| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: ambcomp.c,v 2.98 2025/04/24 01:43:58 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Routines to compute "ambient" values using Monte Carlo
| 6 |
| 7 |
* Hessian calculations based on "Practical Hessian-Based Error Control
| 8 |
* for Irradiance Caching" by Schwarzhaupt, Wann Jensen, & Jarosz
| 9 |
* from ACM SIGGRAPH Asia 2012 conference proceedings.
| 10 |
| 11 |
* Added book-keeping optimization to avoid calculations that would
| 12 |
* cancel due to traversal both directions on edges that are adjacent
| 13 |
* to same-valued triangles. This cuts about half of Hessian math.
| 14 |
| 15 |
* Declarations of external symbols in ambient.h
| 16 |
| 17 |
| 18 |
#include "copyright.h"
| 19 |
| 20 |
#include "ray.h"
| 21 |
#include "ambient.h"
| 22 |
#include "random.h"
| 23 |
| 24 |
#ifndef MINADIV
| 25 |
#define MINADIV 7 /* minimum # divisions in each dimension */
| 26 |
#endif
| 27 |
#ifndef MINSDIST
| 28 |
#define MINSDIST 0.25 /* def. min. spacing = 1/4th division */
| 29 |
#endif
| 30 |
| 31 |
typedef struct {
| 32 |
FVECT p; /* intersection point */
| 33 |
float d; /* reciprocal distance */
| 34 |
SCOLOR v; /* hemisphere sample value */
| 35 |
} AMBSAMP; /* sample value */
| 36 |
| 37 |
typedef struct {
| 38 |
RAY *rp; /* originating ray sample */
| 39 |
int ns; /* number of samples per axis */
| 40 |
int sampOK; /* acquired full sample set? */
| 41 |
int atyp; /* RAMBIENT or TAMBIENT */
| 42 |
SCOLOR acoef; /* division contribution coefficient */
| 43 |
SCOLOR acol; /* accumulated color */
| 44 |
FVECT onrm; /* oriented unperturbed surface normal */
| 45 |
FVECT ux, uy; /* tangent axis unit vectors */
| 46 |
AMBSAMP sa[1]; /* sample array (extends struct) */
| 47 |
} AMBHEMI; /* ambient sample hemisphere */
| 48 |
| 49 |
#define AI(h,i,j) ((i)*(h)->ns + (j))
| 50 |
#define ambsam(h,i,j) (h)->sa[AI(h,i,j)]
| 51 |
| 52 |
typedef struct {
| 53 |
FVECT r_i, r_i1, e_i, rcp, rI2_eJ2;
| 54 |
double I1, I2;
| 55 |
} FFTRI; /* vectors and coefficients for Hessian calculation */
| 56 |
| 57 |
| 58 |
static int
| 59 |
ambcollision( /* proposed direciton collides? */
| 60 |
AMBHEMI *hp,
| 61 |
int i,
| 62 |
int j,
| 63 |
FVECT dv
| 64 |
| 65 |
| 66 |
double cos_thresh;
| 67 |
int ii, jj;
| 68 |
| 69 |
cos_thresh = (PI*MINSDIST)/(double)hp->ns;
| 70 |
cos_thresh = 1. - .5*cos_thresh*cos_thresh;
| 71 |
/* check existing neighbors */
| 72 |
for (ii = i-1; ii <= i+1; ii++) {
| 73 |
if (ii < 0) continue;
| 74 |
if (ii >= hp->ns) break;
| 75 |
for (jj = j-1; jj <= j+1; jj++) {
| 76 |
AMBSAMP *ap;
| 77 |
FVECT avec;
| 78 |
double dprod;
| 79 |
if (jj < 0) continue;
| 80 |
if (jj >= hp->ns) break;
| 81 |
if ((ii==i) & (jj==j)) continue;
| 82 |
ap = &ambsam(hp,ii,jj);
| 83 |
if (ap->d <= .5/FHUGE)
| 84 |
continue; /* no one home */
| 85 |
VSUB(avec, ap->p, hp->rp->rop);
| 86 |
dprod = DOT(avec, dv);
| 87 |
if (dprod >= cos_thresh*VLEN(avec))
| 88 |
return(1); /* collision */
| 89 |
| 90 |
| 91 |
return(0); /* nothing to worry about */
| 92 |
| 93 |
| 94 |
| 95 |
#define XLOTSIZ 251 /* size of used car lot */
| 96 |
#define CFIRST 0 /* first corner */
| 97 |
#define COTHER (CFIRST+4) /* non-corner sample */
| 98 |
#define CMAXTARGET (int)(XLOTSIZ*MINSDIST/(1-MINSDIST))
| 99 |
#define CXCOPY(d,s) (excharr[d][0]=excharr[s][0], excharr[d][1]=excharr[s][1])
| 100 |
| 101 |
static int
| 102 |
psample_class(double ss[2]) /* classify patch sample */
| 103 |
| 104 |
if (ss[0] < MINSDIST) {
| 105 |
if (ss[1] < MINSDIST)
| 106 |
return(CFIRST);
| 107 |
if (ss[1] > 1.-MINSDIST)
| 108 |
return(CFIRST+2);
| 109 |
} else if (ss[0] > 1.-MINSDIST) {
| 110 |
| 111 |
return(CFIRST+1);
| 112 |
| 113 |
return(CFIRST+3);
| 114 |
| 115 |
return(COTHER); /* not in a corner */
| 116 |
| 117 |
| 118 |
static void
| 119 |
trade_patchsamp(double ss[2]) /* trade in problem patch position */
| 120 |
| 121 |
static float excharr[XLOTSIZ][2];
