1 |
/* Copyright (c) 1991 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Routines to compute "ambient" values using Monte Carlo |
9 |
10 |
11 |
#include "ray.h" |
12 |
13 |
#include "ambient.h" |
14 |
15 |
#include "random.h" |
16 |
17 |
typedef struct { |
18 |
short t, p; /* theta, phi indices */ |
19 |
COLOR v; /* value sum */ |
20 |
float r; /* 1/distance sum */ |
21 |
float k; /* variance for this division */ |
22 |
int n; /* number of subsamples */ |
23 |
} AMBSAMP; /* ambient sample division */ |
24 |
25 |
typedef struct { |
26 |
FVECT ux, uy, uz; /* x, y and z axis directions */ |
27 |
short nt, np; /* number of theta and phi directions */ |
28 |
} AMBHEMI; /* ambient sample hemisphere */ |
29 |
30 |
extern double sin(), cos(), sqrt(); |
31 |
32 |
33 |
static int |
34 |
ambcmp(d1, d2) /* decreasing order */ |
35 |
AMBSAMP *d1, *d2; |
36 |
37 |
if (d1->k < d2->k) |
38 |
return(1); |
39 |
if (d1->k > d2->k) |
40 |
return(-1); |
41 |
return(0); |
42 |
43 |
44 |
45 |
static int |
46 |
ambnorm(d1, d2) /* standard order */ |
47 |
AMBSAMP *d1, *d2; |
48 |
49 |
register int c; |
50 |
51 |
if (c = d1->t - d2->t) |
52 |
return(c); |
53 |
return(d1->p - d2->p); |
54 |
55 |
56 |
57 |
divsample(dp, h, r) /* sample a division */ |
58 |
register AMBSAMP *dp; |
59 |
AMBHEMI *h; |
60 |
RAY *r; |
61 |
62 |
RAY ar; |
63 |
int hlist[3]; |
64 |
double spt[2]; |
65 |
double xd, yd, zd; |
66 |
double b2; |
67 |
double phi; |
68 |
register int i; |
69 |
70 |
if (rayorigin(&ar, r, AMBIENT, AVGREFL) < 0) |
71 |
return(-1); |
72 |
hlist[0] = r->rno; |
73 |
hlist[1] = dp->t; |
74 |
hlist[2] = dp->p; |
75 |
multisamp(spt, 2, urand(ilhash(hlist,3)+dp->n)); |
76 |
zd = sqrt((dp->t + spt[0])/h->nt); |
77 |
phi = 2.0*PI * (dp->p + spt[1])/h->np; |
78 |
xd = cos(phi) * zd; |
79 |
yd = sin(phi) * zd; |
80 |
zd = sqrt(1.0 - zd*zd); |
81 |
for (i = 0; i < 3; i++) |
82 |
ar.rdir[i] = xd*h->ux[i] + |
83 |
yd*h->uy[i] + |
84 |
zd*h->uz[i]; |
85 |
dimlist[ndims++] = dp->t*h->np + dp->p + 90171; |
86 |
rayvalue(&ar); |
87 |
ndims--; |
88 |
addcolor(dp->v, ar.rcol); |
89 |
if (ar.rt > FTINY && ar.rt < FHUGE) |
90 |
dp->r += 1.0/ar.rt; |
91 |
/* (re)initialize error */ |
92 |
if (dp->n++) { |
93 |
b2 = bright(dp->v)/dp->n - bright(ar.rcol); |
94 |
b2 = b2*b2 + dp->k*((dp->n-1)*(dp->n-1)); |
95 |
dp->k = b2/(dp->n*dp->n); |
96 |
} else |
97 |
dp->k = 0.0; |
98 |
return(0); |
99 |
100 |
101 |
102 |
double |
103 |
doambient(acol, r, wt, pg, dg) /* compute ambient component */ |
104 |
COLOR acol; |
105 |
RAY *r; |
106 |
double wt; |
107 |
FVECT pg, dg; |
108 |
109 |
double b, d; |
110 |
AMBHEMI hemi; |
111 |
AMBSAMP *div; |
112 |
AMBSAMP dnew; |
113 |
114 |
double arad; |
115 |
int ndivs, ns; |
116 |
register int i, j; |
117 |
/* initialize color */ |
118 |
setcolor(acol, 0.0, 0.0, 0.0); |
119 |
/* initialize hemisphere */ |
120 |
inithemi(&hemi, r, wt); |
121 |
ndivs = hemi.nt * hemi.np; |
122 |
if (ndivs == 0) |
123 |
return(0.0); |
124 |
/* set number of super-samples */ |
125 |
ns = ambssamp * wt + 0.5; |
126 |
if (ns > 0 || pg != NULL || dg != NULL) { |
127 |
div = (AMBSAMP *)malloc(ndivs*sizeof(AMBSAMP)); |
128 |
if (div == NULL) |
129 |
error(SYSTEM, "out of memory in doambient"); |
130 |
} else |
131 |
div = NULL; |
132 |
/* sample the divisions */ |
