root/radiance/ray/src/rt/ambcomp.c
Revision: 2.26
Committed: Wed Apr 16 20:32:00 2014 UTC (11 years ago) by greg
Changes since 2.25: +199 -1 lines
Partial implementation of Hessian calculation
2 static const char RCSid[] = "$Id: ambcomp.c,v 2.25 2014/04/11 20:31:37 greg Exp $";
5 * Routines to compute "ambient" values using Monte Carlo
6 *
7 * Declarations of external symbols in ambient.h
8 */
9
10 #include "copyright.h"
11
12 #include "ray.h"
13 #include "ambient.h"
14 #include "random.h"
15
16 #ifdef NEWAMB
17
18 extern void SDsquare2disk(double ds[2], double seedx, double seedy);
19
20 typedef struct {
21 RAY *rp; /* originating ray sample */
22 FVECT ux, uy; /* tangent axis directions */
23 int ns; /* number of samples per axis */
24 COLOR acoef; /* division contribution coefficient */
25 struct s_ambsamp {
26 COLOR v; /* hemisphere sample value */
27 float p[3]; /* intersection point */
28 } sa[1]; /* sample array (extends struct) */
29 } AMBHEMI; /* ambient sample hemisphere */
30
31 #define ambsamp(h,i,j) (h)->sa[(i)*(h)->ns + (j)]
32
33
34 static AMBHEMI *
35 inithemi( /* initialize sampling hemisphere */
36 COLOR ac,
37 RAY *r,
38 double wt
39 )
40 {
41 AMBHEMI *hp;
42 double d;
43 int n, i;
44 /* set number of divisions */
45 if (ambacc <= FTINY &&
46 wt > (d = 0.8*intens(ac)*r->rweight/(ambdiv*minweight)))
47 wt = d; /* avoid ray termination */
48 n = sqrt(ambdiv * wt) + 0.5;
49 i = 1 + 4*(ambacc > FTINY); /* minimum number of samples */
50 if (n < i)
51 n = i;
52 /* allocate sampling array */
53 hp = (AMBHEMI *)malloc(sizeof(AMBHEMI) +
54 sizeof(struct s_ambsamp)*(n*n - 1));
55 if (hp == NULL)
56 return(NULL);
57 hp->rp = r;
58 hp->ns = n;
59 /* assign coefficient */
60 copycolor(hp->acoef, ac);
61 d = 1.0/(n*n);
62 scalecolor(hp->acoef, d);
63 /* make tangent axes */
64 hp->uy[0] = hp->uy[1] = hp->uy[2] = 0.0;
65 for (i = 0; i < 3; i++)
66 if (r->rn[i] < 0.6 && r->rn[i] > -0.6)
67 break;
68 if (i >= 3)
69 error(CONSISTENCY, "bad ray direction in inithemi()");
70 hp->uy[i] = 1.0;
71 VCROSS(hp->ux, hp->uy, r->rn);
72 normalize(hp->ux);
73 VCROSS(hp->uy, r->rn, hp->ux);
74 /* we're ready to sample */
75 return(hp);
76 }
77
78
79 static int
80 ambsample( /* sample an ambient direction */
81 AMBHEMI *hp,
82 int i,
83 int j,
84 )
85 {
86 struct s_ambsamp *ap = &ambsamp(hp,i,j);
87 RAY ar;
88 int hlist[3];
89 double spt[2], dz;
90 int ii;
91 /* ambient coefficient for weight */
92 if (ambacc > FTINY)
93 setcolor(ar.rcoef, AVGREFL, AVGREFL, AVGREFL);
94 else
95 copycolor(ar.rcoef, hp->acoef);
96 if (rayorigin(&ar, AMBIENT, hp->rp, ar.rcoef) < 0) {
97 setcolor(ap->v, 0., 0., 0.);
98 ap->r = 0.;
