root/radiance/ray/src/rt/ambcomp.c
Revision: 2.92
Committed: Fri Apr 5 01:10:26 2024 UTC (16 months, 1 week ago) by greg
Changes since 2.91: +32 -18 lines
fix: Improved tracking of reflected vs. transmitted rays for antimatter
2 static const char RCSid[] = "$Id: ambcomp.c,v 2.91 2023/11/17 20:02:07 greg Exp $";
5 * Routines to compute "ambient" values using Monte Carlo
6 *
7 * Hessian calculations based on "Practical Hessian-Based Error Control
8 * for Irradiance Caching" by Schwarzhaupt, Wann Jensen, & Jarosz
9 * from ACM SIGGRAPH Asia 2012 conference proceedings.
10 *
11 * Added book-keeping optimization to avoid calculations that would
12 * cancel due to traversal both directions on edges that are adjacent
13 * to same-valued triangles. This cuts about half of Hessian math.
14 *
15 * Declarations of external symbols in ambient.h
16 */
17
18 #include "copyright.h"
19
20 #include "ray.h"
21 #include "ambient.h"
22 #include "random.h"
23
24 #ifndef MINADIV
25 #define MINADIV 7 /* minimum # divisions in each dimension */
26 #endif
27
28 typedef struct {
29 FVECT p; /* intersection point */
30 float d; /* reciprocal distance */
31 SCOLOR v; /* hemisphere sample value */
32 } AMBSAMP; /* sample value */
33
34 typedef struct {
35 RAY *rp; /* originating ray sample */
36 int ns; /* number of samples per axis */
37 int sampOK; /* acquired full sample set? */
38 int atyp; /* RAMBIENT or TAMBIENT */
39 SCOLOR acoef; /* division contribution coefficient */
40 SCOLOR acol; /* accumulated color */
41 FVECT onrm; /* oriented unperturbed surface normal */
42 FVECT ux, uy; /* tangent axis unit vectors */
43 AMBSAMP sa[1]; /* sample array (extends struct) */
44 } AMBHEMI; /* ambient sample hemisphere */
45
46 #define AI(h,i,j) ((i)*(h)->ns + (j))
47 #define ambsam(h,i,j) (h)->sa[AI(h,i,j)]
48
49 typedef struct {
50 FVECT r_i, r_i1, e_i, rcp, rI2_eJ2;
51 double I1, I2;
52 } FFTRI; /* vectors and coefficients for Hessian calculation */
53
54
55 static int
56 ambcollision( /* proposed direciton collides? */
57 AMBHEMI *hp,
58 int i,
59 int j,
60 FVECT dv
61 )
62 {
63 double cos_thresh;
64 int ii, jj;
65 /* min. spacing = 1/4th division */
66 cos_thresh = (PI/4.)/(double)hp->ns;
67 cos_thresh = 1. - .5*cos_thresh*cos_thresh;
68 /* check existing neighbors */
69 for (ii = i-1; ii <= i+1; ii++) {
70 if (ii < 0) continue;
71 if (ii >= hp->ns) break;
72 for (jj = j-1; jj <= j+1; jj++) {
73 AMBSAMP *ap;
74 FVECT avec;
75 double dprod;
76 if (jj < 0) continue;
77 if (jj >= hp->ns) break;
78 if ((ii==i) & (jj==j)) continue;
79 ap = &ambsam(hp,ii,jj);
80 if (ap->d <= .5/FHUGE)
81 continue; /* no one home */
82 VSUB(avec, ap->p, hp->rp->rop);
83 dprod = DOT(avec, dv);
84 if (dprod >= cos_thresh*VLEN(avec))
85 return(1); /* collision */
86 }
87 }
88 return(0); /* nothing to worry about */
89 }
90
91
92 static int
93 ambsample( /* initial ambient division sample */
94 AMBHEMI *hp,
95 int i,
