--- ray/src/rt/ambcomp.c 2013/02/05 05:40:06 2.23 +++ ray/src/rt/ambcomp.c 2014/04/24 19:16:52 2.33 @@ -1,21 +1,587 @@ #ifndef lint -static const char RCSid[] = "$Id: ambcomp.c,v 2.23 2013/02/05 05:40:06 greg Exp $"; +static const char RCSid[] = "$Id: ambcomp.c,v 2.33 2014/04/24 19:16:52 greg Exp $"; #endif /* * Routines to compute "ambient" values using Monte Carlo * + * Hessian calculations based on "Practical Hessian-Based Error Control + * for Irradiance Caching" by Schwarzhaupt, Wann Jensen, & Jarosz + * from ACM SIGGRAPH Asia 2012 conference proceedings. + * * Declarations of external symbols in ambient.h */ #include "copyright.h" #include "ray.h" - #include "ambient.h" - #include "random.h" +#ifdef NEWAMB +extern void SDsquare2disk(double ds[2], double seedx, double seedy); + +typedef struct { + RAY *rp; /* originating ray sample */ + FVECT ux, uy; /* tangent axis unit vectors */ + int ns; /* number of samples per axis */ + COLOR acoef; /* division contribution coefficient */ + struct s_ambsamp { + COLOR v; /* hemisphere sample value */ + FVECT p; /* intersection point */ + } sa[1]; /* sample array (extends struct) */ +} AMBHEMI; /* ambient sample hemisphere */ + +#define ambsamp(h,i,j) (h)->sa[(i)*(h)->ns + (j)] + +typedef struct { + FVECT r_i, r_i1, e_i, rI2_eJ2; + double nf, I1, I2; +} FFTRI; /* vectors and coefficients for Hessian calculation */ + + +static AMBHEMI * +inithemi( /* initialize sampling hemisphere */ + COLOR ac, + RAY *r, + double wt +) +{ + AMBHEMI *hp; + double d; + int n, i; + /* set number of divisions */ + if (ambacc <= FTINY && + wt > (d = 0.8*intens(ac)*r->rweight/(ambdiv*minweight))) + wt = d; /* avoid ray termination */ + n = sqrt(ambdiv * wt) + 0.5; + i = 1 + 5*(ambacc > FTINY); /* minimum number of samples */ + if (n < i) + n = i; + /* allocate sampling array */ + hp = (AMBHEMI *)malloc(sizeof(AMBHEMI) + + sizeof(struct s_ambsamp)*(n*n - 1)); + if (hp == NULL) + return(NULL); + hp->rp = r; + hp->ns = n; + /* assign coefficient */ + copycolor(hp->acoef, ac); + d = 1.0/(n*n); + scalecolor(hp->acoef, d); + /* make tangent plane axes */ + hp->uy[0] = 0.1 - 0.2*frandom(); + hp->uy[1] = 0.1 - 0.2*frandom(); + hp->uy[2] = 0.1 - 0.2*frandom(); + for (i = 0; i < 3; i++) + if (r->ron[i] < 0.6 && r->ron[i] > -0.6) + break; + if (i >= 3) + error(CONSISTENCY, "bad ray direction in inithemi()"); + hp->uy[i] = 1.0; + VCROSS(hp->ux, hp->uy, r->ron); + normalize(hp->ux); + VCROSS(hp->uy, r->ron, hp->ux); + /* we're ready to sample */ + return(hp); +} + + +static struct s_ambsamp * +ambsample( /* sample an ambient direction */ + AMBHEMI *hp, + int i, + int j +) +{ + struct s_ambsamp *ap = &ambsamp(hp,i,j); + RAY ar; + double