99 return(0); /* no sample taken */
100 }
101 if (ambacc > FTINY) {
102 multcolor(ar.rcoef, hp->acoef);
103 scalecolor(ar.rcoef, 1./AVGREFL);
104 }
105 /* generate hemispherical sample */
106 SDsquare2disk(spt, (i+frandom())/hp->ns, (j+frandom())/hp->ns);
107 zd = sqrt(1. - spt[0]*spt[0] - spt[1]*spt[1]);
108 for (ii = 3; ii--; )
109 ar.rdir[ii] = spt[0]*hp->ux[ii] +
110 spt[1]*hp->uy[ii] +
111 zd*hp->rp->ron[ii];
112 checknorm(ar.rdir);
113 dimlist[ndims++] = i*hp->ns + j + 90171;
114 rayvalue(&ar); /* evaluate ray */
115 ndims--;
116 multcolor(ar.rcol, ar.rcoef); /* apply coefficient */
117 copycolor(ap->v, ar.rcol);
118 if (ar.rt > 20.0*maxarad) /* limit vertex distance */
119 ar.rt = 20.0*maxarad;
120 VSUM(ap->p, ar.rorg, ar.rdir, ar.rt);
121 return(1);
122 }
123
124
125 static void
126 ambHessian( /* anisotropic radii & pos. gradient */
127 AMBHEMI *hp,
128 FVECT uv[2], /* returned */
129 float ra[2], /* returned */
130 float pg[2] /* returned */
131 )
132 {
133 if (ra != NULL) { /* compute Hessian-derived radii */
134 } else { /* else copy original tangent axes */
135 VCOPY(uv[0], hp->ux);
136 VCOPY(uv[1], hp->uy);
137 }
138 if (pg == NULL) /* no position gradient requested? */
139 return;
140 }
141
142 int
143 doambient( /* compute ambient component */
144 COLOR rcol, /* input/output color */
145 RAY *r,
146 double wt,
147 FVECT uv[2], /* returned */
148 float ra[2], /* returned */
149 float pg[2], /* returned */
150 float dg[2] /* returned */
151 )
152 {
153 int cnt = 0;
154 FVECT my_uv[2];
155 AMBHEMI *hp;
156 double d, acol[3];
157 struct s_ambsamp *ap;
158 int i, j;
159 /* initialize */
160 if ((hp = inithemi(rcol, r, wt)) == NULL)
161 return(0);
162 if (uv != NULL)
163 memset(uv, 0, sizeof(FVECT)*2);
164 if (ra != NULL)
165 ra[0] = ra[1] = 0.0;
166 if (pg != NULL)
167 pg[0] = pg[1] = 0.0;
168 if (dg != NULL)
169 dg[0] = dg[1] = 0.0;
170 /* sample the hemisphere */
171 acol[0] = acol[1] = acol[2] = 0.0;
172 for (i = hemi.ns; i--; )
173 for (j = hemi.ns; j--; )
174 if (ambsample(hp, i, j)) {
175 ap = &ambsamp(hp,i,j);
176 addcolor(acol, ap->v);
177 ++cnt;
178 }
179 if (!cnt) {
180 setcolor(rcol, 0.0, 0.0, 0.0);
181 free(hp);
182 return(0); /* no valid samples */
183 }
184 d = 1.0 / cnt; /* final indirect irradiance/PI */
185 acol[0] *= d; acol[1] *= d; acol[2] *= d;
186 copycolor(rcol, acol);
187 if (cnt < hp->ns*hp->ns || /* incomplete sampling? */
188 (ra == NULL) & (pg == NULL) & (dg == NULL)) {
189 free(hp);
190 return(-1); /* no radius or gradient calc. */
191 }
192 d = 0.01 * bright(rcol); /* add in 1% before Hessian comp. */
193 if (d < FTINY) d = FTINY;
194 ap = hp->sa; /* using Y channel from here on... */
