358
359 ang += 2.*PI*(ang < 0); /* check direction flags */
360 if ( !(ap->corral>>(int)(ang*(16./PI)) & 1) )
361 return(0);
362 /*
363 * Generate test ray, targeting 20 degrees above sample point plane
364 * along surface normal from cache position. This should be high
365 * enough to miss local geometry we don't really care about.
366 */
367 VSUB(vdif, ap->pos, r->rop);
368 normdot = DOT(anorm, r->ron);
369 ndotd = DOT(vdif, r->ron);
370 nadotd = DOT(vdif, anorm);
371 a = normdot*normdot - cost70sq;
372 b = 2.0*(normdot*ndotd - nadotd*cost70sq);
373 c = ndotd*ndotd - DOT(vdif,vdif)*cost70sq;
374 if (quadratic(t, a, b, c) != 2)
375 return(1); /* should rarely happen */
376 if (t[1] <= FTINY)
377 return(0); /* should fail behind test */
378 rayorigin(&rtst, SHADOW, r, NULL);
379 VSUM(rtst.rdir, vdif, anorm, t[1]); /* further dist. > plane */
380 rtst.rmax = normalize(rtst.rdir); /* short ray test */
381 while (localhit(&rtst, &thescene)) { /* check for occluder */
382 if (rtst.ro->omod != OVOID &&
383 (rtst.clipset == NULL ||
384 !inset(rtst.clipset, rtst.ro->omod)))
385 return(1); /* plug light leak */
386 VCOPY(rtst.rorg, rtst.rop); /* skip invisible surface */
387 rtst.rmax -= rtst.rot;
388 rayclear(&rtst);
389 }
390 return(0); /* seems we're OK */
391 }
392
393
394 static double
395 sumambient( /* get interpolated ambient value */
396 COLOR acol,
397 RAY *r,
398 FVECT rn,
399 int al,
400 AMBTREE *at,
401 FVECT c0,
402 double s
403 )
404 { /* initial limit is 10 degrees plus ambacc radians */
405 const double minangle = 10.0 * PI/180.;
406 double maxangle = minangle + ambacc;
407 double wsum = 0.0;
408 FVECT ck0;
409 int i, j;
410 AMBVAL *av;
411
412 if (at->kid != NULL) { /* sum children first */
413 s *= 0.5;
414 for (i = 0; i < 8; i++) {
415 for (j = 0; j < 3; j++) {
416 ck0[j] = c0[j];
417 if (1<<j & i)
418 ck0[j] += s;
419 if (r->rop[j] < ck0[j] - OCTSCALE*s)
420 break;
421 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
422 break;
423 }
424 if (j == 3)
425 wsum += sumambient(acol, r, rn, al,
426 at->kid+i, ck0, s);
427 }
428 /* good enough? */
429 if (wsum >= 0.05 && s > minarad*10.0)
430 return(wsum);
431 }
432 /* adjust maximum angle */
433 if (at->alist != NULL && (at->alist->lvl <= al) & (r->rweight < 0.6))
434 maxangle = (maxangle - PI/2.)*pow(r->rweight,0.13) + PI/2.;
435 /* sum this node */
436 for (av = at->alist; av != NULL; av = av->next) {
437 double u, v, d, delta_r2, delta_t2;
438 COLOR ct;
439 FVECT uvw[3];
440 /* record access */
441 if (tracktime)
442 av->latick = ambclock;
443 /*
444 * Ambient level test
445 */
446 if (av->lvl > al || /* list sorted, so this works */
447 (av->lvl == al) & (av->weight < 0.9*r->rweight))
448 break;
449 /*
450 * Direction test using unperturbed normal
451 */
452 decodedir(uvw[2], av->ndir);
453 d = DOT(uvw[2], r->ron);
454 if (d <= 0.0) /* >= 90 degrees */
455 continue;
456 delta_r2 = 2.0 - 2.0*d; /* approx. radians^2 */
457 if (delta_r2 >= maxangle*maxangle)
458 continue;
459 /*
460 * Modified ray behind test
461 */
462 VSUB(ck0, r->rop, av->pos);
463 d = DOT(ck0, uvw[2]);
464 if (d < -minarad*ambacc-.001)
465 continue;
466 d /= av->rad[0];
