--- ray/src/rt/ambcomp.c 2005/06/04 06:10:12 2.17 +++ ray/src/rt/ambcomp.c 2005/10/28 16:16:33 2.20 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: ambcomp.c,v 2.17 2005/06/04 06:10:12 greg Exp $"; +static const char RCSid[] = "$Id: ambcomp.c,v 2.20 2005/10/28 16:16:33 greg Exp $"; #endif /* * Routines to compute "ambient" values using Monte Carlo @@ -28,7 +28,7 @@ inithemi( /* initialize sampling hemisphere */ register int i; /* set number of divisions */ if (ambacc <= FTINY && - wt > (d = 0.8*bright(ac)*r->rweight/(ambdiv*minweight))) + wt > (d = 0.8*intens(ac)*r->rweight/(ambdiv*minweight))) wt = d; /* avoid ray termination */ hp->nt = sqrt(ambdiv * wt / PI) + 0.5; i = ambacc > FTINY ? 3 : 1; /* minimum number of samples */ @@ -161,22 +161,22 @@ doambient( /* compute ambient component */ AMBSAMP dnew; register AMBSAMP *dp; double arad; - int ndivs; + int divcnt; register int i, j; /* initialize hemisphere */ inithemi(&hemi, acol, r, wt); - ndivs = hemi.nt * hemi.np; + divcnt = hemi.nt * hemi.np; /* initialize */ if (pg != NULL) pg[0] = pg[1] = pg[2] = 0.0; if (dg != NULL) dg[0] = dg[1] = dg[2] = 0.0; setcolor(acol, 0.0, 0.0, 0.0); - if (ndivs == 0) + if (divcnt == 0) return(0.0); /* allocate super-samples */ if (hemi.ns > 0 || pg != NULL || dg != NULL) { - div = (AMBSAMP *)malloc(ndivs*sizeof(AMBSAMP)); + div = (AMBSAMP *)malloc(divcnt*sizeof(AMBSAMP)); if (div == NULL) error(SYSTEM, "out of memory in doambient"); } else @@ -185,6 +185,7 @@ doambient( /* compute ambient component */ arad = 0.0; if ((dp = div) == NULL) dp = &dnew; + divcnt = 0; for (i = 0; i < hemi.nt; i++) for (j = 0; j < hemi.np; j++) { dp->t = i; dp->p = j; @@ -192,22 +193,27 @@ doambient( /* compute ambient component */ dp->r = 0.0; dp->n = 0; if (divsample(dp, &hemi, r) < 0) { - if (div != NULL) dp++; - hemi.ns = 0; /* incomplete sampling */ - pg = dg = NULL; + if (div != NULL) + dp++; continue; } arad += dp->r; + divcnt++; if (div != NULL) dp++; else addcolor(acol, dp->v); } - if (hemi.ns > 0 && arad > FTINY && ndivs/arad < minarad) + if (!divcnt) + return(0.0); /* no samples taken */ + if (divcnt < hemi.nt*hemi.np) { + pg = dg = NULL; /* incomplete sampling */ + hemi.ns = 0; + } else if (arad > FTINY && divcnt/arad < minarad) { hemi.ns = 0; /* close enough */ - else if (hemi.ns > 0) { /* else perform super-sampling */ + } else if (hemi.ns > 0) { /* else perform super-sampling? */ comperrs(div, &hemi); /* compute errors */ - qsort(div, ndivs, sizeof(AMBSAMP), ambcmp); /* sort divs */ + qsort(div, divcnt, sizeof(AMBSAMP), ambcmp); /* sort divs */ /* super-sample */ for (i = hemi.ns; i > 0; i--) { dnew = *div; @@ -216,7 +222,7 @@ doambient( /* compute ambient component */ continue; } dp = div; /* reinsert */ - j = ndivs < i ? ndivs : i; + j = divcnt < i ? divcnt : i; while (--j > 0 && dnew.k < dp[1].k) { *dp = *(dp+1); dp++; @@ -224,12 +230,12 @@ doambient( /* compute ambient component */ *dp = dnew; } if (pg != NULL || dg != NULL) /* restore order */ - qsort(div, ndivs, sizeof(AMBSAMP), ambnorm); + qsort(div, divcnt, sizeof(AMBSAMP), ambnorm); } /* compute returned values */ if (div != NULL) { - arad = 0.0; - for (i = ndivs, dp = div; i-- > 0; dp++) { + arad = 0.0; /* note: divcnt may be < nt*np */ + for (i = hemi.nt*hemi.np, dp = div; i-- > 0; dp++) { arad += dp->r; if (dp->n > 1) { b = 1.0/dp->n; @@ -258,7 +264,7 @@ doambient( /* compute ambient component */ if (arad <= FTINY) arad = maxarad; else - arad = (ndivs+hemi.ns)/arad; + arad = (divcnt+hemi.ns)/arad; if (pg != NULL) { /* reduce radius if gradient large */ d = DOT(pg,pg); if (d*arad*arad > 1.0)
