root/radiance/ray/src/rt/ambcomp.c
Revision: 2.73
Committed: Fri Oct 14 00:54:21 2016 UTC (8 years, 9 months ago) by greg
Changes since 2.72: +40 -9 lines
2 static const char RCSid[] = "$Id: ambcomp.c,v 2.72 2016/03/16 15:43:04 greg Exp $";
5 * Routines to compute "ambient" values using Monte Carlo
6 *
7 * Hessian calculations based on "Practical Hessian-Based Error Control
8 * for Irradiance Caching" by Schwarzhaupt, Wann Jensen, & Jarosz
9 * from ACM SIGGRAPH Asia 2012 conference proceedings.
10 *
11 * Added book-keeping optimization to avoid calculations that would
12 * cancel due to traversal both directions on edges that are adjacent
13 * to same-valued triangles. This cuts about half of Hessian math.
14 *
15 * Declarations of external symbols in ambient.h
16 */
17
18 #include "copyright.h"
19
20 #include "ray.h"
21 #include "ambient.h"
22 #include "random.h"
23
24 #ifndef OLDAMB
25
26 extern void SDsquare2disk(double ds[2], double seedx, double seedy);
27
28 typedef struct {
29 COLOR v; /* hemisphere sample value */
30 float d; /* reciprocal distance (1/rt) */
31 FVECT p; /* intersection point */
32 } AMBSAMP; /* sample value */
33
34 typedef struct {
35 RAY *rp; /* originating ray sample */
36 int ns; /* number of samples per axis */
37 int sampOK; /* acquired full sample set? */
38 COLOR acoef; /* division contribution coefficient */
39 double acol[3]; /* accumulated color */
40 FVECT ux, uy; /* tangent axis unit vectors */
41 AMBSAMP sa[1]; /* sample array (extends struct) */
42 } AMBHEMI; /* ambient sample hemisphere */
43
44 #define AI(h,i,j) ((i)*(h)->ns + (j))
45 #define ambsam(h,i,j) (h)->sa[AI(h,i,j)]
46
47 typedef struct {
48 FVECT r_i, r_i1, e_i, rcp, rI2_eJ2;
49 double I1, I2;
50 } FFTRI; /* vectors and coefficients for Hessian calculation */
51
52
53 static int
54 ambcollision( /* proposed direciton collides? */
55 AMBHEMI *hp,
56 int i,
57 int j,
58 FVECT dv
59 )
60 {
61 const double cos_thresh = 0.9999995; /* about 3.44 arcminutes */
62 int ii, jj;
63
64 for (ii = i-1; ii <= i+1; ii++) {
65 if (ii < 0) continue;
66 if (ii >= hp->ns) break;
67 for (jj = j-1; jj <= j+1; jj++) {
68 AMBSAMP *ap;
69 FVECT avec;
70 double dprod;
71 if (jj < 0) continue;
72 if (jj >= hp->ns) break;
73 if ((ii==i) & (jj==j)) continue;
74 ap = &ambsam(hp,ii,jj);
75 if (ap->d <= .5/FHUGE) continue;
76 VSUB(avec, ap->p, hp->rp->rop);
77 dprod = DOT(avec, dv);
78 if (dprod >= cos_thresh*VLEN(avec))
79 return(1); /* collision */
80 }
81 }
82 return(0);
83 }
84
85
86 static int
87 ambsample( /* initial ambient division sample */
88 AMBHEMI *hp,
89 int i,
90 int j,
91 int n
92 )
93 {
94 AMBSAMP *ap = &ambsam(hp,i,j);
95 RAY ar;
96 int hlist[3], ii;
97 double spt[2], zd;
98 /* generate hemispherical sample */
99 /* ambient coefficient for weight */
100 if (ambacc > FTINY)
101 setcolor(ar.rcoef, AVGREFL, AVGREFL, AVGREFL);
102 else
103 copycolor(ar.rcoef, hp->acoef);
104 if (rayorigin(&ar, AMBIENT, hp->rp, ar.rcoef) < 0)
105 return(0);
106 if (ambacc > FTINY) {
107 multcolor(ar.rcoef, hp->acoef);
108 scalecolor(ar.rcoef, 1./AVGREFL);
109 }
110 hlist[0] = hp->rp->rno;
111 hlist[1] = j;
112 hlist[2] = i;
113 multisamp(spt, 2, urand(ilhash(hlist,3)+n));
114 resample:
115 SDsquare2disk(spt, (j+spt[1])/hp->ns, (i+spt[0])/hp->ns);
116 zd = sqrt(1. - spt[0]*spt[0] - spt[1]*spt[1]);
117 for (ii = 3; ii--; )
118 ar.rdir[ii] = spt[0]*hp->ux[ii] +
119 spt[1]*hp->uy[ii] +
120 zd*hp->rp->ron[ii];
121 checknorm(ar.rdir);
122 /* avoid coincident samples */
123 if (!n && ambcollision(hp, i, j, ar.rdir)) {
124 spt[0] = frandom(); spt[1] = frandom();
125 goto resample;
126 }
127 dimlist[ndims++] = AI(hp,i,j) + 90171;
128 rayvalue(&ar); /* evaluate ray */
129 ndims--;
130 if (ar.rt <= FTINY)
131 return(0); /* should never happen */
132 multcolor(ar.rcol, ar.rcoef); /* apply coefficient */
133 if (ar.rt*ap->d < 1.0) /* new/closer distance? */
134 ap->d = 1.0/ar.rt;
135 if (!n) { /* record first vertex & value */
136 if (ar.rt > 10.0*thescene.cusize)
137 ar.rt = 10.0*thescene.cusize;
138 VSUM(ap->p, ar.rorg, ar.rdir, ar.rt);
139 copycolor(ap->v, ar.rcol);
140 } else { /* else update recorded value */