467 delta_t2 = d*d;
468 if (delta_t2 >= ambacc*ambacc)
469 continue;
470 /*
471 * Elliptical radii test based on Hessian
472 */
473 decodedir(uvw[0], av->udir);
474 VCROSS(uvw[1], uvw[2], uvw[0]);
475 d = (u = DOT(ck0, uvw[0])) / av->rad[0];
476 delta_t2 += d*d;
477 d = (v = DOT(ck0, uvw[1])) / av->rad[1];
478 delta_t2 += d*d;
479 if (delta_t2 >= ambacc*ambacc)
480 continue;
481 /*
482 * Test for potential light leak
483 */
484 if (av->corral && plugaleak(r, av, uvw[2], atan2a(v,u)))
485 continue;
486 /*
487 * Extrapolate value and compute final weight (hat function)
488 */
489 extambient(ct, av, r->rop, rn, uvw);
490 d = tfunc(maxangle, sqrt(delta_r2), 0.0) *
491 tfunc(ambacc, sqrt(delta_t2), 0.0);
492 scalecolor(ct, d);
493 addcolor(acol, ct);
494 wsum += d;
495 }
496 return(wsum);
497 }
498
499
500 static int
501 makeambient( /* make a new ambient value for storage */
502 COLOR acol,
503 RAY *r,
504 FVECT rn,
505 int al
506 )
507 {
508 AMBVAL amb;
509 FVECT uvw[3];
510 int i;
511
512 amb.weight = 1.0; /* compute weight */
513 for (i = al; i-- > 0; )
514 amb.weight *= AVGREFL;
515 if (r->rweight < 0.1*amb.weight) /* heuristic override */
516 amb.weight = 1.25*r->rweight;
517 setcolor(acol, AVGREFL, AVGREFL, AVGREFL);
518 /* compute ambient */
519 i = doambient(acol, r, amb.weight,
520 uvw, amb.rad, amb.gpos, amb.gdir, &amb.corral);
521 scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */
522 if (i <= 0 || amb.rad[0] <= FTINY) /* no Hessian or zero radius */
523 return(i);
524 /* store value */
525 VCOPY(amb.pos, r->rop);
526 amb.ndir = encodedir(r->ron);
527 amb.udir = encodedir(uvw[0]);
528 amb.lvl = al;
529 copycolor(amb.val, acol);
530 /* insert into tree */
531 avsave(&amb); /* and save to file */
532 if (rn != r->ron) { /* texture */
533 VCOPY(uvw[2], r->ron);
534 extambient(acol, &amb, r->rop, rn, uvw);
535 }
536 return(1);
537 }
538
539
540 static void
541 extambient( /* extrapolate value at pv, nv */
542 COLOR cr,
543 AMBVAL *ap,
544 FVECT pv,
545 FVECT nv,
546 FVECT uvw[3]
547 )
548 {
549 static FVECT my_uvw[3];
550 FVECT v1;
551 int i;
552 double d = 1.0; /* zeroeth order */
553
554 if (uvw == NULL) { /* need local coordinates? */
555 decodedir(my_uvw[2], ap->ndir);
556 decodedir(my_uvw[0], ap->udir);
557 VCROSS(my_uvw[1], my_uvw[2], my_uvw[0]);
558 uvw = my_uvw;
559 }
560 for (i = 3; i--; ) /* gradient due to translation */
561 d += (pv[i] - ap->pos[i]) *
562 (ap->gpos[0]*uvw[0][i] + ap->gpos[1]*uvw[1][i]);
563
564 VCROSS(v1, uvw[2], nv); /* gradient due to rotation */
565 for (i = 3; i--; )
566 d += v1[i] * (ap->gdir[0]*uvw[0][i] + ap->gdir[1]*uvw[1][i]);
567
568 if (d <= 0.0) {
569 setcolor(cr, 0.0, 0.0, 0.0);
570 return;
571 }
572 copycolor(cr, ap->val);
573 scalecolor(cr, d);
574 }
575
576
577 static void
578 avinsert( /* insert ambient value in our tree */
579 AMBVAL *av
580 )
581 {
582 AMBTREE *at;
583 AMBVAL *ap;
584 AMBVAL avh;
585 FVECT ck0;
586 double s;
587 int branch;
588 int i;
589
590 if (av->rad[0] <= FTINY)
591 error(CONSISTENCY, "zero ambient radius in avinsert");
592 at = &atrunk;
593 VCOPY(ck0, thescene.cuorg);
594 s = thescene.cusize;
595 while (s*(OCTSCALE/2) > av->rad[1]*ambacc) {
