root/radiance/ray/src/rt/ambcomp.c
Sun Jul 27 22:12:03 2003 UTC (21 years, 9 months ago) by schorsch
Mon Jul 21 22:30:19 2003 UTC (21 years, 9 months ago) by schorsch
Tue Feb 25 02:47:22 2003 UTC (22 years, 2 months ago) by greg
Sat Feb 22 02:07:28 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.8: +70 -22 lines
Wed Dec 16 18:14:57 1998 UTC (26 years, 4 months ago) by gwlarson
Changes since 2.7: +7 -7 lines
switched to faster table-lookup for sin() and cos() functions
Wed Jun 24 09:35:00 1998 UTC (26 years, 10 months ago) by gwlarson
changed from using effective ray distance to object distance in divsample()
Tue Apr 23 11:06:54 1996 UTC (29 years ago) by greg
fixed bug in super-sampling test which resulted in unnec. sampling
Wed May 3 09:46:31 1995 UTC (30 years ago) by greg
Fri Oct 2 16:14:38 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.3: +0 -2 lines
Wed Mar 4 16:28:25 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.2: +4 -5 lines
Wed Feb 19 12:00:04 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.1: +16 -12 lines
improved gradient estimators
Tue Nov 12 17:10:29 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.16 , to selected 2.10
Mon Nov 4 11:14:46 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.15: +12 -5 lines
Diff to previous 1.15 , to selected 2.10
reinstated capping of irradiance gradient
Tue Oct 22 12:15:41 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.14: +8 -12 lines
Diff to previous 1.14 , to selected 2.10
made it so ambient radius reduce when large gradient detected
fixed incorrect position gradient calculation
Mon Aug 26 10:11:39 1991 UTC (33 years, 8 months ago) by greg
Diff to previous 1.13 , to selected 2.10
added pretest for sampling limit to inithemi()
Thu Aug 22 11:56:58 1991 UTC (33 years, 8 months ago) by greg
Diff to previous 1.12 , to selected 2.10
Tue Aug 20 13:32:51 1991 UTC (33 years, 8 months ago) by greg
Changes since 1.11: +9 -7 lines
Diff to previous 1.11 , to selected 2.10
made ambient value weighting incremental
Tue Aug 13 12:16:41 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.10 , to selected 2.10
Wed Jul 24 10:36:13 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.9 , to selected 2.10
corrected division separation between theta and phi
Thu Jul 11 16:39:00 1991 UTC (33 years, 10 months ago) by greg
Diff to previous 1.8 , to selected 2.10
Thu Jun 13 13:58:24 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.7 , to selected 2.10
Thu Jun 13 12:00:29 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.6: +8 -0 lines
Diff to previous 1.6 , to selected 2.10
placed upper limit on position gradient
Thu Jun 13 10:54:00 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.5: +23 -12 lines
Diff to previous 1.5 , to selected 2.10
made computations of gradients a little more robust
Thu Jun 13 09:41:17 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.4: +15 -4 lines
Diff to previous 1.4 , to selected 2.10
Tue Jun 11 16:37:49 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.3: +12 -16 lines
Diff to previous 1.3 , to selected 2.10
bug fixes
Fri Jun 7 17:08:34 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.2: +19 -26 lines
Diff to previous 1.2 , to selected 2.10
bug fixes
Fri Jun 7 13:43:05 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.1: +97 -23 lines
Diff to previous 1.1 , to selected 2.10
initial implementation of dirgradient() and posgradient()
Fri Jun 7 10:03:52 1991 UTC (33 years, 11 months ago) by greg
Diff to selected 2.10