| 122 |
static short gterm[COTHER+1];
| 123 |
double srep[2];
| 124 |
int sclass, rclass;
| 125 |
int x;
| 126 |
/* reset on corner overload */
| 127 |
if (gterm[COTHER-1] >= (CMAXTARGET+XLOTSIZ)/2)
| 128 |
memset(gterm, 0, sizeof(gterm));
| 129 |
/* (re-)initialize? */
| 130 |
while (gterm[COTHER] < XLOTSIZ) {
| 131 |
excharr[gterm[COTHER]][0] = frandom();
| 132 |
excharr[gterm[COTHER]][1] = frandom();
| 133 |
++gterm[COTHER];
| 134 |
} /* get trade-in candidate... */
| 135 |
sclass = psample_class(ss); /* submitted corner or not? */
| 136 |
switch (sclass) {
| 137 |
case COTHER: /* trade mid-edge with corner/any */
| 138 |
x = irandom( gterm[COTHER-1] > CMAXTARGET
| 139 |
? gterm[COTHER-1] : XLOTSIZ );
| 140 |
break;
| 141 |
case CFIRST: /* kick out of first corner */
| 142 |
x = gterm[CFIRST] + irandom(XLOTSIZ - gterm[CFIRST]);
| 143 |
break;
| 144 |
default: /* kick out of 2nd-4th corner */
| 145 |
x = irandom(XLOTSIZ - (gterm[sclass] - gterm[sclass-1]));
| 146 |
x += (x >= gterm[sclass-1])*(gterm[sclass] - gterm[sclass-1]);
| 147 |
break;
| 148 |
| 149 |
srep[0] = excharr[x][0]; /* save selected trade output */
| 150 |
srep[1] = excharr[x][1];
| 151 |
/* adjust our lot groups */
| 152 |
for (rclass = CFIRST; rclass < COTHER; rclass++)
| 153 |
if (x < gterm[rclass])
| 154 |
break;
| 155 |
if (sclass < rclass) { /* submitted group before replacement? */
| 156 |
CXCOPY(x, gterm[rclass-1]);
| 157 |
while (--rclass > sclass) {
| 158 |
CXCOPY(gterm[rclass], gterm[rclass-1]);
| 159 |
++gterm[rclass];
| 160 |
| 161 |
x = gterm[sclass]++;
| 162 |
} else if (sclass > rclass) { /* submitted group after replacement? */
| 163 |
--gterm[rclass];
| 164 |
CXCOPY(x, gterm[rclass]);
| 165 |
while (++rclass < sclass) {
| 166 |
--gterm[rclass];
| 167 |
CXCOPY(gterm[rclass-1], gterm[rclass]);
| 168 |
| 169 |
x = gterm[sclass-1];
| 170 |
| 171 |
excharr[x][0] = ss[0]; /* complete the transaction */
| 172 |
excharr[x][1] = ss[1];
| 173 |
ss[0] = srep[0];
| 174 |
ss[1] = srep[1];
| 175 |
| 176 |
| 177 |
#undef CXCOPY
| 178 |
#undef XLOTSIZ
| 179 |
#undef COTHER
| 180 |
#undef CFIRST
| 181 |
| 182 |
| 183 |
static int
| 184 |
ambsample( /* initial ambient division sample */
| 185 |
AMBHEMI *hp,
| 186 |
int i,
| 187 |
int j,
| 188 |
int n
| 189 |
| 190 |
| 191 |
AMBSAMP *ap = &ambsam(hp,i,j);
| 192 |
RAY ar;
| 193 |
int hlist[3], ii;
| 194 |
double ss[2];
| 195 |
RREAL spt[2];
| 196 |
double zd;
| 197 |
/* generate hemispherical sample */
| 198 |
/* ambient coefficient for weight */
| 199 |
if (ambacc > FTINY)
| 200 |
setscolor(ar.rcoef, AVGREFL, AVGREFL, AVGREFL);
| 201 |
else
| 202 |
copyscolor(ar.rcoef, hp->acoef);
| 203 |
if (rayorigin(&ar, hp->atyp, hp->rp, ar.rcoef) < 0)
| 204 |
return(0);
| 205 |
if (ambacc > FTINY) {
| 206 |
smultscolor(ar.rcoef, hp->acoef);
| 207 |
scalescolor(ar.rcoef, 1./AVGREFL);
| 208 |
| 209 |
hlist[0] = hp->rp->rno;
| 210 |
hlist[1] = AI(hp,i,j);
| 211 |
hlist[2] = samplendx;
| 212 |
multisamp(ss, 2, urand(ilhash(hlist,3)+n));
| 213 |
patch_redo:
| 214 |
square2disk(spt, (j+ss[1])/hp->ns, (i+ss[0])/hp->ns);
| 215 |
zd = sqrt(1. - spt[0]*spt[0] - spt[1]*spt[1]);
| 216 |
for (ii = 3; ii--; )
| 217 |
ar.rdir[ii] = spt[0]*hp->ux[ii] +
| 218 |
spt[1]*hp->uy[ii] +
| 219 |
zd*hp->onrm[ii];
| 220 |
checknorm(ar.rdir);
| 221 |
/* avoid coincident samples */
| 222 |
if (!n & (hp->ns >= 4) && ambcollision(hp, i, j, ar.rdir)) {
| 223 |
trade_patchsamp(ss);
| 224 |
goto patch_redo;
| 225 |
| 226 |
dimlist[ndims++] = AI(hp,i,j) + 90171;
| 227 |
rayvalue(&ar); /* evaluate ray */
| 228 |
ndims--;
| 229 |
zd = raydistance(&ar);
| 230 |
if (zd <= FTINY)
| 231 |
return(0); /* should never happen */
| 232 |
smultscolor(ar.rcol, ar.rcoef); /* apply coefficient */
| 233 |
if (zd*ap->d < 1.0) /* new/closer distance? */
| 234 |
ap->d = 1.0/zd;
| 235 |
if (!n) { /* record first vertex & value */
| 236 |
if (zd > 10.0*thescene.cusize + 1000.)