596 if (at->kid == NULL)
597 if ((at->kid = newambtree()) == NULL)
598 error(SYSTEM, "out of memory in avinsert");
599 s *= 0.5;
600 branch = 0;
601 for (i = 0; i < 3; i++)
602 if (av->pos[i] > ck0[i] + s) {
603 ck0[i] += s;
604 branch |= 1 << i;
605 }
606 at = at->kid + branch;
607 }
608 avh.next = at->alist; /* order by increasing level */
609 for (ap = &avh; ap->next != NULL; ap = ap->next)
610 if ( ap->next->lvl > av->lvl ||
611 (ap->next->lvl == av->lvl) &
612 (ap->next->weight <= av->weight) )
613 break;
614 av->next = ap->next;
615 ap->next = (AMBVAL*)av;
616 at->alist = avh.next;
617 }
618
619
620 #else /* ! NEWAMB */
621
622 static double sumambient(COLOR acol, RAY *r, FVECT rn, int al,
623 AMBTREE *at, FVECT c0, double s);
624 static double makeambient(COLOR acol, RAY *r, FVECT rn, int al);
625 static void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv);
626
627
628 void
629 multambient( /* compute ambient component & multiply by coef. */
630 COLOR aval,
631 RAY *r,
632 FVECT nrm
633 )
634 {
635 static int rdepth = 0; /* ambient recursion */
636 COLOR acol;
637 double d, l;
638
639 if (ambdiv <= 0) /* no ambient calculation */
640 goto dumbamb;
641 /* check number of bounces */
642 if (rdepth >= ambounce)
643 goto dumbamb;
644 /* check ambient list */
645 if (ambincl != -1 && r->ro != NULL &&
646 ambincl != inset(ambset, r->ro->omod))
647 goto dumbamb;
648
649 if (ambacc <= FTINY) { /* no ambient storage */
650 copycolor(acol, aval);
651 rdepth++;
652 d = doambient(acol, r, r->rweight, NULL, NULL);
653 rdepth--;
654 if (d <= FTINY)
655 goto dumbamb;
656 copycolor(aval, acol);
657 return;
658 }
659
660 if (tracktime) /* sort to minimize thrashing */
661 sortambvals(0);
662 /* interpolate ambient value */
663 setcolor(acol, 0.0, 0.0, 0.0);
664 d = sumambient(acol, r, nrm, rdepth,
665 &atrunk, thescene.cuorg, thescene.cusize);
666 if (d > FTINY) {
667 d = 1.0/d;
668 scalecolor(acol, d);
669 multcolor(aval, acol);
670 return;
671 }
672 rdepth++; /* need to cache new value */
673 d = makeambient(acol, r, nrm, rdepth-1);
674 rdepth--;
675 if (d > FTINY) {
676 multcolor(aval, acol); /* got new value */
677 return;
678 }
679 dumbamb: /* return global value */
680 if ((ambvwt <= 0) | (navsum == 0)) {
681 multcolor(aval, ambval);
682 return;
683 }
684 l = bright(ambval); /* average in computations */
685 if (l > FTINY) {
686 d = (log(l)*(double)ambvwt + avsum) /
687 (double)(ambvwt + navsum);
688 d = exp(d) / l;
689 scalecolor(aval, d);
690 multcolor(aval, ambval); /* apply color of ambval */
691 } else {
692 d = exp( avsum / (double)navsum );
693 scalecolor(aval, d); /* neutral color */
694 }
695 }
696
697
698 static double
699 sumambient( /* get interpolated ambient value */
700 COLOR acol,
701 RAY *r,
702 FVECT rn,
703 int al,
704 AMBTREE *at,
705 FVECT c0,
706 double s
707 )
708 {
709 double d, e1, e2, wt, wsum;
710 COLOR ct;
711 FVECT ck0;
712 int i;
713 int j;
714 AMBVAL *av;
715
716 wsum = 0.0;
717 /* do this node */
718 for (av = at->alist; av != NULL; av = av->next) {
719 double rn_dot = -2.0;
720 if (tracktime)
721 av->latick = ambclock;
722 /*
723 * Ambient level test.
