| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: ambcomp.c,v 2.91 2023/11/17 20:02:07 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Routines to compute "ambient" values using Monte Carlo
| 6 |
| 7 |
* Hessian calculations based on "Practical Hessian-Based Error Control
| 8 |
* for Irradiance Caching" by Schwarzhaupt, Wann Jensen, & Jarosz
| 9 |
* from ACM SIGGRAPH Asia 2012 conference proceedings.
| 10 |
| 11 |
* Added book-keeping optimization to avoid calculations that would
| 12 |
* cancel due to traversal both directions on edges that are adjacent
| 13 |
* to same-valued triangles. This cuts about half of Hessian math.
| 14 |
| 15 |
* Declarations of external symbols in ambient.h
| 16 |
| 17 |
| 18 |
#include "copyright.h"
| 19 |
| 20 |
#include "ray.h"
| 21 |
#include "ambient.h"
| 22 |
#include "random.h"
| 23 |
| 24 |
#ifndef MINADIV
| 25 |
#define MINADIV 7 /* minimum # divisions in each dimension */
| 26 |
#endif
| 27 |
| 28 |
typedef struct {
| 29 |
FVECT p; /* intersection point */
| 30 |
float d; /* reciprocal distance */
| 31 |
SCOLOR v; /* hemisphere sample value */
| 32 |
} AMBSAMP; /* sample value */
| 33 |
| 34 |
typedef struct {
| 35 |
RAY *rp; /* originating ray sample */
| 36 |
int ns; /* number of samples per axis */
| 37 |
int sampOK; /* acquired full sample set? */
| 38 |
int atyp; /* RAMBIENT or TAMBIENT */
| 39 |
SCOLOR acoef; /* division contribution coefficient */
| 40 |
SCOLOR acol; /* accumulated color */
| 41 |
FVECT onrm; /* oriented unperturbed surface normal */
| 42 |
FVECT ux, uy; /* tangent axis unit vectors */
| 43 |
AMBSAMP sa[1]; /* sample array (extends struct) */
| 44 |
} AMBHEMI; /* ambient sample hemisphere */
| 45 |
| 46 |
#define AI(h,i,j) ((i)*(h)->ns + (j))
| 47 |
#define ambsam(h,i,j) (h)->sa[AI(h,i,j)]
| 48 |
| 49 |
typedef struct {
| 50 |
FVECT r_i, r_i1, e_i, rcp, rI2_eJ2;
| 51 |
double I1, I2;
| 52 |
} FFTRI; /* vectors and coefficients for Hessian calculation */
| 53 |
| 54 |
| 55 |
static int
| 56 |
ambcollision( /* proposed direciton collides? */
| 57 |
AMBHEMI *hp,
| 58 |
int i,
| 59 |
int j,
| 60 |
FVECT dv
| 61 |
| 62 |
| 63 |
double cos_thresh;
| 64 |
int ii, jj;
| 65 |
/* min. spacing = 1/4th division */
| 66 |
cos_thresh = (PI/4.)/(double)hp->ns;
| 67 |
cos_thresh = 1. - .5*cos_thresh*cos_thresh;
| 68 |
/* check existing neighbors */
| 69 |
for (ii = i-1; ii <= i+1; ii++) {
| 70 |
if (ii < 0) continue;
| 71 |
if (ii >= hp->ns) break;
| 72 |
for (jj = j-1; jj <= j+1; jj++) {
| 73 |
AMBSAMP *ap;
| 74 |
FVECT avec;
| 75 |
double dprod;
| 76 |
if (jj < 0) continue;
| 77 |
if (jj >= hp->ns) break;
| 78 |
if ((ii==i) & (jj==j)) continue;
| 79 |
ap = &ambsam(hp,ii,jj);
| 80 |
if (ap->d <= .5/FHUGE)
| 81 |
continue; /* no one home */
| 82 |
VSUB(avec, ap->p, hp->rp->rop);
| 83 |
dprod = DOT(avec, dv);
| 84 |
if (dprod >= cos_thresh*VLEN(avec))
| 85 |
return(1); /* collision */
| 86 |
| 87 |
| 88 |
return(0); /* nothing to worry about */
| 89 |
| 90 |
| 91 |
| 92 |
static int
| 93 |
ambsample( /* initial ambient division sample */
| 94 |
AMBHEMI *hp,
| 95 |
int i,
| 96 |
int j,
| 97 |
int n
| 98 |
| 99 |
| 100 |
AMBSAMP *ap = &ambsam(hp,i,j);