| 237 |
zd = 10.0*thescene.cusize + 1000.;
| 238 |
VSUM(ap->p, ar.rorg, ar.rdir, zd);
| 239 |
copyscolor(ap->v, ar.rcol);
| 240 |
} else { /* else update recorded value */
| 241 |
sopscolor(hp->acol, -=, ap->v);
| 242 |
zd = 1.0/(double)(n+1);
| 243 |
scalescolor(ar.rcol, zd);
| 244 |
zd *= (double)n;
| 245 |
scalescolor(ap->v, zd);
| 246 |
saddscolor(ap->v, ar.rcol);
| 247 |
| 248 |
saddscolor(hp->acol, ap->v); /* add to our sum */
| 249 |
return(1);
| 250 |
| 251 |
| 252 |
| 253 |
/* Estimate variance based on ambient division differences */
| 254 |
static float *
| 255 |
getambdiffs(AMBHEMI *hp)
| 256 |
| 257 |
const double normf = 1./(pbright(hp->acoef) + FTINY);
| 258 |
float *earr = (float *)calloc(2*hp->ns*hp->ns, sizeof(float));
| 259 |
float *ep;
| 260 |
AMBSAMP *ap;
| 261 |
double b, b1, d2;
| 262 |
int i, j;
| 263 |
| 264 |
if (earr == NULL) /* out of memory? */
| 265 |
return(NULL);
| 266 |
/* sum squared neighbor diffs */
| 267 |
ap = hp->sa;
| 268 |
ep = earr + hp->ns*hp->ns; /* original estimates to scratch */
| 269 |
for (i = 0; i < hp->ns; i++)
| 270 |
for (j = 0; j < hp->ns; j++, ap++, ep++) {
| 271 |
b = pbright(ap[0].v);
| 272 |
if (i) { /* from above */
| 273 |
b1 = pbright(ap[-hp->ns].v);
| 274 |
d2 = b - b1;
| 275 |
d2 *= d2*normf/(b + b1 + FTINY);
| 276 |
ep[0] += d2;
| 277 |
ep[-hp->ns] += d2;
| 278 |
| 279 |
if (!j) continue;
| 280 |
/* from behind */
| 281 |
b1 = pbright(ap[-1].v);
| 282 |
d2 = b - b1;
| 283 |
| 284 |
ep[0] += d2;
| 285 |
ep[-1] += d2;
| 286 |
if (!i) continue;
| 287 |
/* diagonal */
| 288 |
b1 = pbright(ap[-hp->ns-1].v);
| 289 |
d2 = b - b1;
| 290 |
| 291 |
ep[0] += d2;
| 292 |
ep[-hp->ns-1] += d2;
| 293 |
| 294 |
/* correct for number of neighbors */
| 295 |
| 296 |
ep[0] *= 6./3.;
| 297 |
ep[hp->ns-1] *= 6./3.;
| 298 |
ep[(hp->ns-1)*hp->ns] *= 6./3.;
| 299 |
ep[(hp->ns-1)*hp->ns + hp->ns-1] *= 6./3.;
| 300 |
for (i = 1; i < hp->ns-1; i++) {
| 301 |
ep[i*hp->ns] *= 6./5.;
| 302 |
ep[i*hp->ns + hp->ns-1] *= 6./5.;
| 303 |
| 304 |
for (j = 1; j < hp->ns-1; j++) {
| 305 |
ep[j] *= 6./5.;
| 306 |
ep[(hp->ns-1)*hp->ns + j] *= 6./5.;
| 307 |
| 308 |
/* blur final map to reduce bias */
| 309 |
for (i = 0; i < hp->ns-1; i++) {
| 310 |
float *ep2;
| 311 |
ep = earr + i*hp->ns;
| 312 |
ep2 = ep + hp->ns*hp->ns;
| 313 |
for (j = 0; j < hp->ns-1; j++, ep++, ep2++) {
| 314 |
ep[0] += .5*ep2[0] + .125*(ep2[1] + ep2[hp->ns]);
| 315 |
ep[1] += .125*ep2[0];
| 316 |
ep[hp->ns] += .125*ep2[0];
| 317 |
| 318 |
| 319 |
return(earr);
| 320 |
| 321 |
| 322 |
| 323 |
/* Perform super-sampling on hemisphere (introduces bias) */
| 324 |
static void
| 325 |
ambsupersamp(AMBHEMI *hp, int cnt)
| 326 |
| 327 |
float *earr = getambdiffs(hp);
| 328 |
double e2rem = 0;
| 329 |
float *ep;
| 330 |
int i, j, n, nss;
| 331 |
| 332 |
if (earr == NULL) /* just skip calc. if no memory */
| 333 |
return;
| 334 |
/* accumulate estimated variances */
| 335 |
for (ep = earr + hp->ns*hp->ns; ep > earr; )
| 336 |
e2rem += *--ep;
| 337 |
ep = earr; /* perform super-sampling */
| 338 |
| 339 |
for (j = 0; j < hp->ns; j++) {
| 340 |
if (e2rem <= FTINY)
| 341 |
goto done; /* nothing left to do */
| 342 |
nss = *ep/e2rem*cnt + frandom();
| 343 |
for (n = 1; n <= nss && ambsample(hp,i,j,n); n++)
| 344 |
if (!--cnt) goto done;
| 345 |
e2rem -= *ep++; /* update remainder */
| 346 |
| 347 |
done:
| 348 |
free(earr);
| 349 |
| 350 |
| 351 |
| 352 |
static AMBHEMI *
| 353 |
samp_hemi( /* sample indirect hemisphere */
| 354 |
SCOLOR rcol,
| 355 |
