root/radiance/ray/src/rt/ambient.c
Revision: 2.50
Committed: Thu Jun 5 19:29:34 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.49: +3 -7 lines
2 static const char RCSid[] = "$Id: ambient.c,v 2.49 2003/05/15 05:13:35 greg Exp $";
5 * ambient.c - routines dealing with ambient (inter-reflected) component.
6 *
7 * Declarations of external symbols in ambient.h
8 */
9
10 #include "copyright.h"
11
12 #include "platform.h"
13 #include "ray.h"
14 #include "otypes.h"
15 #include "ambient.h"
16 #include "random.h"
17
18 #ifndef OCTSCALE
19 #define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */
20 #endif
21
22 extern char *shm_boundary; /* memory sharing boundary */
23
24 #define MAXASET 511 /* maximum number of elements in ambient set */
25 OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
26
27 double maxarad; /* maximum ambient radius */
28 double minarad; /* minimum ambient radius */
29
30 static AMBTREE atrunk; /* our ambient trunk node */
31
32 static FILE *ambfp = NULL; /* ambient file pointer */
33 static int nunflshed = 0; /* number of unflushed ambient values */
34
35 #ifndef SORT_THRESH
36 #ifdef SMLMEM
37 #define SORT_THRESH ((3L<<20)/sizeof(AMBVAL))
38 #else
39 #define SORT_THRESH ((9L<<20)/sizeof(AMBVAL))
40 #endif
41 #endif
42 #ifndef SORT_INTVL
43 #define SORT_INTVL (SORT_THRESH<<1)
44 #endif
45 #ifndef MAX_SORT_INTVL
46 #define MAX_SORT_INTVL (SORT_INTVL<<6)
47 #endif
48
49 static double avsum = 0.; /* computed ambient value sum (log) */
50 static unsigned int navsum = 0; /* number of values in avsum */
51 static unsigned int nambvals = 0; /* total number of indirect values */
52 static unsigned int nambshare = 0; /* number of values from file */
53 static unsigned long ambclock = 0; /* ambient access clock */
54 static unsigned long lastsort = 0; /* time of last value sort */
55 static long sortintvl = SORT_INTVL; /* time until next sort */
56 static FILE *ambinp = NULL; /* auxiliary file for input */
57 static long lastpos = -1; /* last flush position */
58
59 #define MAXACLOCK (1L<<30) /* clock turnover value */
60 /*
61 * Track access times unless we are sharing ambient values
62 * through memory on a multiprocessor, when we want to avoid
63 * claiming our own memory (copy on write). Go ahead anyway
64 * if more than two thirds of our values are unshared.
65 * Compile with -Dtracktime=0 to turn this code off.
66 */
67 #ifndef tracktime
68 #define tracktime (shm_boundary == NULL || nambvals > 3*nambshare)
69 #endif
70
71 #define AMBFLUSH (BUFSIZ/AMBVALSIZ)
72
73 #define newambval() (AMBVAL *)malloc(sizeof(AMBVAL))
74 #define freeav(av) free((void *)av);
75
76 static void initambfile(), avsave(), avinsert(), sortambvals(), unloadatree();
77 static int avlmemi();
78 static AMBVAL *avstore();
79 #ifdef F_SETLKW
80 static void aflock();
81 #endif
82
83
84 void
85 setambres(ar) /* set ambient resolution */
86 int ar;
87 {
88 ambres = ar < 0 ? 0 : ar; /* may be done already */
89 /* set min & max radii */
90 if (ar <= 0) {
91 minarad = 0;
92 maxarad = thescene.cusize / 2.0;
93 } else {
94 minarad = thescene.cusize / ar;
95 maxarad = 64 * minarad; /* heuristic */
96 if (maxarad > thescene.cusize / 2.0)
