--- ray/src/rt/ambcomp.c 1991/08/26 10:11:39 1.14 +++ ray/src/rt/ambcomp.c 2014/04/11 20:31:37 2.25 @@ -1,91 +1,108 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: ambcomp.c,v 2.25 2014/04/11 20:31:37 greg Exp $"; #endif - /* * Routines to compute "ambient" values using Monte Carlo + * + * Declarations of external symbols in ambient.h */ -#include "ray.h" +#include "copyright.h" +#include "ray.h" #include "ambient.h" - #include "random.h" -typedef struct { - short t, p; /* theta, phi indices */ - COLOR v; /* value sum */ - float r; /* 1/distance sum */ - float k; /* variance for this division */ - int n; /* number of subsamples */ -} AMBSAMP; /* ambient sample division */ +#ifdef NEWAMB -typedef struct { - FVECT ux, uy, uz; /* x, y and z axis directions */ - short nt, np; /* number of theta and phi directions */ -} AMBHEMI; /* ambient sample hemisphere */ +#else /* ! NEWAMB */ -extern double sin(), cos(), sqrt(); - -static int -ambcmp(d1, d2) /* decreasing order */ -AMBSAMP *d1, *d2; +void +inithemi( /* initialize sampling hemisphere */ + AMBHEMI *hp, + COLOR ac, + RAY *r, + double wt +) { - if (d1->k < d2->k) - return(1); - if (d1->k > d2->k) - return(-1); - return(0); + double d; + int i; + /* set number of divisions */ + if (ambacc <= FTINY && + wt > (d = 0.8*intens(ac)*r->rweight/(ambdiv*minweight))) + wt = d; /* avoid ray termination */ + hp->nt = sqrt(ambdiv * wt / PI) + 0.5; + i = ambacc > FTINY ? 3 : 1; /* minimum number of samples */ + if (hp->nt < i) + hp->nt = i; + hp->np = PI * hp->nt + 0.5; + /* set number of super-samples */ + hp->ns = ambssamp * wt + 0.5; + /* assign coefficient */ + copycolor(hp->acoef, ac); + d = 1.0/(hp->nt*hp->np); + scalecolor(hp->acoef, d); + /* make axes */ + VCOPY(hp->uz, r->ron); + hp->uy[0] = hp->uy[1] = hp->uy[2] = 0.0; + for (i = 0; i < 3; i++) + if (hp->uz[i] < 0.6 && hp->uz[i] > -0.6) + break; + if (i >= 3) + error(CONSISTENCY, "bad ray direction in inithemi"); + hp->uy[i] = 1.0; + fcross(hp->ux, hp->uy, hp->uz); + normalize(hp->ux); + fcross(hp->uy, hp->uz, hp->ux); } -static int -ambnorm(d1, d2) /* standard order */ -AMBSAMP *d1, *d2; +int +divsample( /* sample a division */ + AMBSAMP *dp, + AMBHEMI *h, + RAY *r +) { - register int c; - - if (c = d1->t - d2->t) - return(c); - return(d1->p - d2->p); -} - - -divsample(dp, h, r) /* sample a division */ -register AMBSAMP *dp; -AMBHEMI *h; -RAY *r; -{ RAY ar; int hlist[3]; double spt[2]; double xd, yd, zd; double b2; double phi; - register int i; - - if (rayorigin(&ar, r, AMBIENT, AVGREFL) < 0) + int i; + /* ambient coefficient for weight */ + if (ambacc > FTINY) + setcolor(ar.rcoef, AVGREFL, AVGREFL, AVGREFL); + else + copycolor(ar.rcoef, h->acoef); + if (rayorigin(&ar, AMBIENT, r, ar.rcoef) < 0) return(-1); + if (ambacc > FTINY) { + multcolor(ar.rcoef, h->acoef); + scalecolor(ar.rcoef, 1./AVGREFL); + } hlist[0] = r->rno; hlist[1] = dp->t; hlist[2] = dp->p; multisamp(spt, 2, urand(ilhash(hlist,3)+dp->n)); zd = sqrt((dp->t + spt[0])/h->nt); phi = 2.0*PI * (dp->p + spt[1])/h->np; - xd = cos(phi) * zd; - yd = sin(phi) * zd; + xd = tcos(phi) * zd; + yd = tsin(phi) * zd; zd = sqrt(1.0 - zd*zd); for (i = 0; i < 3; i++) ar.rdir[i] = xd*h->ux[i] + yd*h->uy[i] + zd*h->uz[i]; + checknorm(ar.rdir); dimlist[ndims++] = dp->t*h->np + dp->p + 90171; rayvalue(&ar); ndims--; + multcolor(ar.rcol, ar.rcoef); /* apply coefficient */ addcolor(dp->v, ar.rcol); + /* use rt to improve gradient calc */ if (ar.rt > FTINY && ar.rt < FHUGE) dp->r += 1.0/ar.rt; /* (re)initialize error */ @@ -99,78 +116,134 @@ RAY *r; } +static int +ambcmp( /* decreasing order */ + const void *p1, + const void *p2 +) +{ + const AMBSAMP *d1 = (const AMBSAMP *)p1; + const AMBSAMP *d2 = (const AMBSAMP *)p2; + + if (d1->k < d2->k) + return(1); + if (d1->k > d2->k) + return(-1); + return(0); +} + + +static int +ambnorm( /* standard order */ + const void *p1, + const void *p2 +) +{ + const AMBSAMP *d1 = (const AMBSAMP *)p1; + const AMBSAMP *d2 = (const AMBSAMP *)p2; + int c; + + if ( (c = d1->t - d2->t) ) + return(c); + return(d1->p - d2->p); +} + + double -doambient(acol, r, wt, pg, dg) /* compute ambient component */ -COLOR acol; -RAY *r; -double wt; -FVECT pg, dg; +doambient( /* compute ambient component */ + COLOR rcol, + RAY *r, + double wt, + FVECT pg, + FVECT dg +) { - double b, d; + double b, d=0; AMBHEMI hemi; AMBSAMP *div; AMBSAMP dnew; - register AMBSAMP *dp; + double acol[3]; + AMBSAMP *dp; double arad; - int ndivs, ns; - register int i, j; - /* initialize color */ - setcolor(acol, 0.0, 0.0, 0.0); + int divcnt; + int i, j; /* initialize hemisphere */ - inithemi(&hemi, r, wt); - ndivs = hemi.nt * hemi.np; - if (ndivs == 0) + inithemi(&hemi, rcol, r, wt); + divcnt = hemi.nt * hemi.np; + /* initialize */ + if (pg != NULL) + pg[0] = pg[1] = pg[2] = 0.0; + if (dg != NULL) + dg[0] = dg[1] = dg[2] = 0.0; + setcolor(rcol, 0.0, 0.0, 0.0); + if (divcnt == 0) return(0.0); - /* set number of super-samples */ - ns = ambssamp * wt + 0.5; - if (ns > 0 || pg != NULL || dg != NULL) { - div = (AMBSAMP *)malloc(ndivs*sizeof(AMBSAMP)); + /* allocate super-samples */ + if (hemi.ns > 0 || pg != NULL || dg != NULL) { + div = (AMBSAMP *)malloc(divcnt*sizeof(AMBSAMP)); if (div == NULL) error(SYSTEM, "out of memory in doambient"); } else div = NULL; /* sample the divisions */ arad = 0.0; + acol[0] = acol[1] = acol[2] = 0.0; if ((dp = div) == NULL) dp = &dnew; + divcnt = 0; for (i = 0; i < hemi.nt; i++) for (j = 0; j < hemi.np; j++) { dp->t = i; dp->p = j; setcolor(dp->v, 0.0, 0.0, 0.0); dp->r = 0.0; dp->n = 0; - if (divsample(dp, &hemi, r) < 0) - goto oopsy; + if (divsample(dp, &hemi, r) < 0) { + if (div != NULL) + dp++; + continue; + } + arad += dp->r; + divcnt++; if (div != NULL) dp++; - else { + else addcolor(acol, dp->v); - arad += dp->r; - } } - if (ns > 0) { /* perform super-sampling */ + if (!divcnt) { + if (div != NULL) + free((void *)div); + return(0.0); /* no samples taken */ + } + if (divcnt < hemi.nt*hemi.np) { + pg = dg = NULL; /* incomplete sampling */ + hemi.ns = 0; + } else if (arad > FTINY && divcnt/arad < minarad) { + hemi.ns = 0; /* close enough */ + } else if (hemi.ns > 0) { /* else perform super-sampling? */ comperrs(div, &hemi); /* compute errors */ - qsort(div, ndivs, sizeof(AMBSAMP), ambcmp); /* sort divs */ + qsort(div, divcnt, sizeof(AMBSAMP), ambcmp); /* sort divs */ /* super-sample */ - for (i = ns; i > 0; i--) { - copystruct(&dnew, div); - if (divsample(&dnew, &hemi, r) < 0) - goto oopsy; - /* reinsert */ - dp = div; - j = ndivs < i ? ndivs : i; + for (i = hemi.ns; i > 0; i--) { + dnew = *div; + if (divsample(&dnew, &hemi, r) < 0) { + dp++; + continue; + } + dp = div; /* reinsert */ + j = divcnt < i ? divcnt : i; while (--j > 0 && dnew.k < dp[1].k) { - copystruct(dp, dp+1); + *dp = *(dp+1); dp++; } - copystruct(dp, &dnew); + *dp = dnew; } if (pg != NULL || dg != NULL) /* restore order */ - qsort(div, ndivs, sizeof(AMBSAMP), ambnorm); + qsort(div, divcnt, sizeof(AMBSAMP), ambnorm); } /* compute returned values */ if (div != NULL) { - for (i = ndivs, dp = div; i-- > 0; dp++) { + arad = 0.0; /* note: divcnt may be < nt*np */ + for (i = hemi.nt*hemi.np, dp = div; i-- > 0; dp++) { arad += dp->r; if (dp->n > 1) { b = 1.0/dp->n; @@ -182,7 +255,7 @@ FVECT pg, dg; } b = bright(acol); if (b > FTINY) { - b = ndivs/b; + b = 1.0/b; /* compute & normalize gradient(s) */ if (pg != NULL) { posgradient(pg, div, &hemi); for (i = 0; i < 3; i++) @@ -193,78 +266,42 @@ FVECT pg, dg; for (i = 0; i < 3; i++) dg[i] *= b; } - } else { - if (pg != NULL) - for (i = 0; i < 3; i++) - pg[i] = 0.0; - if (dg != NULL) - for (i = 0; i < 3; i++) - dg[i] = 0.0; } - free((char *)div); + free((void *)div); } - b = 1.0/ndivs; - scalecolor(acol, b); + copycolor(rcol, acol); if (arad <= FTINY) - arad = FHUGE; - else - arad = (ndivs+ns)/arad; - if (arad > maxarad) arad = maxarad; - else if (arad < minarad) + else + arad = (divcnt+hemi.ns)/arad; + if (pg != NULL) { /* reduce radius if gradient large */ + d = DOT(pg,pg); + if (d*arad*arad > 1.0) + arad = 1.0/sqrt(d); + } + if (arad < minarad) { arad = minarad; - arad /= sqrt(wt); - if (pg != NULL) { /* clip pos. gradient if too large */ - d = 4.0*DOT(pg,pg)*arad*arad; - if (d > 1.0) { - d = 1.0/sqrt(d); + if (pg != NULL && d*arad*arad > 1.0) { /* cap gradient */ + d = 1.0/arad/sqrt(d); for (i = 0; i < 3; i++) pg[i] *= d; } } + if ((arad /= sqrt(wt)) > maxarad) + arad = maxarad; return(arad); -oopsy: - if (div != NULL) - free((char *)div); - return(0.0); } -inithemi(hp, r, wt) /* initialize sampling hemisphere */ -register AMBHEMI *hp; -RAY *r; -double wt; +void +comperrs( /* compute initial error estimates */ + AMBSAMP *da, /* assumes standard ordering */ + AMBHEMI *hp +) { - register int i; - /* set number of divisions */ - if (wt < (.25*PI)/ambdiv+FTINY) { - hp->nt = hp->np = 0; - return; /* zero samples */ - } - hp->nt = sqrt(ambdiv * wt / PI) + 0.5; - hp->np = PI * hp->nt + 0.5; - /* make axes */ - VCOPY(hp->uz, r->ron); - hp->uy[0] = hp->uy[1] = hp->uy[2] = 0.0; - for (i = 0; i < 3; i++) - if (hp->uz[i] < 0.6 && hp->uz[i] > -0.6) - break; - if (i >= 3) - error(CONSISTENCY, "bad