195 for (i = hp->ns*hp->ns; i--; ap++)
196 colval(ap->v,CIEY) = bright(ap->v) + d;
197
198 if (uv == NULL) /* make sure we have axis pointers */
199 uv = my_uv;
200 /* compute radii & pos. gradient */
201 ambHessian(hp, uv, ra, pg);
202 if (dg != NULL) /* compute direction gradient */
203 ambdirgrad(hp, uv, dg);
204 if (ra != NULL) { /* adjust/clamp radii */
205 d = pow(wt, -0.25);
206 if ((ra[0] *= d) > maxarad)
207 ra[0] = maxarad;
208 if ((ra[1] *= d) > 2.0*ra[0])
209 ra[1] = 2.0*ra[0];
210 }
211 free(hp); /* clean up and return */
212 return(1);
213 }
214
215
216 #else /* ! NEWAMB */
217
218
219 void
220 inithemi( /* initialize sampling hemisphere */
221 AMBHEMI *hp,
222 COLOR ac,
223 RAY *r,
224 double wt
225 )
226 {
227 double d;
228 int i;
229 /* set number of divisions */
230 if (ambacc <= FTINY &&
231 wt > (d = 0.8*intens(ac)*r->rweight/(ambdiv*minweight)))
232 wt = d; /* avoid ray termination */
233 hp->nt = sqrt(ambdiv * wt / PI) + 0.5;
234 i = ambacc > FTINY ? 3 : 1; /* minimum number of samples */
235 if (hp->nt < i)
236 hp->nt = i;
237 hp->np = PI * hp->nt + 0.5;
238 /* set number of super-samples */
239 hp->ns = ambssamp * wt + 0.5;
240 /* assign coefficient */
241 copycolor(hp->acoef, ac);
242 d = 1.0/(hp->nt*hp->np);
243 scalecolor(hp->acoef, d);
244 /* make axes */
245 VCOPY(hp->uz, r->ron);
246 hp->uy[0] = hp->uy[1] = hp->uy[2] = 0.0;
247 for (i = 0; i < 3; i++)
248 if (hp->uz[i] < 0.6 && hp->uz[i] > -0.6)
249 break;
250 if (i >= 3)
251 error(CONSISTENCY, "bad ray direction in inithemi");
252 hp->uy[i] = 1.0;
253 fcross(hp->ux, hp->uy, hp->uz);
254 normalize(hp->ux);
255 fcross(hp->uy, hp->uz, hp->ux);
256 }
257
258
259 int
260 divsample( /* sample a division */
261 AMBSAMP *dp,
262 AMBHEMI *h,
263 RAY *r
264 )
265 {
266 RAY ar;
267 int hlist[3];
268 double spt[2];
269 double xd, yd, zd;
270 double b2;
271 double phi;
272 int i;
273 /* ambient coefficient for weight */
274 if (ambacc > FTINY)
275 setcolor(ar.rcoef, AVGREFL, AVGREFL, AVGREFL);
276 else
277 copycolor(ar.rcoef, h->acoef);
278 if (rayorigin(&ar, AMBIENT, r, ar.rcoef) < 0)
279 return(-1);
280 if (ambacc > FTINY) {
281 multcolor(ar.rcoef, h->acoef);
282 scalecolor(ar.rcoef, 1./AVGREFL);
283 }
284 hlist[0] = r->rno;
285 hlist[1] = dp->t;
286 hlist[2] = dp->p;
287 multisamp(spt, 2, urand(ilhash(hlist,3)+dp->n));
288 zd = sqrt((dp->t + spt[0])/h->nt);
289 phi = 2.0*PI * (dp->p + spt[1])/h->np;
290 xd = tcos(phi) * zd;
291 yd = tsin(phi) * zd;
292 zd = sqrt(1.0 - zd*zd);
293 for (i = 0; i < 3; i++)
294 ar.rdir[i] = xd*h->ux[i] +
295 yd*h->uy[i] +
296 zd*h->uz[i];
297 checknorm(ar.rdir);