97 maxarad = thescene.cusize / 2.0;
98 }
99 if (minarad <= FTINY)
100 minarad = 10*FTINY;
101 if (maxarad <= minarad)
102 maxarad = 64 * minarad;
103 }
104
105
106 void
107 setambacc(newa) /* set ambient accuracy */
108 double newa;
109 {
110 double ambdiff;
111
112 if (newa < 0.0)
113 newa = 0.0;
114 ambdiff = fabs(newa - ambacc);
115 if (ambdiff >= .01 && (ambacc = newa) > FTINY && nambvals > 0)
116 sortambvals(1); /* rebuild tree */
117 }
118
119
120 void
121 setambient() /* initialize calculation */
122 {
123 int readonly = 0;
124 long pos, flen;
125 AMBVAL amb;
126 /* make sure we're fresh */
127 ambdone();
128 /* init ambient limits */
129 setambres(ambres);
130 setambacc(ambacc);
131 if (ambfile == NULL || !ambfile[0])
132 return;
133 if (ambacc <= FTINY) {
134 sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened",
135 ambfile);
136 error(WARNING, errmsg);
137 return;
138 }
139 /* open ambient file */
140 if ((ambfp = fopen(ambfile, "r+")) == NULL)
141 readonly = (ambfp = fopen(ambfile, "r")) != NULL;
142 if (ambfp != NULL) {
143 initambfile(0); /* file exists */
144 pos = ftell(ambfp);
145 while (readambval(&amb, ambfp))
146 avinsert(avstore(&amb));
147 nambshare = nambvals; /* share loaded values */
148 if (readonly) {
149 sprintf(errmsg,
150 "loaded %u values from read-only ambient file",
151 nambvals);
152 error(WARNING, errmsg);
153 fclose(ambfp); /* close file so no writes */
154 ambfp = NULL;
155 return; /* avoid ambsync() */
156 }
157 /* align file pointer */
158 pos += (long)nambvals*AMBVALSIZ;
159 flen = lseek(fileno(ambfp), (off_t)0L, 2);
160 if (flen != pos) {
161 sprintf(errmsg,
162 "ignoring last %ld values in ambient file (corrupted)",
163 (flen - pos)/AMBVALSIZ);
164 error(WARNING, errmsg);
165 fseek(ambfp, pos, 0);
166 ftruncate(fileno(ambfp), (off_t)pos);
167 }
168 } else if ((ambfp = fopen(ambfile, "w+")) != NULL) {
169 initambfile(1); /* else create new file */
170 } else {
171 sprintf(errmsg, "cannot open ambient file \"%s\"", ambfile);
172 error(SYSTEM, errmsg);
173 }
174 nunflshed++; /* lie */
175 ambsync();
176 }
177
178
179 void
180 ambdone() /* close ambient file and free memory */
181 {
182 if (ambfp != NULL) { /* close ambient file */
183 ambsync();
184 fclose(ambfp);
185 ambfp = NULL;
186 if (ambinp != NULL) {
187 fclose(ambinp);
188 ambinp = NULL;
189 }
190 lastpos = -1;
191 }
192 /* free ambient tree */
193 unloadatree(&atrunk, free);
194 /* reset state variables */
195 avsum = 0.;
196 navsum = 0;
197 nambvals = 0;
198 nambshare = 0;
199 ambclock = 0;
200 lastsort = 0;
201 sortintvl = SORT_INTVL;
202 }
203
204
205 void
206 ambnotify(obj) /* record new modifier */
207 OBJECT obj;
208 {
209 static int hitlimit = 0;
210 register OBJREC *o;
211 register char **amblp;
212
213 if (obj == OVOID) { /* starting over */
214 ambset[0] = 0;
215 hitlimit = 0;
216 return;
217 }
218 o = objptr(obj);
219 if (hitlimit || !ismodifier(o->otype))
220 return;
221 for (amblp = amblist; *amblp != NULL; amblp++)
222 if (!strcmp(o->oname, *amblp)) {
223 if (ambset[0] >= MAXASET) {
224 error(WARNING, "too many modifiers in ambient list");
225 hitlimit++;
226 return; /* should this be fatal? */
227 }