RAY *r,
| 356 |
double wt
| 357 |
| 358 |
| 359 |
int backside = (wt < 0);
| 360 |
AMBHEMI *hp;
| 361 |
double d;
| 362 |
int n, i, j;
| 363 |
/* insignificance check */
| 364 |
d = sintens(rcol);
| 365 |
if (d <= FTINY)
| 366 |
return(NULL);
| 367 |
/* set number of divisions */
| 368 |
if (backside) wt = -wt;
| 369 |
if (ambacc <= FTINY &&
| 370 |
wt > (d *= 0.8*r->rweight/(ambdiv*minweight + 1e-20)))
| 371 |
wt = d; /* avoid ray termination */
| 372 |
n = sqrt(ambdiv * wt) + 0.5;
| 373 |
i = 1 + (MINADIV-1)*(ambacc > FTINY);
| 374 |
if (n < i) /* use minimum number of samples? */
| 375 |
n = i;
| 376 |
/* allocate sampling array */
| 377 |
hp = (AMBHEMI *)malloc(sizeof(AMBHEMI) + sizeof(AMBSAMP)*(n*n - 1));
| 378 |
if (hp == NULL)
| 379 |
error(SYSTEM, "out of memory in samp_hemi");
| 380 |
| 381 |
if (backside) {
| 382 |
hp->atyp = TAMBIENT;
| 383 |
hp->onrm[0] = -r->ron[0];
| 384 |
hp->onrm[1] = -r->ron[1];
| 385 |
hp->onrm[2] = -r->ron[2];
| 386 |
} else {
| 387 |
hp->atyp = RAMBIENT;
| 388 |
VCOPY(hp->onrm, r->ron);
| 389 |
| 390 |
hp->rp = r;
| 391 |
hp->ns = n;
| 392 |
scolorblack(hp->acol);
| 393 |
memset(hp->sa, 0, sizeof(AMBSAMP)*n*n);
| 394 |
hp->sampOK = 0;
| 395 |
/* assign coefficient */
| 396 |
copyscolor(hp->acoef, rcol);
| 397 |
d = 1.0/(n*n);
| 398 |
scalescolor(hp->acoef, d);
| 399 |
/* make tangent plane axes */
| 400 |
if (!getperpendicular(hp->ux, hp->onrm, 1))
| 401 |
error(CONSISTENCY, "bad ray direction in samp_hemi");
| 402 |
VCROSS(hp->uy, hp->onrm, hp->ux);
| 403 |
/* sample divisions */
| 404 |
for (i = hp->ns; i--; )
| 405 |
for (j = hp->ns; j--; )
| 406 |
hp->sampOK += ambsample(hp, i, j, 0);
| 407 |
copyscolor(rcol, hp->acol);
| 408 |
if (!hp->sampOK) { /* utter failure? */
| 409 |
free(hp);
| 410 |
return(NULL);
| 411 |
| 412 |
if (hp->sampOK < hp->ns*hp->ns) {
| 413 |
hp->sampOK *= -1; /* soft failure */
| 414 |
return(hp);
| 415 |
| 416 |
if (hp->sampOK <= MINADIV*MINADIV)
| 417 |
return(hp); /* don't bother super-sampling */
| 418 |
n = ambssamp*wt + 0.5;
| 419 |
if (n >= 4*hp->ns) { /* perform super-sampling? */
| 420 |
ambsupersamp(hp, n);
| 421 |
| 422 |
| 423 |
return(hp); /* all is well */
| 424 |
| 425 |
| 426 |
| 427 |
/* Return brightness of farthest ambient sample */
| 428 |
static double
| 429 |
back_ambval(AMBHEMI *hp, const int n1, const int n2, const int n3)
| 430 |
| 431 |
if (hp->sa[n1].d <= hp->sa[n2].d) {
| 432 |
if (hp->sa[n1].d <= hp->sa[n3].d)
| 433 |
return(hp->sa[n1].v[0]);
| 434 |
return(hp->sa[n3].v[0]);
| 435 |
| 436 |
if (hp->sa[n2].d <= hp->sa[n3].d)
| 437 |
return(hp->sa[n2].v[0]);
| 438 |
| 439 |
| 440 |
| 441 |
| 442 |
/* Compute vectors and coefficients for Hessian/gradient calcs */
| 443 |
static void
| 444 |
comp_fftri(FFTRI *ftp, AMBHEMI *hp, const int n0, const int n1)
| 445 |
| 446 |
double rdot_cp, dot_e, dot_er, rdot_r, rdot_r1, J2;
| 447 |
int ii;
| 448 |
| 449 |
VSUB(ftp->r_i, hp->sa[n0].p, hp->rp->rop);
| 450 |
VSUB(ftp->r_i1, hp->sa[n1].p, hp->rp->rop);
| 451 |
VSUB(ftp->e_i, hp->sa[n1].p, hp->sa[n0].p);
| 452 |
VCROSS(ftp->rcp, ftp->r_i, ftp->r_i1);
| 453 |
rdot_cp = 1.0/DOT(ftp->rcp,ftp->rcp);
| 454 |
dot_e = DOT(ftp->e_i,ftp->e_i);
| 455 |
dot_er = DOT(ftp->e_i, ftp->r_i);
| 456 |
rdot_r = 1.0/DOT(ftp->r_i,ftp->r_i);
| 457 |
rdot_r1 = 1.0/DOT(ftp->r_i1,ftp->r_i1);
| 458 |
ftp->I1 = acos( DOT(ftp->r_i, ftp->r_i1) * sqrt(rdot_r*rdot_r1) ) *
| 459 |
sqrt( rdot_cp );
| 460 |
ftp->I2 = ( DOT(ftp->e_i, ftp->r_i1)*rdot_r1 - dot_er*rdot_r +
| 461 |
