root/radiance/ray/src/rt/aed.c
Revision: 1.5
Committed: Wed Oct 25 15:37:14 1989 UTC (35 years, 8 months ago) by greg
1 /* Copyright (c) 1987 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * aed.c - driver for AED 512 terminal.
9 *
10 * 2/2/87
11 */
12
13 #include <stdio.h>
14
15 #include "driver.h"
16
17 #include "color.h"
18
19
20 /* AED command characters */
21
22 #define AEDFMT "1888N" /* Format string to send to AED */
23 #define CSTAT 0100 /* Console status: lower case */
24 #define SCT 75 /* Set color lookup table */
25 #define SEC 67 /* Set color for vector drawing */
26 #define MOV 81 /* Set CAP (current access pointer) to x, y */
27 #define OPT 40 /* Miscellaneous terminal control */
28 #define SEN 71 /* Set encoding types */
29 #define RST 48 /* Reset terminal */
30 #define FFD 12 /* Clear screen */
31 #define EJC 85 /* Enable Joystick cursor positioning */
32 #define DJC 100 /* Disable Joystick cursor positioning */
33 #define SCC 99 /* Set Cursor Colors */
34 #define SCP 93 /* Set Cursor Parameters */
35 #define DFR 111 /* Draw Filled Rectangle */
36 #define RCP 106 /* Read Cursor Position */
37 #define ESC 27 /* Escape starts a command sequence */
38 #define SCS 96 /* Set Console Status */
39 #define END 1 /* Ctrl-A used to terminate command mode */
40
41 #define BLK 0 /* color table entry for black */
42 #define WHT 7 /* color table entry for white */
43
44 #define command(c) (putc(ESC, stdout), putc(c, stdout))
45 #define byte(b) putc(b, stdout)
46 #define string(s) fputs(s, stdout)
47 #define flush() fflush(stdout)
48
49 #define GAMMA 2.5 /* exponent for color correction */
50
51 #define NCOLORS 248 /* our color table size */
52 #define MINPIX 8 /* minimum hardware color */
53
54 #define NCOLS 512 /* maximum # columns for output */
55 #define NROWS 512-COMHT /* maximum # rows for output */
56 #define COMHT 16 /* height of command line */
57 #define COMCW 63 /* maximum chars on command line */
58
59 int aed_close(), aed_clear(), aed_paintr(),
60 aed_getcur(), aed_comout(), aed_errout();
61
62 static struct driver aed_driver = {
63 aed_close, aed_clear, aed_paintr, aed_getcur,
64 aed_comout, NULL,
65 NCOLS, NROWS
66 };
67
68
69 struct driver *
70 aed_init(name, id) /* open AED */
71 char *name, *id;
72 {
73 if (ttyset(&aed_driver, fileno(stdin)) < 0) { /* set tty driver */
74 stderr_v("cannot access terminal\n");
75 return(NULL);
76 }
77 command(RST); /* reset AED */
78 longwait(2);
79 command(OPT);
80 byte(6); byte(1); /* AED command set */
81 command(SEN);
82 string(AEDFMT);
83 command(SCS); /* set console status */
84 byte(CSTAT);
85 command(SCC); /* set cursor type */
86 byte(BLK); byte(WHT); byte(15);
87 command(SCP);
88 byte('+'); byte(0); byte(1);
89 make_gmap(GAMMA); /* make color map */
90 errvec = aed_errout; /* set error vector */
91 cmdvec = aed_errout;
92 if (wrnvec != NULL)
93 wrnvec = aed_errout;
94 return(&aed_driver);
95 }
96
97
98 static
99 aed_close() /* close AED */
100 {
101 errvec = stderr_v; /* reset error vector */
102 cmdvec = NULL;
103 if (wrnvec != NULL)
104 wrnvec = stderr_v;
