root/radiance/ray/src/rt/ambcomp.c
Revision: 2.98
Committed: Thu Apr 24 01:43:58 2025 UTC (3 months, 2 weeks ago) by greg
Changes since 2.97: +6 -3 lines
perf: Removed ambient collision test for -aa 0, and set maximum threshold to 7°
2 static const char RCSid[] = "$Id: ambcomp.c,v 2.97 2025/01/18 03:49:00 greg Exp $";
5 * Routines to compute "ambient" values using Monte Carlo
6 *
7 * Hessian calculations based on "Practical Hessian-Based Error Control
8 * for Irradiance Caching" by Schwarzhaupt, Wann Jensen, & Jarosz
9 * from ACM SIGGRAPH Asia 2012 conference proceedings.
10 *
11 * Added book-keeping optimization to avoid calculations that would
12 * cancel due to traversal both directions on edges that are adjacent
13 * to same-valued triangles. This cuts about half of Hessian math.
14 *
15 * Declarations of external symbols in ambient.h
16 */
17
18 #include "copyright.h"
19
20 #include "ray.h"
21 #include "ambient.h"
22 #include "random.h"
23
24 #ifndef MINADIV
25 #define MINADIV 7 /* minimum # divisions in each dimension */
26 #endif
27
28 typedef struct {
29 FVECT p; /* intersection point */
30 float d; /* reciprocal distance */
31 SCOLOR v; /* hemisphere sample value */
32 } AMBSAMP; /* sample value */
33
34 typedef struct {
35 RAY *rp; /* originating ray sample */
36 int ns; /* number of samples per axis */
37 int sampOK; /* acquired full sample set? */
38 int atyp; /* RAMBIENT or TAMBIENT */
39 SCOLOR acoef; /* division contribution coefficient */
40 SCOLOR acol; /* accumulated color */
41 FVECT onrm; /* oriented unperturbed surface normal */
42 FVECT ux, uy; /* tangent axis unit vectors */
43 AMBSAMP sa[1]; /* sample array (extends struct) */
44 } AMBHEMI; /* ambient sample hemisphere */
45
46 #define AI(h,i,j) ((i)*(h)->ns + (j))
47 #define ambsam(h,i,j) (h)->sa[AI(h,i,j)]
48
49 typedef struct {
50 FVECT r_i, r_i1, e_i, rcp, rI2_eJ2;
51 double I1, I2;
52 } FFTRI; /* vectors and coefficients for Hessian calculation */
53
54
55 static int
56 ambcollision( /* proposed direciton collides? */
57 AMBHEMI *hp,
58 int i,
59 int j,
60 FVECT dv
61 )
62 {
63 double cos_thresh;
64 int ii, jj;
65 /* min. spacing = 1/4th division */
66 cos_thresh = (PI/4.)/(double)hp->ns;
67 if (cos_thresh > 7.*PI/180.) /* 7 degrees is enough in any case */
68 cos_thresh = 7.*PI/180.;
69 cos_thresh = 1. - .5*cos_thresh*cos_thresh;
70 /* check existing neighbors */
71 for (ii = i-1; ii <= i+1; ii++) {
72 if (ii < 0) continue;
73 if (ii >= hp->ns) break;
74 for (jj = j-1; jj <= j+1; jj++) {
75 AMBSAMP *ap;
76 FVECT avec;
77 double dprod;
78 if (jj < 0) continue;
79 if (jj >= hp->ns) break;
80 if ((ii==i) & (jj==j)) continue;
81 ap = &ambsam(hp,ii,jj);
82 if (ap->d <= .5/FHUGE)
83 continue; /* no one home */
84 VSUB(avec, ap->p, hp->rp->rop);
85 dprod = DOT(avec, dv);
86 if (dprod >= cos_thresh*VLEN(avec))
87 return(1); /* collision */
88 }
89 }
90 return(0); /* nothing to worry about */
91 }
92
93
94 static int
95 ambsample( /* initial ambient division sample */
