--- ray/src/rt/ambcomp.c 2014/05/01 16:01:59 2.43 +++ ray/src/rt/ambcomp.c 2014/05/01 22:34:25 2.45 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: ambcomp.c,v 2.43 2014/05/01 16:01:59 greg Exp $"; +static const char RCSid[] = "$Id: ambcomp.c,v 2.45 2014/05/01 22:34:25 greg Exp $"; #endif /* * Routines to compute "ambient" values using Monte Carlo @@ -22,18 +22,18 @@ static const char RCSid[] = "$Id: ambcomp.c,v 2.43 201 extern void SDsquare2disk(double ds[2], double seedx, double seedy); typedef struct { + COLOR v; /* hemisphere sample value */ + FVECT p; /* intersection point */ +} AMBSAMP; /* sample value */ + +typedef struct { RAY *rp; /* originating ray sample */ FVECT ux, uy; /* tangent axis unit vectors */ int ns; /* number of samples per axis */ COLOR acoef; /* division contribution coefficient */ - struct s_ambsamp { - COLOR v; /* hemisphere sample value */ - FVECT p; /* intersection point */ - } sa[1]; /* sample array (extends struct) */ + AMBSAMP sa[1]; /* sample array (extends struct) */ } AMBHEMI; /* ambient sample hemisphere */ -typedef struct s_ambsamp AMBSAMP; - #define ambsam(h,i,j) (h)->sa[(i)*(h)->ns + (j)] typedef struct { @@ -161,7 +161,7 @@ badsample: static float * getambdiffs(AMBHEMI *hp) { - float *earr = calloc(hp->ns*hp->ns, sizeof(float)); + float *earr = (float *)calloc(hp->ns*hp->ns, sizeof(float)); float *ep; AMBSAMP *ap; double b, d2; @@ -606,7 +606,7 @@ doambient( /* compute ambient component */ ) { AMBHEMI *hp = inithemi(rcol, r, wt); - int cnt = 0; + int cnt; FVECT my_uv[2]; double d, K, acol[3]; AMBSAMP *ap; @@ -624,6 +624,7 @@ doambient( /* compute ambient component */ dg[0] = dg[1] = 0.0; /* sample the hemisphere */ acol[0] = acol[1] = acol[2] = 0.0; + cnt = 0; for (i = hp->ns; i--; ) for (j = hp->ns; j--; ) if ((ap = ambsample(hp, i, j)) != NULL) { @@ -648,11 +649,10 @@ doambient( /* compute ambient component */ free(hp); return(-1); /* no radius or gradient calc. */ } - if (bright(acol) > FTINY) { /* normalize Y values */ - d = 0.99*cnt/bright(acol); + if ((d = bright(acol)) > FTINY) { /* normalize Y values */ + d = 0.99*(hp->ns*hp->ns)/d; K = 0.01; - } else { /* geometric Hessian fall-back */ - d = 0.0; + } else { /* or fall back on geometric Hessian */ K = 1.0; pg = NULL; dg = NULL;
