| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: ambcomp.c,v 2.70 2015/05/21 05:54:54 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Routines to compute "ambient" values using Monte Carlo
| 6 |
| 7 |
* Hessian calculations based on "Practical Hessian-Based Error Control
| 8 |
* for Irradiance Caching" by Schwarzhaupt, Wann Jensen, & Jarosz
| 9 |
* from ACM SIGGRAPH Asia 2012 conference proceedings.
| 10 |
| 11 |
* Added book-keeping optimization to avoid calculations that would
| 12 |
* cancel due to traversal both directions on edges that are adjacent
| 13 |
* to same-valued triangles. This cuts about half of Hessian math.
| 14 |
| 15 |
* Declarations of external symbols in ambient.h
| 16 |
| 17 |
| 18 |
#include "copyright.h"
| 19 |
| 20 |
#include "ray.h"
| 21 |
#include "ambient.h"
| 22 |
#include "random.h"
| 23 |
| 24 |
#ifndef OLDAMB
| 25 |
| 26 |
extern void SDsquare2disk(double ds[2], double seedx, double seedy);
| 27 |
| 28 |
typedef struct {
| 29 |
COLOR v; /* hemisphere sample value */
| 30 |
float d; /* reciprocal distance (1/rt) */
| 31 |
FVECT p; /* intersection point */
| 32 |
} AMBSAMP; /* sample value */
| 33 |
| 34 |
typedef struct {
| 35 |
RAY *rp; /* originating ray sample */
| 36 |
int ns; /* number of samples per axis */
| 37 |
int sampOK; /* acquired full sample set? */
| 38 |
COLOR acoef; /* division contribution coefficient */
| 39 |
double acol[3]; /* accumulated color */
| 40 |
FVECT ux, uy; /* tangent axis unit vectors */
| 41 |
AMBSAMP sa[1]; /* sample array (extends struct) */
| 42 |
} AMBHEMI; /* ambient sample hemisphere */
| 43 |
| 44 |
#define AI(h,i,j) ((i)*(h)->ns + (j))
| 45 |
#define ambsam(h,i,j) (h)->sa[AI(h,i,j)]
| 46 |
| 47 |
typedef struct {
| 48 |
FVECT r_i, r_i1, e_i, rcp, rI2_eJ2;
| 49 |
double I1, I2;
| 50 |
} FFTRI; /* vectors and coefficients for Hessian calculation */
| 51 |
| 52 |
| 53 |
static int
| 54 |
ambsample( /* initial ambient division sample */
| 55 |
AMBHEMI *hp,
| 56 |
int i,
| 57 |
int j,
| 58 |
int n
| 59 |
| 60 |
| 61 |
AMBSAMP *ap = &ambsam(hp,i,j);
| 62 |
RAY ar;
| 63 |
int hlist[3], ii;
| 64 |
double spt[2], zd;
| 65 |
/* generate hemispherical sample */
| 66 |
/* ambient coefficient for weight */
| 67 |
if (ambacc > FTINY)
| 68 |
setcolor(ar.rcoef, AVGREFL, AVGREFL, AVGREFL);
| 69 |
else
| 70 |
copycolor(ar.rcoef, hp->acoef);
| 71 |
if (rayorigin(&ar, AMBIENT, hp->rp, ar.rcoef) < 0)
| 72 |
return(0);
| 73 |
if (ambacc > FTINY) {
| 74 |
multcolor(ar.rcoef, hp->acoef);
| 75 |
scalecolor(ar.rcoef, 1./AVGREFL);
| 76 |
| 77 |
hlist[0] = hp->rp->rno;
| 78 |
hlist[1] = j;
| 79 |
hlist[2] = i;
| 80 |
multisamp(spt, 2, urand(ilhash(hlist,3)+n));
| 81 |
/* avoid coincident samples */
| 82 |
if (!n && (0 < i) & (i < hp->ns-1) &&
| 83 |
(0 < j) & (j < hp->ns-1)) {
| 84 |
if ((spt[0] < 0.1) | (spt[0] >= 0.9))
| 85 |
spt[0] = 0.1 + 0.8*frandom();
| 86 |
if ((spt[1] < 0.1) | (spt[1] >= 0.9))
| 87 |
spt[1] = 0.1 + 0.8*frandom();
| 88 |
| 89 |
SDsquare2disk(spt, (j+spt[1])/hp->ns, (i+spt[0])/hp->ns);
| 90 |
zd = sqrt(1. - spt[0]*spt[0] - spt[1]*spt[1]);
| 91 |
for (ii = 3; ii--; )
| 92 |
ar.rdir[ii] = spt[0]*hp->ux[ii] +
| 93 |
spt[1]*hp->uy[ii] +
| 94 |
zd*hp->rp->ron[ii];
| 95 |
checknorm(ar.rdir);
| 96 |
dimlist[ndims++] = AI(hp,i,j) + 90171;
| 97 |
rayvalue(&ar); /* evaluate ray */
| 98 |
ndims--;
| 99 |
if (ar.rt <= FTINY)
| 100 |
return(0); /* should never happen */
| 101 |
multcolor(ar.rcol, ar.rcoef); /* apply coefficient */
| 102 |
if (ar.rt*ap->d < 1.0) /* new/closer distance? */
| 103 |
ap->d = 1.0/ar.rt;
| 104 |
if (!n) { /* record first vertex & value */
| 105 |
if (ar.rt > 10.0*thescene.cusize)
| 106 |
ar.rt = 10.0*thescene.cusize;
| 107 |
VSUM(ap->p, ar.rorg, ar.rdir, ar.rt);
| 108 |
copycolor(ap->v, ar.rcol);
| 109 |
} else { /* else update recorded value */
| 110 |
hp->acol[RED] -= colval(ap->v,RED);
| 111 |
hp->acol[GRN] -= colval(ap->v,GRN);
| 112 |
hp->acol[BLU] -= colval(ap->v,BLU);
| 113 |
zd = 1.0/(double)(n+1);
| 114 |
scalecolor(ar.rcol, zd);
| 115 |
zd *= (double)n;
| 116 |
scalecolor(ap->v, zd);
| 117 |
addcolor(ap->v, ar.rcol);
| 118 |
| 119 |
addcolor(hp->acol, ap->v); /* add to our sum */
| 120 |
return(1);
| 121 |
| 122 |
| 123 |
| 124 |
/* Estimate errors based on ambient division differences */
| 125 |
static float *
| 126 |
getambdiffs(AMBHEMI *hp)
| 127 |
| 128 |
