Minor code improvements/simplifications
Reorganized calculation now storing average division value & min. distance
Switched to old ambient radius modification with weight
Fixed potential issue with small number of samples
Changes to hem-in too-large cache radii with -ar 0
Minor correction to limit on corraling operation (NEWAMB)
Tore out complicated vertex comparisons that were no faster (-DNEWAMB)
Better fix for previous bug and include diagonals in error est. (NEWAMB)
Fixed bug in ambient super-sampling for scenes with uniform areas (NEWAMB)
Fixed problem with too-distant samples and limited corral to 2 bounces (NEWAMB)
Betterment of last tweak (-DNEWAMB)
Another tweak to prevent corraling in tight quarters (-DNEWAMB)
Fixed bug that caused too-long calculations in cache corral (-DNEWAMB)
Changed (unused) algorithm to threshold at 5th percentile instead of average
Switched to storing reciprocal distance so we can optionally check periphery
Added baroque book-keeping to avoid calculating pointless Hessians
Fixed bug introduced in change to support -as option (-DNEWAMB)
Got rid of struct s_ambsamp, which was never really needed, anyway
Simplified hemisphere sampling call (-DNEWAMB)
Minor optimization
Added support for ambient super-samples (-as) in new calculation (-DNEWAMB)
Re-corrected sign of direction gradient calculation
Fixed bug that was causing segmentation violations for all-black scenes
Fixed eigenvalue calculation for double-root and randomization of axes
Went back to old axis initialization method
Randomize hemisphere orientation for better sampling
Eliminated redundant calcs and put limit on radii based on gradient
Very minor tweaks
Reinstated clamping of translation gradient when increasing radius to minimum
Corrected some math so the results are starting to look agreeable
Fixed floating-point errors due to use of float where double needed
Bug fix and optimization
Fixed numerous errors in Hessian (-DNEWAMB) calculation, doubtless more to go
Tidying up code, bug fixes and minor improvements
Partial implementation of Hessian calculation
Fixed memory leak for certain ambient calculations (thanks to D. Brainard)
Changed bright() to intens() in a couple of places for consistency
(Very) minor optimization
Bug fix for -aa 0 -as > 0
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
switched to faster table-lookup for sin() and cos() functions
changed from using effective ray distance to object distance in divsample()
fixed bug in super-sampling test which resulted in unnec. sampling
changed maxarad heuristic limit and overrode super-sampling for ambient values that have radii less than minarad after division sampling
improved gradient estimators
reinstated capping of irradiance gradient
made it so ambient radius reduce when large gradient detected fixed incorrect position gradient calculation
added pretest for sampling limit to inithemi()
made ambient value weighting incremental
corrected division separation between theta and phi
placed upper limit on position gradient
made computations of gradients a little more robust
bug fixes
bug fixes
initial implementation of dirgradient() and posgradient()
