--- ray/src/rt/ambcomp.c 2016/03/16 15:43:04 2.72 +++ ray/src/rt/ambcomp.c 2016/10/14 00:54:21 2.73 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: ambcomp.c,v 2.72 2016/03/16 15:43:04 greg Exp $"; +static const char RCSid[] = "$Id: ambcomp.c,v 2.73 2016/10/14 00:54:21 greg Exp $"; #endif /* * Routines to compute "ambient" values using Monte Carlo @@ -51,6 +51,39 @@ typedef struct { static int +ambcollision( /* proposed direciton collides? */ + AMBHEMI *hp, + int i, + int j, + FVECT dv +) +{ + const double cos_thresh = 0.9999995; /* about 3.44 arcminutes */ + int ii, jj; + + for (ii = i-1; ii <= i+1; ii++) { + if (ii < 0) continue; + if (ii >= hp->ns) break; + for (jj = j-1; jj <= j+1; jj++) { + AMBSAMP *ap; + FVECT avec; + double dprod; + if (jj < 0) continue; + if (jj >= hp->ns) break; + if ((ii==i) & (jj==j)) continue; + ap = &ambsam(hp,ii,jj); + if (ap->d <= .5/FHUGE) continue; + VSUB(avec, ap->p, hp->rp->rop); + dprod = DOT(avec, dv); + if (dprod >= cos_thresh*VLEN(avec)) + return(1); /* collision */ + } + } + return(0); +} + + +static int ambsample( /* initial ambient division sample */ AMBHEMI *hp, int i, @@ -78,14 +111,7 @@ ambsample( /* initial ambient division sample */ hlist[1] = j; hlist[2] = i; multisamp(spt, 2, urand(ilhash(hlist,3)+n)); - /* avoid coincident samples */ - if (!n && (0 < i) & (i < hp->ns-1) && - (0 < j) & (j < hp->ns-1)) { - if ((spt[0] < 0.1) | (spt[0] >= 0.9)) - spt[0] = 0.1 + 0.8*frandom(); - if ((spt[1] < 0.1) | (spt[1] >= 0.9)) - spt[1] = 0.1 + 0.8*frandom(); - } +resample: SDsquare2disk(spt, (j+spt[1])/hp->ns, (i+spt[0])/hp->ns); zd = sqrt(1. - spt[0]*spt[0] - spt[1]*spt[1]); for (ii = 3; ii--; ) @@ -93,6 +119,11 @@ ambsample( /* initial ambient division sample */ spt[1]*hp->uy[ii] + zd*hp->rp->ron[ii]; checknorm(ar.rdir); + /* avoid coincident samples */ + if (!n && ambcollision(hp, i, j, ar.rdir)) { + spt[0] = frandom(); spt[1] = frandom(); + goto resample; + } dimlist[ndims++] = AI(hp,i,j) + 90171; rayvalue(&ar); /* evaluate ray */ ndims--;