141 hp->acol[RED] -= colval(ap->v,RED);
142 hp->acol[GRN] -= colval(ap->v,GRN);
143 hp->acol[BLU] -= colval(ap->v,BLU);
144 zd = 1.0/(double)(n+1);
145 scalecolor(ar.rcol, zd);
146 zd *= (double)n;
147 scalecolor(ap->v, zd);
148 addcolor(ap->v, ar.rcol);
149 }
150 addcolor(hp->acol, ap->v); /* add to our sum */
151 return(1);
152 }
153
154
155 /* Estimate errors based on ambient division differences */
156 static float *
157 getambdiffs(AMBHEMI *hp)
158 {
159 float *earr = (float *)calloc(hp->ns*hp->ns, sizeof(float));
160 float *ep;
161 AMBSAMP *ap;
162 double b, d2;
163 int i, j;
164
165 if (earr == NULL) /* out of memory? */
166 return(NULL);
167 /* compute squared neighbor diffs */
168 for (ap = hp->sa, ep = earr, i = 0; i < hp->ns; i++)
169 for (j = 0; j < hp->ns; j++, ap++, ep++) {
170 b = bright(ap[0].v);
171 if (i) { /* from above */
172 d2 = b - bright(ap[-hp->ns].v);
173 d2 *= d2;
174 ep[0] += d2;
175 ep[-hp->ns] += d2;
176 }
177 if (!j) continue;
178 /* from behind */
179 d2 = b - bright(ap[-1].v);
180 d2 *= d2;
181 ep[0] += d2;
182 ep[-1] += d2;
183 if (!i) continue;
184 /* diagonal */
185 d2 = b - bright(ap[-hp->ns-1].v);
186 d2 *= d2;
187 ep[0] += d2;
188 ep[-hp->ns-1] += d2;
189 }
190 /* correct for number of neighbors */
191 earr[0] *= 8./3.;
192 earr[hp->ns-1] *= 8./3.;
193 earr[(hp->ns-1)*hp->ns] *= 8./3.;
194 earr[(hp->ns-1)*hp->ns + hp->ns-1] *= 8./3.;
195 for (i = 1; i < hp->ns-1; i++) {
196 earr[i*hp->ns] *= 8./5.;
197 earr[i*hp->ns + hp->ns-1] *= 8./5.;
198 }
199 for (j = 1; j < hp->ns-1; j++) {
200 earr[j] *= 8./5.;
201 earr[(hp->ns-1)*hp->ns + j] *= 8./5.;
202 }
203 return(earr);
204 }
205
206
207 /* Perform super-sampling on hemisphere (introduces bias) */
208 static void
209 ambsupersamp(AMBHEMI *hp, int cnt)
210 {
211 float *earr = getambdiffs(hp);
212 double e2rem = 0;
213 AMBSAMP *ap;
214 float *ep;
215 int i, j, n, nss;
216
217 if (earr == NULL) /* just skip calc. if no memory */
218 return;
219 /* accumulate estimated variances */
220 for (ep = earr + hp->ns*hp->ns; ep > earr; )
221 e2rem += *--ep;
222 ep = earr; /* perform super-sampling */
223 for (ap = hp->sa, i = 0; i < hp->ns; i++)
224 for (j = 0; j < hp->ns; j++, ap++) {
225 if (e2rem <= FTINY)
226 goto done; /* nothing left to do */
227 nss = *ep/e2rem*cnt + frandom();
228 for (n = 1; n <= nss && ambsample(hp,i,j,n); n++)
229 --cnt;
230 e2rem -= *ep++; /* update remainder */
231 }
232 done:
233 free(earr);
234 }
235
236
237 static AMBHEMI *
238 samp_hemi( /* sample indirect hemisphere */
239 COLOR rcol,
240 RAY *r,
241 double wt
242 )
243 {
244 AMBHEMI *hp;
245 double d;
246 int n, i, j;
247 /* set number of divisions */
248 if (ambacc <= FTINY &&
249 wt > (d = 0.8*intens(rcol)*r->rweight/(ambdiv*minweight)))
250 wt = d; /* avoid ray termination */
251 n = sqrt(ambdiv * wt) + 0.5;
252 i = 1 + 5*(ambacc > FTINY); /* minimum number of samples */
253 if (n < i)
254 n = i;
255 /* allocate sampling array */
256 hp = (AMBHEMI *)malloc(sizeof(AMBHEMI) + sizeof(AMBSAMP)*(n*n - 1));
257 if (hp == NULL)
258 error(SYSTEM, "out of memory in samp_hemi");
259 hp->rp = r;
260 hp->ns = n;
261 hp->acol[RED] = hp->acol[GRN] = hp->acol[BLU] = 0.0;
262 memset(hp->sa, 0, sizeof(AMBSAMP)*n*n);
263 hp->sampOK = 0;
264 /* assign coefficient */
265 copycolor(hp->acoef, rcol);
266 d = 1.0/(n*n);
267 scalecolor(hp->acoef, d);
268 /* make tangent plane axes */
269 if (!getperpendicular(hp->ux, r->ron, 1))
270 error(CONSISTENCY, "bad ray direction in samp_hemi");
271 VCROSS(hp->uy, r->ron, hp->ux);
272 /* sample divisions */
273 for (i = hp->ns; i--; )
274 for (j = hp->ns; j--; )
275 hp->sampOK += ambsample(hp, i, j, 0);
276 copycolor(rcol, hp->acol);
277 if (!hp->sampOK) { /* utter failure? */
278 free(hp);
279 return(NULL);
280 }
281 if (hp->sampOK < hp->ns*hp->ns) {
282 hp->sampOK *= -1; /* soft failure */
283 return(hp);
284 }
285 n = ambssamp*wt + 0.5;
286 if (n > 8) { /* perform super-sampling? */
287 ambsupersamp(hp, n);
288 copycolor(rcol, hp->acol);
289 }
290 return(hp); /* all is well */
291 }
292
293
294 /* Return brightness of farthest ambient sample */
295 static double
