--- ray/src/rt/ambcomp.c 2014/05/01 22:34:25 2.45 +++ ray/src/rt/ambcomp.c 2014/05/09 16:05:09 2.55 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: ambcomp.c,v 2.45 2014/05/01 22:34:25 greg Exp $"; +static const char RCSid[] = "$Id: ambcomp.c,v 2.55 2014/05/09 16:05:09 greg Exp $"; #endif /* * Routines to compute "ambient" values using Monte Carlo @@ -8,6 +8,10 @@ static const char RCSid[] = "$Id: ambcomp.c,v 2.45 201 * for Irradiance Caching" by Schwarzhaupt, Wann Jensen, & Jarosz * from ACM SIGGRAPH Asia 2012 conference proceedings. * + * Added book-keeping optimization to avoid calculations that would + * cancel due to traversal both directions on edges that are adjacent + * to same-valued triangles. This cuts about half of Hessian math. + * * Declarations of external symbols in ambient.h */ @@ -21,8 +25,32 @@ static const char RCSid[] = "$Id: ambcomp.c,v 2.45 201 extern void SDsquare2disk(double ds[2], double seedx, double seedy); + /* vertex direction bit positions */ +#define VDB_xy 0 +#define VDB_y 01 +#define VDB_x 02 +#define VDB_Xy 03 +#define VDB_xY 04 +#define VDB_X 05 +#define VDB_Y 06 +#define VDB_XY 07 + /* get opposite vertex direction bit */ +#define VDB_OPP(f) (~(f) & 07) + /* adjacent triangle vertex flags */ +static const int adjacent_trifl[8] = { + 0, /* forbidden diagonal */ + 1<sa[(i)*(h)->ns + (j)] +#define ambndx(h,i,j) ((i)*(h)->ns + (j)) +#define ambsam(h,i,j) (h)->sa[ambndx(h,i,j)] typedef struct { FVECT r_i, r_i1, e_i, rcp, rI2_eJ2; double I1, I2; + int valid; } FFTRI; /* vectors and coefficients for Hessian calculation */ +/* Get index for adjacent vertex */ +static int +adjacent_verti(AMBHEMI *hp, int i, int j, int dbit) +{ + int i0 = i*hp->ns + j; + + switch (dbit) { + case VDB_y: return(i0 - hp->ns); + case VDB_x: return(i0 - 1); + case VDB_Xy: return(i0 - hp->ns + 1); + case VDB_xY: return(i0 + hp->ns - 1); + case VDB_X: return(i0 + 1); + case VDB_Y: return(i0 + hp->ns); + /* the following should never occur */ + case VDB_xy: return(i0 - hp->ns - 1); + case VDB_XY: return(i0 + hp->ns + 1); + } + return(-1); +} + + +/* Get vertex direction bit for the opposite edge to complete triangle */ +static int +vdb_edge(int db1, int db2) +{ + switch (db1) { + case VDB_x: return(db2==VDB_y ? VDB_Xy : VDB_Y); + case VDB_y: return(db2==VDB_x ? VDB_xY : VDB_X); + case VDB_X: return(db2==VDB_Xy ? VDB_y : VDB_xY); + case VDB_Y: return(db2==VDB_xY ? VDB_x : VDB_Xy); + case VDB_xY: return(db2==VDB_x ? VDB_y : VDB_X); + case VDB_Xy: return(db2==VDB_y ? VDB_x : VDB_Y); + } + error(CONSISTENCY, "forbidden diagonal in vdb_edge()"); + return(-1); +} + + static AMBHEMI * inithemi( /* initialize sampling hemisphere */ COLOR ac, @@ -106,23 +174,23 @@ getambsamp(RAY *arp, AMBHEMI *hp, int i, int j, int n) scalecolor(arp->rcoef, 1./AVGREFL); } hlist[0] = hp->rp->rno; - hlist[1] = i; - hlist[2] = j; + hlist[1] = j; + hlist[2] = i; multisamp(spt, 2, urand(ilhash(hlist,3)+n)); if (!n) { /* avoid border samples for