float *earr = (float *)calloc(hp->ns*hp->ns, sizeof(float));
| 129 |
float *ep;
| 130 |
AMBSAMP *ap;
| 131 |
double b, d2;
| 132 |
int i, j;
| 133 |
| 134 |
if (earr == NULL) /* out of memory? */
| 135 |
return(NULL);
| 136 |
/* compute squared neighbor diffs */
| 137 |
for (ap = hp->sa, ep = earr, i = 0; i < hp->ns; i++)
| 138 |
for (j = 0; j < hp->ns; j++, ap++, ep++) {
| 139 |
b = bright(ap[0].v);
| 140 |
if (i) { /* from above */
| 141 |
d2 = b - bright(ap[-hp->ns].v);
| 142 |
d2 *= d2;
| 143 |
ep[0] += d2;
| 144 |
ep[-hp->ns] += d2;
| 145 |
| 146 |
if (!j) continue;
| 147 |
/* from behind */
| 148 |
d2 = b - bright(ap[-1].v);
| 149 |
d2 *= d2;
| 150 |
ep[0] += d2;
| 151 |
ep[-1] += d2;
| 152 |
if (!i) continue;
| 153 |
/* diagonal */
| 154 |
d2 = b - bright(ap[-hp->ns-1].v);
| 155 |
d2 *= d2;
| 156 |
ep[0] += d2;
| 157 |
ep[-hp->ns-1] += d2;
| 158 |
| 159 |
/* correct for number of neighbors */
| 160 |
earr[0] *= 8./3.;
| 161 |
earr[hp->ns-1] *= 8./3.;
| 162 |
earr[(hp->ns-1)*hp->ns] *= 8./3.;
| 163 |
earr[(hp->ns-1)*hp->ns + hp->ns-1] *= 8./3.;
| 164 |
for (i = 1; i < hp->ns-1; i++) {
| 165 |
earr[i*hp->ns] *= 8./5.;
| 166 |
earr[i*hp->ns + hp->ns-1] *= 8./5.;
| 167 |
| 168 |
for (j = 1; j < hp->ns-1; j++) {
| 169 |
earr[j] *= 8./5.;
| 170 |
earr[(hp->ns-1)*hp->ns + j] *= 8./5.;
| 171 |
| 172 |
return(earr);
| 173 |
| 174 |
| 175 |
| 176 |
/* Perform super-sampling on hemisphere (introduces bias) */
| 177 |
static void
| 178 |
ambsupersamp(AMBHEMI *hp, int cnt)
| 179 |
| 180 |
float *earr = getambdiffs(hp);
| 181 |
double e2rem = 0;
| 182 |
AMBSAMP *ap;
| 183 |
float *ep;
| 184 |
int i, j, n, nss;
| 185 |
| 186 |
if (earr == NULL) /* just skip calc. if no memory */
| 187 |
return;
| 188 |
/* accumulate estimated variances */
| 189 |
for (ep = earr + hp->ns*hp->ns; ep > earr; )
| 190 |
e2rem += *--ep;
| 191 |
ep = earr; /* perform super-sampling */
| 192 |
for (ap = hp->sa, i = 0; i < hp->ns; i++)
| 193 |
for (j = 0; j < hp->ns; j++, ap++) {
| 194 |
if (e2rem <= FTINY)
| 195 |
goto done; /* nothing left to do */
| 196 |
nss = *ep/e2rem*cnt + frandom();
| 197 |
for (n = 1; n <= nss && ambsample(hp,i,j,n); n++)
| 198 |
--cnt;
| 199 |
e2rem -= *ep++; /* update remainder */
| 200 |
| 201 |
done:
| 202 |
free(earr);
| 203 |
| 204 |
| 205 |
| 206 |
static AMBHEMI *
| 207 |
samp_hemi( /* sample indirect hemisphere */
| 208 |
COLOR rcol,
| 209 |
RAY *r,
| 210 |
double wt
| 211 |
| 212 |
| 213 |
AMBHEMI *hp;
| 214 |
double d;
| 215 |
int n, i, j;
| 216 |
/* set number of divisions */
| 217 |
if (ambacc <= FTINY &&
| 218 |
wt > (d = 0.8*intens(rcol)*r->rweight/(ambdiv*minweight)))
| 219 |
wt = d; /* avoid ray termination */
| 220 |
n = sqrt(ambdiv * wt) + 0.5;
| 221 |
i = 1 + 5*(ambacc > FTINY); /* minimum number of samples */
| 222 |
if (n < i)
| 223 |
n = i;
| 224 |
/* allocate sampling array */
| 225 |
hp = (AMBHEMI *)malloc(sizeof(AMBHEMI) + sizeof(AMBSAMP)*(n*n - 1));
| 226 |
if (hp == NULL)
| 227 |
error(SYSTEM, "out of memory in samp_hemi");
| 228 |
hp->rp = r;
| 229 |
hp->ns = n;
| 230 |
hp->acol[RED] = hp->acol[GRN] = hp->acol[BLU] = 0.0;
| 231 |
memset(hp->sa, 0, sizeof(AMBSAMP)*n*n);
| 232 |
hp->sampOK = 0;
| 233 |
/* assign coefficient */
| 234 |
copycolor(hp->acoef, rcol);
| 235 |
d = 1.0/(n*n);
| 236 |
scalecolor(hp->acoef, d);
| 237 |
/* make tangent plane axes */
| 238 |
if (!getperpendicular(hp->ux, r->ron, 1))
| 239 |
error(CONSISTENCY, "bad ray direction in samp_hemi");
| 240 |
VCROSS(hp->uy, r->ron, hp->ux);
| 241 |
/* sample divisions */
| 242 |
for (i = hp->ns; i--; )
| 243 |
for (j = hp->ns; j--; )
| 244 |
hp->sampOK += ambsample(hp, i, j, 0);
| 245 |
copycolor(rcol, hp->acol);
| 246 |
if (!hp->sampOK) { /* utter failure? */
| 247 |
free(hp);
| 248 |
return(NULL);
| 249 |
| 250 |
if (hp->sampOK < hp->ns*hp->ns) {
| 251 |
hp->sampOK *= -1; /* soft failure */
| 252 |
return(hp);
| 253 |
| 254 |
n = ambssamp*wt + 0.5;
| 255 |
if (n > 8) { /* perform super-sampling? */
| 256 |
ambsupersamp(hp, n);
| 257 |
| 258 |
| 259 |
return(hp); /* all is well */
| 260 |
| 261 |
| 262 |
| 263 |
/* Return brightness of farthest ambient sample */
| 264 |
static double
| 265 |
back_ambval(AMBHEMI *hp, const int n1, const int n2, const int n3)
| 266 |
| 267 |
if (hp->sa[n1].d <= hp->sa[n2].d) {
| 268 |
if (hp->sa[n1].d <= hp->sa[n3].d)
| 269 |
return(colval(hp->sa[n1].v,CIEY));
| 270 |
return(colval(hp->sa[n3].v,CIEY));