96 int j,
97 int n
98 )
99 {
100 AMBSAMP *ap = &ambsam(hp,i,j);
101 RAY ar;
102 int hlist[3], ii;
103 RREAL spt[2];
104 double zd;
105 /* generate hemispherical sample */
106 /* ambient coefficient for weight */
107 if (ambacc > FTINY)
108 setscolor(ar.rcoef, AVGREFL, AVGREFL, AVGREFL);
109 else
110 copyscolor(ar.rcoef, hp->acoef);
111 if (rayorigin(&ar, hp->atyp, hp->rp, ar.rcoef) < 0)
112 return(0);
113 if (ambacc > FTINY) {
114 smultscolor(ar.rcoef, hp->acoef);
115 scalescolor(ar.rcoef, 1./AVGREFL);
116 }
117 hlist[0] = hp->rp->rno;
118 hlist[1] = j;
119 hlist[2] = i;
120 multisamp(spt, 2, urand(ilhash(hlist,3)+n));
121 resample:
122 square2disk(spt, (j+spt[1])/hp->ns, (i+spt[0])/hp->ns);
123 zd = sqrt(1. - spt[0]*spt[0] - spt[1]*spt[1]);
124 for (ii = 3; ii--; )
125 ar.rdir[ii] = spt[0]*hp->ux[ii] +
126 spt[1]*hp->uy[ii] +
127 zd*hp->onrm[ii];
128 checknorm(ar.rdir);
129 /* avoid coincident samples */
130 if (!n && ambcollision(hp, i, j, ar.rdir)) {
131 spt[0] = frandom(); spt[1] = frandom();
132 goto resample; /* reject this sample */
133 }
134 dimlist[ndims++] = AI(hp,i,j) + 90171;
135 rayvalue(&ar); /* evaluate ray */
136 ndims--;
137 zd = raydistance(&ar);
138 if (zd <= FTINY)
139 return(0); /* should never happen */
140 smultscolor(ar.rcol, ar.rcoef); /* apply coefficient */
141 if (zd*ap->d < 1.0) /* new/closer distance? */
142 ap->d = 1.0/zd;
143 if (!n) { /* record first vertex & value */
144 if (zd > 10.0*thescene.cusize + 1000.)
145 zd = 10.0*thescene.cusize + 1000.;
146 VSUM(ap->p, ar.rorg, ar.rdir, zd);
147 copyscolor(ap->v, ar.rcol);
148 } else { /* else update recorded value */
149 sopscolor(hp->acol, -=, ap->v);
150 zd = 1.0/(double)(n+1);
151 scalescolor(ar.rcol, zd);
152 zd *= (double)n;
153 scalescolor(ap->v, zd);
154 saddscolor(ap->v, ar.rcol);
155 }
156 saddscolor(hp->acol, ap->v); /* add to our sum */
157 return(1);
158 }
159
160
161 /* Estimate variance based on ambient division differences */
162 static float *
163 getambdiffs(AMBHEMI *hp)
164 {
165 const double normf = 1./bright(hp->acoef);
166 float *earr = (float *)calloc(hp->ns*hp->ns, sizeof(float));
167 float *ep;
168 AMBSAMP *ap;
169 double b, b1, d2;
170 int i, j;
171
172 if (earr == NULL) /* out of memory? */
173 return(NULL);
174 /* sum squared neighbor diffs */
175 for (ap = hp->sa, ep = earr, i = 0; i < hp->ns; i++)
176 for (j = 0; j < hp->ns; j++, ap++, ep++) {
177 b = pbright(ap[0].v);
178 if (i) { /* from above */
179 b1 = pbright(ap[-hp->ns].v);
180 d2 = b - b1;
181 d2 *= d2*normf/(b + b1 + FTINY);
182 ep[0] += d2;
183 ep[-hp->ns] += d2;
184 }
185 if (!j) continue;
186 /* from behind */
187 b1 = pbright(ap[-1].v);
188 d2 = b - b1;
189 d2 *= d2*normf/(b + b1 + FTINY);
190 ep[0] += d2;
191 ep[-1] += d2;
192 if (!i) continue;
193 /* diagonal */
194 b1 = pbright(ap[-hp->ns-1].v);
195 d2 = b - b1;
196 d2 *= d2*normf/(b + b1 + FTINY);
197 ep[0] += d2;
198 ep[-hp->ns-1] += d2;