| 101 |
RAY ar;
| 102 |
int hlist[3], ii;
| 103 |
RREAL spt[2];
| 104 |
double zd;
| 105 |
/* generate hemispherical sample */
| 106 |
/* ambient coefficient for weight */
| 107 |
if (ambacc > FTINY)
| 108 |
setscolor(ar.rcoef, AVGREFL, AVGREFL, AVGREFL);
| 109 |
else
| 110 |
copyscolor(ar.rcoef, hp->acoef);
| 111 |
if (rayorigin(&ar, hp->atyp, hp->rp, ar.rcoef) < 0)
| 112 |
return(0);
| 113 |
if (ambacc > FTINY) {
| 114 |
smultscolor(ar.rcoef, hp->acoef);
| 115 |
scalescolor(ar.rcoef, 1./AVGREFL);
| 116 |
| 117 |
hlist[0] = hp->rp->rno;
| 118 |
hlist[1] = j;
| 119 |
hlist[2] = i;
| 120 |
multisamp(spt, 2, urand(ilhash(hlist,3)+n));
| 121 |
resample:
| 122 |
square2disk(spt, (j+spt[1])/hp->ns, (i+spt[0])/hp->ns);
| 123 |
zd = sqrt(1. - spt[0]*spt[0] - spt[1]*spt[1]);
| 124 |
for (ii = 3; ii--; )
| 125 |
ar.rdir[ii] = spt[0]*hp->ux[ii] +
| 126 |
spt[1]*hp->uy[ii] +
| 127 |
zd*hp->onrm[ii];
| 128 |
checknorm(ar.rdir);
| 129 |
/* avoid coincident samples */
| 130 |
if (!n && ambcollision(hp, i, j, ar.rdir)) {
| 131 |
spt[0] = frandom(); spt[1] = frandom();
| 132 |
goto resample; /* reject this sample */
| 133 |
| 134 |
dimlist[ndims++] = AI(hp,i,j) + 90171;
| 135 |
rayvalue(&ar); /* evaluate ray */
| 136 |
ndims--;
| 137 |
zd = raydistance(&ar);
| 138 |
if (zd <= FTINY)
| 139 |
return(0); /* should never happen */
| 140 |
smultscolor(ar.rcol, ar.rcoef); /* apply coefficient */
| 141 |
if (zd*ap->d < 1.0) /* new/closer distance? */
| 142 |
ap->d = 1.0/zd;
| 143 |
if (!n) { /* record first vertex & value */
| 144 |
if (zd > 10.0*thescene.cusize + 1000.)
| 145 |
zd = 10.0*thescene.cusize + 1000.;
| 146 |
VSUM(ap->p, ar.rorg, ar.rdir, zd);
| 147 |
copyscolor(ap->v, ar.rcol);
| 148 |
} else { /* else update recorded value */
| 149 |
sopscolor(hp->acol, -=, ap->v);
| 150 |
zd = 1.0/(double)(n+1);
| 151 |
scalescolor(ar.rcol, zd);
| 152 |
zd *= (double)n;
| 153 |
scalescolor(ap->v, zd);
| 154 |
saddscolor(ap->v, ar.rcol);
| 155 |
| 156 |
saddscolor(hp->acol, ap->v); /* add to our sum */
| 157 |
return(1);
| 158 |
| 159 |
| 160 |
| 161 |
/* Estimate variance based on ambient division differences */
| 162 |
static float *
| 163 |
getambdiffs(AMBHEMI *hp)
| 164 |
| 165 |
const double normf = 1./bright(hp->acoef);
| 166 |
float *earr = (float *)calloc(hp->ns*hp->ns, sizeof(float));
| 167 |
float *ep;
| 168 |
AMBSAMP *ap;
| 169 |
double b, b1, d2;
| 170 |
int i, j;
| 171 |
| 172 |
if (earr == NULL) /* out of memory? */
| 173 |
return(NULL);
| 174 |
/* sum squared neighbor diffs */
| 175 |
for (ap = hp->sa, ep = earr, i = 0; i < hp->ns; i++)
| 176 |
for (j = 0; j < hp->ns; j++, ap++, ep++) {
| 177 |
b = pbright(ap[0].v);
| 178 |
if (i) { /* from above */
| 179 |
b1 = pbright(ap[-hp->ns].v);
| 180 |
d2 = b - b1;
| 181 |
d2 *= d2*normf/(b + b1 + FTINY);
| 182 |
ep[0] += d2;
| 183 |
ep[-hp->ns] += d2;
| 184 |
| 185 |
if (!j) continue;
| 186 |
/* from behind */
| 187 |
b1 = pbright(ap[-1].v);
| 188 |
d2 = b - b1;
| 189 |
| 190 |
ep[0] += d2;
| 191 |
ep[-1] += d2;
| 192 |
if (!i) continue;
| 193 |
/* diagonal */
| 194 |
b1 = pbright(ap[-hp->ns-1].v);
| 195 |
d2 = b - b1;
| 196 |
| 197 |
ep[0] += d2;
| 198 |
ep[-hp->ns-1] += d2;