296 back_ambval(AMBHEMI *hp, const int n1, const int n2, const int n3)
297 {
298 if (hp->sa[n1].d <= hp->sa[n2].d) {
299 if (hp->sa[n1].d <= hp->sa[n3].d)
300 return(colval(hp->sa[n1].v,CIEY));
301 return(colval(hp->sa[n3].v,CIEY));
302 }
303 if (hp->sa[n2].d <= hp->sa[n3].d)
304 return(colval(hp->sa[n2].v,CIEY));
305 return(colval(hp->sa[n3].v,CIEY));
306 }
307
308
309 /* Compute vectors and coefficients for Hessian/gradient calcs */
310 static void
311 comp_fftri(FFTRI *ftp, AMBHEMI *hp, const int n0, const int n1)
312 {
313 double rdot_cp, dot_e, dot_er, rdot_r, rdot_r1, J2;
314 int ii;
315
316 VSUB(ftp->r_i, hp->sa[n0].p, hp->rp->rop);
317 VSUB(ftp->r_i1, hp->sa[n1].p, hp->rp->rop);
318 VSUB(ftp->e_i, hp->sa[n1].p, hp->sa[n0].p);
319 VCROSS(ftp->rcp, ftp->r_i, ftp->r_i1);
320 rdot_cp = 1.0/DOT(ftp->rcp,ftp->rcp);
321 dot_e = DOT(ftp->e_i,ftp->e_i);
322 dot_er = DOT(ftp->e_i, ftp->r_i);
323 rdot_r = 1.0/DOT(ftp->r_i,ftp->r_i);
324 rdot_r1 = 1.0/DOT(ftp->r_i1,ftp->r_i1);
325 ftp->I1 = acos( DOT(ftp->r_i, ftp->r_i1) * sqrt(rdot_r*rdot_r1) ) *
326 sqrt( rdot_cp );
327 ftp->I2 = ( DOT(ftp->e_i, ftp->r_i1)*rdot_r1 - dot_er*rdot_r +
328 dot_e*ftp->I1 )*0.5*rdot_cp;
329 J2 = ( 0.5*(rdot_r - rdot_r1) - dot_er*ftp->I2 ) / dot_e;
330 for (ii = 3; ii--; )
331 ftp->rI2_eJ2[ii] = ftp->I2*ftp->r_i[ii] + J2*ftp->e_i[ii];
332 }
333
334
335 /* Compose 3x3 matrix from two vectors */
336 static void
337 compose_matrix(FVECT mat[3], FVECT va, FVECT vb)
338 {
339 mat[0][0] = 2.0*va[0]*vb[0];
340 mat[1][1] = 2.0*va[1]*vb[1];
341 mat[2][2] = 2.0*va[2]*vb[2];
342 mat[0][1] = mat[1][0] = va[0]*vb[1] + va[1]*vb[0];
343 mat[0][2] = mat[2][0] = va[0]*vb[2] + va[2]*vb[0];
344 mat[1][2] = mat[2][1] = va[1]*vb[2] + va[2]*vb[1];
345 }
346
347
348 /* Compute partial 3x3 Hessian matrix for edge */
349 static void
350 comp_hessian(FVECT hess[3], FFTRI *ftp, FVECT nrm)
351 {
352 FVECT ncp;
353 FVECT m1[3], m2[3], m3[3], m4[3];
354 double d1, d2, d3, d4;
355 double I3, J3, K3;
356 int i, j;
357 /* compute intermediate coefficients */
358 d1 = 1.0/DOT(ftp->r_i,ftp->r_i);
359 d2 = 1.0/DOT(ftp->r_i1,ftp->r_i1);
360 d3 = 1.0/DOT(ftp->e_i,ftp->e_i);
361 d4 = DOT(ftp->e_i, ftp->r_i);
362 I3 = ( DOT(ftp->e_i, ftp->r_i1)*d2*d2 - d4*d1*d1 + 3.0/d3*ftp->I2 )
363 / ( 4.0*DOT(ftp->rcp,ftp->rcp) );
364 J3 = 0.25*d3*(d1*d1 - d2*d2) - d4*d3*I3;
365 K3 = d3*(ftp->I2 - I3/d1 - 2.0*d4*J3);
366 /* intermediate matrices */
367 VCROSS(ncp, nrm, ftp->e_i);
368 compose_matrix(m1, ncp, ftp->rI2_eJ2);
369 compose_matrix(m2, ftp->r_i, ftp->r_i);
370 compose_matrix(m3, ftp->e_i, ftp->e_i);
371 compose_matrix(m4, ftp->r_i, ftp->e_i);
372 d1 = DOT(nrm, ftp->rcp);
373 d2 = -d1*ftp->I2;
374 d1 *= 2.0;
375 for (i = 3; i--; ) /* final matrix sum */
376 for (j = 3; j--; ) {
377 hess[i][j] = m1[i][j] + d1*( I3*m2[i][j] + K3*m3[i][j] +
378 2.0*J3*m4[i][j] );
379 hess[i][j] += d2*(i==j);
380 hess[i][j] *= -1.0/PI;
381 }
382 }
383
384
385 /* Reverse hessian calculation result for edge in other direction */
386 static void
387 rev_hessian(FVECT hess[3])
388 {
389 int i;
390
391 for (i = 3; i--; ) {
392 hess[i][0] = -hess[i][0];
393 hess[i][1] = -hess[i][1];
394 hess[i][2] = -hess[i][2];
395 }
396 }
397
398
399 /* Add to radiometric Hessian from the given triangle */
400 static void
401 add2hessian(FVECT hess[3], FVECT ehess1[3],
402 FVECT ehess2[3], FVECT ehess3[3], double v)
403 {
404 int i, j;
405
406 for (i = 3; i--; )
407 for (j = 3; j--; )
408 hess[i][j] += v*( ehess1[i][j] + ehess2[i][j] + ehess3[i][j] );
409 }
410
411
412 /* Compute partial displacement form factor gradient for edge */
413 static void
414 comp_gradient(FVECT grad, FFTRI *ftp, FVECT nrm)
415 {
416 FVECT ncp;
417 double f1;
418 int i;
419
420 f1 = 2.0*DOT(nrm, ftp->rcp);
421 VCROSS(ncp, nrm, ftp->e_i);
422 for (i = 3; i--; )
423 grad[i] = (0.5/PI)*( ftp->I1*ncp[i] + f1*ftp->rI2_eJ2[i] );
424 }
425
426
427 /* Reverse gradient calculation result for edge in other direction */
428 static void
429 rev_gradient(FVECT grad)
430 {
431 grad[0] = -grad[0];
432 grad[1] = -grad[1];
433 grad[2] = -grad[2];
434 }
435
436
437 /* Add to displacement gradient from the given triangle */