199 }
200 /* correct for number of neighbors */
201 earr[0] *= 8./3.;
202 earr[hp->ns-1] *= 8./3.;
203 earr[(hp->ns-1)*hp->ns] *= 8./3.;
204 earr[(hp->ns-1)*hp->ns + hp->ns-1] *= 8./3.;
205 for (i = 1; i < hp->ns-1; i++) {
206 earr[i*hp->ns] *= 8./5.;
207 earr[i*hp->ns + hp->ns-1] *= 8./5.;
208 }
209 for (j = 1; j < hp->ns-1; j++) {
210 earr[j] *= 8./5.;
211 earr[(hp->ns-1)*hp->ns + j] *= 8./5.;
212 }
213 return(earr);
214 }
215
216
217 /* Perform super-sampling on hemisphere (introduces bias) */
218 static void
219 ambsupersamp(AMBHEMI *hp, int cnt)
220 {
221 float *earr = getambdiffs(hp);
222 double e2rem = 0;
223 float *ep;
224 int i, j, n, nss;
225
226 if (earr == NULL) /* just skip calc. if no memory */
227 return;
228 /* accumulate estimated variances */
229 for (ep = earr + hp->ns*hp->ns; ep > earr; )
230 e2rem += *--ep;
231 ep = earr; /* perform super-sampling */
232 for (i = 0; i < hp->ns; i++)
233 for (j = 0; j < hp->ns; j++) {
234 if (e2rem <= FTINY)
235 goto done; /* nothing left to do */
236 nss = *ep/e2rem*cnt + frandom();
237 for (n = 1; n <= nss && ambsample(hp,i,j,n); n++)
238 if (!--cnt) goto done;
239 e2rem -= *ep++; /* update remainder */
240 }
241 done:
242 free(earr);
243 }
244
245
246 static AMBHEMI *
247 samp_hemi( /* sample indirect hemisphere */
248 SCOLOR rcol,
249 RAY *r,
250 double wt
251 )
252 {
253 int backside = (wt < 0);
254 AMBHEMI *hp;
255 double d;
256 int n, i, j;
257 /* insignificance check */
258 d = sintens(rcol);
259 if (d <= FTINY)
260 return(NULL);
261 /* set number of divisions */
262 if (backside) wt = -wt;
263 if (ambacc <= FTINY &&
264 wt > (d *= 0.8*r->rweight/(ambdiv*minweight)))
265 wt = d; /* avoid ray termination */
266 n = sqrt(ambdiv * wt) + 0.5;
267 i = 1 + (MINADIV-1)*(ambacc > FTINY);
268 if (n < i) /* use minimum number of samples? */
269 n = i;
270 /* allocate sampling array */
271 hp = (AMBHEMI *)malloc(sizeof(AMBHEMI) + sizeof(AMBSAMP)*(n*n - 1));
272 if (hp == NULL)
273 error(SYSTEM, "out of memory in samp_hemi");
274
275 if (backside) {
276 hp->atyp = TAMBIENT;
277 hp->onrm[0] = -r->ron[0];
278 hp->onrm[1] = -r->ron[1];
279 hp->onrm[2] = -r->ron[2];
280 } else {
281 hp->atyp = RAMBIENT;
282 VCOPY(hp->onrm, r->ron);
283 }
284 hp->rp = r;
285 hp->ns = n;
286 scolorblack(hp->acol);
287 memset(hp->sa, 0, sizeof(AMBSAMP)*n*n);
288 hp->sampOK = 0;
289 /* assign coefficient */
290 copyscolor(hp->acoef, rcol);
291 d = 1.0/(n*n);
292 scalescolor(hp->acoef, d);
293 /* make tangent plane axes */
294 if (!getperpendicular(hp->ux, hp->onrm, 1))
295 error(CONSISTENCY, "bad ray direction in samp_hemi");
296 VCROSS(hp->uy, hp->onrm, hp->ux);
297 /* sample divisions */
298 for (i = hp->ns; i--; )
299 for (j = hp->ns; j--; )
300 hp->sampOK += ambsample(hp, i, j, 0);
301 copyscolor(rcol, hp->acol);
302 if (!hp->sampOK) { /* utter failure? */
303 free(hp);
304 return(NULL);
305 }
306 if (hp->sampOK < hp->ns*hp->ns) {