| 199 |
| 200 |
/* correct for number of neighbors */
| 201 |
earr[0] *= 8./3.;
| 202 |
earr[hp->ns-1] *= 8./3.;
| 203 |
earr[(hp->ns-1)*hp->ns] *= 8./3.;
| 204 |
earr[(hp->ns-1)*hp->ns + hp->ns-1] *= 8./3.;
| 205 |
for (i = 1; i < hp->ns-1; i++) {
| 206 |
earr[i*hp->ns] *= 8./5.;
| 207 |
earr[i*hp->ns + hp->ns-1] *= 8./5.;
| 208 |
| 209 |
for (j = 1; j < hp->ns-1; j++) {
| 210 |
earr[j] *= 8./5.;
| 211 |
earr[(hp->ns-1)*hp->ns + j] *= 8./5.;
| 212 |
| 213 |
return(earr);
| 214 |
| 215 |
| 216 |
| 217 |
/* Perform super-sampling on hemisphere (introduces bias) */
| 218 |
static void
| 219 |
ambsupersamp(AMBHEMI *hp, int cnt)
| 220 |
| 221 |
float *earr = getambdiffs(hp);
| 222 |
double e2rem = 0;
| 223 |
float *ep;
| 224 |
int i, j, n, nss;
| 225 |
| 226 |
if (earr == NULL) /* just skip calc. if no memory */
| 227 |
return;
| 228 |
/* accumulate estimated variances */
| 229 |
for (ep = earr + hp->ns*hp->ns; ep > earr; )
| 230 |
e2rem += *--ep;
| 231 |
ep = earr; /* perform super-sampling */
| 232 |
for (i = 0; i < hp->ns; i++)
| 233 |
for (j = 0; j < hp->ns; j++) {
| 234 |
if (e2rem <= FTINY)
| 235 |
goto done; /* nothing left to do */
| 236 |
nss = *ep/e2rem*cnt + frandom();
| 237 |
for (n = 1; n <= nss && ambsample(hp,i,j,n); n++)
| 238 |
if (!--cnt) goto done;
| 239 |
e2rem -= *ep++; /* update remainder */
| 240 |
| 241 |
done:
| 242 |
free(earr);
| 243 |
| 244 |
| 245 |
| 246 |
static AMBHEMI *
| 247 |
samp_hemi( /* sample indirect hemisphere */
| 248 |
SCOLOR rcol,
| 249 |
RAY *r,
| 250 |
double wt
| 251 |
| 252 |
| 253 |
int backside = (wt < 0);
| 254 |
AMBHEMI *hp;
| 255 |
double d;
| 256 |
int n, i, j;
| 257 |
/* insignificance check */
| 258 |
d = sintens(rcol);
| 259 |
if (d <= FTINY)
| 260 |
return(NULL);
| 261 |
/* set number of divisions */
| 262 |
if (backside) wt = -wt;
| 263 |
if (ambacc <= FTINY &&
| 264 |
wt > (d *= 0.8*r->rweight/(ambdiv*minweight)))
| 265 |
wt = d; /* avoid ray termination */
| 266 |
n = sqrt(ambdiv * wt) + 0.5;
| 267 |
i = 1 + (MINADIV-1)*(ambacc > FTINY);
| 268 |
if (n < i) /* use minimum number of samples? */
| 269 |
n = i;
| 270 |
/* allocate sampling array */
| 271 |
hp = (AMBHEMI *)malloc(sizeof(AMBHEMI) + sizeof(AMBSAMP)*(n*n - 1));
| 272 |
if (hp == NULL)
| 273 |
error(SYSTEM, "out of memory in samp_hemi");
| 274 |
| 275 |
if (backside) {
| 276 |
hp->atyp = TAMBIENT;
| 277 |
hp->onrm[0] = -r->ron[0];
| 278 |
hp->onrm[1] = -r->ron[1];
| 279 |
hp->onrm[2] = -r->ron[2];
| 280 |
} else {
| 281 |
hp->atyp = RAMBIENT;
| 282 |
VCOPY(hp->onrm, r->ron);
| 283 |
| 284 |
hp->rp = r;
| 285 |
hp->ns = n;
| 286 |
scolorblack(hp->acol);
| 287 |
memset(hp->sa, 0, sizeof(AMBSAMP)*n*n);
| 288 |
hp->sampOK = 0;
| 289 |
/* assign coefficient */
| 290 |
copyscolor(hp->acoef, rcol);
| 291 |
d = 1.0/(n*n);
| 292 |
scalescolor(hp->acoef, d);
| 293 |
/* make tangent plane axes */
| 294 |
if (!getperpendicular(hp->ux, hp->onrm, 1))
| 295 |
error(CONSISTENCY, "bad ray direction in samp_hemi");
| 296 |
VCROSS(hp->uy, hp->onrm, hp->ux);
| 297 |
/* sample divisions */
| 298 |
for (i = hp->ns; i--; )
| 299 |
for (j = hp->ns; j--; )
| 300 |
hp->sampOK += ambsample(hp, i, j, 0);
| 301 |
copyscolor(rcol, hp->acol);