228 insertelem(ambset, obj);
229 return;
230 }
231 }
232
233
234 void
235 ambient(acol, r, nrm) /* compute ambient component for ray */
236 COLOR acol;
237 register RAY *r;
238 FVECT nrm;
239 {
240 static int rdepth = 0; /* ambient recursion */
241 double d, l;
242
243 if (ambdiv <= 0) /* no ambient calculation */
244 goto dumbamb;
245 /* check number of bounces */
246 if (rdepth >= ambounce)
247 goto dumbamb;
248 /* check ambient list */
249 if (ambincl != -1 && r->ro != NULL &&
250 ambincl != inset(ambset, r->ro->omod))
251 goto dumbamb;
252
253 if (ambacc <= FTINY) { /* no ambient storage */
254 rdepth++;
255 d = doambient(acol, r, r->rweight, NULL, NULL);
256 rdepth--;
257 if (d <= FTINY)
258 goto dumbamb;
259 return;
260 }
261
262 if (tracktime) /* sort to minimize thrashing */
263 sortambvals(0);
264 /* get ambient value */
265 setcolor(acol, 0.0, 0.0, 0.0);
266 d = sumambient(acol, r, nrm, rdepth,
267 &atrunk, thescene.cuorg, thescene.cusize);
268 if (d > FTINY) {
269 scalecolor(acol, 1.0/d);
270 return;
271 }
272 rdepth++; /* need to cache new value */
273 d = makeambient(acol, r, nrm, rdepth-1);
274 rdepth--;
275 if (d > FTINY)
276 return;
277 dumbamb: /* return global value */
278 copycolor(acol, ambval);
279 if (ambvwt <= 0 | navsum == 0)
280 return;
281 l = bright(ambval); /* average in computations */
282 if (l > FTINY) {
283 d = (log(l)*(double)ambvwt + avsum) /
284 (double)(ambvwt + navsum);
285 d = exp(d) / l;
286 scalecolor(acol, d); /* apply color of ambval */
287 } else {
288 d = exp( avsum / (double)navsum );
289 setcolor(acol, d, d, d); /* neutral color */
290 }
291 }
292
293
294 double
295 sumambient(acol, r, rn, al, at, c0, s) /* get interpolated ambient value */
296 COLOR acol;
297 register RAY *r;
298 FVECT rn;
299 int al;
300 AMBTREE *at;
301 FVECT c0;
302 double s;
303 {
304 double d, e1, e2, wt, wsum;
305 COLOR ct;
306 FVECT ck0;
307 int i;
308 register int j;
309 register AMBVAL *av;
310
311 wsum = 0.0;
312 /* do this node */
313 for (av = at->alist; av != NULL; av = av->next) {
314 double rn_dot = -2.0;
315 if (tracktime)
316 av->latick = ambclock;
317 /*
318 * Ambient level test.
319 */
320 if (av->lvl > al) /* list sorted, so this works */
321 break;
322 if (av->weight < r->rweight-FTINY)
323 continue;
324 /*
325 * Ambient radius test.
326 */
327 d = av->pos[0] - r->rop[0];
328 e1 = d * d;
329 d = av->pos[1] - r->rop[1];
330 e1 += d * d;
331 d = av->pos[2] - r->rop[2];
332 e1 += d * d;
333 e1 /= av->rad * av->rad;
334 if (e1 > ambacc*ambacc*1.21)
335 continue;
336 /*
337 * Direction test using closest normal.
338 */
339 d = DOT(av->dir, r->ron);
340 if (rn != r->ron) {
341 rn_dot = DOT(av->dir, rn);
342 if (rn_dot > 1.0-FTINY)
343 rn_dot = 1.0-FTINY;
344 if (rn_dot >= d-FTINY) {
345 d = rn_dot;
346 rn_dot = -2.0;
347 }
348 }
349 e2 = (1.0 - d) * r->rweight;
350 if (e2 < 0.0) e2 = 0.0;
351 if (e1 + e2 > ambacc*ambacc*1.21)
352 continue;
353 /*
354 * Ray behind test.
355 */
356 d = 0.0;
357 for (j = 0; j < 3; j++)
358 d += (r->rop[j] - av->pos[j]) *
359 (av->dir[j] + r->ron[j]);
360 if (d*0.5 < -minarad*ambacc-.001)
361 continue;
362 /*
363 * Jittering final test reduces image artifacts.