96 AMBHEMI *hp,
97 int i,
98 int j,
99 int n
100 )
101 {
102 AMBSAMP *ap = &ambsam(hp,i,j);
103 RAY ar;
104 int hlist[3], ii;
105 double ss[2];
106 RREAL spt[2];
107 double zd;
108 /* generate hemispherical sample */
109 /* ambient coefficient for weight */
110 if (ambacc > FTINY)
111 setscolor(ar.rcoef, AVGREFL, AVGREFL, AVGREFL);
112 else
113 copyscolor(ar.rcoef, hp->acoef);
114 if (rayorigin(&ar, hp->atyp, hp->rp, ar.rcoef) < 0)
115 return(0);
116 if (ambacc > FTINY) {
117 smultscolor(ar.rcoef, hp->acoef);
118 scalescolor(ar.rcoef, 1./AVGREFL);
119 }
120 hlist[0] = hp->rp->rno;
121 hlist[1] = AI(hp,i,j);
122 hlist[2] = samplendx;
123 multisamp(ss, 2, urand(ilhash(hlist,3)+n));
124 resample:
125 square2disk(spt, (j+ss[1])/hp->ns, (i+ss[0])/hp->ns);
126 zd = sqrt(1. - spt[0]*spt[0] - spt[1]*spt[1]);
127 for (ii = 3; ii--; )
128 ar.rdir[ii] = spt[0]*hp->ux[ii] +
129 spt[1]*hp->uy[ii] +
130 zd*hp->onrm[ii];
131 checknorm(ar.rdir);
132 /* avoid coincident samples? */
133 if (!n & (ambacc > FTINY) & (hp->ns >= 4) &&
134 ambcollision(hp, i, j, ar.rdir)) {
135 ss[0] = frandom(); ss[1] = frandom();
136 goto resample; /* reject this sample */
137 }
138 dimlist[ndims++] = AI(hp,i,j) + 90171;
139 rayvalue(&ar); /* evaluate ray */
140 ndims--;
141 zd = raydistance(&ar);
142 if (zd <= FTINY)
143 return(0); /* should never happen */
144 smultscolor(ar.rcol, ar.rcoef); /* apply coefficient */
145 if (zd*ap->d < 1.0) /* new/closer distance? */
146 ap->d = 1.0/zd;
147 if (!n) { /* record first vertex & value */
148 if (zd > 10.0*thescene.cusize + 1000.)
149 zd = 10.0*thescene.cusize + 1000.;
150 VSUM(ap->p, ar.rorg, ar.rdir, zd);
151 copyscolor(ap->v, ar.rcol);
152 } else { /* else update recorded value */
153 sopscolor(hp->acol, -=, ap->v);
154 zd = 1.0/(double)(n+1);
155 scalescolor(ar.rcol, zd);
156 zd *= (double)n;
157 scalescolor(ap->v, zd);
158 saddscolor(ap->v, ar.rcol);
159 }
160 saddscolor(hp->acol, ap->v); /* add to our sum */
161 return(1);
162 }
163
164
165 /* Estimate variance based on ambient division differences */
166 static float *
167 getambdiffs(AMBHEMI *hp)
168 {
169 const double normf = 1./(pbright(hp->acoef) + FTINY);
170 float *earr = (float *)calloc(2*hp->ns*hp->ns, sizeof(float));
171 float *ep;
172 AMBSAMP *ap;
173 double b, b1, d2;
174 int i, j;
175
176 if (earr == NULL) /* out of memory? */
177 return(NULL);
178 /* sum squared neighbor diffs */
179 ap = hp->sa;
180 ep = earr + hp->ns*hp->ns; /* original estimates to scratch */
181 for (i = 0; i < hp->ns; i++)
182 for (j = 0; j < hp->ns; j++, ap++, ep++) {
183 b = pbright(ap[0].v);
184 if (i) { /* from above */
185 b1 = pbright(ap[-hp->ns].v);
186 d2 = b - b1;
187 d2 *= d2*normf/(b + b1 + FTINY);
188 ep[0] += d2;
189 ep[-hp->ns] += d2;
190 }
191 if (!j) continue;
192 /* from behind */
193 b1 = pbright(ap[-1].v);
194 d2 = b - b1;
195 d2 *= d2*normf/(b + b1 + FTINY);
196 ep[0] += d2;
197 ep[-1] += d2;
198 if (!i) continue;
199 /* diagonal */
200 b1 = pbright(ap[-hp->ns-1].v);