| 271 |
| 272 |
if (hp->sa[n2].d <= hp->sa[n3].d)
| 273 |
return(colval(hp->sa[n2].v,CIEY));
| 274 |
| 275 |
| 276 |
| 277 |
| 278 |
/* Compute vectors and coefficients for Hessian/gradient calcs */
| 279 |
static void
| 280 |
comp_fftri(FFTRI *ftp, AMBHEMI *hp, const int n0, const int n1)
| 281 |
| 282 |
double rdot_cp, dot_e, dot_er, rdot_r, rdot_r1, J2;
| 283 |
int ii;
| 284 |
| 285 |
VSUB(ftp->r_i, hp->sa[n0].p, hp->rp->rop);
| 286 |
VSUB(ftp->r_i1, hp->sa[n1].p, hp->rp->rop);
| 287 |
VSUB(ftp->e_i, hp->sa[n1].p, hp->sa[n0].p);
| 288 |
VCROSS(ftp->rcp, ftp->r_i, ftp->r_i1);
| 289 |
rdot_cp = 1.0/DOT(ftp->rcp,ftp->rcp);
| 290 |
dot_e = DOT(ftp->e_i,ftp->e_i);
| 291 |
dot_er = DOT(ftp->e_i, ftp->r_i);
| 292 |
rdot_r = 1.0/DOT(ftp->r_i,ftp->r_i);
| 293 |
rdot_r1 = 1.0/DOT(ftp->r_i1,ftp->r_i1);
| 294 |
ftp->I1 = acos( DOT(ftp->r_i, ftp->r_i1) * sqrt(rdot_r*rdot_r1) ) *
| 295 |
sqrt( rdot_cp );
| 296 |
ftp->I2 = ( DOT(ftp->e_i, ftp->r_i1)*rdot_r1 - dot_er*rdot_r +
| 297 |
dot_e*ftp->I1 )*0.5*rdot_cp;
| 298 |
J2 = ( 0.5*(rdot_r - rdot_r1) - dot_er*ftp->I2 ) / dot_e;
| 299 |
| 300 |
ftp->rI2_eJ2[ii] = ftp->I2*ftp->r_i[ii] + J2*ftp->e_i[ii];
| 301 |
| 302 |
| 303 |
| 304 |
/* Compose 3x3 matrix from two vectors */
| 305 |
static void
| 306 |
compose_matrix(FVECT mat[3], FVECT va, FVECT vb)
| 307 |
| 308 |
mat[0][0] = 2.0*va[0]*vb[0];
| 309 |
mat[1][1] = 2.0*va[1]*vb[1];
| 310 |
mat[2][2] = 2.0*va[2]*vb[2];
| 311 |
mat[0][1] = mat[1][0] = va[0]*vb[1] + va[1]*vb[0];
| 312 |
mat[0][2] = mat[2][0] = va[0]*vb[2] + va[2]*vb[0];
| 313 |
mat[1][2] = mat[2][1] = va[1]*vb[2] + va[2]*vb[1];
| 314 |
| 315 |
| 316 |
| 317 |
/* Compute partial 3x3 Hessian matrix for edge */
| 318 |
static void
| 319 |
comp_hessian(FVECT hess[3], FFTRI *ftp, FVECT nrm)
| 320 |
| 321 |
FVECT ncp;
| 322 |
FVECT m1[3], m2[3], m3[3], m4[3];
| 323 |
double d1, d2, d3, d4;
| 324 |
double I3, J3, K3;
| 325 |
int i, j;
| 326 |
/* compute intermediate coefficients */
| 327 |
d1 = 1.0/DOT(ftp->r_i,ftp->r_i);
| 328 |
d2 = 1.0/DOT(ftp->r_i1,ftp->r_i1);
| 329 |
d3 = 1.0/DOT(ftp->e_i,ftp->e_i);
| 330 |
d4 = DOT(ftp->e_i, ftp->r_i);
| 331 |
I3 = ( DOT(ftp->e_i, ftp->r_i1)*d2*d2 - d4*d1*d1 + 3.0/d3*ftp->I2 )
| 332 |
/ ( 4.0*DOT(ftp->rcp,ftp->rcp) );
| 333 |
J3 = 0.25*d3*(d1*d1 - d2*d2) - d4*d3*I3;
| 334 |
K3 = d3*(ftp->I2 - I3/d1 - 2.0*d4*J3);
| 335 |
/* intermediate matrices */
| 336 |
VCROSS(ncp, nrm, ftp->e_i);
| 337 |
compose_matrix(m1, ncp, ftp->rI2_eJ2);
| 338 |
compose_matrix(m2, ftp->r_i, ftp->r_i);
| 339 |
compose_matrix(m3, ftp->e_i, ftp->e_i);
| 340 |
compose_matrix(m4, ftp->r_i, ftp->e_i);
| 341 |
d1 = DOT(nrm, ftp->rcp);
| 342 |
d2 = -d1*ftp->I2;
| 343 |
d1 *= 2.0;
| 344 |
for (i = 3; i--; ) /* final matrix sum */
| 345 |
for (j = 3; j--; ) {
| 346 |
hess[i][j] = m1[i][j] + d1*( I3*m2[i][j] + K3*m3[i][j] +
| 347 |
2.0*J3*m4[i][j] );
| 348 |
hess[i][j] += d2*(i==j);
| 349 |
hess[i][j] *= -1.0/PI;
| 350 |
| 351 |
| 352 |
| 353 |
| 354 |
/* Reverse hessian calculation result for edge in other direction */
| 355 |
static void
| 356 |
rev_hessian(FVECT hess[3])
| 357 |
| 358 |
int i;
| 359 |
| 360 |
for (i = 3; i--; ) {
| 361 |
hess[i][0] = -hess[i][0];
| 362 |
hess[i][1] = -hess[i][1];
| 363 |
hess[i][2] = -hess[i][2];
| 364 |
| 365 |
| 366 |
| 367 |
| 368 |
/* Add to radiometric Hessian from the given triangle */
| 369 |
static void
| 370 |
add2hessian(FVECT hess[3], FVECT ehess1[3],
| 371 |
FVECT ehess2[3], FVECT ehess3[3], double v)
| 372 |
| 373 |
int i, j;
| 374 |
| 375 |
for (i = 3; i--; )
| 376 |
for (j = 3; j--; )
| 377 |
hess[i][j] += v*( ehess1[i][j] + ehess2[i][j] + ehess3[i][j] );
| 378 |
| 379 |
| 380 |
| 381 |
/* Compute partial displacement form factor gradient for edge */
| 382 |
static void
| 383 |
comp_gradient(FVECT grad, FFTRI *ftp, FVECT nrm)
| 384 |
| 385 |
FVECT ncp;
| 386 |
double f1;
| 387 |
int i;
| 388 |
| 389 |
f1 = 2.0*DOT(nrm, ftp->rcp);
| 390 |
| 391 |
for (i = 3; i--; )
| 392 |
grad[i] = (0.5/PI)*( ftp->I1*ncp[i] + f1*ftp->rI2_eJ2[i] );
| 393 |
| 394 |
| 395 |
| 396 |
/* Reverse gradient calculation result for edge in other direction */
| 397 |
static void
| 398 |
rev_gradient(FVECT grad)
| 399 |
| 400 |
grad[0] = -grad[0];
| 401 |
grad[1] = -grad[1];
| 402 |
grad[2] = -grad[2];
| 403 |
| 404 |
| 405 |
| 406 |
/* Add to displacement gradient from the given triangle */
| 407 |
static void