438 static void
439 add2gradient(FVECT grad, FVECT egrad1, FVECT egrad2, FVECT egrad3, double v)
440 {
441 int i;
442
443 for (i = 3; i--; )
444 grad[i] += v*( egrad1[i] + egrad2[i] + egrad3[i] );
445 }
446
447
448 /* Compute anisotropic radii and eigenvector directions */
449 static void
450 eigenvectors(FVECT uv[2], float ra[2], FVECT hessian[3])
451 {
452 double hess2[2][2];
453 FVECT a, b;
454 double evalue[2], slope1, xmag1;
455 int i;
456 /* project Hessian to sample plane */
457 for (i = 3; i--; ) {
458 a[i] = DOT(hessian[i], uv[0]);
459 b[i] = DOT(hessian[i], uv[1]);
460 }
461 hess2[0][0] = DOT(uv[0], a);
462 hess2[0][1] = DOT(uv[0], b);
463 hess2[1][0] = DOT(uv[1], a);
464 hess2[1][1] = DOT(uv[1], b);
465 /* compute eigenvalue(s) */
466 i = quadratic(evalue, 1.0, -hess2[0][0]-hess2[1][1],
467 hess2[0][0]*hess2[1][1]-hess2[0][1]*hess2[1][0]);
468 if (i == 1) /* double-root (circle) */
469 evalue[1] = evalue[0];
470 if (!i || ((evalue[0] = fabs(evalue[0])) <= FTINY*FTINY) |
471 ((evalue[1] = fabs(evalue[1])) <= FTINY*FTINY) ) {
472 ra[0] = ra[1] = maxarad;
473 return;
474 }
475 if (evalue[0] > evalue[1]) {
476 ra[0] = sqrt(sqrt(4.0/evalue[0]));
477 ra[1] = sqrt(sqrt(4.0/evalue[1]));
478 slope1 = evalue[1];
479 } else {
480 ra[0] = sqrt(sqrt(4.0/evalue[1]));
481 ra[1] = sqrt(sqrt(4.0/evalue[0]));
482 slope1 = evalue[0];
483 }
484 /* compute unit eigenvectors */
485 if (fabs(hess2[0][1]) <= FTINY)
486 return; /* uv OK as is */
487 slope1 = (slope1 - hess2[0][0]) / hess2[0][1];
488 xmag1 = sqrt(1.0/(1.0 + slope1*slope1));
489 for (i = 3; i--; ) {
490 b[i] = xmag1*uv[0][i] + slope1*xmag1*uv[1][i];
491 a[i] = slope1*xmag1*uv[0][i] - xmag1*uv[1][i];
492 }
493 VCOPY(uv[0], a);
494 VCOPY(uv[1], b);
495 }
496
497
498 static void
499 ambHessian( /* anisotropic radii & pos. gradient */
500 AMBHEMI *hp,
501 FVECT uv[2], /* returned */
502 float ra[2], /* returned (optional) */
503 float pg[2] /* returned (optional) */
504 )
505 {
506 static char memerrmsg[] = "out of memory in ambHessian()";
507 FVECT (*hessrow)[3] = NULL;
508 FVECT *gradrow = NULL;
509 FVECT hessian[3];
510 FVECT gradient;
511 FFTRI fftr;
512 int i, j;
513 /* be sure to assign unit vectors */
514 VCOPY(uv[0], hp->ux);
515 VCOPY(uv[1], hp->uy);
516 /* clock-wise vertex traversal from sample POV */
517 if (ra != NULL) { /* initialize Hessian row buffer */
518 hessrow = (FVECT (*)[3])malloc(sizeof(FVECT)*3*(hp->ns-1));
519 if (hessrow == NULL)
520 error(SYSTEM, memerrmsg);
521 memset(hessian, 0, sizeof(hessian));
522 } else if (pg == NULL) /* bogus call? */
523 return;
524 if (pg != NULL) { /* initialize form factor row buffer */
525 gradrow = (FVECT *)malloc(sizeof(FVECT)*(hp->ns-1));
526 if (gradrow == NULL)
527 error(SYSTEM, memerrmsg);
528 memset(gradient, 0, sizeof(gradient));
529 }
530 /* compute first row of edges */
531 for (j = 0; j < hp->ns-1; j++) {
532 comp_fftri(&fftr, hp, AI(hp,0,j), AI(hp,0,j+1));
533 if (hessrow != NULL)
534 comp_hessian(hessrow[j], &fftr, hp->rp->ron);
535 if (gradrow != NULL)
536 comp_gradient(gradrow[j], &fftr, hp->rp->ron);
537 }
538 /* sum each row of triangles */
539 for (i = 0; i < hp->ns-1; i++) {
540 FVECT hesscol[3]; /* compute first vertical edge */
541 FVECT gradcol;
542 comp_fftri(&fftr, hp, AI(hp,i,0), AI(hp,i+1,0));
543 if (hessrow != NULL)
544 comp_hessian(hesscol, &fftr, hp->rp->ron);
545 if (gradrow != NULL)
546 comp_gradient(gradcol, &fftr, hp->rp->ron);
547 for (j = 0; j < hp->ns-1; j++) {
548 FVECT hessdia[3]; /* compute triangle contributions */
549 FVECT graddia;
550 double backg;
551 backg = back_ambval(hp, AI(hp,i,j),
552 AI(hp,i,j+1), AI(hp,i+1,j));
553 /* diagonal (inner) edge */
554 comp_fftri(&fftr, hp, AI(hp,i,j+1), AI(hp,i+1,j));
555 if (hessrow != NULL) {
556 comp_hessian(hessdia, &fftr, hp->rp->ron);
557 rev_hessian(hesscol);
558 add2hessian(hessian, hessrow[j], hessdia, hesscol, backg);
559 }
560 if (gradrow != NULL) {
561 comp_gradient(graddia, &fftr, hp->rp->ron);
562 rev_gradient(gradcol);
563 add2gradient(gradient, gradrow[j], graddia, gradcol, backg);
564 }
565 /* initialize edge in next row */