364 */
365 e1 = sqrt(e1);
366 e2 = sqrt(e2);
367 wt = e1 + e2;
368 if (wt > ambacc*(.9+.2*urand(9015+samplendx)))
369 continue;
370 /*
371 * Recompute directional error using perturbed normal
372 */
373 if (rn_dot > 0.0) {
374 e2 = sqrt((1.0 - rn_dot)*r->rweight);
375 wt = e1 + e2;
376 }
377 if (wt <= 1e-3)
378 wt = 1e3;
379 else
380 wt = 1.0 / wt;
381 wsum += wt;
382 extambient(ct, av, r->rop, rn);
383 scalecolor(ct, wt);
384 addcolor(acol, ct);
385 }
386 if (at->kid == NULL)
387 return(wsum);
388 /* do children */
389 s *= 0.5;
390 for (i = 0; i < 8; i++) {
391 for (j = 0; j < 3; j++) {
392 ck0[j] = c0[j];
393 if (1<<j & i)
394 ck0[j] += s;
395 if (r->rop[j] < ck0[j] - OCTSCALE*s)
396 break;
397 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
398 break;
399 }
400 if (j == 3)
401 wsum += sumambient(acol, r, rn, al, at->kid+i, ck0, s);
402 }
403 return(wsum);
404 }
405
406
407 double
408 makeambient(acol, r, rn, al) /* make a new ambient value */
409 COLOR acol;
410 register RAY *r;
411 FVECT rn;
412 int al;
413 {
414 AMBVAL amb;
415 FVECT gp, gd;
416 /* compute weight */
417 amb.weight = pow(AVGREFL, (double)al);
418 if (r->rweight < 0.1*amb.weight) /* heuristic */
419 amb.weight = r->rweight;
420 /* compute ambient */
421 amb.rad = doambient(acol, r, amb.weight, gp, gd);
422 if (amb.rad <= FTINY)
423 return(0.0);
424 /* store it */
425 VCOPY(amb.pos, r->rop);
426 VCOPY(amb.dir, r->ron);
427 amb.lvl = al;
428 copycolor(amb.val, acol);
429 VCOPY(amb.gpos, gp);
430 VCOPY(amb.gdir, gd);
431 /* insert into tree */
432 avsave(&amb); /* and save to file */
433 if (rn != r->ron)
434 extambient(acol, &amb, r->rop, rn); /* texture */
435 return(amb.rad);
436 }
437
438
439 void
440 extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */
441 COLOR cr;
442 register AMBVAL *ap;
443 FVECT pv, nv;
444 {
445 FVECT v1;
446 register int i;
447 double d;
448
449 d = 1.0; /* zeroeth order */
450 /* gradient due to translation */
451 for (i = 0; i < 3; i++)
452 d += ap->gpos[i]*(pv[i]-ap->pos[i]);
453 /* gradient due to rotation */
454 VCROSS(v1, ap->dir, nv);
455 d += DOT(ap->gdir, v1);
456 if (d <= 0.0) {
457 setcolor(cr, 0.0, 0.0, 0.0);
458 return;
459 }
460 copycolor(cr, ap->val);
461 scalecolor(cr, d);
462 }
463
464
465 static void
466 initambfile(creat) /* initialize ambient file */
467 int creat;
468 {
469 extern char *progname, *octname;
470 static char *mybuf = NULL;
471
472 #ifdef F_SETLKW
473 aflock(creat ? F_WRLCK : F_RDLCK);
474 #endif
475 SET_FILE_BINARY(ambfp);
476 if (mybuf == NULL)
477 mybuf = (char *)bmalloc(BUFSIZ+8);
478 setbuf(ambfp, mybuf);
479 if (creat) { /* new file */
480 newheader("RADIANCE", ambfp);
481 fprintf(ambfp, "%s -av %g %g %g -aw %d -ab %d -aa %g ",
482 progname, colval(ambval,RED),
483 colval(ambval,GRN), colval(ambval,BLU),
484 ambvwt, ambounce, ambacc);
485 fprintf(ambfp, "-ad %d -as %d -ar %d ",
486 ambdiv, ambssamp, ambres);
487 if (octname != NULL)
488 printargs(1, &octname, ambfp);
489 else
490 fputc('\n', ambfp);
491 fprintf(ambfp, "SOFTWARE= %s\n", VersionID);
492 fputnow(ambfp);
493 fputformat(AMBFMT, ambfp);
494 putc('\n', ambfp);
495 putambmagic(ambfp);
496 } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp))
497 error(USER, "bad ambient file");
498 }
499
500
501 static void
502 avsave(av) /* insert and save an ambient value */
503 AMBVAL *av;
504 {
505 avinsert(avstore(av));
506 if (ambfp == NULL)
507 return;
508 if (writambval(av, ambfp) < 0)
509 goto writerr;
510 if (++nunflshed >= AMBFLUSH)
511 if (ambsync() == EOF)
512 goto writerr;
513 return;
514 writerr:
515 error(SYSTEM, "error writing to ambient file");
516 }
517
518
519 static AMBVAL *
520 avstore(aval) /* allocate memory and store aval */
521 register AMBVAL *aval;
