root/radiance/ray/src/rt/aed.c
Revision: 1.1
Committed: Thu Feb 2 10:41:16 1989 UTC (35 years, 3 months ago) by greg
1 /* Copyright (c) 1987 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * aed.c - driver for AED 512 terminal.
9 *
10 * 2/2/87
11 */
12
13 #include <stdio.h>
14
15 #include "driver.h"
16
17 #include "color.h"
18
19
20 /* AED command characters */
21
22 #define AEDFMT "1888N" /* Format string to send to AED */
23 #define CSTAT 0100 /* Console status: lower case */
24 #define SCT 75 /* Set color lookup table */
25 #define SEC 67 /* Set color for vector drawing */
26 #define MOV 81 /* Set CAP (current access pointer) to x, y */
27 #define OPT 40 /* Miscellaneous terminal control */
28 #define SEN 71 /* Set encoding types */
29 #define RST 48 /* Reset terminal */
30 #define FFD 12 /* Clear screen */
31 #define EJC 85 /* Enable Joystick cursor positioning */
32 #define DJC 100 /* Disable Joystick cursor positioning */
33 #define SCC 99 /* Set Cursor Colors */
34 #define SCP 93 /* Set Cursor Parameters */
35 #define DFR 111 /* Draw Filled Rectangle */
36 #define RCP 106 /* Read Cursor Position */
37 #define ESC 27 /* Escape starts a command sequence */
38 #define SCS 96 /* Set Console Status */
39 #define END 1 /* Ctrl-A used to terminate command mode */
40
41 #define BLK 0 /* color table entry for black */
42 #define WHT 7 /* color table entry for white */
43
44 #define command(c) (putc(ESC, stdout), putc(c, stdout))
45 #define byte(b) putc(b, stdout)
46 #define string(s) fputs(s, stdout)
47 #define flush() fflush(stdout)
48
49 #define GAMMA 2.0 /* exponent for color correction */
50
51 #define MINCOLOR 8 /* start of device color table */
52
53 #define NCOLORS 241 /* our color table size (prime) */
54
55 #define hashcolr(c) ((67*(c)[RED]+59*(c)[GRN]+71*(c)[BLU])%NCOLORS)
56
57 #define NCOLS 512 /* maximum # columns for output */
58 #define NROWS 512-COMHT /* maximum # rows for output */
59 #define COMHT 16 /* height of command line */
60 #define COMCW 63 /* maximum chars on command line */
61
62 static COLR colrmap[256]; /* our color map */
63
64 static COLR colrtbl[NCOLORS]; /* our color table */
65
66 static int colres = 64; /* color resolution */
67
68 int aed_close(), aed_clear(), aed_paintr(),
69 aed_getcur(), aed_comout(), aed_errout();
70
71 static struct driver aed_driver = {
72 aed_close, aed_clear, aed_paintr, aed_getcur,
73 aed_comout, NULL,
74 NCOLS, NROWS
75 };
76
77
78 struct driver *
79 aed_init(name) /* open AED */
80 char *name;
81 {
82 if (ttyset(&aed_driver, fileno(stdin)) < 0) { /* set tty driver */
83 stderr_v("cannot access terminal\n");
84 return(NULL);
85 }
86 command(RST); /* reset AED */
87 longwait(2);
88 command(OPT);
89 byte(6); byte(1); /* AED command set */
90 command(SEN);
91 string(AEDFMT);
92 command(SCS); /* set console status */
93 byte(CSTAT);
94 command(SCC); /* set cursor type */
95 byte(BLK); byte(WHT); byte(15);
96 command(SCP);
97 byte('+'); byte(0); byte(1);
98 errvec = aed_errout; /* set error vector */
99 cmdvec = aed_errout;
100 if (wrnvec != NULL)
101 wrnvec = aed_errout;
102 return(&aed_driver);
103 }
104
105
106 static
107 aed_close() /* close AED */
108 {
109 errvec = stderr_v; /* reset error vector */
110 cmdvec = NULL;
111 if (wrnvec != NULL)
112 wrnvec = stderr_v;
113 aedsetcap(0, 0); /* go to bottom */
114 command(SEC);
115 byte(WHT); /* white text */
116 byte(END);
117 byte('\n'); /* scroll */
118 flush();
119 ttydone();
120 }
121
122
123 static
124 aed_clear(x, y) /* clear AED */
125 int x, y;
126 {
127 command(FFD);
128 flush();
129 makemap(); /* init color map */
130 }
131
132
133 static
134 aed_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */
135 COLOR col;
136 int xmin, ymin, xmax, ymax;
137 {
138 int ndx;
139
140 if ((ndx = colindex(col)) < 0) { /* full table? */
141 colres >>= 1;
142 redraw();
143 return;
144 }
145 command(SEC); /* draw rectangle */
146 byte(ndx+MINCOLOR);