566 comp_fftri(&fftr, hp, AI(hp,i+1,j+1), AI(hp,i+1,j));
567 if (hessrow != NULL)
568 comp_hessian(hessrow[j], &fftr, hp->rp->ron);
569 if (gradrow != NULL)
570 comp_gradient(gradrow[j], &fftr, hp->rp->ron);
571 /* new column edge & paired triangle */
572 backg = back_ambval(hp, AI(hp,i+1,j+1),
573 AI(hp,i+1,j), AI(hp,i,j+1));
574 comp_fftri(&fftr, hp, AI(hp,i,j+1), AI(hp,i+1,j+1));
575 if (hessrow != NULL) {
576 comp_hessian(hesscol, &fftr, hp->rp->ron);
577 rev_hessian(hessdia);
578 add2hessian(hessian, hessrow[j], hessdia, hesscol, backg);
579 if (i < hp->ns-2)
580 rev_hessian(hessrow[j]);
581 }
582 if (gradrow != NULL) {
583 comp_gradient(gradcol, &fftr, hp->rp->ron);
584 rev_gradient(graddia);
585 add2gradient(gradient, gradrow[j], graddia, gradcol, backg);
586 if (i < hp->ns-2)
587 rev_gradient(gradrow[j]);
588 }
589 }
590 }
591 /* release row buffers */
592 if (hessrow != NULL) free(hessrow);
593 if (gradrow != NULL) free(gradrow);
594
595 if (ra != NULL) /* extract eigenvectors & radii */
596 eigenvectors(uv, ra, hessian);
597 if (pg != NULL) { /* tangential position gradient */
598 pg[0] = DOT(gradient, uv[0]);
599 pg[1] = DOT(gradient, uv[1]);
600 }
601 }
602
603
604 /* Compute direction gradient from a hemispherical sampling */
605 static void
606 ambdirgrad(AMBHEMI *hp, FVECT uv[2], float dg[2])
607 {
608 AMBSAMP *ap;
609 double dgsum[2];
610 int n;
611 FVECT vd;
612 double gfact;
613
614 dgsum[0] = dgsum[1] = 0.0; /* sum values times -tan(theta) */
615 for (ap = hp->sa, n = hp->ns*hp->ns; n--; ap++) {
616 /* use vector for azimuth + 90deg */
617 VSUB(vd, ap->p, hp->rp->rop);
618 /* brightness over cosine factor */
619 gfact = colval(ap->v,CIEY) / DOT(hp->rp->ron, vd);
620 /* sine = proj_radius/vd_length */
621 dgsum[0] -= DOT(uv[1], vd) * gfact;
622 dgsum[1] += DOT(uv[0], vd) * gfact;
623 }
624 dg[0] = dgsum[0] / (hp->ns*hp->ns);
625 dg[1] = dgsum[1] / (hp->ns*hp->ns);
626 }
627
628
629 /* Compute potential light leak direction flags for cache value */
630 static uint32
631 ambcorral(AMBHEMI *hp, FVECT uv[2], const double r0, const double r1)
632 {
633 const double max_d = 1.0/(minarad*ambacc + 0.001);
634 const double ang_res = 0.5*PI/hp->ns;
635 const double ang_step = ang_res/((int)(16/PI*ang_res) + 1.01);
636 double avg_d = 0;
637 uint32 flgs = 0;
638 FVECT vec;
639 double u, v;
640 double ang, a1;
641 int i, j;
642 /* don't bother for a few samples */
643 if (hp->ns < 8)
644 return(0);
645 /* check distances overhead */
646 for (i = hp->ns*3/4; i-- > hp->ns>>2; )
647 for (j = hp->ns*3/4; j-- > hp->ns>>2; )
648 avg_d += ambsam(hp,i,j).d;
649 avg_d *= 4.0/(hp->ns*hp->ns);
650 if (avg_d*r0 >= 1.0) /* ceiling too low for corral? */
651 return(0);
652 if (avg_d >= max_d) /* insurance */
653 return(0);
654 /* else circle around perimeter */
655 for (i = 0; i < hp->ns; i++)
656 for (j = 0; j < hp->ns; j += !i|(i==hp->ns-1) ? 1 : hp->ns-1) {
657 AMBSAMP *ap = &ambsam(hp,i,j);
658 if ((ap->d <= FTINY) | (ap->d >= max_d))
659 continue; /* too far or too near */
660 VSUB(vec, ap->p, hp->rp->rop);
661 u = DOT(vec, uv[0]);
662 v = DOT(vec, uv[1]);
663 if ((r0*r0*u*u + r1*r1*v*v) * ap->d*ap->d <= u*u + v*v)
664 continue; /* occluder outside ellipse */
665 ang = atan2a(v, u); /* else set direction flags */
666 for (a1 = ang-ang_res; a1 <= ang+ang_res; a1 += ang_step)
667 flgs |= 1L<<(int)(16/PI*(a1 + 2.*PI*(a1 < 0)));
668 }
669 /* add low-angle incident (< 20deg) */
670 if (fabs(hp->rp->rod) <= 0.342) {
671 u = -DOT(hp->rp->rdir, uv[0]);
672 v = -DOT(hp->rp->rdir, uv[1]);
673 if ((r0*r0*u*u + r1*r1*v*v) > hp->rp->rot*hp->rp->rot) {
674 ang = atan2a(v, u);
675 ang += 2.*PI*(ang < 0);
676 ang *= 16/PI;
677 if ((ang < .5) | (ang >= 31.5))
678 flgs |= 0x80000001;
679 else
680 flgs |= 3L<<(int)(ang-.5);
681 }
682 }
683 return(flgs);
684 }
685
686
687 int
688 doambient( /* compute ambient component */
689 COLOR rcol, /* input/output color */
690 RAY *r,
691 double wt,
692 FVECT uv[2], /* returned (optional) */
693 float ra[2], /* returned (optional) */
694 float pg[2], /* returned (optional) */
695 float dg[2], /* returned (optional) */