307 hp->sampOK *= -1; /* soft failure */
308 return(hp);
309 }
310 if (hp->sampOK <= MINADIV*MINADIV)
311 return(hp); /* don't bother super-sampling */
312 n = ambssamp*wt + 0.5;
313 if (n > 8) { /* perform super-sampling? */
314 ambsupersamp(hp, n);
315 copyscolor(rcol, hp->acol);
316 }
317 return(hp); /* all is well */
318 }
319
320
321 /* Return brightness of farthest ambient sample */
322 static double
323 back_ambval(AMBHEMI *hp, const int n1, const int n2, const int n3)
324 {
325 if (hp->sa[n1].d <= hp->sa[n2].d) {
326 if (hp->sa[n1].d <= hp->sa[n3].d)
327 return(hp->sa[n1].v[0]);
328 return(hp->sa[n3].v[0]);
329 }
330 if (hp->sa[n2].d <= hp->sa[n3].d)
331 return(hp->sa[n2].v[0]);
332 return(hp->sa[n3].v[0]);
333 }
334
335
336 /* Compute vectors and coefficients for Hessian/gradient calcs */
337 static void
338 comp_fftri(FFTRI *ftp, AMBHEMI *hp, const int n0, const int n1)
339 {
340 double rdot_cp, dot_e, dot_er, rdot_r, rdot_r1, J2;
341 int ii;
342
343 VSUB(ftp->r_i, hp->sa[n0].p, hp->rp->rop);
344 VSUB(ftp->r_i1, hp->sa[n1].p, hp->rp->rop);
345 VSUB(ftp->e_i, hp->sa[n1].p, hp->sa[n0].p);
346 VCROSS(ftp->rcp, ftp->r_i, ftp->r_i1);
347 rdot_cp = 1.0/DOT(ftp->rcp,ftp->rcp);
348 dot_e = DOT(ftp->e_i,ftp->e_i);
349 dot_er = DOT(ftp->e_i, ftp->r_i);
350 rdot_r = 1.0/DOT(ftp->r_i,ftp->r_i);
351 rdot_r1 = 1.0/DOT(ftp->r_i1,ftp->r_i1);
352 ftp->I1 = acos( DOT(ftp->r_i, ftp->r_i1) * sqrt(rdot_r*rdot_r1) ) *
353 sqrt( rdot_cp );
354 ftp->I2 = ( DOT(ftp->e_i, ftp->r_i1)*rdot_r1 - dot_er*rdot_r +
355 dot_e*ftp->I1 )*0.5*rdot_cp;
356 J2 = ( 0.5*(rdot_r - rdot_r1) - dot_er*ftp->I2 ) / dot_e;
357 for (ii = 3; ii--; )
358 ftp->rI2_eJ2[ii] = ftp->I2*ftp->r_i[ii] + J2*ftp->e_i[ii];
359 }
360
361
362 /* Compose 3x3 matrix from two vectors */
363 static void
364 compose_matrix(FVECT mat[3], FVECT va, FVECT vb)
365 {
366 mat[0][0] = 2.0*va[0]*vb[0];
367 mat[1][1] = 2.0*va[1]*vb[1];
368 mat[2][2] = 2.0*va[2]*vb[2];
369 mat[0][1] = mat[1][0] = va[0]*vb[1] + va[1]*vb[0];
370 mat[0][2] = mat[2][0] = va[0]*vb[2] + va[2]*vb[0];
371 mat[1][2] = mat[2][1] = va[1]*vb[2] + va[2]*vb[1];
372 }
373
374
375 /* Compute partial 3x3 Hessian matrix for edge */
376 static void
377 comp_hessian(FVECT hess[3], FFTRI *ftp, FVECT nrm)
378 {
379 FVECT ncp;
380 FVECT m1[3], m2[3], m3[3], m4[3];
381 double d1, d2, d3, d4;
382 double I3, J3, K3;
383 int i, j;
384 /* compute intermediate coefficients */
385 d1 = 1.0/DOT(ftp->r_i,ftp->r_i);
386 d2 = 1.0/DOT(ftp->r_i1,ftp->r_i1);
387 d3 = 1.0/DOT(ftp->e_i,ftp->e_i);
388 d4 = DOT(ftp->e_i, ftp->r_i);
389 I3 = ( DOT(ftp->e_i, ftp->r_i1)*d2*d2 - d4*d1*d1 + 3.0/d3*ftp->I2 )
390 / ( 4.0*DOT(ftp->rcp,ftp->rcp) );
391 J3 = 0.25*d3*(d1*d1 - d2*d2) - d4*d3*I3;
392 K3 = d3*(ftp->I2 - I3/d1 - 2.0*d4*J3);
393 /* intermediate matrices */
394 VCROSS(ncp, nrm, ftp->e_i);
395 compose_matrix(m1, ncp, ftp->rI2_eJ2);
396 compose_matrix(m2, ftp->r_i, ftp->r_i);
