root/radiance/ray/src/rt/ambcomp.c
Revision: 1.11
Committed: Tue Aug 13 12:16:41 1991 UTC (34 years ago) by greg
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Routines to compute "ambient" values using Monte Carlo
9 */
10
11 #include "ray.h"
12
13 #include "ambient.h"
14
15 #include "random.h"
16
17 typedef struct {
18 short t, p; /* theta, phi indices */
19 COLOR v; /* value sum */
20 float r; /* 1/distance sum */
21 float k; /* variance for this division */
22 int n; /* number of subsamples */
23 } AMBSAMP; /* ambient sample division */
24
25 typedef struct {
26 FVECT ux, uy, uz; /* x, y and z axis directions */
27 short nt, np; /* number of theta and phi directions */
28 } AMBHEMI; /* ambient sample hemisphere */
29
30 extern double sin(), cos(), sqrt();
31
32
33 static int
34 ambcmp(d1, d2) /* decreasing order */
35 AMBSAMP *d1, *d2;
36 {
37 if (d1->k < d2->k)
38 return(1);
39 if (d1->k > d2->k)
40 return(-1);
41 return(0);
42 }
43
44
45 static int
46 ambnorm(d1, d2) /* standard order */
47 AMBSAMP *d1, *d2;
48 {
49 register int c;
50
51 if (c = d1->t - d2->t)
52 return(c);
53 return(d1->p - d2->p);
54 }
55
56
57 divsample(dp, h, r) /* sample a division */
58 register AMBSAMP *dp;
59 AMBHEMI *h;
60 RAY *r;
61 {
62 RAY ar;
63 int hlist[3];
64 double spt[2];
65 double xd, yd, zd;
66 double b2;
67 double phi;
68 register int i;
69
70 if (rayorigin(&ar, r, AMBIENT, 0.5) < 0)
71 return(-1);
72 hlist[0] = r->rno;
73 hlist[1] = dp->t;
74 hlist[2] = dp->p;
75 peano(spt, 2, urand(ilhash(hlist,3)+dp->n), .01);
76 zd = sqrt((dp->t + spt[0])/h->nt);
77 phi = 2.0*PI * (dp->p + spt[1])/h->np;
78 xd = cos(phi) * zd;
79 yd = sin(phi) * zd;
80 zd = sqrt(1.0 - zd*zd);
81 for (i = 0; i < 3; i++)
82 ar.rdir[i] = xd*h->ux[i] +
83 yd*h->uy[i] +
84 zd*h->uz[i];
85 dimlist[ndims++] = dp->t*h->np + dp->p + 90171;
86 rayvalue(&ar);
87 ndims--;
88 addcolor(dp->v, ar.rcol);
89 if (ar.rt > FTINY && ar.rt < FHUGE)
90 dp->r += 1.0/ar.rt;
91 /* (re)initialize error */
92 if (dp->n++) {
93 b2 = bright(dp->v)/dp->n - bright(ar.rcol);
94 b2 = b2*b2 + dp->k*((dp->n-1)*(dp->n-1));
95 dp->k = b2/(dp->n*dp->n);
96 } else
97 dp->k = 0.0;
98 return(0);
99 }
100
101
102 double
103 doambient(acol, r, pg, dg) /* compute ambient component */
104 COLOR acol;
105 RAY *r;
106 FVECT pg, dg;
107 {
108 double b, d;
109 AMBHEMI hemi;
110 AMBSAMP *div;
111 AMBSAMP dnew;
112 register AMBSAMP *dp;
113 double arad;
114 int ndivs, ns;
115 register int i, j;
116 /* initialize color */
117 setcolor(acol, 0.0, 0.0, 0.0);
118 /* initialize hemisphere */
119 inithemi(&hemi, r);
120 ndivs = hemi.nt * hemi.np;
121 if (ndivs == 0)
122 return(0.0);
123 /* set number of super-samples */
124 ns = ambssamp * r->rweight + 0.5;
125 if (ns > 0 || pg != NULL || dg != NULL) {
126 div = (AMBSAMP *)malloc(ndivs*sizeof(AMBSAMP));
127 if (div == NULL)
128 error(SYSTEM, "out of memory in doambient");
129 } else
130 div = NULL;
131 /* sample the divisions */
132 arad = 0.0;
133 if ((dp = div) == NULL)
134 dp = &dnew;