696 uint32 *crlp /* returned (optional) */
697 )
698 {
699 AMBHEMI *hp = samp_hemi(rcol, r, wt);
700 FVECT my_uv[2];
701 double d, K;
702 AMBSAMP *ap;
703 int i;
704 /* clear return values */
705 if (uv != NULL)
706 memset(uv, 0, sizeof(FVECT)*2);
707 if (ra != NULL)
708 ra[0] = ra[1] = 0.0;
709 if (pg != NULL)
710 pg[0] = pg[1] = 0.0;
711 if (dg != NULL)
712 dg[0] = dg[1] = 0.0;
713 if (crlp != NULL)
714 *crlp = 0;
715 if (hp == NULL) /* sampling falure? */
716 return(0);
717
718 if ((ra == NULL) & (pg == NULL) & (dg == NULL) ||
719 (hp->sampOK < 0) | (hp->ns < 6)) {
720 free(hp); /* Hessian not requested/possible */
721 return(-1); /* value-only return value */
722 }
723 if ((d = bright(rcol)) > FTINY) { /* normalize Y values */
724 d = 0.99*(hp->ns*hp->ns)/d;
725 K = 0.01;
726 } else { /* or fall back on geometric Hessian */
727 K = 1.0;
728 pg = NULL;
729 dg = NULL;
730 crlp = NULL;
731 }
732 ap = hp->sa; /* relative Y channel from here on... */
733 for (i = hp->ns*hp->ns; i--; ap++)
734 colval(ap->v,CIEY) = bright(ap->v)*d + K;
735
736 if (uv == NULL) /* make sure we have axis pointers */
737 uv = my_uv;
738 /* compute radii & pos. gradient */
739 ambHessian(hp, uv, ra, pg);
740
741 if (dg != NULL) /* compute direction gradient */
742 ambdirgrad(hp, uv, dg);
743
744 if (ra != NULL) { /* scale/clamp radii */
745 if (pg != NULL) {
746 if (ra[0]*(d = fabs(pg[0])) > 1.0)
747 ra[0] = 1.0/d;
748 if (ra[1]*(d = fabs(pg[1])) > 1.0)
749 ra[1] = 1.0/d;
750 if (ra[0] > ra[1])
751 ra[0] = ra[1];
752 }
753 if (ra[0] < minarad) {
754 ra[0] = minarad;
755 if (ra[1] < minarad)
756 ra[1] = minarad;
757 }
758 ra[0] *= d = 1.0/sqrt(wt);
759 if ((ra[1] *= d) > 2.0*ra[0])
760 ra[1] = 2.0*ra[0];
761 if (ra[1] > maxarad) {
762 ra[1] = maxarad;
763 if (ra[0] > maxarad)
764 ra[0] = maxarad;
765 }
766 /* flag encroached directions */
767 if (crlp != NULL)
768 *crlp = ambcorral(hp, uv, ra[0]*ambacc, ra[1]*ambacc);
769 if (pg != NULL) { /* cap gradient if necessary */
770 d = pg[0]*pg[0]*ra[0]*ra[0] + pg[1]*pg[1]*ra[1]*ra[1];
771 if (d > 1.0) {
772 d = 1.0/sqrt(d);
773 pg[0] *= d;
774 pg[1] *= d;
775 }
776 }
777 }
778 free(hp); /* clean up and return */
779 return(1);
780 }
781
782
783 #else /* ! NEWAMB */
784
785
786 void
787 inithemi( /* initialize sampling hemisphere */
788 AMBHEMI *hp,
789 COLOR ac,
790 RAY *r,
791 double wt
792 )
793 {
794 double d;
795 int i;
796 /* set number of divisions */
797 if (ambacc <= FTINY &&
798 wt > (d = 0.8*intens(ac)*r->rweight/(ambdiv*minweight)))
799 wt = d; /* avoid ray termination */
800 hp->nt = sqrt(ambdiv * wt / PI) + 0.5;
801 i = ambacc > FTINY ? 3 : 1; /* minimum number of samples */
802 if (hp->nt < i)
803 hp->nt = i;
804 hp->np = PI * hp->nt + 0.5;
805 /* set number of super-samples */
806 hp->ns = ambssamp * wt + 0.5;
807 /* assign coefficient */
808 copycolor(hp->acoef, ac);
809 d = 1.0/(hp->nt*hp->np);
810 scalecolor(hp->acoef, d);
811 /* make axes */
812 VCOPY(hp->uz, r->ron);
813 hp->uy[0] = hp->uy[1] = hp->uy[2] = 0.0;
814 for (i = 0; i < 3; i++)
815 if (hp->uz[i] < 0.6 && hp->uz[i] > -0.6)
816 break;
817 if (i >= 3)
818 error(CONSISTENCY, "bad ray direction in inithemi");
819 hp->uy[i] = 1.0;
820 fcross(hp->ux, hp->uy, hp->uz);
821 normalize(hp->ux);
822 fcross(hp->uy, hp->uz, hp->ux);
823 }
824
825
826 int
827 divsample( /* sample a division */
828 AMBSAMP *dp,
829 AMBHEMI *h,
830 RAY *r
831 )
832 {
833 RAY ar;
834 int hlist[3];
835 double spt[2];
836 double xd, yd, zd;
837 double b2;
838 double phi;
839 int i;
840 /* ambient coefficient for weight */
841 if (ambacc > FTINY)
842 setcolor(ar.rcoef, AVGREFL, AVGREFL, AVGREFL);
843 else
844 copycolor(ar.rcoef, h->acoef);
845 if (rayorigin(&ar, AMBIENT, r, ar.rcoef) < 0)
846 return(-1);
847 if (ambacc > FTINY) {
848 multcolor(ar.rcoef, h->acoef);
849 scalecolor(ar.rcoef, 1./AVGREFL);
850 }
851 hlist[0] = r->rno;
852 hlist[1] = dp->t;
853 hlist[2] = dp->p;
854 multisamp(spt, 2, urand(ilhash(hlist,3)+dp->n));
855 zd = sqrt((dp->t + spt[0])/h->nt);
856 phi = 2.0*PI * (dp->p + spt[1])/h->np;
857 xd = tcos(phi) * zd;
858 yd = tsin(phi) * zd;
859 zd = sqrt(1.0 - zd*zd);
860 for (i = 0; i < 3; i++)
