root/Development/ray/src/rt/aed.c
Revision: 2.6
Committed: Tue Mar 30 16:13:00 2004 UTC (21 years, 9 months ago) by schorsch
CVS Tags: rad3R6P1, rad3R6
Changes since 2.5: +8 -7 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 2.6 static const char RCSid[] = "$Id: aed.c,v 2.5 2003/08/20 10:00:09 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * aed.c - driver for AED 512 terminal.
6 greg 2.3 */
7
8 greg 2.4 #include "copyright.h"
9 greg 1.1
10     #include <stdio.h>
11
12 schorsch 2.5 #include "rterror.h"
13     #include "color.h"
14 greg 1.1 #include "driver.h"
15
16
17     /* AED command characters */
18
19     #define AEDFMT "1888N" /* Format string to send to AED */
20     #define CSTAT 0100 /* Console status: lower case */
21     #define SCT 75 /* Set color lookup table */
22     #define SEC 67 /* Set color for vector drawing */
23     #define MOV 81 /* Set CAP (current access pointer) to x, y */
24     #define OPT 40 /* Miscellaneous terminal control */
25     #define SEN 71 /* Set encoding types */
26     #define RST 48 /* Reset terminal */
27     #define FFD 12 /* Clear screen */
28     #define EJC 85 /* Enable Joystick cursor positioning */
29     #define DJC 100 /* Disable Joystick cursor positioning */
30     #define SCC 99 /* Set Cursor Colors */
31     #define SCP 93 /* Set Cursor Parameters */
32     #define DFR 111 /* Draw Filled Rectangle */
33     #define RCP 106 /* Read Cursor Position */
34     #define ESC 27 /* Escape starts a command sequence */
35     #define SCS 96 /* Set Console Status */
36     #define END 1 /* Ctrl-A used to terminate command mode */
37
38     #define BLK 0 /* color table entry for black */
39     #define WHT 7 /* color table entry for white */
40
41     #define command(c) (putc(ESC, stdout), putc(c, stdout))
42     #define byte(b) putc(b, stdout)
43     #define string(s) fputs(s, stdout)
44     #define flush() fflush(stdout)
45
46 greg 1.3 #define GAMMA 2.5 /* exponent for color correction */
47 greg 1.1
48 greg 1.3 #define NCOLORS 248 /* our color table size */
49 greg 1.2 #define MINPIX 8 /* minimum hardware color */
50 greg 1.1
51     #define NCOLS 512 /* maximum # columns for output */
52 greg 1.6 #define NROWS 483-COMHT /* maximum # rows for output */
53 greg 1.1 #define COMHT 16 /* height of command line */
54     #define COMCW 63 /* maximum chars on command line */
55
56 schorsch 2.5 static void aed_errout(char*);
57     static void longwait(int t);
58     static void aedgetcap(int *xp, int *yp);
59     static void aedsetcap(int x, int y);
60 schorsch 2.6 static dr_newcolrf_t anewcolr;
61 schorsch 2.5 static void aedcoord(int x, int y);
62 schorsch 2.6
63     static dr_closef_t aed_close;
64     static dr_clearf_t aed_clear;
65     static dr_paintrf_t aed_paintr;
66     static dr_getcurf_t aed_getcur;
67     static dr_comoutf_t comout;
68 greg 1.1
69     static struct driver aed_driver = {
70     aed_close, aed_clear, aed_paintr, aed_getcur,
71 greg 1.7 aed_comout, NULL, NULL,
72 greg 1.6 1.0, NCOLS, NROWS
73 greg 1.1 };
74
75
76     struct driver *
77 greg 1.5 aed_init(name, id) /* open AED */
78     char *name, *id;
79 greg 1.1 {
80     if (ttyset(&aed_driver, fileno(stdin)) < 0) { /* set tty driver */
81 gregl 2.2 eputs("cannot access terminal\n");
82 greg 1.1 return(NULL);
83     }
84     command(RST); /* reset AED */
85     longwait(2);
86     command(OPT);
87     byte(6); byte(1); /* AED command set */
88     command(SEN);
89     string(AEDFMT);
90     command(SCS); /* set console status */
91     byte(CSTAT);
92     command(SCC); /* set cursor type */
93     byte(BLK); byte(WHT); byte(15);
94     command(SCP);
95     byte('+'); byte(0); byte(1);
96 greg 1.4 make_gmap(GAMMA); /* make color map */
97 gregl 2.2 erract[USER].pf = /* set error vector */
98     erract[SYSTEM].pf =
99     erract[INTERNAL].pf =
100     erract[CONSISTENCY].pf = aed_errout;
101     erract[COMMAND].pf = aed_errout;
102     if (erract[WARNING].pf != NULL)
103     erract[WARNING].pf = aed_errout;
104 greg 1.1 return(&aed_driver);
105     }
106
107
108 schorsch 2.5 static void
109     aed_close(void) /* close AED */
110 greg 1.1 {