dot_e*ftp->I1 )*0.5*rdot_cp;
| 462 |
J2 = ( 0.5*(rdot_r - rdot_r1) - dot_er*ftp->I2 ) / dot_e;
| 463 |
| 464 |
ftp->rI2_eJ2[ii] = ftp->I2*ftp->r_i[ii] + J2*ftp->e_i[ii];
| 465 |
| 466 |
| 467 |
| 468 |
/* Compose 3x3 matrix from two vectors */
| 469 |
static void
| 470 |
compose_matrix(FVECT mat[3], FVECT va, FVECT vb)
| 471 |
| 472 |
mat[0][0] = 2.0*va[0]*vb[0];
| 473 |
mat[1][1] = 2.0*va[1]*vb[1];
| 474 |
mat[2][2] = 2.0*va[2]*vb[2];
| 475 |
mat[0][1] = mat[1][0] = va[0]*vb[1] + va[1]*vb[0];
| 476 |
mat[0][2] = mat[2][0] = va[0]*vb[2] + va[2]*vb[0];
| 477 |
mat[1][2] = mat[2][1] = va[1]*vb[2] + va[2]*vb[1];
| 478 |
| 479 |
| 480 |
| 481 |
/* Compute partial 3x3 Hessian matrix for edge */
| 482 |
static void
| 483 |
comp_hessian(FVECT hess[3], FFTRI *ftp, FVECT nrm)
| 484 |
| 485 |
FVECT ncp;
| 486 |
FVECT m1[3], m2[3], m3[3], m4[3];
| 487 |
double d1, d2, d3, d4;
| 488 |
double I3, J3, K3;
| 489 |
int i, j;
| 490 |
/* compute intermediate coefficients */
| 491 |
d1 = 1.0/DOT(ftp->r_i,ftp->r_i);
| 492 |
d2 = 1.0/DOT(ftp->r_i1,ftp->r_i1);
| 493 |
d3 = 1.0/DOT(ftp->e_i,ftp->e_i);
| 494 |
d4 = DOT(ftp->e_i, ftp->r_i);
| 495 |
I3 = ( DOT(ftp->e_i, ftp->r_i1)*d2*d2 - d4*d1*d1 + 3.0/d3*ftp->I2 )
| 496 |
/ ( 4.0*DOT(ftp->rcp,ftp->rcp) );
| 497 |
J3 = 0.25*d3*(d1*d1 - d2*d2) - d4*d3*I3;
| 498 |
K3 = d3*(ftp->I2 - I3/d1 - 2.0*d4*J3);
| 499 |
/* intermediate matrices */
| 500 |
VCROSS(ncp, nrm, ftp->e_i);
| 501 |
compose_matrix(m1, ncp, ftp->rI2_eJ2);
| 502 |
compose_matrix(m2, ftp->r_i, ftp->r_i);
| 503 |
compose_matrix(m3, ftp->e_i, ftp->e_i);
| 504 |
compose_matrix(m4, ftp->r_i, ftp->e_i);
| 505 |
d1 = DOT(nrm, ftp->rcp);
| 506 |
d2 = -d1*ftp->I2;
| 507 |
d1 *= 2.0;
| 508 |
for (i = 3; i--; ) /* final matrix sum */
| 509 |
for (j = 3; j--; ) {
| 510 |
hess[i][j] = m1[i][j] + d1*( I3*m2[i][j] + K3*m3[i][j] +
| 511 |
2.0*J3*m4[i][j] );
| 512 |
hess[i][j] += d2*(i==j);
| 513 |
hess[i][j] *= -1.0/PI;
| 514 |
| 515 |
| 516 |
| 517 |
| 518 |
/* Reverse hessian calculation result for edge in other direction */
| 519 |
static void
| 520 |
rev_hessian(FVECT hess[3])
| 521 |
| 522 |
int i;
| 523 |
| 524 |
for (i = 3; i--; ) {
| 525 |
hess[i][0] = -hess[i][0];
| 526 |
hess[i][1] = -hess[i][1];
| 527 |
hess[i][2] = -hess[i][2];
| 528 |
| 529 |
| 530 |
| 531 |
| 532 |
/* Add to radiometric Hessian from the given triangle */
| 533 |
static void
| 534 |
add2hessian(FVECT hess[3], FVECT ehess1[3],
| 535 |
FVECT ehess2[3], FVECT ehess3[3], double v)
| 536 |
| 537 |
int i, j;
| 538 |
| 539 |
for (i = 3; i--; )
| 540 |
for (j = 3; j--; )
| 541 |
hess[i][j] += v*( ehess1[i][j] + ehess2[i][j] + ehess3[i][j] );
| 542 |
| 543 |
| 544 |
| 545 |
/* Compute partial displacement form factor gradient for edge */
| 546 |
static void
| 547 |
comp_gradient(FVECT grad, FFTRI *ftp, FVECT nrm)
| 548 |
| 549 |
FVECT ncp;
| 550 |
double f1;
| 551 |
int i;
| 552 |
| 553 |
f1 = 2.0*DOT(nrm, ftp->rcp);
| 554 |
| 555 |
for (i = 3; i--; )
| 556 |
grad[i] = (0.5/PI)*( ftp->I1*ncp[i] + f1*ftp->rI2_eJ2[i] );
| 557 |
| 558 |
| 559 |
| 560 |
/* Reverse gradient calculation result for edge in other direction */
| 561 |
static void
| 562 |
rev_gradient(FVECT grad)
| 563 |
| 564 |
grad[0] = -grad[0];
| 565 |
grad[1] = -grad[1];
| 566 |
grad[2] = -grad[2];
| 567 |
| 568 |
| 569 |
| 570 |
/* Add to displacement gradient from the given triangle */
| 571 |
static void
| 572 |
add2gradient(FVECT grad, FVECT egrad1, FVECT egrad2, FVECT egrad3, double v)
| 573 |
| 574 |
int i;
| 575 |
| 576 |