861 ar.rdir[i] = xd*h->ux[i] +
862 yd*h->uy[i] +
863 zd*h->uz[i];
864 checknorm(ar.rdir);
865 dimlist[ndims++] = dp->t*h->np + dp->p + 90171;
866 rayvalue(&ar);
867 ndims--;
868 multcolor(ar.rcol, ar.rcoef); /* apply coefficient */
869 addcolor(dp->v, ar.rcol);
870 /* use rt to improve gradient calc */
871 if (ar.rt > FTINY && ar.rt < FHUGE)
872 dp->r += 1.0/ar.rt;
873 /* (re)initialize error */
874 if (dp->n++) {
875 b2 = bright(dp->v)/dp->n - bright(ar.rcol);
876 b2 = b2*b2 + dp->k*((dp->n-1)*(dp->n-1));
877 dp->k = b2/(dp->n*dp->n);
878 } else
879 dp->k = 0.0;
880 return(0);
881 }
882
883
884 static int
885 ambcmp( /* decreasing order */
886 const void *p1,
887 const void *p2
888 )
889 {
890 const AMBSAMP *d1 = (const AMBSAMP *)p1;
891 const AMBSAMP *d2 = (const AMBSAMP *)p2;
892
893 if (d1->k < d2->k)
894 return(1);
895 if (d1->k > d2->k)
896 return(-1);
897 return(0);
898 }
899
900
901 static int
902 ambnorm( /* standard order */
903 const void *p1,
904 const void *p2
905 )
906 {
907 const AMBSAMP *d1 = (const AMBSAMP *)p1;
908 const AMBSAMP *d2 = (const AMBSAMP *)p2;
909 int c;
910
911 if ( (c = d1->t - d2->t) )
912 return(c);
913 return(d1->p - d2->p);
914 }
915
916
917 double
918 doambient( /* compute ambient component */
919 COLOR rcol,
920 RAY *r,
921 double wt,
922 FVECT pg,
923 FVECT dg
924 )
925 {
926 double b, d=0;
927 AMBHEMI hemi;
928 AMBSAMP *div;
929 AMBSAMP dnew;
930 double acol[3];
931 AMBSAMP *dp;
932 double arad;
933 int divcnt;
934 int i, j;
935 /* initialize hemisphere */
936 inithemi(&hemi, rcol, r, wt);
937 divcnt = hemi.nt * hemi.np;
938 /* initialize */
939 if (pg != NULL)
940 pg[0] = pg[1] = pg[2] = 0.0;
941 if (dg != NULL)
942 dg[0] = dg[1] = dg[2] = 0.0;
943 setcolor(rcol, 0.0, 0.0, 0.0);
944 if (divcnt == 0)
945 return(0.0);
946 /* allocate super-samples */
947 if (hemi.ns > 0 || pg != NULL || dg != NULL) {
948 div = (AMBSAMP *)malloc(divcnt*sizeof(AMBSAMP));
949 if (div == NULL)
950 error(SYSTEM, "out of memory in doambient");
951 } else
952 div = NULL;
953 /* sample the divisions */
954 arad = 0.0;
955 acol[0] = acol[1] = acol[2] = 0.0;
956 if ((dp = div) == NULL)
957 dp = &dnew;
958 divcnt = 0;
959 for (i = 0; i < hemi.nt; i++)
960 for (j = 0; j < hemi.np; j++) {
961 dp->t = i; dp->p = j;
962 setcolor(dp->v, 0.0, 0.0, 0.0);
963 dp->r = 0.0;
964 dp->n = 0;
965 if (divsample(dp, &hemi, r) < 0) {
966 if (div != NULL)
967 dp++;
968 continue;
969 }
970 arad += dp->r;
971 divcnt++;
972 if (div != NULL)
973 dp++;
974 else
975 addcolor(acol, dp->v);
976 }
977 if (!divcnt) {
978 if (div != NULL)
979 free((void *)div);
980 return(0.0); /* no samples taken */
981 }
982 if (divcnt < hemi.nt*hemi.np) {
983 pg = dg = NULL; /* incomplete sampling */
984 hemi.ns = 0;
985 } else if (arad > FTINY && divcnt/arad < minarad) {
986 hemi.ns = 0; /* close enough */
987 } else if (hemi.ns > 0) { /* else perform super-sampling? */
988 comperrs(div, &hemi); /* compute errors */
989 qsort(div, divcnt, sizeof(AMBSAMP), ambcmp); /* sort divs */
990 /* super-sample */
991 for (i = hemi.ns; i > 0; i--) {
992 dnew = *div;
993 if (divsample(&dnew, &hemi, r) < 0) {
994 dp++;
995 continue;
996 }
997 dp = div; /* reinsert */
998 j = divcnt < i ? divcnt : i;
999 while (--j > 0 && dnew.k < dp[1].k) {
1000 *dp = *(dp+1);
1001 dp++;
1002 }
1003 *dp = dnew;
1004 }
1005 if (pg != NULL || dg != NULL) /* restore order */
1006 qsort(div, divcnt, sizeof(AMBSAMP), ambnorm);
1007 }
1008 /* compute returned values */
1009 if (div != NULL) {
1010 arad = 0.0; /* note: divcnt may be < nt*np */
1011 for (i = hemi.nt*hemi.np, dp = div; i-- > 0; dp++) {
1012 arad += dp->r;
1013 if (dp->n > 1) {
1014 b = 1.0/dp->n;
1015 scalecolor(dp->v, b);
1016 dp->r *= b;
1017 dp->n = 1;
1018 }
1019 addcolor(acol, dp->v);
1020 }
1021 b = bright(acol);
1022 if (b > FTINY) {
1023 b = 1.0/b; /* compute & normalize gradient(s) */
1024 if (pg != NULL) {
1025 posgradient(pg, div, &hemi);
1026 for (i = 0; i < 3; i++)
1027 pg[i] *= b;
1028 }
1029 if (dg != NULL) {
1030 dirgradient(dg, div, &hemi);
1031 for (i = 0; i < 3; i++)
1032 dg[i] *= b;
1033 }
1034 }
1035 free((void *)div);
1036 }