135 for (i = 0; i < hemi.nt; i++)
136 for (j = 0; j < hemi.np; j++) {
137 dp->t = i; dp->p = j;
138 setcolor(dp->v, 0.0, 0.0, 0.0);
139 dp->r = 0.0;
140 dp->n = 0;
141 if (divsample(dp, &hemi, r) < 0)
142 goto oopsy;
143 if (div != NULL)
144 dp++;
145 else {
146 addcolor(acol, dp->v);
147 arad += dp->r;
148 }
149 }
150 if (ns > 0) { /* perform super-sampling */
151 comperrs(div, &hemi); /* compute errors */
152 qsort(div, ndivs, sizeof(AMBSAMP), ambcmp); /* sort divs */
153 /* super-sample */
154 for (i = ns; i > 0; i--) {
155 copystruct(&dnew, div);
156 if (divsample(&dnew, &hemi, r) < 0)
157 goto oopsy;
158 /* reinsert */
159 dp = div;
160 j = ndivs < i ? ndivs : i;
161 while (--j > 0 && dnew.k < dp[1].k) {
162 copystruct(dp, dp+1);
163 dp++;
164 }
165 copystruct(dp, &dnew);
166 }
167 if (pg != NULL || dg != NULL) /* restore order */
168 qsort(div, ndivs, sizeof(AMBSAMP), ambnorm);
169 }
170 /* compute returned values */
171 if (div != NULL) {
172 for (i = ndivs, dp = div; i-- > 0; dp++) {
173 arad += dp->r;
174 if (dp->n > 1) {
175 b = 1.0/dp->n;
176 scalecolor(dp->v, b);
177 dp->r *= b;
178 dp->n = 1;
179 }
180 addcolor(acol, dp->v);
181 }
182 b = bright(acol);
183 if (b > FTINY) {
184 b = ndivs/b;
185 if (pg != NULL) {
186 posgradient(pg, div, &hemi);
187 for (i = 0; i < 3; i++)
188 pg[i] *= b;
189 }
190 if (dg != NULL) {
191 dirgradient(dg, div, &hemi);
192 for (i = 0; i < 3; i++)
193 dg[i] *= b;
194 }
195 } else {
196 if (pg != NULL)
197 for (i = 0; i < 3; i++)
198 pg[i] = 0.0;
199 if (dg != NULL)
200 for (i = 0; i < 3; i++)
201 dg[i] = 0.0;
202 }
203 free((char *)div);
204 }
205 b = 1.0/ndivs;
206 scalecolor(acol, b);
207 if (arad <= FTINY)
208 arad = FHUGE;
209 else
210 arad = (ndivs+ns)/arad;
211 if (arad > maxarad)
212 arad = maxarad;
213 else if (arad < minarad)
214 arad = minarad;
215 arad /= sqrt(r->rweight);
216 if (pg != NULL) { /* clip pos. gradient if too large */
217 d = 4.0*DOT(pg,pg)*arad*arad;
218 if (d > 1.0) {
219 d = 1.0/sqrt(d);
220 for (i = 0; i < 3; i++)
221 pg[i] *= d;
222 }
223 }
224 return(arad);
225 oopsy:
226 if (div != NULL)
227 free((char *)div);
228 return(0.0);
229 }
230
231
232 inithemi(hp, r) /* initialize sampling hemisphere */
233 register AMBHEMI *hp;
234 RAY *r;
235 {
236 register int i;
237 /* set number of divisions */
238 hp->nt = sqrt(ambdiv * r->rweight / PI) + 0.5;
239 hp->np = PI * hp->nt;
240 /* make axes */
241 VCOPY(hp->uz, r->ron);
242 hp->uy[0] = hp->uy[1] = hp->uy[2] = 0.0;
243 for (i = 0; i < 3; i++)
244 if (hp->uz[i] < 0.6 && hp->uz[i] > -0.6)
245 break;
246 if (i >= 3)
247 error(CONSISTENCY, "bad ray direction in inithemi");
248 hp->uy[i] = 1.0;
249 fcross(hp->ux, hp->uy, hp->uz);
250 normalize(hp->ux);
251 fcross(hp->uy, hp->uz, hp->ux);
252 }
253
254
255 comperrs(da, hp) /* compute initial error estimates */
256 AMBSAMP *da; /* assumes standard ordering */
257 register AMBHEMI *hp;
258 {
259 double b, b2;
260 int i, j;
261 register AMBSAMP *dp;
262 /* sum differences from neighbors */
263 dp = da;