133 |
arad = 0.0; |
134 |
if ((dp = div) == NULL) |
135 |
dp = &dnew; |
136 |
for (i = 0; i < hemi.nt; i++) |
137 |
for (j = 0; j < hemi.np; j++) { |
138 |
dp->t = i; dp->p = j; |
139 |
setcolor(dp->v, 0.0, 0.0, 0.0); |
140 |
dp->r = 0.0; |
141 |
dp->n = 0; |
142 |
if (divsample(dp, &hemi, r) < 0) |
143 |
goto oopsy; |
144 |
if (div != NULL) |
145 |
dp++; |
146 |
else { |
147 |
addcolor(acol, dp->v); |
148 |
arad += dp->r; |
149 |
150 |
151 |
if (ns > 0) { /* perform super-sampling */ |
152 |
comperrs(div, &hemi); /* compute errors */ |
153 |
qsort(div, ndivs, sizeof(AMBSAMP), ambcmp); /* sort divs */ |
154 |
/* super-sample */ |
155 |
for (i = ns; i > 0; i--) { |
156 |
copystruct(&dnew, div); |
157 |
if (divsample(&dnew, &hemi, r) < 0) |
158 |
goto oopsy; |
159 |
/* reinsert */ |
160 |
dp = div; |
161 |
j = ndivs < i ? ndivs : i; |
162 |
while (--j > 0 && dnew.k < dp[1].k) { |
163 |
copystruct(dp, dp+1); |
164 |
dp++; |
165 |
166 |
copystruct(dp, &dnew); |
167 |
168 |
if (pg != NULL || dg != NULL) /* restore order */ |
169 |
qsort(div, ndivs, sizeof(AMBSAMP), ambnorm); |
170 |
171 |
/* compute returned values */ |
172 |
if (div != NULL) { |
173 |
for (i = ndivs, dp = div; i-- > 0; dp++) { |
174 |
arad += dp->r; |
175 |
if (dp->n > 1) { |
176 |
b = 1.0/dp->n; |
177 |
scalecolor(dp->v, b); |
178 |
dp->r *= b; |
179 |
dp->n = 1; |
180 |
181 |
182 |
183 |
b = bright(acol); |
184 |
if (b > FTINY) { |
185 |
b = ndivs/b; |
186 |
if (pg != NULL) { |
187 |
posgradient(pg, div, &hemi); |
188 |
189 |
pg[i] *= b; |
190 |
191 |
if (dg != NULL) { |
192 |
dirgradient(dg, div, &hemi); |
193 |
194 |
dg[i] *= b; |
195 |
196 |
} else { |
197 |
if (pg != NULL) |
198 |
199 |
pg[i] = 0.0; |
200 |
if (dg != NULL) |
201 |
202 |
dg[i] = 0.0; |
203 |
204 |
free((char *)div); |
205 |
206 |
b = 1.0/ndivs; |
207 |
scalecolor(acol, b); |
208 |
if (arad <= FTINY) |
209 |
arad = maxarad; |
210 |
else { |
211 |
arad = (ndivs+ns)/arad; |
212 |
if (arad > maxarad) |
213 |
arad = maxarad; |
214 |
215 |
if (pg != NULL) { /* reduce radius if gradient large */ |
216 |
d = DOT(pg,pg); |
217 |
if (d*arad*arad > 1.0) |
218 |
arad = 1.0/sqrt(d); |
219 |
220 |
if (arad < minarad) { |
221 |
arad = minarad; |
222 |
if (pg != NULL && d*arad*arad > 1.0) { /* cap gradient */ |
223 |
d = 1.0/arad/sqrt(d); |
224 |
225 |
pg[i] *= d; |
226 |
227 |
228 |
return(arad/sqrt(wt)); |
229 |
oopsy: |
230 |
if (div != NULL) |
231 |
232 |
return(0.0); |
233 |
234 |
235 |
236 |
inithemi(hp, r, wt) /* initialize sampling hemisphere */ |
237 |
register AMBHEMI *hp; |
238 |
RAY *r; |
239 |
double wt; |
240 |
241 |
register int i; |
242 |
/* set number of divisions */ |
243 |
if (wt < (.25*PI)/ambdiv+FTINY) { |
244 |
hp->nt = hp->np = 0; |
245 |
return; /* zero samples */ |
246 |
247 |
hp->nt = sqrt(ambdiv * wt / PI) + 0.5; |
248 |
hp->np = PI * hp->nt + 0.5; |
249 |
/* make axes */ |
250 |
VCOPY(hp->uz, r->ron); |
251 |
hp->uy[0] = hp->uy[1] = hp->uy[2] = 0.0; |
252 |
253 |
if (hp->uz[i] < 0.6 && hp->uz[i] > -0.6) |
254 |
break; |
255 |
if (i >= 3) |
256 |
error(CONSISTENCY, "bad ray direction in inithemi"); |
257 |
hp->uy[i] = 1.0; |
258 |
fcross(hp->ux, hp->uy, hp->uz); |
259 |
normalize(hp->ux); |
260 |
fcross(hp->uy, hp->uz, hp->ux); |
261 |
262 |
263 |
264 |