for (i = 3; i--; )
| 577 |
grad[i] += v*( egrad1[i] + egrad2[i] + egrad3[i] );
| 578 |
| 579 |
| 580 |
| 581 |
/* Compute anisotropic radii and eigenvector directions */
| 582 |
static void
| 583 |
eigenvectors(FVECT uv[2], float ra[2], FVECT hessian[3])
| 584 |
| 585 |
double hess2[2][2];
| 586 |
FVECT a, b;
| 587 |
double evalue[2], slope1, xmag1;
| 588 |
int i;
| 589 |
/* project Hessian to sample plane */
| 590 |
| 591 |
a[i] = DOT(hessian[i], uv[0]);
| 592 |
b[i] = DOT(hessian[i], uv[1]);
| 593 |
| 594 |
hess2[0][0] = DOT(uv[0], a);
| 595 |
hess2[0][1] = DOT(uv[0], b);
| 596 |
hess2[1][0] = DOT(uv[1], a);
| 597 |
hess2[1][1] = DOT(uv[1], b);
| 598 |
/* compute eigenvalue(s) */
| 599 |
i = quadratic(evalue, 1.0, -hess2[0][0]-hess2[1][1],
| 600 |
hess2[0][0]*hess2[1][1]-hess2[0][1]*hess2[1][0]);
| 601 |
if (i == 1) /* double-root (circle) */
| 602 |
evalue[1] = evalue[0];
| 603 |
if (!i || ((evalue[0] = fabs(evalue[0])) <= FTINY*FTINY) |
| 604 |
((evalue[1] = fabs(evalue[1])) <= FTINY*FTINY) ) {
| 605 |
ra[0] = ra[1] = maxarad;
| 606 |
return;
| 607 |
| 608 |
if (evalue[0] > evalue[1]) {
| 609 |
ra[0] = sqrt(sqrt(4.0/evalue[0]));
| 610 |
ra[1] = sqrt(sqrt(4.0/evalue[1]));
| 611 |
slope1 = evalue[1];
| 612 |
} else {
| 613 |
ra[0] = sqrt(sqrt(4.0/evalue[1]));
| 614 |
ra[1] = sqrt(sqrt(4.0/evalue[0]));
| 615 |
slope1 = evalue[0];
| 616 |
| 617 |
/* compute unit eigenvectors */
| 618 |
if (fabs(hess2[0][1]) <= FTINY)
| 619 |
return; /* uv OK as is */
| 620 |
slope1 = (slope1 - hess2[0][0]) / hess2[0][1];
| 621 |
xmag1 = sqrt(1.0/(1.0 + slope1*slope1));
| 622 |
| 623 |
b[i] = xmag1*uv[0][i] + slope1*xmag1*uv[1][i];
| 624 |
a[i] = slope1*xmag1*uv[0][i] - xmag1*uv[1][i];
| 625 |
| 626 |
VCOPY(uv[0], a);
| 627 |
VCOPY(uv[1], b);
| 628 |
| 629 |
| 630 |
| 631 |
static void
| 632 |
ambHessian( /* anisotropic radii & pos. gradient */
| 633 |
AMBHEMI *hp,
| 634 |
FVECT uv[2], /* returned */
| 635 |
float ra[2], /* returned (optional) */
| 636 |
float pg[2] /* returned (optional) */
| 637 |
| 638 |
| 639 |
static char memerrmsg[] = "out of memory in ambHessian()";
| 640 |
FVECT (*hessrow)[3] = NULL;
| 641 |
FVECT *gradrow = NULL;
| 642 |
FVECT hessian[3];
| 643 |
FVECT gradient;
| 644 |
FFTRI fftr;
| 645 |
int i, j;
| 646 |
/* be sure to assign unit vectors */
| 647 |
VCOPY(uv[0], hp->ux);
| 648 |
VCOPY(uv[1], hp->uy);
| 649 |
/* clock-wise vertex traversal from sample POV */
| 650 |
if (ra != NULL) { /* initialize Hessian row buffer */
| 651 |
hessrow = (FVECT (*)[3])malloc(sizeof(FVECT)*3*(hp->ns-1));
| 652 |
if (hessrow == NULL)
| 653 |
error(SYSTEM, memerrmsg);
| 654 |
memset(hessian, 0, sizeof(hessian));
| 655 |
} else if (pg == NULL) /* bogus call? */
| 656 |
return;
| 657 |
if (pg != NULL) { /* initialize form factor row buffer */
| 658 |
gradrow = (FVECT *)malloc(sizeof(FVECT)*(hp->ns-1));
| 659 |
if (gradrow == NULL)
| 660 |
| 661 |
memset(gradient, 0, sizeof(gradient));
| 662 |
| 663 |
/* compute first row of edges */
| 664 |
for (j = 0; j < hp->ns-1; j++) {
| 665 |
comp_fftri(&fftr, hp, AI(hp,0,j), AI(hp,0,j+1));
| 666 |
if (hessrow != NULL)
| 667 |
comp_hessian(hessrow[j], &fftr, hp->onrm);
| 668 |
if (gradrow != NULL)
| 669 |
comp_gradient(gradrow[j], &fftr, hp->onrm);
| 670 |
| 671 |
/* sum each row of triangles */
| 672 |
| 673 |
FVECT hesscol[3]; /* compute first vertical edge */
| 674 |
FVECT gradcol;
| 675 |
comp_fftri(&fftr, hp, AI(hp,i,0), AI(hp,i+1,0));
| 676 |
| 677 |
comp_hessian(hesscol, &fftr, hp->onrm);
| 678 |
| 679 |