| 302 |
if (!hp->sampOK) { /* utter failure? */
| 303 |
free(hp);
| 304 |
return(NULL);
| 305 |
| 306 |
if (hp->sampOK < hp->ns*hp->ns) {
| 307 |
hp->sampOK *= -1; /* soft failure */
| 308 |
return(hp);
| 309 |
| 310 |
if (hp->sampOK <= MINADIV*MINADIV)
| 311 |
return(hp); /* don't bother super-sampling */
| 312 |
n = ambssamp*wt + 0.5;
| 313 |
if (n > 8) { /* perform super-sampling? */
| 314 |
ambsupersamp(hp, n);
| 315 |
| 316 |
| 317 |
return(hp); /* all is well */
| 318 |
| 319 |
| 320 |
| 321 |
/* Return brightness of farthest ambient sample */
| 322 |
static double
| 323 |
back_ambval(AMBHEMI *hp, const int n1, const int n2, const int n3)
| 324 |
| 325 |
if (hp->sa[n1].d <= hp->sa[n2].d) {
| 326 |
if (hp->sa[n1].d <= hp->sa[n3].d)
| 327 |
return(hp->sa[n1].v[0]);
| 328 |
return(hp->sa[n3].v[0]);
| 329 |
| 330 |
if (hp->sa[n2].d <= hp->sa[n3].d)
| 331 |
return(hp->sa[n2].v[0]);
| 332 |
| 333 |
| 334 |
| 335 |
| 336 |
/* Compute vectors and coefficients for Hessian/gradient calcs */
| 337 |
static void
| 338 |
comp_fftri(FFTRI *ftp, AMBHEMI *hp, const int n0, const int n1)
| 339 |
| 340 |
double rdot_cp, dot_e, dot_er, rdot_r, rdot_r1, J2;
| 341 |
int ii;
| 342 |
| 343 |
VSUB(ftp->r_i, hp->sa[n0].p, hp->rp->rop);
| 344 |
VSUB(ftp->r_i1, hp->sa[n1].p, hp->rp->rop);
| 345 |
VSUB(ftp->e_i, hp->sa[n1].p, hp->sa[n0].p);
| 346 |
VCROSS(ftp->rcp, ftp->r_i, ftp->r_i1);
| 347 |
rdot_cp = 1.0/DOT(ftp->rcp,ftp->rcp);
| 348 |
dot_e = DOT(ftp->e_i,ftp->e_i);
| 349 |
dot_er = DOT(ftp->e_i, ftp->r_i);
| 350 |
rdot_r = 1.0/DOT(ftp->r_i,ftp->r_i);
| 351 |
rdot_r1 = 1.0/DOT(ftp->r_i1,ftp->r_i1);
| 352 |
ftp->I1 = acos( DOT(ftp->r_i, ftp->r_i1) * sqrt(rdot_r*rdot_r1) ) *
| 353 |
sqrt( rdot_cp );
| 354 |
ftp->I2 = ( DOT(ftp->e_i, ftp->r_i1)*rdot_r1 - dot_er*rdot_r +
| 355 |
dot_e*ftp->I1 )*0.5*rdot_cp;
| 356 |
J2 = ( 0.5*(rdot_r - rdot_r1) - dot_er*ftp->I2 ) / dot_e;
| 357 |
| 358 |
ftp->rI2_eJ2[ii] = ftp->I2*ftp->r_i[ii] + J2*ftp->e_i[ii];
| 359 |
| 360 |
| 361 |
| 362 |
/* Compose 3x3 matrix from two vectors */
| 363 |
static void
| 364 |
compose_matrix(FVECT mat[3], FVECT va, FVECT vb)
| 365 |
| 366 |
mat[0][0] = 2.0*va[0]*vb[0];
| 367 |
mat[1][1] = 2.0*va[1]*vb[1];
| 368 |
mat[2][2] = 2.0*va[2]*vb[2];
| 369 |
mat[0][1] = mat[1][0] = va[0]*vb[1] + va[1]*vb[0];
| 370 |
mat[0][2] = mat[2][0] = va[0]*vb[2] + va[2]*vb[0];
| 371 |
mat[1][2] = mat[2][1] = va[1]*vb[2] + va[2]*vb[1];
| 372 |
| 373 |
| 374 |
| 375 |
/* Compute partial 3x3 Hessian matrix for edge */
| 376 |
static void
| 377 |
comp_hessian(FVECT hess[3], FFTRI *ftp, FVECT nrm)
| 378 |
| 379 |
FVECT ncp;
| 380 |
FVECT m1[3], m2[3], m3[3], m4[3];
| 381 |
double d1, d2, d3, d4;
| 382 |
double I3, J3, K3;
| 383 |
int i, j;
| 384 |
/* compute intermediate coefficients */
| 385 |
d1 = 1.0/DOT(ftp->r_i,ftp->r_i);
| 386 |
d2 = 1.0/DOT(ftp->r_i1,ftp->r_i1);
| 387 |
d3 = 1.0/DOT(ftp->e_i,ftp->e_i);
| 388 |
d4 = DOT(ftp->e_i, ftp->r_i);
| 389 |
I3 = ( DOT(ftp->e_i, ftp->r_i1)*d2*d2 - d4*d1*d1 + 3.0/d3*ftp->I2 )
| 390 |
/ ( 4.0*DOT(ftp->rcp,ftp->rcp) );
| 391 |
J3 = 0.25*d3*(d1*d1 - d2*d2) - d4*d3*I3;
| 392 |
K3 = d3*(ftp->I2 - I3/d1 - 2.0*d4*J3);
| 393 |