724 */
725 if (av->lvl > al || /* list sorted, so this works */
726 (av->lvl == al) & (av->weight < 0.9*r->rweight))
727 break;
728 /*
729 * Ambient radius test.
730 */
731 VSUB(ck0, av->pos, r->rop);
732 e1 = DOT(ck0, ck0) / (av->rad * av->rad);
733 if (e1 > ambacc*ambacc*1.21)
734 continue;
735 /*
736 * Direction test using closest normal.
737 */
738 d = DOT(av->dir, r->ron);
739 if (rn != r->ron) {
740 rn_dot = DOT(av->dir, rn);
741 if (rn_dot > 1.0-FTINY)
742 rn_dot = 1.0-FTINY;
743 if (rn_dot >= d-FTINY) {
744 d = rn_dot;
745 rn_dot = -2.0;
746 }
747 }
748 e2 = (1.0 - d) * r->rweight;
749 if (e2 < 0.0)
750 e2 = 0.0;
751 else if (e1 + e2 > ambacc*ambacc*1.21)
752 continue;
753 /*
754 * Ray behind test.
755 */
756 d = 0.0;
757 for (j = 0; j < 3; j++)
758 d += (r->rop[j] - av->pos[j]) *
759 (av->dir[j] + r->ron[j]);
760 if (d*0.5 < -minarad*ambacc-.001)
761 continue;
762 /*
763 * Jittering final test reduces image artifacts.
764 */
765 e1 = sqrt(e1);
766 e2 = sqrt(e2);
767 wt = e1 + e2;
768 if (wt > ambacc*(.9+.2*urand(9015+samplendx)))
769 continue;
770 /*
771 * Recompute directional error using perturbed normal
772 */
773 if (rn_dot > 0.0) {
774 e2 = sqrt((1.0 - rn_dot)*r->rweight);
775 wt = e1 + e2;
776 }
777 if (wt <= 1e-3)
778 wt = 1e3;
779 else
780 wt = 1.0 / wt;
781 wsum += wt;
782 extambient(ct, av, r->rop, rn);
783 scalecolor(ct, wt);
784 addcolor(acol, ct);
785 }
786 if (at->kid == NULL)
787 return(wsum);
788 /* do children */
789 s *= 0.5;
790 for (i = 0; i < 8; i++) {
791 for (j = 0; j < 3; j++) {
792 ck0[j] = c0[j];
793 if (1<<j & i)
794 ck0[j] += s;
795 if (r->rop[j] < ck0[j] - OCTSCALE*s)
796 break;
797 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
798 break;
799 }
800 if (j == 3)
801 wsum += sumambient(acol, r, rn, al,
802 at->kid+i, ck0, s);
803 }
804 return(wsum);
805 }
806
807
808 static double
809 makeambient( /* make a new ambient value for storage */
810 COLOR acol,
811 RAY *r,
812 FVECT rn,
813 int al
814 )
815 {
816 AMBVAL amb;
817 FVECT gp, gd;
818 int i;
819
820 amb.weight = 1.0; /* compute weight */
821 for (i = al; i-- > 0; )
822 amb.weight *= AVGREFL;
823 if (r->rweight < 0.1*amb.weight) /* heuristic override */
824 amb.weight = 1.25*r->rweight;
825 setcolor(acol, AVGREFL, AVGREFL, AVGREFL);
826 /* compute ambient */
827 amb.rad = doambient(acol, r, amb.weight, gp, gd);
828 if (amb.rad <= FTINY) {
829 setcolor(acol, 0.0, 0.0, 0.0);
830 return(0.0);
831 }
832 scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */
833 /* store value */
834 VCOPY(amb.pos, r->rop);
835 VCOPY(amb.dir, r->ron);
836 amb.lvl = al;
837 copycolor(amb.val, acol);
838 VCOPY(amb.gpos, gp);
839 VCOPY(amb.gdir, gd);
840 /* insert into tree */
841 avsave(&amb); /* and save to file */
842 if (rn != r->ron)
843 extambient(acol, &amb, r->rop, rn); /* texture */
844 return(amb.rad);
845 }
846
847
848 static void
849 extambient( /* extrapolate value at pv, nv */
850 COLOR cr,
851 AMBVAL *ap,
852 FVECT pv,
853 FVECT nv
854 )
855 {
856 FVECT v1;
857 int i;