1037 copycolor(rcol, acol);
1038 if (arad <= FTINY)
1039 arad = maxarad;
1040 else
1041 arad = (divcnt+hemi.ns)/arad;
1042 if (pg != NULL) { /* reduce radius if gradient large */
1043 d = DOT(pg,pg);
1044 if (d*arad*arad > 1.0)
1045 arad = 1.0/sqrt(d);
1046 }
1047 if (arad < minarad) {
1048 arad = minarad;
1049 if (pg != NULL && d*arad*arad > 1.0) { /* cap gradient */
1050 d = 1.0/arad/sqrt(d);
1051 for (i = 0; i < 3; i++)
1052 pg[i] *= d;
1053 }
1054 }
1055 if ((arad /= sqrt(wt)) > maxarad)
1056 arad = maxarad;
1057 return(arad);
1058 }
1059
1060
1061 void
1062 comperrs( /* compute initial error estimates */
1063 AMBSAMP *da, /* assumes standard ordering */
1064 AMBHEMI *hp
1065 )
1066 {
1067 double b, b2;
1068 int i, j;
1069 AMBSAMP *dp;
1070 /* sum differences from neighbors */
1071 dp = da;
1072 for (i = 0; i < hp->nt; i++)
1073 for (j = 0; j < hp->np; j++) {
1074 #ifdef DEBUG
1075 if (dp->t != i || dp->p != j)
1076 error(CONSISTENCY,
1077 "division order in comperrs");
1078 #endif
1079 b = bright(dp[0].v);
1080 if (i > 0) { /* from above */
1081 b2 = bright(dp[-hp->np].v) - b;
1082 b2 *= b2 * 0.25;
1083 dp[0].k += b2;
1084 dp[-hp->np].k += b2;
1085 }
1086 if (j > 0) { /* from behind */
1087 b2 = bright(dp[-1].v) - b;
1088 b2 *= b2 * 0.25;
1089 dp[0].k += b2;
1090 dp[-1].k += b2;
1091 } else { /* around */
1092 b2 = bright(dp[hp->np-1].v) - b;
1093 b2 *= b2 * 0.25;
1094 dp[0].k += b2;
1095 dp[hp->np-1].k += b2;
1096 }
1097 dp++;
1098 }
1099 /* divide by number of neighbors */
1100 dp = da;
1101 for (j = 0; j < hp->np; j++) /* top row */
1102 (dp++)->k *= 1.0/3.0;
1103 if (hp->nt < 2)
1104 return;
1105 for (i = 1; i < hp->nt-1; i++) /* central region */
1106 for (j = 0; j < hp->np; j++)
1107 (dp++)->k *= 0.25;
1108 for (j = 0; j < hp->np; j++) /* bottom row */
1109 (dp++)->k *= 1.0/3.0;
1110 }
1111
1112
1113 void
1114 posgradient( /* compute position gradient */
1115 FVECT gv,
1116 AMBSAMP *da, /* assumes standard ordering */
1117 AMBHEMI *hp
1118 )
1119 {
1120 int i, j;
1121 double nextsine, lastsine, b, d;
1122 double mag0, mag1;
1123 double phi, cosp, sinp, xd, yd;
1124 AMBSAMP *dp;
1125
1126 xd = yd = 0.0;
1127 for (j = 0; j < hp->np; j++) {
1128 dp = da + j;
1129 mag0 = mag1 = 0.0;
1130 lastsine = 0.0;
1131 for (i = 0; i < hp->nt; i++) {
1132 #ifdef DEBUG
1133 if (dp->t != i || dp->p != j)
1134 error(CONSISTENCY,
1135 "division order in posgradient");
1136 #endif
1137 b = bright(dp->v);
1138 if (i > 0) {
1139 d = dp[-hp->np].r;
1140 if (dp[0].r > d) d = dp[0].r;
1141 /* sin(t)*cos(t)^2 */
1142 d *= lastsine * (1.0 - (double)i/hp->nt);
1143 mag0 += d*(b - bright(dp[-hp->np].v));
1144 }
1145 nextsine = sqrt((double)(i+1)/hp->nt);
1146 if (j > 0) {
1147 d = dp[-1].r;
1148 if (dp[0].r > d) d = dp[0].r;
1149 mag1 += d * (nextsine - lastsine) *
1150 (b - bright(dp[-1].v));
1151 } else {
1152 d = dp[hp->np-1].r;
1153 if (dp[0].r > d) d = dp[0].r;
1154 mag1 += d * (nextsine - lastsine) *
1155 (b - bright(dp[hp->np-1].v));
1156 }
1157 dp += hp->np;
1158 lastsine = nextsine;
1159 }
1160 mag0 *= 2.0*PI / hp->np;
1161 phi = 2.0*PI * (double)j/hp->np;
1162 cosp = tcos(phi); sinp = tsin(phi);
1163 xd += mag0*cosp - mag1*sinp;
1164 yd += mag0*sinp + mag1*cosp;
1165 }
1166 for (i = 0; i < 3; i++)
1167 gv[i] = (xd*hp->ux[i] + yd*hp->uy[i])*(hp->nt*hp->np)/PI;
1168 }
1169
1170
1171 void
1172 dirgradient( /* compute direction gradient */
1173 FVECT gv,
1174 AMBSAMP *da, /* assumes standard ordering */
1175 AMBHEMI *hp
1176 )
1177 {
1178 int i, j;
1179 double mag;
1180 double phi, xd, yd;
1181 AMBSAMP *dp;
1182
1183 xd = yd = 0.0;
1184 for (j = 0; j < hp->np; j++) {
1185 dp = da + j;
1186 mag = 0.0;
1187 for (i = 0; i < hp->nt; i++) {
1188 #ifdef DEBUG
1189 if (dp->t != i || dp->p != j)
1190 error(CONSISTENCY,
1191 "division order in dirgradient");
1192 #endif
1193 /* tan(t) */
1194 mag += bright(dp->v)/sqrt(hp->nt/(i+.5) - 1.0);
1195 dp += hp->np;
1196 }
1197 phi = 2.0*PI * (j+.5)/hp->np + PI/2.0;
1198 xd += mag * tcos(phi);
1199 yd += mag * tsin(phi);
1200 }
1201 for (i = 0; i < 3; i++)
1202 gv[i] = xd*hp->ux[i] + yd*hp->uy[i];
1203 }
1204
1205 #endif /* ! NEWAMB */