/* intermediate matrices */
| 394 |
VCROSS(ncp, nrm, ftp->e_i);
| 395 |
compose_matrix(m1, ncp, ftp->rI2_eJ2);
| 396 |
compose_matrix(m2, ftp->r_i, ftp->r_i);
| 397 |
compose_matrix(m3, ftp->e_i, ftp->e_i);
| 398 |
compose_matrix(m4, ftp->r_i, ftp->e_i);
| 399 |
d1 = DOT(nrm, ftp->rcp);
| 400 |
d2 = -d1*ftp->I2;
| 401 |
d1 *= 2.0;
| 402 |
for (i = 3; i--; ) /* final matrix sum */
| 403 |
for (j = 3; j--; ) {
| 404 |
hess[i][j] = m1[i][j] + d1*( I3*m2[i][j] + K3*m3[i][j] +
| 405 |
2.0*J3*m4[i][j] );
| 406 |
hess[i][j] += d2*(i==j);
| 407 |
hess[i][j] *= -1.0/PI;
| 408 |
| 409 |
| 410 |
| 411 |
| 412 |
/* Reverse hessian calculation result for edge in other direction */
| 413 |
static void
| 414 |
rev_hessian(FVECT hess[3])
| 415 |
| 416 |
int i;
| 417 |
| 418 |
for (i = 3; i--; ) {
| 419 |
hess[i][0] = -hess[i][0];
| 420 |
hess[i][1] = -hess[i][1];
| 421 |
hess[i][2] = -hess[i][2];
| 422 |
| 423 |
| 424 |
| 425 |
| 426 |
/* Add to radiometric Hessian from the given triangle */
| 427 |
static void
| 428 |
add2hessian(FVECT hess[3], FVECT ehess1[3],
| 429 |
FVECT ehess2[3], FVECT ehess3[3], double v)
| 430 |
| 431 |
int i, j;
| 432 |
| 433 |
for (i = 3; i--; )
| 434 |
for (j = 3; j--; )
| 435 |
hess[i][j] += v*( ehess1[i][j] + ehess2[i][j] + ehess3[i][j] );
| 436 |
| 437 |
| 438 |
| 439 |
/* Compute partial displacement form factor gradient for edge */
| 440 |
static void
| 441 |
comp_gradient(FVECT grad, FFTRI *ftp, FVECT nrm)
| 442 |
| 443 |
FVECT ncp;
| 444 |
double f1;
| 445 |
int i;
| 446 |
| 447 |
f1 = 2.0*DOT(nrm, ftp->rcp);
| 448 |
| 449 |
for (i = 3; i--; )
| 450 |
grad[i] = (0.5/PI)*( ftp->I1*ncp[i] + f1*ftp->rI2_eJ2[i] );
| 451 |
| 452 |
| 453 |
| 454 |
/* Reverse gradient calculation result for edge in other direction */
| 455 |
static void
| 456 |
rev_gradient(FVECT grad)
| 457 |
| 458 |
grad[0] = -grad[0];
| 459 |
grad[1] = -grad[1];
| 460 |
grad[2] = -grad[2];
| 461 |
| 462 |
| 463 |
| 464 |
/* Add to displacement gradient from the given triangle */
| 465 |
static void
| 466 |
add2gradient(FVECT grad, FVECT egrad1, FVECT egrad2, FVECT egrad3, double v)
| 467 |
| 468 |
int i;
| 469 |
| 470 |
for (i = 3; i--; )
| 471 |
grad[i] += v*( egrad1[i] + egrad2[i] + egrad3[i] );
| 472 |
| 473 |
| 474 |
| 475 |
/* Compute anisotropic radii and eigenvector directions */
| 476 |
static void
| 477 |
eigenvectors(FVECT uv[2], float ra[2], FVECT hessian[3])
| 478 |
| 479 |
double hess2[2][2];
| 480 |
FVECT a, b;
| 481 |
double evalue[2], slope1, xmag1;
| 482 |
int i;
| 483 |
/* project Hessian to sample plane */
| 484 |
| 485 |
a[i] = DOT(hessian[i], uv[0]);
| 486 |
b[i] = DOT(hessian[i], uv[1]);
| 487 |
| 488 |
hess2[0][0] = DOT(uv[0], a);
| 489 |
hess2[0][1] = DOT(uv[0], b);
| 490 |
hess2[1][0] = DOT(uv[1], a);
| 491 |
hess2[1][1] = DOT(uv[1], b);
| 492 |
/* compute eigenvalue(s) */
| 493 |
i = quadratic(evalue, 1.0, -hess2[0][0]-hess2[1][1],
| 494 |
hess2[0][0]*hess2[1][1]-hess2[0][1]*hess2[1][0]);
| 495 |
if (i == 1) /* double-root (circle) */
| 496 |
evalue[1] = evalue[0];
| 497 |
if (!i || ((evalue[0] = fabs(evalue[0])) <= FTINY*FTINY) |
| 498 |
((evalue[1] = fabs(evalue[1])) <= FTINY*FTINY) ) {
| 499 |