201 d2 = b - b1;
202 d2 *= d2*normf/(b + b1 + FTINY);
203 ep[0] += d2;
204 ep[-hp->ns-1] += d2;
205 }
206 /* correct for number of neighbors */
207 ep = earr + hp->ns*hp->ns;
208 ep[0] *= 6./3.;
209 ep[hp->ns-1] *= 6./3.;
210 ep[(hp->ns-1)*hp->ns] *= 6./3.;
211 ep[(hp->ns-1)*hp->ns + hp->ns-1] *= 6./3.;
212 for (i = 1; i < hp->ns-1; i++) {
213 ep[i*hp->ns] *= 6./5.;
214 ep[i*hp->ns + hp->ns-1] *= 6./5.;
215 }
216 for (j = 1; j < hp->ns-1; j++) {
217 ep[j] *= 6./5.;
218 ep[(hp->ns-1)*hp->ns + j] *= 6./5.;
219 }
220 /* blur final map to reduce bias */
221 for (i = 0; i < hp->ns-1; i++) {
222 float *ep2;
223 ep = earr + i*hp->ns;
224 ep2 = ep + hp->ns*hp->ns;
225 for (j = 0; j < hp->ns-1; j++, ep++, ep2++) {
226 ep[0] += .5*ep2[0] + .125*(ep2[1] + ep2[hp->ns]);
227 ep[1] += .125*ep2[0];
228 ep[hp->ns] += .125*ep2[0];
229 }
230 }
231 return(earr);
232 }
233
234
235 /* Perform super-sampling on hemisphere (introduces bias) */
236 static void
237 ambsupersamp(AMBHEMI *hp, int cnt)
238 {
239 float *earr = getambdiffs(hp);
240 double e2rem = 0;
241 float *ep;
242 int i, j, n, nss;
243
244 if (earr == NULL) /* just skip calc. if no memory */
245 return;
246 /* accumulate estimated variances */
247 for (ep = earr + hp->ns*hp->ns; ep > earr; )
248 e2rem += *--ep;
249 ep = earr; /* perform super-sampling */
250 for (i = 0; i < hp->ns; i++)
251 for (j = 0; j < hp->ns; j++) {
252 if (e2rem <= FTINY)
253 goto done; /* nothing left to do */
254 nss = *ep/e2rem*cnt + frandom();
255 for (n = 1; n <= nss && ambsample(hp,i,j,n); n++)
256 if (!--cnt) goto done;
257 e2rem -= *ep++; /* update remainder */
258 }
259 done:
260 free(earr);
261 }
262
263
264 static AMBHEMI *
265 samp_hemi( /* sample indirect hemisphere */
266 SCOLOR rcol,
267 RAY *r,
268 double wt
269 )
270 {
271 int backside = (wt < 0);
272 AMBHEMI *hp;
273 double d;
274 int n, i, j;
275 /* insignificance check */
276 d = sintens(rcol);
277 if (d <= FTINY)
278 return(NULL);
279 /* set number of divisions */
280 if (backside) wt = -wt;
281 if (ambacc <= FTINY &&
282 wt > (d *= 0.8*r->rweight/(ambdiv*minweight + 1e-20)))
283 wt = d; /* avoid ray termination */
284 n = sqrt(ambdiv * wt) + 0.5;
285 i = 1 + (MINADIV-1)*(ambacc > FTINY);
286 if (n < i) /* use minimum number of samples? */
287 n = i;
288 /* allocate sampling array */
289 hp = (AMBHEMI *)malloc(sizeof(AMBHEMI) + sizeof(AMBSAMP)*(n*n - 1));
290 if (hp == NULL)
291 error(SYSTEM, "out of memory in samp_hemi");
292
293 if (backside) {
294 hp->atyp = TAMBIENT;
295 hp->onrm[0] = -r->ron[0];
296 hp->onrm[1] = -r->ron[1];
297 hp->onrm[2] = -r->ron[2];
298 } else {
299 hp->atyp = RAMBIENT;
300 VCOPY(hp->onrm, r->ron);
301 }
302 hp->rp = r;
303 hp->ns = n;
304 scolorblack(hp->acol);
305 memset(hp->sa, 0, sizeof(AMBSAMP)*n*n);
306 hp->sampOK = 0;
307 /* assign coefficient */
308 copyscolor(hp->acoef, rcol);
309 d = 1.0/(n*n);
310 scalescolor(hp->acoef, d);
311 /* make tangent plane axes */
312 if (!getperpendicular(hp->ux, hp->onrm, 1))