spt[2], zd; + int ii; + /* ambient coefficient for weight */ + if (ambacc > FTINY) + setcolor(ar.rcoef, AVGREFL, AVGREFL, AVGREFL); + else + copycolor(ar.rcoef, hp->acoef); + if (rayorigin(&ar, AMBIENT, hp->rp, ar.rcoef) < 0) + goto badsample; + if (ambacc > FTINY) { + multcolor(ar.rcoef, hp->acoef); + scalecolor(ar.rcoef, 1./AVGREFL); + } + /* generate hemispherical sample */ + SDsquare2disk(spt, (i+.1+.8*frandom())/hp->ns, + (j+.1+.8*frandom())/hp->ns ); + zd = sqrt(1. - spt[0]*spt[0] - spt[1]*spt[1]); + for (ii = 3; ii--; ) + ar.rdir[ii] = spt[0]*hp->ux[ii] + + spt[1]*hp->uy[ii] + + zd*hp->rp->ron[ii]; + checknorm(ar.rdir); + dimlist[ndims++] = i*hp->ns + j + 90171; + rayvalue(&ar); /* evaluate ray */ + ndims--; + if (ar.rt > 20.0*maxarad) /* limit vertex distance */ + ar.rt = 20.0*maxarad; + else if (ar.rt <= FTINY) /* should never happen! */ + goto badsample; + VSUM(ap->p, ar.rorg, ar.rdir, ar.rt); + multcolor(ar.rcol, ar.rcoef); /* apply coefficient */ + copycolor(ap->v, ar.rcol); + return(ap); +badsample: + setcolor(ap->v, 0., 0., 0.); + VCOPY(ap->p, hp->rp->rop); + return(NULL); +} + + +/* Compute vectors and coefficients for Hessian/gradient calcs */ +static void +comp_fftri(FFTRI *ftp, FVECT ap0, FVECT ap1, FVECT rop) +{ + FVECT vcp; + double dot_e, dot_er, rdot_r, rdot_r1, J2; + int i; + + VSUB(ftp->r_i, ap0, rop); + VSUB(ftp->r_i1, ap1, rop); + VSUB(ftp->e_i, ap1, ap0); + VCROSS(vcp, ftp->e_i, ftp->r_i); + ftp->nf = 1.0/DOT(vcp,vcp); + dot_e = DOT(ftp->e_i,ftp->e_i); + dot_er = DOT(ftp->e_i, ftp->r_i); + rdot_r = 1.0/DOT(ftp->r_i,ftp->r_i); + rdot_r1 = 1.0/DOT(ftp->r_i1,ftp->r_i1); + ftp->I1 = acos( DOT(ftp->r_i, ftp->r_i1) * sqrt(rdot_r*rdot_r1) ) * + sqrt( ftp->nf ); + ftp->I2 = ( DOT(ftp->e_i, ftp->r_i1)*rdot_r1 - dot_er*rdot_r + + dot_e*ftp->I1 )*0.5*ftp->nf; + J2 = ( 0.5*(rdot_r - rdot_r1) - dot_er*ftp->I2 ) / dot_e; + for (i = 3; i--; ) + ftp->rI2_eJ2[i] = ftp->I2*ftp->r_i[i] + J2*ftp->e_i[i]; +} + + +/* Compose 3x3 matrix from two vectors */ +static void +compose_matrix(FVECT mat[3], FVECT va, FVECT vb) +{ + mat[0][0] = 2.0*va[0]*vb[0]; + mat[1][1] = 2.0*va[1]*vb[1]; + mat[2][2] = 2.0*va[2]*vb[2]; + mat[0][1] = mat[1][0] = va[0]*vb[1] + va[1]*vb[0]; + mat[0][2] = mat[2][0] = va[0]*vb[2] + va[2]*vb[0]; + mat[1][2] = mat[2][1] = va[1]*vb[2] + va[2]*vb[1]; +} + + +/* Compute partial 3x3 Hessian matrix for edge */ +static void +comp_hessian(FVECT hess[3], FFTRI *ftp, FVECT nrm) +{ + FVECT vcp; + FVECT m1[3], m2[3], m3[3], m4[3]; + double d1, d2, d3, d4; + double I3, J3, K3; + int i, j; + /* compute intermediate coefficients */ + d1 = 1.0/DOT(ftp->r_i,ftp->r_i); + d2 = 1.0/DOT(ftp->r_i1,ftp->r_i1); + d3 = 