858 double d;
859
860 d = 1.0; /* zeroeth order */
861 /* gradient due to translation */
862 for (i = 0; i < 3; i++)
863 d += ap->gpos[i]*(pv[i]-ap->pos[i]);
864 /* gradient due to rotation */
865 VCROSS(v1, ap->dir, nv);
866 d += DOT(ap->gdir, v1);
867 if (d <= 0.0) {
868 setcolor(cr, 0.0, 0.0, 0.0);
869 return;
870 }
871 copycolor(cr, ap->val);
872 scalecolor(cr, d);
873 }
874
875
876 static void
877 avinsert( /* insert ambient value in our tree */
878 AMBVAL *av
879 )
880 {
881 AMBTREE *at;
882 AMBVAL *ap;
883 AMBVAL avh;
884 FVECT ck0;
885 double s;
886 int branch;
887 int i;
888
889 if (av->rad <= FTINY)
890 error(CONSISTENCY, "zero ambient radius in avinsert");
891 at = &atrunk;
892 VCOPY(ck0, thescene.cuorg);
893 s = thescene.cusize;
894 while (s*(OCTSCALE/2) > av->rad*ambacc) {
895 if (at->kid == NULL)
896 if ((at->kid = newambtree()) == NULL)
897 error(SYSTEM, "out of memory in avinsert");
898 s *= 0.5;
899 branch = 0;
900 for (i = 0; i < 3; i++)
901 if (av->pos[i] > ck0[i] + s) {
902 ck0[i] += s;
903 branch |= 1 << i;
904 }
905 at = at->kid + branch;
906 }
907 avh.next = at->alist; /* order by increasing level */
908 for (ap = &avh; ap->next != NULL; ap = ap->next)
909 if ( ap->next->lvl > av->lvl ||
910 (ap->next->lvl == av->lvl) &
911 (ap->next->weight <= av->weight) )
912 break;
913 av->next = ap->next;
914 ap->next = (AMBVAL*)av;
915 at->alist = avh.next;
916 }
917
918 #endif /* ! NEWAMB */
919
920 /************* FOLLOWING ROUTINES SAME FOR NEW & OLD METHODS ***************/
921
922 static void
923 initambfile( /* initialize ambient file */
924 int cre8
925 )
926 {
927 extern char *progname, *octname;
928 static char *mybuf = NULL;
929
930 #ifdef F_SETLKW
931 aflock(cre8 ? F_WRLCK : F_RDLCK);
932 #endif
933 SET_FILE_BINARY(ambfp);
934 if (mybuf == NULL)
935 mybuf = (char *)bmalloc(BUFSIZ+8);
936 setbuf(ambfp, mybuf);
937 if (cre8) { /* new file */
938 newheader("RADIANCE", ambfp);
939 fprintf(ambfp, "%s -av %g %g %g -aw %d -ab %d -aa %g ",
940 progname, colval(ambval,RED),
941 colval(ambval,GRN), colval(ambval,BLU),
942 ambvwt, ambounce, ambacc);
943 fprintf(ambfp, "-ad %d -as %d -ar %d ",
944 ambdiv, ambssamp, ambres);
945 if (octname != NULL)
946 fputs(octname, ambfp);
947 fputc('\n', ambfp);
948 fprintf(ambfp, "SOFTWARE= %s\n", VersionID);
949 fputnow(ambfp);
950 fputformat(AMBFMT, ambfp);
951 fputc('\n', ambfp);
952 putambmagic(ambfp);
953 } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp))
954 error(USER, "bad ambient file");
955 }
956
957
958 static void
959 avsave( /* insert and save an ambient value */
960 AMBVAL *av
961 )
962 {
963 avstore(av);
964 if (ambfp == NULL)
965 return;
966 if (writambval(av, ambfp) < 0)
967 goto writerr;
968 if (++nunflshed >= AMBFLUSH)
969 if (ambsync() == EOF)
970 goto writerr;
971 return;
972 writerr:
973 error(SYSTEM, "error writing to ambient file");
974 }
975
976
977 static AMBVAL *
978 avstore( /* allocate memory and save aval */
979 AMBVAL *aval
980 )
981 {
982 AMBVAL *av;
983 double d;
984