313 error(CONSISTENCY, "bad ray direction in samp_hemi");
314 VCROSS(hp->uy, hp->onrm, hp->ux);
315 /* sample divisions */
316 for (i = hp->ns; i--; )
317 for (j = hp->ns; j--; )
318 hp->sampOK += ambsample(hp, i, j, 0);
319 copyscolor(rcol, hp->acol);
320 if (!hp->sampOK) { /* utter failure? */
321 free(hp);
322 return(NULL);
323 }
324 if (hp->sampOK < hp->ns*hp->ns) {
325 hp->sampOK *= -1; /* soft failure */
326 return(hp);
327 }
328 if (hp->sampOK <= MINADIV*MINADIV)
329 return(hp); /* don't bother super-sampling */
330 n = ambssamp*wt + 0.5;
331 if (n >= 4*hp->ns) { /* perform super-sampling? */
332 ambsupersamp(hp, n);
333 copyscolor(rcol, hp->acol);
334 }
335 return(hp); /* all is well */
336 }
337
338
339 /* Return brightness of farthest ambient sample */
340 static double
341 back_ambval(AMBHEMI *hp, const int n1, const int n2, const int n3)
342 {
343 if (hp->sa[n1].d <= hp->sa[n2].d) {
344 if (hp->sa[n1].d <= hp->sa[n3].d)
345 return(hp->sa[n1].v[0]);
346 return(hp->sa[n3].v[0]);
347 }
348 if (hp->sa[n2].d <= hp->sa[n3].d)
349 return(hp->sa[n2].v[0]);
350 return(hp->sa[n3].v[0]);
351 }
352
353
354 /* Compute vectors and coefficients for Hessian/gradient calcs */
355 static void
356 comp_fftri(FFTRI *ftp, AMBHEMI *hp, const int n0, const int n1)
357 {
358 double rdot_cp, dot_e, dot_er, rdot_r, rdot_r1, J2;
359 int ii;
360
361 VSUB(ftp->r_i, hp->sa[n0].p, hp->rp->rop);
362 VSUB(ftp->r_i1, hp->sa[n1].p, hp->rp->rop);
363 VSUB(ftp->e_i, hp->sa[n1].p, hp->sa[n0].p);
364 VCROSS(ftp->rcp, ftp->r_i, ftp->r_i1);
365 rdot_cp = 1.0/DOT(ftp->rcp,ftp->rcp);
366 dot_e = DOT(ftp->e_i,ftp->e_i);
367 dot_er = DOT(ftp->e_i, ftp->r_i);
368 rdot_r = 1.0/DOT(ftp->r_i,ftp->r_i);
369 rdot_r1 = 1.0/DOT(ftp->r_i1,ftp->r_i1);
370 ftp->I1 = acos( DOT(ftp->r_i, ftp->r_i1) * sqrt(rdot_r*rdot_r1) ) *
371 sqrt( rdot_cp );
372 ftp->I2 = ( DOT(ftp->e_i, ftp->r_i1)*rdot_r1 - dot_er*rdot_r +
373 dot_e*ftp->I1 )*0.5*rdot_cp;
374 J2 = ( 0.5*(rdot_r - rdot_r1) - dot_er*ftp->I2 ) / dot_e;
375 for (ii = 3; ii--; )
376 ftp->rI2_eJ2[ii] = ftp->I2*ftp->r_i[ii] + J2*ftp->e_i[ii];
377 }
378
379
380 /* Compose 3x3 matrix from two vectors */
381 static void
382 compose_matrix(FVECT mat[3], FVECT va, FVECT vb)
383 {
384 mat[0][0] = 2.0*va[0]*vb[0];
385 mat[1][1] = 2.0*va[1]*vb[1];
386 mat[2][2] = 2.0*va[2]*vb[2];
387 mat[0][1] = mat[1][0] = va[0]*vb[1] + va[1]*vb[0];
388 mat[0][2] = mat[2][0] = va[0]*vb[2] + va[2]*vb[0];
389 mat[1][2] = mat[2][1] = va[1]*vb[2] + va[2]*vb[1];
390 }
391
392
393 /* Compute partial 3x3 Hessian matrix for edge */
394 static void
395 comp_hessian(FVECT hess[3], FFTRI *ftp, FVECT nrm)
396 {
397 FVECT ncp;
398 FVECT m1[3], m2[3], m3[3], m4[3];
399 double d1, d2, d3, d4;
400 double I3, J3, K3;
401 int i, j;
402 /* compute intermediate coefficients */
403 d1 = 1.0/DOT(ftp->r_i,ftp->r_i);
404 d2 = 1.0/DOT(ftp->r_i1,ftp->r_i1);
405 d3 = 1.0/DOT(ftp->e_i,ftp->e_i);
406 d4 = DOT(ftp->e_i, ftp->r_i);
407 I3 = ( DOT(ftp->e_i, ftp->r_i1)*d2*d2 - d4*d1*d1 + 3.0/d3*ftp->I2 )