ra[0] = ra[1] = maxarad;
| 500 |
return;
| 501 |
| 502 |
if (evalue[0] > evalue[1]) {
| 503 |
ra[0] = sqrt(sqrt(4.0/evalue[0]));
| 504 |
ra[1] = sqrt(sqrt(4.0/evalue[1]));
| 505 |
slope1 = evalue[1];
| 506 |
} else {
| 507 |
ra[0] = sqrt(sqrt(4.0/evalue[1]));
| 508 |
ra[1] = sqrt(sqrt(4.0/evalue[0]));
| 509 |
slope1 = evalue[0];
| 510 |
| 511 |
/* compute unit eigenvectors */
| 512 |
if (fabs(hess2[0][1]) <= FTINY)
| 513 |
return; /* uv OK as is */
| 514 |
slope1 = (slope1 - hess2[0][0]) / hess2[0][1];
| 515 |
xmag1 = sqrt(1.0/(1.0 + slope1*slope1));
| 516 |
| 517 |
b[i] = xmag1*uv[0][i] + slope1*xmag1*uv[1][i];
| 518 |
a[i] = slope1*xmag1*uv[0][i] - xmag1*uv[1][i];
| 519 |
| 520 |
VCOPY(uv[0], a);
| 521 |
VCOPY(uv[1], b);
| 522 |
| 523 |
| 524 |
| 525 |
static void
| 526 |
ambHessian( /* anisotropic radii & pos. gradient */
| 527 |
AMBHEMI *hp,
| 528 |
FVECT uv[2], /* returned */
| 529 |
float ra[2], /* returned (optional) */
| 530 |
float pg[2] /* returned (optional) */
| 531 |
| 532 |
| 533 |
static char memerrmsg[] = "out of memory in ambHessian()";
| 534 |
FVECT (*hessrow)[3] = NULL;
| 535 |
FVECT *gradrow = NULL;
| 536 |
FVECT hessian[3];
| 537 |
FVECT gradient;
| 538 |
FFTRI fftr;
| 539 |
int i, j;
| 540 |
/* be sure to assign unit vectors */
| 541 |
VCOPY(uv[0], hp->ux);
| 542 |
VCOPY(uv[1], hp->uy);
| 543 |
/* clock-wise vertex traversal from sample POV */
| 544 |
if (ra != NULL) { /* initialize Hessian row buffer */
| 545 |
hessrow = (FVECT (*)[3])malloc(sizeof(FVECT)*3*(hp->ns-1));
| 546 |
if (hessrow == NULL)
| 547 |
error(SYSTEM, memerrmsg);
| 548 |
memset(hessian, 0, sizeof(hessian));
| 549 |
} else if (pg == NULL) /* bogus call? */
| 550 |
return;
| 551 |
if (pg != NULL) { /* initialize form factor row buffer */
| 552 |
gradrow = (FVECT *)malloc(sizeof(FVECT)*(hp->ns-1));
| 553 |
if (gradrow == NULL)
| 554 |
| 555 |
memset(gradient, 0, sizeof(gradient));
| 556 |
| 557 |
/* compute first row of edges */
| 558 |
for (j = 0; j < hp->ns-1; j++) {
| 559 |
comp_fftri(&fftr, hp, AI(hp,0,j), AI(hp,0,j+1));
| 560 |
if (hessrow != NULL)
| 561 |
comp_hessian(hessrow[j], &fftr, hp->onrm);
| 562 |
if (gradrow != NULL)
| 563 |
comp_gradient(gradrow[j], &fftr, hp->onrm);
| 564 |
| 565 |
/* sum each row of triangles */
| 566 |
for (i = 0; i < hp->ns-1; i++) {
| 567 |
FVECT hesscol[3]; /* compute first vertical edge */
| 568 |
FVECT gradcol;
| 569 |
comp_fftri(&fftr, hp, AI(hp,i,0), AI(hp,i+1,0));
| 570 |
| 571 |
comp_hessian(hesscol, &fftr, hp->onrm);
| 572 |
| 573 |
comp_gradient(gradcol, &fftr, hp->onrm);
| 574 |
| 575 |
FVECT hessdia[3]; /* compute triangle contributions */
| 576 |
FVECT graddia;
| 577 |
double backg;
| 578 |
backg = back_ambval(hp, AI(hp,i,j),
| 579 |
AI(hp,i,j+1), AI(hp,i+1,j));
| 580 |
/* diagonal (inner) edge */
| 581 |
comp_fftri(&fftr, hp, AI(hp,i,j+1), AI(hp,i+1,j));
| 582 |
if (hessrow != NULL) {
| 583 |
comp_hessian(hessdia, &fftr, hp->onrm);
| 584 |
rev_hessian(hesscol);
| 585 |
add2hessian(hessian, hessrow[j], hessdia, hesscol, backg);
| 586 |
| 587 |
if (gradrow != NULL) {
| 588 |
comp_gradient(graddia, &fftr, hp->onrm);
| 589 |
rev_gradient(gradcol);
| 590 |
add2gradient(gradient, gradrow[j], graddia, gradcol, backg);