comp_gradient(gradcol, &fftr, hp->onrm);
| 680 |
| 681 |
FVECT hessdia[3]; /* compute triangle contributions */
| 682 |
FVECT graddia;
| 683 |
double backg;
| 684 |
backg = back_ambval(hp, AI(hp,i,j),
| 685 |
AI(hp,i,j+1), AI(hp,i+1,j));
| 686 |
/* diagonal (inner) edge */
| 687 |
comp_fftri(&fftr, hp, AI(hp,i,j+1), AI(hp,i+1,j));
| 688 |
if (hessrow != NULL) {
| 689 |
comp_hessian(hessdia, &fftr, hp->onrm);
| 690 |
rev_hessian(hesscol);
| 691 |
add2hessian(hessian, hessrow[j], hessdia, hesscol, backg);
| 692 |
| 693 |
if (gradrow != NULL) {
| 694 |
comp_gradient(graddia, &fftr, hp->onrm);
| 695 |
rev_gradient(gradcol);
| 696 |
add2gradient(gradient, gradrow[j], graddia, gradcol, backg);
| 697 |
| 698 |
/* initialize edge in next row */
| 699 |
comp_fftri(&fftr, hp, AI(hp,i+1,j+1), AI(hp,i+1,j));
| 700 |
| 701 |
| 702 |
| 703 |
| 704 |
/* new column edge & paired triangle */
| 705 |
backg = back_ambval(hp, AI(hp,i+1,j+1),
| 706 |
AI(hp,i+1,j), AI(hp,i,j+1));
| 707 |
comp_fftri(&fftr, hp, AI(hp,i,j+1), AI(hp,i+1,j+1));
| 708 |
| 709 |
| 710 |
rev_hessian(hessdia);
| 711 |
| 712 |
if (i < hp->ns-2)
| 713 |
rev_hessian(hessrow[j]);
| 714 |
| 715 |
| 716 |
| 717 |
rev_gradient(graddia);
| 718 |
| 719 |
if (i < hp->ns-2)
| 720 |
rev_gradient(gradrow[j]);
| 721 |
| 722 |
| 723 |
| 724 |
/* release row buffers */
| 725 |
if (hessrow != NULL) free(hessrow);
| 726 |
if (gradrow != NULL) free(gradrow);
| 727 |
| 728 |
if (ra != NULL) /* extract eigenvectors & radii */
| 729 |
eigenvectors(uv, ra, hessian);
| 730 |
if (pg != NULL) { /* tangential position gradient */
| 731 |
pg[0] = DOT(gradient, uv[0]);
| 732 |
pg[1] = DOT(gradient, uv[1]);
| 733 |
| 734 |
| 735 |
| 736 |
| 737 |
/* Compute direction gradient from a hemispherical sampling */
| 738 |
static void
| 739 |
ambdirgrad(AMBHEMI *hp, FVECT uv[2], float dg[2])
| 740 |
| 741 |
AMBSAMP *ap;
| 742 |
double dgsum[2];
| 743 |
int n;
| 744 |
FVECT vd;
| 745 |
double gfact;
| 746 |
| 747 |
dgsum[0] = dgsum[1] = 0.0; /* sum values times -tan(theta) */
| 748 |
for (ap = hp->sa, n = hp->ns*hp->ns; n--; ap++) {
| 749 |
/* use vector for azimuth + 90deg */
| 750 |
VSUB(vd, ap->p, hp->rp->rop);
| 751 |
/* brightness over cosine factor */
| 752 |
gfact = ap->v[0] / DOT(hp->onrm, vd);
| 753 |
/* sine = proj_radius/vd_length */
| 754 |
dgsum[0] -= DOT(uv[1], vd) * gfact;
| 755 |
dgsum[1] += DOT(uv[0], vd) * gfact;
| 756 |
| 757 |
dg[0] = dgsum[0] / (hp->ns*hp->ns);
| 758 |
dg[1] = dgsum[1] / (hp->ns*hp->ns);
| 759 |
| 760 |
| 761 |
| 762 |
/* Compute potential light leak direction flags for cache value */
| 763 |
static uint32
| 764 |
ambcorral(AMBHEMI *hp, FVECT uv[2], const double r0, const double r1)
| 765 |
| 766 |
const double max_d = 1.0/(minarad*ambacc + 0.001);
| 767 |
const double ang_res = 0.5*PI/hp->ns;
| 768 |
const double ang_step = ang_res/((int)(16/PI*ang_res) + 1.01);
| 769 |
double avg_d = 0;
| 770 |
uint32 flgs = 0;
| 771 |
FVECT vec;
| 772 |
double u, v;
| 773 |
double ang, a1;
| 774 |
int i, j;
| 775 |
/* don't bother for a few samples */
| 776 |
if (hp->ns < 8)
| 777 |
return(0);
| 778 |
/* check distances overhead */
| 779 |
for (i = hp->ns*3/4; i-- > hp->ns>>2; )
| 780 |
for (j = hp->ns*3/4; j-- > hp->ns>>2; )
| 781 |
avg_d += ambsam(hp,i,j).d;
| 782 |
avg_d *= 4.0/(hp->ns*hp->ns);
| 783 |
if (avg_d*r0 >= 1.0) /* ceiling too low for corral? */
| 784 |
return(0);
| 785 |
if (avg_d >= max_d) /* insurance */
| 786 |
return(0);
| 787 |
/* else circle around perimeter */
| 788 |
| 789 |