n==0 */ - if ((spt[0] < 0.1) | (spt[0] > 0.9)) + if ((spt[0] < 0.1) | (spt[0] >= 0.9)) spt[0] = 0.1 + 0.8*frandom(); - if ((spt[1] < 0.1) | (spt[1] > 0.9)) + if ((spt[1] < 0.1) | (spt[1] >= 0.9)) spt[1] = 0.1 + 0.8*frandom(); } - SDsquare2disk(spt, (i+spt[0])/hp->ns, (j+spt[1])/hp->ns); + SDsquare2disk(spt, (j+spt[1])/hp->ns, (i+spt[0])/hp->ns); zd = sqrt(1. - spt[0]*spt[0] - spt[1]*spt[1]); for (ii = 3; ii--; ) arp->rdir[ii] = spt[0]*hp->ux[ii] + spt[1]*hp->uy[ii] + zd*hp->rp->ron[ii]; checknorm(arp->rdir); - dimlist[ndims++] = i*hp->ns + j + 90171; + dimlist[ndims++] = ambndx(hp,i,j) + 90171; rayvalue(arp); /* evaluate ray */ ndims--; /* apply coefficient */ multcolor(arp->rcol, arp->rcoef); @@ -140,20 +208,16 @@ ambsample( /* initial ambient division sample */ AMBSAMP *ap = &ambsam(hp,i,j); RAY ar; /* generate hemispherical sample */ - if (!getambsamp(&ar, hp, i, j, 0)) - goto badsample; - /* limit vertex distance */ + if (!getambsamp(&ar, hp, i, j, 0) || ar.rt <= FTINY) { + memset(ap, 0, sizeof(AMBSAMP)); + return(NULL); + } + ap->d = 1.0/ar.rt; /* limit vertex distance */ if (ar.rt > 10.0*thescene.cusize) ar.rt = 10.0*thescene.cusize; - else if (ar.rt <= FTINY) /* should never happen! */ - goto badsample; VSUM(ap->p, ar.rorg, ar.rdir, ar.rt); copycolor(ap->v, ar.rcol); return(ap); -badsample: - setcolor(ap->v, 0., 0., 0.); - VCOPY(ap->p, hp->rp->rop); - return(NULL); } @@ -179,25 +243,31 @@ getambdiffs(AMBHEMI *hp) ep[0] += d2; ep[-hp->ns] += d2; } - if (j) { /* from behind */ - d2 = b - bright(ap[-1].v); - d2 *= d2; - ep[0] += d2; - ep[-1] += d2; - } + if (!j) continue; + /* from behind */ + d2 = b - bright(ap[-1].v); + d2 *= d2; + ep[0] += d2; + ep[-1] += d2; + if (!i) continue; + /* diagonal */ + d2 = b - bright(ap[-hp->ns-1].v); + d2 *= d2; + ep[0] += d2; + ep[-hp->ns-1] += d2; } /* correct for number of neighbors */ - earr[0] *= 2.f; - earr[hp->ns-1] *= 2.f; - earr[(hp->ns-1)*hp->ns] *= 2.f; - earr[(hp->ns-1)*hp->ns + hp->ns-1] *= 2.f; + earr[0] *= 8./3.; + earr[hp->ns-1] *= 8./3.; + earr[(hp->ns-1)*hp->ns] *= 8./3.; + earr[(hp->ns-1)*hp->ns + hp->ns-1] *= 8./3.; for (i = 1; i < hp->ns-1; i++) { - earr[i*hp->ns] *= 4./3.; - earr[i*hp->ns + hp->ns-1] *= 4./3.; + earr[i*hp->ns] *= 8./5.; + earr[i*hp->ns + hp->ns-1] *= 8./5.; } for (j = 1; j < hp->ns-1; j++) { - earr[j] *= 4./3.; - earr[(hp->ns-1)*hp->ns + j] *= 4./3.; + earr[j] *= 8./5.; + earr[(hp->ns-1)*hp->ns + j] *= 8./5.; } return(earr); } @@ -208,23 +278,25 @@ static void ambsupersamp(double acol[3], AMBHEMI *hp, int cnt) { float *earr = getambdiffs(hp); - double e2sum = 0; + double e2rem = 0; AMBSAMP *ap; RAY ar; - COLOR asum; + double asum[3]; float *ep; - int i, j, n; + int i, j, n, nss; if (earr == NULL) /* just skip calc. if no memory */ return; - /* add up estimated variances */ - for (ep = earr + hp->ns*hp->ns; ep-- > earr; ) - e2sum += *ep; + /* accumulate estimated variances */ + for (ep = earr + hp->ns*hp->ns; ep > earr; ) + e2rem += *--ep; ep = earr; /* perform super-sampling */ for (ap = hp->sa, i = 0; i < hp->ns; i++) for (j = 0; j < hp->ns; j++, ap++) { - int nss = *ep/e2sum*cnt + frandom(); - setcolor(asum, 0., 0., 0.); + if (e2rem <= FTINY) + goto done; /* nothing left to do */ + nss = *ep/e2rem*cnt + frandom(); + asum[0] = asum[1] = asum[2] = 0.0; for (n = 1; n <= nss; n++) { if (!getambsamp(&ar, hp, i, j, n)) { nss = n-1; @@ -233,28 +305,107 @@ ambsupersamp(double acol[3], AMBHEMI *hp, int cnt) addcolor(asum, ar.rcol); } if (nss) { /* update returned ambient value */ - const double ssf = 1./(nss + 1); + const double ssf = 1./(nss + 1.); for (n = 3; n--; ) - acol[n] += ssf*colval(asum,n) + + acol[n] += ssf*asum[n] + (ssf - 1.)*colval(ap->v,n); } - e2sum -= *ep++; /* update remainders */ + e2rem -= *ep++; /* update remainders */ cnt -= nss; } +done: free(earr); } +/* Compute vertex flags, indicating farthest in each direction */ +static uby8 * +vertex_flags(AMBHEMI *hp) +{ + uby8 *vflags = (uby8 *)calloc(hp->ns*hp->ns, sizeof(uby8)); + uby8 *vf; + AMBSAMP *ap; + int i, j; + + if (vflags == NULL) + error(SYSTEM, "out of memory in vertex_flags()"); + vf = vflags; + ap = hp->sa; /* compute farthest along first row */ + for (j = 0; j < hp->ns-1; j++, vf++, ap++) + if (ap[0].d <= ap[1].d) + vf[0] |= 1<ns; i++) { + for (j = 0; j < hp->ns-1; j++, vf++, ap++) { + if (ap[0].d <= ap[-hp->ns].d) /* row before */ + vf[0] |= 1<ns] |= 1<ns].d) /* diagonal we care about */ + vf[0] |= 1<ns] |= 1<ns].d) /* final column edge */ + vf[0] |= 1<ns] |= 1<sa[v0].v,CIEY)); + v1 = adjacent_verti(hp, i, j, dbit1); + if (vflags[v0] & 1<v2 */ + return(colval(hp->sa[v1].v,CIEY)); + v2 = adjacent_verti(hp, i, j, dbit2); + if (vflags[v0] & 1<v1 */ + return(colval(hp->sa[v2].v,CIEY)); + /* else check if v1>v2 */ + if (vflags[v1] & 1<sa[v1].v,CIEY)); + return(colval(hp->sa[v2].v,CIEY)); +} + + /* Compute vectors and coefficients for Hessian/gradient calcs */ static void -comp_fftri(FFTRI *ftp, FVECT ap0, FVECT ap1, FVECT rop) +comp_fftri(FFTRI *ftp, AMBHEMI *hp, int i, int j, int dbit, const uby8 *vflags) { - double rdot_cp, dot_e, dot_er, rdot_r, rdot_r1, J2; - int i; + const int i0 = ambndx(hp,i,j); + double rdot_cp, dot_e, dot_er, rdot_r, rdot_r1, J2; + int i1, ii; - VSUB(ftp->r_i, ap0, rop); - VSUB(ftp->r_i1, ap1, rop); - VSUB(ftp->e_i, ap1, ap0); + ftp->valid = 0; /* check if we can skip this edge */ + ii = adjacent_trifl[dbit]; + if ((vflags[i0] & ii) == ii) /* cancels if vertex used as value */ + return; + i1 = adjacent_verti(hp, i, j, dbit); + ii = adjacent_trifl[VDB_OPP(dbit)]; + if ((vflags[i1] & ii) == ii) /* on either end (for both triangles) */ + return; + /* else go ahead with calculation */ + VSUB(ftp->r_i, hp->sa[i0].p, hp->rp->rop); + VSUB(ftp->r_i1, hp->sa[i1].p, hp->rp->rop); + VSUB(ftp->e_i, hp->sa[i1].p, hp->sa[i0].p); VCROSS(ftp->rcp, ftp->r_i, ftp->r_i1); rdot_cp = 1.0/DOT(ftp->rcp,ftp->rcp); dot_e = DOT(ftp->e_i,ftp->e_i); @@ -266,8 +417,9 @@ comp_fftri(FFTRI *ftp, FVECT