397 compose_matrix(m3, ftp->e_i, ftp->e_i);
398 compose_matrix(m4, ftp->r_i, ftp->e_i);
399 d1 = DOT(nrm, ftp->rcp);
400 d2 = -d1*ftp->I2;
401 d1 *= 2.0;
402 for (i = 3; i--; ) /* final matrix sum */
403 for (j = 3; j--; ) {
404 hess[i][j] = m1[i][j] + d1*( I3*m2[i][j] + K3*m3[i][j] +
405 2.0*J3*m4[i][j] );
406 hess[i][j] += d2*(i==j);
407 hess[i][j] *= -1.0/PI;
408 }
409 }
410
411
412 /* Reverse hessian calculation result for edge in other direction */
413 static void
414 rev_hessian(FVECT hess[3])
415 {
416 int i;
417
418 for (i = 3; i--; ) {
419 hess[i][0] = -hess[i][0];
420 hess[i][1] = -hess[i][1];
421 hess[i][2] = -hess[i][2];
422 }
423 }
424
425
426 /* Add to radiometric Hessian from the given triangle */
427 static void
428 add2hessian(FVECT hess[3], FVECT ehess1[3],
429 FVECT ehess2[3], FVECT ehess3[3], double v)
430 {
431 int i, j;
432
433 for (i = 3; i--; )
434 for (j = 3; j--; )
435 hess[i][j] += v*( ehess1[i][j] + ehess2[i][j] + ehess3[i][j] );
436 }
437
438
439 /* Compute partial displacement form factor gradient for edge */
440 static void
441 comp_gradient(FVECT grad, FFTRI *ftp, FVECT nrm)
442 {
443 FVECT ncp;
444 double f1;
445 int i;
446
447 f1 = 2.0*DOT(nrm, ftp->rcp);
448 VCROSS(ncp, nrm, ftp->e_i);
449 for (i = 3; i--; )
450 grad[i] = (0.5/PI)*( ftp->I1*ncp[i] + f1*ftp->rI2_eJ2[i] );
451 }
452
453
454 /* Reverse gradient calculation result for edge in other direction */
455 static void
456 rev_gradient(FVECT grad)
457 {
458 grad[0] = -grad[0];
459 grad[1] = -grad[1];
460 grad[2] = -grad[2];
461 }
462
463
464 /* Add to displacement gradient from the given triangle */
465 static void
466 add2gradient(FVECT grad, FVECT egrad1, FVECT egrad2, FVECT egrad3, double v)
467 {
468 int i;
469
470 for (i = 3; i--; )
471 grad[i] += v*( egrad1[i] + egrad2[i] + egrad3[i] );
472 }
473
474
475 /* Compute anisotropic radii and eigenvector directions */
476 static void
477 eigenvectors(FVECT uv[2], float ra[2], FVECT hessian[3])
478 {
479 double hess2[2][2];
480 FVECT a, b;
481 double evalue[2], slope1, xmag1;
482 int i;
483 /* project Hessian to sample plane */
484 for (i = 3; i--; ) {
485 a[i] = DOT(hessian[i], uv[0]);
486 b[i] = DOT(hessian[i], uv[1]);
487 }
488 hess2[0][0] = DOT(uv[0], a);
489 hess2[0][1] = DOT(uv[0], b);
490 hess2[1][0] = DOT(uv[1], a);
491 hess2[1][1] = DOT(uv[1], b);
492 /* compute eigenvalue(s) */
493 i = quadratic(evalue, 1.0, -hess2[0][0]-hess2[1][1],
494 hess2[0][0]*hess2[1][1]-hess2[0][1]*hess2[1][0]);
495 if (i == 1) /* double-root (circle) */
496 evalue[1] = evalue[0];
497 if (!i || ((evalue[0] = fabs(evalue[0])) <= FTINY*FTINY) |
498 ((evalue[1] = fabs(evalue[1])) <= FTINY*FTINY) ) {
499 ra[0] = ra[1] = maxarad;
500 return;
501 }
502 if (evalue[0] > evalue[1]) {
503 ra[0] = sqrt(sqrt(4.0/evalue[0]));
504 ra[1] = sqrt(sqrt(4.0/evalue[1]));
505 slope1 = evalue[1];
506 } else {
507 ra[0] = sqrt(sqrt(4.0/evalue[1]));
508 ra[1] = sqrt(sqrt(4.0/evalue[0]));