408 / ( 4.0*DOT(ftp->rcp,ftp->rcp) );
409 J3 = 0.25*d3*(d1*d1 - d2*d2) - d4*d3*I3;
410 K3 = d3*(ftp->I2 - I3/d1 - 2.0*d4*J3);
411 /* intermediate matrices */
412 VCROSS(ncp, nrm, ftp->e_i);
413 compose_matrix(m1, ncp, ftp->rI2_eJ2);
414 compose_matrix(m2, ftp->r_i, ftp->r_i);
415 compose_matrix(m3, ftp->e_i, ftp->e_i);
416 compose_matrix(m4, ftp->r_i, ftp->e_i);
417 d1 = DOT(nrm, ftp->rcp);
418 d2 = -d1*ftp->I2;
419 d1 *= 2.0;
420 for (i = 3; i--; ) /* final matrix sum */
421 for (j = 3; j--; ) {
422 hess[i][j] = m1[i][j] + d1*( I3*m2[i][j] + K3*m3[i][j] +
423 2.0*J3*m4[i][j] );
424 hess[i][j] += d2*(i==j);
425 hess[i][j] *= -1.0/PI;
426 }
427 }
428
429
430 /* Reverse hessian calculation result for edge in other direction */
431 static void
432 rev_hessian(FVECT hess[3])
433 {
434 int i;
435
436 for (i = 3; i--; ) {
437 hess[i][0] = -hess[i][0];
438 hess[i][1] = -hess[i][1];
439 hess[i][2] = -hess[i][2];
440 }
441 }
442
443
444 /* Add to radiometric Hessian from the given triangle */
445 static void
446 add2hessian(FVECT hess[3], FVECT ehess1[3],
447 FVECT ehess2[3], FVECT ehess3[3], double v)
448 {
449 int i, j;
450
451 for (i = 3; i--; )
452 for (j = 3; j--; )
453 hess[i][j] += v*( ehess1[i][j] + ehess2[i][j] + ehess3[i][j] );
454 }
455
456
457 /* Compute partial displacement form factor gradient for edge */
458 static void
459 comp_gradient(FVECT grad, FFTRI *ftp, FVECT nrm)
460 {
461 FVECT ncp;
462 double f1;
463 int i;
464
465 f1 = 2.0*DOT(nrm, ftp->rcp);
466 VCROSS(ncp, nrm, ftp->e_i);
467 for (i = 3; i--; )
468 grad[i] = (0.5/PI)*( ftp->I1*ncp[i] + f1*ftp->rI2_eJ2[i] );
469 }
470
471
472 /* Reverse gradient calculation result for edge in other direction */
473 static void
474 rev_gradient(FVECT grad)
475 {
476 grad[0] = -grad[0];
477 grad[1] = -grad[1];
478 grad[2] = -grad[2];
479 }
480
481
482 /* Add to displacement gradient from the given triangle */
483 static void
484 add2gradient(FVECT grad, FVECT egrad1, FVECT egrad2, FVECT egrad3, double v)
485 {
486 int i;
487
488 for (i = 3; i--; )
489 grad[i] += v*( egrad1[i] + egrad2[i] + egrad3[i] );
490 }
491
492
493 /* Compute anisotropic radii and eigenvector directions */
494 static void
495 eigenvectors(FVECT uv[2], float ra[2], FVECT hessian[3])
496 {
497 double hess2[2][2];
498 FVECT a, b;
499 double evalue[2], slope1, xmag1;
500 int i;
501 /* project Hessian to sample plane */
502 for (i = 3; i--; ) {
503 a[i] = DOT(hessian[i], uv[0]);
504 b[i] = DOT(hessian[i], uv[1]);
505 }
506 hess2[0][0] = DOT(uv[0], a);
507 hess2[0][1] = DOT(uv[0], b);
508 hess2[1][0] = DOT(uv[1], a);
509 hess2[1][1] = DOT(uv[1], b);
510 /* compute eigenvalue(s) */
511 i = quadratic(evalue, 1.0, -hess2[0][0]-hess2[1][1],
512 hess2[0][0]*hess2[1][1]-hess2[0][1]*hess2[1][0]);
513 if (i == 1) /* double-root (circle) */
514 evalue[1] = evalue[0];
515 if (!i || ((evalue[0] = fabs(evalue[0])) <= FTINY*FTINY) |
516 ((evalue[1] = fabs(evalue[1])) <= FTINY*FTINY) ) {
517 ra[0] = ra[1] = maxarad;