522 {
523 register AMBVAL *av;
524 double d;
525
526 if ((av = newambval()) == NULL)
527 error(SYSTEM, "out of memory in avstore");
528 copystruct(av, aval);
529 av->latick = ambclock;
530 av->next = NULL;
531 nambvals++;
532 d = bright(av->val);
533 if (d > FTINY) { /* add to log sum for averaging */
534 avsum += log(d);
535 navsum++;
536 }
537 return(av);
538 }
539
540
541 #define ATALLOCSZ 512 /* #/8 trees to allocate at once */
542
543 static AMBTREE *atfreelist = NULL; /* free ambient tree structures */
544
545
546 static AMBTREE *
547 newambtree() /* allocate 8 ambient tree structs */
548 {
549 register AMBTREE *atp, *upperlim;
550
551 if (atfreelist == NULL) { /* get more nodes */
552 atfreelist = (AMBTREE *)malloc(ATALLOCSZ*8*sizeof(AMBTREE));
553 if (atfreelist == NULL)
554 return(NULL);
555 /* link new free list */
556 upperlim = atfreelist + 8*(ATALLOCSZ-1);
557 for (atp = atfreelist; atp < upperlim; atp += 8)
558 atp->kid = atp + 8;
559 atp->kid = NULL;
560 }
561 atp = atfreelist;
562 atfreelist = atp->kid;
563 bzero((char *)atp, 8*sizeof(AMBTREE));
564 return(atp);
565 }
566
567
568 static void
569 freeambtree(atp) /* free 8 ambient tree structs */
570 AMBTREE *atp;
571 {
572 atp->kid = atfreelist;
573 atfreelist = atp;
574 }
575
576
577 static void
578 avinsert(av) /* insert ambient value in our tree */
579 register AMBVAL *av;
580 {
581 register AMBTREE *at;
582 register AMBVAL *ap;
583 AMBVAL avh;
584 FVECT ck0;
585 double s;
586 int branch;
587 register int i;
588
589 if (av->rad <= FTINY)
590 error(CONSISTENCY, "zero ambient radius in avinsert");
591 at = &atrunk;
592 VCOPY(ck0, thescene.cuorg);
593 s = thescene.cusize;
594 while (s*(OCTSCALE/2) > av->rad*ambacc) {
595 if (at->kid == NULL)
596 if ((at->kid = newambtree()) == NULL)
597 error(SYSTEM, "out of memory in avinsert");
598 s *= 0.5;
599 branch = 0;
600 for (i = 0; i < 3; i++)
601 if (av->pos[i] > ck0[i] + s) {
602 ck0[i] += s;
603 branch |= 1 << i;
604 }
605 at = at->kid + branch;
606 }
607 avh.next = at->alist; /* order by increasing level */
608 for (ap = &avh; ap->next != NULL; ap = ap->next)
609 if (ap->next->lvl >= av->lvl)
610 break;
611 av->next = ap->next;
612 ap->next = av;
613 at->alist = avh.next;
614 }
615
616
617 static void
618 unloadatree(at, f) /* unload an ambient value tree */
619 register AMBTREE *at;
620 void (*f)();
621 {
622 register AMBVAL *av;
623 register int i;
624 /* transfer values at this node */
625 for (av = at->alist; av != NULL; av = at->alist) {
626 at->alist = av->next;
627 (*f)(av);
628 }
629 if (at->kid == NULL)
630 return;
631 for (i = 0; i < 8; i++) /* transfer and free children */
632 unloadatree(at->kid+i, f);
633 freeambtree(at->kid);
634 at->kid = NULL;
635 }
636
637
638 static struct avl {
639 AMBVAL *p;
640 unsigned long t;
641 } *avlist1; /* ambient value list with ticks */
642 static AMBVAL **avlist2; /* memory positions for sorting */
643 static int i_avlist; /* index for lists */
644
645
646 static int
647 av2list(av)
648 register AMBVAL *av;
649 {
650 #ifdef DEBUG
651 if (i_avlist >= nambvals)
652 error(CONSISTENCY, "too many ambient values in av2list1");
653 #endif
654 avlist1[i_avlist].p = avlist2[i_avlist] = av;
655 avlist1[i_avlist++].t = av->latick;
656 }
657
658
659 static int
660 alatcmp(av1, av2) /* compare ambient values for MRA */
661 struct avl *av1, *av2;
662 {
663 register long lc = av2->t - av1->t;
664 return(lc<0 ? -1 : lc>0 ? 1 : 0);
665 }
666
667
668 /* GW NOTE 2002/10/3:
669 * I used to compare AMBVAL pointers, but found that this was the
670 * cause of a serious consistency error with gcc, since the optimizer
671 * uses some dangerous trick in pointer subtraction that
672 * assumes pointers differ by exact struct size increments.