1.0/DOT(ftp->e_i,ftp->e_i); + d4 = DOT(ftp->e_i, ftp->r_i); + I3 = 0.25*ftp->nf*( DOT(ftp->e_i, ftp->r_i1)*d2*d2 - d4*d1*d1 + + 3.0/d3*ftp->I2 ); + J3 = 0.25*d3*(d1*d1 - d2*d2) - d4*d3*I3; + K3 = d3*(ftp->I2 - I3/d1 - 2.0*d4*J3); + /* intermediate matrices */ + VCROSS(vcp, nrm, ftp->e_i); + compose_matrix(m1, vcp, ftp->rI2_eJ2); + compose_matrix(m2, ftp->r_i, ftp->r_i); + compose_matrix(m3, ftp->e_i, ftp->e_i); + compose_matrix(m4, ftp->r_i, ftp->e_i); + VCROSS(vcp, ftp->r_i, ftp->e_i); + d1 = DOT(nrm, vcp); + d2 = -d1*ftp->I2; + d1 *= 2.0; + for (i = 3; i--; ) /* final matrix sum */ + for (j = 3; j--; ) { + hess[i][j] = m1[i][j] + d1*( I3*m2[i][j] + K3*m3[i][j] + + 2.0*J3*m4[i][j] ); + hess[i][j] += d2*(i==j); + hess[i][j] *= 1.0/PI; + } +} + + +/* Reverse hessian calculation result for edge in other direction */ +static void +rev_hessian(FVECT hess[3]) +{ + int i; + + for (i = 3; i--; ) { + hess[i][0] = -hess[i][0]; + hess[i][1] = -hess[i][1]; + hess[i][2] = -hess[i][2]; + } +} + + +/* Add to radiometric Hessian from the given triangle */ +static void +add2hessian(FVECT hess[3], FVECT ehess1[3], + FVECT ehess2[3], FVECT ehess3[3], COLORV v) +{ + int i, j; + + for (i = 3; i--; ) + for (j = 3; j--; ) + hess[i][j] += v*( ehess1[i][j] + ehess2[i][j] + ehess3[i][j] ); +} + + +/* Compute partial displacement form factor gradient for edge */ +static void +comp_gradient(FVECT grad, FFTRI *ftp, FVECT nrm) +{ + FVECT vcp; + double f1; + int i; + + VCROSS(vcp, ftp->r_i, ftp->r_i1); + f1 = 2.0*DOT(nrm, vcp); + VCROSS(vcp, nrm, ftp->e_i); + for (i = 3; i--; ) + grad[i] = (-0.5/PI)*( ftp->I1*vcp[i] + f1*ftp->rI2_eJ2[i] ); +} + + +/* Reverse gradient calculation result for edge in other direction */ +static void +rev_gradient(FVECT grad) +{ + grad[0] = -grad[0]; + grad[1] = -grad[1]; + grad[2] = -grad[2]; +} + + +/* Add to displacement gradient from the given triangle */ +static void +add2gradient(FVECT grad, FVECT egrad1, FVECT egrad2, FVECT egrad3, COLORV v) +{ + int i; + + for (i = 3; i--; ) + grad[i] += v*( egrad1[i] + egrad2[i] + egrad3[i] ); +} + + +/* Return brightness of furthest ambient sample */ +static COLORV +back_ambval(struct s_ambsamp *ap1, struct s_ambsamp *ap2, + struct s_ambsamp *ap3, FVECT orig) +{ + COLORV vback; + FVECT vec; + double d2, d2best; + + VSUB(vec, ap1->p, orig); + d2best = DOT(vec,vec); + vback = colval(ap1->v,CIEY); + VSUB(vec, ap2->p, orig); + d2 = DOT(vec,vec); + if (d2 > d2best) { + d2best = d2; + vback = colval(ap2->v,CIEY); + } + VSUB(vec, ap3->p, orig); + d2 = DOT(vec,vec); + if (d2 > d2best) + return(colval(ap3->v,CIEY)); + return(vback); +} + + +/* Compute anisotropic radii and eigenvector directions */ +static int +eigenvectors(FVECT uv[2], float ra[2], FVECT hessian[3]) +{ + double hess2[2][2]; + FVECT a, b; + double evalue[2], slope1, xmag1; + int i; + /* project Hessian to sample plane */ + for (i = 3; i--; ) { + a[i] = DOT(hessian[i], uv[0]); + b[i] = DOT(hessian[i], uv[1]); + } + hess2[0][0] = DOT(uv[0], a); + hess2[0][1] = DOT(uv[0], b); + hess2[1][0] = DOT(uv[1], a); + hess2[1][1] = DOT(uv[1], b); + /* compute eigenvalues */ + if ( quadratic(evalue, 1.0, -hess2[0][0]-hess2[1][1], + hess2[0][0]*hess2[1][1]-hess2[0][1]*hess2[1][0]) != 2 || + (evalue[0] = fabs(evalue[0])) <= FTINY*FTINY || + (evalue[1] = fabs(evalue[1])) <= FTINY*FTINY ) + error(INTERNAL, "bad eigenvalue calculation"); + + if (evalue[0] > evalue[1]) { + ra[0] = sqrt(sqrt(4.0/evalue[0])); + ra[1] = sqrt(sqrt(4.0/evalue[1])); + slope1 = evalue[1]; + } else { + ra[0] = sqrt(sqrt(4.0/evalue[1])); + ra[1] = sqrt(sqrt(4.0/evalue[0])); + slope1 = evalue[0]; + } + /* compute unit eigenvectors */ + if (fabs(hess2[0][1]) <= FTINY) + return; /* uv OK as is */ + slope1 = (slope1 - hess2[0][0]) / hess2[0][1]; + xmag1 = sqrt(1.0/(1.0 + slope1*slope1)); + for (i = 3; i--; ) { + b[i] = xmag1*uv[0][i] + slope1*xmag1*uv[1][i]; + a[i] = slope1*xmag1*uv[0][i] - xmag1*uv[1][i]; + } + VCOPY(uv[0], a); + VCOPY(uv[1], b); +} + + +static void +ambHessian( /* anisotropic radii & pos. gradient */ + AMBHEMI *hp, + FVECT uv[2], /* returned */ + float ra[2], /* returned (optional) */ + float pg[2] /* returned (optional) */ +) +{ + static char memerrmsg[] = "out of memory in ambHessian()"; + FVECT (*hessrow)[3] = NULL; + FVECT *gradrow = NULL; + FVECT hessian[3]; + FVECT gradient; + FFTRI fftr; + int i, j; + /* be sure to assign unit vectors */ + VCOPY(uv[0], hp->ux); + VCOPY(uv[1], hp->uy); + /* clock-wise vertex traversal from sample POV */ + if (ra != NULL) { /* initialize Hessian row buffer */ + hessrow = (FVECT (*)[3])malloc(sizeof(FVECT)*3*(hp->ns-1)); + if (hessrow == NULL) + error(SYSTEM, memerrmsg); + memset(hessian, 0, sizeof(hessian)); + } else if (pg == NULL) /* bogus call? */ + return; + if (pg != NULL) { /* initialize form factor row buffer */ + gradrow = (FVECT *)malloc(sizeof(FVECT)*(hp->ns-1)); + if (gradrow == NULL) + error(SYSTEM, memerrmsg); + memset(gradient, 0, sizeof(gradient)); + } + /* compute first row of edges */ + for (j = 0; j < hp->ns-1; j++) { + comp_fftri(&fftr, ambsamp(hp,0,j).p, + ambsamp(hp,0,j+1).p, hp->rp->rop); + if (hessrow != NULL) + comp_hessian(hessrow[j], &fftr, hp->rp->ron); + if (gradrow != NULL) + comp_gradient(gradrow[j], &fftr, hp->rp->ron); + } + /* sum each row of triangles */ + for (i = 0; i < hp->ns-1; i++) { + FVECT hesscol[3]; /* compute first vertical edge */ + FVECT gradcol; + comp_fftri(&fftr, ambsamp(hp,i,0).p, + ambsamp(hp,i+1,0).p, hp->rp->rop); + if (hessrow != NULL) + comp_hessian(hesscol, &fftr, hp->rp->ron); + if (gradrow != NULL) + comp_gradient(gradcol, &fftr, hp->rp->ron); + for (j = 0; j < hp->ns-1; j++) { + FVECT hessdia[3]; /* compute triangle contributions */ + FVECT graddia; + COLORV backg; + backg = back_ambval(&ambsamp(hp,i,j), &ambsamp(hp,i,j+1), + &ambsamp(hp,i+1,j), hp->rp->rop); + /* diagonal (inner) edge */ + comp_fftri(&fftr, ambsamp(hp,i,j+1).p, + ambsamp(hp,i+1,j).p, hp->rp->rop); + if (hessrow != NULL) { + comp_hessian(hessdia, &fftr, hp->rp->ron); + rev_hessian(hesscol); + add2hessian(hessian, hessrow[j], hessdia, hesscol, backg); + } + if (gradient != NULL) { + comp_gradient(graddia, &fftr, hp->rp->ron); + rev_gradient(gradcol); + add2gradient(gradient, gradrow[j], graddia, gradcol, backg); + } + /* initialize edge in next row */ + comp_fftri(&fftr, ambsamp(hp,i+1,j+1).p, + ambsamp(hp,i+1,j).p, hp->rp->rop); + if (hessrow != NULL) + comp_hessian(hessrow[j], &fftr, hp->rp->ron); + if (gradrow != NULL) + comp_gradient(gradrow[j], &fftr, hp->rp->ron); + /* new column edge & paired triangle */ + backg = back_ambval(&ambsamp(hp,i,j+1), &ambsamp(hp,i+1,j+1), + &ambsamp(hp,i+1,j), hp->rp->rop); + comp_fftri(&fftr, ambsamp(hp,i,j+1).p, ambsamp(hp,i+1,j+1).p, + hp->rp->rop); + if (hessrow != NULL) { + comp_hessian(hesscol, &fftr, hp->rp->ron); + rev_hessian(hessdia); + add2hessian(hessian, hessrow[j], hessdia, hesscol, backg); + if (i < hp->ns-2) + rev_hessian(hessrow[j]); + } + if (gradrow != NULL) { + comp_gradient(gradcol, &fftr, hp->rp->ron); + rev_gradient(graddia); + add2gradient(gradient, gradrow[j], graddia, gradcol, backg); + if (i < hp->ns-2) + rev_gradient(gradrow[j]); + } + } + } + /* release row buffers */ + if (hessrow != NULL) free(hessrow); + if (gradrow != NULL) free(gradrow); + + if (ra != NULL) /* extract eigenvectors & radii */ + eigenvectors(uv, ra, hessian); + if (pg != NULL) { /* tangential position gradient */ + pg[0] = DOT(gradient, uv[0]); + pg[1] = DOT(gradient, uv[1]); + } +} + + +/* Compute direction gradient from a hemispherical sampling */ +static void +ambdirgrad(AMBHEMI *hp, FVECT uv[2], float dg[2]) +{ + struct s_ambsamp *ap; + double dgsum[2]; + int n; + FVECT vd; + double gfact; + + dgsum[0] = dgsum[1] = 0.0; /* sum values times -tan(theta) */ + for (ap = hp->sa, n = hp->ns*hp->ns; n--; ap++) { + /* use vector for azimuth + 90deg */ + VSUB(vd, ap->p, hp->rp->rop); + /* brightness over cosine factor */ + gfact = colval(ap->v,CIEY) / DOT(hp->rp->ron, vd); + /* -sine = -proj_radius/vd_length */ + dgsum[0] += DOT(uv[1], vd) * gfact; + dgsum[1] -= DOT(uv[0], vd) * gfact; + } + dg[0] = dgsum[0] / (hp->ns*hp->ns); + dg[1] = dgsum[1] / (hp->ns*hp->ns); +} + + +int +doambient( /* compute ambient component */ + COLOR rcol, /* input/output color */ + RAY *r, + double wt, + FVECT uv[2], /* returned (optional) */ + float ra[2], /* returned (optional) */ + float pg[2], /* returned (optional) */ + float dg[2] /* returned (optional) */ +) +{ + AMBHEMI *hp = inithemi(rcol, r, wt); + int cnt = 0; + FVECT my_uv[2]; + double d, acol[3]; + struct s_ambsamp *ap; + int i, j; + /* check/initialize */ + if (hp == NULL) + return(0); + if (uv != NULL) + memset(uv, 0, sizeof(FVECT)*2); + if (ra != NULL) + ra[0] = ra[1] = 0.0; + if (pg != NULL) + pg[0] = pg[1] = 0.0; + if (dg != NULL) + dg[0] = dg[1] = 0.0; + /* sample the hemisphere */ + acol[0] = acol[1] = acol[2] = 0.0; + for (i = hp->ns; i--; ) + for (j = hp->ns; j--; ) + if ((ap = ambsample(hp, i, j)) != NULL) { + addcolor(acol, ap->v); + ++cnt; + } + if (!cnt) { + setcolor(rcol, 0.0, 0.0, 0.0); + free(hp); + return(0); /* no valid samples */ + } + copycolor(rcol, acol); /* final indirect irradiance/PI */ + if (cnt < hp->ns*hp->ns || /* incomplete sampling? */ + (ra == NULL) & (pg == NULL) & (dg == NULL)) { + free(hp); + return(-1); /* no radius or gradient calc. */ + } + if (bright(acol) > FTINY) /* normalize Y values */ + d = cnt/bright(acol); + else + d = 0.0; + ap = hp->sa; /* relative Y channel from here on... */ + for (i = hp->ns*hp->ns; i--; ap++) + colval(ap->v,CIEY) = bright(ap->v)*d + 0.01; + + if (uv == NULL) /* make sure we have axis pointers */ + uv = my_uv; + /* compute radii & pos. gradient */ + ambHessian(hp, uv, ra, pg); + + if (dg != NULL) /* compute direction gradient */ + ambdirgrad(hp, uv, dg); + + if (ra != NULL) { /* scale/clamp radii */ + if (ra[0] < minarad) { + ra[0] = minarad; + if (ra[1] < minarad) + ra[1] = minarad; + /* cap gradient if necessary */ + if (pg != NULL) { + d = (pg[0]*pg[0] + pg[1]*pg[1])*ra[0]*ra[0]; + if (d > 1.0) { + d = 1.0/sqrt(d); + pg[0] *= d; + pg[1] *= d; + } + } + } + ra[0] *= d = 1.0/sqrt(sqrt(wt)); + if ((ra[1] *= d) > 2.0*ra[0]) + ra[1] = 2.0*ra[0]; + if (ra[1] > maxarad) { + ra[1] = maxarad; + if (ra[0] > maxarad) + ra[0] = maxarad; + } + } + free(hp); /* clean up and return */ + return(1); +} + + +#else /* ! NEWAMB */ + + void inithemi( /* initialize sampling hemisphere */ AMBHEMI *hp, @@ -156,7 +722,7 @@ doambient( /* compute ambient component */ FVECT dg ) { - double b, d; + double b, d=0; AMBHEMI hemi; AMBSAMP *div; AMBSAMP dnew; @@ -434,3 +1000,5 @@ dirgradient( /* compute direction gradient */ for (i = 0; i < 3; i++) gv[i] = xd*hp->ux[i] + yd*hp->uy[i]; } + +#endif /* ! NEWAMB */