518 return;
519 }
520 if (evalue[0] > evalue[1]) {
521 ra[0] = sqrt(sqrt(4.0/evalue[0]));
522 ra[1] = sqrt(sqrt(4.0/evalue[1]));
523 slope1 = evalue[1];
524 } else {
525 ra[0] = sqrt(sqrt(4.0/evalue[1]));
526 ra[1] = sqrt(sqrt(4.0/evalue[0]));
527 slope1 = evalue[0];
528 }
529 /* compute unit eigenvectors */
530 if (fabs(hess2[0][1]) <= FTINY)
531 return; /* uv OK as is */
532 slope1 = (slope1 - hess2[0][0]) / hess2[0][1];
533 xmag1 = sqrt(1.0/(1.0 + slope1*slope1));
534 for (i = 3; i--; ) {
535 b[i] = xmag1*uv[0][i] + slope1*xmag1*uv[1][i];
536 a[i] = slope1*xmag1*uv[0][i] - xmag1*uv[1][i];
537 }
538 VCOPY(uv[0], a);
539 VCOPY(uv[1], b);
540 }
541
542
543 static void
544 ambHessian( /* anisotropic radii & pos. gradient */
545 AMBHEMI *hp,
546 FVECT uv[2], /* returned */
547 float ra[2], /* returned (optional) */
548 float pg[2] /* returned (optional) */
549 )
550 {
551 static char memerrmsg[] = "out of memory in ambHessian()";
552 FVECT (*hessrow)[3] = NULL;
553 FVECT *gradrow = NULL;
554 FVECT hessian[3];
555 FVECT gradient;
556 FFTRI fftr;
557 int i, j;
558 /* be sure to assign unit vectors */
559 VCOPY(uv[0], hp->ux);
560 VCOPY(uv[1], hp->uy);
561 /* clock-wise vertex traversal from sample POV */
562 if (ra != NULL) { /* initialize Hessian row buffer */
563 hessrow = (FVECT (*)[3])malloc(sizeof(FVECT)*3*(hp->ns-1));
564 if (hessrow == NULL)
565 error(SYSTEM, memerrmsg);
566 memset(hessian, 0, sizeof(hessian));
567 } else if (pg == NULL) /* bogus call? */
568 return;
569 if (pg != NULL) { /* initialize form factor row buffer */
570 gradrow = (FVECT *)malloc(sizeof(FVECT)*(hp->ns-1));
571 if (gradrow == NULL)
572 error(SYSTEM, memerrmsg);
573 memset(gradient, 0, sizeof(gradient));
574 }
575 /* compute first row of edges */
576 for (j = 0; j < hp->ns-1; j++) {
577 comp_fftri(&fftr, hp, AI(hp,0,j), AI(hp,0,j+1));
578 if (hessrow != NULL)
579 comp_hessian(hessrow[j], &fftr, hp->onrm);
580 if (gradrow != NULL)
581 comp_gradient(gradrow[j], &fftr, hp->onrm);
582 }
583 /* sum each row of triangles */
584 for (i = 0; i < hp->ns-1; i++) {
585 FVECT hesscol[3]; /* compute first vertical edge */
586 FVECT gradcol;
587 comp_fftri(&fftr, hp, AI(hp,i,0), AI(hp,i+1,0));
588 if (hessrow != NULL)
589 comp_hessian(hesscol, &fftr, hp->onrm);
590 if (gradrow != NULL)
591 comp_gradient(gradcol, &fftr, hp->onrm);
592 for (j = 0; j < hp->ns-1; j++) {
593 FVECT hessdia[3]; /* compute triangle contributions */
594 FVECT graddia;
595 double backg;
596 backg = back_ambval(hp, AI(hp,i,j),
597 AI(hp,i,j+1), AI(hp,i+1,j));
598 /* diagonal (inner) edge */
599 comp_fftri(&fftr, hp, AI(hp,i,j+1), AI(hp,i+1,j));
600 if (hessrow != NULL) {
601 comp_hessian(hessdia, &fftr, hp->onrm);
602 rev_hessian(hesscol);
603 add2hessian(hessian, hessrow[j], hessdia, hesscol, backg);
604 }
605 if (gradrow != NULL) {
606 comp_gradient(graddia, &fftr, hp->onrm);
607 rev_gradient(gradcol);
608 add2gradient(gradient, gradrow[j], graddia, gradcol, backg);
609 }
610 /* initialize edge in next row */