985 if ((av = newambval()) == NULL)
986 error(SYSTEM, "out of memory in avstore");
987 *av = *aval;
988 av->latick = ambclock;
989 av->next = NULL;
990 nambvals++;
991 d = bright(av->val);
992 if (d > FTINY) { /* add to log sum for averaging */
993 avsum += log(d);
994 navsum++;
995 }
996 avinsert(av); /* insert in our cache tree */
997 return(av);
998 }
999
1000
1001 #define ATALLOCSZ 512 /* #/8 trees to allocate at once */
1002
1003 static AMBTREE *atfreelist = NULL; /* free ambient tree structures */
1004
1005
1006 static AMBTREE *
1007 newambtree(void) /* allocate 8 ambient tree structs */
1008 {
1009 AMBTREE *atp, *upperlim;
1010
1011 if (atfreelist == NULL) { /* get more nodes */
1012 atfreelist = (AMBTREE *)malloc(ATALLOCSZ*8*sizeof(AMBTREE));
1013 if (atfreelist == NULL)
1014 return(NULL);
1015 /* link new free list */
1016 upperlim = atfreelist + 8*(ATALLOCSZ-1);
1017 for (atp = atfreelist; atp < upperlim; atp += 8)
1018 atp->kid = atp + 8;
1019 atp->kid = NULL;
1020 }
1021 atp = atfreelist;
1022 atfreelist = atp->kid;
1023 memset((char *)atp, '\0', 8*sizeof(AMBTREE));
1024 return(atp);
1025 }
1026
1027
1028 static void
1029 freeambtree( /* free 8 ambient tree structs */
1030 AMBTREE *atp
1031 )
1032 {
1033 atp->kid = atfreelist;
1034 atfreelist = atp;
1035 }
1036
1037
1038 static void
1039 unloadatree( /* unload an ambient value tree */
1040 AMBTREE *at,
1041 unloadtf_t *f
1042 )
1043 {
1044 AMBVAL *av;
1045 int i;
1046 /* transfer values at this node */
1047 for (av = at->alist; av != NULL; av = at->alist) {
1048 at->alist = av->next;
1049 (*f)(av);
1050 }
1051 if (at->kid == NULL)
1052 return;
1053 for (i = 0; i < 8; i++) /* transfer and free children */
1054 unloadatree(at->kid+i, f);
1055 freeambtree(at->kid);
1056 at->kid = NULL;
1057 }
1058
1059
1060 static struct avl {
1061 AMBVAL *p;
1062 unsigned long t;
1063 } *avlist1; /* ambient value list with ticks */
1064 static AMBVAL **avlist2; /* memory positions for sorting */
1065 static int i_avlist; /* index for lists */
1066
1067 static int alatcmp(const void *av1, const void *av2);
1068
1069 static void
1070 avfree(AMBVAL *av)
1071 {
1072 free(av);
1073 }
1074
1075 static void
1076 av2list(
1077 AMBVAL *av
1078 )
1079 {
1080 #ifdef DEBUG
1081 if (i_avlist >= nambvals)
1082 error(CONSISTENCY, "too many ambient values in av2list1");
1083 #endif
1084 avlist1[i_avlist].p = avlist2[i_avlist] = (AMBVAL*)av;
1085 avlist1[i_avlist++].t = av->latick;
1086 }
1087
1088
1089 static int
1090 alatcmp( /* compare ambient values for MRA */
1091 const void *av1,
1092 const void *av2
1093 )
1094 {
1095 long lc = ((struct avl *)av2)->t - ((struct avl *)av1)->t;
1096 return(lc<0 ? -1 : lc>0 ? 1 : 0);
1097 }
1098
1099
1100 /* GW NOTE 2002/10/3:
1101 * I used to compare AMBVAL pointers, but found that this was the
1102 * cause of a serious consistency error with gcc, since the optimizer
1103 * uses some dangerous trick in pointer subtraction that
1104 * assumes pointers differ by exact struct size increments.