| 408 |
add2gradient(FVECT grad, FVECT egrad1, FVECT egrad2, FVECT egrad3, double v)
| 409 |
| 410 |
int i;
| 411 |
| 412 |
for (i = 3; i--; )
| 413 |
grad[i] += v*( egrad1[i] + egrad2[i] + egrad3[i] );
| 414 |
| 415 |
| 416 |
| 417 |
/* Compute anisotropic radii and eigenvector directions */
| 418 |
static void
| 419 |
eigenvectors(FVECT uv[2], float ra[2], FVECT hessian[3])
| 420 |
| 421 |
double hess2[2][2];
| 422 |
FVECT a, b;
| 423 |
double evalue[2], slope1, xmag1;
| 424 |
int i;
| 425 |
/* project Hessian to sample plane */
| 426 |
| 427 |
a[i] = DOT(hessian[i], uv[0]);
| 428 |
b[i] = DOT(hessian[i], uv[1]);
| 429 |
| 430 |
hess2[0][0] = DOT(uv[0], a);
| 431 |
hess2[0][1] = DOT(uv[0], b);
| 432 |
hess2[1][0] = DOT(uv[1], a);
| 433 |
hess2[1][1] = DOT(uv[1], b);
| 434 |
/* compute eigenvalue(s) */
| 435 |
i = quadratic(evalue, 1.0, -hess2[0][0]-hess2[1][1],
| 436 |
hess2[0][0]*hess2[1][1]-hess2[0][1]*hess2[1][0]);
| 437 |
if (i == 1) /* double-root (circle) */
| 438 |
evalue[1] = evalue[0];
| 439 |
if (!i || ((evalue[0] = fabs(evalue[0])) <= FTINY*FTINY) |
| 440 |
((evalue[1] = fabs(evalue[1])) <= FTINY*FTINY) ) {
| 441 |
ra[0] = ra[1] = maxarad;
| 442 |
return;
| 443 |
| 444 |
if (evalue[0] > evalue[1]) {
| 445 |
ra[0] = sqrt(sqrt(4.0/evalue[0]));
| 446 |
ra[1] = sqrt(sqrt(4.0/evalue[1]));
| 447 |
slope1 = evalue[1];
| 448 |
} else {
| 449 |
ra[0] = sqrt(sqrt(4.0/evalue[1]));
| 450 |
ra[1] = sqrt(sqrt(4.0/evalue[0]));
| 451 |
slope1 = evalue[0];
| 452 |
| 453 |
/* compute unit eigenvectors */
| 454 |
if (fabs(hess2[0][1]) <= FTINY)
| 455 |
return; /* uv OK as is */
| 456 |
slope1 = (slope1 - hess2[0][0]) / hess2[0][1];
| 457 |
xmag1 = sqrt(1.0/(1.0 + slope1*slope1));
| 458 |
| 459 |
b[i] = xmag1*uv[0][i] + slope1*xmag1*uv[1][i];
| 460 |
a[i] = slope1*xmag1*uv[0][i] - xmag1*uv[1][i];
| 461 |
| 462 |
VCOPY(uv[0], a);
| 463 |
VCOPY(uv[1], b);
| 464 |
| 465 |
| 466 |
| 467 |
static void
| 468 |
ambHessian( /* anisotropic radii & pos. gradient */
| 469 |
AMBHEMI *hp,
| 470 |
FVECT uv[2], /* returned */
| 471 |
float ra[2], /* returned (optional) */
| 472 |
float pg[2] /* returned (optional) */
| 473 |
| 474 |
| 475 |
static char memerrmsg[] = "out of memory in ambHessian()";
| 476 |
FVECT (*hessrow)[3] = NULL;
| 477 |
FVECT *gradrow = NULL;
| 478 |
FVECT hessian[3];
| 479 |
FVECT gradient;
| 480 |
FFTRI fftr;
| 481 |
int i, j;
| 482 |
/* be sure to assign unit vectors */
| 483 |
VCOPY(uv[0], hp->ux);
| 484 |
VCOPY(uv[1], hp->uy);
| 485 |
/* clock-wise vertex traversal from sample POV */
| 486 |
if (ra != NULL) { /* initialize Hessian row buffer */
| 487 |
hessrow = (FVECT (*)[3])malloc(sizeof(FVECT)*3*(hp->ns-1));
| 488 |
if (hessrow == NULL)
| 489 |
error(SYSTEM, memerrmsg);
| 490 |
memset(hessian, 0, sizeof(hessian));
| 491 |
} else if (pg == NULL) /* bogus call? */
| 492 |
return;
| 493 |
if (pg != NULL) { /* initialize form factor row buffer */
| 494 |
gradrow = (FVECT *)malloc(sizeof(FVECT)*(hp->ns-1));
| 495 |
if (gradrow == NULL)
| 496 |
| 497 |
memset(gradient, 0, sizeof(gradient));
| 498 |
| 499 |
/* compute first row of edges */
| 500 |
for (j = 0; j < hp->ns-1; j++) {
| 501 |
comp_fftri(&fftr, hp, AI(hp,0,j), AI(hp,0,j+1));
| 502 |
if (hessrow != NULL)
| 503 |
comp_hessian(hessrow[j], &fftr, hp->rp->ron);
| 504 |
if (gradrow != NULL)
| 505 |
comp_gradient(gradrow[j], &fftr, hp->rp->ron);
| 506 |
| 507 |
/* sum each row of triangles */
| 508 |
for (i = 0; i < hp->ns-1; i++) {
| 509 |
FVECT hesscol[3]; /* compute first vertical edge */
| 510 |
FVECT gradcol;
| 511 |
comp_fftri(&fftr, hp, AI(hp,i,0), AI(hp,i+1,0));
| 512 |
| 513 |
comp_hessian(hesscol, &fftr, hp->rp->ron);
| 514 |
| 515 |
comp_gradient(gradcol, &fftr, hp->rp->ron);
| 516 |
| 517 |
FVECT hessdia[3]; /* compute triangle contributions */
| 518 |
FVECT graddia;
| 519 |
double backg;
| 520 |
backg = back_ambval(hp, AI(hp,i,j),
| 521 |
AI(hp,i,j+1), AI(hp,i+1,j));
| 522 |
/* diagonal (inner) edge */
| 523 |
comp_fftri(&fftr, hp, AI(hp,i,j+1), AI(hp,i+1,j));
| 524 |
if (hessrow != NULL) {
| 525 |
comp_hessian(hessdia, &fftr, hp->rp->ron);
| 526 |
rev_hessian(hesscol);
| 527 |
add2hessian(hessian, hessrow[j], hessdia, hesscol, backg);
| 528 |
| 529 |
if (gradrow != NULL) {
| 530 |
comp_gradient(graddia, &fftr, hp->rp->ron);
| 531 |
rev_gradient(gradcol);
| 532 |
add2gradient(gradient, gradrow[j], graddia, gradcol, backg);