ap0, FVECT ap1, FVECT rop ftp->I2 = ( DOT(ftp->e_i, ftp->r_i1)*rdot_r1 - dot_er*rdot_r + dot_e*ftp->I1 )*0.5*rdot_cp; J2 = ( 0.5*(rdot_r - rdot_r1) - dot_er*ftp->I2 ) / dot_e; - for (i = 3; i--; ) - ftp->rI2_eJ2[i] = ftp->I2*ftp->r_i[i] + J2*ftp->e_i[i]; + for (ii = 3; ii--; ) + ftp->rI2_eJ2[ii] = ftp->I2*ftp->r_i[ii] + J2*ftp->e_i[ii]; + ftp->valid++; } @@ -293,6 +445,11 @@ comp_hessian(FVECT hess[3], FFTRI *ftp, FVECT nrm) double d1, d2, d3, d4; double I3, J3, K3; int i, j; + + if (!ftp->valid) { /* preemptive test */ + memset(hess, 0, sizeof(FVECT)*3); + return; + } /* compute intermediate coefficients */ d1 = 1.0/DOT(ftp->r_i,ftp->r_i); d2 = 1.0/DOT(ftp->r_i1,ftp->r_i1); @@ -316,7 +473,7 @@ comp_hessian(FVECT hess[3], FFTRI *ftp, FVECT nrm) hess[i][j] = m1[i][j] + d1*( I3*m2[i][j] + K3*m3[i][j] + 2.0*J3*m4[i][j] ); hess[i][j] += d2*(i==j); - hess[i][j] *= 1.0/PI; + hess[i][j] *= -1.0/PI; } } @@ -338,7 +495,7 @@ rev_hessian(FVECT hess[3]) /* Add to radiometric Hessian from the given triangle */ static void add2hessian(FVECT hess[3], FVECT ehess1[3], - FVECT ehess2[3], FVECT ehess3[3], COLORV v) + FVECT ehess2[3], FVECT ehess3[3], double v) { int i, j; @@ -356,10 +513,14 @@ comp_gradient(FVECT grad, FFTRI *ftp, FVECT nrm) double f1; int i; + if (!ftp->valid) { /* preemptive test */ + memset(grad, 0, sizeof(FVECT)); + return; + } f1 = 2.0*DOT(nrm, ftp->rcp); VCROSS(ncp, nrm, ftp->e_i); for (i = 3; i--; ) - grad[i] = (-0.5/PI)*( ftp->I1*ncp[i] + f1*ftp->rI2_eJ2[i] ); + grad[i] = (0.5/PI)*( ftp->I1*ncp[i] + f1*ftp->rI2_eJ2[i] ); } @@ -375,7 +536,7 @@ rev_gradient(FVECT grad) /* Add to displacement gradient from the given triangle */ static void -add2gradient(FVECT grad, FVECT egrad1, FVECT egrad2, FVECT egrad3, COLORV v) +add2gradient(FVECT grad, FVECT egrad1, FVECT egrad2, FVECT egrad3, double v) { int i; @@ -384,33 +545,8 @@ add2gradient(FVECT grad, FVECT egrad1, FVECT egrad2, F } -/* Return brightness of furthest ambient sample */ -static COLORV -back_ambval(AMBSAMP *ap1, AMBSAMP *ap2, AMBSAMP *ap3, FVECT orig) -{ - COLORV vback; - FVECT vec; - double d2, d2best; - - VSUB(vec, ap1->p, orig); - d2best = DOT(vec,vec); - vback = colval(ap1->v,CIEY); - VSUB(vec, ap2->p, orig); - d2 = DOT(vec,vec); - if (d2 > d2best) { - d2best = d2; - vback = colval(ap2->v,CIEY); - } - VSUB(vec, ap3->p, orig); - d2 = DOT(vec,vec); - if (d2 > d2best) - return(colval(ap3->v,CIEY)); - return(vback); -} - - /* Compute anisotropic radii and eigenvector directions */ -static int +static void eigenvectors(FVECT uv[2], float ra[2], FVECT hessian[3]) { double hess2[2][2]; @@ -432,9 +568,10 @@ eigenvectors(FVECT uv[2], float ra[2], FVECT hessian[3 if (i == 1) /* double-root (circle) */ evalue[1] = evalue[0]; if (!i || ((evalue[0] = fabs(evalue[0])) <= FTINY*FTINY) | - ((evalue[1] = fabs(evalue[1])) <= FTINY*FTINY) ) - error(INTERNAL, "bad eigenvalue calculation"); - + ((evalue[1] = fabs(evalue[1])) <= FTINY*FTINY) ) { + ra[0] = ra[1] = maxarad; + return; + } if (evalue[0] > evalue[1]) { ra[0] = sqrt(sqrt(4.0/evalue[0])); ra[1] = sqrt(sqrt(4.0/evalue[1])); @@ -469,6 +606,7 @@ ambHessian( /* anisotropic radii & pos. gradient */ static char memerrmsg[] = "out of memory in ambHessian()"; FVECT (*hessrow)[3] = NULL; FVECT *gradrow = NULL; + uby8 *vflags; FVECT hessian[3]; FVECT gradient; FFTRI fftr; @@ -490,10 +628,11 @@ ambHessian( /* anisotropic radii & pos. gradient */ error(SYSTEM, memerrmsg); memset(gradient, 0, sizeof(gradient)); } + /* get vertex position flags */ + vflags = vertex_flags(hp); /* compute first row of edges */ for (j = 0; j < hp->ns-1; j++) { - comp_fftri(&fftr, ambsam(hp,0,j).p, - ambsam(hp,0,j+1).p, hp->rp->rop); + comp_fftri(&fftr, hp, 0, j, VDB_X, vflags); if (hessrow != NULL) comp_hessian(hessrow[j], &fftr, hp->rp->ron); if (gradrow != NULL) @@ -503,8 +642,7 @@ ambHessian( /* anisotropic radii & pos. gradient */ for (i = 0; i < hp->ns-1; i++) { FVECT hesscol[3]; /* compute first vertical edge */ FVECT gradcol; - comp_fftri(&fftr, ambsam(hp,i,0).p, - ambsam(hp,i+1,0).p, hp->rp->rop); + comp_fftri(&fftr, hp, i, 0, VDB_Y, vflags); if (hessrow != NULL) comp_hessian(hesscol, &fftr, hp->rp->ron); if (gradrow != NULL) @@ -512,12 +650,10 @@ ambHessian( /* anisotropic radii & pos. gradient */ for (j = 0; j < hp->ns-1; j++) { FVECT hessdia[3]; /* compute triangle contributions */ FVECT graddia; - COLORV backg; - backg = back_ambval(&ambsam(hp,i,j), &ambsam(hp,i,j+1), - &ambsam(hp,i+1,j), hp->rp->rop); + double backg; + backg = back_ambval(hp, i, j, VDB_X, VDB_Y, vflags); /* diagonal (inner) edge */ - comp_fftri(&fftr, ambsam(hp,i,j+1).p, - ambsam(hp,i+1,j).p, hp->rp->rop); + comp_fftri(&fftr, hp, i, j+1, VDB_xY, vflags); if (hessrow != NULL) { comp_hessian(hessdia, &fftr, hp->rp->ron); rev_hessian(hesscol); @@ -529,17 +665,14 @@ ambHessian( /* anisotropic radii & pos. gradient */ add2gradient(gradient, gradrow[j], graddia, gradcol, backg); } /* initialize edge in next row */ - comp_fftri(&fftr, ambsam(hp,i+1,j+1).p, - ambsam(hp,i+1,j).p, hp->rp->rop); + comp_fftri(&fftr, hp, i+1, j+1, VDB_x, vflags); if (hessrow != NULL) comp_hessian(hessrow[j], &fftr, hp->rp->ron); if (gradrow != NULL) comp_gradient(gradrow[j], &fftr, hp->rp->ron); /* new column edge & paired triangle */ - backg = back_ambval(&ambsam(hp,i,j+1), &ambsam(hp,i+1,j+1), - &ambsam(hp,i+1,j), hp->rp->rop); - comp_fftri(&fftr, ambsam(hp,i,j+1).p, ambsam(hp,i+1,j+1).p, - hp->rp->rop); + backg = back_ambval(hp, i+1, j+1, VDB_x, VDB_y, vflags); + comp_fftri(&fftr, hp, i, j+1, VDB_Y, vflags); if (hessrow != NULL) { comp_hessian(hesscol, &fftr, hp->rp->ron); rev_hessian(hessdia); @@ -559,6 +692,7 @@ ambHessian( /* anisotropic radii & pos. gradient */ /* release row buffers */ if (hessrow != NULL) free(hessrow); if (gradrow != NULL) free(gradrow); + free(vflags); if (ra != NULL) /* extract eigenvectors & radii */ eigenvectors(uv, ra, hessian); @@ -594,6 +728,51 @@ ambdirgrad(AMBHEMI *hp, FVECT uv[2], float