298 dimlist[ndims++] = dp->t*h->np + dp->p + 90171;
299 rayvalue(&ar);
300 ndims--;
301 multcolor(ar.rcol, ar.rcoef); /* apply coefficient */
302 addcolor(dp->v, ar.rcol);
303 /* use rt to improve gradient calc */
304 if (ar.rt > FTINY && ar.rt < FHUGE)
305 dp->r += 1.0/ar.rt;
306 /* (re)initialize error */
307 if (dp->n++) {
308 b2 = bright(dp->v)/dp->n - bright(ar.rcol);
309 b2 = b2*b2 + dp->k*((dp->n-1)*(dp->n-1));
310 dp->k = b2/(dp->n*dp->n);
311 } else
312 dp->k = 0.0;
313 return(0);
314 }
315
316
317 static int
318 ambcmp( /* decreasing order */
319 const void *p1,
320 const void *p2
321 )
322 {
323 const AMBSAMP *d1 = (const AMBSAMP *)p1;
324 const AMBSAMP *d2 = (const AMBSAMP *)p2;
325
326 if (d1->k < d2->k)
327 return(1);
328 if (d1->k > d2->k)
329 return(-1);
330 return(0);
331 }
332
333
334 static int
335 ambnorm( /* standard order */
336 const void *p1,
337 const void *p2
338 )
339 {
340 const AMBSAMP *d1 = (const AMBSAMP *)p1;
341 const AMBSAMP *d2 = (const AMBSAMP *)p2;
342 int c;
343
344 if ( (c = d1->t - d2->t) )
345 return(c);
346 return(d1->p - d2->p);
347 }
348
349
350 double
351 doambient( /* compute ambient component */
352 COLOR rcol,
353 RAY *r,
354 double wt,
355 FVECT pg,
356 FVECT dg
357 )
358 {
359 double b, d=0;
360 AMBHEMI hemi;
361 AMBSAMP *div;
362 AMBSAMP dnew;
363 double acol[3];
364 AMBSAMP *dp;
365 double arad;
366 int divcnt;
367 int i, j;
368 /* initialize hemisphere */
369 inithemi(&hemi, rcol, r, wt);
370 divcnt = hemi.nt * hemi.np;
371 /* initialize */
372 if (pg != NULL)
373 pg[0] = pg[1] = pg[2] = 0.0;
374 if (dg != NULL)
375 dg[0] = dg[1] = dg[2] = 0.0;
376 setcolor(rcol, 0.0, 0.0, 0.0);
377 if (divcnt == 0)
378 return(0.0);
379 /* allocate super-samples */
380 if (hemi.ns > 0 || pg != NULL || dg != NULL) {
381 div = (AMBSAMP *)malloc(divcnt*sizeof(AMBSAMP));
382 if (div == NULL)
383 error(SYSTEM, "out of memory in doambient");
384 } else
385 div = NULL;
386 /* sample the divisions */
387 arad = 0.0;
388 acol[0] = acol[1] = acol[2] = 0.0;
389 if ((dp = div) == NULL)
390 dp = &dnew;
391 divcnt = 0;
392 for (i = 0; i < hemi.nt; i++)
393 for (j = 0; j < hemi.np; j++) {
394 dp->t = i; dp->p = j;
395 setcolor(dp->v, 0.0, 0.0, 0.0);
396 dp->r = 0.0;
397 dp->n = 0;
398 if (divsample(dp, &hemi, r) < 0) {
399 if (div != NULL)
400 dp++;
401 continue;
402 }
403 arad += dp->r;
404 divcnt++;
405 if (div != NULL)
406 dp++;
407 else
408 addcolor(acol, dp->v);
409 }
410 if (!divcnt) {
411 if (div != NULL)
412 free((void *)div);
413 return(0.0); /* no samples taken */
414 }
415 if (divcnt < hemi.nt*hemi.np) {
416 pg = dg = NULL; /* incomplete sampling */
417 hemi.ns = 0;