| 533 |
| 534 |
/* initialize edge in next row */
| 535 |
comp_fftri(&fftr, hp, AI(hp,i+1,j+1), AI(hp,i+1,j));
| 536 |
| 537 |
| 538 |
| 539 |
| 540 |
/* new column edge & paired triangle */
| 541 |
backg = back_ambval(hp, AI(hp,i+1,j+1),
| 542 |
AI(hp,i+1,j), AI(hp,i,j+1));
| 543 |
comp_fftri(&fftr, hp, AI(hp,i,j+1), AI(hp,i+1,j+1));
| 544 |
| 545 |
| 546 |
rev_hessian(hessdia);
| 547 |
| 548 |
if (i < hp->ns-2)
| 549 |
rev_hessian(hessrow[j]);
| 550 |
| 551 |
| 552 |
| 553 |
rev_gradient(graddia);
| 554 |
| 555 |
if (i < hp->ns-2)
| 556 |
rev_gradient(gradrow[j]);
| 557 |
| 558 |
| 559 |
| 560 |
/* release row buffers */
| 561 |
if (hessrow != NULL) free(hessrow);
| 562 |
if (gradrow != NULL) free(gradrow);
| 563 |
| 564 |
if (ra != NULL) /* extract eigenvectors & radii */
| 565 |
eigenvectors(uv, ra, hessian);
| 566 |
if (pg != NULL) { /* tangential position gradient */
| 567 |
pg[0] = DOT(gradient, uv[0]);
| 568 |
pg[1] = DOT(gradient, uv[1]);
| 569 |
| 570 |
| 571 |
| 572 |
| 573 |
/* Compute direction gradient from a hemispherical sampling */
| 574 |
static void
| 575 |
ambdirgrad(AMBHEMI *hp, FVECT uv[2], float dg[2])
| 576 |
| 577 |
AMBSAMP *ap;
| 578 |
double dgsum[2];
| 579 |
int n;
| 580 |
FVECT vd;
| 581 |
double gfact;
| 582 |
| 583 |
dgsum[0] = dgsum[1] = 0.0; /* sum values times -tan(theta) */
| 584 |
for (ap = hp->sa, n = hp->ns*hp->ns; n--; ap++) {
| 585 |
/* use vector for azimuth + 90deg */
| 586 |
VSUB(vd, ap->p, hp->rp->rop);
| 587 |
/* brightness over cosine factor */
| 588 |
gfact = colval(ap->v,CIEY) / DOT(hp->rp->ron, vd);
| 589 |
/* sine = proj_radius/vd_length */
| 590 |
dgsum[0] -= DOT(uv[1], vd) * gfact;
| 591 |
dgsum[1] += DOT(uv[0], vd) * gfact;
| 592 |
| 593 |
dg[0] = dgsum[0] / (hp->ns*hp->ns);
| 594 |
dg[1] = dgsum[1] / (hp->ns*hp->ns);
| 595 |
| 596 |
| 597 |
| 598 |
/* Compute potential light leak direction flags for cache value */
| 599 |
static uint32
| 600 |
ambcorral(AMBHEMI *hp, FVECT uv[2], const double r0, const double r1)
| 601 |
| 602 |
const double max_d = 1.0/(minarad*ambacc + 0.001);
| 603 |
const double ang_res = 0.5*PI/hp->ns;
| 604 |
const double ang_step = ang_res/((int)(16/PI*ang_res) + 1.01);
| 605 |
double avg_d = 0;
| 606 |
uint32 flgs = 0;
| 607 |
FVECT vec;
| 608 |
double u, v;
| 609 |
double ang, a1;
| 610 |
int i, j;
| 611 |
/* don't bother for a few samples */
| 612 |
if (hp->ns < 12)
| 613 |
return(0);
| 614 |
/* check distances overhead */
| 615 |
for (i = hp->ns*3/4; i-- > hp->ns>>2; )
| 616 |
for (j = hp->ns*3/4; j-- > hp->ns>>2; )
| 617 |
avg_d += ambsam(hp,i,j).d;
| 618 |
avg_d *= 4.0/(hp->ns*hp->ns);
| 619 |
if (avg_d*r0 >= 1.0) /* ceiling too low for corral? */
| 620 |
return(0);
| 621 |
if (avg_d >= max_d) /* insurance */
| 622 |
return(0);
| 623 |
/* else circle around perimeter */
| 624 |
for (i = 0; i < hp->ns; i++)
| 625 |
for (j = 0; j < hp->ns; j += !i|(i==hp->ns-1) ? 1 : hp->ns-1) {
| 626 |
| 627 |
if ((ap->d <= FTINY) | (ap->d >= max_d))
| 628 |
continue; /* too far or too near */
| 629 |
VSUB(vec, ap->p, hp->rp->rop);
| 630 |
u = DOT(vec, uv[0]);
| 631 |
v = DOT(vec, uv[1]);
| 632 |
if ((r0*r0*u*u + r1*r1*v*v) * ap->d*ap->d <= u*u + v*v)
| 633 |
continue; /* occluder outside ellipse */
| 634 |
ang = atan2a(v, u); /* else set direction flags */
| 635 |
for (a1 = ang-ang_res; a1 <= ang+ang_res; a1 += ang_step)
| 636 |
flgs |= 1L<<(int)(16/PI*(a1 + 2.*PI*(a1 < 0)));
| 637 |
| 638 |
/* add low-angle incident (< 20deg) */
| 639 |
if (fabs(hp->rp->rod) <= 0.342) {
| 640 |
u = -DOT(hp->rp->rdir, uv[0]);
| 641 |
v = -DOT(hp->rp->rdir, uv[1]);
| 642 |
if ((r0*r0*u*u + r1*r1*v*v) > hp->rp->rot*hp->rp->rot) {
| 643 |
ang = atan2a(v, u);
| 644 |
ang += 2.*PI*(ang < 0);
| 645 |
ang *= 16/PI;
| 646 |
if ((ang < .5) | (ang >= 31.5))
| 647 |
flgs |= 0x80000001;
| 648 |
else
| 649 |
flgs |= 3L<<(int)(ang-.5);
| 650 |
| 651 |
| 652 |
return(flgs);
| 653 |
| 654 |
| 655 |
| 656 |
int
| 657 |
doambient( /* compute ambient component */
| 658 |
COLOR rcol, /* input/output color */
| 659 |
RAY *r,
| 660 |
double wt,
| 661 |
FVECT uv[2], /* returned (optional) */
| 662 |
| 663 |
float pg[2], /* returned (optional) */
| 664 |
float dg[2], /* returned (optional) */
| 665 |
uint32 *crlp /* returned (optional) */
| 666 |
| 667 |
| 668 |
AMBHEMI *hp = samp_hemi(rcol, r, wt);
| 669 |
FVECT my_uv[2];
| 670 |
double d, K;
| 671 |
AMBSAMP *ap;