1105 */
1106 static int
1107 aposcmp( /* compare ambient value positions */
1108 const void *avp1,
1109 const void *avp2
1110 )
1111 {
1112 long diff = *(char * const *)avp1 - *(char * const *)avp2;
1113 if (diff < 0)
1114 return(-1);
1115 return(diff > 0);
1116 }
1117
1118
1119 static int
1120 avlmemi( /* find list position from address */
1121 AMBVAL *avaddr
1122 )
1123 {
1124 AMBVAL **avlpp;
1125
1126 avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2,
1127 nambvals, sizeof(AMBVAL *), &aposcmp);
1128 if (avlpp == NULL)
1129 error(CONSISTENCY, "address not found in avlmemi");
1130 return(avlpp - avlist2);
1131 }
1132
1133
1134 static void
1135 sortambvals( /* resort ambient values */
1136 int always
1137 )
1138 {
1139 AMBTREE oldatrunk;
1140 AMBVAL tav, *tap, *pnext;
1141 int i, j;
1142 /* see if it's time yet */
1143 if (!always && (ambclock++ < lastsort+sortintvl ||
1144 nambvals < SORT_THRESH))
1145 return;
1146 /*
1147 * The idea here is to minimize memory thrashing
1148 * in VM systems by improving reference locality.
1149 * We do this by periodically sorting our stored ambient
1150 * values in memory in order of most recently to least
1151 * recently accessed. This ordering was chosen so that new
1152 * ambient values (which tend to be less important) go into
1153 * higher memory with the infrequently accessed values.
1154 * Since we expect our values to need sorting less
1155 * frequently as the process continues, we double our
1156 * waiting interval after each call.
1157 * This routine is also called by setambacc() with
1158 * the "always" parameter set to 1 so that the ambient
1159 * tree will be rebuilt with the new accuracy parameter.
1160 */
1161 if (tracktime) { /* allocate pointer arrays to sort */
1162 avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *));
1163 avlist1 = (struct avl *)malloc(nambvals*sizeof(struct avl));
1164 } else {
1165 avlist2 = NULL;
1166 avlist1 = NULL;
1167 }
1168 if (avlist1 == NULL) { /* no time tracking -- rebuild tree? */
1169 if (avlist2 != NULL)
1170 free((void *)avlist2);
1171 if (always) { /* rebuild without sorting */
1172 oldatrunk = atrunk;
1173 atrunk.alist = NULL;
1174 atrunk.kid = NULL;
1175 unloadatree(&oldatrunk, &avinsert);
1176 }
1177 } else { /* sort memory by last access time */
1178 /*
1179 * Sorting memory is tricky because it isn't contiguous.
1180 * We have to sort an array of pointers by MRA and also
1181 * by memory position. We then copy values in "loops"
1182 * to minimize memory hits. Nevertheless, we will visit
1183 * everyone at least twice, and this is an expensive process
1184 * when we're thrashing, which is when we need to do it.