comperrs(da, hp) /* compute initial error estimates */ |
265 |
AMBSAMP *da; /* assumes standard ordering */ |
266 |
267 |
268 |
double b, b2; |
269 |
int i, j; |
270 |
271 |
/* sum differences from neighbors */ |
272 |
dp = da; |
273 |
for (i = 0; i < hp->nt; i++) |
274 |
for (j = 0; j < hp->np; j++) { |
275 |
#ifdef DEBUG |
276 |
if (dp->t != i || dp->p != j) |
277 |
error(CONSISTENCY, |
278 |
"division order in comperrs"); |
279 |
#endif |
280 |
b = bright(dp[0].v); |
281 |
if (i > 0) { /* from above */ |
282 |
b2 = bright(dp[-hp->np].v) - b; |
283 |
b2 *= b2 * 0.25; |
284 |
dp[0].k += b2; |
285 |
dp[-hp->np].k += b2; |
286 |
287 |
if (j > 0) { /* from behind */ |
288 |
b2 = bright(dp[-1].v) - b; |
289 |
b2 *= b2 * 0.25; |
290 |
dp[0].k += b2; |
291 |
dp[-1].k += b2; |
292 |
} else { /* around */ |
293 |
b2 = bright(dp[hp->np-1].v) - b; |
294 |
b2 *= b2 * 0.25; |
295 |
dp[0].k += b2; |
296 |
dp[hp->np-1].k += b2; |
297 |
298 |
dp++; |
299 |
300 |
/* divide by number of neighbors */ |
301 |
dp = da; |
302 |
for (j = 0; j < hp->np; j++) /* top row */ |
303 |
(dp++)->k *= 1.0/3.0; |
304 |
if (hp->nt < 2) |
305 |
return; |
306 |
for (i = 1; i < hp->nt-1; i++) /* central region */ |
307 |
for (j = 0; j < hp->np; j++) |
308 |
(dp++)->k *= 0.25; |
309 |
for (j = 0; j < hp->np; j++) /* bottom row */ |
310 |
311 |
312 |
313 |
314 |
posgradient(gv, da, hp) /* compute position gradient */ |
315 |
FVECT gv; |
316 |
317 |
318 |
319 |
320 |
double nextsine, lastsine, b, d; |
321 |
double mag0, mag1; |
322 |
double phi, cosp, sinp, xd, yd; |
323 |
324 |
325 |
xd = yd = 0.0; |
326 |
327 |
dp = da + j; |
328 |
mag0 = mag1 = 0.0; |
329 |
lastsine = 0.0; |
330 |
for (i = 0; i < hp->nt; i++) { |
331 |
#ifdef DEBUG |
332 |
333 |
334 |
"division order in posgradient"); |
335 |
#endif |
336 |
b = bright(dp->v); |
337 |
if (i > 0) { |
338 |
d = dp[-hp->np].r; |
339 |
if (dp[0].r > d) d = dp[0].r; |
340 |
/* sin(t)*cos(t)^2 */ |
341 |
d *= lastsine * (1.0 - (double)i/hp->nt); |
342 |
mag0 += d*(b - bright(dp[-hp->np].v)); |
343 |
344 |
nextsine = sqrt((double)(i+1)/hp->nt); |
345 |
if (j > 0) { |
346 |
d = dp[-1].r; |
347 |
348 |
mag1 += d * (nextsine - lastsine) * |
349 |
(b - bright(dp[-1].v)); |
350 |
} else { |
351 |
d = dp[hp->np-1].r; |
352 |
353 |
354 |
(b - bright(dp[hp->np-1].v)); |
355 |
356 |
dp += hp->np; |
357 |
lastsine = nextsine; |
358 |
359 |
mag0 *= 2.0*PI / hp->np; |
360 |
phi = 2.0*PI * (double)j/hp->np; |
361 |
cosp = cos(phi); sinp = sin(phi); |
362 |
xd += mag0*cosp - mag1*sinp; |
363 |
yd += mag0*sinp + mag1*cosp; |
364 |
365 |
366 |
gv[i] = (xd*hp->ux[i] + yd*hp->uy[i])/PI; |
367 |
368 |
369 |
370 |
dirgradient(gv, da, hp) /* compute direction gradient */ |
371 |
FVECT gv; |
372 |
373 |
374 |
375 |
376 |
double mag; |
377 |
double phi, xd, yd; |
378 |
379 |
380 |
xd = yd = 0.0; |
381 |
382 |
dp = da + j; |
383 |
mag = 0.0; |
384 |
385 |
#ifdef DEBUG |
386 |
387 |
388 |
"division order in dirgradient"); |
389 |
#endif |
390 |
/* tan(t) */ |
391 |
mag += bright(dp->v)/sqrt(hp->nt/(i+.5) - 1.0); |
392 |
dp += hp->np; |
393 |
394 |
phi = 2.0*PI * (j+.5)/hp->np + PI/2.0; |
395 |
xd += mag * cos(phi); |
396 |
yd += mag * sin(phi); |
397 |
398 |
399 |
gv[i] = (xd*hp->ux[i] + yd*hp->uy[i])/(hp->nt*hp->np); |
400 |