| 672 |
int i;
| 673 |
/* clear return values */
| 674 |
if (uv != NULL)
| 675 |
memset(uv, 0, sizeof(FVECT)*2);
| 676 |
if (ra != NULL)
| 677 |
ra[0] = ra[1] = 0.0;
| 678 |
if (pg != NULL)
| 679 |
pg[0] = pg[1] = 0.0;
| 680 |
if (dg != NULL)
| 681 |
dg[0] = dg[1] = 0.0;
| 682 |
if (crlp != NULL)
| 683 |
*crlp = 0;
| 684 |
if (hp == NULL) /* sampling falure? */
| 685 |
return(0);
| 686 |
| 687 |
if ((ra == NULL) & (pg == NULL) & (dg == NULL) ||
| 688 |
(hp->sampOK < 0) | (hp->ns < 6)) {
| 689 |
free(hp); /* Hessian not requested/possible */
| 690 |
return(-1); /* value-only return value */
| 691 |
| 692 |
if ((d = bright(rcol)) > FTINY) { /* normalize Y values */
| 693 |
d = 0.99*(hp->ns*hp->ns)/d;
| 694 |
K = 0.01;
| 695 |
} else { /* or fall back on geometric Hessian */
| 696 |
K = 1.0;
| 697 |
pg = NULL;
| 698 |
dg = NULL;
| 699 |
crlp = NULL;
| 700 |
| 701 |
ap = hp->sa; /* relative Y channel from here on... */
| 702 |
for (i = hp->ns*hp->ns; i--; ap++)
| 703 |
colval(ap->v,CIEY) = bright(ap->v)*d + K;
| 704 |
| 705 |
if (uv == NULL) /* make sure we have axis pointers */
| 706 |
uv = my_uv;
| 707 |
/* compute radii & pos. gradient */
| 708 |
ambHessian(hp, uv, ra, pg);
| 709 |
| 710 |
if (dg != NULL) /* compute direction gradient */
| 711 |
ambdirgrad(hp, uv, dg);
| 712 |
| 713 |
if (ra != NULL) { /* scale/clamp radii */
| 714 |
if (pg != NULL) {
| 715 |
if (ra[0]*(d = fabs(pg[0])) > 1.0)
| 716 |
ra[0] = 1.0/d;
| 717 |
if (ra[1]*(d = fabs(pg[1])) > 1.0)
| 718 |
ra[1] = 1.0/d;
| 719 |
if (ra[0] > ra[1])
| 720 |
ra[0] = ra[1];
| 721 |
| 722 |
if (ra[0] < minarad) {
| 723 |
ra[0] = minarad;
| 724 |
if (ra[1] < minarad)
| 725 |
ra[1] = minarad;
| 726 |
| 727 |
ra[0] *= d = 1.0/sqrt(wt);
| 728 |
if ((ra[1] *= d) > 2.0*ra[0])
| 729 |
ra[1] = 2.0*ra[0];
| 730 |
if (ra[1] > maxarad) {
| 731 |
ra[1] = maxarad;
| 732 |
if (ra[0] > maxarad)
| 733 |
ra[0] = maxarad;
| 734 |
| 735 |
/* flag encroached directions */
| 736 |
if (crlp != NULL)
| 737 |
*crlp = ambcorral(hp, uv, ra[0]*ambacc, ra[1]*ambacc);
| 738 |
if (pg != NULL) { /* cap gradient if necessary */
| 739 |
d = pg[0]*pg[0]*ra[0]*ra[0] + pg[1]*pg[1]*ra[1]*ra[1];
| 740 |
if (d > 1.0) {
| 741 |
d = 1.0/sqrt(d);
| 742 |
pg[0] *= d;
| 743 |
pg[1] *= d;
| 744 |
| 745 |
| 746 |
| 747 |
free(hp); /* clean up and return */
| 748 |
return(1);
| 749 |
| 750 |
| 751 |
| 752 |
#else /* ! NEWAMB */
| 753 |
| 754 |
| 755 |
void
| 756 |
inithemi( /* initialize sampling hemisphere */
| 757 |
AMBHEMI *hp,
| 758 |
COLOR ac,
| 759 |
RAY *r,
| 760 |
double wt
| 761 |
| 762 |
| 763 |
double d;
| 764 |
int i;
| 765 |
| 766 |
| 767 |
wt > (d = 0.8*intens(ac)*r->rweight/(ambdiv*minweight)))
| 768 |
| 769 |
hp->nt = sqrt(ambdiv * wt / PI) + 0.5;
| 770 |
i = ambacc > FTINY ? 3 : 1; /* minimum number of samples */
| 771 |
if (hp->nt < i)
| 772 |
hp->nt = i;
| 773 |
hp->np = PI * hp->nt + 0.5;
| 774 |
/* set number of super-samples */
| 775 |
hp->ns = ambssamp * wt + 0.5;
| 776 |
| 777 |
copycolor(hp->acoef, ac);
| 778 |
d = 1.0/(hp->nt*hp->np);
| 779 |
| 780 |
/* make axes */
| 781 |
VCOPY(hp->uz, r->ron);
| 782 |
hp->uy[0] = hp->uy[1] = hp->uy[2] = 0.0;
| 783 |
for (i = 0; i < 3; i++)
| 784 |
if (hp->uz[i] < 0.6 && hp->uz[i] > -0.6)
| 785 |
break;
| 786 |
if (i >= 3)
| 787 |
error(CONSISTENCY, "bad ray direction in inithemi");
| 788 |
hp->uy[i] = 1.0;
| 789 |
fcross(hp->ux, hp->uy, hp->uz);
| 790 |
normalize(hp->ux);
| 791 |
fcross(hp->uy, hp->uz, hp->ux);
| 792 |
| 793 |
| 794 |
| 795 |
int
| 796 |
divsample( /* sample a division */
| 797 |
AMBSAMP *dp,
| 798 |
AMBHEMI *h,
| 799 |
RAY *r
| 800 |
| 801 |
| 802 |
RAY ar;
| 803 |
int hlist[3];
| 804 |
double spt[2];
| 805 |
double xd, yd, zd;
| 806 |
double b2;
| 807 |
double phi;
| 808 |
int i;
| 809 |
| 810 |
if (ambacc > FTINY)
| 811 |
| 812 |
else
| 813 |
copycolor(ar.rcoef, h->acoef);
| 814 |
if (rayorigin(&ar, AMBIENT, r, ar.rcoef) < 0)
| 815 |
return(-1);
| 816 |
| 817 |
multcolor(ar.rcoef, h->acoef);
| 818 |
| 819 |
| 820 |
hlist[0] = r->rno;
| 821 |
hlist[1] = dp->t;
| 822 |
hlist[2] = dp->p;
| 823 |
multisamp(spt, 2, urand(ilhash(hlist,3)+dp->n));
| 824 |
zd = sqrt((dp->t + spt[0])/h->nt);
| 825 |
phi = 2.0*PI * (dp->p + spt[1])/h->np;
| 826 |
xd = tcos(phi) * zd;
| 827 |
yd = tsin(phi) * zd;
| 828 |
zd = sqrt(1.0 - zd*zd);
| 829 |
| 830 |
ar.rdir[i] = xd*h->ux[i] +
| 831 |
yd*h->uy[i] +
| 832 |