111 gregl 2.2 erract[USER].pf = /* reset error vector */
112     erract[SYSTEM].pf =
113     erract[INTERNAL].pf =
114     erract[CONSISTENCY].pf = eputs;
115     erract[COMMAND].pf = NULL;
116     if (erract[WARNING].pf != NULL)
117     erract[WARNING].pf = wputs;
118 greg 1.1 aedsetcap(0, 0); /* go to bottom */
119     command(SEC);
120     byte(WHT); /* white text */
121     byte(END);
122     byte('\n'); /* scroll */
123     flush();
124     ttydone();
125     }
126
127
128     static
129     aed_clear(x, y) /* clear AED */
130     int x, y;
131     {
132     command(FFD);
133 greg 1.4 new_ctab(NCOLORS); /* init color table */
134 greg 1.3 flush();
135 greg 1.1 }
136
137
138 schorsch 2.5 static void
139 greg 1.1 aed_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */
140     COLOR col;
141     int xmin, ymin, xmax, ymax;
142     {
143 greg 1.3 int ndx;
144
145 greg 1.4 ndx = get_pixel(col, anewcolr); /* calls anewcolr() */
146 greg 1.3 command(SEC); /* draw rectangle */
147     byte(ndx+MINPIX);
148 greg 1.1 aedsetcap(xmin, ymin+COMHT);
149     command(DFR);
150     aedcoord(xmax-1, ymax+(-1+COMHT));
151     flush();
152     }
153
154
155     static int
156     aed_getcur(xp, yp) /* get cursor position */
157     int *xp, *yp;
158     {
159     int com;
160
161     command(EJC); /* enable cursor */
162     com = getch(); /* get key */
163     command(DJC); /* disable cursor */
164     aedgetcap(xp, yp); /* get cursor position */
165     *yp -= COMHT; /* convert coordinates */
166     return(com); /* return key hit */
167     }
168
169
170 schorsch 2.5 static void
171 greg 1.1 aed_comout(out) /* output to command line */
172     register char *out;
173     {
174     static int newl = 1;
175     static int inmsg = 0;
176
177     while (*out) {
178     if (newl) { /* new line */
179     command(SEC);
180     byte(BLK);
181     aedsetcap(0, 0);
182     command(DFR);
183     aedcoord(NCOLS-1, COMHT-1);
184     aedsetcap(1, 4);
185     command(SEC); /* white text */
186     byte(WHT);
187     byte(END);
188     newl = 0;
189     }
190     switch (*out) {
191     case '\n': /* end of line */
192     newl = 1;
193     /* fall through */
194     case '\r':
195     inmsg = 0;
196     byte('\r');
197     break;
198     case '\b': /* back space */
199     if (inmsg > 0 && --inmsg < COMCW)
200     byte('\b');
201     break;
202     default: /* character */
203     if (inmsg++ < COMCW)
204     byte(*out);
205     break;
206     }
207     out++;
208     }
209     flush();
210     }
211
212
213 schorsch 2.5 static void
214 greg 1.1 aed_errout(msg) /* print an error message */
215     char *msg;
216     {
217     aed_comout(msg);
218     if (*msg && msg[strlen(msg)-1] == '\n')
219     longwait(2);
220     }
221
222
223     /*
224     * aedsetcap - sets AED's current access pointer to (x, y).
225     */
226
227 schorsch 2.5 static void
228 greg 1.1 aedsetcap(x, y)
229     register int x, y;
230     {
231     command(MOV);
232     aedcoord(x, y);
233     }
234
235     /*
236     * aedcoord - puts out an (x, y) coordinate in AED 8 bit format.
237     */
238
239 schorsch 2.5 static void
240 greg 1.1 aedcoord(x, y)
241     register int x, y;
242     {
243     byte(((x >> 4) & 0x30) | ((y >> 8) & 0x3));
244     byte(x & 0xff);
245     byte(y & 0xff);
246     }
247
248
249 schorsch 2.5 static void
250 greg 1.1 aedgetcap(xp, yp) /* get cursor postion */
251     int *xp, *yp;
252     {
253     register int c;
254     /* get cursor postition */
255     command(RCP);
256     flush();
257     c = getch();
258     *xp = (c & 0x30) << 4;
259     *yp = (c & 0x3) << 8;
260     *xp |= getch();
261     *yp |= getch();
262     }
263
264
265 schorsch 2.5 static void
266 greg 1.3 anewcolr(index, r, g, b) /* enter a color into our table */
267     int index;
268     int r, g, b;
269 greg 1.1 {
270 greg 1.3 command(SCT);
271     byte((index+MINPIX)&255);
272     byte(1);
273     byte(r);
274     byte(g);
275     byte(b);
276     flush();
277 greg 1.1 }
278
279
280 schorsch 2.5 static void
281 greg 1.1 longwait(t) /* longer wait */
282     int t;
283     {
284     flush();
285     sleep(t);
286     }