for (j = 0; j < hp->ns; j += !i|(i==hp->ns-1) ? 1 : hp->ns-1) {
| 790 |
| 791 |
if ((ap->d <= FTINY) | (ap->d >= max_d))
| 792 |
continue; /* too far or too near */
| 793 |
VSUB(vec, ap->p, hp->rp->rop);
| 794 |
u = DOT(vec, uv[0]);
| 795 |
v = DOT(vec, uv[1]);
| 796 |
if ((r0*r0*u*u + r1*r1*v*v) * ap->d*ap->d <= u*u + v*v)
| 797 |
continue; /* occluder outside ellipse */
| 798 |
ang = atan2a(v, u); /* else set direction flags */
| 799 |
for (a1 = ang-ang_res; a1 <= ang+ang_res; a1 += ang_step)
| 800 |
flgs |= 1L<<(int)(16/PI*(a1 + 2.*PI*(a1 < 0)));
| 801 |
| 802 |
return(flgs);
| 803 |
| 804 |
| 805 |
| 806 |
int
| 807 |
doambient( /* compute ambient component */
| 808 |
SCOLOR rcol, /* input/output color */
| 809 |
RAY *r,
| 810 |
double wt, /* negative for back side */
| 811 |
FVECT uv[2], /* returned (optional) */
| 812 |
| 813 |
float pg[2], /* returned (optional) */
| 814 |
float dg[2], /* returned (optional) */
| 815 |
uint32 *crlp /* returned (optional) */
| 816 |
| 817 |
| 818 |
AMBHEMI *hp = samp_hemi(rcol, r, wt);
| 819 |
FVECT my_uv[2];
| 820 |
double d, K;
| 821 |
AMBSAMP *ap;
| 822 |
int i;
| 823 |
/* clear return values */
| 824 |
if (uv != NULL)
| 825 |
memset(uv, 0, sizeof(FVECT)*2);
| 826 |
if (ra != NULL)
| 827 |
ra[0] = ra[1] = 0.0;
| 828 |
if (pg != NULL)
| 829 |
pg[0] = pg[1] = 0.0;
| 830 |
if (dg != NULL)
| 831 |
dg[0] = dg[1] = 0.0;
| 832 |
if (crlp != NULL)
| 833 |
*crlp = 0;
| 834 |
if (hp == NULL) /* sampling falure? */
| 835 |
return(0);
| 836 |
| 837 |
if ((ra == NULL) & (pg == NULL) & (dg == NULL) ||
| 838 |
(hp->sampOK < 0) | (hp->ns < MINADIV)) {
| 839 |
free(hp); /* Hessian not requested/possible */
| 840 |
return(-1); /* value-only return value */
| 841 |
| 842 |
if ((d = scolor_mean(rcol)) > FTINY) {
| 843 |
d = 0.99*(hp->ns*hp->ns)/d; /* normalize avg. values */
| 844 |
K = 0.01;
| 845 |
} else { /* or fall back on geometric Hessian */
| 846 |
K = 1.0;
| 847 |
pg = NULL;
| 848 |
dg = NULL;
| 849 |
crlp = NULL;
| 850 |
| 851 |
ap = hp->sa; /* single channel from here on... */
| 852 |
for (i = hp->ns*hp->ns; i--; ap++)
| 853 |
ap->v[0] = scolor_mean(ap->v)*d + K;
| 854 |
| 855 |
if (uv == NULL) /* make sure we have axis pointers */
| 856 |
uv = my_uv;
| 857 |
/* compute radii & pos. gradient */
| 858 |
ambHessian(hp, uv, ra, pg);
| 859 |
| 860 |
if (dg != NULL) /* compute direction gradient */
| 861 |
ambdirgrad(hp, uv, dg);
| 862 |
| 863 |
if (ra != NULL) { /* scale/clamp radii */
| 864 |
if (pg != NULL) {
| 865 |
if (ra[0]*(d = fabs(pg[0])) > 1.0)
| 866 |
ra[0] = 1.0/d;
| 867 |
if (ra[1]*(d = fabs(pg[1])) > 1.0)
| 868 |
ra[1] = 1.0/d;
| 869 |
if (ra[0] > ra[1])
| 870 |
ra[0] = ra[1];
| 871 |
| 872 |
if (ra[0] < minarad) {
| 873 |
ra[0] = minarad;
| 874 |
if (ra[1] < minarad)
| 875 |
ra[1] = minarad;
| 876 |
| 877 |
ra[0] *= d = 1.0/sqrt(fabs(wt));
| 878 |
if ((ra[1] *= d) > 2.0*ra[0])
| 879 |
ra[1] = 2.0*ra[0];
| 880 |
if (ra[1] > maxarad) {
| 881 |
ra[1] = maxarad;
| 882 |
if (ra[0] > maxarad)
| 883 |
ra[0] = maxarad;
| 884 |
| 885 |
/* flag encroached directions */
| 886 |
if (crlp != NULL) /* XXX doesn't update with changes to ambacc */
| 887 |
*crlp = ambcorral(hp, uv, ra[0]*ambacc, ra[1]*ambacc);
| 888 |
if (pg != NULL) { /* cap gradient if necessary */
| 889 |
d = pg[0]*pg[0]*ra[0]*ra[0] + pg[1]*pg[1]*ra[1]*ra[1];
| 890 |
if (d > 1.0) {
| 891 |
d = 1.0/sqrt(d);
| 892 |
pg[0] *= d;
| 893 |
pg[1] *= d;
| 894 |
| 895 |
| 896 |
| 897 |
free(hp); /* clean up and return */
| 898 |
return(1);
| 899 |