147 aedsetcap(xmin, ymin+COMHT);
148 command(DFR);
149 aedcoord(xmax-1, ymax+(-1+COMHT));
150 flush();
151 }
152
153
154 static int
155 aed_getcur(xp, yp) /* get cursor position */
156 int *xp, *yp;
157 {
158 int com;
159
160 command(EJC); /* enable cursor */
161 com = getch(); /* get key */
162 command(DJC); /* disable cursor */
163 aedgetcap(xp, yp); /* get cursor position */
164 *yp -= COMHT; /* convert coordinates */
165 return(com); /* return key hit */
166 }
167
168
169 static
170 aed_comout(out) /* output to command line */
171 register char *out;
172 {
173 static int newl = 1;
174 static int inmsg = 0;
175
176 while (*out) {
177 if (newl) { /* new line */
178 command(SEC);
179 byte(BLK);
180 aedsetcap(0, 0);
181 command(DFR);
182 aedcoord(NCOLS-1, COMHT-1);
183 aedsetcap(1, 4);
184 command(SEC); /* white text */
185 byte(WHT);
186 byte(END);
187 newl = 0;
188 }
189 switch (*out) {
190 case '\n': /* end of line */
191 newl = 1;
192 /* fall through */
193 case '\r':
194 inmsg = 0;
195 byte('\r');
196 break;
197 case '\b': /* back space */
198 if (inmsg > 0 && --inmsg < COMCW)
199 byte('\b');
200 break;
201 default: /* character */
202 if (inmsg++ < COMCW)
203 byte(*out);
204 break;
205 }
206 out++;
207 }
208 flush();
209 }
210
211
212 static
213 aed_errout(msg) /* print an error message */
214 char *msg;
215 {
216 aed_comout(msg);
217 if (*msg && msg[strlen(msg)-1] == '\n')
218 longwait(2);
219 }
220
221
222 /*
223 * aedsetcap - sets AED's current access pointer to (x, y).
224 */
225
226 static
227 aedsetcap(x, y)
228 register int x, y;
229 {
230 command(MOV);
231 aedcoord(x, y);
232 }
233
234 /*
235 * aedcoord - puts out an (x, y) coordinate in AED 8 bit format.
236 */
237
238 static
239 aedcoord(x, y)
240 register int x, y;
241 {
242 byte(((x >> 4) & 0x30) | ((y >> 8) & 0x3));
243 byte(x & 0xff);
244 byte(y & 0xff);
245 }
246
247
248 static
249 aedgetcap(xp, yp) /* get cursor postion */
250 int *xp, *yp;
251 {
252 register int c;
253 /* get cursor postition */
254 command(RCP);
255 flush();
256 c = getch();
257 *xp = (c & 0x30) << 4;
258 *yp = (c & 0x3) << 8;
259 *xp |= getch();
260 *yp |= getch();
261 }
262
263
264 static int
265 colindex(col) /* return table index for color */
266 COLOR col;
267 {
268 static COLR clr;
269 int hval;
270 register int ndx, i;
271
272 mapcolor(clr, col);
273
274 hval = ndx = hashcolr(clr);
275
276 for (i = 1; i < NCOLORS; i++) {
277 if (colrtbl[ndx][EXP] == 0) {
278 colrtbl[ndx][RED] = clr[RED];
279 colrtbl[ndx][GRN] = clr[GRN];
280 colrtbl[ndx][BLU] = clr[BLU];
281 colrtbl[ndx][EXP] = COLXS;
282 newcolr(ndx, clr);
283 return(ndx);
284 }
285 if ( colrtbl[ndx][RED] == clr[RED] &&
286 colrtbl[ndx][GRN] == clr[GRN] &&
287 colrtbl[ndx][BLU] == clr[BLU] )
288 return(ndx);
289 ndx = (hval + i*i) % NCOLORS;
290 }
291 return(-1);
292 }
293
294
295 static
296 newcolr(index, clr) /* enter a color into our table */
297 int index;
298 COLR clr;
299 {
300 command(SCT);
301 byte(index+MINCOLOR);
302 byte(1);
303 byte(clr[RED]);
304 byte(clr[GRN]);
305 byte(clr[BLU]);
306 flush();
307 }
308
309
310 static
311 mapcolor(clr, col) /* map to our color space */
312 COLR clr;
313 COLOR col;
314 {
315 register int i, p;
316 /* compute color table value */
317 for (i = 0; i < 3; i++) {
318 p = colval(col,i) * 256.0;
319 if (p < 0) p = 0;
320 else if (p >= 256) p = 255;
321 clr[i] = colrmap[p][i];
322 }
323 clr[EXP] = COLXS;
324 }
325
326
327 static
328 makemap() /* initialize the color map */
329 {
330 double pow();
331 int val;
332 register int i;
333
334 for (i = 0; i < 256; i++) {
335 val = pow(i/256.0, 1.0/GAMMA) * colres;
336 val = (val*256 + 128) / colres;
337 colrmap[i][RED] = colrmap[i][GRN] = colrmap[i][BLU] = val;
338 colrmap[i][EXP] = COLXS;
339 }
340 for (i = 0; i < NCOLORS; i++)
341 colrtbl[i][EXP] = 0;
342 }
343
344
345 static
346 longwait(t) /* longer wait */
347 int t;
348 {
349 flush();
350 sleep(t);
351 }