105 aedsetcap(0, 0); /* go to bottom */
106 command(SEC);
107 byte(WHT); /* white text */
108 byte(END);
109 byte('\n'); /* scroll */
110 flush();
111 ttydone();
112 }
113
114
115 static
116 aed_clear(x, y) /* clear AED */
117 int x, y;
118 {
119 command(FFD);
120 new_ctab(NCOLORS); /* init color table */
121 flush();
122 }
123
124
125 static
126 aed_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */
127 COLOR col;
128 int xmin, ymin, xmax, ymax;
129 {
130 extern int anewcolr();
131 int ndx;
132
133 ndx = get_pixel(col, anewcolr); /* calls anewcolr() */
134 command(SEC); /* draw rectangle */
135 byte(ndx+MINPIX);
136 aedsetcap(xmin, ymin+COMHT);
137 command(DFR);
138 aedcoord(xmax-1, ymax+(-1+COMHT));
139 flush();
140 }
141
142
143 static int
144 aed_getcur(xp, yp) /* get cursor position */
145 int *xp, *yp;
146 {
147 int com;
148
149 command(EJC); /* enable cursor */
150 com = getch(); /* get key */
151 command(DJC); /* disable cursor */
152 aedgetcap(xp, yp); /* get cursor position */
153 *yp -= COMHT; /* convert coordinates */
154 return(com); /* return key hit */
155 }
156
157
158 static
159 aed_comout(out) /* output to command line */
160 register char *out;
161 {
162 static int newl = 1;
163 static int inmsg = 0;
164
165 while (*out) {
166 if (newl) { /* new line */
167 command(SEC);
168 byte(BLK);
169 aedsetcap(0, 0);
170 command(DFR);
171 aedcoord(NCOLS-1, COMHT-1);
172 aedsetcap(1, 4);
173 command(SEC); /* white text */
174 byte(WHT);
175 byte(END);
176 newl = 0;
177 }
178 switch (*out) {
179 case '\n': /* end of line */
180 newl = 1;
181 /* fall through */
182 case '\r':
183 inmsg = 0;
184 byte('\r');
185 break;
186 case '\b': /* back space */
187 if (inmsg > 0 && --inmsg < COMCW)
188 byte('\b');
189 break;
190 default: /* character */
191 if (inmsg++ < COMCW)
192 byte(*out);
193 break;
194 }
195 out++;
196 }
197 flush();
198 }
199
200
201 static
202 aed_errout(msg) /* print an error message */
203 char *msg;
204 {
205 aed_comout(msg);
206 if (*msg && msg[strlen(msg)-1] == '\n')
207 longwait(2);
208 }
209
210
211 /*
212 * aedsetcap - sets AED's current access pointer to (x, y).
213 */
214
215 static
216 aedsetcap(x, y)
217 register int x, y;
218 {
219 command(MOV);
220 aedcoord(x, y);
221 }
222
223 /*
224 * aedcoord - puts out an (x, y) coordinate in AED 8 bit format.
225 */
226
227 static
228 aedcoord(x, y)
229 register int x, y;
230 {
231 byte(((x >> 4) & 0x30) | ((y >> 8) & 0x3));
232 byte(x & 0xff);
233 byte(y & 0xff);
234 }
235
236
237 static
238 aedgetcap(xp, yp) /* get cursor postion */
239 int *xp, *yp;
240 {
241 register int c;
242 /* get cursor postition */
243 command(RCP);
244 flush();
245 c = getch();
246 *xp = (c & 0x30) << 4;
247 *yp = (c & 0x3) << 8;
248 *xp |= getch();
249 *yp |= getch();
250 }
251
252
253 static
254 anewcolr(index, r, g, b) /* enter a color into our table */
255 int index;
256 int r, g, b;
257 {
258 command(SCT);
259 byte((index+MINPIX)&255);
260 byte(1);
261 byte(r);
262 byte(g);
263 byte(b);
264 flush();
265 }
266
267
268 static
269 longwait(t) /* longer wait */
270 int t;
271 {
272 flush();
273 sleep(t);
274 }