673 */
674 static int
675 aposcmp(avp1, avp2) /* compare ambient value positions */
676 const void *avp1, *avp2;
677 {
678 register long diff = *(char * const *)avp1 - *(char * const *)avp2;
679 if (diff < 0)
680 return(-1);
681 return(diff > 0);
682 }
683
684 #if 1
685 static int
686 avlmemi(avaddr) /* find list position from address */
687 AMBVAL *avaddr;
688 {
689 register AMBVAL **avlpp;
690
691 avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2,
692 nambvals, sizeof(AMBVAL *), aposcmp);
693 if (avlpp == NULL)
694 error(CONSISTENCY, "address not found in avlmemi");
695 return(avlpp - avlist2);
696 }
697 #else
698 #define avlmemi(avaddr) ((AMBVAL **)bsearch((char *)&avaddr,(char *)avlist2, \
699 nambvals,sizeof(AMBVAL *),aposcmp) - avlist2)
700 #endif
701
702
703 static void
704 sortambvals(always) /* resort ambient values */
705 int always;
706 {
707 AMBTREE oldatrunk;
708 AMBVAL tav, *tap, *pnext;
709 register int i, j;
710 /* see if it's time yet */
711 if (!always && (ambclock++ < lastsort+sortintvl ||
712 nambvals < SORT_THRESH))
713 return;
714 /*
715 * The idea here is to minimize memory thrashing
716 * in VM systems by improving reference locality.
717 * We do this by periodically sorting our stored ambient
718 * values in memory in order of most recently to least
719 * recently accessed. This ordering was chosen so that new
720 * ambient values (which tend to be less important) go into
721 * higher memory with the infrequently accessed values.
722 * Since we expect our values to need sorting less
723 * frequently as the process continues, we double our
724 * waiting interval after each call.
725 * This routine is also called by setambacc() with
726 * the "always" parameter set to 1 so that the ambient
727 * tree will be rebuilt with the new accuracy parameter.
728 */
729 if (tracktime) { /* allocate pointer arrays to sort */
730 avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *));
731 avlist1 = (struct avl *)malloc(nambvals*sizeof(struct avl));
732 } else {
733 avlist2 = NULL;
734 avlist1 = NULL;
735 }
736 if (avlist1 == NULL) { /* no time tracking -- rebuild tree? */
737 if (avlist2 != NULL)
738 free((void *)avlist2);
739 if (always) { /* rebuild without sorting */
740 copystruct(&oldatrunk, &atrunk);
741 atrunk.alist = NULL;
742 atrunk.kid = NULL;
743 unloadatree(&oldatrunk, avinsert);
744 }
745 } else { /* sort memory by last access time */
746 /*
747 * Sorting memory is tricky because it isn't contiguous.
748 * We have to sort an array of pointers by MRA and also
749 * by memory position. We then copy values in "loops"
750 * to minimize memory hits. Nevertheless, we will visit
751 * everyone at least twice, and this is an expensive process
752 * when we're thrashing, which is when we need to do it.