| 591 |
| 592 |
/* initialize edge in next row */
| 593 |
comp_fftri(&fftr, hp, AI(hp,i+1,j+1), AI(hp,i+1,j));
| 594 |
| 595 |
| 596 |
| 597 |
| 598 |
/* new column edge & paired triangle */
| 599 |
backg = back_ambval(hp, AI(hp,i+1,j+1),
| 600 |
AI(hp,i+1,j), AI(hp,i,j+1));
| 601 |
comp_fftri(&fftr, hp, AI(hp,i,j+1), AI(hp,i+1,j+1));
| 602 |
| 603 |
| 604 |
rev_hessian(hessdia);
| 605 |
| 606 |
if (i < hp->ns-2)
| 607 |
rev_hessian(hessrow[j]);
| 608 |
| 609 |
| 610 |
| 611 |
rev_gradient(graddia);
| 612 |
| 613 |
if (i < hp->ns-2)
| 614 |
rev_gradient(gradrow[j]);
| 615 |
| 616 |
| 617 |
| 618 |
/* release row buffers */
| 619 |
if (hessrow != NULL) free(hessrow);
| 620 |
if (gradrow != NULL) free(gradrow);
| 621 |
| 622 |
if (ra != NULL) /* extract eigenvectors & radii */
| 623 |
eigenvectors(uv, ra, hessian);
| 624 |
if (pg != NULL) { /* tangential position gradient */
| 625 |
pg[0] = DOT(gradient, uv[0]);
| 626 |
pg[1] = DOT(gradient, uv[1]);
| 627 |
| 628 |
| 629 |
| 630 |
| 631 |
/* Compute direction gradient from a hemispherical sampling */
| 632 |
static void
| 633 |
ambdirgrad(AMBHEMI *hp, FVECT uv[2], float dg[2])
| 634 |
| 635 |
AMBSAMP *ap;
| 636 |
double dgsum[2];
| 637 |
int n;
| 638 |
FVECT vd;
| 639 |
double gfact;
| 640 |
| 641 |
dgsum[0] = dgsum[1] = 0.0; /* sum values times -tan(theta) */
| 642 |
for (ap = hp->sa, n = hp->ns*hp->ns; n--; ap++) {
| 643 |
/* use vector for azimuth + 90deg */
| 644 |
VSUB(vd, ap->p, hp->rp->rop);
| 645 |
/* brightness over cosine factor */
| 646 |
gfact = ap->v[0] / DOT(hp->onrm, vd);
| 647 |
/* sine = proj_radius/vd_length */
| 648 |
dgsum[0] -= DOT(uv[1], vd) * gfact;
| 649 |
dgsum[1] += DOT(uv[0], vd) * gfact;
| 650 |
| 651 |
dg[0] = dgsum[0] / (hp->ns*hp->ns);
| 652 |
dg[1] = dgsum[1] / (hp->ns*hp->ns);
| 653 |
| 654 |
| 655 |
| 656 |
/* Compute potential light leak direction flags for cache value */
| 657 |
static uint32
| 658 |
ambcorral(AMBHEMI *hp, FVECT uv[2], const double r0, const double r1)
| 659 |
| 660 |
const double max_d = 1.0/(minarad*ambacc + 0.001);
| 661 |
const double ang_res = 0.5*PI/hp->ns;
| 662 |
const double ang_step = ang_res/((int)(16/PI*ang_res) + 1.01);
| 663 |
double avg_d = 0;
| 664 |
uint32 flgs = 0;
| 665 |
FVECT vec;
| 666 |
double u, v;
| 667 |
double ang, a1;
| 668 |
int i, j;
| 669 |
/* don't bother for a few samples */
| 670 |
if (hp->ns < 8)
| 671 |
return(0);
| 672 |
/* check distances overhead */
| 673 |
for (i = hp->ns*3/4; i-- > hp->ns>>2; )
| 674 |
for (j = hp->ns*3/4; j-- > hp->ns>>2; )
| 675 |
avg_d += ambsam(hp,i,j).d;
| 676 |
avg_d *= 4.0/(hp->ns*hp->ns);
| 677 |
if (avg_d*r0 >= 1.0) /* ceiling too low for corral? */
| 678 |
return(0);
| 679 |
if (avg_d >= max_d) /* insurance */
| 680 |
return(0);
| 681 |
/* else circle around perimeter */
| 682 |
| 683 |
for (j = 0; j < hp->ns; j += !i|(i==hp->ns-1) ? 1 : hp->ns-1) {
| 684 |
| 685 |
if ((ap->d <= FTINY) | (ap->d >= max_d))
| 686 |
continue; /* too far or too near */
| 687 |
VSUB(vec, ap->p, hp->rp->rop);
| 688 |
u = DOT(vec, uv[0]);
| 689 |
v = DOT(vec, uv[1]);
| 690 |
if ((r0*r0*u*u + r1*r1*v*v) * ap->d*ap->d <= u*u + v*v)
| 691 |