1185 */
1186 #ifdef DEBUG
1187 sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...",
1188 nambvals, ambclock);
1189 eputs(errmsg);
1190 #endif
1191 i_avlist = 0;
1192 unloadatree(&atrunk, &av2list); /* empty current tree */
1193 #ifdef DEBUG
1194 if (i_avlist < nambvals)
1195 error(CONSISTENCY, "missing ambient values in sortambvals");
1196 #endif
1197 qsort((char *)avlist1, nambvals, sizeof(struct avl), alatcmp);
1198 qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), aposcmp);
1199 for (i = 0; i < nambvals; i++) {
1200 if (avlist1[i].p == NULL)
1201 continue;
1202 tap = avlist2[i];
1203 tav = *tap;
1204 for (j = i; (pnext = avlist1[j].p) != tap;
1205 j = avlmemi(pnext)) {
1206 *(avlist2[j]) = *pnext;
1207 avinsert(avlist2[j]);
1208 avlist1[j].p = NULL;
1209 }
1210 *(avlist2[j]) = tav;
1211 avinsert(avlist2[j]);
1212 avlist1[j].p = NULL;
1213 }
1214 free((void *)avlist1);
1215 free((void *)avlist2);
1216 /* compute new sort interval */
1217 sortintvl = ambclock - lastsort;
1218 if (sortintvl >= MAX_SORT_INTVL/2)
1219 sortintvl = MAX_SORT_INTVL;
1220 else
1221 sortintvl <<= 1; /* wait twice as long next */
1222 #ifdef DEBUG
1223 eputs("done\n");
1224 #endif
1225 }
1226 if (ambclock >= MAXACLOCK)
1227 ambclock = MAXACLOCK/2;
1228 lastsort = ambclock;
1229 }
1230
1231
1232 #ifdef F_SETLKW
1233
1234 static void
1235 aflock( /* lock/unlock ambient file */
1236 int typ
1237 )
1238 {
1239 static struct flock fls; /* static so initialized to zeroes */
1240
1241 if (typ == fls.l_type) /* already called? */
1242 return;
1243 fls.l_type = typ;
1244 if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0)
1245 error(SYSTEM, "cannot (un)lock ambient file");
1246 }
1247
1248
1249 int
1250 ambsync(void) /* synchronize ambient file */
1251 {
1252 long flen;
1253 AMBVAL avs;
1254 int n;
1255
1256 if (ambfp == NULL) /* no ambient file? */
1257 return(0);
1258 /* gain appropriate access */
1259 aflock(nunflshed ? F_WRLCK : F_RDLCK);
1260 /* see if file has grown */
1261 if ((flen = lseek(fileno(ambfp), (off_t)0, SEEK_END)) < 0)
1262 goto seekerr;
1263 if ((n = flen - lastpos) > 0) { /* file has grown */
1264 if (ambinp == NULL) { /* use duplicate filedes */
1265 ambinp = fdopen(dup(fileno(ambfp)), "r");
1266 if (ambinp == NULL)
1267 error(SYSTEM, "fdopen failed in ambsync");
1268 }
1269 if (fseek(ambinp, lastpos, SEEK_SET) < 0)
1270 goto seekerr;
1271 while (n >= AMBVALSIZ) { /* load contributed values */
1272 if (!readambval(&avs, ambinp)) {
1273 sprintf(errmsg,
1274 "ambient file \"%s\" corrupted near character %ld",
1275 ambfile, flen - n);
1276 error(WARNING, errmsg);
1277 break;
1278 }
1279 avstore(&avs);
1280 n -= AMBVALSIZ;
1281 }
1282 lastpos = flen - n;
1283 /*** seek always as safety measure
1284 if (n) ***/ /* alignment */
1285 if (lseek(fileno(ambfp), (off_t)lastpos, SEEK_SET) < 0)
1286 goto seekerr;
1287 }
1288 n = fflush(ambfp); /* calls write() at last */
1289 if (n != EOF)
1290 lastpos += (long)nunflshed*AMBVALSIZ;
1291 else if ((lastpos = lseek(fileno(ambfp), (off_t)0, SEEK_CUR)) < 0)
1292 goto seekerr;
1293
1294 aflock(F_UNLCK); /* release file */
1295 nunflshed = 0;
1296 return(n);
1297 seekerr:
1298 error(SYSTEM, "seek failed in ambsync");
1299 return -1; /* pro forma return */
1300 }
1301
1302 #else /* ! F_SETLKW */
1303
1304 int
1305 ambsync(void) /* flush ambient file */
1306 {
1307 if (ambfp == NULL)
1308 return(0);
1309 nunflshed = 0;
1310 return(fflush(ambfp));
1311 }
1312
1313 #endif /* ! F_SETLKW */