zd*h->uz[i];
| 833 |
checknorm(ar.rdir);
| 834 |
dimlist[ndims++] = dp->t*h->np + dp->p + 90171;
| 835 |
rayvalue(&ar);
| 836 |
ndims--;
| 837 |
| 838 |
addcolor(dp->v, ar.rcol);
| 839 |
/* use rt to improve gradient calc */
| 840 |
if (ar.rt > FTINY && ar.rt < FHUGE)
| 841 |
dp->r += 1.0/ar.rt;
| 842 |
/* (re)initialize error */
| 843 |
if (dp->n++) {
| 844 |
b2 = bright(dp->v)/dp->n - bright(ar.rcol);
| 845 |
b2 = b2*b2 + dp->k*((dp->n-1)*(dp->n-1));
| 846 |
dp->k = b2/(dp->n*dp->n);
| 847 |
} else
| 848 |
dp->k = 0.0;
| 849 |
return(0);
| 850 |
| 851 |
| 852 |
| 853 |
static int
| 854 |
ambcmp( /* decreasing order */
| 855 |
const void *p1,
| 856 |
const void *p2
| 857 |
| 858 |
| 859 |
const AMBSAMP *d1 = (const AMBSAMP *)p1;
| 860 |
const AMBSAMP *d2 = (const AMBSAMP *)p2;
| 861 |
| 862 |
if (d1->k < d2->k)
| 863 |
return(1);
| 864 |
if (d1->k > d2->k)
| 865 |
return(-1);
| 866 |
return(0);
| 867 |
| 868 |
| 869 |
| 870 |
static int
| 871 |
ambnorm( /* standard order */
| 872 |
const void *p1,
| 873 |
const void *p2
| 874 |
| 875 |
| 876 |
| 877 |
| 878 |
int c;
| 879 |
| 880 |
if ( (c = d1->t - d2->t) )
| 881 |
return(c);
| 882 |
return(d1->p - d2->p);
| 883 |
| 884 |
| 885 |
| 886 |
double
| 887 |
| 888 |
COLOR rcol,
| 889 |
RAY *r,
| 890 |
double wt,
| 891 |
FVECT pg,
| 892 |
FVECT dg
| 893 |
| 894 |
| 895 |
double b, d=0;
| 896 |
AMBHEMI hemi;
| 897 |
AMBSAMP *div;
| 898 |
AMBSAMP dnew;
| 899 |
double acol[3];
| 900 |
AMBSAMP *dp;
| 901 |
double arad;
| 902 |
int divcnt;
| 903 |
int i, j;
| 904 |
/* initialize hemisphere */
| 905 |
inithemi(&hemi, rcol, r, wt);
| 906 |
divcnt = hemi.nt * hemi.np;
| 907 |
/* initialize */
| 908 |
if (pg != NULL)
| 909 |
pg[0] = pg[1] = pg[2] = 0.0;
| 910 |
if (dg != NULL)
| 911 |
dg[0] = dg[1] = dg[2] = 0.0;
| 912 |
setcolor(rcol, 0.0, 0.0, 0.0);
| 913 |
if (divcnt == 0)
| 914 |
return(0.0);
| 915 |
/* allocate super-samples */
| 916 |
if (hemi.ns > 0 || pg != NULL || dg != NULL) {
| 917 |
div = (AMBSAMP *)malloc(divcnt*sizeof(AMBSAMP));
| 918 |
if (div == NULL)
| 919 |
error(SYSTEM, "out of memory in doambient");
| 920 |
} else
| 921 |
div = NULL;
| 922 |
/* sample the divisions */
| 923 |
arad = 0.0;
| 924 |
acol[0] = acol[1] = acol[2] = 0.0;
| 925 |
if ((dp = div) == NULL)
| 926 |
dp = &dnew;
| 927 |
divcnt = 0;
| 928 |
for (i = 0; i < hemi.nt; i++)
| 929 |
for (j = 0; j < hemi.np; j++) {
| 930 |
dp->t = i; dp->p = j;
| 931 |
setcolor(dp->v, 0.0, 0.0, 0.0);
| 932 |
dp->r = 0.0;
| 933 |
dp->n = 0;
| 934 |
if (divsample(dp, &hemi, r) < 0) {
| 935 |
if (div != NULL)
| 936 |
dp++;
| 937 |
continue;
| 938 |
| 939 |
arad += dp->r;
| 940 |
divcnt++;
| 941 |
if (div != NULL)
| 942 |
dp++;
| 943 |
else
| 944 |
addcolor(acol, dp->v);
| 945 |
| 946 |
if (!divcnt) {
| 947 |
if (div != NULL)
| 948 |
free((void *)div);
| 949 |
return(0.0); /* no samples taken */
| 950 |
| 951 |
if (divcnt < hemi.nt*hemi.np) {
| 952 |
pg = dg = NULL; /* incomplete sampling */
| 953 |
hemi.ns = 0;
| 954 |
} else if (arad > FTINY && divcnt/arad < minarad) {
| 955 |
hemi.ns = 0; /* close enough */
| 956 |
} else if (hemi.ns > 0) { /* else perform super-sampling? */
| 957 |
comperrs(div, &hemi); /* compute errors */
| 958 |
qsort(div, divcnt, sizeof(AMBSAMP), ambcmp); /* sort divs */
| 959 |
/* super-sample */
| 960 |
for (i = hemi.ns; i > 0; i--) {
| 961 |
dnew = *div;
| 962 |
if (divsample(&dnew, &hemi, r) < 0) {
| 963 |
dp++;
| 964 |
continue;
| 965 |
| 966 |
dp = div; /* reinsert */
| 967 |
j = divcnt < i ? divcnt : i;
| 968 |
while (--j > 0 && dnew.k < dp[1].k) {
| 969 |
*dp = *(dp+1);
| 970 |
dp++;
| 971 |
| 972 |
*dp = dnew;
| 973 |
| 974 |
if (pg != NULL || dg != NULL) /* restore order */
| 975 |
qsort(div, divcnt, sizeof(AMBSAMP), ambnorm);
| 976 |
| 977 |
/* compute returned values */
| 978 |
if (div != NULL) {
| 979 |
arad = 0.0; /* note: divcnt may be < nt*np */
| 980 |
for (i = hemi.nt*hemi.np, dp = div; i-- > 0; dp++) {
| 981 |
arad += dp->r;
| 982 |
if (dp->n > 1) {
| 983 |
b = 1.0/dp->n;
| 984 |
scalecolor(dp->v, b);
| 985 |
dp->r *= b;
| 986 |
dp->n = 1;
| 987 |
| 988 |
| 989 |
| 990 |
b = bright(acol);
| 991 |
if (b > FTINY) {
| 992 |
b = 1.0/b; /* compute & normalize gradient(s) */
| 993 |
if (pg != NULL) {
| 994 |
posgradient(pg, div, &hemi);
| 995 |
| 996 |
pg[i] *= b;
| 997 |
| 998 |
if (dg != NULL) {
| 999 |
dirgradient(dg, div, &hemi);
| 1000 |
| 1001 |