611 comp_fftri(&fftr, hp, AI(hp,i+1,j+1), AI(hp,i+1,j));
612 if (hessrow != NULL)
613 comp_hessian(hessrow[j], &fftr, hp->onrm);
614 if (gradrow != NULL)
615 comp_gradient(gradrow[j], &fftr, hp->onrm);
616 /* new column edge & paired triangle */
617 backg = back_ambval(hp, AI(hp,i+1,j+1),
618 AI(hp,i+1,j), AI(hp,i,j+1));
619 comp_fftri(&fftr, hp, AI(hp,i,j+1), AI(hp,i+1,j+1));
620 if (hessrow != NULL) {
621 comp_hessian(hesscol, &fftr, hp->onrm);
622 rev_hessian(hessdia);
623 add2hessian(hessian, hessrow[j], hessdia, hesscol, backg);
624 if (i < hp->ns-2)
625 rev_hessian(hessrow[j]);
626 }
627 if (gradrow != NULL) {
628 comp_gradient(gradcol, &fftr, hp->onrm);
629 rev_gradient(graddia);
630 add2gradient(gradient, gradrow[j], graddia, gradcol, backg);
631 if (i < hp->ns-2)
632 rev_gradient(gradrow[j]);
633 }
634 }
635 }
636 /* release row buffers */
637 if (hessrow != NULL) free(hessrow);
638 if (gradrow != NULL) free(gradrow);
639
640 if (ra != NULL) /* extract eigenvectors & radii */
641 eigenvectors(uv, ra, hessian);
642 if (pg != NULL) { /* tangential position gradient */
643 pg[0] = DOT(gradient, uv[0]);
644 pg[1] = DOT(gradient, uv[1]);
645 }
646 }
647
648
649 /* Compute direction gradient from a hemispherical sampling */
650 static void
651 ambdirgrad(AMBHEMI *hp, FVECT uv[2], float dg[2])
652 {
653 AMBSAMP *ap;
654 double dgsum[2];
655 int n;
656 FVECT vd;
657 double gfact;
658
659 dgsum[0] = dgsum[1] = 0.0; /* sum values times -tan(theta) */
660 for (ap = hp->sa, n = hp->ns*hp->ns; n--; ap++) {
661 /* use vector for azimuth + 90deg */
662 VSUB(vd, ap->p, hp->rp->rop);
663 /* brightness over cosine factor */
664 gfact = ap->v[0] / DOT(hp->onrm, vd);
665 /* sine = proj_radius/vd_length */
666 dgsum[0] -= DOT(uv[1], vd) * gfact;
667 dgsum[1] += DOT(uv[0], vd) * gfact;
668 }
669 dg[0] = dgsum[0] / (hp->ns*hp->ns);
670 dg[1] = dgsum[1] / (hp->ns*hp->ns);
671 }
672
673
674 /* Compute potential light leak direction flags for cache value */
675 static uint32
676 ambcorral(AMBHEMI *hp, FVECT uv[2], const double r0, const double r1)
677 {
678 const double max_d = 1.0/(minarad*ambacc + 0.001);
679 const double ang_res = 0.5*PI/hp->ns;
680 const double ang_step = ang_res/((int)(16/PI*ang_res) + 1.01);
681 double avg_d = 0;
682 uint32 flgs = 0;
683 FVECT vec;
684 double u, v;
685 double ang, a1;
686 int i, j;
687 /* don't bother for a few samples */
688 if (hp->ns < 8)
689 return(0);
690 /* check distances overhead */
691 for (i = hp->ns*3/4; i-- > hp->ns>>2; )
692 for (j = hp->ns*3/4; j-- > hp->ns>>2; )
693 avg_d += ambsam(hp,i,j).d;
694 avg_d *= 4.0/(hp->ns*hp->ns);
695 if (avg_d*r0 >= 1.0) /* ceiling too low for corral? */
696 return(0);
697 if (avg_d >= max_d) /* insurance */
698 return(0);
699 /* else circle around perimeter */
700 for (i = 0; i < hp->ns; i++)
701 for (j = 0; j < hp->ns; j += !i|(i==hp->ns-1) ? 1 : hp->ns-1) {
702 AMBSAMP *ap = &ambsam(hp,i,j);
703 if ((ap->d <= FTINY) | (ap->d >= max_d))
704 continue; /* too far or too near */