ray direction in inithemi"); - hp->uy[i] = 1.0; - fcross(hp->ux, hp->uy, hp->uz); - normalize(hp->ux); - fcross(hp->uy, hp->uz, hp->ux); -} - - -comperrs(da, hp) /* compute initial error estimates */ -AMBSAMP *da; /* assumes standard ordering */ -register AMBHEMI *hp; -{ double b, b2; int i, j; - register AMBSAMP *dp; + AMBSAMP *dp; /* sum differences from neighbors */ dp = da; for (i = 0; i < hp->nt; i++) @@ -308,21 +345,24 @@ register AMBHEMI *hp; } -posgradient(gv, da, hp) /* compute position gradient */ -FVECT gv; -AMBSAMP *da; /* assumes standard ordering */ -AMBHEMI *hp; +void +posgradient( /* compute position gradient */ + FVECT gv, + AMBSAMP *da, /* assumes standard ordering */ + AMBHEMI *hp +) { - register int i, j; - double b, d; + int i, j; + double nextsine, lastsine, b, d; double mag0, mag1; double phi, cosp, sinp, xd, yd; - register AMBSAMP *dp; + AMBSAMP *dp; xd = yd = 0.0; for (j = 0; j < hp->np; j++) { dp = da + j; mag0 = mag1 = 0.0; + lastsine = 0.0; for (i = 0; i < hp->nt; i++) { #ifdef DEBUG if (dp->t != i || dp->p != j) @@ -333,43 +373,47 @@ AMBHEMI *hp; if (i > 0) { d = dp[-hp->np].r; if (dp[0].r > d) d = dp[0].r; - d *= 1.0 - sqrt((double)i/hp->nt); + /* sin(t)*cos(t)^2 */ + d *= lastsine * (1.0 - (double)i/hp->nt); mag0 += d*(b - bright(dp[-hp->np].v)); } + nextsine = sqrt((double)(i+1)/hp->nt); if (j > 0) { d = dp[-1].r; if (dp[0].r > d) d = dp[0].r; - mag1 += d*(b - bright(dp[-1].v)); + mag1 += d * (nextsine - lastsine) * + (b - bright(dp[-1].v)); } else { d = dp[hp->np-1].r; if (dp[0].r > d) d = dp[0].r; - mag1 += d*(b - bright(dp[hp->np-1].v)); + mag1 += d * (nextsine - lastsine) * + (b - bright(dp[hp->np-1].v)); } dp += hp->np; + lastsine = nextsine; } - if (hp->nt > 1) { - mag0 /= (double)hp->np; - mag1 /= (double)hp->nt; - } + mag0 *= 2.0*PI / hp->np; phi = 2.0*PI * (double)j/hp->np; - cosp = cos(phi); sinp = sin(phi); + cosp = tcos(phi); sinp = tsin(phi); xd += mag0*cosp - mag1*sinp; yd += mag0*sinp + mag1*cosp; } for (i = 0; i < 3; i++) - gv[i] = (xd*hp->ux[i] + yd*hp->uy[i])/PI; + gv[i] = (xd*hp->ux[i] + yd*hp->uy[i])*(hp->nt*hp->np)/PI; } -dirgradient(gv, da, hp) /* compute direction gradient */ -FVECT gv; -AMBSAMP *da; /* assumes standard ordering */ -AMBHEMI *hp; +void +dirgradient( /* compute direction gradient */ + FVECT gv, + AMBSAMP *da, /* assumes standard ordering */ + AMBHEMI *hp +) { - register int i, j; + int i, j; double mag; double phi, xd, yd; - register AMBSAMP *dp; + AMBSAMP *dp; xd = yd = 0.0; for (j = 0; j < hp->np; j++) { @@ -381,13 +425,16 @@ AMBHEMI *hp; error(CONSISTENCY, "division order in dirgradient"); #endif - mag += sqrt((i+.5)/hp->nt)*bright(dp->v); + /* tan(t) */ + mag += bright(dp->v)/sqrt(hp->nt/(i+.5) - 1.0); dp += hp->np; } phi = 2.0*PI * (j+.5)/hp->np + PI/2.0; - xd += mag * cos(phi); - yd += mag * sin(phi); + xd += mag * tcos(phi); + yd += mag * tsin(phi); } for (i = 0; i < 3; i++) - gv[i] = (xd*hp->ux[i] + yd*hp->uy[i])*PI/(hp->nt*hp->np); + gv[i] = xd*hp->ux[i] + yd*hp->uy[i]; } + +#endif /* ! NEWAMB */