509 slope1 = evalue[0];
510 }
511 /* compute unit eigenvectors */
512 if (fabs(hess2[0][1]) <= FTINY)
513 return; /* uv OK as is */
514 slope1 = (slope1 - hess2[0][0]) / hess2[0][1];
515 xmag1 = sqrt(1.0/(1.0 + slope1*slope1));
516 for (i = 3; i--; ) {
517 b[i] = xmag1*uv[0][i] + slope1*xmag1*uv[1][i];
518 a[i] = slope1*xmag1*uv[0][i] - xmag1*uv[1][i];
519 }
520 VCOPY(uv[0], a);
521 VCOPY(uv[1], b);
522 }
523
524
525 static void
526 ambHessian( /* anisotropic radii & pos. gradient */
527 AMBHEMI *hp,
528 FVECT uv[2], /* returned */
529 float ra[2], /* returned (optional) */
530 float pg[2] /* returned (optional) */
531 )
532 {
533 static char memerrmsg[] = "out of memory in ambHessian()";
534 FVECT (*hessrow)[3] = NULL;
535 FVECT *gradrow = NULL;
536 FVECT hessian[3];
537 FVECT gradient;
538 FFTRI fftr;
539 int i, j;
540 /* be sure to assign unit vectors */
541 VCOPY(uv[0], hp->ux);
542 VCOPY(uv[1], hp->uy);
543 /* clock-wise vertex traversal from sample POV */
544 if (ra != NULL) { /* initialize Hessian row buffer */
545 hessrow = (FVECT (*)[3])malloc(sizeof(FVECT)*3*(hp->ns-1));
546 if (hessrow == NULL)
547 error(SYSTEM, memerrmsg);
548 memset(hessian, 0, sizeof(hessian));
549 } else if (pg == NULL) /* bogus call? */
550 return;
551 if (pg != NULL) { /* initialize form factor row buffer */
552 gradrow = (FVECT *)malloc(sizeof(FVECT)*(hp->ns-1));
553 if (gradrow == NULL)
554 error(SYSTEM, memerrmsg);
555 memset(gradient, 0, sizeof(gradient));
556 }
557 /* compute first row of edges */
558 for (j = 0; j < hp->ns-1; j++) {
559 comp_fftri(&fftr, hp, AI(hp,0,j), AI(hp,0,j+1));
560 if (hessrow != NULL)
561 comp_hessian(hessrow[j], &fftr, hp->onrm);
562 if (gradrow != NULL)
563 comp_gradient(gradrow[j], &fftr, hp->onrm);
564 }
565 /* sum each row of triangles */
566 for (i = 0; i < hp->ns-1; i++) {
567 FVECT hesscol[3]; /* compute first vertical edge */
568 FVECT gradcol;
569 comp_fftri(&fftr, hp, AI(hp,i,0), AI(hp,i+1,0));
570 if (hessrow != NULL)
571 comp_hessian(hesscol, &fftr, hp->onrm);
572 if (gradrow != NULL)
573 comp_gradient(gradcol, &fftr, hp->onrm);
574 for (j = 0; j < hp->ns-1; j++) {
575 FVECT hessdia[3]; /* compute triangle contributions */
576 FVECT graddia;
577 double backg;
578 backg = back_ambval(hp, AI(hp,i,j),
579 AI(hp,i,j+1), AI(hp,i+1,j));
580 /* diagonal (inner) edge */
581 comp_fftri(&fftr, hp, AI(hp,i,j+1), AI(hp,i+1,j));
582 if (hessrow != NULL) {
583 comp_hessian(hessdia, &fftr, hp->onrm);
584 rev_hessian(hesscol);
585 add2hessian(hessian, hessrow[j], hessdia, hesscol, backg);
586 }
587 if (gradrow != NULL) {
588 comp_gradient(graddia, &fftr, hp->onrm);
589 rev_gradient(gradcol);
590 add2gradient(gradient, gradrow[j], graddia, gradcol, backg);
591 }
592 /* initialize edge in next row */
593 comp_fftri(&fftr, hp, AI(hp,i+1,j+1), AI(hp,i+1,j));
594 if (hessrow != NULL)
595 comp_hessian(hessrow[j], &fftr, hp->onrm);
596 if (gradrow != NULL)