418 } else if (arad > FTINY && divcnt/arad < minarad) {
419 hemi.ns = 0; /* close enough */
420 } else if (hemi.ns > 0) { /* else perform super-sampling? */
421 comperrs(div, &hemi); /* compute errors */
422 qsort(div, divcnt, sizeof(AMBSAMP), ambcmp); /* sort divs */
423 /* super-sample */
424 for (i = hemi.ns; i > 0; i--) {
425 dnew = *div;
426 if (divsample(&dnew, &hemi, r) < 0) {
427 dp++;
428 continue;
429 }
430 dp = div; /* reinsert */
431 j = divcnt < i ? divcnt : i;
432 while (--j > 0 && dnew.k < dp[1].k) {
433 *dp = *(dp+1);
434 dp++;
435 }
436 *dp = dnew;
437 }
438 if (pg != NULL || dg != NULL) /* restore order */
439 qsort(div, divcnt, sizeof(AMBSAMP), ambnorm);
440 }
441 /* compute returned values */
442 if (div != NULL) {
443 arad = 0.0; /* note: divcnt may be < nt*np */
444 for (i = hemi.nt*hemi.np, dp = div; i-- > 0; dp++) {
445 arad += dp->r;
446 if (dp->n > 1) {
447 b = 1.0/dp->n;
448 scalecolor(dp->v, b);
449 dp->r *= b;
450 dp->n = 1;
451 }
452 addcolor(acol, dp->v);
453 }
454 b = bright(acol);
455 if (b > FTINY) {
456 b = 1.0/b; /* compute & normalize gradient(s) */
457 if (pg != NULL) {
458 posgradient(pg, div, &hemi);
459 for (i = 0; i < 3; i++)
460 pg[i] *= b;
461 }
462 if (dg != NULL) {
463 dirgradient(dg, div, &hemi);
464 for (i = 0; i < 3; i++)
465 dg[i] *= b;
466 }
467 }
468 free((void *)div);
469 }
470 copycolor(rcol, acol);
471 if (arad <= FTINY)
472 arad = maxarad;
473 else
474 arad = (divcnt+hemi.ns)/arad;
475 if (pg != NULL) { /* reduce radius if gradient large */
476 d = DOT(pg,pg);
477 if (d*arad*arad > 1.0)
478 arad = 1.0/sqrt(d);
479 }
480 if (arad < minarad) {
481 arad = minarad;
482 if (pg != NULL && d*arad*arad > 1.0) { /* cap gradient */
483 d = 1.0/arad/sqrt(d);
484 for (i = 0; i < 3; i++)
485 pg[i] *= d;
486 }
487 }
488 if ((arad /= sqrt(wt)) > maxarad)
489 arad = maxarad;
490 return(arad);
491 }
492
493
494 void
495 comperrs( /* compute initial error estimates */
496 AMBSAMP *da, /* assumes standard ordering */
497 AMBHEMI *hp
498 )
499 {
500 double b, b2;
501 int i, j;
502 AMBSAMP *dp;
503 /* sum differences from neighbors */
504 dp = da;
505 for (i = 0; i < hp->nt; i++)
506 for (j = 0; j < hp->np; j++) {
507 #ifdef DEBUG
508 if (dp->t != i || dp->p != j)
509 error(CONSISTENCY,
510 "division order in comperrs");
511 #endif
512 b = bright(dp[0].v);
513 if (i > 0) { /* from above */
514 b2 = bright(dp[-hp->np].v) - b;
515 b2 *= b2 * 0.25;
516 dp[0].k += b2;
517 dp[-hp->np].k += b2;
518 }
519 if (j > 0) { /* from behind */
520 b2 = bright(dp[-1].v) - b;
521 b2 *= b2 * 0.25;
522 dp[0].k += b2;
523 dp[-1].k += b2;
524 } else { /* around */
525 b2 = bright(dp[hp->np-1].v) - b;