705 VSUB(vec, ap->p, hp->rp->rop);
706 u = DOT(vec, uv[0]);
707 v = DOT(vec, uv[1]);
708 if ((r0*r0*u*u + r1*r1*v*v) * ap->d*ap->d <= u*u + v*v)
709 continue; /* occluder outside ellipse */
710 ang = atan2a(v, u); /* else set direction flags */
711 for (a1 = ang-ang_res; a1 <= ang+ang_res; a1 += ang_step)
712 flgs |= 1L<<(int)(16/PI*(a1 + 2.*PI*(a1 < 0)));
713 }
714 return(flgs);
715 }
716
717
718 int
719 doambient( /* compute ambient component */
720 SCOLOR rcol, /* input/output color */
721 RAY *r,
722 double wt, /* negative for back side */
723 FVECT uv[2], /* returned (optional) */
724 float ra[2], /* returned (optional) */
725 float pg[2], /* returned (optional) */
726 float dg[2], /* returned (optional) */
727 uint32 *crlp /* returned (optional) */
728 )
729 {
730 AMBHEMI *hp = samp_hemi(rcol, r, wt);
731 FVECT my_uv[2];
732 double d, K;
733 AMBSAMP *ap;
734 int i;
735 /* clear return values */
736 if (uv != NULL)
737 memset(uv, 0, sizeof(FVECT)*2);
738 if (ra != NULL)
739 ra[0] = ra[1] = 0.0;
740 if (pg != NULL)
741 pg[0] = pg[1] = 0.0;
742 if (dg != NULL)
743 dg[0] = dg[1] = 0.0;
744 if (crlp != NULL)
745 *crlp = 0;
746 if (hp == NULL) /* sampling falure? */
747 return(0);
748
749 if ((ra == NULL) & (pg == NULL) & (dg == NULL) ||
750 (hp->sampOK < 0) | (hp->ns < MINADIV)) {
751 free(hp); /* Hessian not requested/possible */
752 return(-1); /* value-only return value */
753 }
754 if ((d = scolor_mean(rcol)) > FTINY) {
755 d = 0.99*(hp->ns*hp->ns)/d; /* normalize avg. values */
756 K = 0.01;
757 } else { /* or fall back on geometric Hessian */
758 K = 1.0;
759 pg = NULL;
760 dg = NULL;
761 crlp = NULL;
762 }
763 ap = hp->sa; /* single channel from here on... */
764 for (i = hp->ns*hp->ns; i--; ap++)
765 ap->v[0] = scolor_mean(ap->v)*d + K;
766
767 if (uv == NULL) /* make sure we have axis pointers */
768 uv = my_uv;
769 /* compute radii & pos. gradient */
770 ambHessian(hp, uv, ra, pg);
771
772 if (dg != NULL) /* compute direction gradient */
773 ambdirgrad(hp, uv, dg);
774
775 if (ra != NULL) { /* scale/clamp radii */
776 if (pg != NULL) {
777 if (ra[0]*(d = fabs(pg[0])) > 1.0)
778 ra[0] = 1.0/d;
779 if (ra[1]*(d = fabs(pg[1])) > 1.0)
780 ra[1] = 1.0/d;
781 if (ra[0] > ra[1])
782 ra[0] = ra[1];
783 }
784 if (ra[0] < minarad) {
785 ra[0] = minarad;
786 if (ra[1] < minarad)
787 ra[1] = minarad;
788 }
789 ra[0] *= d = 1.0/sqrt(fabs(wt));
790 if ((ra[1] *= d) > 2.0*ra[0])
791 ra[1] = 2.0*ra[0];
792 if (ra[1] > maxarad) {
793 ra[1] = maxarad;
794 if (ra[0] > maxarad)
795 ra[0] = maxarad;
796 }
797 /* flag encroached directions */
798 if (crlp != NULL) /* XXX doesn't update with changes to ambacc */
799 *crlp = ambcorral(hp, uv, ra[0]*ambacc, ra[1]*ambacc);
800 if (pg != NULL) { /* cap gradient if necessary */
801 d = pg[0]*pg[0]*ra[0]*ra[0] + pg[1]*pg[1]*ra[1]*ra[1];
802 if (d > 1.0) {
803 d = 1.0/sqrt(d);
804 pg[0] *= d;
805 pg[1] *= d;
806 }
807 }
808 }
809 free(hp); /* clean up and return */
810 return(1);
811 }