597 comp_gradient(gradrow[j], &fftr, hp->onrm);
598 /* new column edge & paired triangle */
599 backg = back_ambval(hp, AI(hp,i+1,j+1),
600 AI(hp,i+1,j), AI(hp,i,j+1));
601 comp_fftri(&fftr, hp, AI(hp,i,j+1), AI(hp,i+1,j+1));
602 if (hessrow != NULL) {
603 comp_hessian(hesscol, &fftr, hp->onrm);
604 rev_hessian(hessdia);
605 add2hessian(hessian, hessrow[j], hessdia, hesscol, backg);
606 if (i < hp->ns-2)
607 rev_hessian(hessrow[j]);
608 }
609 if (gradrow != NULL) {
610 comp_gradient(gradcol, &fftr, hp->onrm);
611 rev_gradient(graddia);
612 add2gradient(gradient, gradrow[j], graddia, gradcol, backg);
613 if (i < hp->ns-2)
614 rev_gradient(gradrow[j]);
615 }
616 }
617 }
618 /* release row buffers */
619 if (hessrow != NULL) free(hessrow);
620 if (gradrow != NULL) free(gradrow);
621
622 if (ra != NULL) /* extract eigenvectors & radii */
623 eigenvectors(uv, ra, hessian);
624 if (pg != NULL) { /* tangential position gradient */
625 pg[0] = DOT(gradient, uv[0]);
626 pg[1] = DOT(gradient, uv[1]);
627 }
628 }
629
630
631 /* Compute direction gradient from a hemispherical sampling */
632 static void
633 ambdirgrad(AMBHEMI *hp, FVECT uv[2], float dg[2])
634 {
635 AMBSAMP *ap;
636 double dgsum[2];
637 int n;
638 FVECT vd;
639 double gfact;
640
641 dgsum[0] = dgsum[1] = 0.0; /* sum values times -tan(theta) */
642 for (ap = hp->sa, n = hp->ns*hp->ns; n--; ap++) {
643 /* use vector for azimuth + 90deg */
644 VSUB(vd, ap->p, hp->rp->rop);
645 /* brightness over cosine factor */
646 gfact = ap->v[0] / DOT(hp->onrm, vd);
647 /* sine = proj_radius/vd_length */
648 dgsum[0] -= DOT(uv[1], vd) * gfact;
649 dgsum[1] += DOT(uv[0], vd) * gfact;
650 }
651 dg[0] = dgsum[0] / (hp->ns*hp->ns);
652 dg[1] = dgsum[1] / (hp->ns*hp->ns);
653 }
654
655
656 /* Compute potential light leak direction flags for cache value */
657 static uint32
658 ambcorral(AMBHEMI *hp, FVECT uv[2], const double r0, const double r1)
659 {
660 const double max_d = 1.0/(minarad*ambacc + 0.001);
661 const double ang_res = 0.5*PI/hp->ns;
662 const double ang_step = ang_res/((int)(16/PI*ang_res) + 1.01);
663 double avg_d = 0;
664 uint32 flgs = 0;
665 FVECT vec;
666 double u, v;
667 double ang, a1;
668 int i, j;
669 /* don't bother for a few samples */
670 if (hp->ns < 8)
671 return(0);
672 /* check distances overhead */
673 for (i = hp->ns*3/4; i-- > hp->ns>>2; )
674 for (j = hp->ns*3/4; j-- > hp->ns>>2; )
675 avg_d += ambsam(hp,i,j).d;
676 avg_d *= 4.0/(hp->ns*hp->ns);
677 if (avg_d*r0 >= 1.0) /* ceiling too low for corral? */
678 return(0);
679 if (avg_d >= max_d) /* insurance */
680 return(0);
681 /* else circle around perimeter */
682 for (i = 0; i < hp->ns; i++)
683 for (j = 0; j < hp->ns; j += !i|(i==hp->ns-1) ? 1 : hp->ns-1) {
684 AMBSAMP *ap = &ambsam(hp,i,j);
685 if ((ap->d <= FTINY) | (ap->d >= max_d))
686 continue; /* too far or too near */
687 VSUB(vec, ap->p, hp->rp->rop);
688 u = DOT(vec, uv[0]);