continue; /* occluder outside ellipse */
| 692 |
ang = atan2a(v, u); /* else set direction flags */
| 693 |
for (a1 = ang-ang_res; a1 <= ang+ang_res; a1 += ang_step)
| 694 |
flgs |= 1L<<(int)(16/PI*(a1 + 2.*PI*(a1 < 0)));
| 695 |
| 696 |
return(flgs);
| 697 |
| 698 |
| 699 |
| 700 |
int
| 701 |
doambient( /* compute ambient component */
| 702 |
SCOLOR rcol, /* input/output color */
| 703 |
RAY *r,
| 704 |
double wt, /* negative for back side */
| 705 |
FVECT uv[2], /* returned (optional) */
| 706 |
| 707 |
float pg[2], /* returned (optional) */
| 708 |
float dg[2], /* returned (optional) */
| 709 |
uint32 *crlp /* returned (optional) */
| 710 |
| 711 |
| 712 |
AMBHEMI *hp = samp_hemi(rcol, r, wt);
| 713 |
FVECT my_uv[2];
| 714 |
double d, K;
| 715 |
AMBSAMP *ap;
| 716 |
int i;
| 717 |
/* clear return values */
| 718 |
if (uv != NULL)
| 719 |
memset(uv, 0, sizeof(FVECT)*2);
| 720 |
if (ra != NULL)
| 721 |
ra[0] = ra[1] = 0.0;
| 722 |
if (pg != NULL)
| 723 |
pg[0] = pg[1] = 0.0;
| 724 |
if (dg != NULL)
| 725 |
dg[0] = dg[1] = 0.0;
| 726 |
if (crlp != NULL)
| 727 |
*crlp = 0;
| 728 |
if (hp == NULL) /* sampling falure? */
| 729 |
return(0);
| 730 |
| 731 |
if ((ra == NULL) & (pg == NULL) & (dg == NULL) ||
| 732 |
(hp->sampOK < 0) | (hp->ns < MINADIV)) {
| 733 |
free(hp); /* Hessian not requested/possible */
| 734 |
return(-1); /* value-only return value */
| 735 |
| 736 |
if ((d = scolor_mean(rcol)) > FTINY) {
| 737 |
d = 0.99*(hp->ns*hp->ns)/d; /* normalize avg. values */
| 738 |
K = 0.01;
| 739 |
} else { /* or fall back on geometric Hessian */
| 740 |
K = 1.0;
| 741 |
pg = NULL;
| 742 |
dg = NULL;
| 743 |
crlp = NULL;
| 744 |
| 745 |
ap = hp->sa; /* single channel from here on... */
| 746 |
for (i = hp->ns*hp->ns; i--; ap++)
| 747 |
ap->v[0] = scolor_mean(ap->v)*d + K;
| 748 |
| 749 |
if (uv == NULL) /* make sure we have axis pointers */
| 750 |
uv = my_uv;
| 751 |
/* compute radii & pos. gradient */
| 752 |
ambHessian(hp, uv, ra, pg);
| 753 |
| 754 |
if (dg != NULL) /* compute direction gradient */
| 755 |
ambdirgrad(hp, uv, dg);
| 756 |
| 757 |
if (ra != NULL) { /* scale/clamp radii */
| 758 |
if (pg != NULL) {
| 759 |
if (ra[0]*(d = fabs(pg[0])) > 1.0)
| 760 |
ra[0] = 1.0/d;
| 761 |
if (ra[1]*(d = fabs(pg[1])) > 1.0)
| 762 |
ra[1] = 1.0/d;
| 763 |
if (ra[0] > ra[1])
| 764 |
ra[0] = ra[1];
| 765 |
| 766 |
if (ra[0] < minarad) {
| 767 |
ra[0] = minarad;
| 768 |
if (ra[1] < minarad)
| 769 |
ra[1] = minarad;
| 770 |
| 771 |
ra[0] *= d = 1.0/sqrt(fabs(wt));
| 772 |
if ((ra[1] *= d) > 2.0*ra[0])
| 773 |
ra[1] = 2.0*ra[0];
| 774 |
if (ra[1] > maxarad) {
| 775 |
ra[1] = maxarad;
| 776 |
if (ra[0] > maxarad)
| 777 |
ra[0] = maxarad;
| 778 |
| 779 |
/* flag encroached directions */
| 780 |
if (crlp != NULL) /* XXX doesn't update with changes to ambacc */
| 781 |
*crlp = ambcorral(hp, uv, ra[0]*ambacc, ra[1]*ambacc);
| 782 |
if (pg != NULL) { /* cap gradient if necessary */
| 783 |
d = pg[0]*pg[0]*ra[0]*ra[0] + pg[1]*pg[1]*ra[1]*ra[1];
| 784 |
if (d > 1.0) {
| 785 |
d = 1.0/sqrt(d);
| 786 |
pg[0] *= d;
| 787 |
pg[1] *= d;
| 788 |
| 789 |
| 790 |
| 791 |
free(hp); /* clean up and return */
| 792 |
return(1);
| 793 |