dg[2]) } +/* Compute potential light leak direction flags for cache value */ +static uint32 +ambcorral(AMBHEMI *hp, FVECT uv[2], const double r0, const double r1) +{ + const double max_d = 1.0/(minarad*ambacc + 0.001); + const double ang_res = 0.5*PI/(hp->ns-1); + const double ang_step = ang_res/((int)(16/PI*ang_res) + (1+FTINY)); + double avg_d = 0; + uint32 flgs = 0; + int i, j; + /* don't bother for a few samples */ + if (hp->ns < 12) + return(0); + /* check distances overhead */ + for (i = hp->ns*3/4; i-- > hp->ns>>2; ) + for (j = hp->ns*3/4; j-- > hp->ns>>2; ) + avg_d += ambsam(hp,i,j).d; + avg_d *= 4.0/(hp->ns*hp->ns); + if (avg_d*r0 >= 1.0) /* ceiling too low for corral? */ + return(0); + if (avg_d >= max_d) /* insurance */ + return(0); + /* else circle around perimeter */ + for (i = 0; i < hp->ns; i++) + for (j = 0; j < hp->ns; j += !i|(i==hp->ns-1) ? 1 : hp->ns-1) { + AMBSAMP *ap = &ambsam(hp,i,j); + FVECT vec; + double u, v; + double ang, a1; + int abp; + if ((ap->d <= FTINY) | (ap->d >= max_d)) + continue; /* too far or too near */ + VSUB(vec, ap->p, hp->rp->rop); + u = DOT(vec, uv[0]) * ap->d; + v = DOT(vec, uv[1]) * ap->d; + if ((r0*r0*u*u + r1*r1*v*v) * ap->d*ap->d <= 1.0) + continue; /* occluder outside ellipse */ + ang = atan2a(v, u); /* else set direction flags */ + for (a1 = ang-.5*ang_res; a1 <= ang+.5*ang_res; a1 += ang_step) + flgs |= 1L<<(int)(16/PI*(a1 + 2.*PI*(a1 < 0))); + } + return(flgs); +} + + int doambient( /* compute ambient component */ COLOR rcol, /* input/output color */ @@ -602,7 +781,8 @@ doambient( /* compute ambient component */ FVECT uv[2], /* returned (optional) */ float ra[2], /* returned (optional) */ float pg[2], /* returned (optional) */ - float dg[2] /* returned (optional) */ + float dg[2], /* returned (optional) */ + uint32 *crlp /* returned (optional) */ ) { AMBHEMI *hp = inithemi(rcol, r, wt); @@ -622,6 +802,8 @@ doambient( /* compute ambient component */ pg[0] = pg[1] = 0.0; if (dg != NULL) dg[0] = dg[1] = 0.0; + if (crlp != NULL) + *crlp = 0; /* sample the hemisphere */ acol[0] = acol[1] = acol[2] = 0.0; cnt = 0; @@ -642,7 +824,7 @@ doambient( /* compute ambient component */ return(-1); /* return value w/o Hessian */ } cnt = ambssamp*wt + 0.5; /* perform super-sampling? */ - if (cnt > 0) + if (cnt > 8) ambsupersamp(acol, hp, cnt); copycolor(rcol, acol); /* final indirect irradiance/PI */ if ((ra == NULL) & (pg == NULL) & (dg == NULL)) { @@ -656,6 +838,7 @@ doambient( /* compute ambient component */ K = 1.0; pg = NULL; dg = NULL; + crlp = NULL; } ap = hp->sa; /* relative Y channel from here on... */ for (i = hp->ns*hp->ns; i--; ap++) @@ -691,6 +874,9 @@ doambient( /* compute ambient component */ if (ra[0] > maxarad) ra[0] = maxarad; } + /* flag encroached directions */ + if ((wt >= 0.5-FTINY) & (crlp != NULL)) + *crlp = ambcorral(hp, uv, ra[0]*ambacc, ra[1]*ambacc); if (pg != NULL) { /* cap gradient if necessary */ d = pg[0]*pg[0]*ra[0]*ra[0] + pg[1]*pg[1]*ra[1]*ra[1]; if (d > 1.0) {
