--- ray/src/rt/ambcomp.c 1991/08/26 10:11:39 1.14 +++ ray/src/rt/ambcomp.c 1995/05/03 09:46:31 2.5 @@ -27,9 +27,7 @@ typedef struct { short nt, np; /* number of theta and phi directions */ } AMBHEMI; /* ambient sample hemisphere */ -extern double sin(), cos(), sqrt(); - static int ambcmp(d1, d2) /* decreasing order */ AMBSAMP *d1, *d2; @@ -148,7 +146,9 @@ FVECT pg, dg; arad += dp->r; } } - if (ns > 0) { /* perform super-sampling */ + if (ns > 0 && arad > FTINY && ndivs/arad < minarad) + ns = 0; /* close enough */ + else if (ns > 0) { /* else perform super-sampling */ comperrs(div, &hemi); /* compute errors */ qsort(div, ndivs, sizeof(AMBSAMP), ambcmp); /* sort divs */ /* super-sample */ @@ -206,22 +206,24 @@ FVECT pg, dg; b = 1.0/ndivs; scalecolor(acol, b); if (arad <= FTINY) - arad = FHUGE; + arad = maxarad; else arad = (ndivs+ns)/arad; - if (arad > maxarad) - arad = maxarad; - else if (arad < minarad) + if (pg != NULL) { /* reduce radius if gradient large */ + d = DOT(pg,pg); + if (d*arad*arad > 1.0) + arad = 1.0/sqrt(d); + } + if (arad < minarad) { arad = minarad; - arad /= sqrt(wt); - if (pg != NULL) { /* clip pos. gradient if too large */ - d = 4.0*DOT(pg,pg)*arad*arad; - if (d > 1.0) { - d = 1.0/sqrt(d); + if (pg != NULL && d*arad*arad > 1.0) { /* cap gradient */ + d = 1.0/arad/sqrt(d); for (i = 0; i < 3; i++) pg[i] *= d; } } + if ((arad /= sqrt(wt)) > maxarad) + arad = maxarad; return(arad); oopsy: if (div != NULL) @@ -311,10 +313,10 @@ register AMBHEMI *hp; posgradient(gv, da, hp) /* compute position gradient */ FVECT gv; AMBSAMP *da; /* assumes standard ordering */ -AMBHEMI *hp; +register AMBHEMI *hp; { register int i, j; - double b, d; + double nextsine, lastsine, b, d; double mag0, mag1; double phi, cosp, sinp, xd, yd; register AMBSAMP *dp; @@ -323,6 +325,7 @@ AMBHEMI *hp; for (j = 0; j < hp->np; j++) { dp = da + j; mag0 = mag1 = 0.0; + lastsine = 0.0; for (i = 0; i < hp->nt; i++) { #ifdef DEBUG if (dp->t != i || dp->p != j) @@ -333,24 +336,26 @@ AMBHEMI *hp; if (i > 0) { d = dp[-hp->np].r; if (dp[0].r > d) d = dp[0].r; - d *= 1.0 - sqrt((double)i/hp->nt); + /* sin(t)*cos(t)^2 */ + d *= lastsine * (1.0 - (double)i/hp->nt); mag0 += d*(b - bright(dp[-hp->np].v)); } + nextsine = sqrt((double)(i+1)/hp->nt); if (j > 0) { d = dp[-1].r; if (dp[0].r > d) d = dp[0].r; - mag1 += d*(b - bright(dp[-1].v)); + mag1 += d * (nextsine - lastsine) * + (b - bright(dp[-1].v)); } else { d = dp[hp->np-1].r; if (dp[0].r > d) d = dp[0].r; - mag1 += d*(b - bright(dp[hp->np-1].v)); + mag1 += d * (nextsine - lastsine) * + (b - bright(dp[hp->np-1].v)); } dp += hp->np; + lastsine = nextsine; } - if (hp->nt > 1) { - mag0 /= (double)hp->np; - mag1 /= (double)hp->nt; - } + mag0 *= 2.0*PI / hp->np; phi = 2.0*PI * (double)j/hp->np; cosp = cos(phi); sinp = sin(phi); xd += mag0*cosp - mag1*sinp; @@ -364,7 +369,7 @@ AMBHEMI *hp; dirgradient(gv, da, hp) /* compute direction gradient */ FVECT gv; AMBSAMP *da; /* assumes standard ordering */ -AMBHEMI *hp; +register AMBHEMI *hp; { register int i, j; double mag; @@ -381,7 +386,8 @@ AMBHEMI *hp; error(CONSISTENCY, "division order in dirgradient"); #endif - mag += sqrt((i+.5)/hp->nt)*bright(dp->v); + /* tan(t) */ + mag += bright(dp->v)/sqrt(hp->nt/(i+.5) - 1.0); dp += hp->np; } phi = 2.0*PI * (j+.5)/hp->np + PI/2.0; @@ -389,5 +395,5 @@ AMBHEMI *hp; yd += mag * sin(phi); } for (i = 0; i < 3; i++) - gv[i] = (xd*hp->ux[i] + yd*hp->uy[i])*PI/(hp->nt*hp->np); + gv[i] = (xd*hp->ux[i] + yd*hp->uy[i])/(hp->nt*hp->np); }