689 v = DOT(vec, uv[1]);
690 if ((r0*r0*u*u + r1*r1*v*v) * ap->d*ap->d <= u*u + v*v)
691 continue; /* occluder outside ellipse */
692 ang = atan2a(v, u); /* else set direction flags */
693 for (a1 = ang-ang_res; a1 <= ang+ang_res; a1 += ang_step)
694 flgs |= 1L<<(int)(16/PI*(a1 + 2.*PI*(a1 < 0)));
695 }
696 return(flgs);
697 }
698
699
700 int
701 doambient( /* compute ambient component */
702 SCOLOR rcol, /* input/output color */
703 RAY *r,
704 double wt, /* negative for back side */
705 FVECT uv[2], /* returned (optional) */
706 float ra[2], /* returned (optional) */
707 float pg[2], /* returned (optional) */
708 float dg[2], /* returned (optional) */
709 uint32 *crlp /* returned (optional) */
710 )
711 {
712 AMBHEMI *hp = samp_hemi(rcol, r, wt);
713 FVECT my_uv[2];
714 double d, K;
715 AMBSAMP *ap;
716 int i;
717 /* clear return values */
718 if (uv != NULL)
719 memset(uv, 0, sizeof(FVECT)*2);
720 if (ra != NULL)
721 ra[0] = ra[1] = 0.0;
722 if (pg != NULL)
723 pg[0] = pg[1] = 0.0;
724 if (dg != NULL)
725 dg[0] = dg[1] = 0.0;
726 if (crlp != NULL)
727 *crlp = 0;
728 if (hp == NULL) /* sampling falure? */
729 return(0);
730
731 if ((ra == NULL) & (pg == NULL) & (dg == NULL) ||
732 (hp->sampOK < 0) | (hp->ns < MINADIV)) {
733 free(hp); /* Hessian not requested/possible */
734 return(-1); /* value-only return value */
735 }
736 if ((d = scolor_mean(rcol)) > FTINY) {
737 d = 0.99*(hp->ns*hp->ns)/d; /* normalize avg. values */
738 K = 0.01;
739 } else { /* or fall back on geometric Hessian */
740 K = 1.0;
741 pg = NULL;
742 dg = NULL;
743 crlp = NULL;
744 }
745 ap = hp->sa; /* single channel from here on... */
746 for (i = hp->ns*hp->ns; i--; ap++)
747 ap->v[0] = scolor_mean(ap->v)*d + K;
748
749 if (uv == NULL) /* make sure we have axis pointers */
750 uv = my_uv;
751 /* compute radii & pos. gradient */
752 ambHessian(hp, uv, ra, pg);
753
754 if (dg != NULL) /* compute direction gradient */
755 ambdirgrad(hp, uv, dg);
756
757 if (ra != NULL) { /* scale/clamp radii */
758 if (pg != NULL) {
759 if (ra[0]*(d = fabs(pg[0])) > 1.0)
760 ra[0] = 1.0/d;
761 if (ra[1]*(d = fabs(pg[1])) > 1.0)
762 ra[1] = 1.0/d;
763 if (ra[0] > ra[1])
764 ra[0] = ra[1];
765 }
766 if (ra[0] < minarad) {
767 ra[0] = minarad;
768 if (ra[1] < minarad)
769 ra[1] = minarad;
770 }
771 ra[0] *= d = 1.0/sqrt(fabs(wt));
772 if ((ra[1] *= d) > 2.0*ra[0])
773 ra[1] = 2.0*ra[0];
774 if (ra[1] > maxarad) {
775 ra[1] = maxarad;
776 if (ra[0] > maxarad)
777 ra[0] = maxarad;
778 }
779 /* flag encroached directions */
780 if (crlp != NULL) /* XXX doesn't update with changes to ambacc */
781 *crlp = ambcorral(hp, uv, ra[0]*ambacc, ra[1]*ambacc);
782 if (pg != NULL) { /* cap gradient if necessary */
783 d = pg[0]*pg[0]*ra[0]*ra[0] + pg[1]*pg[1]*ra[1]*ra[1];
784 if (d > 1.0) {
785 d = 1.0/sqrt(d);
786 pg[0] *= d;
787 pg[1] *= d;
788 }
789 }
790 }
791 free(hp); /* clean up and return */
792 return(1);
793 }
