--- ray/src/rt/ambcomp.c 1991/06/07 10:03:52 1.1 +++ ray/src/rt/ambcomp.c 1991/06/13 10:54:00 1.6 @@ -17,9 +17,10 @@ static char SCCSid[] = "$SunId$ LBL"; typedef struct { short t, p; /* theta, phi indices */ COLOR v; /* value sum */ - float k; /* error contribution for this division */ + float r; /* 1/distance sum */ + float k; /* variance for this division */ int n; /* number of subsamples */ -} AMBSAMP; /* ambient division sample */ +} AMBSAMP; /* ambient sample division */ typedef struct { FVECT ux, uy, uz; /* x, y and z axis directions */ @@ -53,7 +54,6 @@ AMBSAMP *d1, *d2; } -static double divsample(dp, h, r) /* sample a division */ register AMBSAMP *dp; AMBHEMI *h; @@ -64,10 +64,10 @@ RAY *r; double xd, yd, zd; double b2; double phi; - register int k; + register int i; if (rayorigin(&ar, r, AMBIENT, 0.5) < 0) - return(0.0); + return(-1); hlist[0] = r->rno; hlist[1] = dp->t; hlist[2] = dp->p; @@ -78,14 +78,16 @@ RAY *r; xd = cos(phi) * zd; yd = sin(phi) * zd; zd = sqrt(1.0 - zd*zd); - for (k = 0; k < 3; k++) - ar.rdir[k] = xd*h->ux[k] + - yd*h->uy[k] + - zd*h->uz[k]; - dimlist[ndims++] = dp->t*h->np + dp->p + 38813; + for (i = 0; i < 3; i++) + ar.rdir[i] = xd*h->ux[i] + + yd*h->uy[i] + + zd*h->uz[i]; + dimlist[ndims++] = dp->t*h->np + dp->p + 90171; rayvalue(&ar); ndims--; addcolor(dp->v, ar.rcol); + if (ar.rt < FHUGE) + dp->r += 1.0/ar.rt; /* (re)initialize error */ if (dp->n++) { b2 = bright(dp->v)/dp->n - bright(ar.rcol); @@ -93,7 +95,7 @@ RAY *r; dp->k = b2/(dp->n*dp->n); } else dp->k = 0.0; - return(ar.rot); + return(0); } @@ -134,31 +136,25 @@ FVECT pg, dg; for (j = 0; j < hemi.np; j++) { dp->t = i; dp->p = j; setcolor(dp->v, 0.0, 0.0, 0.0); + dp->r = 0.0; dp->n = 0; - if ((d = divsample(dp, &hemi, r)) == 0.0) + if (divsample(dp, &hemi, r) < 0) goto oopsy; - if (d < FHUGE) - arad += 1.0 / d; if (div != NULL) dp++; - else + else { addcolor(acol, dp->v); + arad += dp->r; + } } if (ns > 0) { /* perform super-sampling */ - comperrs(div, hemi); /* compute errors */ + comperrs(div, &hemi); /* compute errors */ qsort(div, ndivs, sizeof(AMBSAMP), ambcmp); /* sort divs */ - dp = div + ndivs; /* skim excess */ - for (i = ndivs; i > ns; i--) { - dp--; - addcolor(acol, dp->v); - } /* super-sample */ for (i = ns; i > 0; i--) { copystruct(&dnew, div); - if ((d = divsample(&dnew, &hemi)) == 0.0) + if (divsample(&dnew, &hemi, r) < 0) goto oopsy; - if (d < FHUGE) - arad += 1.0 / d; /* reinsert */ dp = div; j = ndivs < i ? ndivs : i; @@ -167,27 +163,45 @@ FVECT pg, dg; dp++; } copystruct(dp, &dnew); - /* extract darkest */ - if (i <= ndivs) { - dp = div + i-1; - if (dp->n > 1) { - b = 1.0/dp->n; - scalecolor(dp->v, b); - dp->n = 1; - } - addcolor(acol, dp->v); - } } - if (pg != NULL || dg != NULL) /* reorder */ + if (pg != NULL || dg != NULL) /* restore order */ qsort(div, ndivs, sizeof(AMBSAMP), ambnorm); } /* compute returned values */ - if (pg != NULL) - posgradient(pg, div, &hemi); - if (dg != NULL) - dirgradient(dg, div, &hemi); - if (div != NULL) + if (div != NULL) { + for (i = ndivs, dp = div; i-- > 0; dp++) { + arad += dp->r; + if (dp->n > 1) { + b = 1.0/dp->n; + scalecolor(dp->v, b); + dp->r *= b; + dp->n = 1; + } + addcolor(acol, dp->v); + } + b = bright(acol); + if (b > FTINY) { + b = ndivs/b; + if (pg != NULL) { + posgradient(pg, div, &hemi); + for (i = 0; i < 3; i++) + pg[i] *= b; + } + if (dg != NULL) { + dirgradient(dg, div, &hemi); + for (i = 0; i < 3; i++) + dg[i] *= b; + } + } else { + if (pg != NULL) + for (i = 0; i < 3; i++) + pg[i] = 0.0; + if (dg != NULL) + for (i = 0; i < 3; i++) + dg[i] = 0.0; + } free((char *)div); + } b = 1.0/ndivs; scalecolor(acol, b); if (arad <= FTINY) @@ -211,27 +225,27 @@ inithemi(hp, r) /* initialize sampling hemisphere */ register AMBHEMI *hp; RAY *r; { - register int k; + register int i; /* set number of divisions */ hp->nt = sqrt(ambdiv * r->rweight * 0.5) + 0.5; hp->np = 2 * hp->nt; /* make axes */ VCOPY(hp->uz, r->ron); hp->uy[0] = hp->uy[1] = hp->uy[2] = 0.0; - for (k = 0; k < 3; k++) - if (hp->uz[k] < 0.6 && hp->uz[k] > -0.6) + for (i = 0; i < 3; i++) + if (hp->uz[i] < 0.6 && hp->uz[i] > -0.6) break; - if (k >= 3) + if (i >= 3) error(CONSISTENCY, "bad ray direction in inithemi"); - hp->uy[k] = 1.0; - fcross(hp->ux, hp->uz, hp->uy); + hp->uy[i] = 1.0; + fcross(hp->ux, hp->uy, hp->uz); normalize(hp->ux); - fcross(hp->uy, hp->ux, hp->uz); + fcross(hp->uy, hp->uz, hp->ux); } comperrs(da, hp) /* compute initial error estimates */ -AMBSAMP *da; +AMBSAMP *da; /* assumes standard ordering */ register AMBHEMI *hp; { double b, b2; @@ -241,6 +255,11 @@ register AMBHEMI *hp; dp = da; for (i = 0; i < hp->nt; i++) for (j = 0; j < hp->np; j++) { +#ifdef DEBUG + if (dp->t != i || dp->p != j) + error(CONSISTENCY, + "division order in comperrs"); +#endif b = bright(dp[0].v); if (i > 0) { /* from above */ b2 = bright(dp[-hp->np].v) - b; @@ -253,12 +272,11 @@ register AMBHEMI *hp; b2 *= b2 * 0.25; dp[0].k += b2; dp[-1].k += b2; - } - if (j == hp->np-1) { /* around */ - b2 = bright(dp[-(hp->np-1)].v) - b; + } else { /* around */ + b2 = bright(dp[hp->np-1].v) - b; b2 *= b2 * 0.25; dp[0].k += b2; - dp[-(hp->np-1)].k += b2; + dp[hp->np-1].k += b2; } dp++; } @@ -278,17 +296,84 @@ register AMBHEMI *hp; posgradient(gv, da, hp) /* compute position gradient */ FVECT gv; -AMBSAMP *da; +AMBSAMP *da; /* assumes standard ordering */ AMBHEMI *hp; { - gv[0] = 0.0; gv[1] = 0.0; gv[2] = 0.0; + register int i, j; + double b, d; + double mag0, mag1; + double phi, cosp, sinp, xd, yd; + register AMBSAMP *dp; + + xd = yd = 0.0; + for (j = 0; j < hp->np; j++) { + dp = da + j; + mag0 = mag1 = 0.0; + for (i = 0; i < hp->nt; i++) { +#ifdef DEBUG + if (dp->t != i || dp->p != j) + error(CONSISTENCY, + "division order in posgradient"); +#endif + b = bright(dp->v); + if (i > 0) { + d = dp[-hp->np].r; + if (dp[0].r > d) d = dp[0].r; + d *= 1.0 - sqrt((double)i/hp->nt); + mag0 += d*(b - bright(dp[-hp->np].v)); + } + if (j > 0) { + d = dp[-1].r; + if (dp[0].r > d) d = dp[0].r; + mag1 += d*(b - bright(dp[-1].v)); + } else { + d = dp[hp->np-1].r; + if (dp[0].r > d) d = dp[0].r; + mag1 += d*(b - bright(dp[hp->np-1].v)); + } + dp += hp->np; + } + if (hp->nt > 1) { + mag0 /= (double)hp->np; + mag1 /= (double)hp->nt; + } + phi = 2.0*PI * (double)j/hp->np; + cosp = cos(phi); sinp = sin(phi); + xd += mag0*cosp - mag1*sinp; + yd += mag0*sinp + mag1*cosp; + } + for (i = 0; i < 3; i++) + gv[i] = (xd*hp->ux[i] + yd*hp->uy[i])/PI; } dirgradient(gv, da, hp) /* compute direction gradient */ FVECT gv; -AMBSAMP *da; +AMBSAMP *da; /* assumes standard ordering */ AMBHEMI *hp; { - gv[0] = 0.0; gv[1] = 0.0; gv[2] = 0.0; + register int i, j; + double mag; + double phi, xd, yd; + register AMBSAMP *dp; + + xd = yd = 0.0; + for (j = 0; j < hp->np; j++) { + dp = da + j; + mag = 0.0; + for (i = 0; i < hp->nt; i++) { +#ifdef DEBUG + if (dp->t != i || dp->p != j) + error(CONSISTENCY, + "division order in dirgradient"); +#endif + mag += sqrt((i+.5)/hp->nt)*bright(dp->v); + dp += hp->np; + } + phi = 2.0*PI * (j+.5)/hp->np + PI/2.0; + xd += mag * cos(phi); + yd += mag * sin(phi); + } + for (i = 0; i < 3; i++) + gv[i] = (xd*hp->ux[i] + yd*hp->uy[i])*PI/(hp->nt*hp->np); }
