(Very) minor optimization
Bug fix for -aa 0 -as > 0
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
switched to faster table-lookup for sin() and cos() functions
changed from using effective ray distance to object distance in divsample()
fixed bug in super-sampling test which resulted in unnec. sampling
changed maxarad heuristic limit and overrode super-sampling for ambient values that have radii less than minarad after division sampling
improved gradient estimators
reinstated capping of irradiance gradient
made it so ambient radius reduce when large gradient detected fixed incorrect position gradient calculation
added pretest for sampling limit to inithemi()
made ambient value weighting incremental
corrected division separation between theta and phi
placed upper limit on position gradient
made computations of gradients a little more robust
bug fixes
bug fixes
initial implementation of dirgradient() and posgradient()