264 for (i = 0; i < hp->nt; i++)
265 for (j = 0; j < hp->np; j++) {
266 #ifdef DEBUG
267 if (dp->t != i || dp->p != j)
268 error(CONSISTENCY,
269 "division order in comperrs");
270 #endif
271 b = bright(dp[0].v);
272 if (i > 0) { /* from above */
273 b2 = bright(dp[-hp->np].v) - b;
274 b2 *= b2 * 0.25;
275 dp[0].k += b2;
276 dp[-hp->np].k += b2;
277 }
278 if (j > 0) { /* from behind */
279 b2 = bright(dp[-1].v) - b;
280 b2 *= b2 * 0.25;
281 dp[0].k += b2;
282 dp[-1].k += b2;
283 } else { /* around */
284 b2 = bright(dp[hp->np-1].v) - b;
285 b2 *= b2 * 0.25;
286 dp[0].k += b2;
287 dp[hp->np-1].k += b2;
288 }
289 dp++;
290 }
291 /* divide by number of neighbors */
292 dp = da;
293 for (j = 0; j < hp->np; j++) /* top row */
294 (dp++)->k *= 1.0/3.0;
295 if (hp->nt < 2)
296 return;
297 for (i = 1; i < hp->nt-1; i++) /* central region */
298 for (j = 0; j < hp->np; j++)
299 (dp++)->k *= 0.25;
300 for (j = 0; j < hp->np; j++) /* bottom row */
301 (dp++)->k *= 1.0/3.0;
302 }
303
304
305 posgradient(gv, da, hp) /* compute position gradient */
306 FVECT gv;
307 AMBSAMP *da; /* assumes standard ordering */
308 AMBHEMI *hp;
309 {
310 register int i, j;
311 double b, d;
312 double mag0, mag1;
313 double phi, cosp, sinp, xd, yd;
314 register AMBSAMP *dp;
315
316 xd = yd = 0.0;
317 for (j = 0; j < hp->np; j++) {
318 dp = da + j;
319 mag0 = mag1 = 0.0;
320 for (i = 0; i < hp->nt; i++) {
321 #ifdef DEBUG
322 if (dp->t != i || dp->p != j)
323 error(CONSISTENCY,
324 "division order in posgradient");
325 #endif
326 b = bright(dp->v);
327 if (i > 0) {
328 d = dp[-hp->np].r;
329 if (dp[0].r > d) d = dp[0].r;
330 d *= 1.0 - sqrt((double)i/hp->nt);
331 mag0 += d*(b - bright(dp[-hp->np].v));
332 }
333 if (j > 0) {
334 d = dp[-1].r;
335 if (dp[0].r > d) d = dp[0].r;
336 mag1 += d*(b - bright(dp[-1].v));
337 } else {
338 d = dp[hp->np-1].r;
339 if (dp[0].r > d) d = dp[0].r;
340 mag1 += d*(b - bright(dp[hp->np-1].v));
341 }
342 dp += hp->np;
343 }
344 if (hp->nt > 1) {
345 mag0 /= (double)hp->np;
346 mag1 /= (double)hp->nt;
347 }
348 phi = 2.0*PI * (double)j/hp->np;
349 cosp = cos(phi); sinp = sin(phi);
350 xd += mag0*cosp - mag1*sinp;
351 yd += mag0*sinp + mag1*cosp;
352 }
353 for (i = 0; i < 3; i++)
354 gv[i] = (xd*hp->ux[i] + yd*hp->uy[i])/PI;
355 }
356
357
358 dirgradient(gv, da, hp) /* compute direction gradient */
359 FVECT gv;
360 AMBSAMP *da; /* assumes standard ordering */
361 AMBHEMI *hp;
362 {
363 register int i, j;
364 double mag;
365 double phi, xd, yd;
366 register AMBSAMP *dp;
367
368 xd = yd = 0.0;
369 for (j = 0; j < hp->np; j++) {
370 dp = da + j;
371 mag = 0.0;
372 for (i = 0; i < hp->nt; i++) {
373 #ifdef DEBUG
374 if (dp->t != i || dp->p != j)
375 error(CONSISTENCY,
376 "division order in dirgradient");
377 #endif
378 mag += sqrt((i+.5)/hp->nt)*bright(dp->v);
379 dp += hp->np;
380 }
381 phi = 2.0*PI * (j+.5)/hp->np + PI/2.0;
382 xd += mag * cos(phi);
383 yd += mag * sin(phi);
384 }
385 for (i = 0; i < 3; i++)
386 gv[i] = (xd*hp->ux[i] + yd*hp->uy[i])*PI/(hp->nt*hp->np);
387 }