753 */
754 #ifdef DEBUG
755 sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...",
756 nambvals, ambclock);
757 eputs(errmsg);
758 #endif
759 i_avlist = 0;
760 unloadatree(&atrunk, av2list); /* empty current tree */
761 #ifdef DEBUG
762 if (i_avlist < nambvals)
763 error(CONSISTENCY, "missing ambient values in sortambvals");
764 #endif
765 qsort((char *)avlist1, nambvals, sizeof(struct avl), alatcmp);
766 qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), aposcmp);
767 for (i = 0; i < nambvals; i++) {
768 if (avlist1[i].p == NULL)
769 continue;
770 tap = avlist2[i];
771 copystruct(&tav, tap);
772 for (j = i; (pnext = avlist1[j].p) != tap;
773 j = avlmemi(pnext)) {
774 copystruct(avlist2[j], pnext);
775 avinsert(avlist2[j]);
776 avlist1[j].p = NULL;
777 }
778 copystruct(avlist2[j], &tav);
779 avinsert(avlist2[j]);
780 avlist1[j].p = NULL;
781 }
782 free((void *)avlist1);
783 free((void *)avlist2);
784 /* compute new sort interval */
785 sortintvl = ambclock - lastsort;
786 if (sortintvl >= MAX_SORT_INTVL/2)
787 sortintvl = MAX_SORT_INTVL;
788 else
789 sortintvl <<= 1; /* wait twice as long next */
790 #ifdef DEBUG
791 eputs("done\n");
792 #endif
793 }
794 if (ambclock >= MAXACLOCK)
795 ambclock = MAXACLOCK/2;
796 lastsort = ambclock;
797 }
798
799
800 #ifdef F_SETLKW
801
802 static void
803 aflock(typ) /* lock/unlock ambient file */
804 int typ;
805 {
806 static struct flock fls; /* static so initialized to zeroes */
807
808 fls.l_type = typ;
809 if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0)
810 error(SYSTEM, "cannot (un)lock ambient file");
811 }
812
813
814 int
815 ambsync() /* synchronize ambient file */
816 {
817 long flen;
818 AMBVAL avs;
819 register int n;
820
821 if (nunflshed == 0)
822 return(0);
823 if (lastpos < 0) /* initializing (locked in initambfile) */
824 goto syncend;
825 /* gain exclusive access */
826 aflock(F_WRLCK);
827 /* see if file has grown */
828 if ((flen = lseek(fileno(ambfp), (off_t)0L, 2)) < 0)
829 goto seekerr;
830 if (n = flen - lastpos) { /* file has grown */
831 if (ambinp == NULL) { /* use duplicate filedes */
832 ambinp = fdopen(dup(fileno(ambfp)), "r");
833 if (ambinp == NULL)
834 error(SYSTEM, "fdopen failed in ambsync");
835 }
836 if (fseek(ambinp, lastpos, 0) < 0)
837 goto seekerr;
838 while (n >= AMBVALSIZ) { /* load contributed values */
839 if (!readambval(&avs, ambinp)) {
840 sprintf(errmsg,
841 "ambient file \"%s\" corrupted near character %ld",
842 ambfile, flen - n);
843 error(WARNING, errmsg);
844 break;
845 }
846 avinsert(avstore(&avs));
847 n -= AMBVALSIZ;
848 }
849 /*** seek always as safety measure
850 if (n) ***/ /* alignment */
851 if (lseek(fileno(ambfp), (off_t)(flen-n), 0) < 0)
852 goto seekerr;
853 }
854 #ifdef DEBUG
855 if (ambfp->_ptr - ambfp->_base != nunflshed*AMBVALSIZ) {
856 sprintf(errmsg, "ambient file buffer at %d rather than %d",
857 ambfp->_ptr - ambfp->_base,
858 nunflshed*AMBVALSIZ);
859 error(CONSISTENCY, errmsg);
860 }
861 #endif
862 syncend:
863 n = fflush(ambfp); /* calls write() at last */
864 if ((lastpos = lseek(fileno(ambfp), (off_t)0L, 1)) < 0)
865 goto seekerr;
866 aflock(F_UNLCK); /* release file */
867 nunflshed = 0;
868 return(n);
869 seekerr:
870 error(SYSTEM, "seek failed in ambsync");
871 }
872
873 #else
874
875 int
876 ambsync() /* flush ambient file */
877 {
878 if (nunflshed == 0)
879 return(0);
880 nunflshed = 0;
881 return(fflush(ambfp));
882 }
883
884 #endif