dg[i] *= b;
| 1002 |
| 1003 |
| 1004 |
free((void *)div);
| 1005 |
| 1006 |
copycolor(rcol, acol);
| 1007 |
if (arad <= FTINY)
| 1008 |
arad = maxarad;
| 1009 |
else
| 1010 |
arad = (divcnt+hemi.ns)/arad;
| 1011 |
if (pg != NULL) { /* reduce radius if gradient large */
| 1012 |
d = DOT(pg,pg);
| 1013 |
if (d*arad*arad > 1.0)
| 1014 |
arad = 1.0/sqrt(d);
| 1015 |
| 1016 |
if (arad < minarad) {
| 1017 |
arad = minarad;
| 1018 |
if (pg != NULL && d*arad*arad > 1.0) { /* cap gradient */
| 1019 |
d = 1.0/arad/sqrt(d);
| 1020 |
| 1021 |
pg[i] *= d;
| 1022 |
| 1023 |
| 1024 |
if ((arad /= sqrt(wt)) > maxarad)
| 1025 |
arad = maxarad;
| 1026 |
return(arad);
| 1027 |
| 1028 |
| 1029 |
| 1030 |
void
| 1031 |
comperrs( /* compute initial error estimates */
| 1032 |
AMBSAMP *da, /* assumes standard ordering */
| 1033 |
AMBHEMI *hp
| 1034 |
| 1035 |
| 1036 |
double b, b2;
| 1037 |
int i, j;
| 1038 |
AMBSAMP *dp;
| 1039 |
/* sum differences from neighbors */
| 1040 |
dp = da;
| 1041 |
for (i = 0; i < hp->nt; i++)
| 1042 |
for (j = 0; j < hp->np; j++) {
| 1043 |
#ifdef DEBUG
| 1044 |
if (dp->t != i || dp->p != j)
| 1045 |
error(CONSISTENCY,
| 1046 |
"division order in comperrs");
| 1047 |
#endif
| 1048 |
b = bright(dp[0].v);
| 1049 |
if (i > 0) { /* from above */
| 1050 |
b2 = bright(dp[-hp->np].v) - b;
| 1051 |
b2 *= b2 * 0.25;
| 1052 |
dp[0].k += b2;
| 1053 |
dp[-hp->np].k += b2;
| 1054 |
| 1055 |
if (j > 0) { /* from behind */
| 1056 |
b2 = bright(dp[-1].v) - b;
| 1057 |
b2 *= b2 * 0.25;
| 1058 |
dp[0].k += b2;
| 1059 |
dp[-1].k += b2;
| 1060 |
} else { /* around */
| 1061 |
b2 = bright(dp[hp->np-1].v) - b;
| 1062 |
b2 *= b2 * 0.25;
| 1063 |
dp[0].k += b2;
| 1064 |
dp[hp->np-1].k += b2;
| 1065 |
| 1066 |
dp++;
| 1067 |
| 1068 |
/* divide by number of neighbors */
| 1069 |
dp = da;
| 1070 |
for (j = 0; j < hp->np; j++) /* top row */
| 1071 |
(dp++)->k *= 1.0/3.0;
| 1072 |
if (hp->nt < 2)
| 1073 |
return;
| 1074 |
for (i = 1; i < hp->nt-1; i++) /* central region */
| 1075 |
| 1076 |
(dp++)->k *= 0.25;
| 1077 |
for (j = 0; j < hp->np; j++) /* bottom row */
| 1078 |
| 1079 |
| 1080 |
| 1081 |
| 1082 |
void
| 1083 |
posgradient( /* compute position gradient */
| 1084 |
FVECT gv,
| 1085 |
| 1086 |
AMBHEMI *hp
| 1087 |
| 1088 |
| 1089 |
int i, j;
| 1090 |
double nextsine, lastsine, b, d;
| 1091 |
double mag0, mag1;
| 1092 |
double phi, cosp, sinp, xd, yd;
| 1093 |
AMBSAMP *dp;
| 1094 |
| 1095 |
xd = yd = 0.0;
| 1096 |
| 1097 |
dp = da + j;
| 1098 |
mag0 = mag1 = 0.0;
| 1099 |
lastsine = 0.0;
| 1100 |
for (i = 0; i < hp->nt; i++) {
| 1101 |
#ifdef DEBUG
| 1102 |
| 1103 |
error(CONSISTENCY,
| 1104 |
"division order in posgradient");
| 1105 |
#endif
| 1106 |
b = bright(dp->v);
| 1107 |
if (i > 0) {
| 1108 |
d = dp[-hp->np].r;
| 1109 |
if (dp[0].r > d) d = dp[0].r;
| 1110 |
/* sin(t)*cos(t)^2 */
| 1111 |
d *= lastsine * (1.0 - (double)i/hp->nt);
| 1112 |
mag0 += d*(b - bright(dp[-hp->np].v));
| 1113 |
| 1114 |
nextsine = sqrt((double)(i+1)/hp->nt);
| 1115 |
if (j > 0) {
| 1116 |
d = dp[-1].r;
| 1117 |
| 1118 |
mag1 += d * (nextsine - lastsine) *
| 1119 |
(b - bright(dp[-1].v));
| 1120 |
} else {
| 1121 |
d = dp[hp->np-1].r;
| 1122 |
| 1123 |
| 1124 |
(b - bright(dp[hp->np-1].v));
| 1125 |
| 1126 |
dp += hp->np;
| 1127 |
lastsine = nextsine;
| 1128 |
| 1129 |
mag0 *= 2.0*PI / hp->np;
| 1130 |
phi = 2.0*PI * (double)j/hp->np;
| 1131 |
cosp = tcos(phi); sinp = tsin(phi);
| 1132 |
xd += mag0*cosp - mag1*sinp;
| 1133 |
yd += mag0*sinp + mag1*cosp;
| 1134 |
| 1135 |
| 1136 |
gv[i] = (xd*hp->ux[i] + yd*hp->uy[i])*(hp->nt*hp->np)/PI;
| 1137 |
| 1138 |
| 1139 |
| 1140 |
void
| 1141 |
dirgradient( /* compute direction gradient */
| 1142 |
FVECT gv,
| 1143 |
| 1144 |
AMBHEMI *hp
| 1145 |
| 1146 |
| 1147 |
int i, j;
| 1148 |
double mag;
| 1149 |
double phi, xd, yd;
| 1150 |
AMBSAMP *dp;
| 1151 |
| 1152 |
xd = yd = 0.0;
| 1153 |
| 1154 |
dp = da + j;
| 1155 |
mag = 0.0;
| 1156 |
| 1157 |
#ifdef DEBUG
| 1158 |
| 1159 |
error(CONSISTENCY,
| 1160 |
"division order in dirgradient");
| 1161 |
#endif
| 1162 |
/* tan(t) */
| 1163 |
mag += bright(dp->v)/sqrt(hp->nt/(i+.5) - 1.0);
| 1164 |
dp += hp->np;
| 1165 |
| 1166 |
phi = 2.0*PI * (j+.5)/hp->np + PI/2.0;
| 1167 |
xd += mag * tcos(phi);
| 1168 |
yd += mag * tsin(phi);
| 1169 |
| 1170 |
| 1171 |
gv[i] = xd*hp->ux[i] + yd*hp->uy[i];
| 1172 |
| 1173 |
| 1174 |
#endif /* ! NEWAMB */