526 b2 *= b2 * 0.25;
527 dp[0].k += b2;
528 dp[hp->np-1].k += b2;
529 }
530 dp++;
531 }
532 /* divide by number of neighbors */
533 dp = da;
534 for (j = 0; j < hp->np; j++) /* top row */
535 (dp++)->k *= 1.0/3.0;
536 if (hp->nt < 2)
537 return;
538 for (i = 1; i < hp->nt-1; i++) /* central region */
539 for (j = 0; j < hp->np; j++)
540 (dp++)->k *= 0.25;
541 for (j = 0; j < hp->np; j++) /* bottom row */
542 (dp++)->k *= 1.0/3.0;
543 }
544
545
546 void
547 posgradient( /* compute position gradient */
548 FVECT gv,
549 AMBSAMP *da, /* assumes standard ordering */
550 AMBHEMI *hp
551 )
552 {
553 int i, j;
554 double nextsine, lastsine, b, d;
555 double mag0, mag1;
556 double phi, cosp, sinp, xd, yd;
557 AMBSAMP *dp;
558
559 xd = yd = 0.0;
560 for (j = 0; j < hp->np; j++) {
561 dp = da + j;
562 mag0 = mag1 = 0.0;
563 lastsine = 0.0;
564 for (i = 0; i < hp->nt; i++) {
565 #ifdef DEBUG
566 if (dp->t != i || dp->p != j)
567 error(CONSISTENCY,
568 "division order in posgradient");
569 #endif
570 b = bright(dp->v);
571 if (i > 0) {
572 d = dp[-hp->np].r;
573 if (dp[0].r > d) d = dp[0].r;
574 /* sin(t)*cos(t)^2 */
575 d *= lastsine * (1.0 - (double)i/hp->nt);
576 mag0 += d*(b - bright(dp[-hp->np].v));
577 }
578 nextsine = sqrt((double)(i+1)/hp->nt);
579 if (j > 0) {
580 d = dp[-1].r;
581 if (dp[0].r > d) d = dp[0].r;
582 mag1 += d * (nextsine - lastsine) *
583 (b - bright(dp[-1].v));
584 } else {
585 d = dp[hp->np-1].r;
586 if (dp[0].r > d) d = dp[0].r;
587 mag1 += d * (nextsine - lastsine) *
588 (b - bright(dp[hp->np-1].v));
589 }
590 dp += hp->np;
591 lastsine = nextsine;
592 }
593 mag0 *= 2.0*PI / hp->np;
594 phi = 2.0*PI * (double)j/hp->np;
595 cosp = tcos(phi); sinp = tsin(phi);
596 xd += mag0*cosp - mag1*sinp;
597 yd += mag0*sinp + mag1*cosp;
598 }
599 for (i = 0; i < 3; i++)
600 gv[i] = (xd*hp->ux[i] + yd*hp->uy[i])*(hp->nt*hp->np)/PI;
601 }
602
603
604 void
605 dirgradient( /* compute direction gradient */
606 FVECT gv,
607 AMBSAMP *da, /* assumes standard ordering */
608 AMBHEMI *hp
609 )
610 {
611 int i, j;
612 double mag;
613 double phi, xd, yd;
614 AMBSAMP *dp;
615
616 xd = yd = 0.0;
617 for (j = 0; j < hp->np; j++) {
618 dp = da + j;
619 mag = 0.0;
620 for (i = 0; i < hp->nt; i++) {
621 #ifdef DEBUG
622 if (dp->t != i || dp->p != j)
623 error(CONSISTENCY,
624 "division order in dirgradient");
625 #endif
626 /* tan(t) */
627 mag += bright(dp->v)/sqrt(hp->nt/(i+.5) - 1.0);
628 dp += hp->np;
629 }
630 phi = 2.0*PI * (j+.5)/hp->np + PI/2.0;
631 xd += mag * tcos(phi);
632 yd += mag * tsin(phi);
633 }
634 for (i = 0; i < 3; i++)
635 gv[i] = xd*hp->ux[i] + yd*hp->uy[i];
636 }
637
638 #endif /* ! NEWAMB */
